[U-Boot] [PATCH v4] usb: ehci-generic: Add vbus-supply regulator support
Add vbus-supply regulator support. On some board vbus is not controlled by the phy but by an external regulator.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v4: - Remove useless dev->name in dev_dgb()
Changes in v3: - Update test on device_get_supply_regulator() call - Replace pr_err() by dev_err() - Replace debug() by dev_dbg()
Changes in v2: - Add test on device_get_supply_regulator() call
drivers/usb/host/ehci-generic.c | 39 ++++++++++++++++++++++++++++++++++++++- 1 file changed, 38 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 5a56f66cfaa6..0db0ab28d16d 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -11,6 +11,7 @@ #include <asm/io.h> #include <dm.h> #include "ehci.h" +#include <power/regulator.h>
/* * Even though here we don't explicitly use "struct ehci_ctrl" @@ -22,6 +23,9 @@ struct generic_ehci { struct clk *clocks; struct reset_ctl *resets; struct phy phy; +#ifdef CONFIG_DM_REGULATOR + struct udevice *vbus_supply; +#endif int clock_count; int reset_count; }; @@ -145,9 +149,26 @@ static int ehci_usb_probe(struct udevice *dev) } }
+#ifdef CONFIG_DM_REGULATOR + err = device_get_supply_regulator(dev, "vbus-supply", + &priv->vbus_supply); + if (err && err != -ENOENT) + goto reset_err; + + if (priv->vbus_supply) { + err = regulator_set_enable(priv->vbus_supply, true); + if (err) { + dev_err(dev, "Error enabling VBUS supply\n"); + goto reset_err; + } + } else { + dev_dbg(dev, "No vbus supply\n"); + } +#endif + err = ehci_setup_phy(dev, 0); if (err) - goto reset_err; + goto regulator_err;
hccr = map_physmem(dev_read_addr(dev), 0x100, MAP_NOCACHE); hcor = (struct ehci_hcor *)((uintptr_t)hccr + @@ -164,6 +185,15 @@ phy_err: if (ret) dev_err(dev, "failed to shutdown usb phy\n");
+regulator_err: +#ifdef CONFIG_DM_REGULATOR + if (priv->vbus_supply) { + ret = regulator_set_enable(priv->vbus_supply, false); + if (ret) + dev_err(dev, "Error disabling VBUS supply\n"); + } +#endif + reset_err: ret = reset_release_all(priv->resets, priv->reset_count); if (ret) @@ -189,6 +219,13 @@ static int ehci_usb_remove(struct udevice *dev) if (ret) return ret;
+#ifdef CONFIG_DM_REGULATOR + if (priv->vbus_supply) { + ret = regulator_set_enable(priv->vbus_supply, false); + if (ret) + return ret; + } +#endif ret = reset_release_all(priv->resets, priv->reset_count); if (ret) return ret;
Two remaining nits, can you pull the regulator handling into separate functions and put ifdef arounds those, with empty default implementation? That way, the ifdefs won't be spread throughout the code.
Also, rebase on u-boot-usb/master please.
Hi Marek
Agree it will be more readable.
Ok
Thanks
Patrice
On 09/04/2018 09:33 AM, Patrice CHOTARD wrote:
Hi Marek
Ok
Thanks
But the rest is good, thanks.
Patrice CHOTARD
Patrice Chotard
