[PATCH v2] serial: ns16550: Enable clocks during probe
If the UART bus clock has a gate, it must be enabled before the UART can be used.
Signed-off-by: Samuel Holland samuel@sholland.org ---
Changes in v2: - Only enable the first clock, as using the clk_get_bulk() API pushes a board (phycore-rk3288) over its SPL size limit.
drivers/serial/ns16550.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 7592979cab5..072419343a3 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -507,6 +507,7 @@ int ns16550_serial_probe(struct udevice *dev) struct ns16550 *const com_port = dev_get_priv(dev); struct reset_ctl_bulk reset_bulk; fdt_addr_t addr; + struct clk clk; int ret;
/* @@ -524,6 +525,10 @@ int ns16550_serial_probe(struct udevice *dev) if (!ret) reset_deassert_bulk(&reset_bulk);
+ ret = clk_get_by_index(dev, 0, &clk); + if (!ret) + clk_enable(&clk); + com_port->plat = dev_get_plat(dev); ns16550_init(com_port, -1);
Hi Samuel,
Could you provide an example and or details for which SoC type this is in mind?
For current Rockchip we don't need this. Everything works out of the box and is not touched in the clock driver. The setting is done with serial_rockchip.c
Your clk_enable() function makes it a requirement for a enable ops function on all SoCs with compatible "snps,dw-apb-uart" nodes.
The S clock is on position 0 and is set with "clock-frequency" property. The P clock is on position 1 and is not touched.
- ret = clk_get_by_index(dev, 0, &clk);
This tries to enable the S clock instead of the P clock.
So NAK for now.
Johan
From Linux clk-rk3188.c:
GATE(PCLK_UART2, "pclk_uart2", "pclk_peri", 0, RK2928_CLKGATE_CON(8), 2, GFLAGS),
static struct rockchip_clk_branch common_uart2_fracmux __initdata = MUX(SCLK_UART2, "sclk_uart2", mux_sclk_uart2_p, CLK_SET_RATE_PARENT, RK2928_CLKSEL_CON(15), 8, 2, MFLAGS); ===
From serial_rockchip.c:
static int rockchip_serial_probe(struct udevice *dev) { #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rockchip_uart_plat *plat = dev_get_plat(dev);
/* Create some new platform data for the standard driver */ plat->plat.base = plat->dtplat.reg[0]; plat->plat.reg_shift = plat->dtplat.reg_shift;
//// plat->plat.clock = plat->dtplat.clock_frequency; ////
plat->plat.fcr = UART_FCR_DEFVAL; dev_set_plat(dev, &plat->plat);
return ns16550_serial_probe(dev); #else return -ENODEV; #endif }
From clk_rk3066.c:
static int rk3066_clk_enable(struct clk *clk) { struct rk3066_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { case HCLK_NANDC0: rk_clrreg(&priv->cru->cru_clkgate_con[5], BIT(9)); break; case HCLK_SDMMC: rk_clrreg(&priv->cru->cru_clkgate_con[5], BIT(10)); break; case HCLK_SDIO: rk_clrreg(&priv->cru->cru_clkgate_con[5], BIT(11)); break; }
return 0; } static struct clk_ops rk3066_clk_ops = { .disable = rk3066_clk_disable, .enable = rk3066_clk_enable, .get_rate = rk3066_clk_get_rate, .set_rate = rk3066_clk_set_rate, };
For rk3xxx.dtsi:
uart2: serial@20064000 { compatible = "snps,dw-apb-uart"; reg = <0x20064000 0x400>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <1>; clock-names = "baudclk", "apb_pclk"; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; status = "disabled"; };
Changes in v2:
- if (!ret)
clk_enable(&clk);
- com_port->plat = dev_get_plat(dev); ns16550_init(com_port, -1);
Hi Johan,
On 12/13/22 03:06, Johan Jonker wrote:
Hi Samuel,
This is needed for Allwinner sunxi SoCs, which come out of the boot ROM with all clock gates disabled. Currently, the sunxi SPL board code enables a clock gate in clock_init_uart() based on the legacy console UART selection (CONFIG_CONS_INDEX). For new SoCs (e.g. D1), I am using SPL_DM, so now we rely on the DM serial driver to enable the clock gate.
The patch enables clocks on a best-effort basis, and allows the serial device to continue probing even if an error occurs while getting or enabling a clock. So this patch may not be necessary on Rockchip platforms, but it should not hurt anything either.
With the phycore-rk3288 fix[1] applied, I plan to go back to v1 of the patch, which tries to enable all clocks. Presumably both clocks need to be running for the UART to work. So "enabling" them should be conceptually correct, even if no action is needed from U-Boot to accomplish that on Rockchip platforms.
Regards, Samuel
[1]: https://lore.kernel.org/u-boot/20221213103809.1407187-1-w.egorov@phytec.de/
So NAK for now.
Johan
From Linux clk-rk3188.c: GATE(PCLK_UART2, "pclk_uart2", "pclk_peri", 0, RK2928_CLKGATE_CON(8), 2, GFLAGS),
From clk_rk3066.c:
For rk3xxx.dtsi:
Changes in v2:
- if (!ret)
clk_enable(&clk);
Johan Jonker
Samuel Holland
