[PATCH v3 1/1] blk: Rename if_type to uclass_id
Use the word 'uclass' instead of 'if_type' to complete the conversion.
Changes in v3: - Drop previously applied patches - Rebase on -next after EFI changes
Changes in v2: - Use conv_uclass_id() instead of the confusing uclass_id_to_uclass_id()
board/st/common/stm32mp_dfu.c | 2 +- cmd/blk_common.c | 18 +-- cmd/lsblk.c | 2 +- cmd/mmc.c | 2 +- common/usb_storage.c | 6 +- disk/disk-uclass.c | 8 +- disk/part.c | 12 +- doc/usage/partitions.rst | 2 +- drivers/ata/sata.c | 2 +- drivers/block/blk-uclass.c | 145 +++++++++++------------ drivers/block/blk_legacy.c | 58 ++++----- drivers/block/ide.c | 8 +- drivers/block/sandbox.c | 6 +- drivers/mmc/mmc-uclass.c | 2 +- drivers/mmc/mmc_legacy.c | 8 +- drivers/net/fsl_enetc.c | 12 +- drivers/net/fsl_enetc.h | 2 +- drivers/scsi/scsi.c | 6 +- drivers/virtio/virtio_blk.c | 2 +- drivers/xen/pvblock.c | 2 +- fs/fat/fat.c | 2 +- include/blk.h | 116 +++++++++--------- include/efi_api.h | 4 +- include/efi_loader.h | 4 +- lib/efi_loader/efi_device_path.c | 2 +- lib/efi_loader/efi_device_path_to_text.c | 4 +- lib/efi_loader/efi_disk.c | 12 +- lib/efi_loader/efi_net.c | 2 +- lib/efi_loader/efi_var_file.c | 4 +- 29 files changed, 227 insertions(+), 228 deletions(-)
diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index fa48b2a35ee..0096f71dfc1 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -37,7 +37,7 @@ static void board_get_alt_info_mmc(struct udevice *dev, char *buf) if (!desc) return;
- name = blk_get_if_type_name(desc->if_type); + name = blk_get_uclass_name(desc->uclass_id); devnum = desc->devnum; len = strlen(buf);
diff --git a/cmd/blk_common.c b/cmd/blk_common.c index 369c5ae4bbe..75a072caf51 100644 --- a/cmd/blk_common.c +++ b/cmd/blk_common.c @@ -12,10 +12,10 @@ #include <blk.h> #include <command.h>
-int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, +int blk_common_cmd(int argc, char *const argv[], enum uclass_id uclass_id, int *cur_devnump) { - const char *if_name = blk_get_if_type_name(if_type); + const char *if_name = blk_get_uclass_name(uclass_id);
switch (argc) { case 0: @@ -23,16 +23,16 @@ int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, return CMD_RET_USAGE; case 2: if (strncmp(argv[1], "inf", 3) == 0) { - blk_list_devices(if_type); + blk_list_devices(uclass_id); return 0; } else if (strncmp(argv[1], "dev", 3) == 0) { - if (blk_print_device_num(if_type, *cur_devnump)) { + if (blk_print_device_num(uclass_id, *cur_devnump)) { printf("\nno %s devices available\n", if_name); return CMD_RET_FAILURE; } return 0; } else if (strncmp(argv[1], "part", 4) == 0) { - if (blk_list_part(if_type)) + if (blk_list_part(uclass_id)) printf("\nno %s partition table available\n", if_name); return 0; @@ -42,7 +42,7 @@ int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, if (strncmp(argv[1], "dev", 3) == 0) { int dev = (int)dectoul(argv[2], NULL);
- if (!blk_show_device(if_type, dev)) { + if (!blk_show_device(uclass_id, dev)) { *cur_devnump = dev; printf("... is now current device\n"); } else { @@ -52,7 +52,7 @@ int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, } else if (strncmp(argv[1], "part", 4) == 0) { int dev = (int)dectoul(argv[2], NULL);
- if (blk_print_part_devnum(if_type, dev)) { + if (blk_print_part_devnum(uclass_id, dev)) { printf("\n%s device %d not available\n", if_name, dev); return CMD_RET_FAILURE; @@ -71,7 +71,7 @@ int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, printf("\n%s read: device %d block # "LBAFU", count %lu ... ", if_name, *cur_devnump, blk, cnt);
- n = blk_read_devnum(if_type, *cur_devnump, blk, cnt, + n = blk_read_devnum(uclass_id, *cur_devnump, blk, cnt, (ulong *)addr);
printf("%ld blocks read: %s\n", n, @@ -86,7 +86,7 @@ int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, printf("\n%s write: device %d block # "LBAFU", count %lu ... ", if_name, *cur_devnump, blk, cnt);
- n = blk_write_devnum(if_type, *cur_devnump, blk, cnt, + n = blk_write_devnum(uclass_id, *cur_devnump, blk, cnt, (ulong *)addr);
printf("%ld blocks written: %s\n", n, diff --git a/cmd/lsblk.c b/cmd/lsblk.c index 6a1c8f5ef40..d214dafc3be 100644 --- a/cmd/lsblk.c +++ b/cmd/lsblk.c @@ -36,7 +36,7 @@ static int do_lsblk(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv continue; desc = dev_get_uclass_plat(udev); printf("%c %s %u", i ? ',' : ':', - blk_get_if_type_name(desc->if_type), + blk_get_uclass_name(desc->uclass_id), desc->devnum); i++; } diff --git a/cmd/mmc.c b/cmd/mmc.c index 0f1f4e0a71d..6718e99ea7d 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -154,7 +154,7 @@ static struct mmc *__init_mmc_device(int dev, bool force_init,
#ifdef CONFIG_BLOCK_CACHE struct blk_desc *bd = mmc_get_blk_desc(mmc); - blkcache_invalidate(bd->if_type, bd->devnum); + blkcache_invalidate(bd->uclass_id, bd->devnum); #endif
return mmc; diff --git a/common/usb_storage.c b/common/usb_storage.c index 7d420160cd5..e59c819bac5 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -279,7 +279,7 @@ static int usb_stor_probe_device(struct usb_device *udev)
blkdev = &usb_dev_desc[usb_max_devs]; memset(blkdev, '\0', sizeof(struct blk_desc)); - blkdev->if_type = UCLASS_USB; + blkdev->uclass_id = UCLASS_USB; blkdev->devnum = usb_max_devs; blkdev->part_type = PART_TYPE_UNKNOWN; blkdev->target = 0xff; @@ -1577,8 +1577,8 @@ U_BOOT_DRIVER(usb_storage_blk) = { }; #else U_BOOT_LEGACY_BLK(usb) = { - .if_typename = "usb", - .if_type = UCLASS_USB, + .uclass_idname = "usb", + .uclass_id = UCLASS_USB, .max_devs = USB_MAX_STOR_DEV, .desc = usb_dev_desc, }; diff --git a/disk/disk-uclass.c b/disk/disk-uclass.c index 9351a5cfa68..551f8b1dca4 100644 --- a/disk/disk-uclass.c +++ b/disk/disk-uclass.c @@ -191,12 +191,12 @@ unsigned long dev_read(struct udevice *dev, lbaint_t start, start_in_disk += part->gpt_part_info.start; }
- if (blkcache_read(block_dev->if_type, block_dev->devnum, + if (blkcache_read(block_dev->uclass_id, block_dev->devnum, start_in_disk, blkcnt, block_dev->blksz, buffer)) return blkcnt; blks_read = ops->read(dev, start, blkcnt, buffer); if (blks_read == blkcnt) - blkcache_fill(block_dev->if_type, block_dev->devnum, + blkcache_fill(block_dev->uclass_id, block_dev->devnum, start_in_disk, blkcnt, block_dev->blksz, buffer);
return blks_read; @@ -216,7 +216,7 @@ unsigned long dev_write(struct udevice *dev, lbaint_t start, if (!ops->write) return -ENOSYS;
- blkcache_invalidate(block_dev->if_type, block_dev->devnum); + blkcache_invalidate(block_dev->uclass_id, block_dev->devnum);
return ops->write(dev, start, blkcnt, buffer); } @@ -235,7 +235,7 @@ unsigned long dev_erase(struct udevice *dev, lbaint_t start, if (!ops->erase) return -ENOSYS;
return ops->erase(dev, start, blkcnt); } diff --git a/disk/part.c b/disk/part.c index 5705c229d59..d73318c8ffe 100644 --- a/disk/part.c +++ b/disk/part.c @@ -120,7 +120,7 @@ void dev_print(struct blk_desc *dev_desc) return; }
- switch (dev_desc->if_type) { + switch (dev_desc->uclass_id) { case UCLASS_SCSI: printf ("(%d:%d) Vendor: %s Prod.: %s Rev: %s\n", dev_desc->target,dev_desc->lun, @@ -155,7 +155,7 @@ void dev_print(struct blk_desc *dev_desc) puts("device type unknown\n"); return; default: - printf("Unhandled device type: %i\n", dev_desc->if_type); + printf("Unhandled device type: %i\n", dev_desc->uclass_id); return; } puts (" Type: "); @@ -225,7 +225,7 @@ void part_init(struct blk_desc *dev_desc) const int n_ents = ll_entry_count(struct part_driver, part_driver); struct part_driver *entry;
- blkcache_invalidate(dev_desc->if_type, dev_desc->devnum); + blkcache_invalidate(dev_desc->uclass_id, dev_desc->devnum);
dev_desc->part_type = PART_TYPE_UNKNOWN; for (entry = drv; entry != drv + n_ents; entry++) { @@ -248,7 +248,7 @@ static void print_part_header(const char *type, struct blk_desc *dev_desc) CONFIG_IS_ENABLED(AMIGA_PARTITION) || \ CONFIG_IS_ENABLED(EFI_PARTITION) puts ("\nPartition Map for "); - switch (dev_desc->if_type) { + switch (dev_desc->uclass_id) { case UCLASS_IDE: puts ("IDE"); break; @@ -408,7 +408,7 @@ int blk_get_device_by_str(const char *ifname, const char *dev_hwpart_str, * Always should be done, otherwise hw partition 0 will return * stale data after displaying a non-zero hw partition. */ - if ((*dev_desc)->if_type == UCLASS_MMC) + if ((*dev_desc)->uclass_id == UCLASS_MMC) part_init(*dev_desc); }
@@ -762,7 +762,7 @@ void part_set_generic_name(const struct blk_desc *dev_desc, { char *devtype;
- switch (dev_desc->if_type) { + switch (dev_desc->uclass_id) { case UCLASS_IDE: case UCLASS_AHCI: devtype = "hd"; diff --git a/doc/usage/partitions.rst b/doc/usage/partitions.rst index 2c1a12b6bf5..628469bbec9 100644 --- a/doc/usage/partitions.rst +++ b/doc/usage/partitions.rst @@ -20,7 +20,7 @@ generic syntax. interface The interface used to access the partition's device, like ``mmc`` or ``scsi``. For a full list of supported interfaces, consult the - ``if_typename_str`` array in ``drivers/block/blk-uclass.c`` + ``uclass_idname_str`` array in ``drivers/block/blk-uclass.c``
devnum The device number. This defaults to 0. diff --git a/drivers/ata/sata.c b/drivers/ata/sata.c index 604c721cfdc..ce3e9b5a400 100644 --- a/drivers/ata/sata.c +++ b/drivers/ata/sata.c @@ -79,7 +79,7 @@ int __sata_initialize(void)
for (i = 0; i < CONFIG_SYS_SATA_MAX_DEVICE; i++) { memset(&sata_dev_desc[i], 0, sizeof(struct blk_desc)); - sata_dev_desc[i].if_type = UCLASS_AHCI; + sata_dev_desc[i].uclass_id = UCLASS_AHCI; sata_dev_desc[i].devnum = i; sata_dev_desc[i].part_type = PART_TYPE_UNKNOWN; sata_dev_desc[i].type = DEV_TYPE_HARDDISK; diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index a9a85aa37f3..f8157c8d6ae 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -20,7 +20,7 @@ static struct { enum uclass_id id; const char *name; -} if_typename_str[] = { +} uclass_idname_str[] = { { UCLASS_IDE, "ide" }, { UCLASS_SCSI, "scsi" }, { UCLASS_USB, "usb" }, @@ -34,19 +34,19 @@ static struct { { UCLASS_PVBLOCK, "pvblock" }, };
-static enum uclass_id if_typename_to_iftype(const char *if_typename) +static enum uclass_id uclass_idname_to_iftype(const char *uclass_idname) { int i;
- for (i = 0; i < ARRAY_SIZE(if_typename_str); i++) { - if (!strcmp(if_typename, if_typename_str[i].name)) - return if_typename_str[i].id; + for (i = 0; i < ARRAY_SIZE(uclass_idname_str); i++) { + if (!strcmp(uclass_idname, uclass_idname_str[i].name)) + return uclass_idname_str[i].id; }
return UCLASS_INVALID; }
-static enum uclass_id if_type_to_uclass_id(enum uclass_id if_type) +static enum uclass_id conv_uclass_id(enum uclass_id uclass_id) { /* * This strange adjustment is used because we use UCLASS_MASS_STORAGE @@ -65,31 +65,30 @@ static enum uclass_id if_type_to_uclass_id(enum uclass_id if_type) * - rename UCLASS_USB name to "usb_ctlr" * - use UCLASS_MASS_STORAGE instead of UCLASS_USB in if_typename_str */ - if (if_type == UCLASS_USB) + if (uclass_id == UCLASS_USB) return UCLASS_MASS_STORAGE; - - return if_type; + return uclass_id; }
-const char *blk_get_if_type_name(enum uclass_id if_type) +const char *blk_get_uclass_name(enum uclass_id uclass_id) { int i;
- for (i = 0; i < ARRAY_SIZE(if_typename_str); i++) { - if (if_typename_str[i].id == if_type) - return if_typename_str[i].name; + for (i = 0; i < ARRAY_SIZE(uclass_idname_str); i++) { + if (uclass_idname_str[i].id == uclass_id) + return uclass_idname_str[i].name; }
return "(none)"; }
-struct blk_desc *blk_get_devnum_by_type(enum uclass_id if_type, int devnum) +struct blk_desc *blk_get_devnum_by_type(enum uclass_id uclass_id, int devnum) { struct blk_desc *desc; struct udevice *dev; int ret;
- ret = blk_get_device(if_type, devnum, &dev); + ret = blk_get_device(uclass_id, devnum, &dev); if (ret) return NULL; desc = dev_get_uclass_plat(dev); @@ -102,7 +101,7 @@ struct blk_desc *blk_get_devnum_by_type(enum uclass_id if_type, int devnum) * name in a local table. This gives us an interface type which we can match * against the uclass of the block device's parent. */ -struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, int devnum) +struct blk_desc *blk_get_devnum_by_typename(const char *uclass_idname, int devnum) { enum uclass_id uclass_id; enum uclass_id type; @@ -110,16 +109,16 @@ struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, int devnum) struct uclass *uc; int ret;
- type = if_typename_to_iftype(if_typename); + type = uclass_idname_to_iftype(uclass_idname); if (type == UCLASS_INVALID) { debug("%s: Unknown interface type '%s'\n", __func__, - if_typename); + uclass_idname); return NULL; } - uclass_id = if_type_to_uclass_id(type); + uclass_id = conv_uclass_id(type); if (uclass_id == UCLASS_INVALID) { debug("%s: Unknown uclass for interface type'\n", - blk_get_if_type_name(type)); + blk_get_uclass_name(type)); return NULL; }
@@ -129,8 +128,8 @@ struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, int devnum) uclass_foreach_dev(dev, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- debug("%s: if_type=%d, devnum=%d: %s, %d, %d\n", __func__, - type, devnum, dev->name, desc->if_type, desc->devnum); + debug("%s: uclass_id=%d, devnum=%d: %s, %d, %d\n", __func__, + type, devnum, dev->name, desc->uclass_id, desc->devnum); if (desc->devnum != devnum) continue;
@@ -178,14 +177,14 @@ struct blk_desc *blk_get_by_device(struct udevice *dev) /** * get_desc() - Get the block device descriptor for the given device number * - * @if_type: Interface type + * @uclass_id: Interface type * @devnum: Device number (0 = first) * @descp: Returns block device descriptor on success * Return: 0 on success, -ENODEV if there is no such device and no device * with a higher device number, -ENOENT if there is no such device but there * is one with a higher number, or other -ve on other error. */ -static int get_desc(enum uclass_id if_type, int devnum, struct blk_desc **descp) +static int get_desc(enum uclass_id uclass_id, int devnum, struct blk_desc **descp) { bool found_more = false; struct udevice *dev; @@ -199,9 +198,9 @@ static int get_desc(enum uclass_id if_type, int devnum, struct blk_desc **descp) uclass_foreach_dev(dev, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- debug("%s: if_type=%d, devnum=%d: %s, %d, %d\n", __func__, - if_type, devnum, dev->name, desc->if_type, desc->devnum); - if (desc->if_type == if_type) { + debug("%s: uclass_id=%d, devnum=%d: %s, %d, %d\n", __func__, + uclass_id, devnum, dev->name, desc->uclass_id, desc->devnum); + if (desc->uclass_id == uclass_id) { if (desc->devnum == devnum) { ret = device_probe(dev); if (ret) @@ -218,26 +217,26 @@ static int get_desc(enum uclass_id if_type, int devnum, struct blk_desc **descp) return found_more ? -ENOENT : -ENODEV; }
-int blk_select_hwpart_devnum(enum uclass_id if_type, int devnum, int hwpart) +int blk_select_hwpart_devnum(enum uclass_id uclass_id, int devnum, int hwpart) { struct udevice *dev; int ret;
- ret = blk_get_device(if_type, devnum, &dev); + ret = blk_get_device(uclass_id, devnum, &dev); if (ret) return ret;
return blk_select_hwpart(dev, hwpart); }
-int blk_list_part(enum uclass_id if_type) +int blk_list_part(enum uclass_id uclass_id) { struct blk_desc *desc; int devnum, ok; int ret;
for (ok = 0, devnum = 0;; ++devnum) { - ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret == -ENODEV) break; else if (ret) @@ -255,12 +254,12 @@ int blk_list_part(enum uclass_id if_type) return 0; }
-int blk_print_part_devnum(enum uclass_id if_type, int devnum) +int blk_print_part_devnum(enum uclass_id uclass_id, int devnum) { struct blk_desc *desc; int ret;
- ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; if (desc->type == DEV_TYPE_UNKNOWN) @@ -270,14 +269,14 @@ int blk_print_part_devnum(enum uclass_id if_type, int devnum) return 0; }
-void blk_list_devices(enum uclass_id if_type) +void blk_list_devices(enum uclass_id uclass_id) { struct blk_desc *desc; int ret; int i;
for (i = 0;; ++i) { - ret = get_desc(if_type, i, &desc); + ret = get_desc(uclass_id, i, &desc); if (ret == -ENODEV) break; else if (ret) @@ -289,12 +288,12 @@ void blk_list_devices(enum uclass_id if_type) } }
-int blk_print_device_num(enum uclass_id if_type, int devnum) +int blk_print_device_num(enum uclass_id uclass_id, int devnum) { struct blk_desc *desc; int ret;
- ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; printf("\nIDE device %d: ", devnum); @@ -303,13 +302,13 @@ int blk_print_device_num(enum uclass_id if_type, int devnum) return 0; }
-int blk_show_device(enum uclass_id if_type, int devnum) +int blk_show_device(enum uclass_id uclass_id, int devnum) { struct blk_desc *desc; int ret;
printf("\nDevice %d: ", devnum); - ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret == -ENODEV || ret == -ENOENT) { printf("unknown device\n"); return -ENODEV; @@ -324,14 +323,14 @@ int blk_show_device(enum uclass_id if_type, int devnum) return 0; }
-ulong blk_read_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_read_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, void *buffer) { struct blk_desc *desc; ulong n; int ret;
- ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; n = blk_dread(desc, start, blkcnt, buffer); @@ -341,13 +340,13 @@ ulong blk_read_devnum(enum uclass_id if_type, int devnum, lbaint_t start, return n; }
-ulong blk_write_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_write_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, const void *buffer) { struct blk_desc *desc; int ret;
- ret = get_desc(if_type, devnum, &desc); + ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; return blk_dwrite(desc, start, blkcnt, buffer); @@ -370,7 +369,7 @@ int blk_dselect_hwpart(struct blk_desc *desc, int hwpart) return blk_select_hwpart(desc->bdev, hwpart); }
-int blk_first_device(int if_type, struct udevice **devp) +int blk_first_device(int uclass_id, struct udevice **devp) { struct blk_desc *desc; int ret; @@ -382,7 +381,7 @@ int blk_first_device(int if_type, struct udevice **devp) return -ENODEV; do { desc = dev_get_uclass_plat(*devp); - if (desc->if_type == if_type) + if (desc->uclass_id == uclass_id) return 0; ret = uclass_find_next_device(devp); if (ret) @@ -395,10 +394,10 @@ int blk_first_device(int if_type, struct udevice **devp) int blk_next_device(struct udevice **devp) { struct blk_desc *desc; - int ret, if_type; + int ret, uclass_id;
desc = dev_get_uclass_plat(*devp); - if_type = desc->if_type; + uclass_id = desc->uclass_id; do { ret = uclass_find_next_device(devp); if (ret) @@ -406,12 +405,12 @@ int blk_next_device(struct udevice **devp) if (!*devp) return -ENODEV; desc = dev_get_uclass_plat(*devp); - if (desc->if_type == if_type) + if (desc->uclass_id == uclass_id) return 0; } while (1); }
-int blk_find_device(int if_type, int devnum, struct udevice **devp) +int blk_find_device(int uclass_id, int devnum, struct udevice **devp) { struct uclass *uc; struct udevice *dev; @@ -423,9 +422,9 @@ int blk_find_device(int if_type, int devnum, struct udevice **devp) uclass_foreach_dev(dev, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- debug("%s: if_type=%d, devnum=%d: %s, %d, %d\n", __func__, - if_type, devnum, dev->name, desc->if_type, desc->devnum); - if (desc->if_type == if_type && desc->devnum == devnum) { + debug("%s: uclass_id=%d, devnum=%d: %s, %d, %d\n", __func__, + uclass_id, devnum, dev->name, desc->uclass_id, desc->devnum); + if (desc->uclass_id == uclass_id && desc->devnum == devnum) { *devp = dev; return 0; } @@ -434,11 +433,11 @@ int blk_find_device(int if_type, int devnum, struct udevice **devp) return -ENODEV; }
-int blk_get_device(int if_type, int devnum, struct udevice **devp) +int blk_get_device(int uclass_id, int devnum, struct udevice **devp) { int ret;
- ret = blk_find_device(if_type, devnum, devp); + ret = blk_find_device(uclass_id, devnum, devp); if (ret) return ret;
@@ -455,12 +454,12 @@ unsigned long blk_dread(struct blk_desc *block_dev, lbaint_t start, if (!ops->read) return -ENOSYS;
- if (blkcache_read(block_dev->if_type, block_dev->devnum, + if (blkcache_read(block_dev->uclass_id, block_dev->devnum, start, blkcnt, block_dev->blksz, buffer)) return blkcnt; blks_read = ops->read(dev, start, blkcnt, buffer); if (blks_read == blkcnt) - blkcache_fill(block_dev->if_type, block_dev->devnum, + blkcache_fill(block_dev->uclass_id, block_dev->devnum, start, blkcnt, block_dev->blksz, buffer);
return blks_read; @@ -475,7 +474,7 @@ unsigned long blk_dwrite(struct blk_desc *block_dev, lbaint_t start, if (!ops->write) return -ENOSYS;
- blkcache_invalidate(block_dev->if_type, block_dev->devnum); + blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return ops->write(dev, start, blkcnt, buffer); }
@@ -488,7 +487,7 @@ unsigned long blk_derase(struct blk_desc *block_dev, lbaint_t start, if (!ops->erase) return -ENOSYS;
- blkcache_invalidate(block_dev->if_type, block_dev->devnum); + blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return ops->erase(dev, start, blkcnt); }
@@ -525,7 +524,7 @@ const char *blk_get_devtype(struct udevice *dev) return uclass_get_name(device_get_uclass_id(parent)); };
-int blk_find_max_devnum(enum uclass_id if_type) +int blk_find_max_devnum(enum uclass_id uclass_id) { struct udevice *dev; int max_devnum = -ENODEV; @@ -538,18 +537,18 @@ int blk_find_max_devnum(enum uclass_id if_type) uclass_foreach_dev(dev, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- if (desc->if_type == if_type && desc->devnum > max_devnum) + if (desc->uclass_id == uclass_id && desc->devnum > max_devnum) max_devnum = desc->devnum; }
return max_devnum; }
-int blk_next_free_devnum(enum uclass_id if_type) +int blk_next_free_devnum(enum uclass_id uclass_id) { int ret;
- ret = blk_find_max_devnum(if_type); + ret = blk_find_max_devnum(uclass_id); if (ret == -ENODEV) return 0; if (ret < 0) @@ -631,7 +630,7 @@ int blk_count_devices(enum blk_flag_t flag) return count; }
-static int blk_claim_devnum(enum uclass_id if_type, int devnum) +static int blk_claim_devnum(enum uclass_id uclass_id, int devnum) { struct udevice *dev; struct uclass *uc; @@ -643,8 +642,8 @@ static int blk_claim_devnum(enum uclass_id if_type, int devnum) uclass_foreach_dev(dev, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- if (desc->if_type == if_type && desc->devnum == devnum) { - int next = blk_next_free_devnum(if_type); + if (desc->uclass_id == uclass_id && desc->devnum == devnum) { + int next = blk_next_free_devnum(uclass_id);
if (next < 0) return next; @@ -657,7 +656,7 @@ static int blk_claim_devnum(enum uclass_id if_type, int devnum) }
int blk_create_device(struct udevice *parent, const char *drv_name, - const char *name, int if_type, int devnum, int blksz, + const char *name, int uclass_id, int devnum, int blksz, lbaint_t lba, struct udevice **devp) { struct blk_desc *desc; @@ -665,9 +664,9 @@ int blk_create_device(struct udevice *parent, const char *drv_name, int ret;
if (devnum == -1) { - devnum = blk_next_free_devnum(if_type); + devnum = blk_next_free_devnum(uclass_id); } else { - ret = blk_claim_devnum(if_type, devnum); + ret = blk_claim_devnum(uclass_id, devnum); if (ret < 0 && ret != -ENOENT) return ret; } @@ -677,7 +676,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, if (ret) return ret; desc = dev_get_uclass_plat(dev); - desc->if_type = if_type; + desc->uclass_id = uclass_id; desc->blksz = blksz; desc->log2blksz = LOG2(desc->blksz); desc->lba = lba; @@ -690,7 +689,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, }
int blk_create_devicef(struct udevice *parent, const char *drv_name, - const char *name, int if_type, int devnum, int blksz, + const char *name, int uclass_id, int devnum, int blksz, lbaint_t lba, struct udevice **devp) { char dev_name[30], *str; @@ -701,7 +700,7 @@ int blk_create_devicef(struct udevice *parent, const char *drv_name, if (!str) return -ENOMEM;
- ret = blk_create_device(parent, drv_name, str, if_type, devnum, + ret = blk_create_device(parent, drv_name, str, uclass_id, devnum, blksz, lba, devp); if (ret) { free(str); @@ -725,7 +724,7 @@ int blk_probe_or_unbind(struct udevice *dev) return ret; }
-int blk_unbind_all(int if_type) +int blk_unbind_all(int uclass_id) { struct uclass *uc; struct udevice *dev, *next; @@ -737,7 +736,7 @@ int blk_unbind_all(int if_type) uclass_foreach_dev_safe(dev, next, uc) { struct blk_desc *desc = dev_get_uclass_plat(dev);
- if (desc->if_type == if_type) { + if (desc->uclass_id == uclass_id) { ret = device_remove(dev, DM_REMOVE_NORMAL); if (ret) return ret; diff --git a/drivers/block/blk_legacy.c b/drivers/block/blk_legacy.c index 8c6f9cb208e..2ba5cc2d5a8 100644 --- a/drivers/block/blk_legacy.c +++ b/drivers/block/blk_legacy.c @@ -9,14 +9,14 @@ #include <part.h> #include <linux/err.h>
-struct blk_driver *blk_driver_lookup_type(int if_type) +struct blk_driver *blk_driver_lookup_type(int uclass_id) { struct blk_driver *drv = ll_entry_start(struct blk_driver, blk_driver); const int n_ents = ll_entry_count(struct blk_driver, blk_driver); struct blk_driver *entry;
for (entry = drv; entry != drv + n_ents; entry++) { - if (if_type == entry->if_type) + if (uclass_id == entry->uclass_id) return entry; }
@@ -24,14 +24,14 @@ struct blk_driver *blk_driver_lookup_type(int if_type) return NULL; }
-static struct blk_driver *blk_driver_lookup_typename(const char *if_typename) +static struct blk_driver *blk_driver_lookup_typename(const char *uclass_idname) { struct blk_driver *drv = ll_entry_start(struct blk_driver, blk_driver); const int n_ents = ll_entry_count(struct blk_driver, blk_driver); struct blk_driver *entry;
for (entry = drv; entry != drv + n_ents; entry++) { - if (!strcmp(if_typename, entry->if_typename)) + if (!strcmp(uclass_idname, entry->uclass_idname)) return entry; }
@@ -39,11 +39,11 @@ static struct blk_driver *blk_driver_lookup_typename(const char *if_typename) return NULL; }
-const char *blk_get_if_type_name(enum uclass_id if_type) +const char *blk_get_uclass_name(enum uclass_id uclass_id) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id);
- return drv ? drv->if_typename : NULL; + return drv ? drv->uclass_idname : NULL; }
/** @@ -70,14 +70,14 @@ static int get_desc(struct blk_driver *drv, int devnum, struct blk_desc **descp) return drv->get_dev(devnum, descp); }
-int blk_list_part(enum uclass_id if_type) +int blk_list_part(enum uclass_id uclass_id) { struct blk_driver *drv; struct blk_desc *desc; int devnum, ok; bool first = true;
- drv = blk_driver_lookup_type(if_type); + drv = blk_driver_lookup_type(uclass_id); if (!drv) return -ENOSYS; for (ok = 0, devnum = 0; devnum < drv->max_devs; ++devnum) { @@ -97,9 +97,9 @@ int blk_list_part(enum uclass_id if_type) return 0; }
-int blk_print_part_devnum(enum uclass_id if_type, int devnum) +int blk_print_part_devnum(enum uclass_id uclass_id, int devnum) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
@@ -115,9 +115,9 @@ int blk_print_part_devnum(enum uclass_id if_type, int devnum) return 0; }
-void blk_list_devices(enum uclass_id if_type) +void blk_list_devices(enum uclass_id uclass_id) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int i;
@@ -133,9 +133,9 @@ void blk_list_devices(enum uclass_id if_type) } }
-int blk_print_device_num(enum uclass_id if_type, int devnum) +int blk_print_device_num(enum uclass_id uclass_id, int devnum) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
@@ -144,15 +144,15 @@ int blk_print_device_num(enum uclass_id if_type, int devnum) ret = get_desc(drv, devnum, &desc); if (ret) return ret; - printf("\n%s device %d: ", drv->if_typename, devnum); + printf("\n%s device %d: ", drv->uclass_idname, devnum); dev_print(desc);
return 0; }
-int blk_show_device(enum uclass_id if_type, int devnum) +int blk_show_device(enum uclass_id uclass_id, int devnum) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
@@ -174,9 +174,9 @@ int blk_show_device(enum uclass_id if_type, int devnum) return 0; }
-struct blk_desc *blk_get_devnum_by_type(enum uclass_id if_type, int devnum) +struct blk_desc *blk_get_devnum_by_type(enum uclass_id uclass_id, int devnum) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc;
if (!drv) @@ -190,7 +190,7 @@ struct blk_desc *blk_get_devnum_by_type(enum uclass_id if_type, int devnum)
int blk_dselect_hwpart(struct blk_desc *desc, int hwpart) { - struct blk_driver *drv = blk_driver_lookup_type(desc->if_type); + struct blk_driver *drv = blk_driver_lookup_type(desc->uclass_id);
if (!drv) return -ENOSYS; @@ -200,9 +200,9 @@ int blk_dselect_hwpart(struct blk_desc *desc, int hwpart) return 0; }
-struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, int devnum) +struct blk_desc *blk_get_devnum_by_typename(const char *uclass_idname, int devnum) { - struct blk_driver *drv = blk_driver_lookup_typename(if_typename); + struct blk_driver *drv = blk_driver_lookup_typename(uclass_idname); struct blk_desc *desc;
if (!drv) @@ -214,10 +214,10 @@ struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, int devnum) return desc; }
-ulong blk_read_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_read_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, void *buffer) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; ulong n; int ret; @@ -234,10 +234,10 @@ ulong blk_read_devnum(enum uclass_id if_type, int devnum, lbaint_t start, return n; }
-ulong blk_write_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_write_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, const void *buffer) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
@@ -249,9 +249,9 @@ ulong blk_write_devnum(enum uclass_id if_type, int devnum, lbaint_t start, return desc->block_write(desc, start, blkcnt, buffer); }
-int blk_select_hwpart_devnum(enum uclass_id if_type, int devnum, int hwpart) +int blk_select_hwpart_devnum(enum uclass_id uclass_id, int devnum, int hwpart) { - struct blk_driver *drv = blk_driver_lookup_type(if_type); + struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
diff --git a/drivers/block/ide.c b/drivers/block/ide.c index 73da29ad552..ef5644d0b90 100644 --- a/drivers/block/ide.c +++ b/drivers/block/ide.c @@ -537,7 +537,7 @@ static void ide_ident(struct blk_desc *dev_desc) /* Select device */ ide_outb(device, ATA_DEV_HD, ATA_LBA | ATA_DEVICE(device)); - dev_desc->if_type = UCLASS_IDE; + dev_desc->uclass_id = UCLASS_IDE; #ifdef CONFIG_ATAPI
retries = 0; @@ -752,7 +752,7 @@ void ide_init(void)
for (i = 0; i < CONFIG_SYS_IDE_MAXDEVICE; ++i) { ide_dev_desc[i].type = DEV_TYPE_UNKNOWN; - ide_dev_desc[i].if_type = UCLASS_IDE; + ide_dev_desc[i].uclass_id = UCLASS_IDE; ide_dev_desc[i].devnum = i; ide_dev_desc[i].part_type = PART_TYPE_UNKNOWN; ide_dev_desc[i].blksz = 0; @@ -1143,8 +1143,8 @@ UCLASS_DRIVER(ide) = { }; #else U_BOOT_LEGACY_BLK(ide) = { - .if_typename = "ide", - .if_type = UCLASS_IDE, + .uclass_idname = "ide", + .uclass_id = UCLASS_IDE, .max_devs = CONFIG_SYS_IDE_MAXDEVICE, .desc = ide_dev_desc, }; diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index 2de12e0a93e..6e43404bcaa 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -192,7 +192,7 @@ int host_dev_bind(int dev, char *filename, bool removable) }
struct blk_desc *blk_dev = &host_dev->blk_dev; - blk_dev->if_type = UCLASS_ROOT; + blk_dev->uclass_id = UCLASS_ROOT; blk_dev->priv = host_dev; blk_dev->blksz = 512; blk_dev->lba = os_lseek(host_dev->fd, 0, OS_SEEK_END) / blk_dev->blksz; @@ -262,8 +262,8 @@ U_BOOT_DRIVER(sandbox_host_blk) = { }; #else U_BOOT_LEGACY_BLK(sandbox_host) = { - .if_typename = "host", - .if_type = UCLASS_ROOT, + .uclass_idname = "host", + .uclass_id = UCLASS_ROOT, .max_devs = SANDBOX_HOST_MAX_DEVICES, .get_dev = host_get_dev_err, }; diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index b1bd4ae1bc8..759a6b728c8 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -472,7 +472,7 @@ static int mmc_select_hwpart(struct udevice *bdev, int hwpart)
ret = mmc_switch_part(mmc, hwpart); if (!ret) - blkcache_invalidate(desc->if_type, desc->devnum); + blkcache_invalidate(desc->uclass_id, desc->devnum);
return ret; } diff --git a/drivers/mmc/mmc_legacy.c b/drivers/mmc/mmc_legacy.c index 4e0891e5dfe..a101ee43fde 100644 --- a/drivers/mmc/mmc_legacy.c +++ b/drivers/mmc/mmc_legacy.c @@ -132,7 +132,7 @@ static struct mmc mmc_static = { .dsr_imp = 0, .dsr = 0xffffffff, .block_dev = { - .if_type = UCLASS_MMC, + .uclass_id = UCLASS_MMC, .removable = 1, .devnum = 0, .block_read = mmc_bread, @@ -194,7 +194,7 @@ struct mmc *mmc_create(const struct mmc_config *cfg, void *priv) mmc->dsr = 0xffffffff; /* Setup the universal parts of the block interface just once */ bdesc = mmc_get_blk_desc(mmc); - bdesc->if_type = UCLASS_MMC; + bdesc->uclass_id = UCLASS_MMC; bdesc->removable = 1; bdesc->devnum = mmc_get_next_devnum(); bdesc->block_read = mmc_bread; @@ -253,8 +253,8 @@ static int mmc_get_dev(int dev, struct blk_desc **descp) }
U_BOOT_LEGACY_BLK(mmc) = { - .if_typename = "mmc", - .if_type = UCLASS_MMC, + .uclass_idname = "mmc", + .uclass_id = UCLASS_MMC, .max_devs = -1, .get_dev = mmc_get_dev, .select_hwpart = mmc_select_hwpartp, diff --git a/drivers/net/fsl_enetc.c b/drivers/net/fsl_enetc.c index cd4c2c29a65..f1682864611 100644 --- a/drivers/net/fsl_enetc.c +++ b/drivers/net/fsl_enetc.c @@ -144,7 +144,7 @@ static int enetc_init_sgmii(struct udevice *dev) if (!enetc_has_imdio(dev)) return 0;
- if (priv->if_type == PHY_INTERFACE_MODE_2500BASEX) + if (priv->uclass_id == PHY_INTERFACE_MODE_2500BASEX) is2500 = true;
/* @@ -219,7 +219,7 @@ static void enetc_setup_mac_iface(struct udevice *dev, struct enetc_priv *priv = dev_get_priv(dev); u32 if_mode;
- switch (priv->if_type) { + switch (priv->uclass_id) { case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_RGMII_RXID: @@ -276,14 +276,14 @@ static void enetc_start_pcs(struct udevice *dev) return; }
- priv->if_type = dev_read_phy_mode(dev); - if (priv->if_type == PHY_INTERFACE_MODE_NA) { + priv->uclass_id = dev_read_phy_mode(dev); + if (priv->uclass_id == PHY_INTERFACE_MODE_NA) { enetc_dbg(dev, "phy-mode property not found, defaulting to SGMII\n"); - priv->if_type = PHY_INTERFACE_MODE_SGMII; + priv->uclass_id = PHY_INTERFACE_MODE_SGMII; }
- switch (priv->if_type) { + switch (priv->uclass_id) { case PHY_INTERFACE_MODE_SGMII: case PHY_INTERFACE_MODE_2500BASEX: enetc_init_sgmii(dev); diff --git a/drivers/net/fsl_enetc.h b/drivers/net/fsl_enetc.h index 69f2f4aaff1..f2acf367aa3 100644 --- a/drivers/net/fsl_enetc.h +++ b/drivers/net/fsl_enetc.h @@ -158,7 +158,7 @@ struct enetc_priv { struct bd_ring tx_bdr; struct bd_ring rx_bdr;
- int if_type; + int uclass_id; struct mii_dev imdio; struct phy_device *phy; }; diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index 99be5aef877..3e769b0843f 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -456,7 +456,7 @@ static void scsi_init_dev_desc(struct blk_desc *dev_desc, int devnum) { dev_desc->lba = 0; dev_desc->blksz = 0; - dev_desc->if_type = UCLASS_SCSI; + dev_desc->uclass_id = UCLASS_SCSI; dev_desc->devnum = devnum; dev_desc->part_type = PART_TYPE_UNKNOWN;
@@ -706,8 +706,8 @@ U_BOOT_DRIVER(scsi_blk) = { }; #else U_BOOT_LEGACY_BLK(scsi) = { - .if_typename = "scsi", - .if_type = UCLASS_SCSI, + .uclass_idname = "scsi", + .uclass_id = UCLASS_SCSI, .max_devs = SCSI_MAX_DEVICE, .desc = scsi_dev_desc, }; diff --git a/drivers/virtio/virtio_blk.c b/drivers/virtio/virtio_blk.c index 9710b79117c..30cfc56725c 100644 --- a/drivers/virtio/virtio_blk.c +++ b/drivers/virtio/virtio_blk.c @@ -75,7 +75,7 @@ static int virtio_blk_bind(struct udevice *dev) struct blk_desc *desc = dev_get_uclass_plat(dev); int devnum;
- desc->if_type = UCLASS_VIRTIO; + desc->uclass_id = UCLASS_VIRTIO; /* * Initialize the devnum to -ENODEV. This is to make sure that * blk_next_free_devnum() works as expected, since the default diff --git a/drivers/xen/pvblock.c b/drivers/xen/pvblock.c index 1090e528d02..970182cd904 100644 --- a/drivers/xen/pvblock.c +++ b/drivers/xen/pvblock.c @@ -665,7 +665,7 @@ static int pvblock_blk_bind(struct udevice *udev) struct blk_desc *desc = dev_get_uclass_plat(udev); int devnum;
- desc->if_type = UCLASS_PVBLOCK; + desc->uclass_id = UCLASS_PVBLOCK; /* * Initialize the devnum to -ENODEV. This is to make sure that * blk_next_free_devnum() works as expected, since the default diff --git a/fs/fat/fat.c b/fs/fat/fat.c index c64e253abd4..a945904785f 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -1145,7 +1145,7 @@ int file_fat_detectfs(void) }
if (blk_enabled()) { - printf("Interface: %s\n", blk_get_if_type_name(cur_dev->if_type)); + printf("Interface: %s\n", blk_get_uclass_name(cur_dev->uclass_id)); printf(" Device %d: ", cur_dev->devnum); dev_print(cur_dev); } diff --git a/include/blk.h b/include/blk.h index 279f9ea4a9d..cdc6f0fc7eb 100644 --- a/include/blk.h +++ b/include/blk.h @@ -54,7 +54,7 @@ struct blk_desc { * TODO: With driver model we should be able to use the parent * device's uclass instead. */ - enum uclass_id if_type; /* type of the interface */ + enum uclass_id uclass_id; /* type of the interface */ int devnum; /* device number */ unsigned char part_type; /* partition type */ unsigned char target; /* target SCSI ID */ @@ -114,7 +114,7 @@ int blkcache_init(void); /** * blkcache_read() - attempt to read a set of blocks from cache * - * @param iftype - IF_TYPE_x for type of device + * @param iftype - uclass_id_x for type of device * @param dev - device index of particular type * @param start - starting block number * @param blkcnt - number of blocks to read @@ -131,7 +131,7 @@ int blkcache_read(int iftype, int dev, * blkcache_fill() - make data read from a block device available * to the block cache * - * @param iftype - IF_TYPE_x for type of device + * @param iftype - uclass_id_x for type of device * @param dev - device index of particular type * @param start - starting block number * @param blkcnt - number of blocks available @@ -147,7 +147,7 @@ void blkcache_fill(int iftype, int dev, * blkcache_invalidate() - discard the cache for a set of blocks * because of a write or device (re)initialization. * - * @param iftype - IF_TYPE_x for type of device + * @param iftype - uclass_id_x for type of device * @param dev - device index of particular type */ void blkcache_invalidate(int iftype, int dev); @@ -279,22 +279,22 @@ unsigned long blk_derase(struct blk_desc *block_dev, lbaint_t start, * This function does not activate the device. The device will be returned * whether or not it is activated. * - * @if_type: Interface type (enum uclass_id_t) + * @uclass_id: Interface type (enum uclass_id_t) * @devnum: Device number (specific to each interface type) * @devp: the device, if found * Return: 0 if found, -ENODEV if no device found, or other -ve error value */ -int blk_find_device(int if_type, int devnum, struct udevice **devp); +int blk_find_device(int uclass_id, int devnum, struct udevice **devp);
/** * blk_get_device() - Find and probe a block device ready for use * - * @if_type: Interface type (enum uclass_id_t) + * @uclass_id: Interface type (enum uclass_id_t) * @devnum: Device number (specific to each interface type) * @devp: the device, if found * Return: 0 if found, -ENODEV if no device found, or other -ve error value */ -int blk_get_device(int if_type, int devnum, struct udevice **devp); +int blk_get_device(int uclass_id, int devnum, struct udevice **devp);
/** * blk_first_device() - Find the first device for a given interface @@ -305,7 +305,7 @@ int blk_get_device(int if_type, int devnum, struct udevice **devp); * @devp: the device, if found * Return: 0 if found, -ENODEV if no device, or other -ve error value */ -int blk_first_device(int if_type, struct udevice **devp); +int blk_first_device(int uclass_id, struct udevice **devp);
/** * blk_next_device() - Find the next device for a given interface @@ -327,7 +327,7 @@ int blk_next_device(struct udevice **devp); * @parent: Parent of the new device * @drv_name: Driver name to use for the block device * @name: Name for the device - * @if_type: Interface type (enum uclass_id_t) + * @uclass_id: Interface type (enum uclass_id_t) * @devnum: Device number, specific to the interface type, or -1 to * allocate the next available number * @blksz: Block size of the device in bytes (typically 512) @@ -335,7 +335,7 @@ int blk_next_device(struct udevice **devp); * @devp: the new device (which has not been probed) */ int blk_create_device(struct udevice *parent, const char *drv_name, - const char *name, int if_type, int devnum, int blksz, + const char *name, int uclass_id, int devnum, int blksz, lbaint_t lba, struct udevice **devp);
/** @@ -344,7 +344,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, * @parent: Parent of the new device * @drv_name: Driver name to use for the block device * @name: Name for the device (parent name is prepended) - * @if_type: Interface type (enum uclass_id_t) + * @uclass_id: Interface type (enum uclass_id_t) * @devnum: Device number, specific to the interface type, or -1 to * allocate the next available number * @blksz: Block size of the device in bytes (typically 512) @@ -352,7 +352,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, * @devp: the new device (which has not been probed) */ int blk_create_devicef(struct udevice *parent, const char *drv_name, - const char *name, int if_type, int devnum, int blksz, + const char *name, int uclass_id, int devnum, int blksz, lbaint_t lba, struct udevice **devp);
/** @@ -372,33 +372,33 @@ int blk_probe_or_unbind(struct udevice *dev); * * The devices are removed and then unbound. * - * @if_type: Interface type to unbind + * @uclass_id: Interface type to unbind * Return: 0 if OK, -ve on error */ -int blk_unbind_all(int if_type); +int blk_unbind_all(int uclass_id);
/** * blk_find_max_devnum() - find the maximum device number for an interface type * - * Finds the last allocated device number for an interface type @if_type. The + * Finds the last allocated device number for an interface type @uclass_id. The * next number is safe to use for a newly allocated device. * - * @if_type: Interface type to scan + * @uclass_id: Interface type to scan * Return: maximum device number found, or -ENODEV if none, or other -ve on * error */ -int blk_find_max_devnum(enum uclass_id if_type); +int blk_find_max_devnum(enum uclass_id uclass_id);
/** * blk_next_free_devnum() - get the next device number for an interface type * * Finds the next number that is safe to use for a newly allocated device for - * an interface type @if_type. + * an interface type @uclass_id. * - * @if_type: Interface type to scan + * @uclass_id: Interface type to scan * Return: next device number safe to use, or -ve on error */ -int blk_next_free_devnum(enum uclass_id if_type); +int blk_next_free_devnum(enum uclass_id uclass_id);
/** * blk_select_hwpart() - select a hardware partition @@ -447,7 +447,7 @@ static inline ulong blk_dread(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt, void *buffer) { ulong blks_read; - if (blkcache_read(block_dev->if_type, block_dev->devnum, + if (blkcache_read(block_dev->uclass_id, block_dev->devnum, start, blkcnt, block_dev->blksz, buffer)) return blkcnt;
@@ -458,7 +458,7 @@ static inline ulong blk_dread(struct blk_desc *block_dev, lbaint_t start, */ blks_read = block_dev->block_read(block_dev, start, blkcnt, buffer); if (blks_read == blkcnt) - blkcache_fill(block_dev->if_type, block_dev->devnum, + blkcache_fill(block_dev->uclass_id, block_dev->devnum, start, blkcnt, block_dev->blksz, buffer);
return blks_read; @@ -467,14 +467,14 @@ static inline ulong blk_dread(struct blk_desc *block_dev, lbaint_t start, static inline ulong blk_dwrite(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt, const void *buffer) { - blkcache_invalidate(block_dev->if_type, block_dev->devnum); + blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return block_dev->block_write(block_dev, start, blkcnt, buffer); }
static inline ulong blk_derase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) { - blkcache_invalidate(block_dev->if_type, block_dev->devnum); + blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return block_dev->block_erase(block_dev, start, blkcnt); }
@@ -485,15 +485,15 @@ static inline ulong blk_derase(struct blk_desc *block_dev, lbaint_t start, * driver should be provided using U_BOOT_LEGACY_BLK() for each interface * type that is to be supported. * - * @if_typename: Interface type name - * @if_type: Interface type + * @uclass_idname: Interface type name + * @uclass_id: Interface type * @max_devs: Maximum number of devices supported * @desc: Pointer to list of devices for this interface type, * or NULL to use @get_dev() instead */ struct blk_driver { - const char *if_typename; - enum uclass_id if_type; + const char *uclass_idname; + enum uclass_id uclass_id; int max_devs; struct blk_desc *desc; /** @@ -540,7 +540,7 @@ struct blk_driver { #define U_BOOT_LEGACY_BLK(__name) \ ll_entry_declare(struct blk_driver, __name, blk_driver)
-struct blk_driver *blk_driver_lookup_type(int if_type); +struct blk_driver *blk_driver_lookup_type(int uclass_id);
#endif /* !CONFIG_BLK */
@@ -550,23 +550,23 @@ struct blk_driver *blk_driver_lookup_type(int if_type); * This looks through the available block devices of the given type, returning * the one with the given @devnum. * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * Return: point to block device descriptor, or NULL if not found */ -struct blk_desc *blk_get_devnum_by_type(enum uclass_id if_type, int devnum); +struct blk_desc *blk_get_devnum_by_type(enum uclass_id uclass_id, int devnum);
/** * blk_get_devnum_by_type() - Get a block device by type name, and number * - * This looks up the block device type based on @if_typename, then calls + * This looks up the block device type based on @uclass_idname, then calls * blk_get_devnum_by_type(). * - * @if_typename: Block device type name + * @uclass_idname: Block device type name * @devnum: Device number * Return: point to block device descriptor, or NULL if not found */ -struct blk_desc *blk_get_devnum_by_typename(const char *if_typename, +struct blk_desc *blk_get_devnum_by_typename(const char *uclass_idname, int devnum);
/** @@ -585,34 +585,34 @@ int blk_dselect_hwpart(struct blk_desc *desc, int hwpart); /** * blk_list_part() - list the partitions for block devices of a given type * - * This looks up the partition type for each block device of type @if_type, + * This looks up the partition type for each block device of type @uclass_id, * then displays a list of partitions. * - * @if_type: Block device type + * @uclass_id: Block device type * Return: 0 if OK, -ENODEV if there is none of that type */ -int blk_list_part(enum uclass_id if_type); +int blk_list_part(enum uclass_id uclass_id);
/** * blk_list_devices() - list the block devices of a given type * - * This lists each block device of the type @if_type, showing the capacity + * This lists each block device of the type @uclass_id, showing the capacity * as well as type-specific information. * - * @if_type: Block device type + * @uclass_id: Block device type */ -void blk_list_devices(enum uclass_id if_type); +void blk_list_devices(enum uclass_id uclass_id);
/** * blk_show_device() - show information about a given block device * * This shows the block device capacity as well as type-specific information. * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * Return: 0 if OK, -ENODEV for invalid device number */ -int blk_show_device(enum uclass_id if_type, int devnum); +int blk_show_device(enum uclass_id uclass_id, int devnum);
/** * blk_print_device_num() - show information about a given block device @@ -620,45 +620,45 @@ int blk_show_device(enum uclass_id if_type, int devnum); * This is similar to blk_show_device() but returns an error if the block * device type is unknown. * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * Return: 0 if OK, -ENODEV for invalid device number, -ENOENT if the block * device is not connected */ -int blk_print_device_num(enum uclass_id if_type, int devnum); +int blk_print_device_num(enum uclass_id uclass_id, int devnum);
/** * blk_print_part_devnum() - print the partition information for a device * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * Return: 0 if OK, -ENOENT if the block device is not connected, -ENOSYS if * the interface type is not supported, other -ve on other error */ -int blk_print_part_devnum(enum uclass_id if_type, int devnum); +int blk_print_part_devnum(enum uclass_id uclass_id, int devnum);
/** * blk_read_devnum() - read blocks from a device * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * @blkcnt: Number of blocks to read * @buffer: Address to write data to * Return: number of blocks read, or -ve error number on error */ -ulong blk_read_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_read_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, void *buffer);
/** * blk_write_devnum() - write blocks to a device * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * @blkcnt: Number of blocks to write * @buffer: Address to read data from * Return: number of blocks written, or -ve error number on error */ -ulong blk_write_devnum(enum uclass_id if_type, int devnum, lbaint_t start, +ulong blk_write_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, lbaint_t blkcnt, const void *buffer);
/** @@ -667,31 +667,31 @@ ulong blk_write_devnum(enum uclass_id if_type, int devnum, lbaint_t start, * This is similar to blk_dselect_hwpart() but it looks up the interface and * device number. * - * @if_type: Block device type + * @uclass_id: Block device type * @devnum: Device number * @hwpart: Partition number to select * Return: 0 if OK, -ve on error */ -int blk_select_hwpart_devnum(enum uclass_id if_type, int devnum, int hwpart); +int blk_select_hwpart_devnum(enum uclass_id uclass_id, int devnum, int hwpart);
/** - * blk_get_if_type_name() - Get the name of an interface type + * blk_get_uclass_name() - Get the name of an interface type * - * @if_type: Interface type to check + * @uclass_id: Interface type to check * Return: name of interface, or NULL if none */ -const char *blk_get_if_type_name(enum uclass_id if_type); +const char *blk_get_uclass_name(enum uclass_id uclass_id);
/** * blk_common_cmd() - handle common commands with block devices * * @args: Number of arguments to the command (argv[0] is the command itself) * @argv: Command arguments - * @if_type: Interface type + * @uclass_id: Interface type * @cur_devnump: Current device number for this interface type * Return: 0 if OK, CMD_RET_ERROR on error */ -int blk_common_cmd(int argc, char *const argv[], enum uclass_id if_type, +int blk_common_cmd(int argc, char *const argv[], enum uclass_id uclass_id, int *cur_devnump);
enum blk_flag_t { diff --git a/include/efi_api.h b/include/efi_api.h index 83c01085fde..f9c9aa64b24 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -622,7 +622,7 @@ struct efi_device_path_sata { struct efi_device_path_mac_addr { struct efi_device_path dp; struct efi_mac_addr mac; - u8 if_type; + u8 uclass_id; } __packed;
struct efi_device_path_usb_class { @@ -1410,7 +1410,7 @@ struct efi_simple_network_mode { struct efi_mac_address current_address; struct efi_mac_address broadcast_address; struct efi_mac_address permanent_address; - u8 if_type; + u8 uclass_id; u8 mac_changeable; u8 multitx_supported; u8 media_present_supported; diff --git a/include/efi_loader.h b/include/efi_loader.h index fb35087ddb0..f528fdd1837 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -161,7 +161,7 @@ extern bool efi_st_keep_devices;
/* EFI system partition */ extern struct efi_system_partition { - enum uclass_id if_type; + enum uclass_id uclass_id; int devnum; u8 part; } efi_system_partition; @@ -560,7 +560,7 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, struct efi_loaded_image *loaded_image_info); /* Create handles and protocols for the partitions of a block device */ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc, - const char *if_typename, int diskid, + const char *uclass_idname, int diskid, const char *pdevname); /* Called by bootefi to make GOP (graphical) interface available */ efi_status_t efi_gop_register(void); diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index ebffb771228..9787033c3df 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -626,7 +626,7 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) /* We only support IPv4 */ memcpy(&dp->mac, &pdata->enetaddr, ARP_HLEN); /* Ethernet */ - dp->if_type = 1; + dp->uclass_id = 1; return &dp[1]; } #endif diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 6c428ee061f..fde30156b31 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -156,12 +156,12 @@ static char *dp_msging(char *s, struct efi_device_path *dp) struct efi_device_path_mac_addr *mdp = (struct efi_device_path_mac_addr *)dp;
- if (mdp->if_type <= 1) + if (mdp->uclass_id <= 1) n = 6; s += sprintf(s, "MAC("); for (i = 0; i < n; ++i) s += sprintf(s, "%02x", mdp->mac.addr[i]); - s += sprintf(s, ",%u)", mdp->if_type); + s += sprintf(s, ",%u)", mdp->uclass_id);
break; } diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 819dcb4f131..022ca8fef8b 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -498,13 +498,13 @@ static efi_status_t efi_disk_add_dev( diskobj->media.last_block);
/* Store first EFI system partition */ - if (part && !efi_system_partition.if_type) { + if (part && !efi_system_partition.uclass_id) { if (part_info->bootable & PART_EFI_SYSTEM_PARTITION) { - efi_system_partition.if_type = desc->if_type; + efi_system_partition.uclass_id = desc->uclass_id; efi_system_partition.devnum = desc->devnum; efi_system_partition.part = part; EFI_PRINT("EFI system partition: %s %x:%x\n", - blk_get_if_type_name(desc->if_type), + blk_get_uclass_name(desc->uclass_id), desc->devnum, part); } } @@ -640,7 +640,7 @@ static int efi_disk_probe(void *ctx, struct event *event) * has already created an efi_disk at this moment. */ desc = dev_get_uclass_plat(dev); - if (desc->if_type != UCLASS_EFI_LOADER) { + if (desc->uclass_id != UCLASS_EFI_LOADER) { ret = efi_disk_create_raw(dev); if (ret) return -1; @@ -675,7 +675,7 @@ static int efi_disk_delete_raw(struct udevice *dev) return -1;
desc = dev_get_uclass_plat(dev); - if (desc->if_type != UCLASS_EFI_LOADER) { + if (desc->uclass_id != UCLASS_EFI_LOADER) { diskobj = container_of(handle, struct efi_disk_obj, header); efi_free_pool(diskobj->dp); } @@ -794,7 +794,7 @@ efi_status_t efi_disk_get_device_name(const efi_handle_t handle, char *buf, int } else { return EFI_INVALID_PARAMETER; } - if_typename = blk_get_if_type_name(desc->if_type); + if_typename = blk_get_uclass_name(desc->uclass_id); diskid = desc->devnum;
if (is_partition) { diff --git a/lib/efi_loader/efi_net.c b/lib/efi_loader/efi_net.c index 69276b275d9..0cdc1ff5381 100644 --- a/lib/efi_loader/efi_net.c +++ b/lib/efi_loader/efi_net.c @@ -924,7 +924,7 @@ efi_status_t efi_net_register(void) netobj->net_mode.hwaddr_size = ARP_HLEN; netobj->net_mode.media_header_size = ETHER_HDR_SIZE; netobj->net_mode.max_packet_size = PKTSIZE; - netobj->net_mode.if_type = ARP_ETHER; + netobj->net_mode.uclass_id = ARP_ETHER;
netobj->pxe.revision = EFI_PXE_BASE_CODE_PROTOCOL_REVISION; netobj->pxe.start = efi_pxe_base_code_start; diff --git a/lib/efi_loader/efi_var_file.c b/lib/efi_loader/efi_var_file.c index 994e66392fb..3d58caa13da 100644 --- a/lib/efi_loader/efi_var_file.c +++ b/lib/efi_loader/efi_var_file.c @@ -38,13 +38,13 @@ static efi_status_t __maybe_unused efi_set_blk_dev_to_system_partition(void) char part_str[PART_STR_LEN]; int r;
- if (efi_system_partition.if_type == UCLASS_INVALID) { + if (efi_system_partition.uclass_id == UCLASS_INVALID) { log_err("No EFI system partition\n"); return EFI_DEVICE_ERROR; } snprintf(part_str, PART_STR_LEN, "%x:%x", efi_system_partition.devnum, efi_system_partition.part); - r = fs_set_blk_dev(blk_get_if_type_name(efi_system_partition.if_type), + r = fs_set_blk_dev(blk_get_uclass_name(efi_system_partition.uclass_id), part_str, FS_TYPE_ANY); if (r) { log_err("Cannot read EFI system partition\n");
NAK. You seem to have missed out some of my comments. See: https://lists.denx.de/pipermail/u-boot/2022-September/494583.html (against efi_api.h, efi_device_path.c, efi_device_path_to_text.c and efi_net.c)
-Takahiro Akashi
Changes in v3:
Changes in v2:
- name = blk_get_uclass_name(desc->uclass_id); devnum = desc->devnum; len = strlen(buf);
} else if (strncmp(argv[1], "dev", 3) == 0) {blk_list_devices(uclass_id); return 0;
} else if (strncmp(argv[1], "part", 4) == 0) {if (blk_print_device_num(uclass_id, *cur_devnump)) { printf("\nno %s devices available\n", if_name); return CMD_RET_FAILURE; } return 0;
n = blk_read_devnum(uclass_id, *cur_devnump, blk, cnt, (ulong *)addr); printf("%ld blocks read: %s\n", n,
n = blk_write_devnum(uclass_id, *cur_devnump, blk, cnt, (ulong *)addr); printf("%ld blocks written: %s\n", n,
}blk_get_uclass_name(desc->uclass_id), desc->devnum); i++;
- blkcache_invalidate(bd->uclass_id, bd->devnum);
#endif
blkdev->devnum = usb_max_devs; blkdev->part_type = PART_TYPE_UNKNOWN; blkdev->target = 0xff;blkdev->uclass_id = UCLASS_USB;
- .uclass_idname = "usb",
- .uclass_id = UCLASS_USB, .max_devs = USB_MAX_STOR_DEV, .desc = usb_dev_desc,
- if (blkcache_read(block_dev->uclass_id, block_dev->devnum, start_in_disk, blkcnt, block_dev->blksz, buffer)) return blkcnt; blks_read = ops->read(dev, start, blkcnt, buffer); if (blks_read == blkcnt)
return blks_read;
- switch (dev_desc->uclass_id) { case UCLASS_SCSI: printf ("(%d:%d) Vendor: %s Prod.: %s Rev: %s\n", dev_desc->target,dev_desc->lun,
return; } puts (" Type: ");printf("Unhandled device type: %i\n", dev_desc->uclass_id);
- switch (dev_desc->uclass_id) { case UCLASS_IDE: puts ("IDE"); break;
}if ((*dev_desc)->uclass_id == UCLASS_MMC) part_init(*dev_desc);
- switch (dev_desc->uclass_id) { case UCLASS_IDE: case UCLASS_AHCI: devtype = "hd";
sata_dev_desc[i].devnum = i; sata_dev_desc[i].part_type = PART_TYPE_UNKNOWN; sata_dev_desc[i].type = DEV_TYPE_HARDDISK;sata_dev_desc[i].uclass_id = UCLASS_AHCI;
- if (uclass_id == UCLASS_USB) return UCLASS_MASS_STORAGE;
- return if_type;
- return uclass_id;
return "(none)";
- ret = blk_get_device(uclass_id, devnum, &dev); if (ret) return NULL; desc = dev_get_uclass_plat(dev);
- name in a local table. This gives us an interface type which we can match
- against the uclass of the block device's parent.
- type = uclass_idname_to_iftype(uclass_idname); if (type == UCLASS_INVALID) { debug("%s: Unknown interface type '%s'\n", __func__,
if_typename);
return NULL; }uclass_idname);
- uclass_id = conv_uclass_id(type); if (uclass_id == UCLASS_INVALID) { debug("%s: Unknown uclass for interface type'\n",
return NULL; }blk_get_uclass_name(type));
if (desc->devnum != devnum) continue;type, devnum, dev->name, desc->uclass_id, desc->devnum);
- get_desc() - Get the block device descriptor for the given device number
- @if_type: Interface type
- @uclass_id: Interface type
- @devnum: Device number (0 = first)
- @descp: Returns block device descriptor on success
- Return: 0 on success, -ENODEV if there is no such device and no device
- with a higher device number, -ENOENT if there is no such device but there
- is one with a higher number, or other -ve on other error.
if (ret == -ENODEV) break; else if (ret)ret = get_desc(uclass_id, devnum, &desc);
- ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; if (desc->type == DEV_TYPE_UNKNOWN)
for (i = 0;; ++i) {
if (ret == -ENODEV) break; else if (ret)ret = get_desc(uclass_id, i, &desc);
- ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; printf("\nIDE device %d: ", devnum);
- ret = get_desc(uclass_id, devnum, &desc); if (ret == -ENODEV || ret == -ENOENT) { printf("unknown device\n"); return -ENODEV;
- ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; n = blk_dread(desc, start, blkcnt, buffer);
- ret = get_desc(uclass_id, devnum, &desc); if (ret) return ret; return blk_dwrite(desc, start, blkcnt, buffer);
ret = uclass_find_next_device(devp); if (ret)if (desc->uclass_id == uclass_id) return 0;
- int ret, if_type;
int ret, uclass_id;
- uclass_id = desc->uclass_id; do { ret = uclass_find_next_device(devp); if (ret)
} while (1);if (desc->uclass_id == uclass_id) return 0;
}if (desc->uclass_id == uclass_id && desc->devnum == devnum) { *devp = dev; return 0;
- ret = blk_find_device(uclass_id, devnum, devp); if (ret) return ret;
- if (blkcache_read(block_dev->uclass_id, block_dev->devnum, start, blkcnt, block_dev->blksz, buffer)) return blkcnt; blks_read = ops->read(dev, start, blkcnt, buffer); if (blks_read == blkcnt)
return blks_read;
- blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return ops->write(dev, start, blkcnt, buffer);
- blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return ops->erase(dev, start, blkcnt);
return max_devnum;
- ret = blk_find_max_devnum(uclass_id); if (ret == -ENODEV) return 0; if (ret < 0)
int next = blk_next_free_devnum(uclass_id); if (next < 0) return next;
if (devnum == -1) {
} else {devnum = blk_next_free_devnum(uclass_id);
if (ret < 0 && ret != -ENOENT) return ret; }ret = blk_claim_devnum(uclass_id, devnum);
- desc->uclass_id = uclass_id; desc->blksz = blksz; desc->log2blksz = LOG2(desc->blksz); desc->lba = lba;
- ret = blk_create_device(parent, drv_name, str, uclass_id, devnum, blksz, lba, devp); if (ret) { free(str);
}if (uclass_id == entry->uclass_id) return entry;
}if (!strcmp(uclass_idname, entry->uclass_idname)) return entry;
- struct blk_driver *drv = blk_driver_lookup_type(uclass_id);
- return drv ? drv->uclass_idname : NULL;
- drv = blk_driver_lookup_type(uclass_id); if (!drv) return -ENOSYS; for (ok = 0, devnum = 0; devnum < drv->max_devs; ++devnum) {
- struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int ret;
- struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; int i;
if (!drv)
if (!drv)
- struct blk_driver *drv = blk_driver_lookup_type(uclass_id); struct blk_desc *desc; ulong n; int ret;
- dev_desc->uclass_id = UCLASS_IDE;
#ifdef CONFIG_ATAPI
ide_dev_desc[i].devnum = i; ide_dev_desc[i].part_type = PART_TYPE_UNKNOWN; ide_dev_desc[i].blksz = 0;ide_dev_desc[i].uclass_id = UCLASS_IDE;
- .uclass_idname = "ide",
- .uclass_id = UCLASS_IDE, .max_devs = CONFIG_SYS_IDE_MAXDEVICE, .desc = ide_dev_desc,
- blk_dev->uclass_id = UCLASS_ROOT; blk_dev->priv = host_dev; blk_dev->blksz = 512; blk_dev->lba = os_lseek(host_dev->fd, 0, OS_SEEK_END) / blk_dev->blksz;
- .uclass_idname = "host",
- .uclass_id = UCLASS_ROOT, .max_devs = SANDBOX_HOST_MAX_DEVICES, .get_dev = host_get_dev_err,
return ret;
.removable = 1, .devnum = 0, .block_read = mmc_bread,.uclass_id = UCLASS_MMC,
- bdesc->uclass_id = UCLASS_MMC; bdesc->removable = 1; bdesc->devnum = mmc_get_next_devnum(); bdesc->block_read = mmc_bread;
- .uclass_idname = "mmc",
- .uclass_id = UCLASS_MMC, .max_devs = -1, .get_dev = mmc_get_dev, .select_hwpart = mmc_select_hwpartp,
- switch (priv->uclass_id) { case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_RGMII_RXID:
- priv->uclass_id = dev_read_phy_mode(dev);
- if (priv->uclass_id == PHY_INTERFACE_MODE_NA) { enetc_dbg(dev, "phy-mode property not found, defaulting to SGMII\n");
}priv->uclass_id = PHY_INTERFACE_MODE_SGMII;
- switch (priv->uclass_id) { case PHY_INTERFACE_MODE_SGMII: case PHY_INTERFACE_MODE_2500BASEX: enetc_init_sgmii(dev);
- int if_type;
- int uclass_id; struct mii_dev imdio; struct phy_device *phy;
- dev_desc->uclass_id = UCLASS_SCSI; dev_desc->devnum = devnum; dev_desc->part_type = PART_TYPE_UNKNOWN;
- .uclass_idname = "scsi",
- .uclass_id = UCLASS_SCSI, .max_devs = SCSI_MAX_DEVICE, .desc = scsi_dev_desc,
- desc->uclass_id = UCLASS_VIRTIO; /*
- Initialize the devnum to -ENODEV. This is to make sure that
- blk_next_free_devnum() works as expected, since the default
- desc->uclass_id = UCLASS_PVBLOCK; /*
printf(" Device %d: ", cur_dev->devnum); dev_print(cur_dev); }printf("Interface: %s\n", blk_get_uclass_name(cur_dev->uclass_id));
- enum uclass_id uclass_id; /* type of the interface */ int devnum; /* device number */ unsigned char part_type; /* partition type */ unsigned char target; /* target SCSI ID */
- blkcache_read() - attempt to read a set of blocks from cache
- @param iftype - IF_TYPE_x for type of device
- @param iftype - uclass_id_x for type of device
- @param dev - device index of particular type
- @param start - starting block number
- @param blkcnt - number of blocks to read
- blkcache_fill() - make data read from a block device available
- to the block cache
- @param blkcnt - number of blocks available
- blkcache_invalidate() - discard the cache for a set of blocks
- because of a write or device (re)initialization.
- This function does not activate the device. The device will be returned
- whether or not it is activated.
- @if_type: Interface type (enum uclass_id_t)
- @uclass_id: Interface type (enum uclass_id_t)
- @devnum: Device number (specific to each interface type)
- @devp: the device, if found
- Return: 0 if found, -ENODEV if no device found, or other -ve error value
- blk_get_device() - Find and probe a block device ready for use
- blk_first_device() - Find the first device for a given interface
- Return: 0 if found, -ENODEV if no device, or other -ve error value
- blk_next_device() - Find the next device for a given interface
- @parent: Parent of the new device
- @drv_name: Driver name to use for the block device
- @name: Name for the device
- @devnum: Device number, specific to the interface type, or -1 to
- @blksz: Block size of the device in bytes (typically 512)
- @devp: the new device (which has not been probed)
- @name: Name for the device (parent name is prepended)
- The devices are removed and then unbound.
- @if_type: Interface type to unbind
- @uclass_id: Interface type to unbind
- Return: 0 if OK, -ve on error
- blk_find_max_devnum() - find the maximum device number for an interface type
- Finds the last allocated device number for an interface type @if_type. The
- Finds the last allocated device number for an interface type @uclass_id. The
- next number is safe to use for a newly allocated device.
- @if_type: Interface type to scan
- @uclass_id: Interface type to scan
- Return: maximum device number found, or -ENODEV if none, or other -ve on
- error
- blk_next_free_devnum() - get the next device number for an interface type
- Finds the next number that is safe to use for a newly allocated device for
- an interface type @if_type.
- an interface type @uclass_id.
- Return: next device number safe to use, or -ve on error
- blk_select_hwpart() - select a hardware partition
return blks_read;
- blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return block_dev->block_write(block_dev, start, blkcnt, buffer);
- blkcache_invalidate(block_dev->uclass_id, block_dev->devnum); return block_dev->block_erase(block_dev, start, blkcnt);
- driver should be provided using U_BOOT_LEGACY_BLK() for each interface
- type that is to be supported.
- @if_typename: Interface type name
- @uclass_idname: Interface type name
- @max_devs: Maximum number of devices supported
- @desc: Pointer to list of devices for this interface type,
struct blk_driver {
- const char *uclass_idname;
- enum uclass_id uclass_id; int max_devs; struct blk_desc *desc; /**
- This looks through the available block devices of the given type, returning
- the one with the given @devnum.
- @if_type: Block device type
- @uclass_id: Block device type
- Return: point to block device descriptor, or NULL if not found
- blk_get_devnum_by_type() - Get a block device by type name, and number
- This looks up the block device type based on @if_typename, then calls
- This looks up the block device type based on @uclass_idname, then calls
- blk_get_devnum_by_type().
- @if_typename: Block device type name
- @uclass_idname: Block device type name
- blk_list_part() - list the partitions for block devices of a given type
- This looks up the partition type for each block device of type @if_type,
- This looks up the partition type for each block device of type @uclass_id,
- then displays a list of partitions.
- Return: 0 if OK, -ENODEV if there is none of that type
- blk_list_devices() - list the block devices of a given type
- This lists each block device of the type @if_type, showing the capacity
- This lists each block device of the type @uclass_id, showing the capacity
- as well as type-specific information.
- blk_show_device() - show information about a given block device
- This shows the block device capacity as well as type-specific information.
- Return: 0 if OK, -ENODEV for invalid device number
- blk_print_device_num() - show information about a given block device
- This is similar to blk_show_device() but returns an error if the block
- device type is unknown.
- Return: 0 if OK, -ENODEV for invalid device number, -ENOENT if the block
- device is not connected
- blk_print_part_devnum() - print the partition information for a device
- Return: 0 if OK, -ENOENT if the block device is not connected, -ENOSYS if
- the interface type is not supported, other -ve on other error
- blk_read_devnum() - read blocks from a device
- @blkcnt: Number of blocks to read
- @buffer: Address to write data to
- Return: number of blocks read, or -ve error number on error
- blk_write_devnum() - write blocks to a device
- @blkcnt: Number of blocks to write
- @buffer: Address to read data from
- Return: number of blocks written, or -ve error number on error
- This is similar to blk_dselect_hwpart() but it looks up the interface and
- device number.
- @hwpart: Partition number to select
- blk_get_if_type_name() - Get the name of an interface type
- blk_get_uclass_name() - Get the name of an interface type
- @if_type: Interface type to check
- @uclass_id: Interface type to check
- Return: name of interface, or NULL if none
- blk_common_cmd() - handle common commands with block devices
- @args: Number of arguments to the command (argv[0] is the command itself)
- @argv: Command arguments
- @cur_devnump: Current device number for this interface type
- Return: 0 if OK, CMD_RET_ERROR on error
- u8 if_type;
- u8 uclass_id;
} __packed;
- u8 if_type;
- u8 uclass_id; u8 mac_changeable; u8 multitx_supported; u8 media_present_supported;
- enum uclass_id uclass_id; int devnum; u8 part;
dp->if_type = 1;
return &dp[1]; }dp->uclass_id = 1;
s += sprintf(s, "MAC("); for (i = 0; i < n; ++i) s += sprintf(s, "%02x", mdp->mac.addr[i]);if (mdp->uclass_id <= 1) n = 6;
break; }
- if (part && !efi_system_partition.uclass_id) { if (part_info->bootable & PART_EFI_SYSTEM_PARTITION) {
} }blk_get_uclass_name(desc->uclass_id), desc->devnum, part);
- if (desc->uclass_id != UCLASS_EFI_LOADER) { ret = efi_disk_create_raw(dev); if (ret) return -1;
- if (desc->uclass_id != UCLASS_EFI_LOADER) { diskobj = container_of(handle, struct efi_disk_obj, header); efi_free_pool(diskobj->dp); }
if (is_partition) {
- if (efi_system_partition.uclass_id == UCLASS_INVALID) { log_err("No EFI system partition\n"); return EFI_DEVICE_ERROR; } snprintf(part_str, PART_STR_LEN, "%x:%x", efi_system_partition.devnum, efi_system_partition.part);
- r = fs_set_blk_dev(blk_get_uclass_name(efi_system_partition.uclass_id), part_str, FS_TYPE_ANY); if (r) { log_err("Cannot read EFI system partition\n");
-- 2.37.3.968.ga6b4b080e4-goog
Hi Takahiro,
On Sat, 17 Sept 2022 at 04:52, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Use the word 'uclass' instead of 'if_type' to complete the conversion.
OK yes I missed that, sorry.
I sent a new version.
Also, are you planning to do another series to better integrate EFI with driver model?
On Sat, Sep 17, 2022 at 11:27:09AM -0600, Simon Glass wrote:
Hi Takahiro,
No, I'm not.
-Takahiro Akashi
AKASHI Takahiro
