[U-Boot] [PATCH 1/2] pci: mx6: Implement power callback
Implement a callback to toggle the slot power supply. The callback can be overriden in case some more complex power supply for the slot was implemented in hardware, yet for the usual case, one can define a GPIO which toggles the power to the slot.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Liu Ying Ying.Liu@freescale.com --- drivers/pci/pcie_imx.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index 34377e9..8951a93 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -451,6 +451,17 @@ static int imx6_pcie_init_phy(void) return 0; }
+__weak int imx6_pcie_toggle_power(void) +{ +#ifdef CONFIG_PCIE_IMX_POWER_GPIO + gpio_direction_output(CONFIG_PCIE_IMX_POWER_GPIO, 0); + mdelay(20); + gpio_set_value(CONFIG_PCIE_IMX_POWER_GPIO, 1); + mdelay(20); +#endif + return 0; +} + __weak int imx6_pcie_toggle_reset(void) { /* @@ -496,7 +507,7 @@ static int imx6_pcie_deassert_core_reset(void) { struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- /* FIXME: Power-up GPIO goes here. */ + imx6_pcie_toggle_power();
/* Enable PCIe */ clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN);
Add support for PCIe on MX6 SabreSDP board and enable the support in the config file.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Liu Ying Ying.Liu@freescale.com --- board/freescale/mx6sabresd/mx6sabresd.c | 11 +++++++++++ include/configs/mx6sabresd.h | 10 ++++++++++ 2 files changed, 21 insertions(+)
V2: Use the default slot-power callback. This is a nicer and more generic solution, which scales and produces less polution of the code.
NOTE: Please test with and without card, and schedule for v2014.07 . Please note I just managed to test this on MX6DL SabreSDP.
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 12d8c56..d7d932e 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -135,6 +135,16 @@ static void setup_spi(void) imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); }
+iomux_v3_cfg_t const pcie_pads[] = { + MX6_PAD_EIM_D19__GPIO3_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), /* POWER */ + MX6_PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), /* RESET */ +}; + +static void setup_pcie(void) +{ + imx_iomux_v3_setup_multiple_pads(pcie_pads, ARRAY_SIZE(pcie_pads)); +} + iomux_v3_cfg_t const di0_pads[] = { MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, /* DISP0_CLK */ MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02, /* DISP0_HSYNC */ @@ -454,6 +464,7 @@ int overwrite_console(void) int board_eth_init(bd_t *bis) { setup_iomux_enet(); + setup_pcie();
return cpu_eth_init(bis); } diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 4919f53..5d02d23 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -48,4 +48,14 @@ #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI
+#define CONFIG_CMD_PCI +#ifdef CONFIG_CMD_PCI +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCIE_IMX +#define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) +#define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) +#endif + #endif /* __MX6QSABRESD_CONFIG_H */
Best regards, Stefano Babic
Stefano Babic
