[U-Boot] [PATCH] TI: DaVinci: Updating EMAC driver for DM365 and DM646x
The EMAC IP on DM365 and DM646x is slightly different from that on DM644x. This patch updates the DaVinci EMAC driver so that EMAC becomes operational on DM365 in U-Boot. A flag 'CONFIG_DAVINCI_EMAC_VERSION2' is used in the driver. This flag will need to be defined in the DM365 config file.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- The same modifications work on DM646x in a slightly older version of U-Boot. So when enabled this should work on the DM6467 EVM as well. This has at this point of time not been tested on the DM6467 in the latest version of U-Boot. drivers/net/davinci_emac.c | 79 ++++++++++++++++++++++++++++++++++++++++++- 1 files changed, 77 insertions(+), 2 deletions(-)
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index fa8cee4..0d61c91 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -107,6 +107,33 @@ static void davinci_eth_mdio_enable(void) while (adap_mdio->CONTROL & MDIO_CONTROL_IDLE) {;} }
+/* Read a PHY register via MDIO inteface */ +static int mdio_read(int phy_addr, int reg_num) +{ + adap_mdio->USERACCESS0 = MDIO_USERACCESS0_GO | + MDIO_USERACCESS0_WRITE_READ | + ((reg_num & 0x1F) << 21) | + ((phy_addr & 0x1F) << 16); + + /* Wait for command to complete */ + while ((adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) != 0); + + return adap_mdio->USERACCESS0 & 0xFFFF; +} + +/* Write to a PHY register via MDIO inteface */ +void mdio_write(int phy_addr, int reg_num, unsigned int data) +{ + /* Wait for User access register to be ready */ + while ((adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) != 0); + + adap_mdio->USERACCESS0 = MDIO_USERACCESS0_GO | + MDIO_USERACCESS0_WRITE_WRITE | + ((reg_num & 0x1F) << 21) | + ((phy_addr & 0x1F) << 16) | + (data & 0xFFFF); +} + /* * Tries to find an active connected PHY. Returns 1 if address if found. * If no active PHY (or more than one PHY) found returns 0. @@ -248,6 +275,31 @@ static int davinci_mii_phy_write(char *devname, unsigned char addr, unsigned cha
#endif
+static void emac_gigabit_enable(void) +{ + int temp; + + temp = mdio_read(EMAC_MDIO_PHY_NUM, 0); + + if (temp & (1 << 6)) { + /* + * Check if link detected is giga-bit + * If Gigabit mode detected, enable gigbit in MAC and PHY + */ + adap_emac->MACCONTROL |= EMAC_MACCONTROL_GIGFORCE | + EMAC_MACCONTROL_GIGABIT_ENABLE; + + /* + * The SYS_CLK which feeds the SOC for giga-bit operation + * does not seem to be enabled after reset as expected. + * Force enabling SYS_CLK by writing to the PHY + */ + temp = mdio_read(EMAC_MDIO_PHY_NUM, 22); + temp |= (1 << 4); + mdio_write(EMAC_MDIO_PHY_NUM, 22, temp); + } +} +
/* Eth device open */ static int davinci_eth_open(struct eth_device *dev, bd_t *bis) @@ -261,10 +313,15 @@ static int davinci_eth_open(struct eth_device *dev, bd_t *bis) /* Reset EMAC module and disable interrupts in wrapper */ adap_emac->SOFTRESET = 1; while (adap_emac->SOFTRESET != 0) {;} +#if defined(CONFIG_DAVINCI_EMAC_VERSION2) + adap_ewrap->SOFTRST = 1; + while (adap_ewrap->SOFTRST != 0); +#else adap_ewrap->EWCTL = 0; for (cnt = 0; cnt < 5; cnt++) { clkdiv = adap_ewrap->EWCTL; } +#endif
rx_desc = emac_rx_desc;
@@ -282,6 +339,10 @@ static int davinci_eth_open(struct eth_device *dev, bd_t *bis) adap_emac->MACADDRLO = (davinci_eth_mac_addr[5] << 8) | (davinci_eth_mac_addr[4]); +#if defined(CONFIG_DAVINCI_EMAC_VERSION2) + /* Set the Match and Valid Bits */ + adap_emac->MACADDRLO |= (1 << 19) | (1 << 20); +#endif
adap_emac->MACHASH1 = 0; adap_emac->MACHASH2 = 0; @@ -347,8 +408,15 @@ static int davinci_eth_open(struct eth_device *dev, bd_t *bis) clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; adap_mdio->CONTROL = ((clkdiv & 0xff) | MDIO_CONTROL_ENABLE | MDIO_CONTROL_FAULT);
+#if defined(CONFIG_DAVINCI_EMAC_VERSION2) + /* We need to wait for MDIO to start */ + udelay(1000); +#endif + if (!phy.get_link_speed(active_phy_addr)) return(0); + else + emac_gigabit_enable();
/* Start receive process */ adap_emac->RX0HDP = (u_int32_t)emac_rx_desc; @@ -411,7 +479,11 @@ static void davinci_eth_close(struct eth_device *dev)
/* Reset EMAC module and disable interrupts in wrapper */ adap_emac->SOFTRESET = 1; +#if defined(CONFIG_DAVINCI_EMAC_VERSION2) + adap_ewrap->SOFTRST = 1; +#else adap_ewrap->EWCTL = 0; +#endif
debug_emac("- emac_close\n"); } @@ -433,7 +505,8 @@ static int davinci_eth_send_packet (struct eth_device *dev, if (!phy.get_link_speed (active_phy_addr)) { printf ("WARN: emac_send_packet: No link\n"); return (ret_status); - } + } else + emac_gigabit_enable();
/* Check packet size and if < EMAC_MIN_ETHERNET_PKT_SIZE, pad it up */ if (length < EMAC_MIN_ETHERNET_PKT_SIZE) { @@ -456,7 +529,9 @@ static int davinci_eth_send_packet (struct eth_device *dev, if (!phy.get_link_speed (active_phy_addr)) { davinci_eth_ch_teardown (EMAC_CH_TX); return (ret_status); - } + } else + emac_gigabit_enable(); + if (adap_emac->TXINTSTATRAW & 0x01) { ret_status = length; break;
checkpatch complains here. infinite loop statement should be on the next line.
ERROR: trailing statements should be on next line #44: FILE: drivers/net/davinci_emac.c:119: + while ((adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) != 0);
- adap_mdio->USERACCESS0 = MDIO_USERACCESS0_GO |
- /* Wait for command to complete */
- while ((adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) != 0);
- return adap_mdio->USERACCESS0 & 0xFFFF;
- /* Wait for User access register to be ready */
ERROR: trailing statements should be on next line #53: FILE: drivers/net/davinci_emac.c:128: + while ((adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) != 0);
(data & 0xFFFF);
- Tries to find an active connected PHY. Returns 1 if address if found.
- If no active PHY (or more than one PHY) found returns 0.
#endif
- int temp;
- temp = mdio_read(EMAC_MDIO_PHY_NUM, 0);
- if (temp & (1 << 6)) {
Is there a logical #define bitfield that could be used here ?
temp |= (1 << 4);
ERROR: trailing statements should be on next line #103: FILE: drivers/net/davinci_emac.c:318: + while (adap_ewrap->SOFTRST != 0);
- adap_ewrap->SOFTRST = 1;
- while (adap_ewrap->SOFTRST != 0);
You may want to handle this like
#if defined(CONFIG_DAVINIC_EMAC_VERSION) && CONFIG_DAVINCI_EMAC_VERSION >= 2
- /* Set the Match and Valid Bits */
- adap_emac->MACADDRLO |= (1 << 19) | (1 << 20);
Are there some logical #define bitfields that could be used here ?
- /* We need to wait for MDIO to start */
- udelay(1000);
else
- } else
This is a dangling 'else' This is not explicitly mentioned in the coding style. My opinion is to surround with {}
} else
Another dangling else
Tom
s-paulraj@ti.com
Tom
