[U-Boot-Users] MIPS LE build problems
Dear Thomas,
I always wondered what exactly was the reason why I was not able to build the dbau1x00 targets (especially the little endian dbau1550_el target using the ELDK toolchain). Also, I always wondered about the reference to a non-exitent cpu/mips/little/liblittle.a library.
Is ther ea special reason for the current settings of build options for the dbau1x00 targets?
Attached below is a patch which makes all dbau1x00 targets build fine with the current ELDK, and I believe these settings are more correct than the previous ones.
If you don't protest I would like to merge this patch into the public source tree?
I have no objections against patch.
/Thomas
Wolfgang Denk wrote:
Dear Thomas,
Hi Wolfgang
Can I see the patch also, please? I am porting U-Boot on dbau1200 and would like to contribute it to the public source tree. Currently it boots and it can download the kernel over the ethernet. Will try with the PCMCIA and other hardware later. Oh, and it is little endian.
BR, Matej
The patch was attached to Wolfgangs message.
/Thomas
Matej Kupljen wrote:
Hi Wolfgang
BR, Matej
It seems that Wolfgangs original message got lost somewhere.
I have attached the patch.
/Thomas
Hi Wolfgang
BR, Matej
Fix dbau1xxx (= MIPS big and little endian) build options. Incorrect gcc options (big endian -BE switch) were used for dbau1550_el which is a little endian build; also get rid of reference to non-existant cpu/mips/little/liblittle.a library
--- commit 2191923072413972d8dbf3e1b2f8ce6762a85800 tree 7466fe41f385b14b572d4765f5aaadaccd8a48d2 parent 700a0c648df72f2c8e0589c0d0470b5ffd7cab7b author Wolfgang Denk wd@pollux.denx.de Mon, 08 Aug 2005 23:06:32 +0200 committer Wolfgang Denk wd@pollux.denx.de Mon, 08 Aug 2005 23:06:32 +0200
Makefile | 2 +- cpu/mips/config.mk | 12 ++++++++++-- 2 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile --- a/Makefile +++ b/Makefile @@ -1615,7 +1615,7 @@ dbau1550_config : unconfig dbau1550_el_config : unconfig @ >include/config.h @echo "#define CONFIG_DBAU1550 1" >>include/config.h - @./mkconfig -a dbau1x00 mips mips dbau1x00 "" little + @./mkconfig -a dbau1x00 mips mips dbau1x00
######################################################################### ## MIPS64 5Kc diff --git a/cpu/mips/config.mk b/cpu/mips/config.mk --- a/cpu/mips/config.mk +++ b/cpu/mips/config.mk @@ -24,9 +24,17 @@ v=$(shell \ mips-linux-as --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}') MIPSFLAGS=$(shell \ if [ "$v" -lt "14" ]; then \ - echo "-mcpu=4kc -EB -mabicalls"; \ + echo "-mcpu=4kc"; \ else \ - echo "-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined -EB -mabicalls"; \ + echo "-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined"; \ fi)
+ifneq (,$(findstring 4KCle,$(CROSS_COMPILE))) +ENDIANNESS = -EL +else +ENDIANNESS = -EB +endif + +MIPSFLAGS += $(ENDIANNESS) -mabicalls + PLATFORM_CPPFLAGS += $(MIPSFLAGS)
/Thomas
I think the board linker scripts also need to be modified to work with either big or little endian toolchains like below. The third argument to OUTPUT_FORMAT is only used for explicitly little endian compilation.
--- /home/adyer/Projects/u-boot/board/dbau1x00/u-boot.lds 2005-07-25 20:11:54.000000000 -0500 +++ u-boot.lds 2005-07-10 18:17:44.000000000 -0500 @@ -22,9 +22,9 @@ */
/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") +OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-littlemips") */ -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradbigmips") +OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS
The test that decides which endianess to build is not going to work for toolchains other than Denx ones, lots of them have prefixes that don't include 4KCle (they may not build u-boot very well, but that's another issue)
I would suggest doing it by config name and putting ENDIANNESS in config.mk something like so (untested):
dbau1550_config \ dbau1550_el_config : unconfig @ >include/config.h @[ -z "$(findstring _el,$@)" ] || \ { echo "ENDIANNESS = little" >>include/config.mk ; \ echo "little endian" ; \ } @echo "#define CONFIG_DBAU1550 1" >>include/config.h @./mkconfig -a dbau1x00 mips mips dbau1x00
and test for endianness in cpu/mips/config.mk and do the right thing.
Hi
Correct. I'll try it.
I agree.
I'll test it.
BR, Matej
Thanks for pointing out. I was only able to compile the code, not to actually run it.
I am aware of this problem. This is one of the reasons why I started this discussion - I need input from users of other tool chains here.
I disagree. This is IMHO not a good idea. I think the tool chain should "know" which endian mode it is. I don;t ike the ide to encode this in a build target name:
Why do we need two build targets at all? I think there should be just one "dbau1550" target, and your setting of CROSS_COMPILE determines if this is a little or a big endian build.
Comments?
Hi
I am running little endian on DBAU1200.
How can we determine that?
CROSS_COMPILE could be set to anything. It could be: - mipsel-linux - 4kc_le-linux - mips-little-linux - ... Is this true?
BR, Matej
Why do we have to? The only one who needs this type of information is the toolchain, and it knows.
- mipsel-linux
- 4kc_le-linux
- mips-little-linux
Is this true?
Yes.
Hi
Correct. :-)
So, if (for example) if you would like to build the LE version: # CROSS_COMPILE=mipsel-linux-gcc make dbau1200_config # make
and BE: # CROSS_COMPILE=mips-linux-gcc make dbau1200_config # make
But, this way you need two toolchains :-(
How about if you would specify the endianness when you do a config. Like: # CROSS_COMPILE=mipsel-linux-gcc ENDIANNESS=LE make dbau1200_config # make
Comments?
BR, Matej
Right. This iis what I think should work.
Two - or one that can be called using different names (like the ELDK does).
No, this seems even worse to me.
Ummm... How is this handled in the Linux kernel?
Hi
Different names? What about default endianness?
This is in the mipsel-linux-gcc -dumpspecs: *multilib_defaults: EL mips1 mabi=32
And in the mips-linux-gcc -dumpspecs: *multilib_defaults: EB mips1 mabi=32
In .config: CONFIG_CPU_LITTLE_ENDIAN=y or CONFIG_CPU_BIG_ENDIAN=y
Actually, when you're building toolchains for MIPS with crosstool, the difference between the mipsel(EL) and mips(BE) is in kernel config file, which sets the endianness for the toolchain.
BR, Matej
Different names?
Like that:
-> ls -l /opt/eldk/usr/bin/mips*gcc -rwxr-xr-x 1 root root 81896 Mar 6 20:12 /opt/eldk/usr/bin/mips-linux-gcc lrwxrwxrwx 1 root root 14 Mar 12 19:28 /opt/eldk/usr/bin/mips_4KC-gcc -> mips-linux-gcc lrwxrwxrwx 1 root root 14 Mar 12 19:28 /opt/eldk/usr/bin/mips_4KCle-gcc -> mips-linux-gcc
mips_4KC-gcc is big endian, mips_4KCle-gcc is little endian.
The ELDK has
for both, but mips_4KC-gcc passes -DMIPSEB -D_MIPSEB as default options while mips_4KCle-gcc passes -D_MIPSEL -D__MIPSEL -D__MIPSEL__ -DMIPSEL
Seems completely the wrong way round to me... I don't want a random kernel tree to determine if my tool chain is BE or LE. Grrghh..
Hi
I tested this with two toolchains, BE and LE and Wolfgang is right that the toolchain knows what endianness should be. Well this is partly true, because this is know to gcc (look at the -dumpspecs) but not to the linker, because in the linker script for the board (board/xxx/u-boot.lds) you tell the linker what is the default endianness (OUTPUT_FORMAT(default, big, little)).
I think we need to tell the linker what endianness it should use if we are using little endian build, because the default is set to big. Or we can use two linker scripts.
Did I miss something, or is this correct?
BR, Matej
In message 1124262461.16175.22.camel@localhost.localdomain you wrote:
I tested this with two toolchains, BE and LE and Wolfgang is right that the toolchain knows what endianness should be. Well this is partly true, because this is know to gcc (look at the -dumpspecs) but not to the linker, because in the linker script for the board endianness (OUTPUT_FORMAT(default, big, little)).
So is there a clever way to "ask" gcc which endianess it's using? I tried to come up with one but failed so far...
I think rhis is correct.
Hi
You do something similar in the cpu/mips/config.mk where the version of assembler is checked and then appropriate flags are chosen. How about something like: # ${CROSS_COMPILE}gcc -dumpspecs
And check what is written under the *multilib_defaults, if it is EL or EB.
In my case (little endian): *multilib_defaults: EL mips1 mabi=32
And then add to LDFLAGS either -EL or -EB.
I am not a awk/sed/grep expert. :-( Maybe someone else who knows the tools can do that?
BR, Matej
Doesn't work for me.
-> export CROSS_COMPILE=mips_4KC- -> mips_4KC-gcc -dumpspecs ... *multilib_defaults: EB mips1 mabi=32
-> export CROSS_COMPILE=mips_4KCle- -> mips_4KCle-gcc -dumpspecs ... *multilib_defaults: EB mips1 mabi=32
But mips_4KCle-gcc _does_ build LE code just fine ...
Hi
Yes, you need to export the CROSS_COMPILE.
I checked previous messages and you said you have the same compiler and with different names of the links that points to it. /opt/eldk/usr/bin/mips_4KC-gcc -> mips-linux-gcc /opt/eldk/usr/bin/mips_4KCle-gcc -> mips-linux-gcc
Where do you configure the options that this two "different" compilers use? DMIPSEB -D_MIPSEB for mips_4KC-gcc or -D_MIPSEL -D__MIPSEL -D__MIPSEL__ -DMIPSEL for mips_4KCle-gcc?
BR, Matej
Of course I did. See the examples I posted.
Right.
The gcc compiler driver reads and evaluates (1) the name under which the binary was called and (2) the content of the CROSS_COMPILE environment variable.
Hi
Yes, sorry for that. :-(
Aha, thanks for the explanation.
BR, Matej
Hi
I am searching how to do that. How about if the config.mk runs a little test program, like configure does?
For example:
#include <stdio.h> #include <stdlib.h> int main(int argc, char **argv) { unsigned int data = 0x01234567; char *ptr = (char *)&data; if (ptr[0] == 0x01 && ptr[1] == 0x23 && ptr[2] == 0x45 && ptr[3] == 0x67) printf("big\n"); else if (ptr[3] == 0x01 && ptr[2] == 0x23 && ptr[1] == 0x45 && ptr[0] == 0x67) printf("little\n"); else printf("unknown\n"); return 0; }
And then check the output of this program and decides to pass the -EL or -EB to LDFLAGS.
Oh, do you know why I have to use the: -Wa,-allow_branch_to_undefined instead of: -Wa,-mips_allow_branch_to_undefined even though (I guess) I use the same patch as you do?
And why don't you accept the patch that eliminates this patch to binutils?
BR, Matej
If you want to _run_ the test program you have to use the host compiler, which is not interesting. And when you use the cross compiler which you want to test then you cannot run the test program on the development host.
Probably because it's a slightly different version of the patch. See the eldk_build build module on our CVS server: cross_rpms/binutils/SOURCES/binutils-2.14.0-mips-asm-undefbranch.patch target_rpms/binutils/SOURCES/binutils-2.14.0-mips-asm-undefbranch.patch
Ummm.. which patch are you referring to?
Hi
Right! My BIG mistake. Still searching and checking :-(
O.K. I'll check that.
See the mail on this mailing list: From: Eugene Surovegin ebs@ebshome.net Subject: Re: [U-Boot-Users] MIPS build environment Date: 30. Jan 1:20 AM
BR, Matej
Hi
You can try http://www.scratchbox.org/
This should allow you to use autoconf style configuration (./configure) on embedded targets and cross compilation environment by either running the configuration script under a QEmu simulated environment, or by an actual target board connected to the host.
Udi
We can, but we won't.
Maybe. But you don't seriously suggest to make this a requirement to be able to build U-Boot???
I'm not suggesting anything. I'm merely pointing out the availability of an interesting technical solution to a problem encountered here.
Udi
Can you please provide an URL? I can't find a patch from this time in my archive.
Hi
http://sourceforge.net/mailarchive/message.php?msg_id=10690757
BR, Matej
Hi
For example:
BR, Matej
As noted in other email in this thread, executing the above code won't work. What about simply compiling a file containing:
constant int data = 0x01234567;
objdumping the data section, and looking (grepping) to see if the data section has 0x12345678 or 0x78563412?
Speculating ignorantly... gvb
Hi
Thanks. Few comments, though. I use my own toolchain, built with the crosstool and a few patches. binutils: 2.15 gcc: 3.3.5 glibc: 2.3.5
Should this be, like: $(CROSS_COMPILE)as --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}')
Because my compiler is: mipsel-linux-gcc
- echo "-mcpu=4kc"; \
else \
- echo "-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined"; \
fi)
The -mips_allow_branch_to_undefined does not work for me :-) I used this patch: http://sources.redhat.com/ml/binutils/2004-04/msg00476.html And I have to use -allow_branch_to_undefined. Anybody knows why?
BR, Matej
Applied, thanks for pointing out.
participants (6)
Andrew Dyer
Jerry Van Baren
Matej Kupljen
Thomas Lange
Udi Finkelstein
