[PATCH] lmb: notify when adjacent regions are added
lmb_add_region() returns a positive integer if the added regions causes existing regions to be coalesced. We still want to notify the EFI subsystem about these added regions though, so adjust lmb_add() to only bail on errors.
This fixes EFI memory allocation on boards with adjacent memory banks as is the case on several Qualcomm boards like the RB3 Gen 2.
Fixes: 2f6191526a13 (lmb: notify of any changes to the LMB memory map) Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Cc: u-boot-qcom@groups.io --- lib/lmb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 78fe2d4de7c6..7e90f178763b 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -486,9 +486,9 @@ long lmb_add(phys_addr_t base, phys_size_t size) long ret; struct alist *lmb_rgn_lst = &lmb.free_mem;
ret = lmb_add_region(lmb_rgn_lst, base, size); - if (ret) + if (ret < 0) return ret;
if (lmb_should_notify(LMB_NONE)) return lmb_map_update_notify(base, size, MAP_OP_ADD);
On Fri, 18 Oct 2024 at 19:23, Caleb Connolly caleb.connolly@linaro.org wrote:
Reviewed-by: Sughosh Ganu sughosh.ganu@linaro.org
-sughosh
if (ret)
if (ret < 0) return ret; if (lmb_should_notify(LMB_NONE)) return lmb_map_update_notify(base, size, MAP_OP_ADD);
-- 2.46.2
- if (ret)
Tested-by: Neil Armstrong neil.armstrong@linaro.org
Thanks ! Neil
Thanks Caleb,
On Fri, 18 Oct 2024 at 16:53, Caleb Connolly caleb.connolly@linaro.org wrote:
if (ret)
-- 2.46.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Hi Caleb,
On Fri, 18 Oct 2024 at 08:08, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Thanks Caleb,
if (ret)
-- 2.46.2
Is it possible to add a test for this case? It is a good idea to plug a testing gap when fixing a bug.
participants (6)
Caleb Connolly
Ilias Apalodimas
Sughosh Ganu
