[PATCH v2 0/4] fs/squashfs
Hello,
Following the SquashFS support, this series adds support for LZO and ZSTD algorithms.
Changes in v2: - Change tests architecture. - Add tests for LZO and ZSTD. - Skip compression algorithms unsupported by the host's squashfs-tools version. - Add sqfs_decompress_init() and sqfs_decompress_cleanup() to SquashFS support.
Joao Marcos Costa (4): fs/squashfs: add support for LZO decompression fs/squashfs: add support for ZSTD decompression fs/squashfs: Add init. and clean-up functions to decompression test/py: Add tests for LZO and ZSTD
fs/squashfs/sqfs.c | 15 ++- fs/squashfs/sqfs_decompressor.c | 108 +++++++++++++++++- fs/squashfs/sqfs_decompressor.h | 4 + fs/squashfs/sqfs_filesystem.h | 12 +- .../test_fs/test_squashfs/sqfs_common.py | 76 ++++++++---- .../test_fs/test_squashfs/test_sqfs_load.py | 40 ++++--- .../test_fs/test_squashfs/test_sqfs_ls.py | 33 ++++-- 7 files changed, 231 insertions(+), 57 deletions(-)
Add call to lzo's lzo1x_decompress_safe() and rename source length parameter from 'lenp' to 'src_len'.
U-Boot's LZO sources may still have some unsolved issues that could make the decompression crash when dealing with fragmented files, so those should be avoided. The "-no-fragments" option can be passed to mksquashfs.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v2: - Changed commit message. fs/squashfs/sqfs_decompressor.c | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index 09ca6cf6d0..9285df5d3b 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -9,6 +9,11 @@ #include <stdint.h> #include <stdio.h> #include <stdlib.h> + +#if IS_ENABLED(CONFIG_LZO) +#include <linux/lzo.h> +#endif + #if IS_ENABLED(CONFIG_ZLIB) #include <u-boot/zlib.h> #endif @@ -35,20 +40,32 @@ static void zlib_decompression_status(int ret) #endif
int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, - void *source, u32 lenp) + void *source, u32 src_len) { int ret = 0;
switch (comp_type) { #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: - ret = uncompress(dest, dest_len, source, lenp); + ret = uncompress(dest, dest_len, source, src_len); if (ret) { zlib_decompression_status(ret); return -EINVAL; }
break; +#endif +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: { + size_t lzo_dest_len = *dest_len; + ret = lzo1x_decompress_safe(source, src_len, dest, &lzo_dest_len); + if (ret) { + printf("LZO decompression failed. Error code: %d\n", ret); + return -EINVAL; + } + + break; + } #endif default: printf("Error: unknown compression type.\n");
Add call to ZSTD's ZSTD_decompressDCtx(). In this use case, the caller can upper bound the decompressed size, which will be the SquashFS data block (or metadata block) size, so there is no need to use streaming API.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v2: - No changes since the previous version. fs/squashfs/sqfs_decompressor.c | 39 +++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index 9285df5d3b..b5a9d92808 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -18,6 +18,10 @@ #include <u-boot/zlib.h> #endif
+#if IS_ENABLED(CONFIG_ZSTD) +#include <linux/zstd.h> +#endif + #include "sqfs_decompressor.h" #include "sqfs_filesystem.h" #include "sqfs_utils.h" @@ -39,6 +43,31 @@ static void zlib_decompression_status(int ret) } #endif
+#if IS_ENABLED(CONFIG_ZSTD) +static int sqfs_zstd_decompress(void *dest, unsigned long dest_len, + void *source, u32 src_len) +{ + void *workspace; + ZSTD_DCtx *ctx; + size_t wsize; + int ret; + + wsize = ZSTD_DCtxWorkspaceBound(); + + workspace = malloc(wsize); + if (!workspace) + return -ENOMEM; + + ctx = ZSTD_initDCtx(workspace, wsize); + + ret = ZSTD_decompressDCtx(ctx, dest, dest_len, source, src_len); + + free(workspace); + + return ZSTD_isError(ret); +} +#endif /* CONFIG_ZSTD */ + int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, void *source, u32 src_len) { @@ -67,6 +96,16 @@ int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, break; } #endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + ret = sqfs_zstd_decompress(dest, *dest_len, source, src_len); + if (ret) { + printf("ZSTD Error code: %d\n", ZSTD_getErrorCode(ret)); + return -EINVAL; + } + + break; +#endif /* CONFIG_ZSTD */ default: printf("Error: unknown compression type.\n"); return -EINVAL;
Add sqfs_decompressor_init() and sqfs_decompressor_cleanup(). These functions are called respectively in sqfs_probe() and sqfs_close(). For now, only ZSTD requires an initialization logic.
Move squashfs_ctxt definition to sqfs_filesystem.h. This structure is passed to sqfs_decompressor_init() and sqfs_decompressor_cleanup(), so it can no longer be local to sqfs.c.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v2: - This patch was not present in the previous version. fs/squashfs/sqfs.c | 15 ++++++---- fs/squashfs/sqfs_decompressor.c | 52 +++++++++++++++++++++++++++++++-- fs/squashfs/sqfs_decompressor.h | 4 +++ fs/squashfs/sqfs_filesystem.h | 12 +++++++- 4 files changed, 73 insertions(+), 10 deletions(-)
diff --git a/fs/squashfs/sqfs.c b/fs/squashfs/sqfs.c index 340e5ebdb9..598b42cd34 100644 --- a/fs/squashfs/sqfs.c +++ b/fs/squashfs/sqfs.c @@ -23,12 +23,6 @@ #include "sqfs_filesystem.h" #include "sqfs_utils.h"
-struct squashfs_ctxt { - struct disk_partition cur_part_info; - struct blk_desc *cur_dev; - struct squashfs_super_block *sblk; -}; - static struct squashfs_ctxt ctxt;
static int sqfs_disk_read(__u32 block, __u32 nr_blocks, void *buf) @@ -1023,6 +1017,14 @@ int sqfs_probe(struct blk_desc *fs_dev_desc, struct disk_partition *fs_partition
ctxt.sblk = sblk;
+ ret = sqfs_decompressor_init(&ctxt); + + if (ret) { + ctxt.cur_dev = NULL; + free(ctxt.sblk); + return -EINVAL; + } + return 0; }
@@ -1525,6 +1527,7 @@ void sqfs_close(void) { free(ctxt.sblk); ctxt.cur_dev = NULL; + sqfs_decompressor_cleanup(&ctxt); }
void sqfs_closedir(struct fs_dir_stream *dirs) diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index b5a9d92808..e536d85055 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -23,9 +23,57 @@ #endif
#include "sqfs_decompressor.h" -#include "sqfs_filesystem.h" #include "sqfs_utils.h"
+int sqfs_decompressor_init(struct squashfs_ctxt *ctxt) +{ + u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression); + + switch (comp_type) { +#if IS_ENABLED(CONFIG_ZLIB) + case SQFS_COMP_ZLIB: + break; +#endif +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: + break; +#endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + ctxt->zstd_workspace = malloc(ZSTD_DCtxWorkspaceBound()); + if (!ctxt->zstd_workspace) + return -ENOMEM; + break; +#endif + default: + printf("Error: unknown compression type.\n"); + return -EINVAL; + } + + return 0; +} + +void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt) +{ + u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression); + + switch (comp_type) { +#if IS_ENABLED(CONFIG_ZLIB) + case SQFS_COMP_ZLIB: + break; +#endif +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: + break; +#endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + free(ctxt->zstd_workspace); + break; +#endif + } +} + #if IS_ENABLED(CONFIG_ZLIB) static void zlib_decompression_status(int ret) { @@ -62,8 +110,6 @@ static int sqfs_zstd_decompress(void *dest, unsigned long dest_len,
- free(workspace); - return ZSTD_isError(ret); } #endif /* CONFIG_ZSTD */ diff --git a/fs/squashfs/sqfs_decompressor.h b/fs/squashfs/sqfs_decompressor.h index 378965dda8..c67a984425 100644 --- a/fs/squashfs/sqfs_decompressor.h +++ b/fs/squashfs/sqfs_decompressor.h @@ -9,6 +9,7 @@ #define SQFS_DECOMPRESSOR_H
#include <stdint.h> +#include "sqfs_filesystem.h"
#define SQFS_COMP_ZLIB 1 #define SQFS_COMP_LZMA 2 @@ -55,4 +56,7 @@ union squashfs_compression_opts { int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, void *source, u32 lenp);
+int sqfs_decompressor_init(struct squashfs_ctxt *ctxt); +void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt); + #endif /* SQFS_DECOMPRESSOR_H */ diff --git a/fs/squashfs/sqfs_filesystem.h b/fs/squashfs/sqfs_filesystem.h index d63e3a41ad..856cd15e34 100644 --- a/fs/squashfs/sqfs_filesystem.h +++ b/fs/squashfs/sqfs_filesystem.h @@ -9,8 +9,9 @@ #define SQFS_FILESYSTEM_H
#include <asm/unaligned.h> -#include <stdint.h> #include <fs.h> +#include <part.h> +#include <stdint.h>
#define SQFS_UNCOMPRESSED_DATA 0x0002 #define SQFS_MAGIC_NUMBER 0x73717368 @@ -72,6 +73,15 @@ struct squashfs_super_block { __le64 export_table_start; };
+struct squashfs_ctxt { + struct disk_partition cur_part_info; + struct blk_desc *cur_dev; + struct squashfs_super_block *sblk; +#if IS_ENABLED(CONFIG_ZSTD) + void *zstd_workspace; +#endif +}; + struct squashfs_directory_index { u32 index; u32 start;
Improve SquashFS tests architecture. Add 'Compression' class. LZO algorithm may crash if the file is fragmented, so the fragments are disabled when testing LZO.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v2: - This patch was not present in the previous version. .../test_fs/test_squashfs/sqfs_common.py | 76 ++++++++++++++----- .../test_fs/test_squashfs/test_sqfs_load.py | 40 ++++++---- .../test_fs/test_squashfs/test_sqfs_ls.py | 33 +++++--- 3 files changed, 102 insertions(+), 47 deletions(-)
diff --git a/test/py/tests/test_fs/test_squashfs/sqfs_common.py b/test/py/tests/test_fs/test_squashfs/sqfs_common.py index 2dc344d1b2..c96f92c1d8 100644 --- a/test/py/tests/test_fs/test_squashfs/sqfs_common.py +++ b/test/py/tests/test_fs/test_squashfs/sqfs_common.py @@ -5,6 +5,7 @@ import os import random import string +import subprocess
def sqfs_get_random_letters(size): letters = [] @@ -19,24 +20,57 @@ def sqfs_generate_file(path, size): file.write(content) file.close()
-# generate image with three files and a symbolic link -def sqfs_generate_image(cons): - src = os.path.join(cons.config.build_dir, "sqfs_src/") - dest = os.path.join(cons.config.build_dir, "sqfs") - os.mkdir(src) - sqfs_generate_file(src + "frag_only", 100) - sqfs_generate_file(src + "blks_frag", 5100) - sqfs_generate_file(src + "blks_only", 4096) - os.symlink("frag_only", src + "sym") - os.system("mksquashfs " + src + " " + dest + " -b 4096 -always-use-fragments") - -# removes all files created by sqfs_generate_image() -def sqfs_clean(cons): - src = os.path.join(cons.config.build_dir, "sqfs_src/") - dest = os.path.join(cons.config.build_dir, "sqfs") - os.remove(src + "frag_only") - os.remove(src + "blks_frag") - os.remove(src + "blks_only") - os.remove(src + "sym") - os.rmdir(src) - os.remove(dest) +class Compression: + def __init__(self, name, files, sizes, block_size = 4096): + self.name = name + self.files = files + self.sizes = sizes + self.mksquashfs_opts = " -b " + str(block_size) + " -comp " + self.name + + def add_opt(self, opt): + self.mksquashfs_opts += " " + opt + + def gen_image(self, build_dir): + src = os.path.join(build_dir, "sqfs_src/") + os.mkdir(src) + for (f, s) in zip(self.files, self.sizes): + sqfs_generate_file(src + f, s) + + # the symbolic link always targets the first file + os.symlink(self.files[0], src + "sym") + + sqfs_img = os.path.join(build_dir, "sqfs-" + self.name) + i_o = src + " " + sqfs_img + opts = self.mksquashfs_opts + try: + subprocess.run(["mksquashfs " + i_o + opts], shell = True, check = True) + except: + print("mksquashfs error. Compression type: " + self.name) + raise RuntimeError + + def clean_source(self, build_dir): + src = os.path.join(build_dir, "sqfs_src/") + for f in self.files: + os.remove(src + f) + os.remove(src + "sym") + os.rmdir(src) + + def cleanup(self, build_dir): + self.clean_source(build_dir) + sqfs_img = os.path.join(build_dir, "sqfs-" + self.name) + os.remove(sqfs_img) + +files = ["blks_only", "blks_frag", "frag_only"] +sizes = [4096, 5100, 100] +gzip = Compression("gzip", files, sizes) +zstd = Compression("zstd", files, sizes) +lzo = Compression("lzo", files, sizes) + +# use fragment blocks for files larger than block_size +gzip.add_opt("-always-use-fragments") +zstd.add_opt("-always-use-fragments") + +# avoid fragments if lzo is used +lzo.add_opt("-no-fragments") + +comp_opts = [gzip, zstd, lzo] diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py index eb1baae5c5..9e90062384 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py @@ -12,23 +12,35 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_load(u_boot_console): - cons = u_boot_console - sqfs_generate_image(cons) + build_dir = u_boot_console.config.build_dir command = "sqfsload host 0 $kernel_addr_r " - path = os.path.join(cons.config.build_dir, "sqfs")
- try: + for opt in comp_opts: + # generate and load the squashfs image + try: + opt.gen_image(build_dir) + except RuntimeError: + opt.clean_source(build_dir) + # skip unsupported compression types + continue + + path = os.path.join(build_dir, "sqfs-" + opt.name) output = u_boot_console.run_command("host bind 0 " + path) + output = u_boot_console.run_command(command + "xxx") assert "File not found." in output - output = u_boot_console.run_command(command + "frag_only") - assert "100 bytes read in" in output - output = u_boot_console.run_command(command + "blks_frag") - assert "5100 bytes read in" in output - output = u_boot_console.run_command(command + "blks_only") - assert "4096 bytes read in" in output + + for (f, s) in zip(opt.files, opt.sizes): + try: + output = u_boot_console.run_command(command + f) + assert str(s) in output + except: + assert False + opt.cleanup(build_dir) + + # test symbolic link output = u_boot_console.run_command(command + "sym") - assert "100 bytes read in" in output - except: - sqfs_clean(cons) - sqfs_clean(cons) + assert str(opt.sizes[0]) in output + + # remove generated files + opt.cleanup(build_dir) diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py index 3a7b75c778..a0dca2e2fc 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py @@ -12,16 +12,25 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_ls(u_boot_console): - cons = u_boot_console - sqfs_generate_image(cons) - path = os.path.join(cons.config.build_dir, "sqfs") - try: + build_dir = u_boot_console.config.build_dir + for opt in comp_opts: + try: + opt.gen_image(build_dir) + except RuntimeError: + opt.clean_source(build_dir) + # skip unsupported compression types + continue + path = os.path.join(build_dir, "sqfs-" + opt.name) output = u_boot_console.run_command("host bind 0 " + path) - output = u_boot_console.run_command("sqfsls host 0") - assert "4 file(s), 0 dir(s)" in output - assert "<SYM> sym" in output - output = u_boot_console.run_command("sqfsls host 0 xxx") - assert "** Cannot find directory. **" in output - except: - sqfs_clean(cons) - sqfs_clean(cons) + + try: + # list files in root directory + output = u_boot_console.run_command("sqfsls host 0") + assert str(len(opt.files) + 1) + " file(s), 0 dir(s)" in output + assert "<SYM> sym" in output + output = u_boot_console.run_command("sqfsls host 0 xxx") + assert "** Cannot find directory. **" in output + except: + opt.cleanup(build_dir) + assert False + opt.cleanup(build_dir)
Joao Marcos Costa
