[U-Boot] [PATCH] powerpc/85xx: Update P2020DS default env settings
Read MAC address from EEPROM. Add hwconfig settings.
Modified the default othbootargs to include the cache-sram-size parameter. This parameter is needed as the L2 as SRAM is ON by default in the P2020RDB kernel and used by the Gianfar driver.
Also cleanup some of the boot commands.
Signed-off-by: Li Yang leoli@freescale.com Signed-off-by: Zhao Chenhui b35336@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/P2020DS.h | 22 ++++++++++++---------- 1 files changed, 12 insertions(+), 10 deletions(-)
diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index b32a997..6ec71c7 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -651,13 +651,8 @@ /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:02:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:02:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:02:02:FD -#define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:02:03:FD #endif
#define CONFIG_IPADDR 192.168.1.254 @@ -680,8 +675,8 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_EXTRA_ENV_SETTINGS \ - "perf_mode=stable\0" \ - "memctl_intlv_ctl=2\0" \ + "perf_mode=performance\0" \ + "hwconfig=fsl_ddr:ctlr_intlv=bank,bank_intlv=cs0_cs1\0" \ "netdev=eth0\0" \ "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ @@ -690,18 +685,25 @@ "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "satabootcmd=setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" \ "consoledev=ttyS0\0" \ "ramdiskaddr=2000000\0" \ "ramdiskfile=p2020ds/ramdisk.uboot\0" \ "fdtaddr=c00000\0" \ + "othbootargs=cache-sram-size=0x10000\0" \ "fdtfile=p2020ds/p2020ds.dtb\0" \ - "bdev=sda3\0" + "bdev=sda3\0" \ + "partition=scsi 0:0\0"
#define CONFIG_HDBOOT \ "setenv bootargs root=/dev/$bdev rw " \ "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ + "ext2load $partition $loadaddr $bootfile;" \ + "ext2load $partition $fdtaddr $fdtfile;" \ "bootm $loadaddr - $fdtaddr"
#define CONFIG_NFSBOOTCOMMAND \
applied to 85xx next
- k
Kumar Gala
