[PATCH v2] efi_loader: update SetVariable attribute check
UEFI specification v2.10 says that EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated and EFI_UNSUPPORTED should be returned in SetVariable variable service. Current implementation returns EFI_INVALID_PARAMETER, let's fix the return value.
Together with above change, this commit also updates the SetVariable attribute check to be aligned with the EDK2 reference implementation.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v2: - fix coding style - HR must be set with NV
lib/efi_loader/efi_variable.c | 33 ++++++++++++++++++++++++++------- 1 file changed, 26 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index 4c85cfa607..b12e79d658 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -230,9 +230,31 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, u64 time = 0; enum efi_auth_var_type var_type;
- if (!variable_name || !*variable_name || !vendor || - ((attributes & EFI_VARIABLE_RUNTIME_ACCESS) && - !(attributes & EFI_VARIABLE_BOOTSERVICE_ACCESS))) + if (!variable_name || !*variable_name || !vendor) + return EFI_INVALID_PARAMETER; + + if (data_size && !data) + return EFI_INVALID_PARAMETER; + + /* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */ + if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS || + (!(attributes & EFI_VARIABLE_MASK))) + return EFI_UNSUPPORTED; + + /* Make sure if runtime bit is set, boot service bit is set also */ + if ((attributes & + (EFI_VARIABLE_RUNTIME_ACCESS | EFI_VARIABLE_BOOTSERVICE_ACCESS)) == + EFI_VARIABLE_RUNTIME_ACCESS) + return EFI_INVALID_PARAMETER; + + /* only EFI_VARIABLE_NON_VOLATILE attribute is invalid */ + if ((attributes & EFI_VARIABLE_MASK) == EFI_VARIABLE_NON_VOLATILE) + return EFI_INVALID_PARAMETER; + + /* Make sure HR is set with NV */ + if ((attributes & + (EFI_VARIABLE_NON_VOLATILE | EFI_VARIABLE_HARDWARE_ERROR_RECORD)) == + EFI_VARIABLE_HARDWARE_ERROR_RECORD) return EFI_INVALID_PARAMETER;
/* check if a variable exists */ @@ -281,8 +303,6 @@ efi_status_t efi_set_variable_int(const u16 *variable_name,
/* authenticate a variable */ if (IS_ENABLED(CONFIG_EFI_SECURE_BOOT)) { - if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS) - return EFI_INVALID_PARAMETER; if (attributes & EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { u32 env_attr; @@ -300,8 +320,7 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, } } else { if (attributes & - (EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS | - EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS)) { + EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { EFI_PRINT("Secure boot is not configured\n"); return EFI_INVALID_PARAMETER; }
Changes in v2:
fix coding style
- if (!variable_name || !*variable_name || !vendor)
- if (data_size && !data)
- /* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */
- if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS ||
UEFI Spec 2.10, p. 215: "Setting a data variable with no access attributes causes it to be deleted."
We don't want to make deletion unsupported.
Best regards
Heinrich
if ((attributes &
if ((attributes &
if (attributes & EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { u32 env_attr;return EFI_INVALID_PARAMETER;
}EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { EFI_PRINT("Secure boot is not configured\n"); return EFI_INVALID_PARAMETER;
Hi Heinrich,
Changes in v2:
fix coding style
Sorry, you are correct. I will remove the second condition.
Thanks, Masahisa Kojima
Best regards
Heinrich
if ((attributes &
if ((attributes &
EFI_VARIABLE_HARDWARE_ERROR_RECORD) return EFI_INVALID_PARAMETER; /* check if a variable exists */
Masahisa Kojima
