[U-Boot] [PATCH 1/1] sunxi: Add support for A33-OLinuXino board
--- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-a33-olinuxino.dts | 223 +++++++++++++++++++++++++++++++++++ configs/A33_OLinuXino_defconfig | 29 +++++ 3 files changed, 254 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-a33-olinuxino.dts create mode 100644 configs/A33_OLinuXino_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a827613..dbda275 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -221,7 +221,8 @@ dtb-$(CONFIG_MACH_SUN8I_A23) += \ dtb-$(CONFIG_MACH_SUN8I_A33) += \ sun8i-a33-ga10h-v1.1.dtb \ sun8i-a33-q8-tablet.dtb \ - sun8i-a33-sinlinx-sina33.dtb + sun8i-a33-sinlinx-sina33.dtb \ + sun8i-a33-olinuxino.dtb dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ sun8i-a83t-cubietruck-plus.dtb \ diff --git a/arch/arm/dts/sun8i-a33-olinuxino.dts b/arch/arm/dts/sun8i-a33-olinuxino.dts new file mode 100644 index 0000000..2eaeb55 --- /dev/null +++ b/arch/arm/dts/sun8i-a33-olinuxino.dts @@ -0,0 +1,223 @@ +/* + * Copyright 2016 - Stefan Mavrodiev stefan.mavrodiev@gmail.com + * Olimex LTD. support@olimex.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a33.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "A33-OLinuXino"; + compatible = "allwinner,sun8i-a33"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pin_olinuxino>; + + green { + label = "olinuxino:green:usr"; + gpios = <&pio 1 7 GPIO_ACTIVE_HIGH>; /* LED2 */ + linux,default-trigger = "heartbeat"; + }; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_olinuxino>; + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */ + cd-inverted; + status = "okay"; +}; + +&pio { + mmc0_cd_pin_olinuxino: mmc0_cd_pin@0 { + allwinner,pins = "PB4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + led_pin_olinuxino: led_pins@0 { + allwinner,pins = "PB7"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&r_rsb { + status = "okay"; + + axp22x: pmic@3a3 { + compatible = "x-powers,axp223"; + reg = <0x3a3>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + eldoin-supply = <®_dcdc1>; + }; +}; + +#include "axp22x.dtsi" + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-dsi"; +}; + +®_dc1sw { + regulator-always-on; + regulator-name = "vcc-lcd"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-sys"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dc5ldo { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpus"; +}; + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-io"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <2350000>; + regulator-max-microvolt = <2650000>; + regulator-name = "vdd-dll"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-avcc"; +}; + +®_dldo3 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-csi"; +}; + +®_eldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dvdd-csi"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_b>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + usb0_vbus-supply = <®_vcc5v0>; + status = "okay"; + +}; + +&simplefb_lcd { + vcc-lcd-supply = <®_dc1sw>; +}; diff --git a/configs/A33_OLinuXino_defconfig b/configs/A33_OLinuXino_defconfig new file mode 100644 index 0000000..d8fc110 --- /dev/null +++ b/configs/A33_OLinuXino_defconfig @@ -0,0 +1,29 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_A33=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=15291 +CONFIG_MMC0_CD_PIN="PB4" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_AXP_GPIO=y +CONFIG_USB0_ID_DET="PB3" +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-olinuxino" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_VIDEO is not set
On 17-06-16 15:46, stefan.mavrodiev@gmail.com wrote:
Thanks, can you please add a proper commit msg, as well as update board/sunxi/MAINTAINERS with an entry for this board.
Last but not least, have you also submitted the dts file to the upstream kernel?
Regards,
Hans
- sun8i-a33-sinlinx-sina33.dtb \
- sun8i-a33-olinuxino.dtb
- Copyright 2016 - Stefan Mavrodiev stefan.mavrodiev@gmail.com
Olimex LTD. <support@olimex.com>
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "A33-OLinuXino";
- compatible = "allwinner,sun8i-a33";
- aliases {
serial0 = &uart0;
- chosen {
- leds {
green {
+&ehci0 {
- status = "okay";
+&ohci0 {
- status = "okay";
+&mmc0 {
- pinctrl-names = "default";
- pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_olinuxino>;
- vmmc-supply = <®_dcdc1>;
- bus-width = <4>;
- cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */
- cd-inverted;
- status = "okay";
+&pio {
- mmc0_cd_pin_olinuxino: mmc0_cd_pin@0 {
- led_pin_olinuxino: led_pins@0 {
+&r_rsb {
- status = "okay";
- axp22x: pmic@3a3 {
reg = <0x3a3>;
+®_dcdc1 {
- regulator-always-on;
- regulator-min-microvolt = <3300000>;
- regulator-max-microvolt = <3300000>;
- regulator-name = "vcc-dsi";
+®_dc1sw {
- regulator-name = "vcc-lcd";
+®_dcdc2 {
- regulator-min-microvolt = <900000>;
- regulator-max-microvolt = <1400000>;
- regulator-name = "vdd-sys";
+®_dcdc3 {
- regulator-name = "vdd-cpu";
+®_dcdc5 {
- regulator-min-microvolt = <1500000>;
- regulator-max-microvolt = <1500000>;
- regulator-name = "vcc-dram";
+®_dc5ldo {
- regulator-name = "vdd-cpus";
+®_aldo1 {
- regulator-name = "vcc-io";
+®_aldo2 {
- regulator-min-microvolt = <2350000>;
- regulator-max-microvolt = <2650000>;
- regulator-name = "vdd-dll";
+®_aldo3 {
- regulator-name = "vcc-avcc";
+®_dldo3 {
- regulator-min-microvolt = <2800000>;
- regulator-max-microvolt = <2800000>;
- regulator-name = "vcc-csi";
+®_eldo2 {
- regulator-min-microvolt = <1800000>;
- regulator-max-microvolt = <1800000>;
- regulator-name = "vcc-dvdd-csi";
+®_rtc_ldo {
- regulator-name = "vcc-rtc";
+&uart0 {
- pinctrl-0 = <&uart0_pins_b>;
- status = "okay";
+&usb_otg {
- dr_mode = "host";
- status = "okay";
+&usbphy {
- usb0_vbus-supply = <®_vcc5v0>;
- status = "okay";
+&simplefb_lcd {
- vcc-lcd-supply = <®_dc1sw>;
Has the dts file been submitted to the upstream kernel ? If not please do so.
Also please provide a short description of the board in the commit msg, and add a line like "The dts file matches the one submitted to the upstream kernel" the commit msg.
Last but not least, please add a board/sunxi/MAINTAINERS entry for this board.
If you can send a v2 with all the above fixed please, then I'll merge it.
Regards,
Hans
- whole.
conditions:
- aliases {
serial0 = &uart0;
- chosen {
- leds {
green {
+&ehci0 {
- status = "okay";
+&ohci0 {
- status = "okay";
+&mmc0 {
- bus-width = <4>;
- cd-inverted;
- status = "okay";
+&pio {
+&r_rsb {
- status = "okay";
reg = <0x3a3>;
+®_dcdc1 {
+®_dc1sw {
+®_dcdc2 {
+®_dcdc3 {
+®_dcdc5 {
+®_dc5ldo {
+®_aldo1 {
+®_aldo2 {
+®_aldo3 {
+®_dldo3 {
+®_eldo2 {
+®_rtc_ldo {
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "host";
- status = "okay";
+&usbphy {
- status = "okay";
+&simplefb_lcd {
Hans de Goede
