[PATCH] efi_loader: Remove incorrect calls of EFI_CALL in TCG2
There is two unneeded EFI_CALL references in tcg2_measure_pe_image(). The first one in efi_search_protocol() and the second on in the device path calculation. The second isn't even a function we should be calling, but a pointer assignment, which happens to work with the existing macro.
While at it switch the malloc call to a calloc, remove the unnecessary cast and get rid of an unneeded if statement before copying the device path
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_tcg2.c | 15 ++++++--------- 1 file changed, 6 insertions(+), 9 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 1319a8b37868..d026af2b2350 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -839,20 +839,19 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, if (ret != EFI_SUCCESS) return ret;
- ret = EFI_CALL(efi_search_protocol(&handle->header, - &efi_guid_loaded_image_device_path, - &handler)); + ret = efi_search_protocol(&handle->header, + &efi_guid_loaded_image_device_path, &handler); if (ret != EFI_SUCCESS) return ret;
- device_path = EFI_CALL(handler->protocol_interface); + device_path = handler->protocol_interface; device_path_length = efi_dp_size(device_path); if (device_path_length > 0) { /* add end node size */ device_path_length += sizeof(struct efi_device_path); } event_size = sizeof(struct uefi_image_load_event) + device_path_length; - image_load_event = (struct uefi_image_load_event *)malloc(event_size); + image_load_event = calloc(1, event_size); if (!image_load_event) return EFI_OUT_OF_RESOURCES;
@@ -875,10 +874,8 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, goto out; }
- if (device_path_length > 0) { - memcpy(image_load_event->device_path, device_path, - device_path_length); - } + /* device_path_length might be zero */ + memcpy(image_load_event->device_path, device_path, device_path_length);
ret = tcg2_agile_log_append(pcr_index, event_type, &digest_list, event_size, (u8 *)image_load_event);
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
&handler));
- ret = efi_search_protocol(&handle->header,
if (ret != EFI_SUCCESS) return ret;&efi_guid_loaded_image_device_path, &handler);
- device_path = handler->protocol_interface; device_path_length = efi_dp_size(device_path); if (device_path_length > 0) { /* add end node size */ device_path_length += sizeof(struct efi_device_path); } event_size = sizeof(struct uefi_image_load_event) + device_path_length;
- image_load_event = calloc(1, event_size); if (!image_load_event) return EFI_OUT_OF_RESOURCES;
Heinrich,
It is a quite common mistake. For most people, it is not very trivial when we should use EFI_CALL and when should not. Do you think that we should leave a note somewhere?
It would be much better if we can check any occurrence of mismatch, say using EFI_CALL for a non-EFIAPI function, at compile time.
-Takahiro Akashi
&handler));
-- 2.33.0
AKASHI Takahiro
Ilias Apalodimas
