[U-Boot-Users] Where do you find *.dtb files?
Hi all,
I'm trying to boot linux-2.6.21-rc5 on my mpc832xemds board which is running u-boot 1.2.0.
According to u-boot I need a device tree blob:
=> help bootm bootm [addr [arg ...]] - boot application image stored in memory passing arguments 'arg ...'; when booting a Linux kernel, 'arg' can be the address of an initrd image When booting a Linux kernel which requires a flat device-tree a third argument is required which is the address of the of the device-tree blob. To boot that kernel without an initrd image, use a '-' for the second argument. If you do not pass a third a bd_info struct will be passed instead
Can anybody tell me where I can find one for this board?
TIA,
Alex
Alex Zeffertt wrote:
Hi all,
TIA,
Alex
Kernel tree under arch/powerpc/boot/dts? http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=tree;f=arch/powerpc/boot/dts;h=2591d25045401b8beea474a1b4e117527e478521;hb=HEAD
Best regards, gvb
On Thu, 2007-05-03 at 05:31, Alex Zeffertt wrote:
Hi all,
In short, you make the ".dtb" file from a .dts file. The DTS files are likely found in the Linux kernel sources in the directory arch/powerpc/boot/dts/ or else you make one up specifically for your (custom) board.
You use the Device Tree Compiler, which is found on www.jdl.com/git_repos
The command invocation you want will be something like:
.dtc -b 0 -f -I dts -O dtb mpcXXXX.dts > mpcXXXX.dtb
And you may want to add something like "-S 0x3000" too.
HTH, jdl
Alex Zeffertt
Jerry Van Baren
Jon Loeliger
