[U-Boot-Users] [PATCH] Improve the FDT help message.
Add a note that "fdt copy" makes the new address active. Remove most of the extra hints at the end of the fdt help.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com ---
The fdt copy improvement was suggested by Bartlomiej Sieka, thanks!
common/cmd_fdt.c | 10 +++------- 1 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 74e28b5..9cd22ee 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -683,7 +683,7 @@ U_BOOT_CMD( #ifdef CONFIG_OF_BOARD_SETUP "fdt boardsetup - Do board-specific set up\n" #endif - "fdt move <fdt> <newaddr> <length> - Copy the fdt to <addr>\n" + "fdt move <fdt> <newaddr> <length> - Copy the fdt to <addr> and make it active\n" "fdt print <path> [<prop>] - Recursive print starting at <path>\n" "fdt list <path> [<prop>] - Print one level starting at <path>\n" "fdt set <path> <prop> [<val>] - Set <property> [to <val>]\n" @@ -696,10 +696,6 @@ U_BOOT_CMD( #ifdef CONFIG_OF_HAS_BD_T "fdt bd_t - Add/replace the /bd_t branch in the tree\n" #endif - "Hints:\n" - " If the property you are setting/printing has a '#' character or spaces,\n" - " you MUST escape it with a \ character or quote it with ".\n" - "Examples: fdt print / # print the whole tree\n" - " fdt print /cpus "#address-cells"\n" - " fdt set /cpus "#address-cells" "[00 00 00 01]"\n" + "NOTE: If the path or property you are setting/printing has a '#' character\n" + " or spaces, you MUST escape it with a \ character or quote it with ".\n" );
Jerry Van Baren
