Re: [U-Boot] u-boot: How to read file from FAT filesystem on NorFlash MTD partition
sorry for jumping in so late, but Wolfgang just broughtthis thread to my attention. So here are my ideas and comments to your approach/patch:
- Which command can do this? (fatload seems can not because the
interface is not known)
- From which verion u-boot supports this feature? Our u-boot is based
v2009.08. Do we need to update to latest one? (v2009.11-rc1)
I check the document and didn't found the answer. So I have to write it by myself.
I created a patch which provide two functions: fat_norflash_init() fat_norflash_load()
The user call these function in sequence to read file from FAT file system on Nor Flash.
It's possible to do it this way of course, but we really shouldn't go this way. The "right way" to implement FAT support on NOR FLASH would be to add a small block layer to the MTD devices. And MTD block device could then be used by the existing file system drivers (e.g. fatls etc).
We already can export the NOR FLASH as an MTD device, using the CONFIG_FLASH_CFI_MTD config option. It shouldn't be too hard to add a block layer over this MTD device, like done in the Linux kernel (drivers/mtd/mtdblock_ro.c).
This approach has multiple advantages:
- Multiple file systems will be usable (FAT, EXT2 etc.) - Multiple MTD devices will be supported (NOR, NAND etc.)
It would be great if you could rework your patch according to my suggestions.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan,
I agree with you.
I though this is supported(and Wolfgang also told me that) in u-boot but can't find the documents, so I did it it a ugly but directly access way.
I will try it next week. Thank you for your suggestions.
Stefan Roese
Xianwei Zeng
