[PATCH 1/4] misc: make CONFIG_IRQ selectable for all platforms
UCLASS_IRQ driver is not Intel specific. Make CONFIG_IRQ selectable for all platfroms.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/misc/Kconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 29432ae7eb..5eab1ed9c6 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -211,10 +211,9 @@ config FSL_SEC_MON like software violations or hardware security violations.
config IRQ - bool "Intel Interrupt controller" - depends on X86 || SANDBOX + bool "Interrupt controller" help - This enables support for Intel interrupt controllers, including ITSS. + This enables support for interrupt controllers, including ITSS. Some devices have extra features, such as Apollo Lake. The device has its own uclass since there are several operations involved.
GIC_V3_ITS uses UCLASS_IRQ driver. Update Kconfig to select IRQ when GIC_V3_ITS is enabled.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fbe90875ae..f8b4d422d9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -67,6 +67,7 @@ config GIC_V3_ITS bool "ARM GICV3 ITS" select REGMAP select SYSCON + select IRQ help ARM GICV3 Interrupt translation service (ITS). Basic support for programming locality specific peripheral
Tested-by: Vladimir Oltean vladimir.oltean@nxp.com
Wasim,
While this fixes my U-Boot booting issue on NXP LS1028A-RDB (thank you for that):
U-Boot 2021.01 (Jan 27 2021 - 17:40:36 +0200)
SoC: LS1028AE Rev1.0 (0x870b0010) Clock Configuration: CPU0(A72):1300 MHz CPU1(A72):1300 MHz Bus: 400 MHz DDR: 1600 MT/s Reset Configuration Word (RCW): 00000000: 34004010 00000030 00000000 00000000 00000010: 00000000 00b90000 0030c000 00000000 00000020: 01e03150 00002580 00000000 00003296 00000030: 00000000 00000008 00000000 00000000 00000040: 00000000 00000000 00000000 00000000 00000050: 00000000 00000000 00000000 00000000 00000060: 00000000 00000000 200e705a 00000000 00000070: bb580000 00000000 Model: NXP Layerscape 1028a RDB Board Board: LS1028AE Rev1.0-RDB, Version: A, boot from SD FPGA: v8 (RDB) SERDES1 Reference : Clock1 = 100.00MHz Clock2 = 100.00MHz DRAM: 3.9 GiB DDR 3.9 GiB (DDR4, 32-bit, CL=11, ECC on) Error binding driver 'gic-v3': -96 Some drivers failed to bind initcall sequence 00000000fbdcc328 failed at call 000000008201a174 (err=-96) ### ERROR ### Please RESET the board ###
I'm thinking it would be unwise to apply the patches as-is, since now, the GIC-v3 ITS driver does bind, but when Linux boots, apparently it now sees some IRQ storms and dies very quickly in the boot process. Did you try to boot Linux after these patches?
On the other hand, the board works just fine with CONFIG_GIC_V3_ITS disabled. The kontron_sl28_defconfig doesn't even have it. What do we use the GIC ITS for in U-Boot?
One boot attempt:
[ 1.940732] 000: Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000 [ 1.949998] 000: Mem abort info: [ 1.953229] 000: ESR = 0x86000004 [ 1.956726] 000: EC = 0x21: IABT (current EL), IL = 32 bits [ 1.962490] 000: SET = 0, FnV = 0 [ 1.965987] 000: EA = 0, S1PTW = 0 [ 1.969567] 000: [0000000000000000] user address but active_mm is swapper [ 1.976377] 000: Internal error: Oops: 86000004 [#1] PREEMPT_RT SMP [ 1.982662] 000: Modules linked in: [ 1.986154] 000: [ 1.988078] 000: CPU: 0 PID: 156 Comm: irq/121-ptp_qor Not tainted 5.4.3-rt1-00870-g12d35e436edf #126 [ 1.997330] 000: Hardware name: LS1028A RDB Board (DT) [ 2.002479] 000: pstate: 40000005 (nZcv daif -PAN -UAO) [ 2.007716] 000: pc : 0x0 [ 2.010339] 000: lr : ptp_qoriq_isr+0x48/0x1c0 [ 2.014799] 000: sp : ffff800010aebd60 [ 2.018554] 000: x29: ffff800010aebd60 [ 2.022396] 000: x28: 0000000000000000 [ 2.026237] 000: [ 2.028160] 000: x27: ffff0020799bb6b0 [ 2.032001] 000: x26: ffffd45f45338000 [ 2.035842] 000: [ 2.037765] 000: x25: ffffd45f47369000 [ 2.041605] 000: x24: 0000000000000004 [ 2.045445] 000: [ 2.047368] 000: x23: ffff0020799bb228 [ 2.051208] 000: x22: ffff0020799bb600 [ 2.055048] 000: [ 2.056970] 000: x21: ffffd45f47369000 [ 2.060811] 000: x20: ffff0020799bb600 [ 2.064651] 000: [ 2.066573] 000: x19: ffff0020799bb200 [ 2.070414] 000: x18: ffffffffffffffff [ 2.074254] 000: [ 2.076176] 000: x17: 0000000000000007 [ 2.080017] 000: x16: 0000000000000001 [ 2.083858] 000: [ 2.085779] 000: x15: ffffd45f47369948 [ 2.089621] 000: x14: 0000000000000000 [ 2.093462] 000: [ 2.095384] 000: x13: 0000000000000004 [ 2.099225] 000: x12: 0000000000000004 [ 2.103066] 000: [ 2.104988] 000: x11: 0000000000000001 [ 2.108830] 000: x10: 0000000000000000 [ 2.112671] 000: [ 2.114593] 000: x9 : ffff00207a978e00 [ 2.118435] 000: x8 : 0000000000000000 [ 2.122276] 000: [ 2.124198] 000: x7 : 0000000000000000 [ 2.128040] 000: x6 : 0000000000000000 [ 2.131880] 000: [ 2.133802] 000: x5 : 0000000000000001 [ 2.137643] 000: x4 : 0000000000000000 [ 2.141484] 000: [ 2.143406] 000: x3 : ffff0020799bb240 [ 2.147248] 000: x2 : 0000000000000000 [ 2.151088] 000: [ 2.153010] 000: x1 : 0000000000000000 [ 2.156852] 000: x0 : 0000000000000004 [ 2.160691] 000: [ 2.162614] 000: Call trace: [ 2.165497] 000: 0x0 [ 2.167769] 000: irq_forced_thread_fn+0x38/0xb8 [ 2.172404] 000: irq_thread+0x14c/0x248 [ 2.176333] 000: kthread+0x118/0x120 [ 2.180003] 000: ret_from_fork+0x10/0x18 [ 2.184024] 000: Code: bad PC value [ 2.187518] 000: ---[ end trace 0000000000000001 ]--- [ 2.192591] 000: genirq: exiting task "irq/121-ptp_qor" (156) is an active IRQ thread (irq 121) [ 2.201366] 000: ptp_qoriq: device tree node missing required elements, try automatic configuration [ 2.210630] 000: pps pps0: new PPS source ptp0 [ 2.215470] 000: hclge is initializing [ 2.219241] 000: hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 2.226928] 000: hns3: Copyright (c) 2017 Huawei Corporation. [ 2.232735] 000: e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 2.240251] 000: e1000: Copyright (c) 1999-2006 Intel Corporation. [ 2.246481] 000: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k [ 2.252774] 000: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 2.259180] 000: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k [ 2.266607] 000: igb: Copyright (c) 2007-2014 Intel Corporation. [ 2.272666] 000: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 2.280966] 000: igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 2.287535] 000: sky2: driver version 1.30 [ 2.291982] 000: usbcore: registered new interface driver r8152 [ 2.297950] 000: usbcore: registered new interface driver asix [ 2.303827] 000: usbcore: registered new interface driver ax88179_178a [ 2.310692] 000: VFIO - User Level meta-driver version: 0.3 [ 2.320551] 000: dwc3 3100000.usb: Adding to iommu group 8 [ 2.326128] 000: dwc3 3100000.usb: Failed to get clk 'ref': -2 [ 2.332388] 000: dwc3 3110000.usb: Adding to iommu group 9 [ 2.337951] 000: dwc3 3110000.usb: Failed to get clk 'ref': -2 [ 2.344910] 000: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.352034] 000: ehci-pci: EHCI PCI platform driver [ 2.356961] 000: ehci-platform: EHCI generic platform driver [ 2.362723] 000: ehci-orion: EHCI orion driver [ 2.367240] 000: ehci-exynos: EHCI EXYNOS driver [ 2.371930] 000: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.378583] 000: ohci-pci: OHCI PCI platform driver [ 2.383508] 000: ohci-platform: OHCI generic platform driver [ 2.389253] 000: ohci-exynos: OHCI EXYNOS driver [ 2.394136] 000: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.400097] 000: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 2.408305] 000: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010 [ 2.418274] 000: xhci-hcd xhci-hcd.0.auto: irq 19, io mem 0x03100000
Two:
[ 0.000000] 000: printk: bootconsole [uart8250] enabled [ 0.000000] 000: efi: Getting EFI parameters from FDT: [ 0.000000] 000: efi: UEFI not found. [ 0.000000] 000: cma: Reserved 256 MiB at 0x00000000eb800000 [ 0.000000] 000: NUMA: No NUMA configuration found [ 0.000000] 000: NUMA: Faking a node at [mem 0x0000000080000000-0x00000020ffffffff] [ 0.000000] 000: NUMA: NODE_DATA [mem 0x20ff805780-0x20ff806fff] [ 0.000000] 000: Zone ranges: [ 0.000000] 000: DMA32 [ 0.000000] 000: [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] 000: Normal [ 0.000000] 000: [mem 0x0000000100000000-0x00000020ffffffff] [ 0.000000] 000: Movable zone start for each node [ 0.000000] 000: Early memory node ranges [ 0.000000] 000: node 0: [mem 0x0000000080000000-0x00000000fbdfffff] [ 0.000000] 000: node 0: [mem 0x0000002080000000-0x00000020ffffffff] [ 0.000000] 000: Initmem setup node 0 [mem 0x0000000080000000-0x00000020ffffffff] [ 0.000000] 000: On node 0 totalpages: 1031680 [ 0.000000] 000: DMA32 zone: 8192 pages used for memmap [ 0.000000] 000: DMA32 zone: 0 pages reserved [ 0.000000] 000: DMA32 zone: 507392 pages, LIFO batch:63 [ 0.000000] 000: Normal zone: 8192 pages used for memmap [ 0.000000] 000: Normal zone: 524288 pages, LIFO batch:63 [ 0.000000] 000: psci: probing for conduit method from DT. [ 0.000000] 000: psci: PSCIv1.1 detected in firmware. [ 0.000000] 000: psci: Using standard PSCI v0.2 function IDs [ 0.000000] 000: psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] 000: psci: SMC Calling Convention v1.1 [ 0.000000] 000: percpu: Embedded 20 pages/cpu s44992 r8192 d28736 u81920 [ 0.000000] 000: pcpu-alloc: s44992 r8192 d28736 u81920 alloc=20*4096 [ 0.000000] 000: [ 0.000000] 000: pcpu-alloc: [ 0.000000] 000: [0] [ 0.000000] 000: 0 [ 0.000000] 000: [0] [ 0.000000] 000: 1 [ 0.000000] 000: [ 0.000000] 000: Detected PIPT I-cache on CPU0 [ 0.000000] 000: CPU features: detected: GIC system register CPU interface [ 0.000000] 000: CPU features: detected: EL2 vector hardening [ 0.000000] 000: CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] 000: CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] 000: Speculative Store Bypass Disable mitigation not required [ 0.000000] 000: Built 1 zonelists, mobility grouping on. Total pages: 1015296 [ 0.000000] 000: Policy zone: Normal [ 0.000000] 000: Kernel command line: root=/dev/mmcblk0p2 rootwait rw earlycon=uart8250,0x21c0500 console=ttyS0,115200 cma=256M video=1920x1080-32@60 [ 0.000000] 000: Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes, linear) [ 0.000000] 000: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] 000: software IO TLB: mapped [mem 0xe7800000-0xeb800000] (64MB) [ 0.000000] 000: Memory: 3676404K/4126720K available (18620K kernel code, 2574K rwdata, 8856K rodata, 5888K init, 1078K bss, 188172K reserved, 262144K cma-reserved) [ 0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] 000: rcu: Preemptible hierarchical RCU implementation. [ 0.000000] 000: rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=2. [ 0.000000] 000: rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] 000: rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] 000: No expedited grace period (rcu_normal_after_boot). [ 0.000000] 000: Tasks RCU enabled. [ 0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] 000: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] 000: GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] 000: GICv3: 256 SPIs implemented [ 0.000000] 000: GICv3: 0 Extended SPIs implemented [ 0.000000] 000: GICv3: Distributor has no Range Selector support [ 0.000000] 000: GICv3: 16 PPIs implemented [ 0.000000] 000: GICv3: no VLPI support, no direct LPI support [ 0.000000] 000: GICv3: CPU0: found redistributor 0 region 0:0x0000000006040000 [ 0.000000] 000: ITS [mem 0x06020000-0x0603ffff] [ 0.000000] 000: ITS@0x0000000006020000: allocated 65536 Devices @20fa880000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] 000: ITS: using cache flushing for cmd queue [ 0.000000] 000: GICv3: Using preallocated redistributor tables [ 0.000000] 000: GICv3: using LPI property table @0x0000000080000000 [ 0.000000] 000: GICv3: CPU0: using reserved LPI pending table @0x0000000080010000 [ 0.000000] 000: random: get_random_bytes called from start_kernel+0x2bc/0x44c with crng_init=0 [ 0.000000] 000: arch_timer: cp15 timer(s) running at 25.00MHz (phys). [ 0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns [ 0.000000] 000: sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns [ 0.008763] 000: Console: colour dummy device 80x25 [ 0.013728] 000: Calibrating delay loop (skipped), value calculated using timer frequency.. [ 0.022257] 000: 50.00 BogoMIPS (lpj=100000) [ 0.026562] 000: pid_max: default: 32768 minimum: 301 [ 0.031707] 000: LSM: Security Framework initializing [ 0.036850] 000: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.044786] 000: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.077183] 000: ASID allocator initialised with 32768 entries [ 0.091086] 000: rcu: Hierarchical SRCU implementation. [ 0.120434] 000: Platform MSI: gic-its@6020000 domain created [ 0.126289] 000: PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created [ 0.134329] 000: fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created [ 0.143055] 000: EFI services will not be available. [ 0.156089] 000: smp: Bringing up secondary CPUs ... [ 0.209227] 001: Detected PIPT I-cache on CPU1 [ 0.213724] 001: GICv3: CPU1: found redistributor 1 region 0:0x0000000006060000 [ 0.221119] 001: GICv3: CPU1: using reserved LPI pending table @0x0000000080020000 [ 0.228778] 001: CPU1: Booted secondary processor 0x0000000001 [0x410fd083] [ 0.235863] 000: smp: Brought up 1 node, 2 CPUs [ 0.240453] 000: SMP: Total of 2 processors activated. [ 0.245659] 000: CPU features: detected: 32-bit EL0 Support [ 0.251295] 000: CPU features: detected: CRC32 instructions [ 0.267887] 000: CPU: All CPU(s) started at EL2 [ 0.272475] 000: alternatives: patching kernel code [ 0.278129] 001: devtmpfs: initialized [ 0.284195] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.294492] 000: futex hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.304767] 000: xor: measuring software checksum speed [ 0.350099] 001: 8regs : 5166.000 MB/sec [ 0.394125] 000: 32regs : 5734.000 MB/sec [ 0.438822] 001: arm64_neon: 5476.000 MB/sec [ 0.443495] 001: xor: using function: 32regs (5734.000 MB/sec) [ 0.449392] 001: pinctrl core: initialized pinctrl subsystem [ 0.455737] 001: DMI not present or invalid. [ 0.460286] 001: NET: Registered protocol family 16 [ 0.466047] 001: DMA: preallocated 256 KiB pool for atomic allocations [ 0.472650] 001: audit: initializing netlink subsys (disabled) [ 0.478632] 001: audit: type=2000 audit(0.408:1): state=initialized audit_enabled=0 res=1 [ 0.486915] 000: cpuidle: using governor menu [ 0.491564] 000: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.499446] 000: Serial: AMBA PL011 UART driver [ 0.504087] 000: imx mu driver is registered. [ 0.508509] 000: imx rpmsg driver is registered. [ 0.514358] 000: Machine: LS1028A RDB Board [ 0.518597] 000: SoC family: QorIQ LS1028A [ 0.522733] 000: SoC ID: svr:0x870b0010, Revision: 1.0 [ 0.544354] 000: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.551580] 000: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.558823] 000: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.566038] 000: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.574650] 001: cryptd: max_cpu_qlen set to 1000 [ 0.649361] 001: raid6: neonx8 gen() 2861 MB/s [ 0.721407] 000: raid6: neonx8 xor() 2687 MB/s [ 0.794243] 001: raid6: neonx4 gen() 2657 MB/s [ 0.866279] 000: raid6: neonx4 xor() 2432 MB/s [ 0.939116] 000: raid6: neonx2 gen() 2115 MB/s [ 1.011931] 001: raid6: neonx2 xor() 2364 MB/s [ 1.083989] 000: raid6: neonx1 gen() 1662 MB/s [ 1.156804] 001: raid6: neonx1 xor() 1798 MB/s [ 1.228884] 000: raid6: int64x8 gen() 1453 MB/s [ 1.301705] 001: raid6: int64x8 xor() 1170 MB/s [ 1.373732] 000: raid6: int64x4 gen() 1499 MB/s [ 1.446565] 001: raid6: int64x4 xor() 1177 MB/s [ 1.518601] 000: raid6: int64x2 gen() 1098 MB/s [ 1.591403] 001: raid6: int64x2 xor() 1117 MB/s [ 1.663490] 000: raid6: int64x1 gen() 790 MB/s [ 1.736300] 001: raid6: int64x1 xor() 755 MB/s [ 1.741062] 001: raid6: using algorithm neonx8 gen() 2861 MB/s [ 1.746952] 001: raid6: .... xor() 2687 MB/s, rmw enabled [ 1.752411] 001: raid6: using neon recovery algorithm [ 1.757865] 001: ACPI: Interpreter disabled. [ 1.764209] 001: iommu: Default domain type: Passthrough [ 1.769785] 001: vgaarb: loaded [ 1.773116] 001: SCSI subsystem initialized [ 1.777433] 000: libata version 3.00 loaded. [ 1.781878] 000: usbcore: registered new interface driver usbfs [ 1.787896] 000: usbcore: registered new interface driver hub [ 1.793730] 000: usbcore: registered new device driver usb [ 1.799615] 001: imx-i2c 2000000.i2c: can't get pinctrl, bus recovery not supported [ 1.807487] 001: i2c i2c-0: IMX I2C adapter registered [ 1.812983] 001: mc: Linux media interface: v0.10 [ 1.817758] 001: videodev: Linux video capture interface: v2.00 [ 1.823783] 001: pps_core: LinuxPPS API ver. 1 registered [ 1.829244] 001: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it [ 1.838913] 001: PTP clock support registered [ 1.843377] 001: EDAC MC: Ver: 3.0.0 [ 1.847550] 001: No BMan portals available! [ 1.852000] 001: QMan: Allocated lookup table at (____ptrval____), entry count 65537 [ 1.859913] 001: No QMan portals available! [ 1.864246] 001: No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree [ 1.871035] 001: FPGA manager framework [ 1.874972] 001: Advanced Linux Sound Architecture Driver Initialized. [ 1.882211] 000: clocksource: Switched to clocksource arch_sys_counter [ 1.888902] 000: VFS: Disk quotas dquot_6.6.0 [ 1.893335] 000: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.900853] 000: pnp: PnP ACPI: disabled [ 1.908556] 000: thermal_sys: Registered thermal governor 'step_wise' [ 1.915075] 000: thermal_sys: Registered thermal governor 'power_allocator' [ 1.922340] 000: NET: Registered protocol family 2 [ 1.927476] 001: tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 1.936713] 001: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.945359] 001: TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 1.954049] 001: TCP: Hash tables configured (established 32768 bind 32768) [ 1.961254] 001: UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 1.968736] 001: UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 1.976738] 001: NET: Registered protocol family 1 [ 1.981882] 001: RPC: Registered named UNIX socket transport module. [ 1.988311] 001: RPC: Registered udp transport module. [ 1.993509] 001: RPC: Registered tcp transport module. [ 1.998700] 001: RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.005655] 001: PCI: CLS 0 bytes, default 64 [ 2.010529] 001: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 2.019353] 001: kvm [1]: IPA Size Limit: 44bits [ 2.024608] 001: kvm [1]: GICv3: no GICV resource entry [ 2.029901] 001: kvm [1]: disabling GICv2 emulation [ 2.034856] 001: kvm [1]: GIC system register CPU interface enabled [ 2.041217] 001: kvm [1]: vgic interrupt IRQ1 [ 2.045680] 001: kvm [1]: Hyp mode initialized successfully [ 2.052293] 001: Initialise system trusted keyrings [ 2.057342] 000: workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 2.068357] 000: squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.075094] 000: NFS: Registering the id_resolver key type [ 2.080660] 000: Key type id_resolver registered [ 2.085336] 000: Key type id_legacy registered [ 2.089834] 000: nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.097072] 000: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 2.103934] 000: fuse: init (API version 7.31) [ 2.108629] 000: 9p: Installing v9fs 9p2000 file system support [ 2.125562] 000: Key type asymmetric registered [ 2.130158] 000: Asymmetric key parser 'x509' registered [ 2.135554] 000: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 2.143565] 001: io scheduler mq-deadline registered [ 2.148589] 001: io scheduler kyber registered [ 2.157589] 001: pci-host-generic 1f0000000.pcie: host bridge /soc/pcie@1f0000000 ranges: [ 2.165891] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8000000..0x1f815ffff -> 0x00000000 [ 2.174621] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8160000..0x1f81cffff -> 0x00000000 [ 2.183340] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f81d0000..0x1f81effff -> 0x00000000 [ 2.192071] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f81f0000..0x1f820ffff -> 0x00000000 [ 2.200791] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8210000..0x1f822ffff -> 0x00000000 [ 2.209521] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8230000..0x1f824ffff -> 0x00000000 [ 2.218229] 001: pci-host-generic 1f0000000.pcie: MEM 0x1fc000000..0x1fc3fffff -> 0x00000000 [ 2.226993] 001: pci-host-generic 1f0000000.pcie: ECAM at [mem 0x1f0000000-0x1f00fffff] for [bus 00] [ 2.236301] 001: pci-host-generic 1f0000000.pcie: PCI host bridge to bus 0000:00 [ 2.243778] 001: pci_bus 0000:00: root bus resource [bus 00] [ 2.249504] 001: pci_bus 0000:00: root bus resource [mem 0x1f8000000-0x1f815ffff] (bus address [0x00000000-0x0015ffff]) [ 2.260400] 001: pci_bus 0000:00: root bus resource [mem 0x1f8160000-0x1f81cffff pref] (bus address [0x00000000-0x0006ffff]) [ 2.271749] 001: pci_bus 0000:00: root bus resource [mem 0x1f81d0000-0x1f81effff] (bus address [0x00000000-0x0001ffff]) [ 2.282646] 001: pci_bus 0000:00: root bus resource [mem 0x1f81f0000-0x1f820ffff pref] (bus address [0x00000000-0x0001ffff]) [ 2.293996] 001: pci_bus 0000:00: root bus resource [mem 0x1f8210000-0x1f822ffff] (bus address [0x00000000-0x0001ffff]) [ 2.304891] 001: pci_bus 0000:00: root bus resource [mem 0x1f8230000-0x1f824ffff pref] (bus address [0x00000000-0x0001ffff]) [ 2.316239] 001: pci_bus 0000:00: root bus resource [mem 0x1fc000000-0x1fc3fffff] (bus address [0x00000000-0x003fffff]) [ 2.327146] 001: pci 0000:00:00.0: [1957:e100] type 00 class 0x020001 [ 2.333696] 001: pci 0000:00:00.0: BAR 0: [mem 0x1f8000000-0x1f803ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.344682] 001: pci 0000:00:00.0: BAR 2: [mem 0x1f8160000-0x1f816ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.356127] 001: pci 0000:00:00.0: VF BAR 0: [mem 0x1f81d0000-0x1f81dffff 64bit] (from Enhanced Allocation, properties 0x4) [ 2.367378] 001: pci 0000:00:00.0: VF BAR 2: [mem 0x1f81f0000-0x1f81fffff 64bit pref] (from Enhanced Allocation, properties 0x3) [ 2.379101] 001: pci 0000:00:00.0: PME# supported from D0 D3hot [ 2.385089] 001: pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x1f81d0000-0x1f81effff 64bit] (contains BAR0 for 2 VFs) [ 2.395567] 001: pci 0000:00:00.0: VF(n) BAR2 space: [mem 0x1f81f0000-0x1f820ffff 64bit pref] (contains BAR2 for 2 VFs) [ 2.406588] 001: pci 0000:00:00.1: [1957:e100] type 00 class 0x020001 [ 2.413132] 001: pci 0000:00:00.1: BAR 0: [mem 0x1f8040000-0x1f807ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.424121] 001: pci 0000:00:00.1: BAR 2: [mem 0x1f8170000-0x1f817ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.435566] 001: pci 0000:00:00.1: VF BAR 0: [mem 0x1f8210000-0x1f821ffff 64bit] (from Enhanced Allocation, properties 0x4) [ 2.446815] 001: pci 0000:00:00.1: VF BAR 2: [mem 0x1f8230000-0x1f823ffff 64bit pref] (from Enhanced Allocation, properties 0x3) [ 2.458536] 001: pci 0000:00:00.1: PME# supported from D0 D3hot [ 2.464522] 001: pci 0000:00:00.1: VF(n) BAR0 space: [mem 0x1f8210000-0x1f822ffff 64bit] (contains BAR0 for 2 VFs) [ 2.474998] 001: pci 0000:00:00.1: VF(n) BAR2 space: [mem 0x1f8230000-0x1f824ffff 64bit pref] (contains BAR2 for 2 VFs) [ 2.486004] 001: pci 0000:00:00.2: [1957:e100] type 00 class 0x020001 [ 2.492548] 001: pci 0000:00:00.2: BAR 0: [mem 0x1f8080000-0x1f80bffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.503535] 001: pci 0000:00:00.2: BAR 2: [mem 0x1f8180000-0x1f818ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.514992] 001: pci 0000:00:00.2: PME# supported from D0 D3hot [ 2.521072] 001: pci 0000:00:00.3: [1957:ee01] type 00 class 0x088001 [ 2.527621] 001: pci 0000:00:00.3: BAR 0: [mem 0x1f8100000-0x1f811ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.538607] 001: pci 0000:00:00.3: BAR 2: [mem 0x1f8190000-0x1f819ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.550064] 001: pci 0000:00:00.3: PME# supported from D0 D3hot [ 2.556142] 001: pci 0000:00:00.4: [1957:ee02] type 00 class 0x088001 [ 2.562684] 001: pci 0000:00:00.4: BAR 0: [mem 0x1f8120000-0x1f813ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.573670] 001: pci 0000:00:00.4: BAR 2: [mem 0x1f81a0000-0x1f81affff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.585125] 001: pci 0000:00:00.4: PME# supported from D0 D3hot [ 2.591199] 001: pci 0000:00:00.5: [1957:eef0] type 00 class 0x020801 [ 2.597746] 001: pci 0000:00:00.5: BAR 0: [mem 0x1f8140000-0x1f815ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.608731] 001: pci 0000:00:00.5: BAR 2: [mem 0x1f81b0000-0x1f81bffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.620175] 001: pci 0000:00:00.5: BAR 4: [mem 0x1fc000000-0x1fc3fffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.631173] 001: pci 0000:00:00.5: PME# supported from D0 D3hot [ 2.637266] 001: pci 0000:00:00.6: [1957:e100] type 00 class 0x020001 [ 2.643797] 001: pci 0000:00:00.6: BAR 0: [mem 0x1f80c0000-0x1f80fffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.654803] 001: pci 0000:00:00.6: BAR 2: [mem 0x1f81c0000-0x1f81cffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.666238] 001: pci 0000:00:00.6: PME# supported from D0 D3hot [ 2.672865] 001: pci 0000:00:1f.0: [1957:e001] type 00 class 0x080700 [ 2.679415] 001: OF: /soc/pcie@1f0000000: no msi-map translation for rid 0xf8 on (null) [ 2.688089] 001: layerscape-pcie 3400000.pcie: host bridge /soc/pcie@3400000 ranges: [ 2.695935] 001: layerscape-pcie 3400000.pcie: IO 0x8000010000..0x800001ffff -> 0x00000000 [ 2.704574] 001: layerscape-pcie 3400000.pcie: MEM 0x8040000000..0x807fffffff -> 0x40000000 [ 2.713286] 001: layerscape-pcie 3400000.pcie: PCI host bridge to bus 0001:00 [ 2.720511] 001: pci_bus 0001:00: root bus resource [bus 00-ff] [ 2.726493] 001: pci_bus 0001:00: root bus resource [io 0x0000-0xffff] [ 2.733194] 001: pci_bus 0001:00: root bus resource [mem 0x8040000000-0x807fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.744277] 001: pci 0001:00:00.0: [1957:82c0] type 01 class 0x060400 [ 2.750842] 001: pci 0001:00:00.0: supports D1 D2 [ 2.755595] 001: pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot [ 2.763317] 001: pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.770448] 001: pci 0001:00:00.0: PCI bridge to [bus 01] [ 2.776008] 001: layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges: [ 2.783850] 001: layerscape-pcie 3500000.pcie: IO 0x8800010000..0x880001ffff -> 0x00000000 [ 2.792489] 001: layerscape-pcie 3500000.pcie: MEM 0x8840000000..0x887fffffff -> 0x40000000 [ 2.801193] 001: layerscape-pcie 3500000.pcie: PCI host bridge to bus 0002:00 [ 2.808419] 001: pci_bus 0002:00: root bus resource [bus 00-ff] [ 2.814402] 001: pci_bus 0002:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff]) [ 2.823912] 001: pci_bus 0002:00: root bus resource [mem 0x8840000000-0x887fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.834998] 001: pci 0002:00:00.0: [1957:82c0] type 01 class 0x060400 [ 2.841561] 001: pci 0002:00:00.0: supports D1 D2 [ 2.846318] 001: pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot [ 2.854019] 001: pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.861149] 001: pci 0002:00:00.0: PCI bridge to [bus 01] [ 2.867359] 001: EINJ: ACPI disabled. [ 2.874057] 001: Bus freq driver module loaded [ 2.881994] 001: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 2.890080] 001: printk: console [ttyS0] disabled [ 2.894892] 001: 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 15, base_baud = 12500000) is a 16550A [ 2.904234] 001: printk: console [ttyS0] enabled [ 2.908909] 001: printk: bootconsole [uart8250] disabled [ 0.000000] 000: Booting Linux on physical CPU 0x0000000000 [0x410fd083] [ 0.000000] 000: Linux version 5.4.3-rt1 (tigrisor@skbuf) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT_RT Sun Aug 23 22:39:15 EEST 20 20 [ 0.000000] 000: Machine model: LS1028A RDB Board [ 0.000000] 000: earlycon: uart8250 at MMIO 0x00000000021c0500 (options '') [ 0.000000] 000: printk: bootconsole [uart8250] enabled [ 0.000000] 000: efi: Getting EFI parameters from FDT: [ 0.000000] 000: efi: UEFI not found. [ 0.000000] 000: cma: Reserved 256 MiB at 0x00000000eb800000 [ 0.000000] 000: NUMA: No NUMA configuration found [ 0.000000] 000: NUMA: Faking a node at [mem 0x0000000080000000-0x00000020ffffffff] [ 0.000000] 000: NUMA: NODE_DATA [mem 0x20ff805780-0x20ff806fff] [ 0.000000] 000: Zone ranges: [ 0.000000] 000: DMA32 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] 000: Normal [mem 0x0000000100000000-0x00000020ffffffff] [ 0.000000] 000: Movable zone start for each node [ 0.000000] 000: Early memory node ranges [ 0.000000] 000: node 0: [mem 0x0000000080000000-0x00000000fbdfffff] [ 0.000000] 000: node 0: [mem 0x0000002080000000-0x00000020ffffffff] [ 0.000000] 000: Initmem setup node 0 [mem 0x0000000080000000-0x00000020ffffffff] [ 0.000000] 000: psci: probing for conduit method from DT. [ 0.000000] 000: psci: PSCIv1.1 detected in firmware. [ 0.000000] 000: psci: Using standard PSCI v0.2 function IDs [ 0.000000] 000: psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] 000: psci: SMC Calling Convention v1.1 [ 0.000000] 000: percpu: Embedded 20 pages/cpu s44992 r8192 d28736 u81920 [ 0.000000] 000: Detected PIPT I-cache on CPU0 [ 0.000000] 000: CPU features: detected: GIC system register CPU interface [ 0.000000] 000: CPU features: detected: EL2 vector hardening [ 0.000000] 000: CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] 000: CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] 000: Speculative Store Bypass Disable mitigation not required [ 0.000000] 000: Built 1 zonelists, mobility grouping on. Total pages: 1015296 [ 0.000000] 000: Policy zone: Normal [ 0.000000] 000: Kernel command line: root=/dev/mmcblk0p2 rootwait rw earlycon=uart8250,0x21c0500 console=ttyS0,115200 cma=256M video=1920x1080-32@60 [ 0.000000] 000: Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes, linear) [ 0.000000] 000: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] 000: software IO TLB: mapped [mem 0xe7800000-0xeb800000] (64MB) [ 0.000000] 000: Memory: 3676404K/4126720K available (18620K kernel code, 2574K rwdata, 8856K rodata, 5888K init, 1078K bss, 188172K reserved, 262144K cma-reserved) [ 0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] 000: rcu: Preemptible hierarchical RCU implementation. [ 0.000000] 000: rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=2. [ 0.000000] 000: rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] 000: rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] 000: No expedited grace period (rcu_normal_after_boot). [ 0.000000] 000: Tasks RCU enabled. [ 0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] 000: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] 000: GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] 000: GICv3: 256 SPIs implemented [ 0.000000] 000: GICv3: 0 Extended SPIs implemented [ 0.000000] 000: GICv3: Distributor has no Range Selector support [ 0.000000] 000: GICv3: 16 PPIs implemented [ 0.000000] 000: GICv3: no VLPI support, no direct LPI support [ 0.000000] 000: GICv3: CPU0: found redistributor 0 region 0:0x0000000006040000 [ 0.000000] 000: ITS [mem 0x06020000-0x0603ffff] [ 0.000000] 000: ITS@0x0000000006020000: allocated 65536 Devices @20fa880000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] 000: ITS: using cache flushing for cmd queue [ 0.000000] 000: GICv3: Using preallocated redistributor tables [ 0.000000] 000: GICv3: using LPI property table @0x0000000080000000 [ 0.000000] 000: GICv3: CPU0: using reserved LPI pending table @0x0000000080010000 [ 0.000000] 000: random: get_random_bytes called from start_kernel+0x2bc/0x44c with crng_init=0 [ 0.000000] 000: arch_timer: cp15 timer(s) running at 25.00MHz (phys). [ 0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns [ 0.000000] 000: sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns [ 0.008763] 000: Console: colour dummy device 80x25 [ 0.022253] 000: Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000) [ 0.026562] 000: pid_max: default: 32768 minimum: 301 [ 0.031707] 000: LSM: Security Framework initializing [ 0.036850] 000: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.044786] 000: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.077183] 000: ASID allocator initialised with 32768 entries [ 0.091086] 000: rcu: Hierarchical SRCU implementation. [ 0.120434] 000: Platform MSI: gic-its@6020000 domain created [ 0.126289] 000: PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created [ 0.134329] 000: fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created [ 0.143055] 000: EFI services will not be available. [ 0.156089] 000: smp: Bringing up secondary CPUs ... [ 0.209227] 001: Detected PIPT I-cache on CPU1 [ 0.213724] 001: GICv3: CPU1: found redistributor 1 region 0:0x0000000006060000 [ 0.221119] 001: GICv3: CPU1: using reserved LPI pending table @0x0000000080020000 [ 0.228778] 001: CPU1: Booted secondary processor 0x0000000001 [0x410fd083] [ 0.235863] 000: smp: Brought up 1 node, 2 CPUs [ 0.240453] 000: SMP: Total of 2 processors activated. [ 0.245659] 000: CPU features: detected: 32-bit EL0 Support [ 0.251295] 000: CPU features: detected: CRC32 instructions [ 0.267887] 000: CPU: All CPU(s) started at EL2 [ 0.272475] 000: alternatives: patching kernel code [ 0.278129] 001: devtmpfs: initialized [ 0.284195] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.294492] 000: futex hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.304767] 000: xor: measuring software checksum speed [ 0.350099] 001: 8regs : 5166.000 MB/sec [ 0.394125] 000: 32regs : 5734.000 MB/sec [ 0.438822] 001: arm64_neon: 5476.000 MB/sec [ 0.443495] 001: xor: using function: 32regs (5734.000 MB/sec) [ 0.449392] 001: pinctrl core: initialized pinctrl subsystem [ 0.455737] 001: DMI not present or invalid. [ 0.460286] 001: NET: Registered protocol family 16 [ 0.466047] 001: DMA: preallocated 256 KiB pool for atomic allocations [ 0.472650] 001: audit: initializing netlink subsys (disabled) [ 0.478632] 001: audit: type=2000 audit(0.408:1): state=initialized audit_enabled=0 res=1 [ 0.486915] 000: cpuidle: using governor menu [ 0.491564] 000: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.499446] 000: Serial: AMBA PL011 UART driver [ 0.504087] 000: imx mu driver is registered. [ 0.508509] 000: imx rpmsg driver is registered. [ 0.514358] 000: Machine: LS1028A RDB Board [ 0.518597] 000: SoC family: QorIQ LS1028A [ 0.522733] 000: SoC ID: svr:0x870b0010, Revision: 1.0 [ 0.544354] 000: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.551580] 000: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.558823] 000: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.566038] 000: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.574650] 001: cryptd: max_cpu_qlen set to 1000 [ 0.649361] 001: raid6: neonx8 gen() 2861 MB/s [ 0.721407] 000: raid6: neonx8 xor() 2687 MB/s [ 0.794243] 001: raid6: neonx4 gen() 2657 MB/s [ 0.866279] 000: raid6: neonx4 xor() 2432 MB/s [ 0.939116] 000: raid6: neonx2 gen() 2115 MB/s [ 1.011931] 001: raid6: neonx2 xor() 2364 MB/s [ 1.083989] 000: raid6: neonx1 gen() 1662 MB/s [ 1.156804] 001: raid6: neonx1 xor() 1798 MB/s [ 1.228884] 000: raid6: int64x8 gen() 1453 MB/s [ 1.301705] 001: raid6: int64x8 xor() 1170 MB/s [ 1.373732] 000: raid6: int64x4 gen() 1499 MB/s [ 1.446565] 001: raid6: int64x4 xor() 1177 MB/s [ 1.518601] 000: raid6: int64x2 gen() 1098 MB/s [ 1.591403] 001: raid6: int64x2 xor() 1117 MB/s [ 1.663490] 000: raid6: int64x1 gen() 790 MB/s [ 1.736300] 001: raid6: int64x1 xor() 755 MB/s [ 1.741062] 001: raid6: using algorithm neonx8 gen() 2861 MB/s [ 1.746952] 001: raid6: .... xor() 2687 MB/s, rmw enabled [ 1.752411] 001: raid6: using neon recovery algorithm [ 1.757865] 001: ACPI: Interpreter disabled. [ 1.764209] 001: iommu: Default domain type: Passthrough [ 1.769785] 001: vgaarb: loaded [ 1.773116] 001: SCSI subsystem initialized [ 1.781878] 000: usbcore: registered new interface driver usbfs [ 1.787896] 000: usbcore: registered new interface driver hub [ 1.793730] 000: usbcore: registered new device driver usb [ 1.799615] 001: imx-i2c 2000000.i2c: can't get pinctrl, bus recovery not supported [ 1.807487] 001: i2c i2c-0: IMX I2C adapter registered [ 1.812983] 001: mc: Linux media interface: v0.10 [ 1.817758] 001: videodev: Linux video capture interface: v2.00 [ 1.823783] 001: pps_core: LinuxPPS API ver. 1 registered [ 1.829244] 001: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it [ 1.838913] 001: PTP clock support registered [ 1.843377] 001: EDAC MC: Ver: 3.0.0 [ 1.847550] 001: No BMan portals available! [ 1.852000] 001: QMan: Allocated lookup table at (____ptrval____), entry count 65537 [ 1.859913] 001: No QMan portals available! [ 1.864246] 001: No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree [ 1.871035] 001: FPGA manager framework [ 1.874972] 001: Advanced Linux Sound Architecture Driver Initialized. [ 1.882211] 000: clocksource: Switched to clocksource arch_sys_counter [ 1.888902] 000: VFS: Disk quotas dquot_6.6.0 [ 1.893335] 000: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.900853] 000: pnp: PnP ACPI: disabled [ 1.915055] 000: thermal_sys: Registered thermal governor 'step_wise' [ 1.922110] 000: thermal_sys: Registered thermal governor 'power_allocator' [ 1.922340] 000: NET: Registered protocol family 2 [ 1.927476] 001: tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 1.936713] 001: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.945359] 001: TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 1.954049] 001: TCP: Hash tables configured (established 32768 bind 32768) [ 1.961254] 001: UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 1.968736] 001: UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 1.976738] 001: NET: Registered protocol family 1 [ 1.981882] 001: RPC: Registered named UNIX socket transport module. [ 1.988311] 001: RPC: Registered udp transport module. [ 1.993509] 001: RPC: Registered tcp transport module. [ 1.998700] 001: RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.005655] 001: PCI: CLS 0 bytes, default 64 [ 2.010529] 001: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 2.019353] 001: kvm [1]: IPA Size Limit: 44bits [ 2.024608] 001: kvm [1]: GICv3: no GICV resource entry [ 2.029901] 001: kvm [1]: disabling GICv2 emulation [ 2.034856] 001: kvm [1]: GIC system register CPU interface enabled [ 2.041217] 001: kvm [1]: vgic interrupt IRQ1 [ 2.045680] 001: kvm [1]: Hyp mode initialized successfully [ 2.052293] 001: Initialise system trusted keyrings [ 2.057342] 000: workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 2.068357] 000: squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.075094] 000: NFS: Registering the id_resolver key type [ 2.080660] 000: Key type id_resolver registered [ 2.085336] 000: Key type id_legacy registered [ 2.089834] 000: nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.097072] 000: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 2.103934] 000: fuse: init (API version 7.31) [ 2.108629] 000: 9p: Installing v9fs 9p2000 file system support [ 2.125562] 000: Key type asymmetric registered [ 2.130158] 000: Asymmetric key parser 'x509' registered [ 2.135554] 000: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 2.143565] 001: io scheduler mq-deadline registered [ 2.148589] 001: io scheduler kyber registered [ 2.157589] 001: pci-host-generic 1f0000000.pcie: host bridge /soc/pcie@1f0000000 ranges: [ 2.165891] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8000000..0x1f815ffff -> 0x00000000 [ 2.174621] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8160000..0x1f81cffff -> 0x00000000 [ 2.183340] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f81d0000..0x1f81effff -> 0x00000000 [ 2.192071] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f81f0000..0x1f820ffff -> 0x00000000 [ 2.200791] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8210000..0x1f822ffff -> 0x00000000 [ 2.209521] 001: pci-host-generic 1f0000000.pcie: MEM 0x1f8230000..0x1f824ffff -> 0x00000000 [ 2.218229] 001: pci-host-generic 1f0000000.pcie: MEM 0x1fc000000..0x1fc3fffff -> 0x00000000 [ 2.226993] 001: pci-host-generic 1f0000000.pcie: ECAM at [mem 0x1f0000000-0x1f00fffff] for [bus 00] [ 2.236301] 001: pci-host-generic 1f0000000.pcie: PCI host bridge to bus 0000:00 [ 2.243778] 001: pci_bus 0000:00: root bus resource [bus 00] [ 2.249504] 001: pci_bus 0000:00: root bus resource [mem 0x1f8000000-0x1f815ffff] (bus address [0x00000000-0x0015ffff]) [ 2.260400] 001: pci_bus 0000:00: root bus resource [mem 0x1f8160000-0x1f81cffff pref] (bus address [0x00000000-0x0006ffff]) [ 2.271749] 001: pci_bus 0000:00: root bus resource [mem 0x1f81d0000-0x1f81effff] (bus address [0x00000000-0x0001ffff]) [ 2.282646] 001: pci_bus 0000:00: root bus resource [mem 0x1f81f0000-0x1f820ffff pref] (bus address [0x00000000-0x0001ffff]) [ 2.293996] 001: pci_bus 0000:00: root bus resource [mem 0x1f8210000-0x1f822ffff] (bus address [0x00000000-0x0001ffff]) [ 2.304891] 001: pci_bus 0000:00: root bus resource [mem 0x1f8230000-0x1f824ffff pref] (bus address [0x00000000-0x0001ffff]) [ 2.316239] 001: pci_bus 0000:00: root bus resource [mem 0x1fc000000-0x1fc3fffff] (bus address [0x00000000-0x003fffff]) [ 2.327146] 001: pci 0000:00:00.0: [1957:e100] type 00 class 0x020001 [ 2.333696] 001: pci 0000:00:00.0: BAR 0: [mem 0x1f8000000-0x1f803ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.344682] 001: pci 0000:00:00.0: BAR 2: [mem 0x1f8160000-0x1f816ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.356127] 001: pci 0000:00:00.0: VF BAR 0: [mem 0x1f81d0000-0x1f81dffff 64bit] (from Enhanced Allocation, properties 0x4) [ 2.367378] 001: pci 0000:00:00.0: VF BAR 2: [mem 0x1f81f0000-0x1f81fffff 64bit pref] (from Enhanced Allocation, properties 0x3) [ 2.379101] 001: pci 0000:00:00.0: PME# supported from D0 D3hot [ 2.385089] 001: pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x1f81d0000-0x1f81effff 64bit] (contains BAR0 for 2 VFs) [ 2.395567] 001: pci 0000:00:00.0: VF(n) BAR2 space: [mem 0x1f81f0000-0x1f820ffff 64bit pref] (contains BAR2 for 2 VFs) [ 2.406588] 001: pci 0000:00:00.1: [1957:e100] type 00 class 0x020001 [ 2.413132] 001: pci 0000:00:00.1: BAR 0: [mem 0x1f8040000-0x1f807ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.424121] 001: pci 0000:00:00.1: BAR 2: [mem 0x1f8170000-0x1f817ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.435566] 001: pci 0000:00:00.1: VF BAR 0: [mem 0x1f8210000-0x1f821ffff 64bit] (from Enhanced Allocation, properties 0x4) [ 2.446815] 001: pci 0000:00:00.1: VF BAR 2: [mem 0x1f8230000-0x1f823ffff 64bit pref] (from Enhanced Allocation, properties 0x3) [ 2.458536] 001: pci 0000:00:00.1: PME# supported from D0 D3hot [ 2.464522] 001: pci 0000:00:00.1: VF(n) BAR0 space: [mem 0x1f8210000-0x1f822ffff 64bit] (contains BAR0 for 2 VFs) [ 2.474998] 001: pci 0000:00:00.1: VF(n) BAR2 space: [mem 0x1f8230000-0x1f824ffff 64bit pref] (contains BAR2 for 2 VFs) [ 2.486004] 001: pci 0000:00:00.2: [1957:e100] type 00 class 0x020001 [ 2.492548] 001: pci 0000:00:00.2: BAR 0: [mem 0x1f8080000-0x1f80bffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.503535] 001: pci 0000:00:00.2: BAR 2: [mem 0x1f8180000-0x1f818ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.514992] 001: pci 0000:00:00.2: PME# supported from D0 D3hot [ 2.521072] 001: pci 0000:00:00.3: [1957:ee01] type 00 class 0x088001 [ 2.527621] 001: pci 0000:00:00.3: BAR 0: [mem 0x1f8100000-0x1f811ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.538607] 001: pci 0000:00:00.3: BAR 2: [mem 0x1f8190000-0x1f819ffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.550064] 001: pci 0000:00:00.3: PME# supported from D0 D3hot [ 2.556142] 001: pci 0000:00:00.4: [1957:ee02] type 00 class 0x088001 [ 2.562684] 001: pci 0000:00:00.4: BAR 0: [mem 0x1f8120000-0x1f813ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.573670] 001: pci 0000:00:00.4: BAR 2: [mem 0x1f81a0000-0x1f81affff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.585125] 001: pci 0000:00:00.4: PME# supported from D0 D3hot [ 2.591199] 001: pci 0000:00:00.5: [1957:eef0] type 00 class 0x020801 [ 2.597746] 001: pci 0000:00:00.5: BAR 0: [mem 0x1f8140000-0x1f815ffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.608731] 001: pci 0000:00:00.5: BAR 2: [mem 0x1f81b0000-0x1f81bffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.620175] 001: pci 0000:00:00.5: BAR 4: [mem 0x1fc000000-0x1fc3fffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.631173] 001: pci 0000:00:00.5: PME# supported from D0 D3hot [ 2.637266] 001: pci 0000:00:00.6: [1957:e100] type 00 class 0x020001 [ 2.643797] 001: pci 0000:00:00.6: BAR 0: [mem 0x1f80c0000-0x1f80fffff 64bit] (from Enhanced Allocation, properties 0x0) [ 2.654803] 001: pci 0000:00:00.6: BAR 2: [mem 0x1f81c0000-0x1f81cffff 64bit pref] (from Enhanced Allocation, properties 0x1) [ 2.666238] 001: pci 0000:00:00.6: PME# supported from D0 D3hot [ 2.672865] 001: pci 0000:00:1f.0: [1957:e001] type 00 class 0x080700 [ 2.679415] 001: OF: /soc/pcie@1f0000000: no msi-map translation for rid 0xf8 on (null) [ 2.688089] 001: layerscape-pcie 3400000.pcie: host bridge /soc/pcie@3400000 ranges: [ 2.695935] 001: layerscape-pcie 3400000.pcie: IO 0x8000010000..0x800001ffff -> 0x00000000 [ 2.704574] 001: layerscape-pcie 3400000.pcie: MEM 0x8040000000..0x807fffffff -> 0x40000000 [ 2.713286] 001: layerscape-pcie 3400000.pcie: PCI host bridge to bus 0001:00 [ 2.720511] 001: pci_bus 0001:00: root bus resource [bus 00-ff] [ 2.726493] 001: pci_bus 0001:00: root bus resource [io 0x0000-0xffff] [ 2.733194] 001: pci_bus 0001:00: root bus resource [mem 0x8040000000-0x807fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.744277] 001: pci 0001:00:00.0: [1957:82c0] type 01 class 0x060400 [ 2.750842] 001: pci 0001:00:00.0: supports D1 D2 [ 2.755595] 001: pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot [ 2.763317] 001: pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.770448] 001: pci 0001:00:00.0: PCI bridge to [bus 01] [ 2.776008] 001: layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges: [ 2.783850] 001: layerscape-pcie 3500000.pcie: IO 0x8800010000..0x880001ffff -> 0x00000000 [ 2.792489] 001: layerscape-pcie 3500000.pcie: MEM 0x8840000000..0x887fffffff -> 0x40000000 [ 2.801193] 001: layerscape-pcie 3500000.pcie: PCI host bridge to bus 0002:00 [ 2.808419] 001: pci_bus 0002:00: root bus resource [bus 00-ff] [ 2.814402] 001: pci_bus 0002:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff]) [ 2.823912] 001: pci_bus 0002:00: root bus resource [mem 0x8840000000-0x887fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.834998] 001: pci 0002:00:00.0: [1957:82c0] type 01 class 0x060400 [ 2.841561] 001: pci 0002:00:00.0: supports D1 D2 [ 2.846318] 001: pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot [ 2.854019] 001: pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.861149] 001: pci 0002:00:00.0: PCI bridge to [bus 01] [ 2.867359] 001: EINJ: ACPI disabled. [ 2.874057] 001: Bus freq driver module loaded [ 2.881994] 001: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 2.890080] 001: printk: console [ttyS0] disabled [ 2.894892] 001: 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 15, base_baud = 12500000) is a 16550A [ 2.904234] 001: printk: console [ttyS0] enabled [ 2.908909] 001: printk: bootconsole [uart8250] disabled [ 2.914608] 001: 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 15, base_baud = 12500000) is a 16550A [ 2.914903] 001: SuperH (H)SCI(F) driver initialized [ 2.915182] 001: msm_serial: driver initialized [ 2.916665] 001: arm-smmu 5000000.iommu: probing hardware configuration... [ 2.916669] 001: arm-smmu 5000000.iommu: SMMUv2 with: [ 2.916673] 001: arm-smmu 5000000.iommu: stage 1 translation [ 2.916675] 001: arm-smmu 5000000.iommu: stage 2 translation [ 2.916677] 001: arm-smmu 5000000.iommu: nested translation [ 2.916681] 001: arm-smmu 5000000.iommu: stream matching with 128 register groups [ 2.916686] 001: arm-smmu 5000000.iommu: 64 context banks (0 stage-2 only) [ 2.916695] 001: arm-smmu 5000000.iommu: Supported page sizes: 0x61311000 [ 2.916698] 001: arm-smmu 5000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA [ 2.916701] 001: arm-smmu 5000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA [ 2.923152] 001: brd: module loaded [ 2.927512] 001: loop: module loaded [ 2.928927] 000: imx ahci driver is registered. [ 2.929142] 000: ahci-qoriq 3200000.sata: Adding to iommu group 0 [ 2.929194] 000: ahci-qoriq 3200000.sata: 3200000.sata supply ahci not found, using dummy regulator [ 2.929247] 000: ahci-qoriq 3200000.sata: 3200000.sata supply phy not found, using dummy regulator [ 2.929276] 000: ahci-qoriq 3200000.sata: 3200000.sata supply target not found, using dummy regulator [ 2.929361] 000: ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode [ 2.929366] 000: ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst [ 2.929839] 001: scsi host0: ahci-qoriq [ 2.930011] 001: ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 21 [ 2.932166] 001: spi-nor spi0.0: unrecognized JEDEC id bytes: 96 2d 8e 08 20 80 [ 2.933372] 001: libphy: Fixed MDIO Bus: probed [ 2.933862] 001: tun: Universal TUN/TAP device driver, 1.6 [ 2.934044] 001: mscc_felix 0000:00:00.5: Adding to iommu group 1 [ 2.934273] 001: mscc_felix 0000:00:00.5: Failed to register DSA switch: -517 [ 2.934731] 001: thunder_xcv, ver 1.0 [ 2.934756] 001: thunder_bgx, ver 1.0 [ 2.934781] 001: nicpf, ver 1.0 [ 2.934995] 001: Freescale FM module, FMD API version 21.1.0 [ 2.935083] 001: Freescale FM Ports module [ 2.935085] 001: fsl_mac: fsl_mac: FSL FMan MAC API based driver [ 2.935144] 001: fsl_dpa: FSL DPAA Ethernet driver [ 2.935191] 001: fsl_advanced: FSL DPAA Advanced drivers: [ 2.935192] 001: fsl_proxy: FSL DPAA Proxy initialization driver [ 2.935238] 001: fsl_oh: FSL FMan Offline Parsing port driver Starting syslogd[ 2.935376] 001: fsl_enetc 0000:00:00.0: Adding to iommu group 2 : [ 3.042231] 000: fsl_enetc 0000:00:00.0: enabling device (0400 -> 0402) OK[ 3.042481] 000: libphy: Freescale ENETC MDIO Bus: probed
[ 3.043174] 001: fsl_enetc 0000:00:00.0: no MAC address specified for SI1, using d2:6b:82:84:e6:6d Starting klogd: [ 3.043179] 001: fsl_enetc 0000:00:00.0: no MAC address specified for SI2, using 26:9f:a4:dd:60:11 OK [ 3.044200] 001: fsl_enetc 0000:00:00.0 eth0: ENETC PF driver v1.0 Running sysctl: [ 3.044207] 001: fsl_enetc 0000:00:00.0: enetc_tsn_init: setup done [ 3.044277] 001: fsl_enetc 0000:00:00.1: Adding to iommu group 3 [ 3.044296] 001: fsl_enetc 0000:00:00.1: device is disabled, skipping OK [ 3.044337] 001: fsl_enetc 0000:00:00.2: Adding to iommu group 4 [ 3.150221] 000: fsl_enetc 0000:00:00.2: enabling device (0400 -> 0402) [ 3.151001] 001: fsl_enetc 0000:00:00.2 eth1: ENETC PF driver v1.0 Populating /dev [ 3.151008] 001: fsl_enetc 0000:00:00.2: enetc_tsn_init: setup done using udev: [ 3.151075] 001: fsl_enetc 0000:00:00.6: Adding to iommu group 5 [ 3.151096] 001: fsl_enetc 0000:00:00.6: device is disabled, skipping [ 3.151192] 001: fsl_enetc_mdio 0000:00:00.3: Adding to iommu group 6 [ 3.244419] 001: ata1: SATA link down (SStatus 0 SControl 300) [ 3.258222] 000: fsl_enetc_mdio 0000:00:00.3: enabling device (0400 -> 0402) [ 3.258439] 000: libphy: FSL PCIe IE Central MDIO Bus: probed [ 3.260826] 000: fsl_enetc_ptp 0000:00:00.4: Adding to iommu group 7 [ 3.260846] 000: fsl_enetc_ptp 0000:00:00.4: enabling device (0404 -> 0406) [ 3.261027] 000: ptp_qoriq: device tree node missing required elements, try automatic configuration [ 3.261200] 000: pps pps0: new PPS source ptp0 [ 3.261553] 000: hclge is initializing [ 3.261555] 000: hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 3.261557] 000: hns3: Copyright (c) 2017 Huawei Corporation. [ 3.261594] 000: e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 3.261596] 000: e1000: Copyright (c) 1999-2006 Intel Corporation. [ 3.261622] 000: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k [ 3.261624] 000: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 3.261652] 000: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k [ 3.261654] 000: igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.261678] 000: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 3.261680] 000: igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 3.261862] 000: sky2: driver version 1.30 [ 3.262174] 000: usbcore: registered new interface driver r8152 [ 3.262193] 000: usbcore: registered new interface driver asix [ 3.262274] 000: usbcore: registered new interface driver ax88179_178a [ 3.262592] 000: VFIO - User Level meta-driver version: 0.3 [ 3.262829] 000: dwc3 3100000.usb: Adding to iommu group 8 [ 3.262887] 000: dwc3 3100000.usb: Failed to get clk 'ref': -2 [ 3.263299] 000: dwc3 3110000.usb: Adding to iommu group 9 [ 3.263341] 000: dwc3 3110000.usb: Failed to get clk 'ref': -2 [ 3.264875] 001: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.264880] 001: ehci-pci: EHCI PCI platform driver [ 3.264903] 001: ehci-platform: EHCI generic platform driver [ 3.264967] 001: ehci-orion: EHCI orion driver [ 3.265021] 001: ehci-exynos: EHCI EXYNOS driver [ 3.265068] 001: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.265078] 001: ohci-pci: OHCI PCI platform driver [ 3.265102] 001: ohci-platform: OHCI generic platform driver [ 3.265158] 001: ohci-exynos: OHCI EXYNOS driver [ 3.265372] 001: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.265385] 001: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 3.265468] 001: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010 [ 3.265565] 001: xhci-hcd xhci-hcd.0.auto: irq 19, io mem 0x03100000 [ 3.266011] 001: hub 1-0:1.0: USB hub found [ 3.266026] 001: hub 1-0:1.0: 1 port detected [ 3.266190] 001: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.266196] 001: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 3.266243] 001: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.266276] 001: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.266527] 001: hub 2-0:1.0: USB hub found [ 3.266541] 001: hub 2-0:1.0: 1 port detected [ 3.266873] 001: usbcore: registered new interface driver usb-storage [ 3.268715] 001: ftm-alarm 2800000.timer: registered as rtc1 [ 3.269216] 001: i2c /dev entries driver [ 3.271413] 001: i2c i2c-0: Added multiplexed i2c bus 1 [ 3.271637] 001: i2c i2c-0: Added multiplexed i2c bus 2 [ 3.271828] 001: i2c i2c-0: Added multiplexed i2c bus 3 [ 3.277128] 001: rtc-pcf2127-i2c 4-0051: registered as rtc0 [ 3.277167] 001: i2c i2c-0: Added multiplexed i2c bus 4 [ 3.277288] 001: i2c i2c-0: Added multiplexed i2c bus 5 [ 3.277404] 001: i2c i2c-0: Added multiplexed i2c bus 6 [ 3.277601] 001: i2c i2c-0: Added multiplexed i2c bus 7 [ 3.277710] 001: i2c i2c-0: Added multiplexed i2c bus 8 [ 3.277715] 001: pca954x 0-0077: registered 8 multiplexed busses for I2C mux pca9847 [ 3.279907] 001: sp805-wdt c000000.watchdog: registration successful [ 3.280004] 001: sp805-wdt c010000.watchdog: registration successful [ 3.280959] 001: qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver [ 3.281223] 001: sdhci: Secure Digital Host Controller Interface driver [ 3.281225] 001: sdhci: Copyright(c) Pierre Ossman [ 3.281442] 001: Synopsys Designware Multimedia Card Interface Driver [ 3.281900] 001: sdhci-pltfm: SDHCI platform and OF driver helper [ 3.282313] 001: sdhci-esdhc 2140000.mmc: Adding to iommu group 10 [ 3.306928] 001: mmc0: SDHCI controller on 2140000.mmc [2140000.mmc] using ADMA [ 3.307167] 001: sdhci-esdhc 2150000.mmc: Adding to iommu group 11 [ 3.334813] 000: mmc1: SDHCI controller on 2150000.mmc [2150000.mmc] using ADMA [ 3.343582] 001: caam 8000000.crypto: device ID = 0x0a12070000000000 (Era 10) [ 3.343603] 001: caam 8000000.crypto: job rings = 3, qi = 0 [ 3.349309] 001: caam_jr 8010000.jr: Adding to iommu group 12 [ 3.358964] 001: caam algorithms registered in /proc/crypto [ 3.361018] 001: caam 8000000.crypto: caam pkc algorithms registered in /proc/crypto [ 3.361417] 001: caam_jr 8010000.jr: registering rng-caam [ 3.361513] 001: caam_jr 8020000.jr: Adding to iommu group 13 [ 3.361888] 001: caam_jr 8030000.jr: Adding to iommu group 14 [ 3.362852] 001: usbcore: registered new interface driver usbhid [ 3.362856] 001: usbhid: USB HID core driver [ 3.363778] 000: No fsl,qman node [ 3.363781] 000: Freescale USDPAA process driver [ 3.363783] 000: fsl-usdpaa: no region found [ 3.363784] 000: Freescale USDPAA process IRQ driver [ 3.365525] 000: optee: probing for conduit method from DT. [ 3.365531] 000: optee: api uid mismatch [ 3.365728] 000: galcore f0c0000.gpu: Adding to iommu group 15 [ 3.365820] 000: Galcore version 6.4.0.234062 [ 3.402486] 001: pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 3.411248] 001: NET: Registered protocol family 26 [ 3.411258] 001: GACT probability NOT on [ 3.411264] 001: Mirror/redirect action on [ 3.411288] 001: u32 classifier [ 3.411289] 001: input device check on [ 3.411291] 001: Actions configured [ 3.411826] 001: Initializing XFRM netlink socket [ 3.412089] 001: NET: Registered protocol family 10 [ 3.416158] 000: mmc1: new HS400 MMC card at address 0001 [ 3.416592] 000: mmcblk1: mmc1:0001 Q2J55L 7.13 GiB [ 3.416812] 001: Segment Routing with IPv6 [ 3.416815] 000: mmcblk1boot0: mmc1:0001 Q2J55L partition 1 2.00 MiB [ 3.416895] 001: sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.417048] 000: mmcblk1boot1: mmc1:0001 Q2J55L partition 2 2.00 MiB [ 3.417226] 000: mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (508:0) [ 3.417432] 001: NET: Registered protocol family 17 [ 3.417463] 001: NET: Registered protocol family 15 [ 3.417536] 001: Bridge firewalling registered [ 3.421743] 001: 8021q: 802.1Q VLAN Support v1.8 [ 3.421758] 001: lib80211: common routines for IEEE802.11 drivers [ 3.421858] 001: 9pnet: Installing 9P2000 support [ 3.421876] 001: tsn generic netlink module v1 init... [ 3.421915] 001: Key type dns_resolver registered [ 3.422276] 001: registered taskstats version 1 [ 3.422279] 001: Loading compiled-in X.509 certificates [ 3.422703] 000: mmcblk1: p1 [ 3.471998] 001: mmc0: new ultra high speed SDR104 SDHC card at address 0001 [ 3.764244] 001: mmcblk0: mmc0:0001 EB1QT 29.8 GiB [ 3.910926] 001: Btrfs loaded, crc32c=crc32c-generic [ 3.997641] 001: pcieport 0001:00:00.0: Adding to iommu group 16 [ 3.997889] 001: pcieport 0001:00:00.0: PME: Signaling with IRQ 103 [ 4.002365] 001: mmcblk0: p1 p2 [ 4.121098] 001: pcieport 0001:00:00.0: AER: enabled with IRQ 104 [ 4.264500] 001: pcieport 0002:00:00.0: Adding to iommu group 17 [ 4.337158] 001: pcieport 0002:00:00.0: PME: Signaling with IRQ 105 [ 4.337349] 001: pcieport 0002:00:00.0: AER: enabled with IRQ 106 [ 4.344922] 001: libphy: VSC9959 internal MDIO bus: probed [ 4.345195] 001: mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 0 [ 4.345467] 001: mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 1 [ 4.345737] 001: mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 2 [ 4.346007] 001: mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 3 [ 4.611128] 001: mscc_felix 0000:00:00.5 swp0 (uninitialized): PHY [0000:00:00.3:10] driver [Microsemi GE VSC8514 SyncE] [ 4.855123] 001: mscc_felix 0000:00:00.5 swp1 (uninitialized): PHY [0000:00:00.3:11] driver [Microsemi GE VSC8514 SyncE] [ 5.095124] 001: mscc_felix 0000:00:00.5 swp2 (uninitialized): PHY [0000:00:00.3:12] driver [Microsemi GE VSC8514 SyncE] [ 5.343125] 001: mscc_felix 0000:00:00.5 swp3 (uninitialized): PHY [0000:00:00.3:13] driver [Microsemi GE VSC8514 SyncE] [ 5.343554] 001: mscc_felix 0000:00:00.5: configuring for fixed/internal link mode [ 5.343576] 001: mscc_felix 0000:00:00.5: Link is Up - 2.5Gbps/Full - flow control off [ 5.343594] 001: DSA: tree 0 setup [ 5.346976] 001: rtc-pcf2127-i2c 4-0051: setting system clock to 2021-01-29T06:42:20 UTC (1611902540) [ 5.347188] 001: ALSA device list: [ 5.347193] 001: No soundcards found. [ 5.405610] 001: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.405627] 001: ext4 filesystem being mounted at /root supports timestamps until 2038 (0x7fffffff) [ 5.405651] 001: VFS: Mounted root (ext4 filesystem) on device 179:98. [ 5.406129] 001: devtmpfs: mounted [ 5.409579] 001: Freeing unused kernel memory: 5888K [ 5.409691] 001: Run /sbin/init as init process [ 5.451418] 000: random: fast init done [ 5.500188] 001: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 5.500200] 001: ext4 filesystem being remounted at / supports timestamps until 2038 (0x7fffffff) [ 5.700919] 001: udevd[403]: starting version 3.2.9 [ 5.718841] 001: random: udevd: uninitialized urandom read (16 bytes read) [ 5.719538] 001: random: udevd: uninitialized urandom read (16 bytes read) [ 5.719577] 001: random: udevd: uninitialized urandom read (16 bytes read) [ 5.732954] 001: udevd[404]: starting eudev-3.2.9 [ 6.119966] 001: mali-dp f080000.display: Adding to iommu group 18 [ 6.120131] 001: [drm] found ARM Mali-DP500 version r1p2 [ 6.120347] 001: cdns-mhdp-imx f200000.display: IRQ plug_in not found [ 6.120351] 001: cdns-mhdp-imx f200000.display: No plug_in irq number [ 6.120354] 001: cdns-mhdp-imx f200000.display: IRQ plug_out not found [ 6.120357] 001: cdns-mhdp-imx f200000.display: No plug_out irq number [ 6.120360] 001: cdns-mhdp-imx f200000.display: lane-mapping 0x4e [ 6.121646] 001: [drm] Started firmware! [ 6.121777] 001: [drm:cdns_mhdp_firmware_init_imx8qm] *ERROR* NO HDMI FW running [ 6.121917] 001: [drm:__cdns_dp_probe] *ERROR* NO dp FW running [ 6.121935] 001: mali-dp f080000.display: failed to bind f200000.display (ops cdns_mhdp_imx_ops): -6 [ 6.121940] 001: [drm:malidp_bind [mali_dp]] *ERROR* Failed to bind all components [ 6.122858] 001: mali-dp f080000.display: master bind failed: -6 [ 6.155664] 001: ina2xx 3-0040: power monitor ina220 (Rshunt = 500 uOhm) [ 6.162890] 001: pn54x_dev_init [ 6.162961] 001: pn54x_probe [ 6.162971] 001: pn544 7-0028: FIRM GPIO <OPTIONAL> error getting from OF node [ 6.162977] 001: pn544 7-0028: CLKREQ GPIO <OPTIONAL> error getting from OF node [ 6.162986] 001: pn544 7-0028: 7-0028 supply nxp,pn54x-pvdd not found, using dummy regulator [ 6.163029] 001: pn544 7-0028: 7-0028 supply nxp,pn54x-vbat not found, using dummy regulator [ 6.163064] 001: pn544 7-0028: 7-0028 supply nxp,pn54x-pmuvcc not found, using dummy regulator [ 6.163094] 001: pn544 7-0028: 7-0028 supply nxp,pn54x-sevdd not found, using dummy regulator [ 6.166866] 001: sgtl5000 2-000a: sgtl5000 revision 0x11 [ 6.171013] 001: fsl_enetc 0000:00:00.2 eno2: renamed from eth1 [ 6.176418] 001: sgtl5000 2-000a: Using internal LDO instead of VDDD: check ER1 erratum [ 6.190649] 001: fsl_enetc 0000:00:00.0 eno0: renamed from eth0 [ 6.216654] 001: CAN device driver interface [ 6.221979] 001: flexcan 2180000.can: 2180000.can supply xceiver not found, using dummy regulator [ 6.222724] 001: flexcan 2190000.can: 2190000.can supply xceiver not found, using dummy regulator [ 6.232856] 001: asoc-simple-card sound: sgtl5000 <-> f130000.audio-controller mapping ok [ 6.232885] 001: asoc-simple-card sound: ASoC: no DMI vendor name! done Initializing random number generator: OK Saving random seed: OK [ 7.476943] 001: urandom_read: 6 callbacks suppressed [ 7.476952] 001: random: dd: uninitialized urandom read (512 bytes read) Starting haveged: haveged: listening socket at 3 OK Starting system message bus: done Starting network: OK Starting dhcpcd... no interfaces have a carrier fo[ 7.996946] 000: Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000 [ 8.006399] 000: Mem abort info: [ 8.009632] 000: ESR = 0x96000046 [ 8.013129] 000: EC = 0x25: DABT (current EL), IL = 32 bits [ 8.018894] 000: SET = 0, FnV = 0 [ 8.022391] 000: EA = 0, S1PTW = 0 [ 8.025971] 000: Data abort info: [ 8.029293] 000: ISV = 0, ISS = 0x00000046 [ 8.033574] 000: CM = 0, WnR = 1 [ 8.036982] 000: user pgtable: 4k pages, 48-bit VAs, pgdp=00000020f7f37000 [ 8.043880] 000: [0000000000000000] pgd=00000020f7d6e003 [ 8.049207] 000: , pud=00000020f7daa003 [ 8.053051] 000: , pmd=0000000000000000 [ 8.056896] 000: [ 8.058822] 000: Internal error: Oops: 96000046 [#1] PREEMPT_RT SMP [ 8.065108] 000: Modules linked in: [ 8.068600] 000: flexcan [ 8.071220] 000: can_dev [ 8.073840] 000: pn5xx_i2c [ 8.076635] 000: snd_soc_sgtl5000 [ 8.080040] 000: lm90 [ 8.082398] 000: ina2xx [ 8.084932] 000: mali_dp [ 8.087551] 000: [ 8.089475] 000: CPU: 0 PID: 510 Comm: irq/113-eno0-rx Not tainted 5.4.3-rt1 #1 [ 8.096808] 000: Hardware name: LS1028A RDB Board (DT) [ 8.101958] 000: pstate: 60000005 (nZCv daif -PAN -UAO) [ 8.107196] 000: pc : enetc_msix+0x30/0xe0 [ 8.111308] 000: lr : enetc_msix+0x28/0xe0 [ 8.115412] 000: sp : ffff800010debd60 [ 8.119167] 000: x29: ffff800010debd60 [ 8.123008] 000: x28: ffff002077ec6580 [ 8.126850] 000: [ 8.128772] 000: x27: ffff002077ec6580 [ 8.132613] 000: x26: ffffdd2a363373c0 [ 8.136454] 000: [ 8.138376] 000: x25: 0000000000000001 [ 8.142217] 000: x24: ffff002077ec6580 [ 8.146058] 000: [ 8.147980] 000: x23: ffffdd2a36336bb0 [ 8.151822] 000: x22: ffff0020799b8200 [ 8.155663] 000: [ 8.157585] 000: x21: ffff002079999810 [ 8.161426] 000: x20: ffffdd2a384db448 [ 8.165267] 000: [ 8.167189] 000: x19: ffff002079999800 [ 8.171030] 000: x18: 0000000000000000 [ 8.174872] 000: [ 8.176795] 000: x17: 0000000000000000 [ 8.180636] 000: x16: 0000000000000000 [ 8.184477] 000: [ 8.183802] 001: random: crng init done [ 8.186399] 000: x15: 0000000000000000 [ 8.194086] 000: x14: 0000000000000000 [ 8.197927] 000: [ 8.199850] 000: x13: 00000000000003dd [ 8.203691] 000: x12: 0000000000000000 [ 8.207531] 000: [ 8.209454] 000: x11: 0000000000000000 [ 8.213295] 000: x10: 0000000000000a40 [ 8.217135] 000: [ 8.219057] 000: x9 : ffff800010debb40 [ 8.222898] 000: x8 : ffff002077ec7020 [ 8.226739] 000: [ 8.228661] 000: x7 : ffff00207b9de7c0 [ 8.232502] 000: x6 : ffff00207b9ddd80 [ 8.236343] 000: [ 8.238265] 000: x5 : 0000000000000000 [ 8.242106] 000: x4 : 0000000080000000 [ 8.245947] 000: [ 8.247869] 000: x3 : ffffdd2a384db470 [ 8.251710] 000: x2 : 0000000080000001 [ 8.255551] 000: [ 8.257473] 000: x1 : cccedfb3c69b7100 [ 8.261314] 000: x0 : 0000000000000000 [ 8.265154] 000: [ 8.267076] 000: Call trace: [ 8.269959] 000: enetc_msix+0x30/0xe0 [ 8.273716] 000: irq_forced_thread_fn+0x38/0xc0 [ 8.278346] 000: irq_thread+0x138/0x240 [ 8.282276] 000: kthread+0xf4/0x120 [ 8.285858] 000: ret_from_fork+0x10/0x18 [ 8.289881] 000: Code: aa0103f5 941cce9b f84106a0 d50332bf (b900001f) [ 8.296429] 000: ---[ end trace 0000000000000002 ]--- [ 8.301515] 000: genirq: exiting task "irq/113-eno0-rx" (510) is an active IRQ thread (irq 113) [ 18.250233] 001: mmc0: Timeout waiting for hardware interrupt. [ 18.256124] 001: mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 18.263047] 001: mmc0: sdhci: Sys addr: 0x00000002 | Version: 0x00002202 [ 18.269972] 001: mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000000 [ 18.276894] 001: mmc0: sdhci: Argument: 0x000a2e18 | Trn mode: 0x0000003b [ 18.283816] 001: mmc0: sdhci: Present: 0x01fd0008 | Host ctl: 0x00000032 [ 18.290737] 001: mmc0: sdhci: Power: 0x00000006 | Blk gap: 0x00000000 [ 18.297656] 001: mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000028 [ 18.304575] 001: mmc0: sdhci: Timeout: 0x0000000b | Int stat: 0x0000000b [ 18.311494] 001: mmc0: sdhci: Int enab: 0x037f108f | Sig enab: 0x037f108b [ 18.318412] 001: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00002202 [ 18.325330] 001: mmc0: sdhci: Caps: 0x01fa0000 | Caps_1: 0x0000af00 [ 18.332248] 001: mmc0: sdhci: Cmd: 0x0000123a | Max curr: 0x00000000 [ 18.339166] 001: mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x00ee7f12 [ 18.346084] 001: mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900 [ 18.353003] 001: mmc0: sdhci: Host ctl2: 0x00000083 [ 18.357917] 001: mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xe7447208 [ 18.364835] 001: mmc0: sdhci: ============================================
Vladimir,
-----Original Message----- From: Vladimir Oltean olteanv@gmail.com Sent: Wednesday, January 27, 2021 9:20 PM To: Wasim Khan (OSS) wasim.khan@oss.nxp.com Cc: u-boot@lists.denx.de; sjg@chromium.org; bmeng.cn@gmail.com; mario.six@gdsys.cc; bharat.gooty@broadcom.com; rayagonda.kokatanur@broadcom.com; t-kristo@ti.com; Varun Sethi V.Sethi@nxp.com; Wasim Khan wasim.khan@nxp.com Subject: Re: [PATCH 2/4] arch: arm: update Kconfig to select IRQ when GIC_V3_ITS is enabled
Wasim,
On Tue, Jan 12, 2021 at 10:05:07AM +0100, Wasim Khan wrote:
GIC_V3_ITS uses UCLASS_IRQ driver. Update Kconfig to select IRQ when GIC_V3_ITS is enabled.
Signed-off-by: Wasim Khan wasim.khan@nxp.com
While this fixes my U-Boot booting issue on NXP LS1028A-RDB (thank you for that):
I'm thinking it would be unwise to apply the patches as-is, since now, the GIC-v3 ITS driver does bind, but when Linux boots, apparently it now sees some IRQ storms and dies very quickly in the boot process. Did you try to boot Linux after these patches?
On the other hand, the board works just fine with CONFIG_GIC_V3_ITS disabled. The kontron_sl28_defconfig doesn't even have it. What do we use the GIC ITS for in U-Boot?
One boot attempt:
[ 1.940732] 000: Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
Thanks for reporting this. Yes, I tested LX2162aqds and did not face any issue in the limited trials I performed. I agree with you to hold on this series until crash you reported is fixed.
use 'select' to enable IRQ as it does not have architecture specific dependency.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- arch/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 3aa99e08fc..362b220948 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -167,6 +167,7 @@ config X86 select TIMER select USE_PRIVATE_LIBGCC select X86_TSC_TIMER + select IRQ imply HAS_ROM if X86_RESET_VECTOR imply BLK imply CMD_DM @@ -197,7 +198,6 @@ config X86 imply USB_HOST_ETHER imply PCH imply RTC_MC146818 - imply IRQ imply ACPIGEN if !QEMU imply SYSINFO if GENERATE_SMBIOS_TABLE imply SYSINFO_SMBIOS if GENERATE_SMBIOS_TABLE
Enable IRQ using select for sandbox architecture.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- arch/Kconfig | 1 + configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 1 - configs/sandbox_flattree_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - 5 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 362b220948..336a5a68ef 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -109,6 +109,7 @@ config SANDBOX select SPI select SUPPORT_OF_CONTROL select SYSRESET_CMD_POWEROFF + select IRQ imply BITREVERSE select BLOBLIST imply CMD_DM diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 5fbbfd7236..534f58f868 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -133,7 +133,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f1ec701a9f..56f83695e0 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -160,7 +160,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index edca7f1808..8098d652dc 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -114,7 +114,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 479f0226e3..0afb0bec34 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -134,7 +134,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y
UCLASS_IRQ driver is not Intel specific. Make CONFIG_IRQ selectable for all platfroms.
drivers/misc/Kconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
Tested-by: Vladimir Oltean vladimir.oltean@nxp.com
Vladimir Oltean
Wasim Khan
Wasim Khan
