[U-Boot] [PATCH] nand: Remove unused CONFIG_MTD_NAND_ECC_JFFS2 option
This option was removed along with legacy NAND support in be33b046b549ad88c204c209508cd7657232ffbd. Clean up some remnants.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- doc/README.nand | 12 ------------ include/configs/ethernut5.h | 1 - 2 files changed, 13 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index dee0e00..46d7edd 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -99,12 +99,6 @@ Configuration Options: CONFIG_CMD_NAND_TORTURE Enables the torture command (see description of this command below).
- CONFIG_MTD_NAND_ECC_JFFS2 - Define this if you want the Error Correction Code information in - the out-of-band data to be formatted to match the JFFS2 file system. - CONFIG_MTD_NAND_ECC_YAFFS would be another useful choice for - someone to implement. - CONFIG_SYS_MAX_NAND_DEVICE The maximum number of NAND devices you want to support.
@@ -312,12 +306,6 @@ Platform specific options NOTE: =====
-The current NAND implementation is based on what is in recent -Linux kernels. The old legacy implementation has been removed. - -If you have board code which used CONFIG_NAND_LEGACY, you'll need -to convert to the current NAND interface for it to continue to work. - The Disk On Chip driver is currently broken and has been for some time. There is a driver in drivers/mtd/nand, taken from Linux, that works with the current NAND system but has not yet been adapted to the u-boot diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index ce61a16..b79000e 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -153,7 +153,6 @@
/* JFFS2 */ #ifdef CONFIG_CMD_JFFS2 -#define CONFIG_MTD_NAND_ECC_JFFS2 #define CONFIG_JFFS2_CMDLINE #define CONFIG_JFFS2_NAND #endif
Peter Tyser
