[U-Boot] [PATCH] imx: add support for i.MX7/i.MX8MQ reset controller
Add support for the reset controller that's used on the i.MX7D and i.MX8MQ. This will be needed to be able to assert the PCIe reset pins. Bindings taken from Linux, driver implementation mostly taken from Linux and adjusted to U-Boot infrastructure.
Signed-off-by: Patrick Wildt patrick@blueri.se
diff --git a/arch/arm/dts/fsl-imx8mq.dtsi b/arch/arm/dts/fsl-imx8mq.dtsi index 814a1b7df4..52a76b4ba4 100644 --- a/arch/arm/dts/fsl-imx8mq.dtsi +++ b/arch/arm/dts/fsl-imx8mq.dtsi @@ -19,6 +19,7 @@ #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/pins-imx8mq.h> +#include <dt-bindings/reset/imx8mq-reset.h> #include <dt-bindings/thermal/thermal.h>
/ { @@ -269,6 +270,12 @@ #clock-cells = <1>; };
+ src: reset-controller@30390000 { + compatible = "fsl,imx8mq-src", "syscon"; + reg = <0x0 0x30390000 0x0 0x10000>; + #reset-cells = <1>; + }; + gpc: gpc@303a0000 { compatible = "fsl,imx8mq-gpc", "fsl,imx7d-gpc", "syscon"; reg = <0x0 0x303a0000 0x0 0x10000>; diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index e45731edda..c0e5860e85 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -38,4 +38,5 @@ CONFIG_PINCTRL_IMX8M=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y CONFIG_DM_THERMAL=y diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 6ec6f39c85..976f3a701c 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -127,4 +127,11 @@ config RESET_HISILICON help Support for reset controller on HiSilicon SoCs.
+config RESET_IMX7 + bool "i.MX7/8 Reset Driver" + depends on DM_RESET && (ARCH_MX7 || ARCH_IMX8M) + default y + help + Support for reset controller on i.MX7/8 SoCs. + endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 7fec75bb49..f5875fce09 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -20,3 +20,4 @@ obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o obj-$(CONFIG_RESET_MEDIATEK) += reset-mediatek.o obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o obj-$(CONFIG_RESET_HISILICON) += reset-hisilicon.o +obj-$(CONFIG_RESET_IMX7) += reset-imx7.o diff --git a/drivers/reset/reset-imx7.c b/drivers/reset/reset-imx7.c new file mode 100644 index 0000000000..f2ca5cf801 --- /dev/null +++ b/drivers/reset/reset-imx7.c @@ -0,0 +1,312 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2017, Impinj, Inc. + */ + +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <dt-bindings/reset/imx7-reset.h> +#include <dt-bindings/reset/imx8mq-reset.h> +#include <reset-uclass.h> + +struct imx7_reset_priv { + void __iomem *base; + struct reset_ops ops; +}; + +struct imx7_src_signal { + unsigned int offset, bit; +}; + +enum imx7_src_registers { + SRC_A7RCR0 = 0x0004, + SRC_M4RCR = 0x000c, + SRC_ERCR = 0x0014, + SRC_HSICPHY_RCR = 0x001c, + SRC_USBOPHY1_RCR = 0x0020, + SRC_USBOPHY2_RCR = 0x0024, + SRC_MIPIPHY_RCR = 0x0028, + SRC_PCIEPHY_RCR = 0x002c, + SRC_DDRC_RCR = 0x1000, +}; + +static const struct imx7_src_signal imx7_src_signals[IMX7_RESET_NUM] = { + [IMX7_RESET_A7_CORE_POR_RESET0] = { SRC_A7RCR0, BIT(0) }, + [IMX7_RESET_A7_CORE_POR_RESET1] = { SRC_A7RCR0, BIT(1) }, + [IMX7_RESET_A7_CORE_RESET0] = { SRC_A7RCR0, BIT(4) }, + [IMX7_RESET_A7_CORE_RESET1] = { SRC_A7RCR0, BIT(5) }, + [IMX7_RESET_A7_DBG_RESET0] = { SRC_A7RCR0, BIT(8) }, + [IMX7_RESET_A7_DBG_RESET1] = { SRC_A7RCR0, BIT(9) }, + [IMX7_RESET_A7_ETM_RESET0] = { SRC_A7RCR0, BIT(12) }, + [IMX7_RESET_A7_ETM_RESET1] = { SRC_A7RCR0, BIT(13) }, + [IMX7_RESET_A7_SOC_DBG_RESET] = { SRC_A7RCR0, BIT(20) }, + [IMX7_RESET_A7_L2RESET] = { SRC_A7RCR0, BIT(21) }, + [IMX7_RESET_SW_M4C_RST] = { SRC_M4RCR, BIT(1) }, + [IMX7_RESET_SW_M4P_RST] = { SRC_M4RCR, BIT(2) }, + [IMX7_RESET_EIM_RST] = { SRC_ERCR, BIT(0) }, + [IMX7_RESET_HSICPHY_PORT_RST] = { SRC_HSICPHY_RCR, BIT(1) }, + [IMX7_RESET_USBPHY1_POR] = { SRC_USBOPHY1_RCR, BIT(0) }, + [IMX7_RESET_USBPHY1_PORT_RST] = { SRC_USBOPHY1_RCR, BIT(1) }, + [IMX7_RESET_USBPHY2_POR] = { SRC_USBOPHY2_RCR, BIT(0) }, + [IMX7_RESET_USBPHY2_PORT_RST] = { SRC_USBOPHY2_RCR, BIT(1) }, + [IMX7_RESET_MIPI_PHY_MRST] = { SRC_MIPIPHY_RCR, BIT(1) }, + [IMX7_RESET_MIPI_PHY_SRST] = { SRC_MIPIPHY_RCR, BIT(2) }, + [IMX7_RESET_PCIEPHY] = { SRC_PCIEPHY_RCR, BIT(2) | BIT(1) }, + [IMX7_RESET_PCIEPHY_PERST] = { SRC_PCIEPHY_RCR, BIT(3) }, + [IMX7_RESET_PCIE_CTRL_APPS_EN] = { SRC_PCIEPHY_RCR, BIT(6) }, + [IMX7_RESET_PCIE_CTRL_APPS_TURNOFF] = { SRC_PCIEPHY_RCR, BIT(11) }, + [IMX7_RESET_DDRC_PRST] = { SRC_DDRC_RCR, BIT(0) }, + [IMX7_RESET_DDRC_CORE_RST] = { SRC_DDRC_RCR, BIT(1) }, +}; + +static int imx7_reset_deassert_imx7(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx7_src_signals; + u32 val; + + if (rst->id >= IMX7_RESET_NUM) + return -EINVAL; + + if (rst->id == IMX7_RESET_PCIEPHY) { + /* + * wait for more than 10us to release phy g_rst and + * btnrst + */ + udelay(10); + } + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX7_RESET_PCIE_CTRL_APPS_EN: + val |= sig[rst->id].bit; + break; + default: + val &= ~sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +static int imx7_reset_assert_imx7(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx7_src_signals; + u32 val; + + if (rst->id >= IMX7_RESET_NUM) + return -EINVAL; + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX7_RESET_PCIE_CTRL_APPS_EN: + val &= ~sig[rst->id].bit; + break; + default: + val |= sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +enum imx8mq_src_registers { + SRC_A53RCR0 = 0x0004, + SRC_HDMI_RCR = 0x0030, + SRC_DISP_RCR = 0x0034, + SRC_GPU_RCR = 0x0040, + SRC_VPU_RCR = 0x0044, + SRC_PCIE2_RCR = 0x0048, + SRC_MIPIPHY1_RCR = 0x004c, + SRC_MIPIPHY2_RCR = 0x0050, + SRC_DDRC2_RCR = 0x1004, +}; + +static const struct imx7_src_signal imx8mq_src_signals[IMX8MQ_RESET_NUM] = { + [IMX8MQ_RESET_A53_CORE_POR_RESET0] = { SRC_A53RCR0, BIT(0) }, + [IMX8MQ_RESET_A53_CORE_POR_RESET1] = { SRC_A53RCR0, BIT(1) }, + [IMX8MQ_RESET_A53_CORE_POR_RESET2] = { SRC_A53RCR0, BIT(2) }, + [IMX8MQ_RESET_A53_CORE_POR_RESET3] = { SRC_A53RCR0, BIT(3) }, + [IMX8MQ_RESET_A53_CORE_RESET0] = { SRC_A53RCR0, BIT(4) }, + [IMX8MQ_RESET_A53_CORE_RESET1] = { SRC_A53RCR0, BIT(5) }, + [IMX8MQ_RESET_A53_CORE_RESET2] = { SRC_A53RCR0, BIT(6) }, + [IMX8MQ_RESET_A53_CORE_RESET3] = { SRC_A53RCR0, BIT(7) }, + [IMX8MQ_RESET_A53_DBG_RESET0] = { SRC_A53RCR0, BIT(8) }, + [IMX8MQ_RESET_A53_DBG_RESET1] = { SRC_A53RCR0, BIT(9) }, + [IMX8MQ_RESET_A53_DBG_RESET2] = { SRC_A53RCR0, BIT(10) }, + [IMX8MQ_RESET_A53_DBG_RESET3] = { SRC_A53RCR0, BIT(11) }, + [IMX8MQ_RESET_A53_ETM_RESET0] = { SRC_A53RCR0, BIT(12) }, + [IMX8MQ_RESET_A53_ETM_RESET1] = { SRC_A53RCR0, BIT(13) }, + [IMX8MQ_RESET_A53_ETM_RESET2] = { SRC_A53RCR0, BIT(14) }, + [IMX8MQ_RESET_A53_ETM_RESET3] = { SRC_A53RCR0, BIT(15) }, + [IMX8MQ_RESET_A53_SOC_DBG_RESET] = { SRC_A53RCR0, BIT(20) }, + [IMX8MQ_RESET_A53_L2RESET] = { SRC_A53RCR0, BIT(21) }, + [IMX8MQ_RESET_SW_NON_SCLR_M4C_RST] = { SRC_M4RCR, BIT(0) }, + [IMX8MQ_RESET_OTG1_PHY_RESET] = { SRC_USBOPHY1_RCR, BIT(0) }, + [IMX8MQ_RESET_OTG2_PHY_RESET] = { SRC_USBOPHY2_RCR, BIT(0) }, + [IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N] = { SRC_MIPIPHY_RCR, BIT(1) }, + [IMX8MQ_RESET_MIPI_DSI_RESET_N] = { SRC_MIPIPHY_RCR, BIT(2) }, + [IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N] = { SRC_MIPIPHY_RCR, BIT(3) }, + [IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N] = { SRC_MIPIPHY_RCR, BIT(4) }, + [IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N] = { SRC_MIPIPHY_RCR, BIT(5) }, + [IMX8MQ_RESET_PCIEPHY] = { SRC_PCIEPHY_RCR, + BIT(2) | BIT(1) }, + [IMX8MQ_RESET_PCIEPHY_PERST] = { SRC_PCIEPHY_RCR, BIT(3) }, + [IMX8MQ_RESET_PCIE_CTRL_APPS_EN] = { SRC_PCIEPHY_RCR, BIT(6) }, + [IMX8MQ_RESET_PCIE_CTRL_APPS_TURNOFF] = { SRC_PCIEPHY_RCR, BIT(11) }, + [IMX8MQ_RESET_HDMI_PHY_APB_RESET] = { SRC_HDMI_RCR, BIT(0) }, + [IMX8MQ_RESET_DISP_RESET] = { SRC_DISP_RCR, BIT(0) }, + [IMX8MQ_RESET_GPU_RESET] = { SRC_GPU_RCR, BIT(0) }, + [IMX8MQ_RESET_VPU_RESET] = { SRC_VPU_RCR, BIT(0) }, + [IMX8MQ_RESET_PCIEPHY2] = { SRC_PCIE2_RCR, + BIT(2) | BIT(1) }, + [IMX8MQ_RESET_PCIEPHY2_PERST] = { SRC_PCIE2_RCR, BIT(3) }, + [IMX8MQ_RESET_PCIE2_CTRL_APPS_EN] = { SRC_PCIE2_RCR, BIT(6) }, + [IMX8MQ_RESET_PCIE2_CTRL_APPS_TURNOFF] = { SRC_PCIE2_RCR, BIT(11) }, + [IMX8MQ_RESET_MIPI_CSI1_CORE_RESET] = { SRC_MIPIPHY1_RCR, BIT(0) }, + [IMX8MQ_RESET_MIPI_CSI1_PHY_REF_RESET] = { SRC_MIPIPHY1_RCR, BIT(1) }, + [IMX8MQ_RESET_MIPI_CSI1_ESC_RESET] = { SRC_MIPIPHY1_RCR, BIT(2) }, + [IMX8MQ_RESET_MIPI_CSI2_CORE_RESET] = { SRC_MIPIPHY2_RCR, BIT(0) }, + [IMX8MQ_RESET_MIPI_CSI2_PHY_REF_RESET] = { SRC_MIPIPHY2_RCR, BIT(1) }, + [IMX8MQ_RESET_MIPI_CSI2_ESC_RESET] = { SRC_MIPIPHY2_RCR, BIT(2) }, + [IMX8MQ_RESET_DDRC1_PRST] = { SRC_DDRC_RCR, BIT(0) }, + [IMX8MQ_RESET_DDRC1_CORE_RESET] = { SRC_DDRC_RCR, BIT(1) }, + [IMX8MQ_RESET_DDRC1_PHY_RESET] = { SRC_DDRC_RCR, BIT(2) }, + [IMX8MQ_RESET_DDRC2_PHY_RESET] = { SRC_DDRC2_RCR, BIT(0) }, + [IMX8MQ_RESET_DDRC2_CORE_RESET] = { SRC_DDRC2_RCR, BIT(1) }, + [IMX8MQ_RESET_DDRC2_PRST] = { SRC_DDRC2_RCR, BIT(2) }, +}; + +static int imx7_reset_deassert_imx8mq(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mq_src_signals; + u32 val; + + if (rst->id >= IMX8MQ_RESET_NUM) + return -EINVAL; + + if (rst->id == IMX8MQ_RESET_PCIEPHY || + rst->id == IMX8MQ_RESET_PCIEPHY2) { + /* + * wait for more than 10us to release phy g_rst and + * btnrst + */ + udelay(10); + } + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MQ_RESET_PCIE_CTRL_APPS_EN: + case IMX8MQ_RESET_PCIE2_CTRL_APPS_EN: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N: /* fallthrough */ + val |= sig[rst->id].bit; + break; + default: + val &= ~sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +static int imx7_reset_assert_imx8mq(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mq_src_signals; + u32 val; + + if (rst->id >= IMX8MQ_RESET_NUM) + return -EINVAL; + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MQ_RESET_PCIE_CTRL_APPS_EN: + case IMX8MQ_RESET_PCIE2_CTRL_APPS_EN: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_RESET_N: /* fallthrough */ + case IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N: /* fallthrough */ + val &= ~sig[rst->id].bit; + break; + default: + val |= sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +static int imx7_reset_assert(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + return priv->ops.rst_assert(rst); +} + +static int imx7_reset_deassert(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + return priv->ops.rst_deassert(rst); +} + +static int imx7_reset_free(struct reset_ctl *rst) +{ + return 0; +} + +static int imx7_reset_request(struct reset_ctl *rst) +{ + return 0; +} + +static const struct reset_ops imx7_reset_reset_ops = { + .request = imx7_reset_request, + .free = imx7_reset_free, + .rst_assert = imx7_reset_assert, + .rst_deassert = imx7_reset_deassert, +}; + +static const struct udevice_id imx7_reset_ids[] = { + { .compatible = "fsl,imx7d-src" }, + { .compatible = "fsl,imx8mq-src" }, + { } +}; + +static int imx7_reset_probe(struct udevice *dev) +{ + struct imx7_reset_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr(dev); + if (!priv->base) + return -ENOMEM; + + if (device_is_compatible(dev, "fsl,imx8mq-src")) { + priv->ops.rst_assert = imx7_reset_assert_imx8mq; + priv->ops.rst_deassert = imx7_reset_deassert_imx8mq; + } else if (device_is_compatible(dev, "fsl,imx7d-src")) { + priv->ops.rst_assert = imx7_reset_assert_imx7; + priv->ops.rst_deassert = imx7_reset_deassert_imx7; + } + + return 0; +} + +U_BOOT_DRIVER(imx7_reset) = { + .name = "imx7_reset", + .id = UCLASS_RESET, + .of_match = imx7_reset_ids, + .ops = &imx7_reset_reset_ops, + .probe = imx7_reset_probe, + .priv_auto_alloc_size = sizeof(struct imx7_reset_priv), +}; diff --git a/include/dt-bindings/reset/imx7-reset.h b/include/dt-bindings/reset/imx7-reset.h new file mode 100644 index 0000000000..bb92452ffb --- /dev/null +++ b/include/dt-bindings/reset/imx7-reset.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (C) 2017 Impinj, Inc. + * + * Author: Andrey Smirnov andrew.smirnov@gmail.com + */ + +#ifndef DT_BINDING_RESET_IMX7_H +#define DT_BINDING_RESET_IMX7_H + +#define IMX7_RESET_A7_CORE_POR_RESET0 0 +#define IMX7_RESET_A7_CORE_POR_RESET1 1 +#define IMX7_RESET_A7_CORE_RESET0 2 +#define IMX7_RESET_A7_CORE_RESET1 3 +#define IMX7_RESET_A7_DBG_RESET0 4 +#define IMX7_RESET_A7_DBG_RESET1 5 +#define IMX7_RESET_A7_ETM_RESET0 6 +#define IMX7_RESET_A7_ETM_RESET1 7 +#define IMX7_RESET_A7_SOC_DBG_RESET 8 +#define IMX7_RESET_A7_L2RESET 9 +#define IMX7_RESET_SW_M4C_RST 10 +#define IMX7_RESET_SW_M4P_RST 11 +#define IMX7_RESET_EIM_RST 12 +#define IMX7_RESET_HSICPHY_PORT_RST 13 +#define IMX7_RESET_USBPHY1_POR 14 +#define IMX7_RESET_USBPHY1_PORT_RST 15 +#define IMX7_RESET_USBPHY2_POR 16 +#define IMX7_RESET_USBPHY2_PORT_RST 17 +#define IMX7_RESET_MIPI_PHY_MRST 18 +#define IMX7_RESET_MIPI_PHY_SRST 19 + +/* + * IMX7_RESET_PCIEPHY is a logical reset line combining PCIEPHY_BTN + * and PCIEPHY_G_RST + */ +#define IMX7_RESET_PCIEPHY 20 +#define IMX7_RESET_PCIEPHY_PERST 21 + +/* + * IMX7_RESET_PCIE_CTRL_APPS_EN is not strictly a reset line, but it + * can be used to inhibit PCIe LTTSM, so, in a way, it can be thoguht + * of as one + */ +#define IMX7_RESET_PCIE_CTRL_APPS_EN 22 +#define IMX7_RESET_DDRC_PRST 23 +#define IMX7_RESET_DDRC_CORE_RST 24 + +#define IMX7_RESET_PCIE_CTRL_APPS_TURNOFF 25 + +#define IMX7_RESET_NUM 26 + +#endif diff --git a/include/dt-bindings/reset/imx8mq-reset.h b/include/dt-bindings/reset/imx8mq-reset.h new file mode 100755 index 0000000000..9a301082d3 --- /dev/null +++ b/include/dt-bindings/reset/imx8mq-reset.h @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 Zodiac Inflight Innovations + * + * Author: Andrey Smirnov andrew.smirnov@gmail.com + */ + +#ifndef DT_BINDING_RESET_IMX8MQ_H +#define DT_BINDING_RESET_IMX8MQ_H + +#define IMX8MQ_RESET_A53_CORE_POR_RESET0 0 +#define IMX8MQ_RESET_A53_CORE_POR_RESET1 1 +#define IMX8MQ_RESET_A53_CORE_POR_RESET2 2 +#define IMX8MQ_RESET_A53_CORE_POR_RESET3 3 +#define IMX8MQ_RESET_A53_CORE_RESET0 4 +#define IMX8MQ_RESET_A53_CORE_RESET1 5 +#define IMX8MQ_RESET_A53_CORE_RESET2 6 +#define IMX8MQ_RESET_A53_CORE_RESET3 7 +#define IMX8MQ_RESET_A53_DBG_RESET0 8 +#define IMX8MQ_RESET_A53_DBG_RESET1 9 +#define IMX8MQ_RESET_A53_DBG_RESET2 10 +#define IMX8MQ_RESET_A53_DBG_RESET3 11 +#define IMX8MQ_RESET_A53_ETM_RESET0 12 +#define IMX8MQ_RESET_A53_ETM_RESET1 13 +#define IMX8MQ_RESET_A53_ETM_RESET2 14 +#define IMX8MQ_RESET_A53_ETM_RESET3 15 +#define IMX8MQ_RESET_A53_SOC_DBG_RESET 16 +#define IMX8MQ_RESET_A53_L2RESET 17 +#define IMX8MQ_RESET_SW_NON_SCLR_M4C_RST 18 +#define IMX8MQ_RESET_OTG1_PHY_RESET 19 +#define IMX8MQ_RESET_OTG2_PHY_RESET 20 +#define IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N 21 +#define IMX8MQ_RESET_MIPI_DSI_RESET_N 22 +#define IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N 23 +#define IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N 24 +#define IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N 25 +#define IMX8MQ_RESET_PCIEPHY 26 +#define IMX8MQ_RESET_PCIEPHY_PERST 27 +#define IMX8MQ_RESET_PCIE_CTRL_APPS_EN 28 +#define IMX8MQ_RESET_PCIE_CTRL_APPS_TURNOFF 29 +#define IMX8MQ_RESET_HDMI_PHY_APB_RESET 30 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_DISP_RESET 31 +#define IMX8MQ_RESET_GPU_RESET 32 +#define IMX8MQ_RESET_VPU_RESET 33 +#define IMX8MQ_RESET_PCIEPHY2 34 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_PCIEPHY2_PERST 35 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_PCIE2_CTRL_APPS_EN 36 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_PCIE2_CTRL_APPS_TURNOFF 37 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_CORE_RESET 38 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_PHY_REF_RESET 39 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_ESC_RESET 40 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_CORE_RESET 41 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_PHY_REF_RESET 42 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_ESC_RESET 43 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_DDRC1_PRST 44 +#define IMX8MQ_RESET_DDRC1_CORE_RESET 45 +#define IMX8MQ_RESET_DDRC1_PHY_RESET 46 +#define IMX8MQ_RESET_DDRC2_PRST 47 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_DDRC2_CORE_RESET 48 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_DDRC2_PHY_RESET 49 /* i.MX8MM does NOT support */ + +#define IMX8MQ_RESET_NUM 50 + +#endif
diff --git a/arch/arm/dts/fsl-imx8mq.dtsi b/arch/arm/dts/fsl-imx8mq.dtsi index c35c23e293..d843b401be 100644 --- a/arch/arm/dts/fsl-imx8mq.dtsi +++ b/arch/arm/dts/fsl-imx8mq.dtsi @@ -19,6 +19,7 @@ #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/pins-imx8mq.h> +#include <dt-bindings/reset/imx8mq-reset.h> #include <dt-bindings/thermal/thermal.h>
Hi Patrick,
This looks good to me, thanks.
Only suggestion I have is to split this work in three patches:
- One that introduces the reset controller driver - One for the dts part - Another one for the defconfig
Signed-off-by: Patrick Wildt patrick@blueri.se --- drivers/reset/Kconfig | 7 + drivers/reset/Makefile | 1 + drivers/reset/reset-imx7.c | 312 +++++++++++++++++++++++ include/dt-bindings/reset/imx7-reset.h | 52 ++++ include/dt-bindings/reset/imx8mq-reset.h | 64 +++++ 5 files changed, 436 insertions(+) create mode 100644 drivers/reset/reset-imx7.c create mode 100644 include/dt-bindings/reset/imx7-reset.h create mode 100755 include/dt-bindings/reset/imx8mq-reset.h
Hi Patrick,
Just a suggestion for future submissions: when submitting a new version, always describe what has changed.
Reviewed-by: Fabio Estevam festevam@gmail.com
This patch adds the reset controller node to the i.MX8MQ SoC device tree.
Signed-off-by: Patrick Wildt patrick@blueri.se --- arch/arm/dts/fsl-imx8mq.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
Hi Patrick,
#reset-cells = <1>;
This reset-controller node is already part of the upstream kernel imx8mq.dtsi.
What about syncing the U-Boot version with the one from kernel 5.3.2? Also, please note the dtsi name change.
Thanks
-- 2.23.0
On Fri, Oct 04, 2019 at 09:39:29AM -0300, Fabio Estevam wrote:
Hi Patrick,
#reset-cells = <1>;
Thanks
Hi Fabio,
yes, that's true. It does make sense to sync the device trees and do the name change. Can the diff with the reset controller driver (patch 1/3) be merged anyway, and I'll follow up with the DTS change? Would be easier for me to handle the number of patches to submit.
Thank you for the review!
Best regards, Patrick
-- 2.23.0
Hi Patrick,
I think so.
Stefano is the one who will apply your patch if he is happy with it.
Regards,
Fabio Estevam
Hi Fabio, Patrick,
On 04/10/19 17:52, Fabio Estevam wrote:
Hi Patrick,
I think so.
I agree with you, too. I merge patches into -next.
Regards, Stefano Babic
Regards,
Fabio Estevam
This patch makes sure that the reset controller driver is compiled for the i.MX8MQ EVK.
Signed-off-by: Patrick Wildt patrick@blueri.se --- configs/imx8mq_evk_defconfig | 1 + 1 file changed, 1 insertion(+)
Fabio Estevam
Patrick Wildt
Stefano Babic
