[U-Boot] [PATCH] arm: socfpga: Enable ethernet PHY configuration to RGMII again
With commit c32a6fd0 [net: Don't call board/cpu_eth_init() with driver model], cpu_eth_init() is not called on SoCFPGA any more. Since this function configures the internal PHY interface to RGMII (via the physel_X bits), its still needed. So lets rename this function and call it in arch_early_init_r().
Tested on socfpga_sr1500.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/misc.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 9b43b92..2b1cd4a 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -104,7 +104,7 @@ static void dwmac_deassert_reset(const unsigned int of_reset_id) socfpga_per_reset(reset, 0); }
-int cpu_eth_init(bd_t *bis) +static int dwmac_eth_init(void) { const void *fdt = gd->fdt_blob; struct fdtdec_phandle_args args; @@ -363,6 +363,10 @@ int arch_early_init_r(void) socfpga_per_reset(SOCFPGA_RESET(NAND), 0); #endif
+#ifdef CONFIG_ETH_DESIGNWARE + dwmac_eth_init(); +#endif + return 0; }
I just sent and applied very similar patch, can you try u-boot-socfpga/master and see if it works for you?
Thanks!
Done and works just fine. So please feel free to upstream your patch version.
Thanks, Stefan
Can this be done in the driver? You have a device tree representation I think. If you are using the compat list in fdtdec.c then it suggests that you need a driver.
Does u-boot DM already have the ability to handle resets of various IP blocks on the chip ? I don't think so, so for now I'll opt for fixing this breakage.
Hi Marek,
OK I see what you mean. We might need to rename the current UCLASS_RESET to make room for this.
Stefan Roese
