[U-Boot] [PULL] efi patch queue 2017-12-17
Hi Tom,
This is my current patch queue for efi. Please pull.
Alex
The following changes since commit 15616a0aa58173bce1efe47569bf2e10d023ae9c:
Merge git://git.denx.de/u-boot-dm (2017-12-14 15:46:07 -0500)
git://github.com/agraf/u-boot.git tags/signed-efi-v2018.01
for you to fetch changes up to bde6bfe4c3234480a0eef3b5bda8cf5fc83d3c79:
efi_loader: comments for dp_part_fill() (2017-12-16 23:07:56 +0100)
---------------------------------------------------------------- Patch queue for efi - 2017-12-17
A few fixes for 2018.01:
- Compile fix with helloworld example - DP match fix (fixes FreeBSD loader and grub on block storage) - More DP fixes for SD, block - Fix use-after-free
---------------------------------------------------------------- Alexander Graf (3): efi_loader: helloworld.c: Explicitly use .rodata for loaded_image_guid efi_loader: helloworld.c: Reduce file size efi_loader: Ensure efi_dp_find_obj() finds exact matches
Heinrich Schuchardt (7): efi_loader: return status from efi_setup_loaded_image() efi_loader: new function efi_delete_handle() efi_loader: error handling in efi_load_image() efi_loader: correctly determine if an MMC device is an SD-card efi_loader: correctly setup device paths for block devices efi_loader: correct DeviceNodeToText for media types efi_loader: comments for dp_part_fill()
arch/arm/lib/elf_arm_efi.lds | 11 +- include/efi_loader.h | 10 +- lib/efi_loader/efi_boottime.c | 228 +++++++++++++++++-------------- lib/efi_loader/efi_device_path.c | 56 ++++++-- lib/efi_loader/efi_device_path_to_text.c | 43 ++++-- lib/efi_loader/helloworld.c | 3 +- 6 files changed, 214 insertions(+), 137 deletions(-)
On Sun, Dec 17, 2017 at 09:33:44PM +0100, Alexander Graf wrote:
Hi Tom,
Alex
This was for the OpenBSD bootloader, FreeBSD has a different one. I'd test again but am away from hardware for a few days.
arch/arm/lib/elf_arm_efi.lds | 11 +- include/efi_loader.h | 10 +- lib/efi_loader/efi_boottime.c | 228 +++++++++++++++++-------------- lib/efi_loader/efi_device_path.c | 56 ++++++-- lib/efi_loader/efi_device_path_to_text.c | 43 ++++-- lib/efi_loader/helloworld.c | 3 +- 6 files changed, 214 insertions(+), 137 deletions(-) _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Tom,
Alex
This was for every bootloaders, it just fixes FreeBSD's, OpenBSD's and Grub :)
Hi Tom,
Alex
Alexander Graf
Emmanuel Vadot
Jonathan Gray
