[U-Boot] [PATCH v2] arm: dts: vf6: fix DTC unit warnings
Fix following warnings for all vf6 based boards:
Warning (unit_address_vs_reg): Node /soc/ifc@1530000/board-control@3,0/mdio-mux-emi1 has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /soc/aips-bus@40000000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /soc/aips-bus@40080000 has a unit name, but no reg property
Signed-off-by: Heiko Schocher hs@denx.de --- This warnings pop up with the DTC compiler: $ /tmp/dtc/dtc -v Version: DTC 1.4.1-gbeef80b8
This fixes the compile warnings for: https://travis-ci.org/u-boot/u-boot/jobs/122880431
see: https://travis-ci.org/hsdenx/u-boot/jobs/123238780
Changes in v2: - added comment from bhuvanchandra.dv@toradex.com : used the changes Stefan Agner posted o LKML: https://lkml.org/lkml/2016/4/2/11
arch/arm/dts/ls1021a-qds.dtsi | 2 +- arch/arm/dts/vf.dtsi | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/ls1021a-qds.dtsi b/arch/arm/dts/ls1021a-qds.dtsi index ca9e835..4cb6337 100644 --- a/arch/arm/dts/ls1021a-qds.dtsi +++ b/arch/arm/dts/ls1021a-qds.dtsi @@ -138,7 +138,7 @@ device-width = <1>; ranges = <0 3 0 0x100>;
- mdio-mux-emi1 { + mdio-mux-emi1@54 { compatible = "mdio-mux-mmioreg"; mdio-parent-bus = <&mdio0>; #address-cells = <1>; diff --git a/arch/arm/dts/vf.dtsi b/arch/arm/dts/vf.dtsi index 1530d2f..c10c564 100644 --- a/arch/arm/dts/vf.dtsi +++ b/arch/arm/dts/vf.dtsi @@ -32,6 +32,7 @@ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; + reg = <0x40000000 0x00070000>; ranges;
uart0: serial@40027000 { @@ -119,6 +120,7 @@ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; + reg = <0x40080000 0x0007f000>; ranges;
uart4: serial@400a9000 {
Freescale Vybrid and ls1021xx are different SoCs, may be we can split this patchset.
Apart from that. Reviewed-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com
Changes in v2:
mdio-mux-emi1 {
reg = <0x40000000 0x00070000>; ranges; uart0: serial@40027000 {
reg = <0x40080000 0x0007f000>; ranges; uart4: serial@400a9000 {
Bhuvanchandra DV
Heiko Schocher
