[U-Boot] [PATCH] configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZE
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c)
GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- include/configs/M54418TWR.h | 4 +--- include/configs/MERGERBOX.h | 3 +-- include/configs/P1023RDS.h | 3 +-- include/configs/ac14xx.h | 3 +-- include/configs/adp-ag101.h | 5 ----- include/configs/adp-ag101p.h | 5 ----- include/configs/adp-ag102.h | 5 ----- include/configs/ap_sh4a_4a.h | 2 -- include/configs/armadillo-800eva.h | 1 - include/configs/devkit3250.h | 1 - include/configs/dlvision-10g.h | 3 +-- include/configs/ecovec.h | 2 -- include/configs/io.h | 3 +-- include/configs/iocon.h | 3 +-- include/configs/km/km83xx-common.h | 1 - include/configs/koelsch.h | 1 - include/configs/kzm9g.h | 1 - include/configs/lager.h | 1 - include/configs/mxs.h | 1 - include/configs/o2dnt-common.h | 4 +--- include/configs/r0p7734.h | 2 -- include/configs/shmin.h | 1 - include/configs/snowball.h | 2 -- include/configs/u8500_href.h | 1 - include/configs/vl_ma2sc.h | 1 - 25 files changed, 8 insertions(+), 51 deletions(-)
diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index de063b7..031672e 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -268,10 +268,8 @@ /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 256 #define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) - 32) + GENERATED_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index 3dcea0b..930699b 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -121,9 +121,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* End of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE -\ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index b513545..ec72c78 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -194,9 +194,8 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ #define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_END - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index aa584b7..f57820d 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -289,9 +289,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE #define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/adp-ag101.h b/include/configs/adp-ag101.h index e31131f..e318c75 100644 --- a/include/configs/adp-ag101.h +++ b/include/configs/adp-ag101.h @@ -139,11 +139,6 @@ #define CONFIG_SYS_MALLOC_LEN (512 << 10)
/* - * size in bytes reserved for initial data - */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 - -/* * AHB Controller configuration */ #define CONFIG_FTAHBC020S diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index ded3f33..24904b0 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -139,11 +139,6 @@ #define CONFIG_SYS_MALLOC_LEN (512 << 10)
/* - * size in bytes reserved for initial data - */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 - -/* * AHB Controller configuration */ #define CONFIG_FTAHBC020S diff --git a/include/configs/adp-ag102.h b/include/configs/adp-ag102.h index 1e4ce2e..39f7a3c 100644 --- a/include/configs/adp-ag102.h +++ b/include/configs/adp-ag102.h @@ -204,11 +204,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
/* - * size in bytes reserved for initial data -*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128 - -/* * AHB Controller configuration */ #define CONFIG_FTAHBC020S diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index bb39491..4282d70 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -134,8 +134,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e5569c7..17a2da0 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -94,7 +94,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000 #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) #define CONFIG_SYS_TEXT_BASE 0xE80C0000
diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index bcb21fe..3d39b10 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -29,7 +29,6 @@ */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_MALLOC_LEN SZ_1M -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_SDRAM_BASE EMC_DYCS0_BASE #define CONFIG_SYS_SDRAM_SIZE SZ_64M #define CONFIG_SYS_TEXT_BASE 0x83FA0000 diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 31fc65d..7877897 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -217,9 +217,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ #define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size/bytes res'd for init data*/ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_END - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 3a5cc74..e26591c 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -158,8 +158,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ diff --git a/include/configs/io.h b/include/configs/io.h index 7f86767..9da6cc6 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -198,9 +198,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ #define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */
/* diff --git a/include/configs/iocon.h b/include/configs/iocon.h index d34b91d..f36c2a3 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -238,9 +238,8 @@ int fpga_gpio_get(unsigned int bus, int pin); #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ #define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */
/* diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 5e075c8..ae6b6dc 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -84,7 +84,6 @@ #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* End of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index 964d0dc..90e2d7a 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -106,7 +106,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000 #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index f183279..4d11c7d 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -88,7 +88,6 @@
#define CONFIG_SYS_MONITOR_BASE (KZM_FLASH_BASE) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
#define CONFIG_SYS_TEXT_BASE 0x00000000 diff --git a/include/configs/lager.h b/include/configs/lager.h index 32a2655..b420e45 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -109,7 +109,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000 #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
#if defined(CONFIG_SYS_USE_BOOT_NORFLASH) diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 7c3f041..b44f38e 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -59,7 +59,6 @@
/* Memory sizes */ #define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Initial data */ #define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */ #define CONFIG_SYS_MEMTEST_END 0x40400000 /* 4 MB RAM test */
diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 18714ea..133dc6f 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -275,10 +275,8 @@ #define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE #endif
-/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 53128ec..a71709b 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -140,8 +140,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ diff --git a/include/configs/shmin.h b/include/configs/shmin.h index f8155ef..4d38f6c 100644 --- a/include/configs/shmin.h +++ b/include/configs/shmin.h @@ -62,7 +62,6 @@ #define CONFIG_SYS_MONITOR_BASE (SHMIN_FLASH_BASE_1 + CONFIG_ENV_SECT_SIZE) #define CONFIG_SYS_MONITOR_LEN (128 * 1024) #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 256 #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/snowball.h b/include/configs/snowball.h index 9a069f3..dacb560 100644 --- a/include/configs/snowball.h +++ b/include/configs/snowball.h @@ -41,8 +41,6 @@ #define CONFIG_ENV_SIZE (8*1024) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 256*1024)
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_CMD_ENV #define CONFIG_CMD_SAVEENV diff --git a/include/configs/u8500_href.h b/include/configs/u8500_href.h index 629299d..8d7970a 100644 --- a/include/configs/u8500_href.h +++ b/include/configs/u8500_href.h @@ -29,7 +29,6 @@ #define CONFIG_ENV_SIZE (128*1024) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 256*1024) #endif -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */
/* * PL011 Configuration diff --git a/include/configs/vl_ma2sc.h b/include/configs/vl_ma2sc.h index 88aaa95..2187f77 100644 --- a/include/configs/vl_ma2sc.h +++ b/include/configs/vl_ma2sc.h @@ -363,7 +363,6 @@ */ #define CONFIG_SYS_MALLOC_LEN \ ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#ifndef CONFIG_RAMLOAD #define CONFIG_BOOTCOMMAND "run nfsboot"
Masahiro Yamada
