[U-Boot-Users] Debugging U-Boot Under DDD
This may be a trivial question, but I hope that someone can answer me. I am bring up u-boot on 8xx.
While doing source level debugging under ddd, whenever I do step, stepi, next or nexti I see green instruction pointer jump all over the code. e.g. it would go to first line, than third line, than 7 line. If I look at machine code window, it is running in normal predictable way.
See: http://www.denx.de/twiki/bin/view/DULG/DebuggingTricks
Matthew
This SF.Net email sponsored by Black Hat Briefings & Training. Attend Black Hat Briefings & Training, Las Vegas July 24-29 - digital self defense, top technical experts, no vendor pitches, unmatched networking opportunities. Visit www.blackhat.com _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
It's not a trivial question, but a FAQ.
See http://www.denx.de/twiki/bin/view/DULG/DebuggingTricks
Thanks for the link.
I have debugged u-boot to a point, it has relocated code, setup execptions / interrrupts etc and in main_loop().
At this point if I "Cont", I get pop-up from ddd
/.../u-boot-1.1.1/serial.c: No such file or directory.
There are 23 serial.c files in the tree. Those possibly relavent to me are
./cpu/mpc8xx/serial.c ./tools/gdb/serial.c ./drivers/serial.c
Just before relocating the code, I typed following statements
(gdb) symbol-file (gdb) add-symbol-file u-boot 0xbda000 (gdb) dir cpu/mpc8xx (gdb) dir board/fads (gdb) dir tools/gdb/serial.c (gdb) dir drivers/serial.c
Well, my question is why I am getting "No such file or directory" from ddd and how can I fix this problem.
Usman
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de When it is incorrect, it is, at least *authoritatively* incorrect. - Hitchiker's Guide To The Galaxy
In message 20040712194303.3117.qmail@web50504.mail.yahoo.com you wrote:
At this point if I "Cont", I get pop-up from ddd /.../u-boot-1.1.1/serial.c: No such file or directory.
Sounds like a toolchain or user problem to me.
How did you start gdb / DDD? Did you really load "u-boot" (i. e. the ELF file)?
None of these should be necessary. Which toolchain are you using?
I am using eldk
[root@lab1 eldk]# cat version ELDK version 3.0 ppc_8xx: Build 2004-02-16
I am starting ddd with following command line
ddd --debugger /opt/eldk/usr/bin/ppc_8xx-gdb target remote bdi:2001 symbol u-boot set $pc = 0x02000100 # my flash is mapped @ 0x02000000 I am using bin {& not elf}, apart from this problem, it seems to be doing fine.
TA
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de Old programmers never die, they just become managers.
I am bringing up u-boot-1.1.1 on 852T.
I used "make FADS860T_config" for configuration. Since this is the closet match I could find.
I was given FADS board with 852T, with working cpu, sdram and flash under BDI2000. I took values from bdi configuration and applied to u-boot.
If I single step starting from 0x02000100 (my flash starts @ 0x02000000) through to function void cpu_init_f (volatile immap_t * immr) line # 177. It works ok, but if I "Cont" after starting from 0x02000100, I get SIGABRT at line 177 of file u/mpc8xx/cpu_init.c.
{ line 177 is the actual line from u-boot-1.1.1 tree, line 181 which it claims below is after I added few lines}
Program received signal SIGABRT, Aborted. 0x02002540 in cpu_init_f (immr=0xff000000) at cpu_init.c:181 /home/uansari/sw/bootcode/u-boot-1.1.1/cpu/mpc8xx/cpu_init.c:181:5157:beg:0x2002540
Actual line is code:
/* now restrict to preliminary range */ memctl->memc_br0 = CFG_BR0_PRELIM; --->memctl->memc_or0 = CFG_OR0_PRELIM;
#if (defined(CFG_OR1_PRELIM) && defined(CFG_BR1_PRELIM)) memctl->memc_or1 = CFG_OR1_PRELIM; memctl->memc_br1 = CFG_BR1_PRELIM; #endif
Any idea what is going on here ?
Thanks for the help.
This probably means that your BDI2000 config file is not OK.
Such reports are useless. Always quote the exact lines in text.
This is much better.
Read the comment in lines 127...141.
In message 20040713001816.61544.qmail@web50501.mail.yahoo.com you wrote:
I am using eldk
OK.
Try loading the ELF file instead - then GDB will automatically load all required information about source files.
I tried loading elf file, this is what I get
BDI>erase 0x02000000 chip Erasing flash at 0x02000000 Erasing flash passed BDI>prog 0x02000000 u-boot elf Programming u-boot , please wait .... - File offset 0x00000078 to address 0x04000000 size 131408 # Programming flash memory failed at 0x04000040
TA
I am using eldk
OK.
be
doing fine.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de The human mind treats a new idea the way the body treats a strange protein - it rejects it. - P. Medawar
You misunderstood. I was talking about loading the ELF file in GDB, not about programming it to flash using the BDI's telnet interface. These are completely different things.
Now I am confuse. I am running code which is stored on the flash. I am using ddd (gdb in background) to do source level debugging. If I load elf binary gdb, than I am not really running code on the 852t, but on by Linux / Intell based PC.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de Always leave room to add an explanation if it doesn't work out.
No. This is a cross debugger. Loading a file into GDB and running it on the target are completely separate things.
Matthew McClintock
Talib Alim
