[PATCH v2] mmc: Add support for enumerating MMC card in a given mode using mmc command
Add support for enumerating MMC card in a given mode using mmc rescan and mmc dev commands. The speed mode is provided as the last argument in these commands and is indicated using the index from enum bus_mode in include/mmc.h. A speed mode can be set only if it has already been enabled in the device tree.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com ---
Changes since v1: - Removed #ifdef around the definition of user_speed_mode field - Replaced #if with if (IS_ENABLED()) - Removed repeated MMC_CAP(MMC_LEGACY) - initialized user_speed_mode to MMC_MODES_SPEED in mmc_init_device and mmc_dp_preinit - corrected curr_device to dev and included part check, the case when mode is provided in the argument
cmd/Kconfig | 10 ++++++ cmd/mmc.c | 75 +++++++++++++++++++++++++++++----------- doc/usage/mmc.rst | 49 ++++++++++++++++++++++++-- drivers/mmc/mmc-uclass.c | 5 ++- drivers/mmc/mmc.c | 22 +++++++++++- include/mmc.h | 2 ++ 6 files changed, 138 insertions(+), 25 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index ffef3cc76ca4..3a857b3f6e2e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2389,4 +2389,14 @@ config CMD_UBIFS help UBIFS is a file system for flash devices which works on top of UBI.
+config MMC_SPEED_MODE_SET + bool "set speed mode using mmc command" + depends on CMD_MMC + default n + help + Enable setting speed mode using mmc rescan and mmc dev commands. + The speed mode is provided as the last argument in these commands + and is indicated using the index from enum bus_mode in + include/mmc.h. A speed mode can be set only if it has already + been enabled in the device tree. endmenu diff --git a/cmd/mmc.c b/cmd/mmc.c index b942576b58ac..e256210a3705 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -120,7 +120,9 @@ static void print_mmcinfo(struct mmc *mmc) } } } -static struct mmc *init_mmc_device(int dev, bool force_init) + +static struct mmc *init_mmc_device(int dev, bool force_init, + enum bus_mode speed_mode) { struct mmc *mmc; mmc = find_mmc_device(dev); @@ -134,6 +136,10 @@ static struct mmc *init_mmc_device(int dev, bool force_init)
if (force_init) mmc->has_init = 0; + + if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET)) + mmc->user_speed_mode = speed_mode; + if (mmc_init(mmc)) return NULL;
@@ -159,7 +165,7 @@ static int do_mmcinfo(struct cmd_tbl *cmdtp, int flag, int argc, } }
- mmc = init_mmc_device(curr_device, false); + mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
@@ -293,7 +299,7 @@ static int do_mmcrpmb(struct cmd_tbl *cmdtp, int flag, if (flag == CMD_FLAG_REPEAT && !cmd_is_repeatable(cp)) return CMD_RET_SUCCESS;
@@ -338,7 +344,7 @@ static int do_mmc_read(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[2], NULL, 16); cnt = simple_strtoul(argv[3], NULL, 16);
@@ -387,7 +393,7 @@ static int do_mmc_sparse_write(struct cmd_tbl *cmdtp, int flag, return CMD_RET_FAILURE; }
@@ -431,7 +437,7 @@ static int do_mmc_write(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[2], NULL, 16); cnt = simple_strtoul(argv[3], NULL, 16);
@@ -460,7 +466,7 @@ static int do_mmc_erase(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[1], NULL, 16); cnt = simple_strtoul(argv[2], NULL, 16);
@@ -482,8 +488,19 @@ static int do_mmc_rescan(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct mmc *mmc; + enum bus_mode speed_mode = MMC_MODES_END; + + if (argc == 1) { + mmc = init_mmc_device(curr_device, true, MMC_MODES_END); + } else if (argc == 2) { + /* parse the mode */ + speed_mode = simple_strtoul(argv[1], NULL, 10); + /* Need to pass the the speed mode required too */ + mmc = init_mmc_device(curr_device, true, speed_mode); + } else { + return CMD_RET_USAGE; + }
- mmc = init_mmc_device(curr_device, true); if (!mmc) return CMD_RET_FAILURE;
@@ -496,7 +513,7 @@ static int do_mmc_part(struct cmd_tbl *cmdtp, int flag, struct blk_desc *mmc_dev; struct mmc *mmc;
@@ -515,11 +532,14 @@ static int do_mmc_dev(struct cmd_tbl *cmdtp, int flag, { int dev, part = 0, ret; struct mmc *mmc; + enum bus_mode speed_mode = MMC_MODES_END;
if (argc == 1) { dev = curr_device; + mmc = init_mmc_device(dev, true, MMC_MODES_END); } else if (argc == 2) { dev = simple_strtoul(argv[1], NULL, 10); + mmc = init_mmc_device(dev, true, MMC_MODES_END); } else if (argc == 3) { dev = (int)simple_strtoul(argv[1], NULL, 10); part = (int)simple_strtoul(argv[2], NULL, 10); @@ -528,11 +548,21 @@ static int do_mmc_dev(struct cmd_tbl *cmdtp, int flag, PART_ACCESS_MASK); return CMD_RET_FAILURE; } + mmc = init_mmc_device(dev, true, MMC_MODES_END); + } else if (argc == 4) { + dev = (int)simple_strtoul(argv[1], NULL, 10); + part = (int)simple_strtoul(argv[2], NULL, 10); + if (part > PART_ACCESS_MASK) { + printf("#part_num shouldn't be larger than %d\n", + PART_ACCESS_MASK); + return CMD_RET_FAILURE; + } + speed_mode = simple_strtoul(argv[3], NULL, 10); + mmc = init_mmc_device(dev, true, speed_mode); } else { return CMD_RET_USAGE; }
- mmc = init_mmc_device(dev, true); if (!mmc) return CMD_RET_FAILURE;
@@ -636,7 +666,7 @@ static int do_mmc_hwpartition(struct cmd_tbl *cmdtp, int flag, enum mmc_hwpart_conf_mode mode = MMC_HWPART_CONF_CHECK; int i, r, pidx;
@@ -726,7 +756,7 @@ static int do_mmc_bootbus(struct cmd_tbl *cmdtp, int flag, reset = simple_strtoul(argv[3], NULL, 10); mode = simple_strtoul(argv[4], NULL, 10);
- mmc = init_mmc_device(dev, false); + mmc = init_mmc_device(dev, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
@@ -789,7 +819,7 @@ static int do_mmc_boot_resize(struct cmd_tbl *cmdtp, int flag, bootsize = simple_strtoul(argv[2], NULL, 10); rpmbsize = simple_strtoul(argv[3], NULL, 10);
@@ -844,7 +874,7 @@ static int do_mmc_partconf(struct cmd_tbl *cmdtp, int flag,
@@ -887,7 +917,7 @@ static int do_mmc_rst_func(struct cmd_tbl *cmdtp, int flag, return CMD_RET_USAGE; }
@@ -939,7 +969,7 @@ static int do_mmc_bkops_enable(struct cmd_tbl *cmdtp, int flag,
@@ -958,7 +988,7 @@ static int do_mmc_boot_wp(struct cmd_tbl *cmdtp, int flag, int err; struct mmc *mmc;
- mmc = init_mmc_device(curr_device, false); + mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE; if (IS_SD(mmc)) { @@ -983,9 +1013,9 @@ static struct cmd_tbl cmd_mmc[] = { #if CONFIG_IS_ENABLED(CMD_MMC_SWRITE) U_BOOT_CMD_MKENT(swrite, 3, 0, do_mmc_sparse_write, "", ""), #endif - U_BOOT_CMD_MKENT(rescan, 1, 1, do_mmc_rescan, "", ""), + U_BOOT_CMD_MKENT(rescan, 2, 1, do_mmc_rescan, "", ""), U_BOOT_CMD_MKENT(part, 1, 1, do_mmc_part, "", ""), - U_BOOT_CMD_MKENT(dev, 3, 0, do_mmc_dev, "", ""), + U_BOOT_CMD_MKENT(dev, 4, 0, do_mmc_dev, "", ""), U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""), #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) U_BOOT_CMD_MKENT(hwpartition, 28, 0, do_mmc_hwpartition, "", ""), @@ -1042,9 +1072,12 @@ U_BOOT_CMD( "mmc swrite addr blk#\n" #endif "mmc erase blk# cnt\n" - "mmc rescan\n" + "mmc rescan [mode]\n" "mmc part - lists available partition on current mmc device\n" - "mmc dev [dev] [part] - show or set current mmc device [partition]\n" + "mmc dev [dev] [part] [mode] - show or set current mmc device [partition] and set mode\n" + " - the required speed mode is passed as the index from the following list\n" + " [MMC_LEGACY, MMC_HS, SD_HS, MMC_HS_52, MMC_DDR_52, UHS_SDR12, UHS_SDR25,\n" + " UHS_SDR50, UHS_DDR50, UHS_SDR104, MMC_HS_200, MMC_HS_400, MMC_HS_400_ES]\n" "mmc list - lists available devices\n" "mmc wp - power on write protect boot partitions\n" #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) diff --git a/doc/usage/mmc.rst b/doc/usage/mmc.rst index f20efe3d7063..d15b151884fd 100644 --- a/doc/usage/mmc.rst +++ b/doc/usage/mmc.rst @@ -12,9 +12,9 @@ Synopsis mmc read addr blk# cnt mmc write addr blk# cnt mmc erase blk# cnt - mmc rescan + mmc rescan [mode] mmc part - mmc dev [dev] [part] + mmc dev [dev] [part] [mode] mmc list mmc wp mmc bootbus <dev> <boot_bus_width> <reset_boot_bus_width> <boot_mode> @@ -49,6 +49,27 @@ The 'mmc erase' command erases *cnt* blocks on the MMC device starting at block
The 'mmc rescan' command scans the available MMC device.
+ mode + speed mode to set. + CONFIG_MMC_SPEED_MODE_SET should be enabled. The required speed mode is + passed as the index from the following list. + + 0 - MMC_LEGACY + 1 - MMC_HS + 2 - SD_HS + 3 - MMC_HS_52 + 4 - MMC_DDR_52 + 5 - UHS_SDR12 + 6 - UHS_SDR25 + 7 - UHS_SDR50 + 8 - UHS_DDR50 + 9 - UHS_SDR104 + 10 - MMC_HS_200 + 11 - MMC_HS_400 + 12 - MMC_HS_400_ES + + A speed mode can be set only if it has already been enabled in the device tree + The 'mmc part' command displays the list available partition on current mmc device.
The 'mmc dev' command shows or set current mmc device. @@ -58,6 +79,27 @@ The 'mmc dev' command shows or set current mmc device. part partition number to change
+ mode + speed mode to set. + CONFIG_MMC_SPEED_MODE_SET should be enabled. The required speed mode is + passed as the index from the following list. + + 0 - MMC_LEGACY + 1 - MMC_HS + 2 - SD_HS + 3 - MMC_HS_52 + 4 - MMC_DDR_52 + 5 - UHS_SDR12 + 6 - UHS_SDR25 + 7 - UHS_SDR50 + 8 - UHS_DDR50 + 9 - UHS_SDR104 + 10 - MMC_HS_200 + 11 - MMC_HS_400 + 12 - MMC_HS_400_ES + + A speed mode can be set only if it has already been enabled in the device tree + The 'mmc list' command displays the list available devices.
The 'mmc wp' command enables "power on write protect" function for boot partitions. @@ -194,6 +236,9 @@ The current device can be shown or set via 'mmc dev' command: => mmc dev 2 0 switch to partitions #0, OK mmc2 is current device + => mmc dev 0 1 4 + switch to partitions #1, OK + mmc0(part 1) is current device
The list of available devices can be shown via 'mmc list' command: :: diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 0e13238c7e7a..3ee92d03ca23 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -342,6 +342,9 @@ void mmc_do_preinit(void)
if (!m) continue; + + m->user_speed_mode = MMC_MODES_END; /* Initialising user set speed mode */ + if (m->preinit) mmc_start_init(m); } @@ -414,7 +417,7 @@ int mmc_bind(struct udevice *dev, struct mmc *mmc, const struct mmc_config *cfg) /* setup initial part type */ bdesc->part_type = cfg->part_type; mmc->dev = dev; - + mmc->user_speed_mode = MMC_MODES_END; return 0; }
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 8078a89f18cb..bd348974ae7d 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2862,7 +2862,25 @@ int mmc_start_init(struct mmc *mmc) * timings. */ mmc->host_caps = mmc->cfg->host_caps | MMC_CAP(MMC_LEGACY) | - MMC_CAP(MMC_LEGACY) | MMC_MODE_1BIT; + MMC_MODE_1BIT; + + if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET)) { + if (mmc->user_speed_mode != MMC_MODES_END) { + int i; + /* set host caps */ + if (mmc->host_caps & MMC_CAP(mmc->user_speed_mode)) { + /* Remove all existing speed capabilities */ + for (i = MMC_LEGACY; i < MMC_MODES_END; i++) + mmc->host_caps &= ~MMC_CAP(i); + mmc->host_caps |= (MMC_CAP(mmc->user_speed_mode) + | MMC_CAP(MMC_LEGACY) | + MMC_MODE_1BIT); + } else { + pr_err("bus_mode requested is not supported\n"); + return -EINVAL; + } + } + } #if CONFIG_IS_ENABLED(DM_MMC) mmc_deferred_probe(mmc); #endif @@ -3060,6 +3078,8 @@ int mmc_init_device(int num) }
m = mmc_get_mmc_dev(dev); + m->user_speed_mode = MMC_MODES_END; /* Initialising user set speed mode */ + if (!m) return 0; if (m->preinit) diff --git a/include/mmc.h b/include/mmc.h index 0bf19de20e52..d24cebbe4781 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -726,6 +726,8 @@ struct mmc { */ u32 quirks; u8 hs400_tuning; + + enum bus_mode user_speed_mode; /* intput speed mode from user */ };
Hi Aswath,
Changes since v1:
- bool "set speed mode using mmc command"
- depends on CMD_MMC
- default n
- help
how about using wrapper function?
static struct mmc *__init_mmc_device(int dev, bool force_init, enum bus_mode spped_mode) { ... }
static struct mmc *init_mmc_device(int dev, bool force_init) { return __init_mmc_device(dev, force_init, MMC_MODES_END); }
Then it doesn't need to touch all init_mmc_device caller. Just my opinion :)
Best Regards, Jaehoon Chung
- if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET))
- if (mmc_init(mmc)) return NULL;
- mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
- enum bus_mode speed_mode = MMC_MODES_END;
- if (argc == 1) {
- } else if (argc == 2) {
- } else {
- } else if (argc == 4) {
PART_ACCESS_MASK);
} else { return CMD_RET_USAGE; }mmc = init_mmc_device(dev, true, speed_mode);
- mmc = init_mmc_device(dev, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
- mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE; if (IS_SD(mmc)) {
- U_BOOT_CMD_MKENT(rescan, 2, 1, do_mmc_rescan, "", ""), U_BOOT_CMD_MKENT(part, 1, 1, do_mmc_part, "", ""),
- U_BOOT_CMD_MKENT(dev, 4, 0, do_mmc_dev, "", ""), U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""),
- "mmc rescan\n"
- "mmc rescan [mode]\n" "mmc part - lists available partition on current mmc device\n"
- "mmc dev [dev] [part] [mode] - show or set current mmc device [partition] and set mode\n"
- " - the required speed mode is passed as the index from the following list\n"
- " [MMC_LEGACY, MMC_HS, SD_HS, MMC_HS_52, MMC_DDR_52, UHS_SDR12, UHS_SDR25,\n"
- " UHS_SDR50, UHS_DDR50, UHS_SDR104, MMC_HS_200, MMC_HS_400, MMC_HS_400_ES]\n" "mmc list - lists available devices\n" "mmc wp - power on write protect boot partitions\n"
- mmc rescan
- mmc rescan [mode] mmc part
- mmc dev [dev] [part] [mode] mmc list mmc wp mmc bootbus <dev> <boot_bus_width> <reset_boot_bus_width> <boot_mode>
- mode
speed mode to set.
0 - MMC_LEGACY
1 - MMC_HS
2 - SD_HS
3 - MMC_HS_52
4 - MMC_DDR_52
5 - UHS_SDR12
6 - UHS_SDR25
7 - UHS_SDR50
8 - UHS_DDR50
9 - UHS_SDR104
10 - MMC_HS_200
11 - MMC_HS_400
12 - MMC_HS_400_ES
- mode
speed mode to set.
0 - MMC_LEGACY
1 - MMC_HS
2 - SD_HS
3 - MMC_HS_52
4 - MMC_DDR_52
5 - UHS_SDR12
6 - UHS_SDR25
7 - UHS_SDR50
8 - UHS_DDR50
9 - UHS_SDR104
10 - MMC_HS_200
11 - MMC_HS_400
12 - MMC_HS_400_ES
- => mmc dev 0 1 4
- switch to partitions #1, OK
- mmc0(part 1) is current device
if (!m) continue;
- if (m->preinit) mmc_start_init(m); }
- mmc->user_speed_mode = MMC_MODES_END; return 0;
MMC_MODE_1BIT;
- if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET)) {
int i;
/* set host caps */
MMC_MODE_1BIT);
} else {
return -EINVAL;
- m->user_speed_mode = MMC_MODES_END; /* Initialising user set speed mode */
- if (!m) return 0; if (m->preinit)
- enum bus_mode user_speed_mode; /* intput speed mode from user */
Hi Jaehoon,
On 02/08/21 3:26 am, Jaehoon Chung wrote:
Hi Aswath,
Changes since v1:
- default n
- help
Yeah, I think that is good idea. Will post a respin after making this change.
Also, may I know if you were able test this patch ?
Thanks, Aswath
- if (argc == 1) {
- } else {
PART_ACCESS_MASK);
- "mmc rescan\n"
- mmc rescan
- mode
speed mode to set.
0 - MMC_LEGACY
1 - MMC_HS
2 - SD_HS
3 - MMC_HS_52
4 - MMC_DDR_52
5 - UHS_SDR12
6 - UHS_SDR25
7 - UHS_SDR50
8 - UHS_DDR50
9 - UHS_SDR104
10 - MMC_HS_200
11 - MMC_HS_400
12 - MMC_HS_400_ES
- mode
speed mode to set.
0 - MMC_LEGACY
1 - MMC_HS
2 - SD_HS
3 - MMC_HS_52
4 - MMC_DDR_52
5 - UHS_SDR12
6 - UHS_SDR25
7 - UHS_SDR50
8 - UHS_DDR50
9 - UHS_SDR104
10 - MMC_HS_200
11 - MMC_HS_400
12 - MMC_HS_400_ES
- => mmc dev 0 1 4
if (!m) continue;
MMC_MODE_1BIT;
int i;
/* set host caps */
MMC_MODE_1BIT);
} else {
return -EINVAL;
Aswath Govindraju
Jaehoon Chung
