[U-Boot] [PATCH 0/3] test: Port FIT test to a pytest
We have a few tests still not part of the pytest framework. This means that they do not run automatically with 'make tests'.
This series converts the FIT test to the new framework.
Simon Glass (3): test: Indent test-fit.py to match the next patch test: Convert the FIT test to test/py test: Move the FIT test into the correct place
test/image/test-fit.py | 481 ---------------------------------------------- test/py/tests/test_fit.py | 428 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 428 insertions(+), 481 deletions(-) delete mode 100755 test/image/test-fit.py create mode 100755 test/py/tests/test_fit.py
We plan to rewrite this script to use the pytest framework. To make it easier to review the changes, indent the code to match the next patch. This gets all of the whitespace changes out of the way.
test/image/test-fit.py | 606 ++++++++++++++++++++++++------------------------- 1 file changed, 303 insertions(+), 303 deletions(-)
diff --git a/test/image/test-fit.py b/test/image/test-fit.py index ca38f71a15..c83719bb2d 100755 --- a/test/image/test-fit.py +++ b/test/image/test-fit.py @@ -134,310 +134,310 @@ sb save hostfs 0 %(loadables2_addr)x %(loadables2_out)s %(loadables2_size)x reset '''
-def debug_stdout(stdout): - if DEBUG: + def debug_stdout(stdout): + if DEBUG: + print stdout + + def make_fname(leaf): + """Make a temporary filename + + Args: + leaf: Leaf name of file to create (within temporary directory) + Return: + Temporary filename + """ + global base_dir + + return os.path.join(base_dir, leaf) + + def filesize(fname): + """Get the size of a file + + Args: + fname: Filename to check + Return: + Size of file in bytes + """ + return os.stat(fname).st_size + + def read_file(fname): + """Read the contents of a file + + Args: + fname: Filename to read + Returns: + Contents of file as a string + """ + with open(fname, 'r') as fd: + return fd.read() + + def make_dtb(): + """Make a sample .dts file and compile it to a .dtb + + Returns: + Filename of .dtb file created + """ + src = make_fname('u-boot.dts') + dtb = make_fname('u-boot.dtb') + with open(src, 'w') as fd: + print >>fd, base_fdt + command.Output('dtc', src, '-O', 'dtb', '-o', dtb) + return dtb + + def make_its(params): + """Make a sample .its file with parameters embedded + + Args: + params: Dictionary containing parameters to embed in the %() strings + Returns: + Filename of .its file created + """ + its = make_fname('test.its') + with open(its, 'w') as fd: + print >>fd, base_its % params + return its + + def make_fit(mkimage, params): + """Make a sample .fit file ready for loading + + This creates a .its script with the selected parameters and uses mkimage to + turn this into a .fit image. + + Args: + mkimage: Filename of 'mkimage' utility + params: Dictionary containing parameters to embed in the %() strings + Return: + Filename of .fit file created + """ + fit = make_fname('test.fit') + its = make_its(params) + command.Output(mkimage, '-f', its, fit) + with open(make_fname('u-boot.dts'), 'w') as fd: + print >>fd, base_fdt + return fit + + def make_kernel(filename, text): + """Make a sample kernel with test data + + Args: + filename: the name of the file you want to create + Returns: + Full path and filename of the kernel it created + """ + fname = make_fname(filename) + data = '' + for i in range(100): + data += 'this %s %d is unlikely to boot\n' % (text, i) + with open(fname, 'w') as fd: + print >>fd, data + return fname + + def make_ramdisk(filename, text): + """Make a sample ramdisk with test data + + Returns: + Filename of ramdisk created + """ + fname = make_fname(filename) + data = '' + for i in range(100): + data += '%s %d was seldom used in the middle ages\n' % (text, i) + with open(fname, 'w') as fd: + print >>fd, data + return fname + + def find_matching(text, match): + """Find a match in a line of text, and return the unmatched line portion + + This is used to extract a part of a line from some text. The match string + is used to locate the line - we use the first line that contains that + match text. + + Once we find a match, we discard the match string itself from the line, + and return what remains. + + TODO: If this function becomes more generally useful, we could change it + to use regex and return groups. + + Args: + text: Text to check (each line separated by \n) + match: String to search for + Return: + String containing unmatched portion of line + Exceptions: + ValueError: If match is not found + + >>> find_matching('first line:10\nsecond_line:20', 'first line:') + '10' + >>> find_matching('first line:10\nsecond_line:20', 'second line') + Traceback (most recent call last): + ... + ValueError: Test aborted + >>> find_matching('first line:10\nsecond_line:20', 'second_line:') + '20' + """ + for line in text.splitlines(): + pos = line.find(match) + if pos != -1: + return line[:pos] + line[pos + len(match):] + + print "Expected '%s' but not found in output:" + print text + raise ValueError('Test aborted') + + def set_test(name): + """Set the name of the current test and print a message + + Args: + name: Name of test + """ + global test_name + + test_name = name + print name + + def fail(msg, stdout): + """Raise an error with a helpful failure message + + Args: + msg: Message to display + """ print stdout - -def make_fname(leaf): - """Make a temporary filename - - Args: - leaf: Leaf name of file to create (within temporary directory) - Return: - Temporary filename - """ - global base_dir - - return os.path.join(base_dir, leaf) - -def filesize(fname): - """Get the size of a file - - Args: - fname: Filename to check - Return: - Size of file in bytes - """ - return os.stat(fname).st_size - -def read_file(fname): - """Read the contents of a file - - Args: - fname: Filename to read - Returns: - Contents of file as a string - """ - with open(fname, 'r') as fd: - return fd.read() - -def make_dtb(): - """Make a sample .dts file and compile it to a .dtb - - Returns: - Filename of .dtb file created - """ - src = make_fname('u-boot.dts') - dtb = make_fname('u-boot.dtb') - with open(src, 'w') as fd: - print >>fd, base_fdt - command.Output('dtc', src, '-O', 'dtb', '-o', dtb) - return dtb - -def make_its(params): - """Make a sample .its file with parameters embedded - - Args: - params: Dictionary containing parameters to embed in the %() strings - Returns: - Filename of .its file created - """ - its = make_fname('test.its') - with open(its, 'w') as fd: - print >>fd, base_its % params - return its - -def make_fit(mkimage, params): - """Make a sample .fit file ready for loading - - This creates a .its script with the selected parameters and uses mkimage to - turn this into a .fit image. - - Args: - mkimage: Filename of 'mkimage' utility - params: Dictionary containing parameters to embed in the %() strings - Return: - Filename of .fit file created - """ - fit = make_fname('test.fit') - its = make_its(params) - command.Output(mkimage, '-f', its, fit) - with open(make_fname('u-boot.dts'), 'w') as fd: - print >>fd, base_fdt - return fit - -def make_kernel(filename, text): - """Make a sample kernel with test data - - Args: - filename: the name of the file you want to create - Returns: - Full path and filename of the kernel it created - """ - fname = make_fname(filename) - data = '' - for i in range(100): - data += 'this %s %d is unlikely to boot\n' % (text, i) - with open(fname, 'w') as fd: - print >>fd, data - return fname - -def make_ramdisk(filename, text): - """Make a sample ramdisk with test data - - Returns: - Filename of ramdisk created - """ - fname = make_fname(filename) - data = '' - for i in range(100): - data += '%s %d was seldom used in the middle ages\n' % (text, i) - with open(fname, 'w') as fd: - print >>fd, data - return fname - -def find_matching(text, match): - """Find a match in a line of text, and return the unmatched line portion - - This is used to extract a part of a line from some text. The match string - is used to locate the line - we use the first line that contains that - match text. - - Once we find a match, we discard the match string itself from the line, - and return what remains. - - TODO: If this function becomes more generally useful, we could change it - to use regex and return groups. - - Args: - text: Text to check (each line separated by \n) - match: String to search for - Return: - String containing unmatched portion of line - Exceptions: - ValueError: If match is not found - - >>> find_matching('first line:10\nsecond_line:20', 'first line:') - '10' - >>> find_matching('first line:10\nsecond_line:20', 'second line') - Traceback (most recent call last): - ... - ValueError: Test aborted - >>> find_matching('first line:10\nsecond_line:20', 'second_line:') - '20' - """ - for line in text.splitlines(): - pos = line.find(match) - if pos != -1: - return line[:pos] + line[pos + len(match):] - - print "Expected '%s' but not found in output:" - print text - raise ValueError('Test aborted') - -def set_test(name): - """Set the name of the current test and print a message - - Args: - name: Name of test - """ - global test_name - - test_name = name - print name - -def fail(msg, stdout): - """Raise an error with a helpful failure message - - Args: - msg: Message to display - """ - print stdout - raise ValueError("Test '%s' failed: %s" % (test_name, msg)) - -def run_fit_test(mkimage, u_boot): - """Basic sanity check of FIT loading in U-Boot - - TODO: Almost everything: - - hash algorithms - invalid hash/contents should be detected - - signature algorithms - invalid sig/contents should be detected - - compression - - checking that errors are detected like: - - image overwriting - - missing images - - invalid configurations - - incorrect os/arch/type fields - - empty data - - images too large/small - - invalid FDT (e.g. putting a random binary in instead) - - default configuration selection - - bootm command line parameters should have desired effect - - run code coverage to make sure we are testing all the code - """ - global test_name - - # Set up invariant files - control_dtb = make_dtb() - kernel = make_kernel('test-kernel.bin', 'kernel') - ramdisk = make_ramdisk('test-ramdisk.bin', 'ramdisk') - loadables1 = make_kernel('test-loadables1.bin', 'lenrek') - loadables2 = make_ramdisk('test-loadables2.bin', 'ksidmar') - kernel_out = make_fname('kernel-out.bin') - fdt_out = make_fname('fdt-out.dtb') - ramdisk_out = make_fname('ramdisk-out.bin') - loadables1_out = make_fname('loadables1-out.bin') - loadables2_out = make_fname('loadables2-out.bin') - - # Set up basic parameters with default values - params = { - 'fit_addr' : 0x1000, - - 'kernel' : kernel, - 'kernel_out' : kernel_out, - 'kernel_addr' : 0x40000, - 'kernel_size' : filesize(kernel), - - 'fdt_out' : fdt_out, - 'fdt_addr' : 0x80000, - 'fdt_size' : filesize(control_dtb), - 'fdt_load' : '', - - 'ramdisk' : ramdisk, - 'ramdisk_out' : ramdisk_out, - 'ramdisk_addr' : 0xc0000, - 'ramdisk_size' : filesize(ramdisk), - 'ramdisk_load' : '', - 'ramdisk_config' : '', - - 'loadables1' : loadables1, - 'loadables1_out' : loadables1_out, - 'loadables1_addr' : 0x100000, - 'loadables1_size' : filesize(loadables1), - 'loadables1_load' : '', - - 'loadables2' : loadables2, - 'loadables2_out' : loadables2_out, - 'loadables2_addr' : 0x140000, - 'loadables2_size' : filesize(loadables2), - 'loadables2_load' : '', - - 'loadables_config' : '', - } - - # Make a basic FIT and a script to load it - fit = make_fit(mkimage, params) - params['fit'] = fit - cmd = base_script % params - - # First check that we can load a kernel - # We could perhaps reduce duplication with some loss of readability - set_test('Kernel load') - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(kernel) != read_file(kernel_out): - fail('Kernel not loaded', stdout) - if read_file(control_dtb) == read_file(fdt_out): - fail('FDT loaded but should be ignored', stdout) - if read_file(ramdisk) == read_file(ramdisk_out): - fail('Ramdisk loaded but should not be', stdout) - - # Find out the offset in the FIT where U-Boot has found the FDT - line = find_matching(stdout, 'Booting using the fdt blob at ') - fit_offset = int(line, 16) - params['fit_addr'] - fdt_magic = struct.pack('>L', 0xd00dfeed) - data = read_file(fit) - - # Now find where it actually is in the FIT (skip the first word) - real_fit_offset = data.find(fdt_magic, 4) - if fit_offset != real_fit_offset: - fail('U-Boot loaded FDT from offset %#x, FDT is actually at %#x' % - (fit_offset, real_fit_offset), stdout) - - # Now a kernel and an FDT - set_test('Kernel + FDT load') - params['fdt_load'] = 'load = <%#x>;' % params['fdt_addr'] - fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(kernel) != read_file(kernel_out): - fail('Kernel not loaded', stdout) - if read_file(control_dtb) != read_file(fdt_out): - fail('FDT not loaded', stdout) - if read_file(ramdisk) == read_file(ramdisk_out): - fail('Ramdisk loaded but should not be', stdout) - - # Try a ramdisk - set_test('Kernel + FDT + Ramdisk load') - params['ramdisk_config'] = 'ramdisk = "ramdisk@1";' - params['ramdisk_load'] = 'load = <%#x>;' % params['ramdisk_addr'] - fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(ramdisk) != read_file(ramdisk_out): - fail('Ramdisk not loaded', stdout) - - # Configuration with some Loadables - set_test('Kernel + FDT + Ramdisk load + Loadables') - params['loadables_config'] = 'loadables = "kernel@2", "ramdisk@2";' - params['loadables1_load'] = 'load = <%#x>;' % params['loadables1_addr'] - params['loadables2_load'] = 'load = <%#x>;' % params['loadables2_addr'] - fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(loadables1) != read_file(loadables1_out): - fail('Loadables1 (kernel) not loaded', stdout) - if read_file(loadables2) != read_file(loadables2_out): - fail('Loadables2 (ramdisk) not loaded', stdout) + raise ValueError("Test '%s' failed: %s" % (test_name, msg)) + + def run_fit_test(mkimage, u_boot): + """Basic sanity check of FIT loading in U-Boot + + TODO: Almost everything: + - hash algorithms - invalid hash/contents should be detected + - signature algorithms - invalid sig/contents should be detected + - compression + - checking that errors are detected like: + - image overwriting + - missing images + - invalid configurations + - incorrect os/arch/type fields + - empty data + - images too large/small + - invalid FDT (e.g. putting a random binary in instead) + - default configuration selection + - bootm command line parameters should have desired effect + - run code coverage to make sure we are testing all the code + """ + global test_name + + # Set up invariant files + control_dtb = make_dtb() + kernel = make_kernel('test-kernel.bin', 'kernel') + ramdisk = make_ramdisk('test-ramdisk.bin', 'ramdisk') + loadables1 = make_kernel('test-loadables1.bin', 'lenrek') + loadables2 = make_ramdisk('test-loadables2.bin', 'ksidmar') + kernel_out = make_fname('kernel-out.bin') + fdt_out = make_fname('fdt-out.dtb') + ramdisk_out = make_fname('ramdisk-out.bin') + loadables1_out = make_fname('loadables1-out.bin') + loadables2_out = make_fname('loadables2-out.bin') + + # Set up basic parameters with default values + params = { + 'fit_addr' : 0x1000, + + 'kernel' : kernel, + 'kernel_out' : kernel_out, + 'kernel_addr' : 0x40000, + 'kernel_size' : filesize(kernel), + + 'fdt_out' : fdt_out, + 'fdt_addr' : 0x80000, + 'fdt_size' : filesize(control_dtb), + 'fdt_load' : '', + + 'ramdisk' : ramdisk, + 'ramdisk_out' : ramdisk_out, + 'ramdisk_addr' : 0xc0000, + 'ramdisk_size' : filesize(ramdisk), + 'ramdisk_load' : '', + 'ramdisk_config' : '', + + 'loadables1' : loadables1, + 'loadables1_out' : loadables1_out, + 'loadables1_addr' : 0x100000, + 'loadables1_size' : filesize(loadables1), + 'loadables1_load' : '', + + 'loadables2' : loadables2, + 'loadables2_out' : loadables2_out, + 'loadables2_addr' : 0x140000, + 'loadables2_size' : filesize(loadables2), + 'loadables2_load' : '', + + 'loadables_config' : '', + } + + # Make a basic FIT and a script to load it + fit = make_fit(mkimage, params) + params['fit'] = fit + cmd = base_script % params + + # First check that we can load a kernel + # We could perhaps reduce duplication with some loss of readability + set_test('Kernel load') + stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) + debug_stdout(stdout) + if read_file(kernel) != read_file(kernel_out): + fail('Kernel not loaded', stdout) + if read_file(control_dtb) == read_file(fdt_out): + fail('FDT loaded but should be ignored', stdout) + if read_file(ramdisk) == read_file(ramdisk_out): + fail('Ramdisk loaded but should not be', stdout) + + # Find out the offset in the FIT where U-Boot has found the FDT + line = find_matching(stdout, 'Booting using the fdt blob at ') + fit_offset = int(line, 16) - params['fit_addr'] + fdt_magic = struct.pack('>L', 0xd00dfeed) + data = read_file(fit) + + # Now find where it actually is in the FIT (skip the first word) + real_fit_offset = data.find(fdt_magic, 4) + if fit_offset != real_fit_offset: + fail('U-Boot loaded FDT from offset %#x, FDT is actually at %#x' % + (fit_offset, real_fit_offset), stdout) + + # Now a kernel and an FDT + set_test('Kernel + FDT load') + params['fdt_load'] = 'load = <%#x>;' % params['fdt_addr'] + fit = make_fit(mkimage, params) + stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) + debug_stdout(stdout) + if read_file(kernel) != read_file(kernel_out): + fail('Kernel not loaded', stdout) + if read_file(control_dtb) != read_file(fdt_out): + fail('FDT not loaded', stdout) + if read_file(ramdisk) == read_file(ramdisk_out): + fail('Ramdisk loaded but should not be', stdout) + + # Try a ramdisk + set_test('Kernel + FDT + Ramdisk load') + params['ramdisk_config'] = 'ramdisk = "ramdisk@1";' + params['ramdisk_load'] = 'load = <%#x>;' % params['ramdisk_addr'] + fit = make_fit(mkimage, params) + stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) + debug_stdout(stdout) + if read_file(ramdisk) != read_file(ramdisk_out): + fail('Ramdisk not loaded', stdout) + + # Configuration with some Loadables + set_test('Kernel + FDT + Ramdisk load + Loadables') + params['loadables_config'] = 'loadables = "kernel@2", "ramdisk@2";' + params['loadables1_load'] = 'load = <%#x>;' % params['loadables1_addr'] + params['loadables2_load'] = 'load = <%#x>;' % params['loadables2_addr'] + fit = make_fit(mkimage, params) + stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) + debug_stdout(stdout) + if read_file(loadables1) != read_file(loadables1_out): + fail('Loadables1 (kernel) not loaded', stdout) + if read_file(loadables2) != read_file(loadables2_out): + fail('Loadables2 (ramdisk) not loaded', stdout)
def run_tests(): """Parse options, run the FIT tests and print the result"""
Convert this test to use the pytest framework.
test/image/test-fit.py | 229 +++++++++++++++++++------------------------------ 1 file changed, 88 insertions(+), 141 deletions(-)
diff --git a/test/image/test-fit.py b/test/image/test-fit.py index c83719bb2d..7e6b96dae4 100755 --- a/test/image/test-fit.py +++ b/test/image/test-fit.py @@ -1,37 +1,13 @@ -#!/usr/bin/python -# # Copyright (c) 2013, Google Inc. # -# Sanity check of the FIT handling in U-Boot -# # SPDX-License-Identifier: GPL-2.0+ # -# To run this: -# -# make O=sandbox sandbox_config -# make O=sandbox -# ./test/image/test-fit.py -u sandbox/u-boot -# -# Note: The above testing requires the Python development package, typically -# called python-devel or something similar. +# Sanity check of the FIT handling in U-Boot
-import doctest -from optparse import OptionParser import os -import shutil +import pytest import struct -import sys -import tempfile - -# Enable printing of all U-Boot output -DEBUG = True - -# The 'command' library in patman is convenient for running commands -base_path = os.path.dirname(sys.argv[0]) -patman = os.path.join(base_path, '../../tools/patman') -sys.path.append(patman) - -import command +import u_boot_utils as util
# Define a base ITS which we can adjust using % and a dictionary base_its = ''' @@ -131,13 +107,11 @@ sb save hostfs 0 %(fdt_addr)x %(fdt_out)s %(fdt_size)x sb save hostfs 0 %(ramdisk_addr)x %(ramdisk_out)s %(ramdisk_size)x sb save hostfs 0 %(loadables1_addr)x %(loadables1_out)s %(loadables1_size)x sb save hostfs 0 %(loadables2_addr)x %(loadables2_out)s %(loadables2_size)x -reset '''
- def debug_stdout(stdout): - if DEBUG: - print stdout - +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('fit_signature') +def test_fit(u_boot_console): def make_fname(leaf): """Make a temporary filename
@@ -146,9 +120,8 @@ reset Return: Temporary filename """ - global base_dir
- return os.path.join(base_dir, leaf) + return os.path.join(cons.config.build_dir, leaf)
def filesize(fname): """Get the size of a file @@ -180,8 +153,8 @@ reset src = make_fname('u-boot.dts') dtb = make_fname('u-boot.dtb') with open(src, 'w') as fd: - print >>fd, base_fdt - command.Output('dtc', src, '-O', 'dtb', '-o', dtb) + print >> fd, base_fdt + util.run_and_log(cons, ['dtc', src, '-O', 'dtb', '-o', dtb]) return dtb
def make_its(params): @@ -194,7 +167,7 @@ reset """ its = make_fname('test.its') with open(its, 'w') as fd: - print >>fd, base_its % params + print >> fd, base_its % params return its
def make_fit(mkimage, params): @@ -211,9 +184,9 @@ reset """ fit = make_fname('test.fit') its = make_its(params) - command.Output(mkimage, '-f', its, fit) + util.run_and_log(cons, [mkimage, '-f', its, fit]) with open(make_fname('u-boot.dts'), 'w') as fd: - print >>fd, base_fdt + print >> fd, base_fdt return fit
def make_kernel(filename, text): @@ -229,7 +202,7 @@ reset for i in range(100): data += 'this %s %d is unlikely to boot\n' % (text, i) with open(fname, 'w') as fd: - print >>fd, data + print >> fd, data return fname
def make_ramdisk(filename, text): @@ -243,7 +216,7 @@ reset for i in range(100): data += '%s %d was seldom used in the middle ages\n' % (text, i) with open(fname, 'w') as fd: - print >>fd, data + print >> fd, data return fname
def find_matching(text, match): @@ -260,52 +233,58 @@ reset to use regex and return groups.
Args: - text: Text to check (each line separated by \n) + text: Text to check (list of strings, one for each command issued) match: String to search for Return: String containing unmatched portion of line Exceptions: ValueError: If match is not found
- >>> find_matching('first line:10\nsecond_line:20', 'first line:') + >>> find_matching(['first line:10', 'second_line:20'], 'first line:') '10' - >>> find_matching('first line:10\nsecond_line:20', 'second line') + >>> find_matching(['first line:10', 'second_line:20'], 'second line') Traceback (most recent call last): ... ValueError: Test aborted - >>> find_matching('first line:10\nsecond_line:20', 'second_line:') + >>> find_matching('first line:10', 'second_line:20'], 'second_line:') '20' + >>> find_matching('first line:10', 'second_line:20\nthird_line:30'], + 'third_line:') + '30' """ - for line in text.splitlines(): + __tracebackhide__ = True + for line in '\n'.join(text).splitlines(): pos = line.find(match) if pos != -1: return line[:pos] + line[pos + len(match):]
- print "Expected '%s' but not found in output:" - print text - raise ValueError('Test aborted') + pytest.fail("Expected '%s' but not found in output")
- def set_test(name): - """Set the name of the current test and print a message + def check_equal(expected_fname, actual_fname, failure_msg): + """Check that a file matches its expected contents
Args: - name: Name of test + expected_fname: Filename containing expected contents + actual_fname: Filename containing actual contents + failure_msg: Message to print on failure """ - global test_name - - test_name = name - print name + expected_data = read_file(expected_fname) + actual_data = read_file(actual_fname) + assert expected_data == actual_data, failure_msg
- def fail(msg, stdout): - """Raise an error with a helpful failure message + def check_not_equal(expected_fname, actual_fname, failure_msg): + """Check that a file does not match its expected contents
Args: - msg: Message to display + expected_fname: Filename containing expected contents + actual_fname: Filename containing actual contents + failure_msg: Message to print on failure """ - print stdout - raise ValueError("Test '%s' failed: %s" % (test_name, msg)) + expected_data = read_file(expected_fname) + actual_data = read_file(actual_fname) + assert expected_data != actual_data, failure_msg
- def run_fit_test(mkimage, u_boot): + def run_fit_test(mkimage): """Basic sanity check of FIT loading in U-Boot
TODO: Almost everything: @@ -324,8 +303,6 @@ reset - bootm command line parameters should have desired effect - run code coverage to make sure we are testing all the code """ - global test_name - # Set up invariant files control_dtb = make_dtb() kernel = make_kernel('test-kernel.bin', 'kernel') @@ -381,101 +358,71 @@ reset
# First check that we can load a kernel # We could perhaps reduce duplication with some loss of readability - set_test('Kernel load') - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(kernel) != read_file(kernel_out): - fail('Kernel not loaded', stdout) - if read_file(control_dtb) == read_file(fdt_out): - fail('FDT loaded but should be ignored', stdout) - if read_file(ramdisk) == read_file(ramdisk_out): - fail('Ramdisk loaded but should not be', stdout) + cons.config.dtb = control_dtb + cons.restart_uboot() + with cons.log.section('Kernel load'): + output = cons.run_command_list(cmd.splitlines()) + check_equal(kernel, kernel_out, 'Kernel not loaded') + check_not_equal(control_dtb, fdt_out, + 'FDT loaded but should be ignored') + check_not_equal(ramdisk, ramdisk_out, + 'Ramdisk loaded but should not be')
# Find out the offset in the FIT where U-Boot has found the FDT - line = find_matching(stdout, 'Booting using the fdt blob at ') + line = find_matching(output, 'Booting using the fdt blob at ') fit_offset = int(line, 16) - params['fit_addr'] fdt_magic = struct.pack('>L', 0xd00dfeed) data = read_file(fit)
# Now find where it actually is in the FIT (skip the first word) real_fit_offset = data.find(fdt_magic, 4) - if fit_offset != real_fit_offset: - fail('U-Boot loaded FDT from offset %#x, FDT is actually at %#x' % - (fit_offset, real_fit_offset), stdout) + assert fit_offset == real_fit_offset, ( + 'U-Boot loaded FDT from offset %#x, FDT is actually at %#x' % + (fit_offset, real_fit_offset))
# Now a kernel and an FDT - set_test('Kernel + FDT load') + with cons.log.section('Kernel + FDT load'): params['fdt_load'] = 'load = <%#x>;' % params['fdt_addr'] fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(kernel) != read_file(kernel_out): - fail('Kernel not loaded', stdout) - if read_file(control_dtb) != read_file(fdt_out): - fail('FDT not loaded', stdout) - if read_file(ramdisk) == read_file(ramdisk_out): - fail('Ramdisk loaded but should not be', stdout) + cons.restart_uboot() + output = cons.run_command_list(cmd.splitlines()) + check_equal(kernel, kernel_out, 'Kernel not loaded') + check_equal(control_dtb, fdt_out, 'FDT not loaded') + check_not_equal(ramdisk, ramdisk_out, + 'Ramdisk loaded but should not be')
# Try a ramdisk - set_test('Kernel + FDT + Ramdisk load') + with cons.log.section('Kernel + FDT + Ramdisk load'): params['ramdisk_config'] = 'ramdisk = "ramdisk@1";' params['ramdisk_load'] = 'load = <%#x>;' % params['ramdisk_addr'] fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(ramdisk) != read_file(ramdisk_out): - fail('Ramdisk not loaded', stdout) + cons.restart_uboot() + output = cons.run_command_list(cmd.splitlines()) + check_equal(ramdisk, ramdisk_out, 'Ramdisk not loaded')
# Configuration with some Loadables - set_test('Kernel + FDT + Ramdisk load + Loadables') + with cons.log.section('Kernel + FDT + Ramdisk load + Loadables'): params['loadables_config'] = 'loadables = "kernel@2", "ramdisk@2";' - params['loadables1_load'] = 'load = <%#x>;' % params['loadables1_addr'] - params['loadables2_load'] = 'load = <%#x>;' % params['loadables2_addr'] + params['loadables1_load'] = ('load = <%#x>;' % + params['loadables1_addr']) + params['loadables2_load'] = ('load = <%#x>;' % + params['loadables2_addr']) fit = make_fit(mkimage, params) - stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) - debug_stdout(stdout) - if read_file(loadables1) != read_file(loadables1_out): - fail('Loadables1 (kernel) not loaded', stdout) - if read_file(loadables2) != read_file(loadables2_out): - fail('Loadables2 (ramdisk) not loaded', stdout) - -def run_tests(): - """Parse options, run the FIT tests and print the result""" - global base_path, base_dir - - # Work in a temporary directory - base_dir = tempfile.mkdtemp() - parser = OptionParser() - parser.add_option('-u', '--u-boot', - default=os.path.join(base_path, 'u-boot'), - help='Select U-Boot sandbox binary') - parser.add_option('-k', '--keep', action='store_true', - help="Don't delete temporary directory even when tests pass") - parser.add_option('-t', '--selftest', action='store_true', - help='Run internal self tests') - (options, args) = parser.parse_args() - - # Find the path to U-Boot, and assume mkimage is in its tools/mkimage dir - base_path = os.path.dirname(options.u_boot) - mkimage = os.path.join(base_path, 'tools/mkimage') - - # There are a few doctests - handle these here - if options.selftest: - doctest.testmod() - return - - title = 'FIT Tests' - print title, '\n', '=' * len(title) - - run_fit_test(mkimage, options.u_boot) - - print '\nTests passed' - print 'Caveat: this is only a sanity check - test coverage is poor' - - # Remove the temporary directory unless we are asked to keep it - if options.keep: - print "Output files are in '%s'" % base_dir - else: - shutil.rmtree(base_dir) - -run_tests() + cons.restart_uboot() + output = cons.run_command_list(cmd.splitlines()) + check_equal(loadables1, loadables1_out, + 'Loadables1 (kernel) not loaded') + check_equal(loadables2, loadables2_out, + 'Loadables2 (ramdisk) not loaded') + + cons = u_boot_console + try: + # We need to use our own device tree file. Remember to restore it + # afterwards. + old_dtb = cons.config.dtb + mkimage = cons.config.build_dir + '/tools/mkimage' + run_fit_test(mkimage) + finally: + # Go back to the original U-Boot with the correct dtb. + cons.config.dtb = old_dtb + cons.restart_uboot()
Move this test so that it will run when 'make tests' is used.
test/{image/test-fit.py => py/tests/test_fit.py} | 0 1 file changed, 0 insertions(+), 0 deletions(-) rename test/{image/test-fit.py => py/tests/test_fit.py} (100%)
diff --git a/test/image/test-fit.py b/test/py/tests/test_fit.py similarity index 100% rename from test/image/test-fit.py rename to test/py/tests/test_fit.py
Thanks! This reminded me that I should be using make tests not invoking test.py directly for sandbox, so I'm increasing my local test coverage at least. For travis-ci, we should add those other sandbox configurations in, I'll take a kick at that shortly.
