[PATCH] lx2160a: Add the serdes configurtion details for QDS
Add 8_10_0 and 21_2_0 seredes protocol for QDS Add 10_12_3 seredes protocol for QDS Add the IOSLOT and the mezzanine card mapping against each serdes protocol.
Signed-off-by: Vikas Singh vikas.singh@nxp.com --- board/freescale/lx2160a/eth_lx2160aqds.c | 84 +++++++++++++++++++++++++++++++- 1 file changed, 83 insertions(+), 1 deletion(-)
diff --git a/board/freescale/lx2160a/eth_lx2160aqds.c b/board/freescale/lx2160a/eth_lx2160aqds.c index 55e8a42..741cca7 100644 --- a/board/freescale/lx2160a/eth_lx2160aqds.c +++ b/board/freescale/lx2160a/eth_lx2160aqds.c @@ -75,6 +75,29 @@ struct serdes_phy_config { * This table has limited serdes protocol entries. It can be expanded as per * requirement. */ +/***************************************************************** + | SERDES_1 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 3 | IO_SLOT_1 | M11-USXGMII | + | 7 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_2 | M4-PCIE-SGMII | + | 8 | IO_SLOT_1 | M12-XFI | + | 10 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_2 | M12-XFI | + | 13 | IO_SLOT_1 | M8-100G | + | | IO_SLOT_2 | M8-100G | + | 14 | IO_SLOT_1 | M8-100G | + | 15 | IO_SLOT_1 | M13-25G | + | 17 | IO_SLOT_1 | M13-25G | + | 19 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_2 | M7-40G | + | | IO_SLOT_6 | M13-25G | + | 20 | IO_SLOT_1 | M7-40G | + | | IO_SLOT_2 | M7-40G | + | 21 | IO_SLOT_1 | M13-25G | + | | IO_SLOT_2 | M13-25G | + ***************************************************************** + */ static const struct serdes_phy_config serdes1_phy_config[] = { {3, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, EMI1, IO_SLOT_1}, @@ -101,6 +124,12 @@ static const struct serdes_phy_config serdes1_phy_config[] = { {WRIOP1_DPMAC10, {SGMII_CARD_PORT4_PHY_ADDR, -1}, EMI1, IO_SLOT_2} } }, {8, {} }, + {10, {{WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {AQ_PHY_ADDR3, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {AQ_PHY_ADDR4, -1}, + EMI1, IO_SLOT_1} } }, {13, {{WRIOP1_DPMAC1, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, EMI1, IO_SLOT_1}, {WRIOP1_DPMAC2, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, @@ -132,13 +161,49 @@ static const struct serdes_phy_config serdes1_phy_config[] = { {20, {{WRIOP1_DPMAC1, {CORTINA_PHY_ADDR1, -1}, EMI1, IO_SLOT_1}, {WRIOP1_DPMAC2, {CORTINA_PHY_ADDR1, -1}, - EMI1, IO_SLOT_2} } } + EMI1, IO_SLOT_2} } }, + {21, {{WRIOP1_DPMAC3, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC9, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_2}, + {WRIOP1_DPMAC10, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_2} } } };
+/***************************************************************** + | SERDES_2 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 3 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 5 | IO_SLOT_7 | M4-PCIE-SGMII | + | 10 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 11 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 12 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + ***************************************************************** + */ static const struct serdes_phy_config serdes2_phy_config[] = { {2, {} }, {3, {} }, {5, {} }, + {10, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } }, {11, {{WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, EMI1, IO_SLOT_7}, {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, @@ -151,8 +216,25 @@ static const struct serdes_phy_config serdes2_phy_config[] = { EMI1, IO_SLOT_8}, {WRIOP1_DPMAC14, {SGMII_CARD_PORT4_PHY_ADDR, -1}, EMI1, IO_SLOT_8} } }, + {12, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } } };
+/***************************************************************** + | SERDES_3 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_5 | M4-PCIE-SGMII | + | | IO_SLOT_6 | M4-PCIE-SGMII | + | 3 | IO_SLOT_5 | M4-PCIE-SGMII | + | | IO_SLOT_6 | M4-PCIE-SGMII | + ***************************************************************** + */ static const struct serdes_phy_config serdes3_phy_config[] = { {2, {} }, {3, {} }
Vikas Singh
