[U-Boot] Please pull u-boot-ti/master
Hello,
I've resolved the conflict with the SPL Linux series.
The following changes since commit cd207cde948ecf9ff50a0fa1ae2650f65579c9c9: Marek Vasut (1): IXP: Fix GPIO_INT_ACT_LOW_SET()
git://git.denx.de/u-boot-ti master
Christian Riesch (1): calimain, enbw_cmc: Fix typo in comments
Grazvydas Ignotas (1): twl4030: fix potential power supply handling issues
Heiko Schocher (1): ARM: davinci: fixes for cam_enc_4xx board
Simon Schwarz (8): Add cmd_spl command devkit8000: add config for spl command omap-common: Add NAND SPL linux booting devkit8000/spl: init GPMC for dm9000 in SPL omap-common/spl: Add linux boot to SPL omap/spl: change output of spl_parse_image_header devkit8000: Implement and activate direct OS boot arm: Add Prep subcommand support to bootm
Stefano Babic (8): Add cache functions to SPL for armv7 OMAP3: SPL: do not call I2C init if no I2C is set. SPL: call cleanup_before_linux() before booting Linux OMAP3: twister: add support to boot Linux from SPL NAND: TI: fix warnings in omap_gpmc.c OMAP3: mt_ventoux: updated timing for FPGA OMAP3: mt_ventoux: sets its own mtdparts Davinci: ea20: use gpio framework to access gpios
Tom Rini (1): cam_enc_4xx: Rename 'images' to 'imgs'
jacopo mondi (1): omap3_spi: receive transmit mode
arch/arm/cpu/armv7/Makefile | 2 - arch/arm/cpu/armv7/cpu.c | 2 + arch/arm/cpu/armv7/omap-common/spl.c | 46 ++++- arch/arm/cpu/armv7/omap-common/spl_nand.c | 47 ++++- arch/arm/cpu/armv7/omap3/board.c | 2 + arch/arm/include/asm/bootm.h | 26 +++ arch/arm/include/asm/omap_common.h | 2 + arch/arm/lib/Makefile | 5 +- arch/arm/lib/bootm.c | 349 +++++++++++++++-------------- board/ait/cam_enc_4xx/cam_enc_4xx.c | 103 +++++---- board/ait/cam_enc_4xx/config.mk | 7 + board/ait/cam_enc_4xx/u-boot-spl.lds | 2 +- board/davinci/ea20/ea20.c | 38 +--- board/enbw/enbw_cmc/enbw_cmc.c | 2 +- board/omicron/calimain/calimain.c | 2 +- board/technexion/twister/twister.c | 23 ++ board/teejet/mt_ventoux/mt_ventoux.h | 11 +- board/timll/devkit8000/devkit8000.c | 37 +++ common/Makefile | 1 + common/cmd_spl.c | 188 ++++++++++++++++ doc/README.commands.spl | 31 +++ drivers/mtd/nand/omap_gpmc.c | 14 +- drivers/power/twl4030.c | 18 ++- drivers/spi/omap3_spi.c | 66 +++++- drivers/spi/omap3_spi.h | 2 + include/cmd_spl.h | 31 +++ include/configs/cam_enc_4xx.h | 13 +- include/configs/devkit8000.h | 15 +- include/configs/ea20.h | 2 + include/configs/mt_ventoux.h | 10 + include/configs/twister.h | 12 + include/image.h | 2 + 32 files changed, 835 insertions(+), 276 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h create mode 100644 common/cmd_spl.c create mode 100644 doc/README.commands.spl create mode 100644 include/cmd_spl.h
Hi Tom,
Le 27/03/2012 00:40, Tom Rini a écrit :
Hello,
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
