[U-Boot] Removing the need for boards.cfg
At present, as a work-around, we generate boards.cfg if needed. This is quite a slow process since each board config must be fully processed.
What can we do to improve this? We only need a small number of options in order to start buildman - things like CONFIG_SYS_ARCH, CONFIG_SYS_CPU, etc.
I wonder if we could run a script which adds these to the defconfigs for each board and then apply a patch to mainline? Would that require removing the options from the config.h files? Or could we do that later as a separate step?
Hi.
We cannot add CONFIG_SYS_ARCH, CONFIG_SYS_CPU, etc. to defconfigs because they are not user-editable options. (They must be always selected in correct combination.)
This is already discussed when I posted the RFC version of the Kconfig series.
We can easily do
[1] Choose boards by arch
Just grep CONFIG_ARM=y, CONFIG_MIPS=y, CONFIG_SANDBOX=y in defconfigs
[2] Choose boards by board name
It is the file name of defconfigs
My question is, do we really need to choose by CPU, Vendor, SoC ? I know they are useful. For ex. nvidia developers probably want to build only Tegra boards.
One possible idea I come up with is to have 'board group' in .buildman file so people can build only boards they are interested in.
Something like this:
---------->8---------------
[board-alisa] tegra20: harmony seaboard ventana tegra30: beaver tegra114: dalmore tegra124: venice2 tegra: tegra20 tegra30 tegra114 tegra124
-----------8<---------------
With the settings above,
"tools/buildman/buildman tegra20" is the same as "tools/buildman/buildman harmony seaboard ventana"
"tools/buildman/buildman tegra" is the same as "tools/buildman/buildman tegra20 tegra30 tegra114 tegra124" and also the same as "tools/buildman/buildman harmony seaboard ventana beaver dalmore venice2"
We have to setup ~/.buildman at the first run. (and modify it when adding new boards)
Better to provide a tool to auto-generate .buildman file?
Best Regards Masahiro Yamada
On Fri, Aug 01, 2014 at 09:22:42PM +0900, Masahiro Yamada wrote:
Hi.
We can easily do
For me, I don't see CPU or Vendor as super important but SoC is. I'll often be doing some TI work for say am335x or am43xx and be checking over those two board configs but once I'm done (or nearing done) I need to build for SoC==am33xx to catch all of the other vendors that have boards in the family.
Simon, Tom,
Hi.
We can easily do
If MAKEALL/buildman is invoked without any arguments (which means build all the board), boards.cfg is not necessary in the first place.
It that case, can we skip generating boards.cfg ? (We can get the board list by 'ls configs' )
We need a database only when we want to select boards by CPU, Vendor, SoC.
Dear Masahiro,
This would neither give all build target names no=r do the needed translation of names (like upper case -> lower case translations), etc.
On 1 August 2014 12:31, Wolfgang Denk wd@denx.de wrote:
Dear Masahiro,
Skipping in an optimised case doesn't buy us much. I normally want to build 'sandbox' at least before I go ahead and build everything.
I suppose what I'm asking is whether there is a fast way for buildman to detect all these fields without having to run 'make xxx_defconfig' on every board. For example, a simple read and scan of a few config files, or worse case a C preprocessor run?
Dear Masahiro,
What is the best way to replace "./MAKEALL -a powerpc" or "./MAKEALL -a arm"? You must have verified compiling for all targets. I am wondering if you can share your setup. I still heavily rely on MAKEALL to build all targets I care.
York
Hi York,
Dear Masahiro,
York
I think "./MAKEALL -a powerpc" or "./MAKEALL -a arm" is still working as it was.
Isn't it on your machine?
It is. But it just takes long to generate boards.cfg. I am wondering if you have a better way.
York
________________________________ From: Masahiro Yamada Sent: Mon, 04/08/2014 18:22 To: Sun York-R58495 yorksun@freescale.com CC: Tom Rini trini@ti.com; Simon Glass sjg@chromium.org; U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [U-Boot] Removing the need for boards.cfg
Hi York,
Dear Masahiro,
York
On 08/04/2014 06:22 PM, Masahiro Yamada wrote:
Hi York,
Dear Masahiro,
York
Dear Masahiro,
Generating boards.cfg gives me another trouble. I use Jenkins (http://jenkins-ci.org/) for internal development. Even I can manually run MAKEALL to generate boards.cfg, the same script under Jenkins cannot. I have this error
./MAKEALL -c mpc83xx -c mpc85xx -c mpc86xx Could not find boards.cfg Generating boards.cfg ... (jobs: 8) Traceback (most recent call last): File "tools/genboardscfg.py", line 504, in <module> main() File "tools/genboardscfg.py", line 501, in main gen_boards_cfg(jobs) File "tools/genboardscfg.py", line 471, in gen_boards_cfg __gen_boards_cfg(jobs) File "tools/genboardscfg.py", line 437, in __gen_boards_cfg indicator = Indicator(len(defconfigs)) File "tools/genboardscfg.py", line 384, in __init__ width = get_terminal_columns() File "tools/genboardscfg.py", line 59, in get_terminal_columns ret = fcntl.ioctl(sys.stdout.fileno(), termios.TIOCGWINSZ, arg) IOError: [Errno 22] Invalid argument Failed to generate boards.cfg
Looks like the script is trying to get the terminal window size. There is no terminal for my case. Checking variable TERM, it is "dumb". I can make it work by removing the two lines but I don't think that's the solution.
--- a/tools/genboardscfg.py +++ b/tools/genboardscfg.py @@ -58,8 +58,6 @@ def get_terminal_columns(): try: ret = fcntl.ioctl(sys.stdout.fileno(), termios.TIOCGWINSZ, arg) except IOError as exception: - if exception.errno != errno.ENOTTY: - raise
I am not an expert on python. Can you take a deep look? The host has ubuntu 12.04.3 with python 2.7.3.
York
Hello York,
Hi York,
Dear Masahiro,
York
Dear Masahiro,
raise
I can't parse the python either, but is this not the same issue? (just from the looks of it) https://patchwork.ozlabs.org/patch/377897/
Regards, Jeroen
It is the same solution/workaround, but I'm not sure if Roger has the same issue.
York
Hi Masahiro,
On 1 August 2014 06:22, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi.
My understanding is that if you have a 'select' option in Kconfig then it will be selected always, but it will still appear in the defconfig. I think that is the way the kernel works. So there are options that cannot be changed, and don't appear in the menu, but they are selected just the same.
We can easily do
OK.
Almost, as Wolfgang points out.
That doesn't sound very different to having a boards.cfg file again. If we really need it, it seems better to me to have an auto-generated boards.cfg which is checked into the source tree, at least for now. When people add boards they can re-run the generation script.
But I'd like to avoid that if possible, so will await your thoughts on the above Kconfig question.
On Fri, Aug 08, 2014 at 05:06:03AM -0600, Simon Glass wrote:
Hi Masahiro,
Hi.
Maybe we came up with the wrong answer during RFC on Kconfig then. It's good if selecting say CONFIG_TARGET_AM335X_EVM results in CONFIG_SYS_ARCH="arm", CONFIG_SYS_CPU="armv7", etc.
I _think_ the problem here is what I ran into with doing CONS_INDEX patches. You cannot do 'select SYS_CPU="armv7"'. So we would instead need to get rid of CONFIG_SYS_CPU and instead do CONFIG_SYS_CPU_ARMV7, etc, etc.
Hi Tom,
Hi Masahiro,
Hi.
-- Tom
Hi Tom,
Hi Masahiro,
Hi.
Well I think we should run this one to ground first - if a 'select' item doesn't appear in Kconfig then I think we have a bit of a problem. Will await Masahiro's thoughts.
On Sun, Aug 10, 2014 at 08:16:43PM -0600, Simon Glass wrote:
Hi Tom,
Hi Masahiro,
Hi.
It's not that we can't select, it's: board/ti/am335x/Kconfig:27:warning: 'CONS_INDEX' has wrong type. 'select' only accept arguments of boolean and tristate type
So we'd have to modify Kconfig to accept int/hex/string as well so we could do: config SYS_CPU default "armv7" if SOCA || SOCB || ... default "ppc4xx' if SOCC || SOCD || ..
And that also seems like a conflict-generating nightmare down the line too.
+Masahiro
Hi Tom,
Hi Tom,
Hi Masahiro,
Hi.
We currently have this in the Kconfig for snow:
if TARGET_SNOW
config SYS_CPU string default "armv7"
config SYS_BOARD string default "smdk5250"
config SYS_VENDOR string default "samsung"
config SYS_SOC string default "exynos"
config SYS_CONFIG_NAME string default "snow"
endif
so now I'm wondering why we can't just pick this up somehow. Sure we might need to read all the Kconfig files (using the library you mentioned) but then we could perhaps very quickly work out the CPU, BOARD, etc. based on the target name. It makes me wonder if genboardscfg.py could be a lot more efficient?
I wonder (and I haven't had my coffee nor dug into this much more yet) about using say https://github.com/ulfalizer/Kconfiglib to have buildman parse all configs/ and then use that information to build what's been asked (depending on how long the reading+parsing takes). If it's relatively quick, that would be a big argument in favour of dropping MAKEALL.
Hi Tom,
Well I've had my wine but it seems to parse the Kconfig files rather than the #includes that are part of U-Boot's system. Unless I'm missing something, we would still need to find out things like the CPU type, even with that tool.
On Sun, Aug 10, 2014 at 08:22:35PM -0600, Simon Glass wrote:
Hi Tom,
Well, my thought was: foreach Kconfig file, read to build state machine foreach defconfig, evaluate config, spl/config, tpl/config, store object
Now we can poke those objects for everything with CONFIG_SYS_CPU whatever, and so forth. Or maybe that all takes longer than what we do today.
participants (6)
Jeroen Hofstee
Masahiro Yamada
York Sun
