[U-Boot] [PATCH v4 19/36] sf: Remove unneeded flash drivers files
Now the common probing is handled in spi_flash_probe.c hence removed the unneeded flash drivers.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v4: - none Changes for v3: - none Changes for v2: - none
drivers/mtd/spi/Makefile | 8 - drivers/mtd/spi/atmel.c | 544 ----------------------------------- drivers/mtd/spi/eon.c | 60 ---- drivers/mtd/spi/gigadevice.c | 65 ----- drivers/mtd/spi/macronix.c | 98 ------- drivers/mtd/spi/spansion.c | 141 --------- drivers/mtd/spi/spi_flash_internal.h | 11 - drivers/mtd/spi/sst.c | 238 --------------- drivers/mtd/spi/stmicro.c | 202 ------------- drivers/mtd/spi/winbond.c | 141 --------- 10 files changed, 1508 deletions(-) delete mode 100644 drivers/mtd/spi/atmel.c delete mode 100644 drivers/mtd/spi/eon.c delete mode 100644 drivers/mtd/spi/gigadevice.c delete mode 100644 drivers/mtd/spi/macronix.c delete mode 100644 drivers/mtd/spi/spansion.c delete mode 100644 drivers/mtd/spi/sst.c delete mode 100644 drivers/mtd/spi/stmicro.c delete mode 100644 drivers/mtd/spi/winbond.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 2605e57..5678134 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -18,14 +18,6 @@ ifdef CONFIG_CMD_SF COBJS-y += spi_flash.o endif COBJS-$(CONFIG_SPI_FLASH) += spi_flash_probe.o spi_flash_ops.o -COBJS-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o -COBJS-$(CONFIG_SPI_FLASH_EON) += eon.o -COBJS-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o -COBJS-$(CONFIG_SPI_FLASH_MACRONIX) += macronix.o -COBJS-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o -COBJS-$(CONFIG_SPI_FLASH_SST) += sst.o -COBJS-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o -COBJS-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o COBJS-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o COBJS-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o
diff --git a/drivers/mtd/spi/atmel.c b/drivers/mtd/spi/atmel.c deleted file mode 100644 index f34df43..0000000 --- a/drivers/mtd/spi/atmel.c +++ /dev/null @@ -1,544 +0,0 @@ -/* - * Atmel SPI DataFlash support - * - * Copyright (C) 2008 Atmel Corporation - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -/* AT45-specific commands */ -#define CMD_AT45_READ_STATUS 0xd7 -#define CMD_AT45_ERASE_PAGE 0x81 -#define CMD_AT45_LOAD_PROG_BUF1 0x82 -#define CMD_AT45_LOAD_BUF1 0x84 -#define CMD_AT45_LOAD_PROG_BUF2 0x85 -#define CMD_AT45_LOAD_BUF2 0x87 -#define CMD_AT45_PROG_BUF1 0x88 -#define CMD_AT45_PROG_BUF2 0x89 - -/* AT45 status register bits */ -#define AT45_STATUS_P2_PAGE_SIZE (1 << 0) -#define AT45_STATUS_READY (1 << 7) - -/* DataFlash family IDs, as obtained from the second idcode byte */ -#define DF_FAMILY_AT26F 0 -#define DF_FAMILY_AT45 1 -#define DF_FAMILY_AT26DF 2 /* AT25DF and AT26DF */ - -struct atmel_spi_flash_params { - u8 idcode1; - /* Log2 of page size in power-of-two mode */ - u8 l2_page_size; - u8 pages_per_block; - u8 blocks_per_sector; - u8 nr_sectors; - const char *name; -}; - -/* spi_flash needs to be first so upper layers can free() it */ -struct atmel_spi_flash { - struct spi_flash flash; - const struct atmel_spi_flash_params *params; -}; - -static inline struct atmel_spi_flash * -to_atmel_spi_flash(struct spi_flash *flash) -{ - return container_of(flash, struct atmel_spi_flash, flash); -} - -static const struct atmel_spi_flash_params atmel_spi_flash_table[] = { - { - .idcode1 = 0x22, - .l2_page_size = 8, - .pages_per_block = 8, - .blocks_per_sector = 16, - .nr_sectors = 4, - .name = "AT45DB011D", - }, - { - .idcode1 = 0x23, - .l2_page_size = 8, - .pages_per_block = 8, - .blocks_per_sector = 16, - .nr_sectors = 8, - .name = "AT45DB021D", - }, - { - .idcode1 = 0x24, - .l2_page_size = 8, - .pages_per_block = 8, - .blocks_per_sector = 32, - .nr_sectors = 8, - .name = "AT45DB041D", - }, - { - .idcode1 = 0x25, - .l2_page_size = 8, - .pages_per_block = 8, - .blocks_per_sector = 32, - .nr_sectors = 16, - .name = "AT45DB081D", - }, - { - .idcode1 = 0x26, - .l2_page_size = 9, - .pages_per_block = 8, - .blocks_per_sector = 32, - .nr_sectors = 16, - .name = "AT45DB161D", - }, - { - .idcode1 = 0x27, - .l2_page_size = 9, - .pages_per_block = 8, - .blocks_per_sector = 64, - .nr_sectors = 64, - .name = "AT45DB321D", - }, - { - .idcode1 = 0x28, - .l2_page_size = 10, - .pages_per_block = 8, - .blocks_per_sector = 32, - .nr_sectors = 32, - .name = "AT45DB642D", - }, - { - .idcode1 = 0x47, - .l2_page_size = 8, - .pages_per_block = 16, - .blocks_per_sector = 16, - .nr_sectors = 64, - .name = "AT25DF321", - }, -}; - -static int at45_wait_ready(struct spi_flash *flash, unsigned long timeout) -{ - struct spi_slave *spi = flash->spi; - unsigned long timebase; - int ret; - u8 cmd = CMD_AT45_READ_STATUS; - u8 status; - - timebase = get_timer(0); - - ret = spi_xfer(spi, 8, &cmd, NULL, SPI_XFER_BEGIN); - if (ret) - return -1; - - do { - ret = spi_xfer(spi, 8, NULL, &status, 0); - if (ret) - return -1; - - if (status & AT45_STATUS_READY) - break; - } while (get_timer(timebase) < timeout); - - /* Deactivate CS */ - spi_xfer(spi, 0, NULL, NULL, SPI_XFER_END); - - if (status & AT45_STATUS_READY) - return 0; - - /* Timed out */ - return -1; -} - -/* - * Assemble the address part of a command for AT45 devices in - * non-power-of-two page size mode. - */ -static void at45_build_address(struct atmel_spi_flash *asf, u8 *cmd, u32 offset) -{ - unsigned long page_addr; - unsigned long byte_addr; - unsigned long page_size; - unsigned int page_shift; - - /* - * The "extra" space per page is the power-of-two page size - * divided by 32. - */ - page_shift = asf->params->l2_page_size; - page_size = (1 << page_shift) + (1 << (page_shift - 5)); - page_shift++; - page_addr = offset / page_size; - byte_addr = offset % page_size; - - cmd[0] = page_addr >> (16 - page_shift); - cmd[1] = page_addr << (page_shift - 8) | (byte_addr >> 8); - cmd[2] = byte_addr; -} - -static int dataflash_read_fast_at45(struct spi_flash *flash, - u32 offset, size_t len, void *buf) -{ - struct atmel_spi_flash *asf = to_atmel_spi_flash(flash); - u8 cmd[5]; - - cmd[0] = CMD_READ_ARRAY_FAST; - at45_build_address(asf, cmd + 1, offset); - cmd[4] = 0x00; - - return spi_flash_read_common(flash, cmd, sizeof(cmd), buf, len); -} - -/* - * TODO: the two write funcs (_p2/_at45) should get unified ... - */ -static int dataflash_write_p2(struct spi_flash *flash, - u32 offset, size_t len, const void *buf) -{ - struct atmel_spi_flash *asf = to_atmel_spi_flash(flash); - unsigned long page_size; - u32 addr = offset; - size_t chunk_len; - size_t actual; - int ret; - u8 cmd[4]; - - /* - * TODO: This function currently uses only page buffer #1. We can - * speed this up by using both buffers and loading one buffer while - * the other is being programmed into main memory. - */ - - page_size = (1 << asf->params->l2_page_size); - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual += chunk_len) { - chunk_len = min(len - actual, page_size - (addr % page_size)); - - /* Use the same address bits for both commands */ - cmd[0] = CMD_AT45_LOAD_BUF1; - cmd[1] = addr >> 16; - cmd[2] = addr >> 8; - cmd[3] = addr; - - ret = spi_flash_cmd_write(flash->spi, cmd, 4, - buf + actual, chunk_len); - if (ret < 0) { - debug("SF: Loading AT45 buffer failed\n"); - goto out; - } - - cmd[0] = CMD_AT45_PROG_BUF1; - ret = spi_flash_cmd_write(flash->spi, cmd, 4, NULL, 0); - if (ret < 0) { - debug("SF: AT45 page programming failed\n"); - goto out; - } - - ret = at45_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret < 0) { - debug("SF: AT45 page programming timed out\n"); - goto out; - } - - addr += chunk_len; - } - - debug("SF: AT45: Successfully programmed %zu bytes @ 0x%x\n", - len, offset); - ret = 0; - -out: - spi_release_bus(flash->spi); - return ret; -} - -static int dataflash_write_at45(struct spi_flash *flash, - u32 offset, size_t len, const void *buf) -{ - struct atmel_spi_flash *asf = to_atmel_spi_flash(flash); - unsigned long page_addr; - unsigned long byte_addr; - unsigned long page_size; - unsigned int page_shift; - size_t chunk_len; - size_t actual; - int ret; - u8 cmd[4]; - - /* - * TODO: This function currently uses only page buffer #1. We can - * speed this up by using both buffers and loading one buffer while - * the other is being programmed into main memory. - */ - - page_shift = asf->params->l2_page_size; - page_size = (1 << page_shift) + (1 << (page_shift - 5)); - page_shift++; - page_addr = offset / page_size; - byte_addr = offset % page_size; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual += chunk_len) { - chunk_len = min(len - actual, page_size - byte_addr); - - /* Use the same address bits for both commands */ - cmd[0] = CMD_AT45_LOAD_BUF1; - cmd[1] = page_addr >> (16 - page_shift); - cmd[2] = page_addr << (page_shift - 8) | (byte_addr >> 8); - cmd[3] = byte_addr; - - ret = spi_flash_cmd_write(flash->spi, cmd, 4, - buf + actual, chunk_len); - if (ret < 0) { - debug("SF: Loading AT45 buffer failed\n"); - goto out; - } - - cmd[0] = CMD_AT45_PROG_BUF1; - ret = spi_flash_cmd_write(flash->spi, cmd, 4, NULL, 0); - if (ret < 0) { - debug("SF: AT45 page programming failed\n"); - goto out; - } - - ret = at45_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret < 0) { - debug("SF: AT45 page programming timed out\n"); - goto out; - } - - page_addr++; - byte_addr = 0; - } - - debug("SF: AT45: Successfully programmed %zu bytes @ 0x%x\n", - len, offset); - ret = 0; - -out: - spi_release_bus(flash->spi); - return ret; -} - -/* - * TODO: the two erase funcs (_p2/_at45) should get unified ... - */ -static int dataflash_erase_p2(struct spi_flash *flash, u32 offset, size_t len) -{ - struct atmel_spi_flash *asf = to_atmel_spi_flash(flash); - unsigned long page_size; - - size_t actual; - int ret; - u8 cmd[4]; - - /* - * TODO: This function currently uses page erase only. We can - * probably speed things up by using block and/or sector erase - * when possible. - */ - - page_size = (1 << asf->params->l2_page_size); - - if (offset % page_size || len % page_size) { - debug("SF: Erase offset/length not multiple of page size\n"); - return -1; - } - - cmd[0] = CMD_AT45_ERASE_PAGE; - cmd[3] = 0x00; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual += page_size) { - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - - ret = spi_flash_cmd_write(flash->spi, cmd, 4, NULL, 0); - if (ret < 0) { - debug("SF: AT45 page erase failed\n"); - goto out; - } - - ret = at45_wait_ready(flash, SPI_FLASH_PAGE_ERASE_TIMEOUT); - if (ret < 0) { - debug("SF: AT45 page erase timed out\n"); - goto out; - } - - offset += page_size; - } - - debug("SF: AT45: Successfully erased %zu bytes @ 0x%x\n", - len, offset); - ret = 0; - -out: - spi_release_bus(flash->spi); - return ret; -} - -static int dataflash_erase_at45(struct spi_flash *flash, u32 offset, size_t len) -{ - struct atmel_spi_flash *asf = to_atmel_spi_flash(flash); - unsigned long page_addr; - unsigned long page_size; - unsigned int page_shift; - size_t actual; - int ret; - u8 cmd[4]; - - /* - * TODO: This function currently uses page erase only. We can - * probably speed things up by using block and/or sector erase - * when possible. - */ - - page_shift = asf->params->l2_page_size; - page_size = (1 << page_shift) + (1 << (page_shift - 5)); - page_shift++; - page_addr = offset / page_size; - - if (offset % page_size || len % page_size) { - debug("SF: Erase offset/length not multiple of page size\n"); - return -1; - } - - cmd[0] = CMD_AT45_ERASE_PAGE; - cmd[3] = 0x00; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual += page_size) { - cmd[1] = page_addr >> (16 - page_shift); - cmd[2] = page_addr << (page_shift - 8); - - ret = spi_flash_cmd_write(flash->spi, cmd, 4, NULL, 0); - if (ret < 0) { - debug("SF: AT45 page erase failed\n"); - goto out; - } - - ret = at45_wait_ready(flash, SPI_FLASH_PAGE_ERASE_TIMEOUT); - if (ret < 0) { - debug("SF: AT45 page erase timed out\n"); - goto out; - } - - page_addr++; - } - - debug("SF: AT45: Successfully erased %zu bytes @ 0x%x\n", - len, offset); - ret = 0; - -out: - spi_release_bus(flash->spi); - return ret; -} - -struct spi_flash *spi_flash_probe_atmel(struct spi_slave *spi, u8 *idcode) -{ - const struct atmel_spi_flash_params *params; - unsigned page_size; - unsigned int family; - struct atmel_spi_flash *asf; - unsigned int i; - int ret; - u8 status; - - for (i = 0; i < ARRAY_SIZE(atmel_spi_flash_table); i++) { - params = &atmel_spi_flash_table[i]; - if (params->idcode1 == idcode[1]) - break; - } - - if (i == ARRAY_SIZE(atmel_spi_flash_table)) { - debug("SF: Unsupported DataFlash ID %02x\n", - idcode[1]); - return NULL; - } - - asf = spi_flash_alloc(struct atmel_spi_flash, spi, params->name); - if (!asf) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - asf->params = params; - - /* Assuming power-of-two page size initially. */ - page_size = 1 << params->l2_page_size; - - family = idcode[1] >> 5; - - switch (family) { - case DF_FAMILY_AT45: - /* - * AT45 chips have configurable page size. The status - * register indicates which configuration is active. - */ - ret = spi_flash_cmd(spi, CMD_AT45_READ_STATUS, &status, 1); - if (ret) - goto err; - - debug("SF: AT45 status register: %02x\n", status); - - if (!(status & AT45_STATUS_P2_PAGE_SIZE)) { - asf->flash.read = dataflash_read_fast_at45; - asf->flash.write = dataflash_write_at45; - asf->flash.erase = dataflash_erase_at45; - page_size += 1 << (params->l2_page_size - 5); - } else { - asf->flash.write = dataflash_write_p2; - asf->flash.erase = dataflash_erase_p2; - } - - asf->flash.page_size = page_size; - asf->flash.sector_size = page_size; - break; - - case DF_FAMILY_AT26F: - case DF_FAMILY_AT26DF: - asf->flash.page_size = page_size; - asf->flash.sector_size = 4096; - /* clear SPRL# bit for locked flash */ - spi_flash_cmd_write_status(&asf->flash, 0); - break; - - default: - debug("SF: Unsupported DataFlash family %u\n", family); - goto err; - } - - asf->flash.size = page_size * params->pages_per_block - * params->blocks_per_sector - * params->nr_sectors; - - return &asf->flash; - -err: - free(asf); - return NULL; -} diff --git a/drivers/mtd/spi/eon.c b/drivers/mtd/spi/eon.c deleted file mode 100644 index 25cfc12..0000000 --- a/drivers/mtd/spi/eon.c +++ /dev/null @@ -1,60 +0,0 @@ -/* - * (C) Copyright 2010, ucRobotics Inc. - * Author: Chong Huang chuang@ucrobotics.com - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -struct eon_spi_flash_params { - u8 idcode1; - u16 nr_sectors; - const char *name; -}; - -static const struct eon_spi_flash_params eon_spi_flash_table[] = { - { - .idcode1 = 0x16, - .nr_sectors = 1024, - .name = "EN25Q32B", - }, - { - .idcode1 = 0x18, - .nr_sectors = 4096, - .name = "EN25Q128", - }, -}; - -struct spi_flash *spi_flash_probe_eon(struct spi_slave *spi, u8 *idcode) -{ - const struct eon_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - - for (i = 0; i < ARRAY_SIZE(eon_spi_flash_table); ++i) { - params = &eon_spi_flash_table[i]; - if (params->idcode1 == idcode[2]) - break; - } - - if (i == ARRAY_SIZE(eon_spi_flash_table)) { - debug("SF: Unsupported EON ID %02x\n", idcode[1]); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - flash->page_size = 256; - flash->sector_size = 256 * 16 * 16; - flash->size = 256 * 16 * params->nr_sectors; - - return flash; -} diff --git a/drivers/mtd/spi/gigadevice.c b/drivers/mtd/spi/gigadevice.c deleted file mode 100644 index b42581a..0000000 --- a/drivers/mtd/spi/gigadevice.c +++ /dev/null @@ -1,65 +0,0 @@ -/* - * Gigadevice SPI flash driver - * Copyright 2013, Samsung Electronics Co., Ltd. - * Author: Banajit Goswami banajit.g@samsung.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -struct gigadevice_spi_flash_params { - uint16_t id; - uint16_t nr_blocks; - const char *name; -}; - -static const struct gigadevice_spi_flash_params gigadevice_spi_flash_table[] = { - { - .id = 0x6016, - .nr_blocks = 64, - .name = "GD25LQ", - }, - { - .id = 0x4017, - .nr_blocks = 128, - .name = "GD25Q64B", - }, -}; - -struct spi_flash *spi_flash_probe_gigadevice(struct spi_slave *spi, u8 *idcode) -{ - const struct gigadevice_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - - for (i = 0; i < ARRAY_SIZE(gigadevice_spi_flash_table); i++) { - params = &gigadevice_spi_flash_table[i]; - if (params->id == ((idcode[1] << 8) | idcode[2])) - break; - } - - if (i == ARRAY_SIZE(gigadevice_spi_flash_table)) { - debug("SF: Unsupported Gigadevice ID %02x%02x\n", - idcode[1], idcode[2]); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - /* page_size */ - flash->page_size = 256; - /* sector_size = page_size * pages_per_sector */ - flash->sector_size = flash->page_size * 16; - /* size = sector_size * sector_per_block * number of blocks */ - flash->size = flash->sector_size * 16 * params->nr_blocks; - - return flash; -} diff --git a/drivers/mtd/spi/macronix.c b/drivers/mtd/spi/macronix.c deleted file mode 100644 index 70435eb..0000000 --- a/drivers/mtd/spi/macronix.c +++ /dev/null @@ -1,98 +0,0 @@ -/* - * Copyright 2009(C) Marvell International Ltd. and its affiliates - * Prafulla Wadaskar prafulla@marvell.com - * - * Based on drivers/mtd/spi/stmicro.c - * - * Copyright 2008, Network Appliance Inc. - * Jason McMullan mcmullan@netapp.com - * - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -struct macronix_spi_flash_params { - u16 idcode; - u16 nr_blocks; - const char *name; -}; - -static const struct macronix_spi_flash_params macronix_spi_flash_table[] = { - { - .idcode = 0x2013, - .nr_blocks = 8, - .name = "MX25L4005", - }, - { - .idcode = 0x2014, - .nr_blocks = 16, - .name = "MX25L8005", - }, - { - .idcode = 0x2015, - .nr_blocks = 32, - .name = "MX25L1605D", - }, - { - .idcode = 0x2016, - .nr_blocks = 64, - .name = "MX25L3205D", - }, - { - .idcode = 0x2017, - .nr_blocks = 128, - .name = "MX25L6405D", - }, - { - .idcode = 0x2018, - .nr_blocks = 256, - .name = "MX25L12805D", - }, - { - .idcode = 0x2618, - .nr_blocks = 256, - .name = "MX25L12855E", - }, -}; - -struct spi_flash *spi_flash_probe_macronix(struct spi_slave *spi, u8 *idcode) -{ - const struct macronix_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - u16 id = idcode[2] | idcode[1] << 8; - - for (i = 0; i < ARRAY_SIZE(macronix_spi_flash_table); i++) { - params = ¯onix_spi_flash_table[i]; - if (params->idcode == id) - break; - } - - if (i == ARRAY_SIZE(macronix_spi_flash_table)) { - debug("SF: Unsupported Macronix ID %04x\n", id); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - flash->page_size = 256; - flash->sector_size = 256 * 16 * 16; - flash->size = flash->sector_size * params->nr_blocks; - - /* Clear BP# bits for read-only flash */ - spi_flash_cmd_write_status(flash, 0); - - return flash; -} diff --git a/drivers/mtd/spi/spansion.c b/drivers/mtd/spi/spansion.c deleted file mode 100644 index fa7ac8c..0000000 --- a/drivers/mtd/spi/spansion.c +++ /dev/null @@ -1,141 +0,0 @@ -/* - * Copyright (C) 2009 Freescale Semiconductor, Inc. - * - * Author: Mingkai Hu (Mingkai.hu@freescale.com) - * Based on stmicro.c by Wolfgang Denk (wd@denx.de), - * TsiChung Liew (Tsi-Chung.Liew@freescale.com), - * and Jason McMullan (mcmullan@netapp.com) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -struct spansion_spi_flash_params { - u16 idcode1; - u16 idcode2; - u16 pages_per_sector; - u16 nr_sectors; - const char *name; -}; - -static const struct spansion_spi_flash_params spansion_spi_flash_table[] = { - { - .idcode1 = 0x0213, - .idcode2 = 0, - .pages_per_sector = 256, - .nr_sectors = 16, - .name = "S25FL008A", - }, - { - .idcode1 = 0x0214, - .idcode2 = 0, - .pages_per_sector = 256, - .nr_sectors = 32, - .name = "S25FL016A", - }, - { - .idcode1 = 0x0215, - .idcode2 = 0, - .pages_per_sector = 256, - .nr_sectors = 64, - .name = "S25FL032A", - }, - { - .idcode1 = 0x0216, - .idcode2 = 0, - .pages_per_sector = 256, - .nr_sectors = 128, - .name = "S25FL064A", - }, - { - .idcode1 = 0x2018, - .idcode2 = 0x0301, - .pages_per_sector = 256, - .nr_sectors = 256, - .name = "S25FL128P_64K", - }, - { - .idcode1 = 0x2018, - .idcode2 = 0x0300, - .pages_per_sector = 1024, - .nr_sectors = 64, - .name = "S25FL128P_256K", - }, - { - .idcode1 = 0x0215, - .idcode2 = 0x4d00, - .pages_per_sector = 256, - .nr_sectors = 64, - .name = "S25FL032P", - }, - { - .idcode1 = 0x0216, - .idcode2 = 0x4d00, - .pages_per_sector = 256, - .nr_sectors = 128, - .name = "S25FL064P", - }, - { - .idcode1 = 0x2018, - .idcode2 = 0x4d01, - .pages_per_sector = 256, - .nr_sectors = 256, - .name = "S25FL129P_64K/S25FL128S_64K", - }, - { - .idcode1 = 0x0219, - .idcode2 = 0x4d01, - .pages_per_sector = 256, - .nr_sectors = 512, - .name = "S25FL256S_64K", - }, - { - .idcode1 = 0x0220, - .idcode2 = 0x4d01, - .pages_per_sector = 256, - .nr_sectors = 1024, - .name = "S25FL512S_64K", - }, -}; - -struct spi_flash *spi_flash_probe_spansion(struct spi_slave *spi, u8 *idcode) -{ - const struct spansion_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - unsigned short jedec, ext_jedec; - - jedec = idcode[1] << 8 | idcode[2]; - ext_jedec = idcode[3] << 8 | idcode[4]; - - for (i = 0; i < ARRAY_SIZE(spansion_spi_flash_table); i++) { - params = &spansion_spi_flash_table[i]; - if (params->idcode1 == jedec) { - if (params->idcode2 == ext_jedec) - break; - } - } - - if (i == ARRAY_SIZE(spansion_spi_flash_table)) { - debug("SF: Unsupported SPANSION ID %04x %04x\n", - jedec, ext_jedec); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - flash->page_size = 256; - flash->sector_size = 256 * params->pages_per_sector; - flash->size = flash->sector_size * params->nr_sectors; - - return flash; -} diff --git a/drivers/mtd/spi/spi_flash_internal.h b/drivers/mtd/spi/spi_flash_internal.h index 6227d2e..286082a 100644 --- a/drivers/mtd/spi/spi_flash_internal.h +++ b/drivers/mtd/spi/spi_flash_internal.h @@ -127,14 +127,3 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout);
/* Erase sectors. */ int spi_flash_cmd_erase(struct spi_flash *flash, u32 offset, size_t len); - -/* Manufacturer-specific probe functions */ -struct spi_flash *spi_flash_probe_spansion(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_atmel(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_eon(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_macronix(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_sst(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_stmicro(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode); -struct spi_flash *spi_flash_probe_gigadevice(struct spi_slave *spi, u8 *idcode); diff --git a/drivers/mtd/spi/sst.c b/drivers/mtd/spi/sst.c deleted file mode 100644 index 256867c..0000000 --- a/drivers/mtd/spi/sst.c +++ /dev/null @@ -1,238 +0,0 @@ -/* - * Driver for SST serial flashes - * - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Copyright 2008, Network Appliance Inc. - * Jason McMullan mcmullan@netapp.com - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * Copyright (c) 2008-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -#define CMD_SST_BP 0x02 /* Byte Program */ -#define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */ - -#define SST_SR_WIP (1 << 0) /* Write-in-Progress */ -#define SST_SR_WEL (1 << 1) /* Write enable */ -#define SST_SR_BP0 (1 << 2) /* Block Protection 0 */ -#define SST_SR_BP1 (1 << 3) /* Block Protection 1 */ -#define SST_SR_BP2 (1 << 4) /* Block Protection 2 */ -#define SST_SR_AAI (1 << 6) /* Addressing mode */ -#define SST_SR_BPL (1 << 7) /* BP bits lock */ - -#define SST_FEAT_WP (1 << 0) /* Supports AAI word program */ -#define SST_FEAT_MBP (1 << 1) /* Supports multibyte program */ - -struct sst_spi_flash_params { - u8 idcode1; - u8 flags; - u16 nr_sectors; - const char *name; -}; - -struct sst_spi_flash { - struct spi_flash flash; - const struct sst_spi_flash_params *params; -}; - -static const struct sst_spi_flash_params sst_spi_flash_table[] = { - { - .idcode1 = 0x8d, - .flags = SST_FEAT_WP, - .nr_sectors = 128, - .name = "SST25VF040B", - }, - { - .idcode1 = 0x8e, - .flags = SST_FEAT_WP, - .nr_sectors = 256, - .name = "SST25VF080B", - }, - { - .idcode1 = 0x41, - .flags = SST_FEAT_WP, - .nr_sectors = 512, - .name = "SST25VF016B", - }, - { - .idcode1 = 0x4a, - .flags = SST_FEAT_WP, - .nr_sectors = 1024, - .name = "SST25VF032B", - }, - { - .idcode1 = 0x4b, - .flags = SST_FEAT_MBP, - .nr_sectors = 2048, - .name = "SST25VF064C", - }, - { - .idcode1 = 0x01, - .flags = SST_FEAT_WP, - .nr_sectors = 16, - .name = "SST25WF512", - }, - { - .idcode1 = 0x02, - .flags = SST_FEAT_WP, - .nr_sectors = 32, - .name = "SST25WF010", - }, - { - .idcode1 = 0x03, - .flags = SST_FEAT_WP, - .nr_sectors = 64, - .name = "SST25WF020", - }, - { - .idcode1 = 0x04, - .flags = SST_FEAT_WP, - .nr_sectors = 128, - .name = "SST25WF040", - }, - { - .idcode1 = 0x05, - .flags = SST_FEAT_WP, - .nr_sectors = 256, - .name = "SST25WF080", - }, -}; - -static int -sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) -{ - int ret; - u8 cmd[4] = { - CMD_SST_BP, - offset >> 16, - offset >> 8, - offset, - }; - - debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset); - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - return ret; - - ret = spi_flash_cmd_write(flash->spi, cmd, sizeof(cmd), buf, 1); - if (ret) - return ret; - - return spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); -} - -static int -sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, const void *buf) -{ - size_t actual, cmd_len; - int ret; - u8 cmd[4]; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - /* If the data is not word aligned, write out leading single byte */ - actual = offset % 2; - if (actual) { - ret = sst_byte_write(flash, offset, buf); - if (ret) - goto done; - } - offset += actual; - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - goto done; - - cmd_len = 4; - cmd[0] = CMD_SST_AAI_WP; - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - cmd[3] = offset; - - for (; actual < len - 1; actual += 2) { - debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, - cmd[0], offset); - - ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, - buf + actual, 2); - if (ret) { - debug("SF: sst word program failed\n"); - break; - } - - ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret) - break; - - cmd_len = 1; - offset += 2; - } - - if (!ret) - ret = spi_flash_cmd_write_disable(flash); - - /* If there is a single trailing byte, write it out */ - if (!ret && actual != len) - ret = sst_byte_write(flash, offset, buf + actual); - - done: - debug("SF: sst: program %s %zu bytes @ 0x%zx\n", - ret ? "failure" : "success", len, offset - actual); - - spi_release_bus(flash->spi); - return ret; -} - -struct spi_flash * -spi_flash_probe_sst(struct spi_slave *spi, u8 *idcode) -{ - const struct sst_spi_flash_params *params; - struct sst_spi_flash *stm; - size_t i; - - for (i = 0; i < ARRAY_SIZE(sst_spi_flash_table); ++i) { - params = &sst_spi_flash_table[i]; - if (params->idcode1 == idcode[2]) - break; - } - - if (i == ARRAY_SIZE(sst_spi_flash_table)) { - debug("SF: Unsupported SST ID %02x\n", idcode[1]); - return NULL; - } - - stm = spi_flash_alloc(struct sst_spi_flash, spi, params->name); - if (!stm) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - stm->params = params; - - if (stm->params->flags & SST_FEAT_WP) - stm->flash.write = sst_write_wp; - stm->flash.page_size = 256; - stm->flash.sector_size = 4096; - stm->flash.size = stm->flash.sector_size * params->nr_sectors; - - /* Flash powers up read-only, so clear BP# bits */ - spi_flash_cmd_write_status(&stm->flash, 0); - - return &stm->flash; -} diff --git a/drivers/mtd/spi/stmicro.c b/drivers/mtd/spi/stmicro.c deleted file mode 100644 index c5fa64e..0000000 --- a/drivers/mtd/spi/stmicro.c +++ /dev/null @@ -1,202 +0,0 @@ -/* - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Copyright 2008, Network Appliance Inc. - * Jason McMullan mcmullan@netapp.com - * - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -/* M25Pxx-specific commands */ -#define CMD_M25PXX_RES 0xab /* Release from DP, and Read Signature */ - -struct stmicro_spi_flash_params { - u16 id; - u16 pages_per_sector; - u16 nr_sectors; - const char *name; -}; - -static const struct stmicro_spi_flash_params stmicro_spi_flash_table[] = { - { - .id = 0x2011, - .pages_per_sector = 128, - .nr_sectors = 4, - .name = "M25P10", - }, - { - .id = 0x2015, - .pages_per_sector = 256, - .nr_sectors = 32, - .name = "M25P16", - }, - { - .id = 0x2012, - .pages_per_sector = 256, - .nr_sectors = 4, - .name = "M25P20", - }, - { - .id = 0x2016, - .pages_per_sector = 256, - .nr_sectors = 64, - .name = "M25P32", - }, - { - .id = 0x2013, - .pages_per_sector = 256, - .nr_sectors = 8, - .name = "M25P40", - }, - { - .id = 0x2017, - .pages_per_sector = 256, - .nr_sectors = 128, - .name = "M25P64", - }, - { - .id = 0x2014, - .pages_per_sector = 256, - .nr_sectors = 16, - .name = "M25P80", - }, - { - .id = 0x2018, - .pages_per_sector = 1024, - .nr_sectors = 64, - .name = "M25P128", - }, - { - .id = 0xba16, - .pages_per_sector = 256, - .nr_sectors = 64, - .name = "N25Q32", - }, - { - .id = 0xbb16, - .pages_per_sector = 256, - .nr_sectors = 64, - .name = "N25Q32A", - }, - { - .id = 0xba17, - .pages_per_sector = 256, - .nr_sectors = 128, - .name = "N25Q064", - }, - { - .id = 0xbb17, - .pages_per_sector = 256, - .nr_sectors = 128, - .name = "N25Q64A", - }, - { - .id = 0xba18, - .pages_per_sector = 256, - .nr_sectors = 256, - .name = "N25Q128", - }, - { - .id = 0xbb18, - .pages_per_sector = 256, - .nr_sectors = 256, - .name = "N25Q128A", - }, - { - .id = 0xba19, - .pages_per_sector = 256, - .nr_sectors = 512, - .name = "N25Q256", - }, - { - .id = 0xbb19, - .pages_per_sector = 256, - .nr_sectors = 512, - .name = "N25Q256A", - }, - { - .id = 0xba20, - .pages_per_sector = 256, - .nr_sectors = 1024, - .name = "N25Q512", - }, - { - .id = 0xbb20, - .pages_per_sector = 256, - .nr_sectors = 1024, - .name = "N25Q512A", - }, - { - .id = 0xba21, - .pages_per_sector = 256, - .nr_sectors = 2048, - .name = "N25Q1024", - }, - { - .id = 0xbb21, - .pages_per_sector = 256, - .nr_sectors = 2048, - .name = "N25Q1024A", - }, -}; - -struct spi_flash *spi_flash_probe_stmicro(struct spi_slave *spi, u8 *idcode) -{ - const struct stmicro_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - u16 id; - - if (idcode[0] == 0xff) { - i = spi_flash_cmd(spi, CMD_M25PXX_RES, - idcode, 4); - if (i) - return NULL; - if ((idcode[3] & 0xf0) == 0x10) { - idcode[0] = 0x20; - idcode[1] = 0x20; - idcode[2] = idcode[3] + 1; - } else { - return NULL; - } - } - - id = ((idcode[1] << 8) | idcode[2]); - - for (i = 0; i < ARRAY_SIZE(stmicro_spi_flash_table); i++) { - params = &stmicro_spi_flash_table[i]; - if (params->id == id) - break; - } - - if (i == ARRAY_SIZE(stmicro_spi_flash_table)) { - debug("SF: Unsupported STMicro ID %04x\n", id); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - flash->page_size = 256; - flash->sector_size = 256 * params->pages_per_sector; - flash->size = flash->sector_size * params->nr_sectors; - - /* for >= 512MiB flashes, use flag status instead of read_status */ - if (flash->size >= 0x4000000) - flash->poll_cmd = CMD_FLAG_STATUS; - - return flash; -} diff --git a/drivers/mtd/spi/winbond.c b/drivers/mtd/spi/winbond.c deleted file mode 100644 index b31911a..0000000 --- a/drivers/mtd/spi/winbond.c +++ /dev/null @@ -1,141 +0,0 @@ -/* - * Copyright 2008, Network Appliance Inc. - * Author: Jason McMullan <mcmullan <at> netapp.com> - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <malloc.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -struct winbond_spi_flash_params { - uint16_t id; - uint16_t nr_blocks; - const char *name; -}; - -static const struct winbond_spi_flash_params winbond_spi_flash_table[] = { - { - .id = 0x2014, - .nr_blocks = 16, - .name = "W25P80", - }, - { - .id = 0x2015, - .nr_blocks = 32, - .name = "W25P16", - }, - { - .id = 0x2016, - .nr_blocks = 64, - .name = "W25P32", - }, - { - .id = 0x3013, - .nr_blocks = 8, - .name = "W25X40", - }, - { - .id = 0x3015, - .nr_blocks = 32, - .name = "W25X16", - }, - { - .id = 0x3016, - .nr_blocks = 64, - .name = "W25X32", - }, - { - .id = 0x3017, - .nr_blocks = 128, - .name = "W25X64", - }, - { - .id = 0x4014, - .nr_blocks = 16, - .name = "W25Q80BL/W25Q80BV", - }, - { - .id = 0x4015, - .nr_blocks = 32, - .name = "W25Q16CL/W25Q16DV", - }, - { - .id = 0x4016, - .nr_blocks = 64, - .name = "W25Q32BV/W25Q32FV_SPI", - }, - { - .id = 0x4017, - .nr_blocks = 128, - .name = "W25Q64CV/W25Q64FV_SPI", - }, - { - .id = 0x4018, - .nr_blocks = 256, - .name = "W25Q128BV/W25Q128FV_SPI", - }, - { - .id = 0x4019, - .nr_blocks = 512, - .name = "W25Q256", - }, - { - .id = 0x5014, - .nr_blocks = 16, - .name = "W25Q80BW", - }, - { - .id = 0x6015, - .nr_blocks = 32, - .name = "W25Q16DW", - }, - { - .id = 0x6016, - .nr_blocks = 64, - .name = "W25Q32DW/W25Q32FV_QPI", - }, - { - .id = 0x6017, - .nr_blocks = 128, - .name = "W25Q64DW/W25Q64FV_QPI", - }, - { - .id = 0x6018, - .nr_blocks = 256, - .name = "W25Q128FW/W25Q128FV_QPI", - }, -}; - -struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode) -{ - const struct winbond_spi_flash_params *params; - struct spi_flash *flash; - unsigned int i; - - for (i = 0; i < ARRAY_SIZE(winbond_spi_flash_table); i++) { - params = &winbond_spi_flash_table[i]; - if (params->id == ((idcode[1] << 8) | idcode[2])) - break; - } - - if (i == ARRAY_SIZE(winbond_spi_flash_table)) { - debug("SF: Unsupported Winbond ID %02x%02x\n", - idcode[1], idcode[2]); - return NULL; - } - - flash = spi_flash_alloc_base(spi, params->name); - if (!flash) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - - flash->page_size = 256; - flash->sector_size = (idcode[1] == 0x20) ? 65536 : 4096; - flash->size = 4096 * 16 * params->nr_blocks; - - return flash; -}
