[U-Boot] [PATCH 0/3] USB: Add cadence USB3 gadget driver and host driver
These patches introduce new Cadence USBSS driver to U-Boot.
The first patch is to add the Cadence USB3 IP(CDNS3) driver for the usb gadget, but the host mode is not supported now. The second patch introduce the xhci-imx8 usb host driver separately. The cdns3 usb gadget driver and xhci-imx8 host driver both use DM mode.
The current driver has been validated on i.MX8 platform.
Sherry Sun (3): USB: gadget: Add the cadence USB3 gadget driver USB: host: Add the USB3 host driver USB: gadget: core: introduce ->udc_set_speed() method
Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 20 + drivers/usb/cdns3/Makefile | 5 + drivers/usb/cdns3/cdns3-generic.c | 176 ++ drivers/usb/cdns3/cdns3-nxp-reg-def.h | 158 ++ drivers/usb/cdns3/core.c | 408 +++++ drivers/usb/cdns3/core.h | 129 ++ drivers/usb/cdns3/dev-regs-macro.h | 116 ++ drivers/usb/cdns3/dev-regs-map.h | 117 ++ drivers/usb/cdns3/gadget-export.h | 26 + drivers/usb/cdns3/gadget.c | 2278 +++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 238 +++ drivers/usb/cdns3/io.h | 30 + drivers/usb/cdns3/linux-compat.h | 16 + drivers/usb/gadget/epautoconf.c | 4 + drivers/usb/gadget/gadget_chips.h | 7 + drivers/usb/gadget/udc/Makefile | 1 + drivers/usb/gadget/udc/udc-core.c | 23 + drivers/usb/host/Kconfig | 9 + drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-imx8.c | 311 ++++ include/cdns3-uboot.h | 26 + include/linux/usb/gadget.h | 5 + include/usb/imx8_usb3_reg_def.h | 455 +++++ scripts/Makefile.spl | 1 + 26 files changed, 4563 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/cdns3-generic.c create mode 100644 drivers/usb/cdns3/cdns3-nxp-reg-def.h create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/dev-regs-macro.h create mode 100644 drivers/usb/cdns3/dev-regs-map.h create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/io.h create mode 100644 drivers/usb/cdns3/linux-compat.h create mode 100644 drivers/usb/host/xhci-imx8.c create mode 100644 include/cdns3-uboot.h create mode 100644 include/usb/imx8_usb3_reg_def.h
This driver is ported from NXP i.MX U-Boot version imx_v2019.04 and some changes have also been made to adapt to U-Boot.
Add the Cadence USB3 IP(CDNS3) driver for the gadget (device mode), while the host mode is not supported.
The CDNS3 gadget driver support DM mode. And gadget_is_cdns3 checking is added to provide bcdUSB value in device descriptor.
Signed-off-by: Sherry Sun sherry.sun@nxp.com --- Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 20 + drivers/usb/cdns3/Makefile | 5 + drivers/usb/cdns3/cdns3-generic.c | 176 ++ drivers/usb/cdns3/cdns3-nxp-reg-def.h | 158 ++ drivers/usb/cdns3/core.c | 408 +++++ drivers/usb/cdns3/core.h | 129 ++ drivers/usb/cdns3/dev-regs-macro.h | 116 ++ drivers/usb/cdns3/dev-regs-map.h | 117 ++ drivers/usb/cdns3/gadget-export.h | 26 + drivers/usb/cdns3/gadget.c | 2278 +++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 238 +++ drivers/usb/cdns3/io.h | 30 + drivers/usb/cdns3/linux-compat.h | 16 + drivers/usb/gadget/epautoconf.c | 4 + drivers/usb/gadget/gadget_chips.h | 7 + drivers/usb/gadget/udc/Makefile | 1 + include/cdns3-uboot.h | 26 + include/linux/usb/gadget.h | 3 + scripts/Makefile.spl | 1 + 21 files changed, 3762 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/cdns3-generic.c create mode 100644 drivers/usb/cdns3/cdns3-nxp-reg-def.h create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/dev-regs-macro.h create mode 100644 drivers/usb/cdns3/dev-regs-map.h create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/io.h create mode 100644 drivers/usb/cdns3/linux-compat.h create mode 100644 include/cdns3-uboot.h
diff --git a/Makefile b/Makefile index f3857ab6a9..2639c81f38 100644 --- a/Makefile +++ b/Makefile @@ -728,6 +728,7 @@ libs-$(CONFIG_SYS_FSL_DDR) += drivers/ddr/fsl/ libs-$(CONFIG_SYS_FSL_MMDC) += drivers/ddr/fsl/ libs-$(CONFIG_$(SPL_)ALTERA_SDRAM) += drivers/ddr/altera/ libs-y += drivers/serial/ +libs-y += drivers/usb/cdns3/ libs-y += drivers/usb/dwc3/ libs-y += drivers/usb/common/ libs-y += drivers/usb/emul/ diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 3b53bf2c58..98f5e936e5 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -70,6 +70,8 @@ source "drivers/usb/host/Kconfig"
source "drivers/usb/dwc3/Kconfig"
+source "drivers/usb/cdns3/Kconfig" + source "drivers/usb/musb/Kconfig"
source "drivers/usb/musb-new/Kconfig" diff --git a/drivers/usb/cdns3/Kconfig b/drivers/usb/cdns3/Kconfig new file mode 100644 index 0000000000..11a7144b05 --- /dev/null +++ b/drivers/usb/cdns3/Kconfig @@ -0,0 +1,20 @@ +config USB_CDNS3 + tristate "Cadence USB3 Dual-Role Controller" + depends on (USB && USB_GADGET) + help + Say Y here if your system has a cadence USB3 dual-role controller. + It supports: dual-role switch Host-only, and Peripheral-only. + + When compiled dynamically, the module will be called cdns3.ko. + +if USB_CDNS3 + +config USB_CDNS3_GADGET + bool "Cadence USB3 device controller" + depends on USB_GADGET + select USB_GADGET_DUALSPEED + help + Say Y here to enable device controller functionality of the + cadence usb3 driver. + +endif diff --git a/drivers/usb/cdns3/Makefile b/drivers/usb/cdns3/Makefile new file mode 100644 index 0000000000..374fa06efa --- /dev/null +++ b/drivers/usb/cdns3/Makefile @@ -0,0 +1,5 @@ +obj-$(CONFIG_USB_CDNS3) += cdns3.o + +cdns3-y := core.o +cdns3-$(CONFIG_USB_CDNS3_GADGET) += gadget.o +cdns3-$(CONFIG_$(SPL_)DM_USB_GADGET) += cdns3-generic.o diff --git a/drivers/usb/cdns3/cdns3-generic.c b/drivers/usb/cdns3/cdns3-generic.c new file mode 100644 index 0000000000..5a17a475c3 --- /dev/null +++ b/drivers/usb/cdns3/cdns3-generic.c @@ -0,0 +1,176 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 NXP + */ + +#include <common.h> +#include <asm-generic/io.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <malloc.h> +#include <usb.h> +#include <clk.h> +#include <power-domain.h> +#include <linux/usb/gadget.h> +#include "core.h" +#include "gadget.h" + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + +static int cdns3_setup_phy(struct udevice *dev, + struct cdns3_generic_peripheral *priv) +{ + int ret = 0; + + struct udevice phy_dev; + int phy_off; + + phy_off = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), + "cdns3,usbphy"); + if (phy_off < 0) + return -EINVAL; + + phy_dev.node = offset_to_ofnode(phy_off); + +#if CONFIG_IS_ENABLED(POWER_DOMAIN) + if (!power_domain_get(&phy_dev, &priv->phy_pd)) { + if (power_domain_on(&priv->phy_pd)) + return -EINVAL; + } +#endif + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_get_by_name(&phy_dev, "main_clk", &priv->phy_clk); + if (ret) { + printf("Failed to get phy_clk\n"); + return ret; + } + + ret = clk_enable(&priv->phy_clk); + if (ret) { + printf("Failed to enable phy_clk\n"); + return ret; + } +#endif + return ret; +} + +static int cdns3_shutdown_phy(struct udevice *dev, + struct cdns3_generic_peripheral *priv) +{ + int ret; + +#if CONFIG_IS_ENABLED(CLK) + if (priv->phy_clk.dev) { + ret = clk_disable(&priv->phy_clk); + if (ret) + return ret; + + ret = clk_free(&priv->phy_clk); + if (ret) + return ret; + } +#endif + + ret = power_domain_off(&priv->phy_pd); + if (ret) + printf("conn_usb2_phy Power down failed! (error = %d)\n", ret); + + return ret; +} + +static int cdns3_generic_peripheral_clk_init(struct udevice *dev, + struct cdns3_generic_peripheral + *priv) +{ + int ret; + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) + return ret; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_enable_bulk(&priv->clks); + if (ret) { + clk_release_bulk(&priv->clks); + return ret; + } +#endif + + return 0; +} + +int dm_usb_gadget_handle_interrupts(struct udevice *dev) +{ + struct cdns3_generic_peripheral *priv = dev_get_priv(dev); + struct cdns3 *cdns3 = &priv->cdns3; + + cdns3_role_irq_handler(cdns3); + + return 0; +} + +static int cdns3_generic_peripheral_probe(struct udevice *dev) +{ + int ret; + struct cdns3_generic_peripheral *priv = dev_get_priv(dev); + struct cdns3 *cdns3 = &priv->cdns3; + + cdns3->dev = dev; + + cdns3_setup_phy(dev, priv); + ret = cdns3_generic_peripheral_clk_init(dev, priv); + if (ret) + return ret; + + ret = cdns3_init(cdns3); + printf("cdns3_uboot_initmode %d\n", ret); + + return 0; +} + +static int cdns3_generic_peripheral_remove(struct udevice *dev) +{ + struct cdns3_generic_peripheral *priv = dev_get_priv(dev); + struct cdns3 *cdns3 = &priv->cdns3; + int ret = 0; + + cdns3_exit(cdns3); + + clk_release_bulk(&priv->clks); + cdns3_shutdown_phy(dev, priv); + + return ret; +} + +static int cdns3_generic_peripheral_ofdata_to_platdata(struct udevice *dev) +{ + struct cdns3_generic_peripheral *priv = dev_get_priv(dev); + struct cdns3 *cdns3 = &priv->cdns3; + + cdns3->none_core_regs = (void __iomem *)devfdt_get_addr_index(dev, 0); + cdns3->xhci_regs = (void __iomem *)devfdt_get_addr_index(dev, 1); + cdns3->dev_regs = (void __iomem *)devfdt_get_addr_index(dev, 2); + cdns3->phy_regs = (void __iomem *)devfdt_get_addr_index(dev, 3); + cdns3->otg_regs = (void __iomem *)devfdt_get_addr_index(dev, 4); + + return 0; +} + +static const struct udevice_id cdns3_generic_peripheral_ids[] = { + { .compatible = "Cadence,usb3" }, + {}, +}; + +U_BOOT_DRIVER(cdns3_generic_peripheral) = { + .name = "cdns3-generic-peripheral", + .id = UCLASS_USB_GADGET_GENERIC, + .of_match = cdns3_generic_peripheral_ids, + .ofdata_to_platdata = cdns3_generic_peripheral_ofdata_to_platdata, + .probe = cdns3_generic_peripheral_probe, + .remove = cdns3_generic_peripheral_remove, + .priv_auto_alloc_size = sizeof(struct cdns3_generic_peripheral), +}; +#endif + diff --git a/drivers/usb/cdns3/cdns3-nxp-reg-def.h b/drivers/usb/cdns3/cdns3-nxp-reg-def.h new file mode 100644 index 0000000000..f0597c7f5d --- /dev/null +++ b/drivers/usb/cdns3/cdns3-nxp-reg-def.h @@ -0,0 +1,158 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __DRIVERS_USB_CDNS3_NXP_H +#define __DRIVERS_USB_CDNS3_NXP_H + +#define USB3_CORE_CTRL1 0x00 +#define USB3_CORE_CTRL2 0x04 +#define USB3_INT_REG 0x08 +#define USB3_CORE_STATUS 0x0c +#define XHCI_DEBUG_LINK_ST 0x10 +#define XHCI_DEBUG_BUS 0x14 +#define USB3_SSPHY_CTRL1 0x40 +#define USB3_SSPHY_CTRL2 0x44 +#define USB3_SSPHY_STATUS 0x4c +#define USB2_PHY_CTRL1 0x50 +#define USB2_PHY_CTRL2 0x54 +#define USB2_PHY_STATUS 0x5c + +/* Register bits definition */ + +/* USB3_CORE_CTRL1 */ +#define SW_RESET_MASK (0x3f << 26) +#define PWR_SW_RESET BIT(31) +#define APB_SW_RESET BIT(30) +#define AXI_SW_RESET BIT(29) +#define RW_SW_RESET BIT(28) +#define PHY_SW_RESET BIT(27) +#define PHYAHB_SW_RESET BIT(26) +#define ALL_SW_RESET (PWR_SW_RESET | APB_SW_RESET | AXI_SW_RESET | \ + RW_SW_RESET | PHY_SW_RESET | PHYAHB_SW_RESET) +#define OC_DISABLE BIT(9) +#define MDCTRL_CLK_SEL BIT(7) +#define MODE_STRAP_MASK (0x7) +#define DEV_MODE BIT(2) +#define HOST_MODE BIT(1) +#define OTG_MODE BIT(0) + +/* USB3_INT_REG */ +#define CLK_125_REQ BIT(29) +#define LPM_CLK_REQ BIT(28) +#define DEVU3_WAEKUP_EN BIT(14) +#define OTG_WAKEUP_EN BIT(12) +#define DEV_INT_EN (3 << 8) /* DEV INT b9:8 */ +#define HOST_INT1_EN BIT(0) /* HOST INT b7:0 */ + +/* USB3_CORE_STATUS */ +#define MDCTRL_CLK_STATUS BIT(15) +#define DEV_POWER_ON_READY BIT(13) +#define HOST_POWER_ON_READY BIT(12) + +/* USB3_SSPHY_STATUS */ +#define PHY_REFCLK_REQ BIT(0) + +/* PHY register definition */ +#define PHY_PMA_CMN_CTRL1 (0xC800 * 4) +#define TB_ADDR_CMN_DIAG_HSCLK_SEL (0x01e0 * 4) +#define TB_ADDR_CMN_PLL0_VCOCAL_INIT_TMR (0x0084 * 4) +#define TB_ADDR_CMN_PLL0_VCOCAL_ITER_TMR (0x0085 * 4) +#define TB_ADDR_CMN_PLL0_INTDIV (0x0094 * 4) +#define TB_ADDR_CMN_PLL0_FRACDIV (0x0095 * 4) +#define TB_ADDR_CMN_PLL0_HIGH_THR (0x0096 * 4) +#define TB_ADDR_CMN_PLL0_SS_CTRL1 (0x0098 * 4) +#define TB_ADDR_CMN_PLL0_SS_CTRL2 (0x0099 * 4) +#define TB_ADDR_CMN_PLL0_DSM_DIAG (0x0097 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_OVRD (0x01c2 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_FBH_OVRD (0x01c0 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_FBL_OVRD (0x01c1 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_V2I_TUNE (0x01C5 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_CP_TUNE (0x01C6 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_LF_PROG (0x01C7 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_TEST_MODE (0x01c4 * 4) +#define TB_ADDR_CMN_PSM_CLK_CTRL (0x0061 * 4) +#define TB_ADDR_XCVR_DIAG_RX_LANE_CAL_RST_TMR (0x40ea * 4) +#define TB_ADDR_XCVR_PSM_RCTRL (0x4001 * 4) +#define TB_ADDR_TX_PSC_A0 (0x4100 * 4) +#define TB_ADDR_TX_PSC_A1 (0x4101 * 4) +#define TB_ADDR_TX_PSC_A2 (0x4102 * 4) +#define TB_ADDR_TX_PSC_A3 (0x4103 * 4) +#define TB_ADDR_TX_DIAG_ECTRL_OVRD (0x41f5 * 4) +#define TB_ADDR_TX_PSC_CAL (0x4106 * 4) +#define TB_ADDR_TX_PSC_RDY (0x4107 * 4) +#define TB_ADDR_RX_PSC_A0 (0x8000 * 4) +#define TB_ADDR_RX_PSC_A1 (0x8001 * 4) +#define TB_ADDR_RX_PSC_A2 (0x8002 * 4) +#define TB_ADDR_RX_PSC_A3 (0x8003 * 4) +#define TB_ADDR_RX_PSC_CAL (0x8006 * 4) +#define TB_ADDR_RX_PSC_RDY (0x8007 * 4) +#define TB_ADDR_TX_TXCC_MGNLS_MULT_000 (0x4058 * 4) +#define TB_ADDR_TX_DIAG_BGREF_PREDRV_DELAY (0x41e7 * 4) +#define TB_ADDR_RX_SLC_CU_ITER_TMR (0x80e3 * 4) +#define TB_ADDR_RX_SIGDET_HL_FILT_TMR (0x8090 * 4) +#define TB_ADDR_RX_SAMP_DAC_CTRL (0x8058 * 4) +#define TB_ADDR_RX_DIAG_SIGDET_TUNE (0x81dc * 4) +#define TB_ADDR_RX_DIAG_LFPSDET_TUNE2 (0x81df * 4) +#define TB_ADDR_RX_DIAG_BS_TM (0x81f5 * 4) +#define TB_ADDR_RX_DIAG_DFE_CTRL1 (0x81d3 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQE_TRIM4 (0x81c7 * 4) +#define TB_ADDR_RX_DIAG_ILL_E_TRIM0 (0x81c2 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQ_TRIM0 (0x81c1 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQE_TRIM6 (0x81c9 * 4) +#define TB_ADDR_RX_DIAG_RXFE_TM3 (0x81f8 * 4) +#define TB_ADDR_RX_DIAG_RXFE_TM4 (0x81f9 * 4) +#define TB_ADDR_RX_DIAG_LFPSDET_TUNE (0x81dd * 4) +#define TB_ADDR_RX_DIAG_DFE_CTRL3 (0x81d5 * 4) +#define TB_ADDR_RX_DIAG_SC2C_DELAY (0x81e1 * 4) +#define TB_ADDR_RX_REE_VGA_GAIN_NODFE (0x81bf * 4) +#define TB_ADDR_XCVR_PSM_CAL_TMR (0x4002 * 4) +#define TB_ADDR_XCVR_PSM_A0BYP_TMR (0x4004 * 4) +#define TB_ADDR_XCVR_PSM_A0IN_TMR (0x4003 * 4) +#define TB_ADDR_XCVR_PSM_A1IN_TMR (0x4005 * 4) +#define TB_ADDR_XCVR_PSM_A2IN_TMR (0x4006 * 4) +#define TB_ADDR_XCVR_PSM_A3IN_TMR (0x4007 * 4) +#define TB_ADDR_XCVR_PSM_A4IN_TMR (0x4008 * 4) +#define TB_ADDR_XCVR_PSM_A5IN_TMR (0x4009 * 4) +#define TB_ADDR_XCVR_PSM_A0OUT_TMR (0x400a * 4) +#define TB_ADDR_XCVR_PSM_A1OUT_TMR (0x400b * 4) +#define TB_ADDR_XCVR_PSM_A2OUT_TMR (0x400c * 4) +#define TB_ADDR_XCVR_PSM_A3OUT_TMR (0x400d * 4) +#define TB_ADDR_XCVR_PSM_A4OUT_TMR (0x400e * 4) +#define TB_ADDR_XCVR_PSM_A5OUT_TMR (0x400f * 4) +#define TB_ADDR_TX_RCVDET_EN_TMR (0x4122 * 4) +#define TB_ADDR_TX_RCVDET_ST_TMR (0x4123 * 4) +#define TB_ADDR_XCVR_DIAG_LANE_FCM_EN_MGN_TMR (0x40f2 * 4) +#define TB_ADDR_TX_RCVDETSC_CTRL (0x4124 * 4) + +/* Register bits definition */ + +/* TB_ADDR_TX_RCVDETSC_CTRL */ +#define RXDET_IN_P3_32KHZ BIT(0) + +/* OTG registers definition */ +#define OTGSTS 0x4 +#define OTGREFCLK 0xc + +/* Register bits definition */ +/* OTGSTS */ +#define OTG_NRDY BIT(11) +/* OTGREFCLK */ +#define OTG_STB_CLK_SWITCH_EN BIT(31) + +/* xHCI registers definition */ +#define XECP_PORT_CAP_REG 0x8000 +#define XECP_PM_PMCSR 0x8018 +#define XECP_AUX_CTRL_REG1 0x8120 + +/* Register bits definition */ +/* XECP_PORT_CAP_REG */ +#define LPM_2_STB_SWITCH_EN BIT(25) + +/* XECP_AUX_CTRL_REG1 */ +#define CFG_RXDET_P3_EN BIT(15) + +/* XECP_PM_PMCSR */ +#define PS_D0 BIT(0) +#endif /* __DRIVERS_USB_CDNS3_NXP_H */ diff --git a/drivers/usb/cdns3/core.c b/drivers/usb/cdns3/core.c new file mode 100644 index 0000000000..be3f45c5dd --- /dev/null +++ b/drivers/usb/cdns3/core.c @@ -0,0 +1,408 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Cadence Design Systems - https://www.cadence.com/ + * Copyright 2019 NXP + */ +#include <common.h> +#include <malloc.h> +#include <asm/dma-mapping.h> +#include <asm/io.h> +#include <linux/bug.h> +#include <linux/list.h> +#include <linux/compat.h> +#include <cdns3-uboot.h> + +#include "linux-compat.h" +#include "cdns3-nxp-reg-def.h" +#include "core.h" +#include "gadget-export.h" + +static LIST_HEAD(cdns3_list); + +/* Need SoC level to implement the clock */ +__weak int cdns3_enable_clks(int index) +{ + return 0; +} + +__weak int cdns3_disable_clks(int index) +{ + return 0; +} + +static void cdns3_usb_phy_init(void __iomem *regs) +{ + u32 value; + + pr_debug("begin of %s\n", __func__); + + writel(0x0830, regs + PHY_PMA_CMN_CTRL1); + writel(0x10, regs + TB_ADDR_CMN_DIAG_HSCLK_SEL); + writel(0x00F0, regs + TB_ADDR_CMN_PLL0_VCOCAL_INIT_TMR); + writel(0x0018, regs + TB_ADDR_CMN_PLL0_VCOCAL_ITER_TMR); + writel(0x00D0, regs + TB_ADDR_CMN_PLL0_INTDIV); + writel(0x4aaa, regs + TB_ADDR_CMN_PLL0_FRACDIV); + writel(0x0034, regs + TB_ADDR_CMN_PLL0_HIGH_THR); + writel(0x1ee, regs + TB_ADDR_CMN_PLL0_SS_CTRL1); + writel(0x7F03, regs + TB_ADDR_CMN_PLL0_SS_CTRL2); + writel(0x0020, regs + TB_ADDR_CMN_PLL0_DSM_DIAG); + writel(0x0000, regs + TB_ADDR_CMN_DIAG_PLL0_OVRD); + writel(0x0000, regs + TB_ADDR_CMN_DIAG_PLL0_FBH_OVRD); + writel(0x0000, regs + TB_ADDR_CMN_DIAG_PLL0_FBL_OVRD); + writel(0x0007, regs + TB_ADDR_CMN_DIAG_PLL0_V2I_TUNE); + writel(0x0027, regs + TB_ADDR_CMN_DIAG_PLL0_CP_TUNE); + writel(0x0008, regs + TB_ADDR_CMN_DIAG_PLL0_LF_PROG); + writel(0x0022, regs + TB_ADDR_CMN_DIAG_PLL0_TEST_MODE); + writel(0x000a, regs + TB_ADDR_CMN_PSM_CLK_CTRL); + writel(0x139, regs + TB_ADDR_XCVR_DIAG_RX_LANE_CAL_RST_TMR); + writel(0xbefc, regs + TB_ADDR_XCVR_PSM_RCTRL); + + writel(0x7799, regs + TB_ADDR_TX_PSC_A0); + writel(0x7798, regs + TB_ADDR_TX_PSC_A1); + writel(0x509b, regs + TB_ADDR_TX_PSC_A2); + writel(0x3, regs + TB_ADDR_TX_DIAG_ECTRL_OVRD); + writel(0x509b, regs + TB_ADDR_TX_PSC_A3); + writel(0x2090, regs + TB_ADDR_TX_PSC_CAL); + writel(0x2090, regs + TB_ADDR_TX_PSC_RDY); + + writel(0xA6FD, regs + TB_ADDR_RX_PSC_A0); + writel(0xA6FD, regs + TB_ADDR_RX_PSC_A1); + writel(0xA410, regs + TB_ADDR_RX_PSC_A2); + writel(0x2410, regs + TB_ADDR_RX_PSC_A3); + + writel(0x23FF, regs + TB_ADDR_RX_PSC_CAL); + writel(0x2010, regs + TB_ADDR_RX_PSC_RDY); + + writel(0x0020, regs + TB_ADDR_TX_TXCC_MGNLS_MULT_000); + writel(0x00ff, regs + TB_ADDR_TX_DIAG_BGREF_PREDRV_DELAY); + writel(0x0002, regs + TB_ADDR_RX_SLC_CU_ITER_TMR); + writel(0x0013, regs + TB_ADDR_RX_SIGDET_HL_FILT_TMR); + writel(0x0000, regs + TB_ADDR_RX_SAMP_DAC_CTRL); + writel(0x1004, regs + TB_ADDR_RX_DIAG_SIGDET_TUNE); + writel(0x4041, regs + TB_ADDR_RX_DIAG_LFPSDET_TUNE2); + writel(0x0480, regs + TB_ADDR_RX_DIAG_BS_TM); + writel(0x8006, regs + TB_ADDR_RX_DIAG_DFE_CTRL1); + writel(0x003f, regs + TB_ADDR_RX_DIAG_ILL_IQE_TRIM4); + writel(0x543f, regs + TB_ADDR_RX_DIAG_ILL_E_TRIM0); + writel(0x543f, regs + TB_ADDR_RX_DIAG_ILL_IQ_TRIM0); + writel(0x0000, regs + TB_ADDR_RX_DIAG_ILL_IQE_TRIM6); + writel(0x8000, regs + TB_ADDR_RX_DIAG_RXFE_TM3); + writel(0x0003, regs + TB_ADDR_RX_DIAG_RXFE_TM4); + writel(0x2408, regs + TB_ADDR_RX_DIAG_LFPSDET_TUNE); + writel(0x05ca, regs + TB_ADDR_RX_DIAG_DFE_CTRL3); + writel(0x0258, regs + TB_ADDR_RX_DIAG_SC2C_DELAY); + writel(0x1fff, regs + TB_ADDR_RX_REE_VGA_GAIN_NODFE); + + writel(0x02c6, regs + TB_ADDR_XCVR_PSM_CAL_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A0BYP_TMR); + writel(0x02c6, regs + TB_ADDR_XCVR_PSM_A0IN_TMR); + writel(0x0010, regs + TB_ADDR_XCVR_PSM_A1IN_TMR); + writel(0x0010, regs + TB_ADDR_XCVR_PSM_A2IN_TMR); + writel(0x0010, regs + TB_ADDR_XCVR_PSM_A3IN_TMR); + writel(0x0010, regs + TB_ADDR_XCVR_PSM_A4IN_TMR); + writel(0x0010, regs + TB_ADDR_XCVR_PSM_A5IN_TMR); + + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A0OUT_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A1OUT_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A2OUT_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A3OUT_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A4OUT_TMR); + writel(0x0002, regs + TB_ADDR_XCVR_PSM_A5OUT_TMR); + + /* Change rx detect parameter */ + writel(0x960, regs + TB_ADDR_TX_RCVDET_EN_TMR); + writel(0x01e0, regs + TB_ADDR_TX_RCVDET_ST_TMR); + writel(0x0090, regs + TB_ADDR_XCVR_DIAG_LANE_FCM_EN_MGN_TMR); + + /* RXDET_IN_P3_32KHZ, Receiver detect slow clock enable */ + value = readl(regs + TB_ADDR_TX_RCVDETSC_CTRL); + value |= RXDET_IN_P3_32KHZ; + writel(value, regs + TB_ADDR_TX_RCVDETSC_CTRL); + + udelay(10); + + pr_debug("end of %s\n", __func__); +} + +static void cdns3_reset_core(struct cdns3 *cdns) +{ + u32 value; + + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value |= ALL_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + udelay(1); +} + +static void cdns3_set_role(struct cdns3 *cdns, enum cdns3_roles role) +{ + u32 value; + int timeout_us = 100000; + + if (role == CDNS3_ROLE_END) + return; + + /* Wait clk value */ + value = readl(cdns->none_core_regs + USB3_SSPHY_STATUS); + writel(value, cdns->none_core_regs + USB3_SSPHY_STATUS); + udelay(1); + value = readl(cdns->none_core_regs + USB3_SSPHY_STATUS); + while ((value & 0xf0000000) != 0xf0000000 && timeout_us-- > 0) { + value = readl(cdns->none_core_regs + USB3_SSPHY_STATUS); + dev_dbg(cdns->dev, "clkvld:0x%x\n", value); + udelay(1); + } + + if (timeout_us <= 0) + dev_err(cdns->dev, "wait clkvld timeout\n"); + + /* Set all Reset bits */ + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value |= ALL_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + udelay(1); + + if (role == CDNS3_ROLE_HOST) { + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value = (value & ~MODE_STRAP_MASK) | HOST_MODE | OC_DISABLE; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + value &= ~PHYAHB_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + mdelay(1); + cdns3_usb_phy_init(cdns->phy_regs); + /* Force B Session Valid as 1 */ + writel(0x0060, cdns->phy_regs + 0x380a4); + mdelay(1); + + value = readl(cdns->none_core_regs + USB3_INT_REG); + value |= HOST_INT1_EN; + writel(value, cdns->none_core_regs + USB3_INT_REG); + + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value &= ~ALL_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + + dev_dbg(cdns->dev, "wait xhci_power_on_ready\n"); + + value = readl(cdns->none_core_regs + USB3_CORE_STATUS); + timeout_us = 100000; + while (!(value & HOST_POWER_ON_READY) && timeout_us-- > 0) { + value = readl(cdns->none_core_regs + USB3_CORE_STATUS); + udelay(1); + } + + if (timeout_us <= 0) + dev_err(cdns->dev, "wait xhci_power_on_ready timeout\n"); + + mdelay(1); + + dev_dbg(cdns->dev, "switch to host role successfully\n"); + } else { /* gadget mode */ + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value = (value & ~MODE_STRAP_MASK) | DEV_MODE; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + value &= ~PHYAHB_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + + cdns3_usb_phy_init(cdns->phy_regs); + /* Force B Session Valid as 1 */ + writel(0x0060, cdns->phy_regs + 0x380a4); + value = readl(cdns->none_core_regs + USB3_INT_REG); + value |= DEV_INT_EN; + writel(value, cdns->none_core_regs + USB3_INT_REG); + + value = readl(cdns->none_core_regs + USB3_CORE_CTRL1); + value &= ~ALL_SW_RESET; + writel(value, cdns->none_core_regs + USB3_CORE_CTRL1); + + dev_dbg(cdns->dev, "wait gadget_power_on_ready\n"); + + value = readl(cdns->none_core_regs + USB3_CORE_STATUS); + timeout_us = 100000; + while (!(value & DEV_POWER_ON_READY) && timeout_us-- > 0) { + value = readl(cdns->none_core_regs + USB3_CORE_STATUS); + udelay(1); + } + + if (timeout_us <= 0) + dev_err(cdns->dev, + "wait gadget_power_on_ready timeout\n"); + + mdelay(1); + + dev_dbg(cdns->dev, "switch to gadget role successfully\n"); + } +} + +static enum cdns3_roles cdns3_get_role(struct cdns3 *cdns) +{ + return cdns->roles[CDNS3_ROLE_HOST] + ? CDNS3_ROLE_HOST + : CDNS3_ROLE_GADGET; +} + +/** + * cdns3_core_init_role - initialize role of operation + * @cdns: Pointer to cdns3 structure + * + * Returns 0 on success otherwise negative errno + */ +static int cdns3_core_init_role(struct cdns3 *cdns, enum usb_dr_mode dr_mode) +{ + cdns->role = CDNS3_ROLE_END; + if (dr_mode == USB_DR_MODE_UNKNOWN) + dr_mode = USB_DR_MODE_OTG; + + /* Currently, only support gadget mode */ + if (dr_mode == USB_DR_MODE_OTG || dr_mode == USB_DR_MODE_HOST) { + dev_err(cdns->dev, "doesn't support host and OTG, only for gadget\n"); + return -EPERM; + } + + if (dr_mode == USB_DR_MODE_PERIPHERAL) { + if (cdns3_gadget_init(cdns)) + dev_info(cdns->dev, "doesn't support gadget\n"); + } + + if (!cdns->roles[CDNS3_ROLE_HOST] && !cdns->roles[CDNS3_ROLE_GADGET]) { + dev_err(cdns->dev, "no supported roles\n"); + return -ENODEV; + } + + return 0; +} + +static void cdns3_remove_roles(struct cdns3 *cdns) +{ + /* Only support gadget */ + cdns3_gadget_remove(cdns); +} + +#if !CONFIG_IS_ENABLED(DM_USB_GADGET) +int cdns3_uboot_init(struct cdns3_device *cdns3_dev) +{ + struct device *dev = NULL; + struct cdns3 *cdns; + int ret; + + cdns = devm_kzalloc(dev, sizeof(*cdns), GFP_KERNEL); + if (!cdns) + return -ENOMEM; + + cdns->dev = dev; + + /* + * Request memory region + * region-0: nxp wrap registers + * region-1: xHCI + * region-2: Peripheral + * region-3: PHY registers + * region-4: OTG registers + */ + cdns->none_core_regs = (void __iomem *)cdns3_dev->none_core_base; + cdns->xhci_regs = (void __iomem *)cdns3_dev->xhci_base; + cdns->dev_regs = (void __iomem *)cdns3_dev->dev_base; + cdns->phy_regs = (void __iomem *)cdns3_dev->phy_base; + cdns->otg_regs = (void __iomem *)cdns3_dev->otg_base; + cdns->index = cdns3_dev->index; + + ret = cdns3_enable_clks(cdns->index); + if (ret) + return ret; + + ret = cdns3_core_init_role(cdns, cdns3_dev->dr_mode); + if (ret) + goto err1; + + cdns->role = cdns3_get_role(cdns); + dev_dbg(dev, "the init role is %d\n", cdns->role); + cdns3_set_role(cdns, cdns->role); + ret = cdns3_role_start(cdns, cdns->role); + if (ret) { + dev_err(dev, "can't start %s role\n", cdns3_role(cdns)->name); + goto err2; + } + + dev_dbg(dev, "Cadence USB3 core: probe succeed\n"); + + list_add_tail(&cdns->list, &cdns3_list); + + return 0; + +err2: + cdns3_remove_roles(cdns); +err1: + cdns3_disable_clks(cdns->index); + + /* For u-boot, need to free the memory manually here. */ + if (cdns) + free(cdns); + + return ret; +} + +void cdns3_uboot_exit(int index) +{ + struct cdns3 *cdns; + + list_for_each_entry(cdns, &cdns3_list, list) { + if (cdns->index != index) + continue; + + cdns3_role_stop(cdns); + cdns3_remove_roles(cdns); + cdns3_reset_core(cdns); + cdns3_disable_clks(index); + + list_del(&cdns->list); + kfree(cdns); + break; + } +} + +void cdns3_uboot_handle_interrupt(int index) +{ + struct cdns3 *cdns = NULL; + + list_for_each_entry(cdns, &cdns3_list, list) { + if (cdns->index != index) + continue; + + cdns3_role_irq_handler(cdns); + break; + } +} + +#else +int cdns3_init(struct cdns3 *cdns) +{ + int ret; + + ret = cdns3_core_init_role(cdns, USB_DR_MODE_PERIPHERAL); + + cdns->role = cdns3_get_role(cdns); + dev_dbg(dev, "the init role is %d\n", cdns->role); + cdns3_set_role(cdns, cdns->role); + ret = cdns3_role_start(cdns, cdns->role); + if (ret) { + dev_err(dev, "can't start %s role\n", cdns3_role(cdns)->name); + goto err; + } + + dev_dbg(dev, "Cadence USB3 core: probe succeed\n"); + + return 0; + +err: + cdns3_remove_roles(cdns); + + return ret; +} + +void cdns3_exit(struct cdns3 *cdns) +{ + cdns3_role_stop(cdns); + cdns3_remove_roles(cdns); + cdns3_reset_core(cdns); +} +#endif diff --git a/drivers/usb/cdns3/core.h b/drivers/usb/cdns3/core.h new file mode 100644 index 0000000000..b512e157c3 --- /dev/null +++ b/drivers/usb/cdns3/core.h @@ -0,0 +1,129 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 NXP + */ + +#ifndef __DRIVERS_USB_CDNS3_CORE_H +#define __DRIVERS_USB_CDNS3_CORE_H + +struct cdns3; +enum cdns3_roles { + CDNS3_ROLE_HOST = 0, + CDNS3_ROLE_GADGET, + CDNS3_ROLE_END, +}; + +/** + * struct cdns3_role_driver - host/gadget role driver + * @start: start this role + * @stop: stop this role + * @suspend: suspend callback for this role + * @resume: resume callback for this role + * @irq: irq handler for this role + * @name: role name string (host/gadget) + */ +struct cdns3_role_driver { + int (*start)(struct cdns3 *cdns); + void (*stop)(struct cdns3 *cdns); + int (*suspend)(struct cdns3 *cdns, bool do_wakeup); + int (*resume)(struct cdns3 *cdns, bool hibernated); + int (*irq)(struct cdns3 *cdns); + const char *name; +}; + +#define CDNS3_NUM_OF_CLKS 5 +/** + * struct cdns3 - Representation of Cadence USB3 DRD controller. + * @dev: pointer to Cadence device struct + * @xhci_regs: pointer to base of xhci registers + * @xhci_res: the resource for xhci + * @dev_regs: pointer to base of dev registers + * @none_core_regs: pointer to base of nxp wrapper registers + * @phy_regs: pointer to base of phy registers + * @otg_regs: pointer to base of otg registers + * @irq: irq number for controller + * @roles: array of supported roles for this controller + * @role: current role + * @host_dev: the child host device pointer for cdns3 core + * @gadget_dev: the child gadget device pointer for cdns3 core + * @usbphy: usbphy for this controller + * @cdns3_clks: Clock pointer array for cdns3 core + * @extcon: Type-C extern connector + * @extcon_nb: notifier block for Type-C extern connector + * @role_switch_wq: work queue item for role switch + * @in_lpm: the controller in low power mode + * @wakeup_int: the wakeup interrupt + */ +struct cdns3 { +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + struct udevice *dev; +#else + struct device *dev; +#endif + void __iomem *xhci_regs; + struct resource *xhci_res; + struct usbss_dev_register_block_type __iomem *dev_regs; + void __iomem *none_core_regs; + void __iomem *phy_regs; + void __iomem *otg_regs; + int irq; + struct cdns3_role_driver *roles[CDNS3_ROLE_END]; + enum cdns3_roles role; +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + struct udevice *host_dev; + struct udevice *gadget_dev; +#else + struct device *host_dev; + struct device *gadget_dev; +#endif + struct clk *cdns3_clks[CDNS3_NUM_OF_CLKS]; + + int index; + struct list_head list; +}; + +static inline struct cdns3_role_driver *cdns3_role(struct cdns3 *cdns) +{ + WARN_ON(cdns->role >= CDNS3_ROLE_END || !cdns->roles[cdns->role]); + return cdns->roles[cdns->role]; +} + +static inline int cdns3_role_start(struct cdns3 *cdns, enum cdns3_roles role) +{ + if (role >= CDNS3_ROLE_END) + return 0; + + if (!cdns->roles[role]) + return -ENXIO; + + cdns->role = role; + return cdns->roles[role]->start(cdns); +} + +static inline void cdns3_role_stop(struct cdns3 *cdns) +{ + enum cdns3_roles role = cdns->role; + + if (role == CDNS3_ROLE_END) + return; + + cdns->roles[role]->stop(cdns); + cdns->role = CDNS3_ROLE_END; +} + +static inline void cdns3_role_irq_handler(struct cdns3 *cdns) +{ + enum cdns3_roles role = cdns->role; + + if (role == CDNS3_ROLE_END) + return; + + cdns->roles[role]->irq(cdns); +} + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) +int cdns3_init(struct cdns3 *cdns); +void cdns3_exit(struct cdns3 *cdns); +#endif + +#endif /* __DRIVERS_USB_CDNS3_CORE_H */ diff --git a/drivers/usb/cdns3/dev-regs-macro.h b/drivers/usb/cdns3/dev-regs-macro.h new file mode 100644 index 0000000000..85bf6c3772 --- /dev/null +++ b/drivers/usb/cdns3/dev-regs-macro.h @@ -0,0 +1,116 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Cadence Design Systems - http://www.cadence.com + * Copyright 2019 NXP + */ + +#ifndef __REG_USBSS_DEV_ADDR_MAP_MACRO_H__ +#define __REG_USBSS_DEV_ADDR_MAP_MACRO_H__ + +/* macros for field CFGRST */ +#define USB_CONF__CFGRST__MASK 0x00000001U +#define USB_CONF__CFGSET__MASK 0x00000002U +#define USB_CONF__USB3DIS__MASK 0x00000008U +#define USB_CONF__DEVEN__MASK 0x00004000U +#define USB_CONF__DEVDS__MASK 0x00008000U +#define USB_CONF__L1EN__MASK 0x00010000U +#define USB_CONF__L1DS__MASK 0x00020000U +#define USB_CONF__CLK2OFFDS__MASK 0x00080000U +#define USB_CONF__U1EN__MASK 0x01000000U +#define USB_CONF__U1DS__MASK 0x02000000U +#define USB_CONF__U2EN__MASK 0x04000000U +#define USB_CONF__U2DS__MASK 0x08000000U + +/* macros for field CFGSTS */ +#define USB_STS__CFGSTS__MASK 0x00000001U +#define USB_STS__USBSPEED__READ(src) (((uint32_t)(src) & 0x00000070U) >> 4) + +/* macros for field ENDIAN_MIRROR */ +#define USB_STS__LPMST__READ(src) (((uint32_t)(src) & 0x000c0000U) >> 18) + +/* macros for field USB2CONS */ +#define USB_STS__U1ENS__MASK 0x01000000U +#define USB_STS__U2ENS__MASK 0x02000000U +#define USB_STS__LST__READ(src) (((uint32_t)(src) & 0x3c000000U) >> 26) + +/* macros for field SET_ADDR */ +#define USB_CMD__SET_ADDR__MASK 0x00000001U +#define USB_CMD__STMODE 0x00000200U +#define USB_CMD__TMODE_SEL(x) (x << 10) +#define USB_CMD__FADDR__WRITE(src) (((uint32_t)(src) << 1) & 0x000000feU) + +/* macros for field CONIEN */ +#define USB_IEN__CONIEN__MASK 0x00000001U +#define USB_IEN__DISIEN__MASK 0x00000002U +#define USB_IEN__UWRESIEN__MASK 0x00000004U +#define USB_IEN__UHRESIEN__MASK 0x00000008U +#define USB_IEN__U3EXTIEN__MASK 0x00000020U +#define USB_IEN__CON2IEN__MASK 0x00010000U +#define USB_IEN__U2RESIEN__MASK 0x00040000U +#define USB_IEN__L2ENTIEN__MASK 0x00100000U +#define USB_IEN__L2EXTIEN__MASK 0x00200000U + +/* macros for field CONI */ +#define USB_ISTS__CONI__SHIFT 0 +#define USB_ISTS__DISI__SHIFT 1 +#define USB_ISTS__UWRESI__SHIFT 2 +#define USB_ISTS__UHRESI__SHIFT 3 +#define USB_ISTS__U3EXTI__SHIFT 5 +#define USB_ISTS__CON2I__SHIFT 16 +#define USB_ISTS__DIS2I__SHIFT 17 +#define USB_ISTS__DIS2I__MASK 0x00020000U +#define USB_ISTS__U2RESI__SHIFT 18 +#define USB_ISTS__L2ENTI__SHIFT 20 +#define USB_ISTS__L2EXTI__SHIFT 21 + +/* macros for field TRADDR */ +#define EP_TRADDR__TRADDR__WRITE(src) ((uint32_t)(src) & 0xffffffffU) + +/* macros for field ENABLE */ +#define EP_CFG__ENABLE__MASK 0x00000001U +#define EP_CFG__EPTYPE__WRITE(src) (((uint32_t)(src) << 1) & 0x00000006U) +#define EP_CFG__MAXBURST__WRITE(src) (((uint32_t)(src) << 8) & 0x00000f00U) +#define EP_CFG__MAXPKTSIZE__WRITE(src) (((uint32_t)(src) << 16) & 0x07ff0000U) +#define EP_CFG__BUFFERING__WRITE(src) (((uint32_t)(src) << 27) & 0xf8000000U) + +/* macros for field EPRST */ +#define EP_CMD__EPRST__MASK 0x00000001U +#define EP_CMD__SSTALL__MASK 0x00000002U +#define EP_CMD__CSTALL__MASK 0x00000004U +#define EP_CMD__ERDY__MASK 0x00000008U +#define EP_CMD__REQ_CMPL__MASK 0x00000020U +#define EP_CMD__DRDY__MASK 0x00000040U +#define EP_CMD__DFLUSH__MASK 0x00000080U + +/* macros for field SETUP */ +#define EP_STS__SETUP__MASK 0x00000001U +#define EP_STS__STALL__MASK 0x00000002U +#define EP_STS__IOC__MASK 0x00000004U +#define EP_STS__ISP__MASK 0x00000008U +#define EP_STS__DESCMIS__MASK 0x00000010U +#define EP_STS__TRBERR__MASK 0x00000080U +#define EP_STS__NRDY__MASK 0x00000100U +#define EP_STS__DBUSY__MASK 0x00000200U +#define EP_STS__OUTSMM__MASK 0x00004000U +#define EP_STS__ISOERR__MASK 0x00008000U + +/* macros for field SETUPEN */ +#define EP_STS_EN__SETUPEN__MASK 0x00000001U +#define EP_STS_EN__DESCMISEN__MASK 0x00000010U +#define EP_STS_EN__TRBERREN__MASK 0x00000080U + +/* macros for field EOUTEN0 */ +#define EP_IEN__EOUTEN0__MASK 0x00000001U +#define EP_IEN__EINEN0__MASK 0x00010000U + +/* macros for field EOUT0 */ +#define EP_ISTS__EOUT0__MASK 0x00000001U +#define EP_ISTS__EIN0__MASK 0x00010000U + +/* macros for field LFPS_MIN_DET_U1_EXIT */ +#define DBG_LINK1__LFPS_MIN_GEN_U1_EXIT__WRITE(src) \ + (((uint32_t)(src)\ + << 8) & 0x0000ff00U) +#define DBG_LINK1__LFPS_MIN_GEN_U1_EXIT_SET__MASK 0x02000000U + +#endif /* __REG_USBSS_DEV_ADDR_MAP_MACRO_H__ */ diff --git a/drivers/usb/cdns3/dev-regs-map.h b/drivers/usb/cdns3/dev-regs-map.h new file mode 100644 index 0000000000..c2d43068b7 --- /dev/null +++ b/drivers/usb/cdns3/dev-regs-map.h @@ -0,0 +1,117 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Cadence Design Systems - http://www.cadence.com + * Copyright 2019 NXP + */ + +#ifndef __REG_USBSS_DEV_ADDR_MAP_H__ +#define __REG_USBSS_DEV_ADDR_MAP_H__ + +#include "dev-regs-macro.h" + +struct usbss_dev_register_block_type { + u32 usb_conf; /* 0x0 - 0x4 */ + u32 usb_sts; /* 0x4 - 0x8 */ + u32 usb_cmd; /* 0x8 - 0xc */ + u32 usb_iptn; /* 0xc - 0x10 */ + u32 usb_lpm; /* 0x10 - 0x14 */ + u32 usb_ien; /* 0x14 - 0x18 */ + u32 usb_ists; /* 0x18 - 0x1c */ + u32 ep_sel; /* 0x1c - 0x20 */ + u32 ep_traddr; /* 0x20 - 0x24 */ + u32 ep_cfg; /* 0x24 - 0x28 */ + u32 ep_cmd; /* 0x28 - 0x2c */ + u32 ep_sts; /* 0x2c - 0x30 */ + u32 ep_sts_sid; /* 0x30 - 0x34 */ + u32 ep_sts_en; /* 0x34 - 0x38 */ + u32 drbl; /* 0x38 - 0x3c */ + u32 ep_ien; /* 0x3c - 0x40 */ + u32 ep_ists; /* 0x40 - 0x44 */ + u32 usb_pwr; /* 0x44 - 0x48 */ + u32 usb_conf2; /* 0x48 - 0x4c */ + u32 usb_cap1; /* 0x4c - 0x50 */ + u32 usb_cap2; /* 0x50 - 0x54 */ + u32 usb_cap3; /* 0x54 - 0x58 */ + u32 usb_cap4; /* 0x58 - 0x5c */ + u32 usb_cap5; /* 0x5c - 0x60 */ + u32 PAD2_73; /* 0x60 - 0x64 */ + u32 usb_cpkt1; /* 0x64 - 0x68 */ + u32 usb_cpkt2; /* 0x68 - 0x6c */ + u32 usb_cpkt3; /* 0x6c - 0x70 */ + char pad__0[0x90]; /* 0x70 - 0x100 */ + u32 PAD2_78; /* 0x100 - 0x104 */ + u32 dbg_link1; /* 0x104 - 0x108 */ + u32 PAD2_80; /* 0x108 - 0x10c */ + u32 PAD2_81; /* 0x10c - 0x110 */ + u32 PAD2_82; /* 0x110 - 0x114 */ + u32 PAD2_83; /* 0x114 - 0x118 */ + u32 PAD2_84; /* 0x118 - 0x11c */ + u32 PAD2_85; /* 0x11c - 0x120 */ + u32 PAD2_86; /* 0x120 - 0x124 */ + u32 PAD2_87; /* 0x124 - 0x128 */ + u32 PAD2_88; /* 0x128 - 0x12c */ + u32 PAD2_89; /* 0x12c - 0x130 */ + u32 PAD2_90; /* 0x130 - 0x134 */ + u32 PAD2_91; /* 0x134 - 0x138 */ + u32 PAD2_92; /* 0x138 - 0x13c */ + u32 PAD2_93; /* 0x13c - 0x140 */ + u32 PAD2_94; /* 0x140 - 0x144 */ + u32 PAD2_95; /* 0x144 - 0x148 */ + u32 PAD2_96; /* 0x148 - 0x14c */ + u32 PAD2_97; /* 0x14c - 0x150 */ + u32 PAD2_98; /* 0x150 - 0x154 */ + u32 PAD2_99; /* 0x154 - 0x158 */ + u32 PAD2_100; /* 0x158 - 0x15c */ + u32 PAD2_101; /* 0x15c - 0x160 */ + u32 PAD2_102; /* 0x160 - 0x164 */ + u32 PAD2_103; /* 0x164 - 0x168 */ + u32 PAD2_104; /* 0x168 - 0x16c */ + u32 PAD2_105; /* 0x16c - 0x170 */ + u32 PAD2_106; /* 0x170 - 0x174 */ + u32 PAD2_107; /* 0x174 - 0x178 */ + u32 PAD2_108; /* 0x178 - 0x17c */ + u32 PAD2_109; /* 0x17c - 0x180 */ + u32 PAD2_110; /* 0x180 - 0x184 */ + u32 PAD2_111; /* 0x184 - 0x188 */ + u32 PAD2_112; /* 0x188 - 0x18c */ + char pad__1[0x20]; /* 0x18c - 0x1ac */ + u32 PAD2_114; /* 0x1ac - 0x1b0 */ + u32 PAD2_115; /* 0x1b0 - 0x1b4 */ + u32 PAD2_116; /* 0x1b4 - 0x1b8 */ + u32 PAD2_117; /* 0x1b8 - 0x1bc */ + u32 PAD2_118; /* 0x1bc - 0x1c0 */ + u32 PAD2_119; /* 0x1c0 - 0x1c4 */ + u32 PAD2_120; /* 0x1c4 - 0x1c8 */ + u32 PAD2_121; /* 0x1c8 - 0x1cc */ + u32 PAD2_122; /* 0x1cc - 0x1d0 */ + u32 PAD2_123; /* 0x1d0 - 0x1d4 */ + u32 PAD2_124; /* 0x1d4 - 0x1d8 */ + u32 PAD2_125; /* 0x1d8 - 0x1dc */ + u32 PAD2_126; /* 0x1dc - 0x1e0 */ + u32 PAD2_127; /* 0x1e0 - 0x1e4 */ + u32 PAD2_128; /* 0x1e4 - 0x1e8 */ + u32 PAD2_129; /* 0x1e8 - 0x1ec */ + u32 PAD2_130; /* 0x1ec - 0x1f0 */ + u32 PAD2_131; /* 0x1f0 - 0x1f4 */ + u32 PAD2_132; /* 0x1f4 - 0x1f8 */ + u32 PAD2_133; /* 0x1f8 - 0x1fc */ + u32 PAD2_134; /* 0x1fc - 0x200 */ + u32 PAD2_135; /* 0x200 - 0x204 */ + u32 PAD2_136; /* 0x204 - 0x208 */ + u32 PAD2_137; /* 0x208 - 0x20c */ + u32 PAD2_138; /* 0x20c - 0x210 */ + u32 PAD2_139; /* 0x210 - 0x214 */ + u32 PAD2_140; /* 0x214 - 0x218 */ + u32 PAD2_141; /* 0x218 - 0x21c */ + u32 PAD2_142; /* 0x21c - 0x220 */ + u32 PAD2_143; /* 0x220 - 0x224 */ + u32 PAD2_144; /* 0x224 - 0x228 */ + char pad__2[0xd8]; /* 0x228 - 0x300 */ + u32 dma_axi_ctrl; /* 0x300 - 0x304 */ + u32 PAD2_147; /* 0x304 - 0x308 */ + u32 PAD2_148; /* 0x308 - 0x30c */ + u32 PAD2_149; /* 0x30c - 0x310 */ + u32 PAD2_150; /* 0x310 - 0x314 */ +}; + +#endif /* __REG_USBSS_DEV_ADDR_MAP_H__ */ diff --git a/drivers/usb/cdns3/gadget-export.h b/drivers/usb/cdns3/gadget-export.h new file mode 100644 index 0000000000..0b011b56c6 --- /dev/null +++ b/drivers/usb/cdns3/gadget-export.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __CDNS3_GADGET_EXPORT_H +#define __CDNS3_GADGET_EXPORT_H + +#ifdef CONFIG_USB_CDNS3_GADGET + +int cdns3_gadget_init(struct cdns3 *cdns); +void cdns3_gadget_remove(struct cdns3 *cdns); +#else + +static inline int cdns3_gadget_init(struct cdns3 *cdns) +{ + return -ENXIO; +} + +static inline void cdns3_gadget_remove(struct cdns3 *cdns) +{ +} + +#endif + +#endif /* __CDNS3_GADGET_EXPORT_H */ diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c new file mode 100644 index 0000000000..9858c66304 --- /dev/null +++ b/drivers/usb/cdns3/gadget.c @@ -0,0 +1,2278 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Cadence Design Systems - https://www.cadence.com/ + * Copyright 2019 NXP + */ +#include <common.h> +#include <malloc.h> +#include <asm/dma-mapping.h> +#include <asm/io.h> +#include <linux/bug.h> +#include <linux/list.h> +#include <linux/compat.h> + +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/composite.h> + +#include "core.h" +#include "gadget-export.h" +#include "gadget.h" +#include "io.h" + +static void __cdns3_gadget_start(struct usb_ss_dev *usb_ss); +static void cdns_prepare_setup_packet(struct usb_ss_dev *usb_ss); +static void cdns_ep_config(struct usb_ss_endpoint *usb_ss_ep); + +static const char *const speed_names[] = { + [USB_SPEED_UNKNOWN] = "UNKNOWN", + [USB_SPEED_LOW] = "low-speed", + [USB_SPEED_FULL] = "full-speed", + [USB_SPEED_HIGH] = "high-speed", + [USB_SPEED_WIRELESS] = "wireless", + [USB_SPEED_SUPER] = "super-speed", +}; + +const char *usb_speed_string(enum usb_device_speed speed) +{ + if (speed < 0 || speed >= ARRAY_SIZE(speed_names)) + speed = USB_SPEED_UNKNOWN; + return speed_names[speed]; +} + +static struct usb_endpoint_descriptor cdns3_gadget_ep0_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + .bmAttributes = USB_ENDPOINT_XFER_CONTROL, +}; + +static u32 gadget_readl(struct usb_ss_dev *usb_ss, u32 __iomem *reg) +{ + return cdns_readl(reg); +} + +static void gadget_writel(struct usb_ss_dev *usb_ss, + u32 __iomem *reg, u32 value) +{ + cdns_writel(reg, value); +} + +/** + * next_request - returns next request from list + * @list: list containing requests + * + * Returns request or NULL if no requests in list + */ +static struct usb_request *next_request(struct list_head *list) +{ + if (list_empty(list)) + return NULL; + return list_first_entry(list, struct usb_request, list); +} + +/** + * select_ep - selects endpoint + * @usb_ss: extended gadget object + * @ep: endpoint address + */ +static void select_ep(struct usb_ss_dev *usb_ss, u32 ep) +{ + if (!usb_ss || !usb_ss->regs) { + dev_err(&usb_ss->dev, "Failed to select endpoint!\n"); + return; + } + + gadget_writel(usb_ss, &usb_ss->regs->ep_sel, ep); +} + +/** + * usb_ss_allocate_trb_pool - Allocates TRB's pool for selected endpoint + * @usb_ss_ep: extended endpoint object + * + * Function will return 0 on success or -ENOMEM on allocation error + */ +static int usb_ss_allocate_trb_pool(struct usb_ss_endpoint *usb_ss_ep) +{ + if (usb_ss_ep->trb_pool) + return 0; + + usb_ss_ep->trb_pool = + dma_alloc_coherent(sizeof(struct usb_ss_trb) * USB_SS_TRBS_NUM, + (unsigned long *)&usb_ss_ep->trb_pool_dma); + + if (!usb_ss_ep->trb_pool) { + dev_err(&usb_ss_ep->usb_ss->dev, + "Failed to allocate TRB pool for endpoint %s\n", + usb_ss_ep->name); + return -ENOMEM; + } + + memset(usb_ss_ep->trb_pool, 0, + sizeof(struct usb_ss_trb) * USB_SS_TRBS_NUM); + + return 0; +} + +/** + * cdns_ep_stall_flush - Stalls and flushes selected endpoint + * @usb_ss_ep: extended endpoint object + * + * Endpoint must be selected before call to this function + */ +static void cdns_ep_stall_flush(struct usb_ss_endpoint *usb_ss_ep) +{ + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__DFLUSH__MASK | EP_CMD__ERDY__MASK | + EP_CMD__SSTALL__MASK); + + /* wait for DFLUSH cleared */ + while (gadget_readl(usb_ss, &usb_ss->regs->ep_cmd) & + EP_CMD__DFLUSH__MASK) + ; + + usb_ss_ep->stalled_flag = 1; +} + +/** + * cdns_ep0_config - Configures default endpoint + * @usb_ss: extended gadget object + * + * Functions sets parameters: maximal packet size and enables interrupts + */ +static void cdns_ep0_config(struct usb_ss_dev *usb_ss) +{ + u32 max_packet_size = 0; + + switch (usb_ss->gadget.speed) { + case USB_SPEED_UNKNOWN: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_0; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_0; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(0); + break; + + case USB_SPEED_LOW: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_8; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_8; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(8); + break; + + case USB_SPEED_FULL: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_64; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_64; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(64); + break; + + case USB_SPEED_HIGH: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_64; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_64; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(64); + break; + + case USB_SPEED_WIRELESS: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_64; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_64; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(64); + break; + + case USB_SPEED_SUPER: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_512; + usb_ss->gadget.ep0->maxpacket = ENDPOINT_MAX_PACKET_SIZE_512; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(512); + break; + } + + /* init ep out */ + select_ep(usb_ss, USB_DIR_OUT); + + gadget_writel(usb_ss, &usb_ss->regs->ep_cfg, + EP_CFG__ENABLE__MASK | + EP_CFG__MAXPKTSIZE__WRITE(max_packet_size)); + gadget_writel(usb_ss, &usb_ss->regs->ep_sts_en, + EP_STS_EN__SETUPEN__MASK | + EP_STS_EN__DESCMISEN__MASK | + EP_STS_EN__TRBERREN__MASK); + + /* init ep in */ + select_ep(usb_ss, USB_DIR_IN); + + gadget_writel(usb_ss, &usb_ss->regs->ep_cfg, + EP_CFG__ENABLE__MASK | + EP_CFG__MAXPKTSIZE__WRITE(max_packet_size)); + gadget_writel(usb_ss, &usb_ss->regs->ep_sts_en, + EP_STS_EN__SETUPEN__MASK | + EP_STS_EN__TRBERREN__MASK); + + cdns_prepare_setup_packet(usb_ss); +} + +/** + * cdns_gadget_unconfig - Unconfigures device controller + * @usb_ss: extended gadget object + */ +static void cdns_gadget_unconfig(struct usb_ss_dev *usb_ss) +{ + /* RESET CONFIGURATION */ + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__CFGRST__MASK); + + usb_ss->hw_configured_flag = 0; +} + +/** + * cdns_ep0_run_transfer - Do transfer on default endpoint hardware + * @usb_ss: extended gadget object + * @dma_addr: physical address where data is/will be stored + * @length: data length + * @erdy: set it to 1 when ERDY packet should be sent - + * exit from flow control state + */ +static void cdns_ep0_run_transfer(struct usb_ss_dev *usb_ss, + dma_addr_t dma_addr, + unsigned int length, int erdy) +{ + usb_ss->trb_ep0[0] = TRB_SET_DATA_BUFFER_POINTER(dma_addr); + usb_ss->trb_ep0[1] = TRB_SET_TRANSFER_LENGTH((u32)length); + usb_ss->trb_ep0[2] = TRB_SET_CYCLE_BIT | + TRB_SET_INT_ON_COMPLETION | TRB_TYPE_NORMAL; + + cdns_flush_cache((uintptr_t)usb_ss->trb_ep0, 20); + cdns_flush_cache((uintptr_t)dma_addr, length); + + dev_dbg(&usb_ss->dev, "DRBL(%02X)\n", + usb_ss->ep0_data_dir ? USB_DIR_IN : USB_DIR_OUT); + + select_ep(usb_ss, usb_ss->ep0_data_dir + ? USB_DIR_IN : USB_DIR_OUT); + + gadget_writel(usb_ss, &usb_ss->regs->ep_traddr, + EP_TRADDR__TRADDR__WRITE(usb_ss->trb_ep0_dma)); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__DRDY__MASK); /* drbl */ + + if (erdy) + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK); +} + +/** + * cdns_ep_run_transfer - Do transfer on no-default endpoint hardware + * @usb_ss_ep: extended endpoint object + * + * Returns zero on success or negative value on failure + */ +static int cdns_ep_run_transfer(struct usb_ss_endpoint *usb_ss_ep) +{ + dma_addr_t trb_dma; + struct usb_request *request = next_request(&usb_ss_ep->request_list); + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + struct usb_ss_trb *trb; + + if (!request) + return -EINVAL; + + dev_dbg(&usb_ss->dev, "DRBL(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + + usb_ss_ep->hw_pending_flag = 1; + trb_dma = request->dma; + + /* must allocate buffer aligned to 8 */ + if (request->dma % ADDR_MODULO_8) { + memcpy(usb_ss_ep->cpu_addr, request->buf, request->length); + trb_dma = usb_ss_ep->dma_addr; + } + + cdns_flush_cache((uintptr_t)trb_dma, request->length); + + trb = usb_ss_ep->trb_pool; + + /* fill TRB */ + trb->offset0 = trb_dma; + + trb->offset4 = TRB_SET_BURST_LENGTH(16) | + TRB_SET_TRANSFER_LENGTH(request->length); + + trb->offset8 = TRB_SET_CYCLE_BIT + | TRB_SET_INT_ON_COMPLETION + | TRB_SET_INT_ON_SHORT_PACKET + | TRB_TYPE_NORMAL; + + cdns_flush_cache((uintptr_t)trb, sizeof(struct usb_ss_trb)); + + /* arm transfer on selected endpoint */ + select_ep(usb_ss_ep->usb_ss, + usb_ss_ep->endpoint.desc->bEndpointAddress); + + gadget_writel(usb_ss, &usb_ss->regs->ep_traddr, + EP_TRADDR__TRADDR__WRITE(usb_ss_ep->trb_pool_dma)); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__DRDY__MASK); /* DRDY */ + return 0; +} + +/** + * cdns_get_setup_ret - Returns status of handling setup packet + * Setup is handled by gadget driver + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns zero on success or negative value on failure + */ +static int cdns_get_setup_ret(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + int ret; + + spin_unlock(&usb_ss->lock); + usb_ss->setup_pending = 1; + ret = usb_ss->gadget_driver->setup(&usb_ss->gadget, ctrl_req); + usb_ss->setup_pending = 0; + spin_lock(&usb_ss->lock); + return ret; +} + +static void cdns_prepare_setup_packet(struct usb_ss_dev *usb_ss) +{ + usb_ss->ep0_data_dir = 0; + cdns_ep0_run_transfer(usb_ss, usb_ss->setup_dma, 8, 0); +} + +/** + * cdns_req_ep0_set_address - Handling of SET_ADDRESS standard USB request + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns_req_ep0_set_address(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + enum usb_device_state device_state = usb_ss->gadget.state; + u32 reg; + u32 addr; + + addr = le16_to_cpu(ctrl_req->wValue); + + if (addr > DEVICE_ADDRESS_MAX) { + dev_err(&usb_ss->dev, + "Device address (%d) cannot be greater than %d\n", + addr, DEVICE_ADDRESS_MAX); + return -EINVAL; + } + + if (device_state == USB_STATE_CONFIGURED) { + dev_err(&usb_ss->dev, "USB device already configured\n"); + return -EINVAL; + } + + reg = gadget_readl(usb_ss, &usb_ss->regs->usb_cmd); + + gadget_writel(usb_ss, &usb_ss->regs->usb_cmd, reg + | USB_CMD__FADDR__WRITE(addr) + | USB_CMD__SET_ADDR__MASK); + + usb_gadget_set_state(&usb_ss->gadget, + (addr ? USB_STATE_ADDRESS : USB_STATE_DEFAULT)); + + cdns_prepare_setup_packet(usb_ss); + + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK | EP_CMD__REQ_CMPL__MASK); + return 0; +} + +/** + * cdns_req_ep0_get_status - Handling of GET_STATUS standard USB request + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns_req_ep0_get_status(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + u16 usb_status = 0; + unsigned int length = 2; + u32 recip = ctrl_req->bRequestType & USB_RECIP_MASK; + u32 reg; + + switch (recip) { + case USB_RECIP_DEVICE: + reg = gadget_readl(usb_ss, &usb_ss->regs->usb_sts); + + if (reg & USB_STS__U1ENS__MASK) + usb_status |= 1uL << USB_DEV_STAT_U1_ENABLED; + + if (reg & USB_STS__U2ENS__MASK) + usb_status |= 1uL << USB_DEV_STAT_U2_ENABLED; + + if (usb_ss->wake_up_flag) + usb_status |= 1uL << USB_DEVICE_REMOTE_WAKEUP; + + /* self powered */ + usb_status |= 1uL << USB_DEVICE_SELF_POWERED; + break; + + case USB_RECIP_INTERFACE: + return cdns_get_setup_ret(usb_ss, ctrl_req); + + case USB_RECIP_ENDPOINT: + /* check if endpoint is stalled */ + select_ep(usb_ss, ctrl_req->wIndex); + if (gadget_readl(usb_ss, &usb_ss->regs->ep_sts) + & EP_STS__STALL__MASK) + usb_status = 1; + break; + + default: + return -EINVAL; + } + + *(u16 *)usb_ss->setup = cpu_to_le16(usb_status); + + usb_ss->actual_ep0_request = NULL; + cdns_ep0_run_transfer(usb_ss, usb_ss->setup_dma, length, 1); + return 0; +} + +/** + * cdns_req_ep0_handle_feature - + * Handling of GET/SET_FEATURE standard USB request + * + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * @set: must be set to 1 for SET_FEATURE request + * + * Returns 0 if success, error code on error + */ +static int cdns_req_ep0_handle_feature(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req, + int set) +{ + u32 recip = ctrl_req->bRequestType & USB_RECIP_MASK; + struct usb_ss_endpoint *usb_ss_ep; + u32 reg; + u8 tmode = 0; + + switch (recip) { + case USB_RECIP_DEVICE: + + switch (ctrl_req->wValue) { + case USB_DEVICE_U1_ENABLE: + if (usb_ss->gadget.state != USB_STATE_CONFIGURED) + return -EINVAL; + if (usb_ss->gadget.speed != USB_SPEED_SUPER) + return -EINVAL; + + reg = gadget_readl(usb_ss, &usb_ss->regs->usb_conf); + if (set) + /* set U1EN */ + reg |= USB_CONF__U1EN__MASK; + else + /* set U1 disable */ + reg |= USB_CONF__U1DS__MASK; + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, reg); + break; + + case USB_DEVICE_U2_ENABLE: + if (usb_ss->gadget.state != USB_STATE_CONFIGURED) + return -EINVAL; + if (usb_ss->gadget.speed != USB_SPEED_SUPER) + return -EINVAL; + + reg = gadget_readl(usb_ss, &usb_ss->regs->usb_conf); + if (set) + /* set U2EN */ + reg |= USB_CONF__U2EN__MASK; + else + /* set U2 disable */ + reg |= USB_CONF__U2DS__MASK; + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, reg); + break; + + case USB_DEVICE_A_ALT_HNP_SUPPORT: + break; + + case USB_DEVICE_A_HNP_SUPPORT: + break; + + case USB_DEVICE_B_HNP_ENABLE: + if (!usb_ss->gadget.b_hnp_enable && set) + usb_ss->gadget.b_hnp_enable = 1; + break; + + case USB_DEVICE_REMOTE_WAKEUP: + usb_ss->wake_up_flag = !!set; + break; + + case USB_DEVICE_TEST_MODE: + if (usb_ss->gadget.state != USB_STATE_CONFIGURED) + return -EINVAL; + if (usb_ss->gadget.speed != USB_SPEED_HIGH && + usb_ss->gadget.speed != USB_SPEED_FULL) + return -EINVAL; + if (ctrl_req->wLength != 0 || + ctrl_req->bRequestType & USB_DIR_IN) { + dev_err(&usb_ss->dev, "req is error\n"); + return -EINVAL; + } + tmode = le16_to_cpu(ctrl_req->wIndex) >> 8; + switch (tmode) { + case TEST_J: + case TEST_K: + case TEST_SE0_NAK: + case TEST_PACKET: + reg = gadget_readl(usb_ss, + &usb_ss->regs->usb_cmd); + tmode -= 1; + reg |= USB_CMD__STMODE | + USB_CMD__TMODE_SEL(tmode); + gadget_writel(usb_ss, &usb_ss->regs->usb_cmd, + reg); + dev_info(&usb_ss->dev, + "set test mode, val=0x%x", reg); + break; + default: + return -EINVAL; + } + break; + + default: + return -EINVAL; + } + break; + + case USB_RECIP_INTERFACE: + return cdns_get_setup_ret(usb_ss, ctrl_req); + + case USB_RECIP_ENDPOINT: + select_ep(usb_ss, ctrl_req->wIndex); + u8 ep_index = CAST_EP_ADDR_TO_INDEX(ctrl_req->wIndex); + + if (set) { + /* set stall */ + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__SSTALL__MASK); + + /* handle non zero endpoint software endpoint */ + if (ctrl_req->wIndex & 0x7F) { + usb_ss_ep = usb_ss->eps[ep_index]; + usb_ss_ep->stalled_flag = 1; + } + } else { + struct usb_request *request; + + if (ctrl_req->wIndex & 0x7F) { + if (usb_ss->eps[ep_index]->wedge_flag) + goto jmp_wedge; + } + + /* clear stall */ + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__CSTALL__MASK | + EP_CMD__EPRST__MASK); + /* wait for EPRST cleared */ + while (gadget_readl(usb_ss, &usb_ss->regs->ep_cmd) + & EP_CMD__EPRST__MASK) + ; + + /* handle non zero endpoint software endpoint */ + if (ctrl_req->wIndex & 0x7F) { + usb_ss_ep = usb_ss->eps[ep_index]; + usb_ss_ep->stalled_flag = 0; + + request = + next_request(&usb_ss_ep->request_list); + if (request) + cdns_ep_run_transfer(usb_ss_ep); + } + } +jmp_wedge: + select_ep(usb_ss, 0x00); + break; + + default: + return -EINVAL; + } + + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK | EP_CMD__REQ_CMPL__MASK); + + return 0; +} + +/** + * cdns_req_ep0_set_sel - Handling of SET_SEL standard USB request + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns_req_ep0_set_sel(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + if (usb_ss->gadget.state < USB_STATE_ADDRESS) + return -EINVAL; + + if (ctrl_req->wLength != 6) { + dev_err(&usb_ss->dev, "Set SEL should be 6 bytes, got %d\n", + ctrl_req->wLength); + return -EINVAL; + } + + usb_ss->ep0_data_dir = 0; + usb_ss->actual_ep0_request = NULL; + cdns_ep0_run_transfer(usb_ss, usb_ss->setup_dma, 6, 1); + + return 0; +} + +/** + * cdns_req_ep0_set_isoch_delay - + * Handling of GET_ISOCH_DELAY standard USB request + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns_req_ep0_set_isoch_delay(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + if (ctrl_req->wIndex || ctrl_req->wLength) + return -EINVAL; + + usb_ss->isoch_delay = ctrl_req->wValue; + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK | EP_CMD__REQ_CMPL__MASK); + return 0; +} + +/** + * cdns_req_ep0_set_configuration - Handling of SET_CONFIG standard USB request + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, 0x7FFF on deferred status stage, error code on error + */ +static int cdns_req_ep0_set_configuration(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + enum usb_device_state device_state = usb_ss->gadget.state; + u32 config = le16_to_cpu(ctrl_req->wValue); + struct usb_ep *ep; + struct usb_ss_endpoint *usb_ss_ep, *temp_ss_ep; + int i, result = 0; + + switch (device_state) { + case USB_STATE_ADDRESS: + /* Configure non-control EPs */ + list_for_each_entry_safe(usb_ss_ep, temp_ss_ep, + &usb_ss->ep_match_list, + ep_match_pending_list) { + cdns_ep_config(usb_ss_ep); + list_del(&usb_ss_ep->ep_match_pending_list); + } + + list_for_each_entry(ep, &usb_ss->gadget.ep_list, ep_list) { + usb_ss_ep = to_usb_ss_ep(ep); + if (usb_ss_ep->used) + cdns_ep_config(usb_ss_ep); + } + +#ifdef CDNS_THREADED_IRQ_HANDLING + usb_ss->ep_ien = gadget_readl(usb_ss, &usb_ss->regs->ep_ien) + | EP_IEN__EOUTEN0__MASK | EP_IEN__EINEN0__MASK; +#endif + result = cdns_get_setup_ret(usb_ss, ctrl_req); + + if (result != 0) + return result; + + if (config) { + if (!usb_ss->hw_configured_flag) { + /* SET CONFIGURATION */ + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__CFGSET__MASK); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK | + EP_CMD__REQ_CMPL__MASK); + /* wait until configuration set */ + while (!(gadget_readl(usb_ss, + &usb_ss->regs->usb_sts) + & USB_STS__CFGSTS__MASK)) + ; + usb_ss->hw_configured_flag = 1; + + list_for_each_entry(ep, &usb_ss->gadget.ep_list, + ep_list) { + usb_ss_ep = to_usb_ss_ep(ep); + if (usb_ss_ep->enabled) + cdns_ep_run_transfer(usb_ss_ep); + } + } + + usb_gadget_set_state(&usb_ss->gadget, + USB_STATE_CONFIGURED); + + } else { + cdns_gadget_unconfig(usb_ss); + for (i = 0; i < usb_ss->ep_nums; i++) + usb_ss->eps[i]->enabled = 0; + usb_gadget_set_state(&usb_ss->gadget, + USB_STATE_ADDRESS); + } + break; + + case USB_STATE_CONFIGURED: + result = cdns_get_setup_ret(usb_ss, ctrl_req); + if (!config && !result) { + cdns_gadget_unconfig(usb_ss); + for (i = 0; i < usb_ss->ep_nums; i++) + usb_ss->eps[i]->enabled = 0; + usb_gadget_set_state(&usb_ss->gadget, + USB_STATE_ADDRESS); + } + break; + + default: + result = -EINVAL; + } + + return result; +} + +/** + * cdns_ep0_standard_request - Handling standard USB requests + * @usb_ss: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns_ep0_standard_request(struct usb_ss_dev *usb_ss, + struct usb_ctrlrequest *ctrl_req) +{ + switch (ctrl_req->bRequest) { + case USB_REQ_SET_ADDRESS: + return cdns_req_ep0_set_address(usb_ss, ctrl_req); + case USB_REQ_SET_CONFIGURATION: + return cdns_req_ep0_set_configuration(usb_ss, ctrl_req); + case USB_REQ_GET_STATUS: + return cdns_req_ep0_get_status(usb_ss, ctrl_req); + case USB_REQ_CLEAR_FEATURE: + return cdns_req_ep0_handle_feature(usb_ss, ctrl_req, 0); + case USB_REQ_SET_FEATURE: + return cdns_req_ep0_handle_feature(usb_ss, ctrl_req, 1); + case USB_REQ_SET_SEL: + return cdns_req_ep0_set_sel(usb_ss, ctrl_req); + case USB_REQ_SET_ISOCH_DELAY: + return cdns_req_ep0_set_isoch_delay(usb_ss, ctrl_req); + default: + return cdns_get_setup_ret(usb_ss, ctrl_req); + } +} + +/** + * cdns_ep0_setup_phase - Handling setup USB requests + * @usb_ss: extended gadget object + */ +static void cdns_ep0_setup_phase(struct usb_ss_dev *usb_ss) +{ + int result; + struct usb_ctrlrequest *ctrl_req = + (struct usb_ctrlrequest *)usb_ss->setup; + + if ((ctrl_req->bRequestType & USB_TYPE_MASK) == USB_TYPE_STANDARD) + result = cdns_ep0_standard_request(usb_ss, ctrl_req); + else + result = cdns_get_setup_ret(usb_ss, ctrl_req); + + if (result != 0 && result != USB_GADGET_DELAYED_STATUS) { + dev_dbg(&usb_ss->dev, "STALL(00) %d\n", result); + + /* set_stall on ep0 */ + select_ep(usb_ss, 0x00); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__SSTALL__MASK); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK | EP_CMD__REQ_CMPL__MASK); + return; + } +} + +/** + * cdns_check_ep_interrupt_proceed - Processes interrupt related to endpoint + * @usb_ss_ep: extended endpoint object + * + * Returns 0 + */ +static int cdns_check_ep_interrupt_proceed(struct usb_ss_endpoint *usb_ss_ep) +{ + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + struct usb_request *request; + u32 ep_sts_reg; + + select_ep(usb_ss, usb_ss_ep->address); + ep_sts_reg = gadget_readl(usb_ss, &usb_ss->regs->ep_sts); + + dev_dbg(&usb_ss->dev, "EP_STS: %08X\n", ep_sts_reg); + + if (ep_sts_reg & EP_STS__TRBERR__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__TRBERR__MASK); + + dev_dbg(&usb_ss->dev, "TRBERR(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + } + + if (ep_sts_reg & EP_STS__ISOERR__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__ISOERR__MASK); + dev_dbg(&usb_ss->dev, "ISOERR(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + } + + if (ep_sts_reg & EP_STS__OUTSMM__MASK) { + gadget_writel(usb_ss, &usb_ss->regs->ep_sts, + EP_STS__OUTSMM__MASK); + dev_dbg(&usb_ss->dev, "OUTSMM(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + } + + if (ep_sts_reg & EP_STS__NRDY__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__NRDY__MASK); + dev_dbg(&usb_ss->dev, "NRDY(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + } + + if ((ep_sts_reg & EP_STS__IOC__MASK) || + (ep_sts_reg & EP_STS__ISP__MASK)) { + u8 ep_dir; + + cdns_flush_cache((uintptr_t)usb_ss_ep->trb_pool, + sizeof(struct usb_ss_trb)); + + gadget_writel(usb_ss, &usb_ss->regs->ep_sts, + EP_STS__IOC__MASK | EP_STS__ISP__MASK); + + /* get just completed request */ + request = next_request(&usb_ss_ep->request_list); + ep_dir = usb_ss_ep->endpoint.desc->bEndpointAddress; + usb_gadget_unmap_request(&usb_ss->gadget, request, + ep_dir & ENDPOINT_DIR_MASK); + + request->status = 0; + request->actual = + le32_to_cpu(((u32 *)usb_ss_ep->trb_pool)[1]) + & ACTUAL_TRANSFERRED_BYTES_MASK; + + dev_dbg(&usb_ss->dev, "IOC(%02X) %d\n", + usb_ss_ep->endpoint.desc->bEndpointAddress, + request->actual); + + list_del(&request->list); + + usb_ss_ep->hw_pending_flag = 0; + if (request->complete) { + spin_unlock(&usb_ss->lock); + usb_gadget_giveback_request(&usb_ss_ep->endpoint, + request); + spin_lock(&usb_ss->lock); + } + + /* handle deferred STALL */ + if (usb_ss_ep->stalled_flag) { + cdns_ep_stall_flush(usb_ss_ep); + return 0; + } + + /* exit if hardware transfer already started */ + if (usb_ss_ep->hw_pending_flag) + return 0; + + /* if any request queued run it! */ + if (!list_empty(&usb_ss_ep->request_list)) + cdns_ep_run_transfer(usb_ss_ep); + } + + if (ep_sts_reg & EP_STS__DESCMIS__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__DESCMIS__MASK); + dev_dbg(&usb_ss->dev, "DESCMIS(%02X)\n", + usb_ss_ep->endpoint.desc->bEndpointAddress); + } + + return 0; +} + +/** + * cdns_check_ep0_interrupt_proceed - Processes interrupt related to endpoint 0 + * @usb_ss: extended gadget object + * @dir: 1 for IN direction, 0 for OUT direction + */ +static void cdns_check_ep0_interrupt_proceed(struct usb_ss_dev *usb_ss, int dir) +{ + u32 ep_sts_reg; + int i; + + select_ep(usb_ss, 0 | (dir ? USB_DIR_IN : USB_DIR_OUT)); + ep_sts_reg = gadget_readl(usb_ss, &usb_ss->regs->ep_sts); + + dev_dbg(&usb_ss->dev, "EP_STS: %08X\n", ep_sts_reg); + + if ((ep_sts_reg & EP_STS__SETUP__MASK) && dir == 0) { + cdns_flush_cache((uintptr_t)usb_ss->setup, 8); + + dev_dbg(&usb_ss->dev, "SETUP(%02X)\n", 0x00); + + gadget_writel(usb_ss, &usb_ss->regs->ep_sts, + EP_STS__SETUP__MASK | + EP_STS__IOC__MASK | EP_STS__ISP__MASK); + + dev_dbg(&usb_ss->dev, "SETUP: "); + for (i = 0; i < 8; i++) + dev_dbg(&usb_ss->dev, "%02X ", usb_ss->setup[i]); + dev_dbg(&usb_ss->dev, "\nSTATE: %d\n", usb_ss->gadget.state); + usb_ss->ep0_data_dir = usb_ss->setup[0] & USB_DIR_IN; + cdns_ep0_setup_phase(usb_ss); + ep_sts_reg &= ~(EP_STS__SETUP__MASK | + EP_STS__IOC__MASK | + EP_STS__ISP__MASK); + } + + if (ep_sts_reg & EP_STS__TRBERR__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__TRBERR__MASK); + dev_dbg(&usb_ss->dev, "TRBERR(%02X)\n", + dir ? USB_DIR_IN : USB_DIR_OUT); + } + + if (ep_sts_reg & EP_STS__DESCMIS__MASK) { + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__DESCMIS__MASK); + + dev_dbg(&usb_ss->dev, "DESCMIS(%02X)\n", + dir ? USB_DIR_IN : USB_DIR_OUT); + + if (dir == 0 && !usb_ss->setup_pending) { + usb_ss->ep0_data_dir = 0; + cdns_ep0_run_transfer(usb_ss, + usb_ss->setup_dma, 8, 0); + } + } + + if ((ep_sts_reg & EP_STS__IOC__MASK) || + (ep_sts_reg & EP_STS__ISP__MASK)) { + cdns_flush_cache((uintptr_t)usb_ss->trb_ep0, 20); + + gadget_writel(usb_ss, + &usb_ss->regs->ep_sts, EP_STS__IOC__MASK); + if (usb_ss->actual_ep0_request) { + usb_gadget_unmap_request(&usb_ss->gadget, + usb_ss->actual_ep0_request, + usb_ss->ep0_data_dir); + + usb_ss->actual_ep0_request->actual = + le32_to_cpu((usb_ss->trb_ep0)[1]) + & ACTUAL_TRANSFERRED_BYTES_MASK; + + dev_dbg(&usb_ss->dev, "IOC(%02X) %d\n", + dir ? USB_DIR_IN : USB_DIR_OUT, + usb_ss->actual_ep0_request->actual); + list_del_init(&usb_ss->actual_ep0_request->list); + } + + if (usb_ss->actual_ep0_request && + usb_ss->actual_ep0_request->complete) { + spin_unlock(&usb_ss->lock); + usb_ss->actual_ep0_request->complete(usb_ss->gadget.ep0, + usb_ss->actual_ep0_request); + spin_lock(&usb_ss->lock); + } + cdns_prepare_setup_packet(usb_ss); + gadget_writel(usb_ss, + &usb_ss->regs->ep_cmd, EP_CMD__REQ_CMPL__MASK); + } +} + +/** + * cdns_check_usb_interrupt_proceed - Processes interrupt related to device + * @usb_ss: extended gadget object + * @usb_ists: bitmap representation of device's reported interrupts + * (usb_ists register value) + */ +static void cdns_check_usb_interrupt_proceed(struct usb_ss_dev *usb_ss, + u32 usb_ists) +{ + int interrupt_bit = ffs(usb_ists) - 1; + int speed; + u32 val; + + dev_dbg(&usb_ss->dev, "USB interrupt detected\n"); + + switch (interrupt_bit) { + case USB_ISTS__CON2I__SHIFT: + /* FS/HS Connection detected */ + dev_dbg(&usb_ss->dev, + "[Interrupt] FS/HS Connection detected\n"); + val = gadget_readl(usb_ss, &usb_ss->regs->usb_sts); + speed = USB_STS__USBSPEED__READ(val); + if (speed == USB_SPEED_WIRELESS) + speed = USB_SPEED_SUPER; + dev_dbg(&usb_ss->dev, "Speed value: %s (%d), usbsts:0x%x\n", + usb_speed_string(speed), speed, val); + usb_ss->gadget.speed = speed; + usb_ss->is_connected = 1; + usb_gadget_set_state(&usb_ss->gadget, USB_STATE_POWERED); + cdns_ep0_config(usb_ss); + break; + + case USB_ISTS__CONI__SHIFT: + /* SS Connection detected */ + dev_dbg(&usb_ss->dev, "[Interrupt] SS Connection detected\n"); + val = gadget_readl(usb_ss, &usb_ss->regs->usb_sts); + speed = USB_STS__USBSPEED__READ(val); + if (speed == USB_SPEED_WIRELESS) + speed = USB_SPEED_SUPER; + dev_dbg(&usb_ss->dev, "Speed value: %s (%d), usbsts:0x%x\n", + usb_speed_string(speed), speed, val); + usb_ss->gadget.speed = speed; + usb_ss->is_connected = 1; + usb_gadget_set_state(&usb_ss->gadget, USB_STATE_POWERED); + cdns_ep0_config(usb_ss); + break; + + case USB_ISTS__DIS2I__SHIFT: + case USB_ISTS__DISI__SHIFT: + /* SS Disconnection detected */ + val = gadget_readl(usb_ss, &usb_ss->regs->usb_sts); + dev_dbg(&usb_ss->dev, + "[Interrupt] Disconnection detected: usbsts:0x%x\n", + val); + if (usb_ss->gadget_driver && + usb_ss->gadget_driver->disconnect) { + spin_unlock(&usb_ss->lock); + usb_ss->gadget_driver->disconnect(&usb_ss->gadget); + spin_lock(&usb_ss->lock); + } + usb_ss->gadget.speed = USB_SPEED_UNKNOWN; + usb_gadget_set_state(&usb_ss->gadget, USB_STATE_NOTATTACHED); + usb_ss->is_connected = 0; + cdns_gadget_unconfig(usb_ss); + break; + + case USB_ISTS__L2ENTI__SHIFT: + dev_dbg(&usb_ss->dev, + "[Interrupt] Device suspended\n"); + break; + + case USB_ISTS__L2EXTI__SHIFT: + dev_dbg(&usb_ss->dev, "[Interrupt] L2 exit detected\n"); + /* + * Exit from standby mode + * on L2 exit (Suspend in HS/FS or SS) + */ + break; + case USB_ISTS__U3EXTI__SHIFT: + /* + * Exit from standby mode + * on U3 exit (Suspend in HS/FS or SS) + */ + dev_dbg(&usb_ss->dev, "[Interrupt] U3 exit detected\n"); + break; + + /* resets cases */ + case USB_ISTS__UWRESI__SHIFT: + case USB_ISTS__UHRESI__SHIFT: + case USB_ISTS__U2RESI__SHIFT: + dev_dbg(&usb_ss->dev, "[Interrupt] Reset detected\n"); + val = gadget_readl(usb_ss, &usb_ss->regs->usb_sts); + speed = USB_STS__USBSPEED__READ(val); + if (speed == USB_SPEED_WIRELESS) + speed = USB_SPEED_SUPER; + usb_gadget_set_state(&usb_ss->gadget, USB_STATE_DEFAULT); + usb_ss->gadget.speed = speed; + cdns_gadget_unconfig(usb_ss); + cdns_ep0_config(usb_ss); + break; + default: + break; + } + + /* Clear interrupt bit */ + gadget_writel(usb_ss, &usb_ss->regs->usb_ists, (1uL << interrupt_bit)); +} + +#ifdef CDNS_THREADED_IRQ_HANDLING +static irqreturn_t cdns_irq_handler(int irq, void *_usb_ss) +{ + struct usb_ss_dev *usb_ss = _usb_ss; + + usb_ss->usb_ien = gadget_readl(usb_ss, &usb_ss->regs->usb_ien); + usb_ss->ep_ien = gadget_readl(usb_ss, &usb_ss->regs->ep_ien); + + if (!gadget_readl(usb_ss, &usb_ss->regs->usb_ists) && + !gadget_readl(usb_ss, &usb_ss->regs->ep_ists)) { + dev_dbg(&usb_ss->dev, "--BUBBLE INTERRUPT 0 !!!\n"); + if (gadget_readl(usb_ss, &usb_ss->regs->usb_sts) & + USB_STS__CFGSTS__MASK) + return IRQ_HANDLED; + return IRQ_NONE; + } + + gadget_writel(usb_ss, &usb_ss->regs->usb_ien, 0); + gadget_writel(usb_ss, &usb_ss->regs->ep_ien, 0); + + gadget_readl(usb_ss, &usb_ss->regs->dma_axi_ctrl); + return IRQ_WAKE_THREAD; +} +#endif + +/** + * cdns_irq_handler - irq line interrupt handler + * @cdns: cdns3 instance + * + * Returns IRQ_HANDLED when interrupt raised by USBSS_DEV, + * IRQ_NONE when interrupt raised by other device connected + * to the irq line + */ +static int cdns_irq_handler_thread(struct cdns3 *cdns) +{ + struct usb_ss_dev *usb_ss = + container_of(cdns->gadget_dev, struct usb_ss_dev, dev); + u32 reg; + int ret = IRQ_NONE; + unsigned long flags; + + spin_lock_irqsave(&usb_ss->lock, flags); + + /* check USB device interrupt */ + reg = gadget_readl(usb_ss, &usb_ss->regs->usb_ists); + if (reg) { + dev_dbg(&usb_ss->dev, "usb_ists: %08X\n", reg); + cdns_check_usb_interrupt_proceed(usb_ss, reg); + ret = IRQ_HANDLED; + } + + /* check endpoint interrupt */ + reg = gadget_readl(usb_ss, &usb_ss->regs->ep_ists); + if (reg != 0) { + dev_dbg(&usb_ss->dev, "ep_ists: %08X\n", reg); + } else { + if (gadget_readl(usb_ss, &usb_ss->regs->usb_sts) & + USB_STS__CFGSTS__MASK) + ret = IRQ_HANDLED; + goto irqend; + } + + /* handle default endpoint OUT */ + if (reg & EP_ISTS__EOUT0__MASK) { + cdns_check_ep0_interrupt_proceed(usb_ss, 0); + ret = IRQ_HANDLED; + } + + /* handle default endpoint IN */ + if (reg & EP_ISTS__EIN0__MASK) { + cdns_check_ep0_interrupt_proceed(usb_ss, 1); + ret = IRQ_HANDLED; + } + + /* check if interrupt from non default endpoint, if no exit */ + reg &= ~(EP_ISTS__EOUT0__MASK | EP_ISTS__EIN0__MASK); + if (!reg) + goto irqend; + + do { + unsigned int bit_pos = ffs(reg); + u32 bit_mask = 1 << (bit_pos - 1); + u8 ep_index = CAST_EP_REG_POS_TO_INDEX(bit_pos); + + dev_dbg(&usb_ss->dev, "Interrupt on index: %d bitmask %08X\n", + ep_index, bit_mask); + cdns_check_ep_interrupt_proceed(usb_ss->eps[ep_index]); + reg &= ~bit_mask; + ret = IRQ_HANDLED; + } while (reg); + +irqend: + + spin_unlock_irqrestore(&usb_ss->lock, flags); +#ifdef CDNS_THREADED_IRQ_HANDLING + local_irq_save(flags); + gadget_writel(usb_ss, &usb_ss->regs->usb_ien, usb_ss->usb_ien); + gadget_writel(usb_ss, &usb_ss->regs->ep_ien, usb_ss->ep_ien); + local_irq_restore(flags); +#endif + return ret; +} + +/** + * usb_ss_gadget_ep0_enable + * Function shouldn't be called by gadget driver, + * endpoint 0 is allways active + */ +static int usb_ss_gadget_ep0_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + return -EINVAL; +} + +/** + * usb_ss_gadget_ep0_disable + * Function shouldn't be called by gadget driver, + * endpoint 0 is allways active + */ +static int usb_ss_gadget_ep0_disable(struct usb_ep *ep) +{ + return -EINVAL; +} + +/** + * usb_ss_gadget_ep0_set_halt + * @ep: pointer to endpoint zero object + * @value: 1 for set stall, 0 for clear stall + * + * Returns 0 + */ +static int usb_ss_gadget_ep0_set_halt(struct usb_ep *ep, int value) +{ + /* TODO */ + return 0; +} + +/** + * usb_ss_gadget_ep0_queue Transfer data on endpoint zero + * @ep: pointer to endpoint zero object + * @request: pointer to request object + * @gfp_flags: gfp flags + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep0_queue(struct usb_ep *ep, + struct usb_request *request, + gfp_t gfp_flags) +{ + int ret; + unsigned long flags; + int erdy_sent = 0; + /* get extended endpoint */ + struct usb_ss_endpoint *usb_ss_ep = + to_usb_ss_ep(ep); + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + + dev_dbg(&usb_ss->dev, "QUEUE(%02X) %d\n", + usb_ss->ep0_data_dir ? USB_DIR_IN : USB_DIR_OUT, + request->length); + + /* send STATUS stage */ + if (request->length == 0 && request->zero == 0) { + spin_lock_irqsave(&usb_ss->lock, flags); + select_ep(usb_ss, 0x00); + if (!usb_ss->hw_configured_flag) { + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__CFGSET__MASK); + /* SET CONFIGURATION */ + cdns_prepare_setup_packet(usb_ss); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK + | EP_CMD__REQ_CMPL__MASK); + /* wait until configuration set */ + while (!(gadget_readl(usb_ss, &usb_ss->regs->usb_sts) + & USB_STS__CFGSTS__MASK)) + ; + erdy_sent = 1; + usb_ss->hw_configured_flag = 1; + + list_for_each_entry(ep, &usb_ss->gadget.ep_list, + ep_list) { + if (to_usb_ss_ep(ep)->enabled) + cdns_ep_run_transfer(to_usb_ss_ep(ep)); + } + } + if (!erdy_sent) + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__ERDY__MASK + | EP_CMD__REQ_CMPL__MASK); + if (request->complete) + request->complete(usb_ss->gadget.ep0, request); + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + + spin_lock_irqsave(&usb_ss->lock, flags); + ret = usb_gadget_map_request(&usb_ss->gadget, request, + usb_ss->ep0_data_dir); + if (ret) { + dev_err(&usb_ss->dev, "failed to map request\n"); + return -EINVAL; + } + + usb_ss->actual_ep0_request = request; + cdns_ep0_run_transfer(usb_ss, request->dma, request->length, 1); + list_add_tail(&request->list, &usb_ss_ep->request_list); + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return 0; +} + +/** + * cdns_ep_config Configure hardware endpoint + * @usb_ss_ep: extended endpoint object + */ +static void cdns_ep_config(struct usb_ss_endpoint *usb_ss_ep) +{ + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + u32 ep_cfg = 0; + u32 max_packet_size = 0; + u32 bEndpointAddress = usb_ss_ep->num | usb_ss_ep->dir; + u32 interrupt_mask = 0; + bool is_iso_ep = (usb_ss_ep->type == USB_ENDPOINT_XFER_ISOC); + + dev_dbg(&usb_ss->dev, + "%s: %s addr=0x%x, speed %d, is_iso_ep %d\n", __func__, + usb_ss_ep->name, bEndpointAddress, usb_ss->gadget.speed, + is_iso_ep); + + if (is_iso_ep) { + ep_cfg = EP_CFG__EPTYPE__WRITE(USB_ENDPOINT_XFER_ISOC); + interrupt_mask = INTERRUPT_MASK; + } else { + ep_cfg = EP_CFG__EPTYPE__WRITE(USB_ENDPOINT_XFER_BULK); + } + + switch (usb_ss->gadget.speed) { + case USB_SPEED_UNKNOWN: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_0; + break; + + case USB_SPEED_LOW: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_8; + break; + + case USB_SPEED_FULL: + max_packet_size = (is_iso_ep ? + ENDPOINT_MAX_PACKET_SIZE_1023 : + ENDPOINT_MAX_PACKET_SIZE_64); + break; + + case USB_SPEED_HIGH: + max_packet_size = (is_iso_ep ? + ENDPOINT_MAX_PACKET_SIZE_1024 : + ENDPOINT_MAX_PACKET_SIZE_512); + break; + + case USB_SPEED_WIRELESS: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_512; + break; + + case USB_SPEED_SUPER: + max_packet_size = ENDPOINT_MAX_PACKET_SIZE_1024; + break; + } + + ep_cfg |= EP_CFG__MAXPKTSIZE__WRITE(max_packet_size); + + if (is_iso_ep) { + ep_cfg |= EP_CFG__BUFFERING__WRITE(1); + ep_cfg |= EP_CFG__MAXBURST__WRITE(0); + } else { + ep_cfg |= EP_CFG__BUFFERING__WRITE(3); + ep_cfg |= EP_CFG__MAXBURST__WRITE(15); + } + + select_ep(usb_ss, bEndpointAddress); + gadget_writel(usb_ss, &usb_ss->regs->ep_cfg, ep_cfg); + gadget_writel(usb_ss, &usb_ss->regs->ep_sts_en, + EP_STS_EN__TRBERREN__MASK | interrupt_mask); + + /* enable interrupt for selected endpoint */ + ep_cfg = gadget_readl(usb_ss, &usb_ss->regs->ep_ien); + ep_cfg |= CAST_EP_ADDR_TO_BIT_POS(bEndpointAddress); + gadget_writel(usb_ss, &usb_ss->regs->ep_ien, ep_cfg); +} + +/** + * usb_ss_gadget_ep_enable Enable endpoint + * @ep: endpoint object + * @desc: endpoint descriptor + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + struct usb_ss_endpoint *usb_ss_ep; + struct usb_ss_dev *usb_ss; + unsigned long flags; + unsigned long *dma_addr; + int ret; + u32 ep_cfg; + + usb_ss_ep = to_usb_ss_ep(ep); + usb_ss = usb_ss_ep->usb_ss; + + if (!ep || !desc || desc->bDescriptorType != USB_DT_ENDPOINT) { + dev_err(&usb_ss->dev, "usb-ss: invalid parameters\n"); + return -EINVAL; + } + + if (!desc->wMaxPacketSize) { + dev_err(&usb_ss->dev, "usb-ss: missing wMaxPacketSize\n"); + return -EINVAL; + } + + ret = usb_ss_allocate_trb_pool(usb_ss_ep); + if (ret) + return ret; + + if (!usb_ss_ep->cpu_addr) { + dma_addr = (unsigned long *)&usb_ss_ep->dma_addr; + usb_ss_ep->cpu_addr = dma_alloc_coherent(4096, dma_addr); + + if (!usb_ss_ep->cpu_addr) + return -ENOMEM; + } + + dev_dbg(&usb_ss->dev, "Enabling endpoint: %s, addr=0x%x\n", + ep->name, desc->bEndpointAddress); + spin_lock_irqsave(&usb_ss->lock, flags); + select_ep(usb_ss, desc->bEndpointAddress); + ep_cfg = gadget_readl(usb_ss, &usb_ss->regs->ep_cfg); + ep_cfg |= EP_CFG__ENABLE__MASK; + gadget_writel(usb_ss, &usb_ss->regs->ep_cfg, ep_cfg); + + usb_ss_ep->enabled = 1; + ep->desc = desc; + usb_ss_ep->hw_pending_flag = 0; + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return 0; +} + +static int usb_ss_gadget_match_ep(struct usb_gadget *gadget, + struct usb_ep *ep, + struct usb_endpoint_descriptor *desc) +{ + struct usb_ss_dev __maybe_unused *usb_ss = gadget_to_usb_ss(gadget); + struct usb_ss_endpoint *usb_ss_ep; + unsigned long flags; + + usb_ss_ep = to_usb_ss_ep(ep); + + dev_dbg(&usb_ss->dev, "match endpoint: %s\n", usb_ss_ep->name); + + u8 num = simple_strtoul(&ep->name[2], NULL, 10); + + spin_lock_irqsave(&usb_ss->lock, flags); + usb_ss_ep->num = num; + usb_ss_ep->used = true; + usb_ss_ep->endpoint.desc = desc; + usb_ss_ep->dir = usb_endpoint_dir_in(desc) ? USB_DIR_IN : USB_DIR_OUT; + usb_ss_ep->type = usb_endpoint_type(desc); + usb_ss_ep->address = desc->bEndpointAddress; + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return 1; +} + +static void usb_ss_free_trb_pool(struct usb_ss_endpoint *usb_ss_ep) +{ + if (usb_ss_ep->trb_pool) { + dma_free_coherent(usb_ss_ep->trb_pool); + usb_ss_ep->trb_pool = NULL; + } + + if (usb_ss_ep->cpu_addr) { + dma_free_coherent(usb_ss_ep->cpu_addr); + usb_ss_ep->cpu_addr = NULL; + } +} + +/** + * usb_ss_gadget_ep_disable Disable endpoint + * @ep: endpoint object + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep_disable(struct usb_ep *ep) +{ + struct usb_ss_endpoint *usb_ss_ep; + struct usb_ss_dev *usb_ss; + unsigned long flags; + int ret = 0; + struct usb_request *request; + u32 ep_cfg; + + if (!ep) { + pr_debug("usb-ss: invalid parameters\n"); + return -EINVAL; + } + + usb_ss_ep = to_usb_ss_ep(ep); + usb_ss = usb_ss_ep->usb_ss; + + spin_lock_irqsave(&usb_ss->lock, flags); + if (!usb_ss->start_gadget) { + dev_dbg(&usb_ss->dev, + "Disabling endpoint at disconnection: %s\n", ep->name); + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + + dev_dbg(&usb_ss->dev, + "Disabling endpoint: %s\n", ep->name); + + while (!list_empty(&usb_ss_ep->request_list)) { + request = next_request(&usb_ss_ep->request_list); + usb_gadget_unmap_request(&usb_ss->gadget, request, + ep->desc->bEndpointAddress & + USB_DIR_IN); + request->status = -ESHUTDOWN; + list_del(&request->list); + spin_unlock(&usb_ss->lock); + usb_gadget_giveback_request(ep, request); + spin_lock(&usb_ss->lock); + } + + select_ep(usb_ss, ep->desc->bEndpointAddress); + ep_cfg = gadget_readl(usb_ss, &usb_ss->regs->ep_cfg); + ep_cfg &= ~EP_CFG__ENABLE__MASK; + gadget_writel(usb_ss, &usb_ss->regs->ep_cfg, ep_cfg); + ep->desc = NULL; + usb_ss_ep->enabled = 0; + + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return ret; +} + +/** + * usb_ss_gadget_ep_alloc_request Allocates request + * @ep: endpoint object associated with request + * @gfp_flags: gfp flags + * + * Returns allocated request address, NULL on allocation error + */ +static struct usb_request *usb_ss_gadget_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags) +{ + struct usb_request *request; + + request = kzalloc(sizeof(*request), gfp_flags); + if (!request) + return NULL; + + return request; +} + +/** + * usb_ss_gadget_ep_free_request Free memory occupied by request + * @ep: endpoint object associated with request + * @request: request to free memory + */ +static void usb_ss_gadget_ep_free_request(struct usb_ep *ep, + struct usb_request *request) +{ + kfree(request); +} + +/** + * usb_ss_gadget_ep_queue Transfer data on endpoint + * @ep: endpoint object + * @request: request object + * @gfp_flags: gfp flags + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep_queue(struct usb_ep *ep, + struct usb_request *request, gfp_t gfp_flags) +{ + struct usb_ss_endpoint *usb_ss_ep = + to_usb_ss_ep(ep); + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + unsigned long flags; + int ret = 0; + int empty_list = 0; + + spin_lock_irqsave(&usb_ss->lock, flags); + + request->actual = 0; + request->status = -EINPROGRESS; + + dev_dbg(&usb_ss->dev, + "Queuing endpoint: %s\n", usb_ss_ep->name); + + dev_dbg(&usb_ss->dev, "QUEUE(%02X) %d\n", + ep->desc->bEndpointAddress, request->length); + + ret = usb_gadget_map_request(&usb_ss->gadget, request, + ep->desc->bEndpointAddress & USB_DIR_IN); + + if (ret) { + spin_unlock_irqrestore(&usb_ss->lock, flags); + return ret; + } + + empty_list = list_empty(&usb_ss_ep->request_list); + list_add_tail(&request->list, &usb_ss_ep->request_list); + + if (!usb_ss->hw_configured_flag) { + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + + if (empty_list) { + if (!usb_ss_ep->stalled_flag) + cdns_ep_run_transfer(usb_ss_ep); + } + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return ret; +} + +/** + * usb_ss_gadget_ep_dequeue Remove request from transfer queue + * @ep: endpoint object associated with request + * @request: request object + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep_dequeue(struct usb_ep *ep, + struct usb_request *request) +{ + struct usb_ss_endpoint *usb_ss_ep = + to_usb_ss_ep(ep); + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + struct usb_request *req, *req_temp; + unsigned long flags; + + spin_lock_irqsave(&usb_ss->lock, flags); + if (!usb_ss->start_gadget) { + dev_dbg(&usb_ss->dev, + "DEQUEUE at disconnection: %s\n", ep->name); + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + dev_dbg(&usb_ss->dev, "DEQUEUE(%02X) %d\n", + usb_ss_ep->address, request->length); + + list_for_each_entry_safe(req, req_temp, + &usb_ss_ep->request_list, list) { + if (request == req) { + request->status = -ECONNRESET; + usb_gadget_unmap_request(&usb_ss->gadget, request, + usb_ss_ep->address & + USB_DIR_IN); + list_del_init(&request->list); + if (request->complete) { + spin_unlock(&usb_ss->lock); + usb_gadget_giveback_request + (&usb_ss_ep->endpoint, request); + spin_lock(&usb_ss->lock); + } + break; + } + } + + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; +} + +/** + * usb_ss_gadget_ep_set_halt Sets/clears stall on selected endpoint + * @ep: endpoint object to set/clear stall on + * @value: 1 for set stall, 0 for clear stall + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_ep_set_halt(struct usb_ep *ep, int value) +{ + struct usb_ss_endpoint *usb_ss_ep = + to_usb_ss_ep(ep); + struct usb_ss_dev *usb_ss = usb_ss_ep->usb_ss; + unsigned long flags; + + /* return error when endpoint disabled */ + if (!usb_ss_ep->enabled) + return -EPERM; + + /* if actual transfer is pending defer setting stall on this endpoint */ + if (usb_ss_ep->hw_pending_flag && value) { + usb_ss_ep->stalled_flag = 1; + return 0; + } + + dev_dbg(&usb_ss->dev, "HALT(%02X) %d\n", usb_ss_ep->address, value); + + spin_lock_irqsave(&usb_ss->lock, flags); + + select_ep(usb_ss, ep->desc->bEndpointAddress); + if (value) { + cdns_ep_stall_flush(usb_ss_ep); + } else { + /* + * TODO: + * epp->wedgeFlag = 0; + */ + usb_ss_ep->wedge_flag = 0; + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__CSTALL__MASK | EP_CMD__EPRST__MASK); + /* wait for EPRST cleared */ + while (gadget_readl(usb_ss, &usb_ss->regs->ep_cmd) & + EP_CMD__EPRST__MASK) + ; + usb_ss_ep->stalled_flag = 0; + } + usb_ss_ep->hw_pending_flag = 0; + + spin_unlock_irqrestore(&usb_ss->lock, flags); + + return 0; +} + +/** + * usb_ss_gadget_ep_set_wedge Set wedge on selected endpoint + * @ep: endpoint object + * + * Returns 0 + */ +static int usb_ss_gadget_ep_set_wedge(struct usb_ep *ep) +{ + struct usb_ss_endpoint *usb_ss_ep = to_usb_ss_ep(ep); + struct usb_ss_dev __maybe_unused *usb_ss = usb_ss_ep->usb_ss; + + dev_dbg(&usb_ss->dev, "WEDGE(%02X)\n", usb_ss_ep->address); + usb_ss_gadget_ep_set_halt(ep, 1); + usb_ss_ep->wedge_flag = 1; + return 0; +} + +static const struct usb_ep_ops usb_ss_gadget_ep0_ops = { + .enable = usb_ss_gadget_ep0_enable, + .disable = usb_ss_gadget_ep0_disable, + .alloc_request = usb_ss_gadget_ep_alloc_request, + .free_request = usb_ss_gadget_ep_free_request, + .queue = usb_ss_gadget_ep0_queue, + .dequeue = usb_ss_gadget_ep_dequeue, + .set_halt = usb_ss_gadget_ep0_set_halt, + .set_wedge = usb_ss_gadget_ep_set_wedge, +}; + +static const struct usb_ep_ops usb_ss_gadget_ep_ops = { + .enable = usb_ss_gadget_ep_enable, + .disable = usb_ss_gadget_ep_disable, + .alloc_request = usb_ss_gadget_ep_alloc_request, + .free_request = usb_ss_gadget_ep_free_request, + .queue = usb_ss_gadget_ep_queue, + .dequeue = usb_ss_gadget_ep_dequeue, + .set_halt = usb_ss_gadget_ep_set_halt, + .set_wedge = usb_ss_gadget_ep_set_wedge, +}; + +/** + * usb_ss_gadget_get_frame Returns number of actual ITP frame + * @gadget: gadget object + * + * Returns number of actual ITP frame + */ +static int usb_ss_gadget_get_frame(struct usb_gadget *gadget) +{ + struct usb_ss_dev *usb_ss = gadget_to_usb_ss(gadget); + + dev_dbg(&usb_ss->dev, "%s\n", __func__); + return gadget_readl(usb_ss, &usb_ss->regs->usb_iptn); +} + +static int usb_ss_gadget_wakeup(struct usb_gadget *gadget) +{ + struct usb_ss_dev __maybe_unused *usb_ss = gadget_to_usb_ss(gadget); + + dev_dbg(&usb_ss->dev, "%s\n", __func__); + return 0; +} + +static int usb_ss_gadget_set_selfpowered(struct usb_gadget *gadget, + int is_selfpowered) +{ + struct usb_ss_dev __maybe_unused *usb_ss = gadget_to_usb_ss(gadget); + + dev_dbg(&usb_ss->dev, "%s: %d\n", __func__, is_selfpowered); + return 0; +} + +static int usb_ss_gadget_pullup(struct usb_gadget *gadget, int is_on) +{ + struct usb_ss_dev *usb_ss = gadget_to_usb_ss(gadget); + + if (!usb_ss->start_gadget) + return 0; + + dev_dbg(&usb_ss->dev, "%s: %d\n", __func__, is_on); + + if (is_on) + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__DEVEN__MASK); + else + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__DEVDS__MASK); + + return 0; +} + +/** + * usb_ss_gadget_udc_start Gadget start + * @gadget: gadget object + * @driver: driver which operates on this gadget + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_gadget_udc_start(struct usb_gadget *gadget, + struct usb_gadget_driver *driver) +{ + struct usb_ss_dev *usb_ss = gadget_to_usb_ss(gadget); + unsigned long flags; + + if (usb_ss->gadget_driver) { + dev_err(&usb_ss->dev, "%s is already bound\n", + usb_ss->gadget.name); + return -EBUSY; + } + + dev_dbg(&usb_ss->dev, "%s begins\n", __func__); + + spin_lock_irqsave(&usb_ss->lock, flags); + usb_ss->gadget_driver = driver; + if (!usb_ss->start_gadget) { + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + + __cdns3_gadget_start(usb_ss); + spin_unlock_irqrestore(&usb_ss->lock, flags); + dev_dbg(&usb_ss->dev, "%s ends\n", __func__); + + return 0; +} + +/** + * usb_ss_gadget_udc_stop Stops gadget + * @gadget: gadget object + * + * Returns 0 + */ +static int usb_ss_gadget_udc_stop(struct usb_gadget *gadget) +{ + struct usb_ss_dev *usb_ss = gadget_to_usb_ss(gadget); + struct usb_ep *ep; + struct usb_ss_endpoint *usb_ss_ep; + int i; + u32 bEndpointAddress; + + usb_ss->gadget_driver = NULL; + if (!usb_ss->start_gadget) + return 0; + + list_for_each_entry(ep, &usb_ss->gadget.ep_list, ep_list) { + usb_ss_ep = to_usb_ss_ep(ep); + bEndpointAddress = usb_ss_ep->num | usb_ss_ep->dir; + usb_ss_ep->used = false; + select_ep(usb_ss, bEndpointAddress); + gadget_writel(usb_ss, &usb_ss->regs->ep_cmd, + EP_CMD__EPRST__MASK); + while (gadget_readl(usb_ss, &usb_ss->regs->ep_cmd) + & EP_CMD__EPRST__MASK) + ; + } + + /* disable interrupt for device */ + gadget_writel(usb_ss, &usb_ss->regs->usb_ien, 0); + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, USB_CONF__DEVDS__MASK); + + for (i = 0; i < usb_ss->ep_nums ; i++) + usb_ss_free_trb_pool(usb_ss->eps[i]); + + return 0; +} + +static void cdns3_gadget_set_speed(struct usb_gadget *g, + enum usb_device_speed speed) +{ + struct usb_ss_dev *usb_ss = gadget_to_usb_ss(g); + + usb_ss->gadget.max_speed = speed; +} + +static const struct usb_gadget_ops usb_ss_gadget_ops = { + .get_frame = usb_ss_gadget_get_frame, + .wakeup = usb_ss_gadget_wakeup, + .set_selfpowered = usb_ss_gadget_set_selfpowered, + .pullup = usb_ss_gadget_pullup, + .udc_start = usb_ss_gadget_udc_start, + .udc_stop = usb_ss_gadget_udc_stop, + .match_ep = usb_ss_gadget_match_ep, + .udc_set_speed = cdns3_gadget_set_speed, + +}; + +/** + * usb_ss_init_ep Initializes software endpoints of gadget + * @usb_ss: extended gadget object + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_init_ep(struct usb_ss_dev *usb_ss) +{ + struct usb_ss_endpoint *usb_ss_ep; + u32 ep_enabled_reg, iso_ep_reg, bulk_ep_reg; + int i; + int ep_reg_pos, ep_dir, ep_number; + int found_endpoints = 0; + + /* Read it from USB_CAP3 to USB_CAP5 */ + ep_enabled_reg = 0x00ff00ff; + iso_ep_reg = 0x00fe00fe; + bulk_ep_reg = 0x00fe00fe; + + dev_dbg(&usb_ss->dev, "Initializing non-zero endpoints\n"); + dev_dbg(&usb_ss->dev, + "ep_enabled_reg: 0x%x, iso_ep_reg: 0x%x, bulk_ep_reg:0x%x\n", + ep_enabled_reg, iso_ep_reg, bulk_ep_reg); + + for (i = 0; i < USB_SS_ENDPOINTS_MAX_COUNT; i++) { + ep_number = (i / 2) + 1; + ep_dir = i % 2; + ep_reg_pos = (16 * ep_dir) + ep_number; + + if (!(ep_enabled_reg & (1uL << ep_reg_pos))) + continue; + + /* create empty endpoint object */ + usb_ss_ep = devm_kzalloc(&usb_ss->dev, sizeof(*usb_ss_ep), + GFP_KERNEL); + if (!usb_ss_ep) + return -ENOMEM; + + /* set parent of endpoint object */ + usb_ss_ep->usb_ss = usb_ss; + + /* set index of endpoint in endpoints container */ + usb_ss->eps[found_endpoints++] = usb_ss_ep; + + /* set name of endpoint */ + snprintf(usb_ss_ep->name, sizeof(usb_ss_ep->name), "ep%d%s", + ep_number, !!ep_dir ? "in" : "out"); + usb_ss_ep->endpoint.name = usb_ss_ep->name; + dev_dbg(&usb_ss->dev, "Initializing endpoint: %s\n", + usb_ss_ep->name); + + usb_ep_set_maxpacket_limit(&usb_ss_ep->endpoint, + ENDPOINT_MAX_PACKET_LIMIT); + usb_ss_ep->endpoint.max_streams = ENDPOINT_MAX_STREAMS; + usb_ss_ep->endpoint.ops = &usb_ss_gadget_ep_ops; + if (ep_dir) + usb_ss_ep->caps.dir_in = 1; + else + usb_ss_ep->caps.dir_out = 1; + + /* check endpoint type */ + if (iso_ep_reg & (1uL << ep_reg_pos)) + usb_ss_ep->caps.type_iso = 1; + + if (bulk_ep_reg & (1uL << ep_reg_pos)) { + usb_ss_ep->caps.type_bulk = 1; + usb_ss_ep->caps.type_int = 1; + usb_ss_ep->endpoint.maxburst = 15; + } + + list_add_tail(&usb_ss_ep->endpoint.ep_list, + &usb_ss->gadget.ep_list); + INIT_LIST_HEAD(&usb_ss_ep->request_list); + INIT_LIST_HEAD(&usb_ss_ep->ep_match_pending_list); + } + usb_ss->ep_nums = found_endpoints; + + return 0; +} + +/** + * usb_ss_init_ep0 Initializes software endpoint 0 of gadget + * @usb_ss: extended gadget object + * + * Returns 0 on success, error code elsewhere + */ +static int usb_ss_init_ep0(struct usb_ss_dev *usb_ss) +{ + struct usb_ss_endpoint *ep0; + + dev_dbg(&usb_ss->dev, "Initializing EP0\n"); + ep0 = devm_kzalloc(&usb_ss->dev, sizeof(struct usb_ss_endpoint), + GFP_KERNEL); + + if (!ep0) + return -ENOMEM; + + /* fill CDNS fields */ + ep0->usb_ss = usb_ss; + sprintf(ep0->name, "ep0"); + + /* fill linux fields */ + ep0->endpoint.ops = &usb_ss_gadget_ep0_ops; + ep0->endpoint.maxburst = 1; + usb_ep_set_maxpacket_limit(&ep0->endpoint, ENDPOINT0_MAX_PACKET_LIMIT); + ep0->address = 0; + ep0->enabled = 1; + ep0->caps.type_control = 1; + ep0->caps.dir_in = 1; + ep0->caps.dir_out = 1; + ep0->endpoint.name = ep0->name; + ep0->endpoint.desc = &cdns3_gadget_ep0_desc; + usb_ss->gadget.ep0 = &ep0->endpoint; + INIT_LIST_HEAD(&ep0->request_list); + + return 0; +} + +#if !CONFIG_IS_ENABLED(DM_USB_GADGET) +static void cdns3_gadget_release(struct device *dev) +{ + struct usb_ss_dev *usb_ss = container_of(dev, struct usb_ss_dev, dev); + + kfree(usb_ss); +} +#endif + +static int __cdns3_gadget_init(struct cdns3 *cdns) +{ + struct usb_ss_dev *usb_ss; + int ret; +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + struct udevice *dev; + struct cdns3_generic_peripheral *priv = container_of(cdns, + struct cdns3_generic_peripheral, cdns3); + + usb_ss = &priv->usb_ss_dev; + dev = &usb_ss->dev; +#else + struct device *dev; + + usb_ss = kzalloc(sizeof(*usb_ss), GFP_KERNEL); + if (!usb_ss) + return -ENOMEM; + + dev = &usb_ss->dev; + dev->release = cdns3_gadget_release; +#endif + dev->parent = cdns->dev; + dev_set_name(dev, "gadget-cdns3-dev"); + cdns->gadget_dev = dev; + usb_ss->sysdev = cdns->dev; + ret = device_register(dev); + if (ret) + goto err1; + + usb_ss->regs = cdns->dev_regs; + + /* fill gadget fields */ + usb_ss->gadget.ops = &usb_ss_gadget_ops; + usb_ss->gadget.max_speed = USB_SPEED_SUPER; + usb_ss->gadget.speed = USB_SPEED_UNKNOWN; + usb_ss->gadget.name = "cdns3-gadget"; + usb_ss->is_connected = 0; + spin_lock_init(&usb_ss->lock); + + usb_ss->in_standby_mode = 1; + + /* initialize endpoint container */ + INIT_LIST_HEAD(&usb_ss->gadget.ep_list); + INIT_LIST_HEAD(&usb_ss->ep_match_list); + ret = usb_ss_init_ep0(usb_ss); + if (ret) { + dev_err(dev, "Failed to create endpoint 0\n"); + ret = -ENOMEM; + goto err2; + } + + ret = usb_ss_init_ep(usb_ss); + if (ret) { + dev_err(dev, "Failed to create non zero endpoints\n"); + ret = -ENOMEM; + goto err2; + } + + /* allocate memory for default endpoint TRB */ + usb_ss->trb_ep0 = (u32 *)dma_alloc_coherent(20, + (unsigned long *)&usb_ss->trb_ep0_dma); + if (!usb_ss->trb_ep0) { + dev_err(dev, "Failed to allocate memory for ep0 TRB\n"); + ret = -ENOMEM; + goto err2; + } + + /* allocate memory for setup packet buffer */ + usb_ss->setup = (u8 *)dma_alloc_coherent(8, + (unsigned long *)&usb_ss->setup_dma); + if (!usb_ss->setup) { + dev_err(dev, "Failed to allocate memory for SETUP buffer\n"); + ret = -ENOMEM; + goto err3; + } + + /* add USB gadget device */ + ret = usb_add_gadget_udc((struct device *)(&usb_ss->dev), + &usb_ss->gadget); + if (ret < 0) { + dev_err(dev, "Failed to register USB device controller\n"); + goto err4; + } + + return 0; + +err4: + dma_free_coherent(usb_ss->setup); +err3: + dma_free_coherent(usb_ss->trb_ep0); +err2: +err1: + cdns->gadget_dev = NULL; + + return ret; +} + +/** + * cdns3_gadget_remove: parent must call this to remove UDC + * + * cdns: cdns3 instance + * + */ +void cdns3_gadget_remove(struct cdns3 *cdns) +{ + struct usb_ss_dev *usb_ss; + + if (!cdns->roles[CDNS3_ROLE_GADGET]) + return; + + usb_ss = container_of(cdns->gadget_dev, struct usb_ss_dev, dev); + usb_del_gadget_udc(&usb_ss->gadget); + dma_free_coherent(usb_ss->setup); + dma_free_coherent(usb_ss->trb_ep0); + device_unregister(cdns->gadget_dev); + cdns->gadget_dev = NULL; +} + +static void __cdns3_gadget_start(struct usb_ss_dev *usb_ss) +{ + u32 usb_conf_reg = 0; + + /* configure endpoint 0 hardware */ + cdns_ep0_config(usb_ss); + + /* enable interrupts for endpoint 0 (in and out) */ + gadget_writel(usb_ss, &usb_ss->regs->ep_ien, + EP_IEN__EOUTEN0__MASK | EP_IEN__EINEN0__MASK); + + /* enable interrupt for device */ + gadget_writel(usb_ss, &usb_ss->regs->usb_ien, + USB_IEN__U2RESIEN__MASK + | USB_ISTS__DIS2I__MASK + | USB_IEN__CON2IEN__MASK + | USB_IEN__UHRESIEN__MASK + | USB_IEN__UWRESIEN__MASK + | USB_IEN__DISIEN__MASK + | USB_IEN__CONIEN__MASK + | USB_IEN__U3EXTIEN__MASK + | USB_IEN__L2ENTIEN__MASK + | USB_IEN__L2EXTIEN__MASK); + + usb_conf_reg = USB_CONF__CLK2OFFDS__MASK | + USB_CONF__L1DS__MASK; + if (usb_ss->gadget.max_speed == USB_SPEED_HIGH) + usb_conf_reg |= USB_CONF__USB3DIS__MASK; + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, usb_conf_reg); + + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, + USB_CONF__U1DS__MASK + | USB_CONF__U2DS__MASK + /* + * TODO: + * | USB_CONF__L1EN__MASK + */ + ); + + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, USB_CONF__DEVEN__MASK); + + gadget_writel(usb_ss, &usb_ss->regs->dbg_link1, + DBG_LINK1__LFPS_MIN_GEN_U1_EXIT_SET__MASK | + DBG_LINK1__LFPS_MIN_GEN_U1_EXIT__WRITE(0x3C)); +} + +static int cdns3_gadget_start(struct cdns3 *cdns) +{ + struct usb_ss_dev *usb_ss = container_of(cdns->gadget_dev, + struct usb_ss_dev, dev); + unsigned long flags; + + dev_dbg(&usb_ss->dev, "%s begins\n", __func__); + + pm_runtime_get_sync(cdns->dev); + spin_lock_irqsave(&usb_ss->lock, flags); + usb_ss->start_gadget = 1; + if (!usb_ss->gadget_driver) { + spin_unlock_irqrestore(&usb_ss->lock, flags); + return 0; + } + + __cdns3_gadget_start(usb_ss); + usb_ss->in_standby_mode = 0; + spin_unlock_irqrestore(&usb_ss->lock, flags); + dev_dbg(&usb_ss->dev, "%s ends\n", __func__); + + return 0; +} + +static void __cdns3_gadget_stop(struct cdns3 *cdns) +{ + struct usb_ss_dev *usb_ss; + unsigned long flags; + + usb_ss = container_of(cdns->gadget_dev, struct usb_ss_dev, dev); + if (usb_ss->gadget_driver) + usb_ss->gadget_driver->disconnect(&usb_ss->gadget); + usb_gadget_disconnect(&usb_ss->gadget); + spin_lock_irqsave(&usb_ss->lock, flags); + /* disable interrupt for device */ + gadget_writel(usb_ss, &usb_ss->regs->usb_ien, 0); + gadget_writel(usb_ss, &usb_ss->regs->usb_conf, USB_CONF__DEVDS__MASK); + usb_ss->start_gadget = 0; + spin_unlock_irqrestore(&usb_ss->lock, flags); +} + +static void cdns3_gadget_stop(struct cdns3 *cdns) +{ + if (cdns->role == CDNS3_ROLE_GADGET) + __cdns3_gadget_stop(cdns); +} + +/** + * cdns3_gadget_init - initialize device structure + * + * cdns: cdns3 instance + * + * This function initializes the gadget. + */ +int cdns3_gadget_init(struct cdns3 *cdns) +{ + struct cdns3_role_driver *rdrv; + + rdrv = devm_kzalloc(cdns->dev, sizeof(*rdrv), GFP_KERNEL); + if (!rdrv) + return -ENOMEM; + + rdrv->start = cdns3_gadget_start; + rdrv->stop = cdns3_gadget_stop; + rdrv->irq = cdns_irq_handler_thread; + rdrv->name = "gadget"; + cdns->roles[CDNS3_ROLE_GADGET] = rdrv; + return __cdns3_gadget_init(cdns); +} diff --git a/drivers/usb/cdns3/gadget.h b/drivers/usb/cdns3/gadget.h new file mode 100644 index 0000000000..475015f812 --- /dev/null +++ b/drivers/usb/cdns3/gadget.h @@ -0,0 +1,238 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Cadence Design Systems - http://www.cadence.com + * Copyright 2019 NXP + */ +#ifndef __DRIVERS_CDNS3_GADGET +#define __DRIVERS_CDNS3_GADGET + +#include "dev-regs-map.h" + +#if IS_ENABLED(CONFIG_USB_CDNS_MISC) +#include "cdns_misc.h" +#endif + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) +#include <dm.h> +#include <clk.h> +#include <power-domain.h> +#endif + +#define gadget_to_usb_ss(g) \ + (container_of(g, struct usb_ss_dev, gadget)) + +#define to_usb_ss_ep(ep) \ + (container_of(ep, struct usb_ss_endpoint, endpoint)) + +#define ep_to_usb_ss_ep(ep) \ + (container_of(ep, struct usb_ss_endpoint, endpoint)) + +/*-------------------------------------------------------------------------*/ +/* TRB macros */ + +/* Common TRB fields */ +#define TRB_SET_CYCLE_BIT 1uL +#define TRB_SET_CHAIN_BIT 0x10 + +/* offset 0 */ +#define TRB_DATA_BUFFER_POINTER_MASK 0xFFFFFFFF +#define TRB_SET_DATA_BUFFER_POINTER(p) (p & TRB_DATA_BUFFER_POINTER_MASK) + +/* offset 4 */ +#define TRB_TRANSFER_LENGTH_MASK 0x1FFFF +#define TRB_SET_TRANSFER_LENGTH(l) (l & TRB_TRANSFER_LENGTH_MASK) + +#define TRB_BURST_LENGTH_MASK 0xFF +#define TRB_SET_BURST_LENGTH(l) ((l & TRB_BURST_LENGTH_MASK) << 24) + +/* offset 8 */ +#define TRB_SET_INT_ON_SHORT_PACKET 0x04 +#define TRB_SET_FIFO_MODE 0x08 +#define TRB_SET_INT_ON_COMPLETION 0x20 + +#define TRB_TYPE_NORMAL 0x400 + +#define TRB_STREAM_ID_MASK 0xFFFF +#define TRB_SET_STREAM_ID(sid) ((sid & TRB_STREAM_ID_MASK) << 16) + +/*-------------------------------------------------------------------------*/ +/* Driver numeric constants */ + +#define DEVICE_ADDRESS_MAX 127 + +/* Endpoint init values */ +#define ENDPOINT_MAX_PACKET_LIMIT 1024 + +#define ENDPOINT_MAX_STREAMS 15 + +#define ENDPOINT0_MAX_PACKET_LIMIT 512 + +/* All endpoints except EP0 */ +#define USB_SS_ENDPOINTS_MAX_COUNT 30 + +#define USB_SS_TRBS_NUM 32 + +/* Standby mode */ +#define STB_CLK_SWITCH_DONE_MASK 0x200 +#define STB_CLK_SWITCH_EN_MASK 0x100 +#define STB_CLK_SWITCH_EN_SHIFT 8 + +#define ENDPOINT_MAX_PACKET_SIZE_0 0 +#define ENDPOINT_MAX_PACKET_SIZE_8 8 +#define ENDPOINT_MAX_PACKET_SIZE_64 64 +#define ENDPOINT_MAX_PACKET_SIZE_512 512 +#define ENDPOINT_MAX_PACKET_SIZE_1023 1023 +#define ENDPOINT_MAX_PACKET_SIZE_1024 1024 + +#define SS_LINK_STATE_U3 3 +#define FSHS_LPM_STATE_L2 2 + +#define ADDR_MODULO_8 8 + +#define INTERRUPT_MASK 0xFFFFFFFF + +#define ACTUAL_TRANSFERRED_BYTES_MASK 0x1FFFF + +#define ENDPOINT_DIR_MASK 0x80 + +/*-------------------------------------------------------------------------*/ + +/** + * IS_REG_REQUIRING_ACTIVE_REF_CLOCK - Macro checks if desired + * register requires active clock, it involves such registers as: + * EP_CFG, EP_TR_ADDR, EP_CMD, EP_SEL, USB_CONF + * @usb_ss: extended gadget object + * @reg: register address + */ +#define IS_REG_REQUIRING_ACTIVE_REF_CLOCK(usb_ss, reg) (!(reg) || \ + ((reg) >= &(usb_ss)->regs->ep_sel && (reg) <= &(usb_ss)->regs->ep_cmd)) + +/** + * CAST_EP_REG_POS_TO_INDEX - Macro converts bit position of ep_ists register to + * index of endpoint object in usb_ss_dev.eps[] container + * @i: bit position of endpoint for which endpoint object is required + * + * Remember that endpoint container doesn't contain default endpoint + */ +#define CAST_EP_REG_POS_TO_INDEX(i) (((i) / 16) + ((((i) % 16) - 2) * 2)) + +/** + * CAST_EP_ADDR_TO_INDEX - Macro converts endpoint address to + * index of endpoint object in usb_ss_dev.eps[] container + * @ep_addr: endpoint address for which endpoint object is required + * + * Remember that endpoint container doesn't contain default endpoint + */ +#define CAST_EP_ADDR_TO_INDEX(ep_addr) \ + ((((ep_addr) & 0x7F) - 1) + (((ep_addr) & 0x80) ? 1 : 0)) + +/** + * CAST_EP_ADDR_TO_BIT_POS - Macro converts endpoint address to + * bit position in ep_ists register + * @ep_addr: endpoint address for which bit position is required + * + * Remember that endpoint container doesn't contain default endpoint + */ +#define CAST_EP_ADDR_TO_BIT_POS(ep_addr) \ + (((uint32_t)1 << ((ep_addr) & 0x7F)) << (((ep_addr) & 0x80) ? 16 : 0)) + +#define CAST_INDEX_TO_EP_ADDR(index) \ + (((index) / 2 + 1) | (((index) % 2) ? 0x80 : 0x00)) + +/*-------------------------------------------------------------------------*/ +/* Used structs */ + +struct usb_ss_trb { + u32 offset0; + u32 offset4; + u32 offset8; +}; + +struct usb_ss_dev; + +struct usb_ep_caps { + unsigned type_control:1; + unsigned type_iso:1; + unsigned type_bulk:1; + unsigned type_int:1; + unsigned dir_in:1; + unsigned dir_out:1; +}; + +struct usb_ss_endpoint { + struct usb_ep endpoint; + struct list_head request_list; + struct list_head ep_match_pending_list; + + struct usb_ss_trb *trb_pool; + dma_addr_t trb_pool_dma; + + struct usb_ss_dev *usb_ss; + char name[20]; + int hw_pending_flag; + int stalled_flag; + int wedge_flag; + void *cpu_addr; + dma_addr_t dma_addr; + u8 dir; + u8 num; + u8 type; + u8 address; + bool used; + bool enabled; + struct usb_ep_caps caps; +}; + +struct usb_ss_dev { +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + struct udevice dev; +#else + struct device dev; +#endif + struct usbss_dev_register_block_type __iomem *regs; + + struct usb_gadget gadget; + struct usb_gadget_driver *gadget_driver; + + dma_addr_t setup_dma; + dma_addr_t trb_ep0_dma; + u32 *trb_ep0; + u8 *setup; + + struct usb_ss_endpoint *eps[USB_SS_ENDPOINTS_MAX_COUNT]; + int ep_nums; + struct usb_request *actual_ep0_request; + int ep0_data_dir; + int hw_configured_flag; + int wake_up_flag; + u16 isoch_delay; + spinlock_t lock; /* protection lock */ + + unsigned is_connected:1; + unsigned in_standby_mode:1; + + u32 usb_ien; + u32 ep_ien; + int setup_pending; +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + struct udevice *sysdev; +#else + struct device *sysdev; +#endif + bool start_gadget; /* The device mode is enabled */ + struct list_head ep_match_list; +}; + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) +struct cdns3_generic_peripheral { + struct cdns3 cdns3; + struct usb_ss_dev usb_ss_dev; + struct clk_bulk clks; + struct power_domain phy_pd; + struct clk phy_clk; +}; +#endif + +#define OTG_STS_SELECTOR 0xF000 /* OTG status selector */ + +#endif /* __DRIVERS_CDNS3_GADGET */ diff --git a/drivers/usb/cdns3/io.h b/drivers/usb/cdns3/io.h new file mode 100644 index 0000000000..22b1b03950 --- /dev/null +++ b/drivers/usb/cdns3/io.h @@ -0,0 +1,30 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Cadence Design Systems - https://www.cadence.com/ + * Copyright 2019 NXP + */ + +#ifndef __DRIVERS_USB_CDNS_IO_H +#define __DRIVERS_USB_CDNS_IO_H + +#include <linux/io.h> + +static inline u32 cdns_readl(u32 __iomem *reg) +{ + u32 value = 0; + + value = readl(reg); + return value; +} + +static inline void cdns_writel(u32 __iomem *reg, u32 value) +{ + writel(value, reg); +} + +static inline void cdns_flush_cache(uintptr_t addr, int length) +{ + flush_dcache_range(addr, addr + ROUND(length, ARCH_DMA_MINALIGN)); +} + +#endif /* __DRIVERS_USB_CDNS_IO_H */ diff --git a/drivers/usb/cdns3/linux-compat.h b/drivers/usb/cdns3/linux-compat.h new file mode 100644 index 0000000000..b544e73ae4 --- /dev/null +++ b/drivers/usb/cdns3/linux-compat.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 NXP + */ + +#ifndef __CDNS3_LINUX_COMPAT__ +#define __CDNS3_LINUX_COMPAT__ + +#define dev_WARN(dev, format, arg...) debug(format, ##arg) + +static inline void *devm_kzalloc(struct device *dev, unsigned int size, + unsigned int flags) +{ + return kzalloc(size, flags); +} +#endif diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c index 179b94cdd0..360f2b75ff 100644 --- a/drivers/usb/gadget/epautoconf.c +++ b/drivers/usb/gadget/epautoconf.c @@ -167,6 +167,10 @@ static int ep_matches( size = 64; put_unaligned(cpu_to_le16(size), &desc->wMaxPacketSize); } + + if (gadget->ops->match_ep) + return gadget->ops->match_ep(gadget, ep, desc); + return 1; }
diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index 2c8f235d51..ba9114cf37 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -149,6 +149,11 @@ #define gadget_is_dwc3(g) 0 #endif
+#ifdef CONFIG_USB_CDNS3_GADGET +#define gadget_is_cdns3(g) (!strcmp("cdns3-gadget", (g)->name)) +#else +#define gadget_is_cdns3(g) 0 +#endif /** * usb_gadget_controller_number - support bcdDevice id convention * @gadget: the controller being driven @@ -208,5 +213,7 @@ static inline int usb_gadget_controller_number(struct usb_gadget *gadget) return 0x22; else if (gadget_is_dwc3(gadget)) return 0x23; + else if (gadget_is_cdns3(gadget)) + return 0x24; return -ENOENT; } diff --git a/drivers/usb/gadget/udc/Makefile b/drivers/usb/gadget/udc/Makefile index 95dbf0c82e..414edad921 100644 --- a/drivers/usb/gadget/udc/Makefile +++ b/drivers/usb/gadget/udc/Makefile @@ -4,6 +4,7 @@
ifndef CONFIG_$(SPL_)DM_USB_GADGET obj-$(CONFIG_USB_DWC3_GADGET) += udc-core.o +obj-$(CONFIG_USB_CDNS3_GADGET) += udc-core.o endif
obj-$(CONFIG_$(SPL_)DM_USB_GADGET) += udc-core.o diff --git a/include/cdns3-uboot.h b/include/cdns3-uboot.h new file mode 100644 index 0000000000..28c6ac6e61 --- /dev/null +++ b/include/cdns3-uboot.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 NXP + */ + +#ifndef __CDNS3_UBOOT_H_ +#define __CDNS3_UBOOT_H_ + +#include <linux/usb/otg.h> + +#if !CONFIG_IS_ENABLED(DM_USB_GADGET) +struct cdns3_device { + unsigned long none_core_base; + unsigned long xhci_base; + unsigned long dev_base; + unsigned long phy_base; + unsigned long otg_base; + enum usb_dr_mode dr_mode; + int index; +}; + +int cdns3_uboot_init(struct cdns3_device *dev); +void cdns3_uboot_exit(int index); +void cdns3_uboot_handle_interrupt(int index); +#endif +#endif /* __CDNS3_UBOOT_H_ */ diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 497798a32a..a34f3478f3 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -447,6 +447,9 @@ struct usb_gadget_ops { int (*udc_start)(struct usb_gadget *, struct usb_gadget_driver *); int (*udc_stop)(struct usb_gadget *); + int (*match_ep)(struct usb_gadget *gadget, + struct usb_ep *ep, + struct usb_endpoint_descriptor *desc); };
/** diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 7af6b120b6..d731c21aa4 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -88,6 +88,7 @@ endif
libs-y += drivers/ libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/dwc3/ +libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/cdns3/ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/
This driver is ported from NXP i.MX U-Boot version imx_v2019.04 and some changes have also been made to adapt to U-Boot.
Add the USB3 host driver for NXP imx8 platform, and the cadence IP is in it.
The USB3 host driver support DM mode. It will probe USB3 host node, enable the power and clk of both USB3 controller and USB3 PHY.
Signed-off-by: Sherry Sun sherry.sun@nxp.com --- drivers/usb/host/Kconfig | 9 + drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-imx8.c | 311 ++++++++++++++++++++++ include/usb/imx8_usb3_reg_def.h | 455 ++++++++++++++++++++++++++++++++ 4 files changed, 776 insertions(+) create mode 100644 drivers/usb/host/xhci-imx8.c create mode 100644 include/usb/imx8_usb3_reg_def.h
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index b1188bcbf5..73c98e0cf4 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -94,6 +94,15 @@ config USB_XHCI_FSL depends on !SPL_NO_USB help Enables support for the on-chip xHCI controller on NXP Layerscape SoCs. + +config USB_XHCI_IMX8 + bool "XHCI support for imx8" + depends on ARCH_IMX8 + default y + help + Enables support for the on-chip xHCI controller on imx8qm and + imx8qxp SoCs. + endif # USB_XHCI_HCD
config USB_EHCI_HCD diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 6aa574f6f7..e5a0a4ea5a 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -55,6 +55,7 @@ obj-$(CONFIG_USB_XHCI_OMAP) += xhci-omap.o obj-$(CONFIG_USB_XHCI_PCI) += xhci-pci.o obj-$(CONFIG_USB_XHCI_RCAR) += xhci-rcar.o obj-$(CONFIG_USB_XHCI_STI) += dwc3-sti-glue.o +obj-$(CONFIG_USB_XHCI_IMX8) += xhci-imx8.o
# designware obj-$(CONFIG_USB_DWC2) += dwc2.o diff --git a/drivers/usb/host/xhci-imx8.c b/drivers/usb/host/xhci-imx8.c new file mode 100644 index 0000000000..abac37d446 --- /dev/null +++ b/drivers/usb/host/xhci-imx8.c @@ -0,0 +1,311 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * NXP i.MX8 USB HOST xHCI Controller (Cadence IP) + * + * Author: Peter Chen peter.chen@nxp.com + */ + +#include <common.h> +#include <usb.h> +#include <malloc.h> +#include <usb/imx8_usb3_reg_def.h> +#include <dm.h> +#include <clk.h> +#include <power-domain.h> +#include <asm/arch/clock.h> +#include <linux/compat.h> +#include "xhci.h" + +/* Declare global data pointer */ +DECLARE_GLOBAL_DATA_PTR; + +/* According to UG CH 3.1.1 Bring-up Sequence */ +static void imx_usb3_phy_init(void) +{ + writel(0x0830, PHY_PMA_CMN_CTRL1); + writel(0x10, TB_ADDR_CMN_DIAG_HSCLK_SEL); + writel(0x00F0, TB_ADDR_CMN_PLL0_VCOCAL_INIT_TMR); + writel(0x0018, TB_ADDR_CMN_PLL0_VCOCAL_ITER_TMR); + writel(0x00D0, TB_ADDR_CMN_PLL0_INTDIV); + writel(0x4aaa, TB_ADDR_CMN_PLL0_FRACDIV); + writel(0x0034, TB_ADDR_CMN_PLL0_HIGH_THR); + writel(0x1ee, TB_ADDR_CMN_PLL0_SS_CTRL1); + writel(0x7F03, TB_ADDR_CMN_PLL0_SS_CTRL2); + writel(0x0020, TB_ADDR_CMN_PLL0_DSM_DIAG); + writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_OVRD); + writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_FBH_OVRD); + writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_FBL_OVRD); + writel(0x0007, TB_ADDR_CMN_DIAG_PLL0_V2I_TUNE); + writel(0x0027, TB_ADDR_CMN_DIAG_PLL0_CP_TUNE); + writel(0x0008, TB_ADDR_CMN_DIAG_PLL0_LF_PROG); + writel(0x0022, TB_ADDR_CMN_DIAG_PLL0_TEST_MODE); + writel(0x000a, TB_ADDR_CMN_PSM_CLK_CTRL); + writel(0x139, TB_ADDR_XCVR_DIAG_RX_LANE_CAL_RST_TMR); + writel(0xbefc, TB_ADDR_XCVR_PSM_RCTRL); + + writel(0x7799, TB_ADDR_TX_PSC_A0); + writel(0x7798, TB_ADDR_TX_PSC_A1); + writel(0x509b, TB_ADDR_TX_PSC_A2); + writel(0x3, TB_ADDR_TX_DIAG_ECTRL_OVRD); + writel(0x5098, TB_ADDR_TX_PSC_A3); + writel(0x2090, TB_ADDR_TX_PSC_CAL); + writel(0x2090, TB_ADDR_TX_PSC_RDY); + + writel(0xA6FD, TB_ADDR_RX_PSC_A0); + writel(0xA6FD, TB_ADDR_RX_PSC_A1); + writel(0xA410, TB_ADDR_RX_PSC_A2); + writel(0x2410, TB_ADDR_RX_PSC_A3); + + writel(0x23FF, TB_ADDR_RX_PSC_CAL); + writel(0x2010, TB_ADDR_RX_PSC_RDY); + + writel(0x0020, TB_ADDR_TX_TXCC_MGNLS_MULT_000); + writel(0x00ff, TB_ADDR_TX_DIAG_BGREF_PREDRV_DELAY); + writel(0x0002, TB_ADDR_RX_SLC_CU_ITER_TMR); + writel(0x0013, TB_ADDR_RX_SIGDET_HL_FILT_TMR); + writel(0x0000, TB_ADDR_RX_SAMP_DAC_CTRL); + writel(0x1004, TB_ADDR_RX_DIAG_SIGDET_TUNE); + writel(0x4041, TB_ADDR_RX_DIAG_LFPSDET_TUNE2); + writel(0x0480, TB_ADDR_RX_DIAG_BS_TM); + writel(0x8006, TB_ADDR_RX_DIAG_DFE_CTRL1); + writel(0x003f, TB_ADDR_RX_DIAG_ILL_IQE_TRIM4); + writel(0x543f, TB_ADDR_RX_DIAG_ILL_E_TRIM0); + writel(0x543f, TB_ADDR_RX_DIAG_ILL_IQ_TRIM0); + writel(0x0000, TB_ADDR_RX_DIAG_ILL_IQE_TRIM6); + writel(0x8000, TB_ADDR_RX_DIAG_RXFE_TM3); + writel(0x0003, TB_ADDR_RX_DIAG_RXFE_TM4); + writel(0x2408, TB_ADDR_RX_DIAG_LFPSDET_TUNE); + writel(0x05ca, TB_ADDR_RX_DIAG_DFE_CTRL3); + writel(0x0258, TB_ADDR_RX_DIAG_SC2C_DELAY); + writel(0x1fff, TB_ADDR_RX_REE_VGA_GAIN_NODFE); + + writel(0x02c6, TB_ADDR_XCVR_PSM_CAL_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A0BYP_TMR); + writel(0x02c6, TB_ADDR_XCVR_PSM_A0IN_TMR); + writel(0x0010, TB_ADDR_XCVR_PSM_A1IN_TMR); + writel(0x0010, TB_ADDR_XCVR_PSM_A2IN_TMR); + writel(0x0010, TB_ADDR_XCVR_PSM_A3IN_TMR); + writel(0x0010, TB_ADDR_XCVR_PSM_A4IN_TMR); + writel(0x0010, TB_ADDR_XCVR_PSM_A5IN_TMR); + + writel(0x0002, TB_ADDR_XCVR_PSM_A0OUT_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A1OUT_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A2OUT_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A3OUT_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A4OUT_TMR); + writel(0x0002, TB_ADDR_XCVR_PSM_A5OUT_TMR); + + /* Change rx detect parameter */ + writel(0x960, TB_ADDR_TX_RCVDET_EN_TMR); + writel(0x01e0, TB_ADDR_TX_RCVDET_ST_TMR); + writel(0x0090, TB_ADDR_XCVR_DIAG_LANE_FCM_EN_MGN_TMR); + + udelay(10); + + /* force rx detect */ +/* writel(0xc000, TB_ADDR_TX_RCVDET_OVRD); */ +} + +void imx8_xhci_init(void) +{ + u32 tmp_data; + + tmp_data = readl(USB3_SSPHY_STATUS); + writel(tmp_data, USB3_SSPHY_STATUS); + tmp_data = readl(USB3_SSPHY_STATUS); + while ((tmp_data & 0xf0000000) != 0xf0000000) { + printf("clkvld is incorrect = 0x%x\n", tmp_data); + udelay(10); + tmp_data = readl(USB3_SSPHY_STATUS); + } + + tmp_data = readl(USB3_CORE_CTRL1); + tmp_data = (tmp_data & 0xfffffff8) | 0x202; + writel(tmp_data, USB3_CORE_CTRL1); + tmp_data &= ~0x04000000; /* clear PHY apb reset */ + writel(tmp_data, USB3_CORE_CTRL1); + imx_usb3_phy_init(); + + tmp_data = readl(USB3_CORE_CTRL1); + tmp_data &= ~0xfc000000; /* clear all sw_rst */ + writel(tmp_data, USB3_CORE_CTRL1); + + debug("wait xhci_power_on_ready\n"); + tmp_data = readl(USB3_CORE_STATUS); + while (!(tmp_data & 0x1000)) + tmp_data = readl(USB3_CORE_STATUS); + + debug("xhci_power_on_ready\n"); + + tmp_data = readl(USBSTS); + debug("waiting CNR 0x%x\n", tmp_data); + while (tmp_data & 0x800) + tmp_data = readl(USBSTS); + + debug("check CNR has finished\n"); +} + +void imx8_xhci_reset(void) +{ + /* Set CORE ctrl to default value, that all rst are hold */ + writel(0xfc000001, USB3_CORE_CTRL1); +} + +static int xhci_imx8_power(struct udevice *dev, bool on) +{ + struct udevice usbotg_dev, phy_dev; + struct power_domain pd; + const void *blob = gd->fdt_blob; + int offset = dev_of_offset(dev); + int usbotg_off, phy_off; + + usbotg_off = fdtdec_lookup_phandle(blob, + offset, + "cdns3,usb"); + if (usbotg_off < 0) + return -EINVAL; + usbotg_dev.node = offset_to_ofnode(usbotg_off); + + phy_off = fdtdec_lookup_phandle(blob, + usbotg_off, + "cdns3,usbphy"); + if (phy_off < 0) + return -EINVAL; + phy_dev.node = offset_to_ofnode(phy_off); + + if (on) { + if (!power_domain_get(&usbotg_dev, &pd)) { + if (power_domain_on(&pd)) + return -EINVAL; + } + if (!power_domain_get(&phy_dev, &pd)) { + if (power_domain_on(&pd)) + return -EINVAL; + } + } else { + if (!power_domain_get(&phy_dev, &pd)) { + if (power_domain_off(&pd)) + return -EINVAL; + } + } + + return 0; +} + +static int xhci_imx8_clk(struct udevice *dev, bool on) +{ + int ret; + struct udevice usbotg_dev, phy_dev; + const void *blob = gd->fdt_blob; + int offset = dev_of_offset(dev); + int usbotg_off, phy_off; + struct clk_bulk clks; + struct clk phy_clk; + + usbotg_off = fdtdec_lookup_phandle(blob, + offset, + "cdns3,usb"); + if (usbotg_off < 0) + return -EINVAL; + usbotg_dev.node = offset_to_ofnode(usbotg_off); + + phy_off = fdtdec_lookup_phandle(blob, + usbotg_off, + "cdns3,usbphy"); + if (phy_off < 0) + return -EINVAL; + phy_dev.node = offset_to_ofnode(phy_off); + + ret = clk_get_bulk(&usbotg_dev, &clks); + if (ret) + return ret; + ret = clk_get_by_name(&phy_dev, "main_clk", &phy_clk); + if (ret) + return ret; + + if (on) { + ret = clk_enable_bulk(&clks); + if (ret) + return ret; + + ret = clk_enable(&phy_clk); + if (ret) + return ret; + } else { + clk_release_bulk(&clks); + + if (phy_clk.dev) { + ret = clk_disable(&phy_clk); + if (ret) + return ret; + ret = clk_free(&phy_clk); + if (ret) + return ret; + } + } + + return 0; +} + +static int xhci_imx8_probe(struct udevice *dev) +{ + struct xhci_hccr *hccr; + struct xhci_hcor *hcor; + + int len; + +#if CONFIG_IS_ENABLED(POWER_DOMAIN) + xhci_imx8_power(dev, true); +#endif + +#if CONFIG_IS_ENABLED(CLK) + xhci_imx8_clk(dev, true); +#endif + + imx8_xhci_init(); + + hccr = (struct xhci_hccr *)HCIVERSION_CAPLENGTH; + len = HC_LENGTH(xhci_readl(&hccr->cr_capbase)); + hcor = (struct xhci_hcor *)((uintptr_t)hccr + len); + printf("XHCI-imx8 init hccr 0x%p and hcor 0x%p hc_length %d\n", + (uint32_t *)hccr, (uint32_t *)hcor, len); + + return xhci_register(dev, hccr, hcor); +} + +static int xhci_imx8_remove(struct udevice *dev) +{ + int ret = xhci_deregister(dev); + + if (!ret) + imx8_xhci_reset(); + +#if CONFIG_IS_ENABLED(CLK) + xhci_imx8_clk(dev, false); +#endif + +#if CONFIG_IS_ENABLED(POWER_DOMAIN) + xhci_imx8_power(dev, false); +#endif + + return ret; +} + +static const struct udevice_id xhci_usb_ids[] = { + { .compatible = "Cadence,usb3-host", }, + { } +}; + +U_BOOT_DRIVER(xhci_imx8) = { + .name = "xhci_imx8", + .id = UCLASS_USB, + .of_match = xhci_usb_ids, + .probe = xhci_imx8_probe, + .remove = xhci_imx8_remove, + .ops = &xhci_usb_ops, + .platdata_auto_alloc_size = sizeof(struct usb_platdata), + .priv_auto_alloc_size = sizeof(struct xhci_ctrl), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; diff --git a/include/usb/imx8_usb3_reg_def.h b/include/usb/imx8_usb3_reg_def.h new file mode 100644 index 0000000000..dfa16e47e3 --- /dev/null +++ b/include/usb/imx8_usb3_reg_def.h @@ -0,0 +1,455 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + * + * NXP i.MX8 USB HOST xHCI Controller (Cadence IP) Register Definition + */ + +#ifndef _IMX8_USB3_H_ +#define _IMX8_USB3_H_ + +#define REG32(m) (m) + +#define USB3_REGS_BASE 0x5B110000 +#define USB3_CTRL_BASE (USB3_REGS_BASE + 0x00000) +#define USB3_CORE_BASE (USB3_REGS_BASE + 0x10000) +#define USB3_PHY_BASE (USB3_REGS_BASE + 0x50000) +/* PHY registers */ +#define PHY_PMA_CMN_CTRL1 (USB3_PHY_BASE + 0xC800 * 4) +#define TB_ADDR_CMN_DIAG_HSCLK_SEL (USB3_PHY_BASE + 0x01e0 * 4) +#define TB_ADDR_CMN_PLL0_VCOCAL_INIT_TMR (USB3_PHY_BASE + 0x0084 * 4) +#define TB_ADDR_CMN_PLL0_VCOCAL_ITER_TMR (USB3_PHY_BASE + 0x0085 * 4) +#define TB_ADDR_CMN_PLL0_INTDIV (USB3_PHY_BASE + 0x0094 * 4) +#define TB_ADDR_CMN_PLL0_FRACDIV (USB3_PHY_BASE + 0x0095 * 4) +#define TB_ADDR_CMN_PLL0_HIGH_THR (USB3_PHY_BASE + 0x0096 * 4) +#define TB_ADDR_CMN_PLL0_SS_CTRL1 (USB3_PHY_BASE + 0x0098 * 4) +#define TB_ADDR_CMN_PLL0_SS_CTRL2 (USB3_PHY_BASE + 0x0099 * 4) +#define TB_ADDR_CMN_PLL0_DSM_DIAG (USB3_PHY_BASE + 0x0097 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_OVRD (USB3_PHY_BASE + 0x01c2 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_FBH_OVRD (USB3_PHY_BASE + 0x01c0 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_FBL_OVRD (USB3_PHY_BASE + 0x01c1 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_V2I_TUNE (USB3_PHY_BASE + 0x01C5 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_CP_TUNE (USB3_PHY_BASE + 0x01C6 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_LF_PROG (USB3_PHY_BASE + 0x01C7 * 4) +#define TB_ADDR_CMN_DIAG_PLL0_TEST_MODE (USB3_PHY_BASE + 0x01c4 * 4) +#define TB_ADDR_CMN_PSM_CLK_CTRL (USB3_PHY_BASE + 0x0061 * 4) +#define TB_ADDR_XCVR_DIAG_RX_LANE_CAL_RST_TMR (USB3_PHY_BASE + 0x40ea * 4) +#define TB_ADDR_XCVR_PSM_RCTRL (USB3_PHY_BASE + 0x4001 * 4) +#define TB_ADDR_TX_PSC_A0 (USB3_PHY_BASE + 0x4100 * 4) +#define TB_ADDR_TX_PSC_A1 (USB3_PHY_BASE + 0x4101 * 4) +#define TB_ADDR_TX_PSC_A2 (USB3_PHY_BASE + 0x4102 * 4) +#define TB_ADDR_TX_PSC_A3 (USB3_PHY_BASE + 0x4103 * 4) +#define TB_ADDR_TX_DIAG_ECTRL_OVRD (USB3_PHY_BASE + 0x41f5 * 4) +#define TB_ADDR_TX_PSC_CAL (USB3_PHY_BASE + 0x4106 * 4) +#define TB_ADDR_TX_PSC_RDY (USB3_PHY_BASE + 0x4107 * 4) +#define TB_ADDR_RX_PSC_A0 (USB3_PHY_BASE + 0x8000 * 4) +#define TB_ADDR_RX_PSC_A1 (USB3_PHY_BASE + 0x8001 * 4) +#define TB_ADDR_RX_PSC_A2 (USB3_PHY_BASE + 0x8002 * 4) +#define TB_ADDR_RX_PSC_A3 (USB3_PHY_BASE + 0x8003 * 4) +#define TB_ADDR_RX_PSC_CAL (USB3_PHY_BASE + 0x8006 * 4) +#define TB_ADDR_RX_PSC_RDY (USB3_PHY_BASE + 0x8007 * 4) +#define TB_ADDR_TX_TXCC_MGNLS_MULT_000 (USB3_PHY_BASE + 0x4058 * 4) +#define TB_ADDR_TX_DIAG_BGREF_PREDRV_DELAY (USB3_PHY_BASE + 0x41e7 * 4) +#define TB_ADDR_RX_SLC_CU_ITER_TMR (USB3_PHY_BASE + 0x80e3 * 4) +#define TB_ADDR_RX_SIGDET_HL_FILT_TMR (USB3_PHY_BASE + 0x8090 * 4) +#define TB_ADDR_RX_SAMP_DAC_CTRL (USB3_PHY_BASE + 0x8058 * 4) +#define TB_ADDR_RX_DIAG_SIGDET_TUNE (USB3_PHY_BASE + 0x81dc * 4) +#define TB_ADDR_RX_DIAG_LFPSDET_TUNE2 (USB3_PHY_BASE + 0x81df * 4) +#define TB_ADDR_RX_DIAG_BS_TM (USB3_PHY_BASE + 0x81f5 * 4) +#define TB_ADDR_RX_DIAG_DFE_CTRL1 (USB3_PHY_BASE + 0x81d3 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQE_TRIM4 (USB3_PHY_BASE + 0x81c7 * 4) +#define TB_ADDR_RX_DIAG_ILL_E_TRIM0 (USB3_PHY_BASE + 0x81c2 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQ_TRIM0 (USB3_PHY_BASE + 0x81c1 * 4) +#define TB_ADDR_RX_DIAG_ILL_IQE_TRIM6 (USB3_PHY_BASE + 0x81c9 * 4) +#define TB_ADDR_RX_DIAG_RXFE_TM3 (USB3_PHY_BASE + 0x81f8 * 4) +#define TB_ADDR_RX_DIAG_RXFE_TM4 (USB3_PHY_BASE + 0x81f9 * 4) +#define TB_ADDR_RX_DIAG_LFPSDET_TUNE (USB3_PHY_BASE + 0x81dd * 4) +#define TB_ADDR_RX_DIAG_DFE_CTRL3 (USB3_PHY_BASE + 0x81d5 * 4) +#define TB_ADDR_RX_DIAG_SC2C_DELAY (USB3_PHY_BASE + 0x81e1 * 4) +#define TB_ADDR_RX_REE_VGA_GAIN_NODFE (USB3_PHY_BASE + 0x81bf * 4) +#define TB_ADDR_XCVR_PSM_CAL_TMR (USB3_PHY_BASE + 0x4002 * 4) +#define TB_ADDR_XCVR_PSM_A0BYP_TMR (USB3_PHY_BASE + 0x4004 * 4) +#define TB_ADDR_XCVR_PSM_A0IN_TMR (USB3_PHY_BASE + 0x4003 * 4) +#define TB_ADDR_XCVR_PSM_A1IN_TMR (USB3_PHY_BASE + 0x4005 * 4) +#define TB_ADDR_XCVR_PSM_A2IN_TMR (USB3_PHY_BASE + 0x4006 * 4) +#define TB_ADDR_XCVR_PSM_A3IN_TMR (USB3_PHY_BASE + 0x4007 * 4) +#define TB_ADDR_XCVR_PSM_A4IN_TMR (USB3_PHY_BASE + 0x4008 * 4) +#define TB_ADDR_XCVR_PSM_A5IN_TMR (USB3_PHY_BASE + 0x4009 * 4) +#define TB_ADDR_XCVR_PSM_A0OUT_TMR (USB3_PHY_BASE + 0x400a * 4) +#define TB_ADDR_XCVR_PSM_A1OUT_TMR (USB3_PHY_BASE + 0x400b * 4) +#define TB_ADDR_XCVR_PSM_A2OUT_TMR (USB3_PHY_BASE + 0x400c * 4) +#define TB_ADDR_XCVR_PSM_A3OUT_TMR (USB3_PHY_BASE + 0x400d * 4) +#define TB_ADDR_XCVR_PSM_A4OUT_TMR (USB3_PHY_BASE + 0x400e * 4) +#define TB_ADDR_XCVR_PSM_A5OUT_TMR (USB3_PHY_BASE + 0x400f * 4) +#define TB_ADDR_TX_RCVDET_EN_TMR (USB3_PHY_BASE + 0x4122 * 4) +#define TB_ADDR_TX_RCVDET_ST_TMR (USB3_PHY_BASE + 0x4123 * 4) +#define TB_ADDR_XCVR_DIAG_LANE_FCM_EN_MGN_TMR (USB3_PHY_BASE + 0x40f2 * 4) + +/* Host registers */ +#define HCIVERSION_CAPLENGTH (USB3_CORE_BASE + 0x10000) +#define HCSPARAMS1 (USB3_CORE_BASE + 0x10004) +#define HCSPARAMS2 (USB3_CORE_BASE + 0x10008) +#define HCSPARAMS3 (USB3_CORE_BASE + 0x1000c) +#define HCCPARAMS (USB3_CORE_BASE + 0x10010) +#define DBOFF (USB3_CORE_BASE + 0x10014) +#define RTSOFF (USB3_CORE_BASE + 0x10018) +#define USBCMD (USB3_CORE_BASE + 0x10080) +#define USBSTS (USB3_CORE_BASE + 0x10084) +#define PAGESIZE (USB3_CORE_BASE + 0x10088) +#define DNCTRL (USB3_CORE_BASE + 0x10094) +#define CRCR_LO (USB3_CORE_BASE + 0x10098) +#define CRCR_HI (USB3_CORE_BASE + 0x1009c) +#define DCBAAP_LO (USB3_CORE_BASE + 0x100b0) +#define DCBAAP_HI (USB3_CORE_BASE + 0x100b4) +#define CONFIG (USB3_CORE_BASE + 0x100b8) +#define PORTSC1USB2 (USB3_CORE_BASE + 0x10480) +#define PORTPMSC1USB2 (USB3_CORE_BASE + 0x10484) +#define PORT1HLPMC (USB3_CORE_BASE + 0x1048c) +#define PORTSC1USB3 (USB3_CORE_BASE + 0x10490) +#define PORTPMSC1USB3 (USB3_CORE_BASE + 0x10494) +#define PORTLI1 (USB3_CORE_BASE + 0x10498) +#define MFINDEX (USB3_CORE_BASE + 0x12000) +#define IMAN0 (USB3_CORE_BASE + 0x12020) +#define IMOD0 (USB3_CORE_BASE + 0x12024) +#define ERSTSZ0 (USB3_CORE_BASE + 0x12028) +#define XHCI_RESERVED0 (USB3_CORE_BASE + 0x1202c) +#define ERSTBA0_LO (USB3_CORE_BASE + 0x12030) +#define ERSTBA0_HI (USB3_CORE_BASE + 0x12034) +#define ERDP0_LO (USB3_CORE_BASE + 0x12038) +#define ERDP0_HI (USB3_CORE_BASE + 0x1203c) +#define IMAN1 (USB3_CORE_BASE + 0x12040) +#define IMOD1 (USB3_CORE_BASE + 0x12044) +#define ERSTSZ1 (USB3_CORE_BASE + 0x12048) +#define XHCI_RESERVED1 (USB3_CORE_BASE + 0x1204c) +#define ERSTBA1_LO (USB3_CORE_BASE + 0x12050) +#define ERSTBA1_HI (USB3_CORE_BASE + 0x12054) +#define ERDP1_LO (USB3_CORE_BASE + 0x12058) +#define ERDP1_HI (USB3_CORE_BASE + 0x1205c) +#define IMAN2 (USB3_CORE_BASE + 0x12060) +#define IMOD2 (USB3_CORE_BASE + 0x12064) +#define ERSTSZ2 (USB3_CORE_BASE + 0x12068) +#define XHCI_RESERVED2 (USB3_CORE_BASE + 0x1206c) +#define ERSTBA2_LO (USB3_CORE_BASE + 0x12070) +#define ERSTBA2_HI (USB3_CORE_BASE + 0x12074) +#define ERDP2_LO (USB3_CORE_BASE + 0x12078) +#define ERDP2_HI (USB3_CORE_BASE + 0x1207c) +#define IMAN3 (USB3_CORE_BASE + 0x12080) +#define IMOD3 (USB3_CORE_BASE + 0x12084) +#define ERSTSZ3 (USB3_CORE_BASE + 0x12088) +#define XHCI_RESERVED3 (USB3_CORE_BASE + 0x1208c) +#define ERSTBA3_LO (USB3_CORE_BASE + 0x12090) +#define ERSTBA3_HI (USB3_CORE_BASE + 0x12094) +#define ERDP3_LO (USB3_CORE_BASE + 0x12098) +#define ERDP3_HI (USB3_CORE_BASE + 0x1209c) +#define IMAN4 (USB3_CORE_BASE + 0x120a0) +#define IMOD4 (USB3_CORE_BASE + 0x120a4) +#define ERSTSZ4 (USB3_CORE_BASE + 0x120a8) +#define XHCI_RESERVED4 (USB3_CORE_BASE + 0x120ac) +#define ERSTBA4_LO (USB3_CORE_BASE + 0x120b0) +#define ERSTBA4_HI (USB3_CORE_BASE + 0x120b4) +#define ERDP4_LO (USB3_CORE_BASE + 0x120b8) +#define ERDP4_HI (USB3_CORE_BASE + 0x120bc) +#define IMAN5 (USB3_CORE_BASE + 0x120c0) +#define IMOD5 (USB3_CORE_BASE + 0x120c4) +#define ERSTSZ5 (USB3_CORE_BASE + 0x120c8) +#define XHCI_RESERVED5 (USB3_CORE_BASE + 0x120cc) +#define ERSTBA5_LO (USB3_CORE_BASE + 0x120d0) +#define ERSTBA5_HI (USB3_CORE_BASE + 0x120d4) +#define ERDP5_LO (USB3_CORE_BASE + 0x120d8) +#define ERDP5_HI (USB3_CORE_BASE + 0x120dc) +#define IMAN6 (USB3_CORE_BASE + 0x120e0) +#define IMOD6 (USB3_CORE_BASE + 0x120e4) +#define ERSTSZ6 (USB3_CORE_BASE + 0x120e8) +#define XHCI_RESERVED6 (USB3_CORE_BASE + 0x120ec) +#define ERSTBA6_LO (USB3_CORE_BASE + 0x120f0) +#define ERSTBA6_HI (USB3_CORE_BASE + 0x120f4) +#define ERDP6_LO (USB3_CORE_BASE + 0x120f8) +#define ERDP6_HI (USB3_CORE_BASE + 0x120fc) +#define IMAN7 (USB3_CORE_BASE + 0x12100) +#define IMOD7 (USB3_CORE_BASE + 0x12104) +#define ERSTSZ7 (USB3_CORE_BASE + 0x12108) +#define XHCI_RESERVED7 (USB3_CORE_BASE + 0x1210c) +#define ERSTBA7_LO (USB3_CORE_BASE + 0x12110) +#define ERSTBA7_HI (USB3_CORE_BASE + 0x12114) +#define ERDP7_LO (USB3_CORE_BASE + 0x12118) +#define ERDP7_HI (USB3_CORE_BASE + 0x1211c) +#define DB0 (USB3_CORE_BASE + 0x13000) +#define DB1 (USB3_CORE_BASE + 0x13004) +#define DB2 (USB3_CORE_BASE + 0x13008) +#define DB3 (USB3_CORE_BASE + 0x1300c) +#define DB4 (USB3_CORE_BASE + 0x13010) +#define DB5 (USB3_CORE_BASE + 0x13014) +#define DB6 (USB3_CORE_BASE + 0x13018) +#define DB7 (USB3_CORE_BASE + 0x1301c) +#define DB8 (USB3_CORE_BASE + 0x13020) +#define DB9 (USB3_CORE_BASE + 0x13024) +#define DB10 (USB3_CORE_BASE + 0x13028) +#define DB11 (USB3_CORE_BASE + 0x1302c) +#define DB12 (USB3_CORE_BASE + 0x13030) +#define DB13 (USB3_CORE_BASE + 0x13034) +#define DB14 (USB3_CORE_BASE + 0x13038) +#define DB15 (USB3_CORE_BASE + 0x1303c) +#define DB16 (USB3_CORE_BASE + 0x13040) +#define DB17 (USB3_CORE_BASE + 0x13044) +#define DB18 (USB3_CORE_BASE + 0x13048) +#define DB19 (USB3_CORE_BASE + 0x1304c) +#define DB20 (USB3_CORE_BASE + 0x13050) +#define DB21 (USB3_CORE_BASE + 0x13054) +#define DB22 (USB3_CORE_BASE + 0x13058) +#define DB23 (USB3_CORE_BASE + 0x1305c) +#define DB24 (USB3_CORE_BASE + 0x13060) +#define DB25 (USB3_CORE_BASE + 0x13064) +#define DB26 (USB3_CORE_BASE + 0x13068) +#define DB27 (USB3_CORE_BASE + 0x1306c) +#define DB28 (USB3_CORE_BASE + 0x13070) +#define DB29 (USB3_CORE_BASE + 0x13074) +#define DB30 (USB3_CORE_BASE + 0x13078) +#define DB31 (USB3_CORE_BASE + 0x1307c) +#define DB32 (USB3_CORE_BASE + 0x13080) +#define XECP_PORT_CAP_REG (USB3_CORE_BASE + 0x18000) +#define XECP_PORT_1_REG (USB3_CORE_BASE + 0x18004) +#define XECP_CDNS_DEBUG_BUS_CAP (USB3_CORE_BASE + 0x18008) +#define XECP_CDNS_DEBUG_BUS_CTRL (USB3_CORE_BASE + 0x1800c) +#define XECP_CDNS_DEBUG_BUS_STATUS (USB3_CORE_BASE + 0x18010) +#define XECP_PM_CAP (USB3_CORE_BASE + 0x18014) +#define XECP_PM_PMCSR (USB3_CORE_BASE + 0x18018) +#define XECP_MSI_CAP (USB3_CORE_BASE + 0x1801c) +#define XECP_MSI_ADDR_L (USB3_CORE_BASE + 0x18020) +#define XECP_MSI_ADDR_H (USB3_CORE_BASE + 0x18024) +#define XECP_MSI_DATA (USB3_CORE_BASE + 0x18028) +#define XECP_AXI_CAP (USB3_CORE_BASE + 0x1802c) +#define XECP_AXI_CFG0 (USB3_CORE_BASE + 0x18030) +#define XECP_AXI_CTRL0 (USB3_CORE_BASE + 0x18034) +#define XECP_AXI_CTRL1 (USB3_CORE_BASE + 0x18038) +#define XECP_AXI_CTRL2 (USB3_CORE_BASE + 0x1803c) +#define XECP_SUPP_USB2_CAP0 (USB3_CORE_BASE + 0x18040) +#define XECP_SUPP_USB2_CAP1 (USB3_CORE_BASE + 0x18044) +#define XECP_SUPP_USB2_CAP2 (USB3_CORE_BASE + 0x18048) +#define XECP_SUPP_USB2_PROTOCOL_SLOT_TYPE (USB3_CORE_BASE + 0x1804c) +#define XECP_PSI_FULL_SPEED (USB3_CORE_BASE + 0x18050) +#define XECP_PSI_LOW_SPEED (USB3_CORE_BASE + 0x18054) +#define XECP_PSI_HIGH_SPEED (USB3_CORE_BASE + 0x18058) +#define XECP_SUPP_USB3_CAP0 (USB3_CORE_BASE + 0x18060) +#define XECP_SUPP_USB3_CAP1 (USB3_CORE_BASE + 0x18064) +#define XECP_SUPP_USB3_CAP2 (USB3_CORE_BASE + 0x18068) +#define XECP_SUPP_USB3_PROTOCOL_SLOT_TYPE (USB3_CORE_BASE + 0x1806c) +#define PSI_SUPER_SPEED (USB3_CORE_BASE + 0x18070) +#define XECP_CMDM_STS0 (USB3_CORE_BASE + 0x18080) +#define XECP_CMDM_RESERVED_1 (USB3_CORE_BASE + 0x18084) +#define XECP_CMDM_RESERVED_2 (USB3_CORE_BASE + 0x18088) +#define XECP_CMDM_RESERVED_3 (USB3_CORE_BASE + 0x1808c) +#define XECP_CMDM_RESERVED_4 (USB3_CORE_BASE + 0x18090) +#define XECP_CMDM_RESERVED_5 (USB3_CORE_BASE + 0x18094) +#define XECP_CMDM_CTRL_REG1 (USB3_CORE_BASE + 0x18098) +#define XECP_CMDM_CTRL_REG2 (USB3_CORE_BASE + 0x1809c) +#define XECP_CMDM_CTRL_REG3 (USB3_CORE_BASE + 0x180a0) +#define XECP_HOST_CTRL_CAP (USB3_CORE_BASE + 0x180b0) +#define XECP_HOST_CTRL_RSVD (USB3_CORE_BASE + 0x180b4) +#define XECP_HOST_CLR_MASK_REG (USB3_CORE_BASE + 0x180b8) +#define XECP_HOST_CLR_IN_EP_VALID_REG (USB3_CORE_BASE + 0x180bc) +#define XECP_HOST_CLR_PMASK_REG (USB3_CORE_BASE + 0x180c0) +#define XECP_HOST_CTRL_OCRD_REG (USB3_CORE_BASE + 0x180c4) +#define XECP_HOST_CTRL_TEST_BUS_LO (USB3_CORE_BASE + 0x180c8) +#define XECP_HOST_CTRL_TEST_BUS_HI (USB3_CORE_BASE + 0x180cc) +#define XECP_HOST_CTRL_TRM_REG1 (USB3_CORE_BASE + 0x180d0) +#define XECP_HOST_CTRL_SCH_REG1 (USB3_CORE_BASE + 0x180d4) +#define XECP_HOST_CTRL_ODMA_REG (USB3_CORE_BASE + 0x180d8) +#define XECP_HOST_CTRL_IDMA_REG (USB3_CORE_BASE + 0x180dc) +#define XECP_HOST_CTRL_PORT_CTRL (USB3_CORE_BASE + 0x180e0) +#define XECP_AUX_CTRL_REG (USB3_CORE_BASE + 0x18100) +#define XECP_HOST_BW_OV_SS_REG (USB3_CORE_BASE + 0x18104) +#define XECP_HOST_BW_OV_HS_REG (USB3_CORE_BASE + 0x18108) +#define XECP_HOST_BW_OV_FS_LS_REG (USB3_CORE_BASE + 0x1810c) +#define XECP_HOST_BW_OV_SYS_REG (USB3_CORE_BASE + 0x18110) +#define XECP_HOST_CTRL_SCH_ASYNC_DELAY_REG (USB3_CORE_BASE + 0x18114) +#define XECP_UPORTS_PON_RST_REG (USB3_CORE_BASE + 0x18118) +#define XECP_HOST_CTRL_TRM_REG3 (USB3_CORE_BASE + 0x1811c) +#define XECP_AUX_CTRL_REG1 (USB3_CORE_BASE + 0x18120) +#define XECP_HOST_CTRL_WATERMARK_REG (USB3_CORE_BASE + 0x18128) +#define XECP_HOST_CTRL_PORT_LINK_REG (USB3_CORE_BASE + 0x1812c) +#define XECP_USB2_LINK_MGR_CTRL_REG1 (USB3_CORE_BASE + 0x18130) +#define XECP_USB2_LINK_MGR_CTRL_REG2 (USB3_CORE_BASE + 0x18134) +#define XECP_USB2_LINK_MGR_CTRL_REG3 (USB3_CORE_BASE + 0x18138) +#define XECP_USB2_LINK_MGR_CTRL_REG4 (USB3_CORE_BASE + 0x1813c) +#define XECP_HOST_CTRL_BW_MAX_REG (USB3_CORE_BASE + 0x18140) +#define XECP_FPGA_REVISION_REG (USB3_CORE_BASE + 0x18144) +#define XECP_HOST_INTF_CTRL_REG (USB3_CORE_BASE + 0x18148) +#define XECP_BW_OV_SS_BURST_REG (USB3_CORE_BASE + 0x1814c) +#define XECP_HOST_CTRL_TRM_REG2 (USB3_CORE_BASE + 0x18150) +#define XECP_HOST_CTRL_BW_MAX1_REG (USB3_CORE_BASE + 0x18168) +#define XECP_HOST_CTRL_BW_MAX2_REG (USB3_CORE_BASE + 0x1816c) +#define XECP_USB2_LINESTATE_REG (USB3_CORE_BASE + 0x18170) +#define XECP_HOST_PROTO_GAP_TIMER1_REG (USB3_CORE_BASE + 0x18174) +#define XECP_HOST_PROTO_GAP_TIMER2_REG (USB3_CORE_BASE + 0x18178) +#define XECP_HOST_PROTO_BTO_TIMER_REG (USB3_CORE_BASE + 0x1817c) +#define XECP_HOST_CTRL_PSCH_REG (USB3_CORE_BASE + 0x18180) +#define XECP_HOST_CTRL_PSCH1_REG (USB3_CORE_BASE + 0x18184) +#define XECP_HOST_CTRL_LTM_REG (USB3_CORE_BASE + 0x18190) +#define XECP_AUX_CTRL_REG2 (USB3_CORE_BASE + 0x18194) +#define XECP_AUX_CTRL_REG3 (USB3_CORE_BASE + 0x18198) +#define XECP_DEBUG_CTRL_REG (USB3_CORE_BASE + 0x1819c) +#define XECP_HOST_CTRL_SCH_REG2 (USB3_CORE_BASE + 0x181a0) +#define XECP_AUX_DEBUG_READ_ONLY (USB3_CORE_BASE + 0x181a4) +#define XECP_AUX_CTRL_PORTNUM_REG (USB3_CORE_BASE + 0x181a8) +#define XECP_AUX_CTRL_DEV_REMOVE_REG (USB3_CORE_BASE + 0x181ac) +#define XECP_HOST_CTRL_DEBUG_PORT_DESC (USB3_CORE_BASE + 0x181b0) +#define XECP_HOST_CTRL_DEBUG_PORT_TRM (USB3_CORE_BASE + 0x181b4) +#define XECP_HOST_CTRL_DEBUG_PORT_IDMA (USB3_CORE_BASE + 0x181b8) +#define XECP_HOST_CTRL_DEBUG_PORT_ODMA (USB3_CORE_BASE + 0x181bc) +#define XECP_HOST_CTRL_DEBUG_PORT_MISC (USB3_CORE_BASE + 0x181c0) +#define XECP_HOST_CTRL_TTE_REG1 (USB3_CORE_BASE + 0x181e0) +#define XECP_HOST_CTRL_LTM_REG1 (USB3_CORE_BASE + 0x181e4) +#define XECP_HOST_CTRL_LTM_REG2 (USB3_CORE_BASE + 0x181e8) +#define XECP_AUX_SCRATCHPAD_0 (USB3_CORE_BASE + 0x18200) +#define XECP_AUX_SCRATCHPAD_1 (USB3_CORE_BASE + 0x18204) +#define XECP_BATTERY_CHARGE_REG (USB3_CORE_BASE + 0x18210) +#define XECP_BATTERY_CHARGE_REG1 (USB3_CORE_BASE + 0x18214) +#define XECP_BATTERY_CHARGE_REG2 (USB3_CORE_BASE + 0x18218) +#define XECP_BATTERY_CHARGE_REG3 (USB3_CORE_BASE + 0x1821c) +#define XECP_HOST_CTRL_PORT_LINK_REG1 (USB3_CORE_BASE + 0x18220) +#define XECP_USBLEGSUP (USB3_CORE_BASE + 0x18370) +#define XECP_USBLEGCTLSTS (USB3_CORE_BASE + 0x18374) +#define XECP_DCID (USB3_CORE_BASE + 0x18380) +#define XECP_DCDB (USB3_CORE_BASE + 0x18384) +#define XECP_DCERSTSZ (USB3_CORE_BASE + 0x18388) +#define XECP_RSVD_0C (USB3_CORE_BASE + 0x1838c) +#define XECP_DCERSTBA_LOW (USB3_CORE_BASE + 0x18390) +#define XECP_DCERSTBA_HIGH (USB3_CORE_BASE + 0x18394) +#define XECP_DCERDP_LOW (USB3_CORE_BASE + 0x18398) +#define XECP_DCERDP_HIGH (USB3_CORE_BASE + 0x1839c) +#define XECP_DCCTRL (USB3_CORE_BASE + 0x183a0) +#define XECP_DCST (USB3_CORE_BASE + 0x183a4) +#define XECP_DCPORTSC (USB3_CORE_BASE + 0x183a8) +#define XECP_RSVD_2C (USB3_CORE_BASE + 0x183ac) +#define XECP_DCCP_LOW (USB3_CORE_BASE + 0x183b0) +#define XECP_DCCP_HIGH (USB3_CORE_BASE + 0x183b4) +#define XECP_DCDDI1 (USB3_CORE_BASE + 0x183b8) +#define XECP_DCDDI2 (USB3_CORE_BASE + 0x183bc) +#define XECP_USB3_TEST_PORT0_REG (USB3_CORE_BASE + 0x18800) + +/* OTG registers */ +#define OTGCMD (USB3_CORE_BASE + 0x0) +#define OTGSTS (USB3_CORE_BASE + 0x4) +#define OTGSTATE (USB3_CORE_BASE + 0x8) +#define OTGREFCLK (USB3_CORE_BASE + 0xc) +#define OTGIEN (USB3_CORE_BASE + 0x10) +#define OTGIVECT (USB3_CORE_BASE + 0x14) +#define OTGVERSION (USB3_CORE_BASE + 0x18) +#define OTGSIMULATE (USB3_CORE_BASE + 0x1c) +#define CLK_FREQ (USB3_CORE_BASE + 0x20) +#define OTGTMR (USB3_CORE_BASE + 0x24) +#define ADPBC_STS (USB3_CORE_BASE + 0xe0) +#define ADP_RAMP_TIME (USB3_CORE_BASE + 0xe4) +#define ADPBC_CTRL1 (USB3_CORE_BASE + 0xe8) +#define ADPBC_CTRL2 (USB3_CORE_BASE + 0xec) +#define SFR0 (USB3_CORE_BASE + 0xf0) +#define SFR1 (USB3_CORE_BASE + 0xf4) +#define SFR2 (USB3_CORE_BASE + 0xf8) +#define SFR3 (USB3_CORE_BASE + 0xfc) + +/* Device registers */ +#define usb_conf (USB3_CORE_BASE + 0x20000) +#define usb_sts (USB3_CORE_BASE + 0x20004) +#define usb_cmd (USB3_CORE_BASE + 0x20008) +#define usb_iptn (USB3_CORE_BASE + 0x2000c) +#define usb_lpm (USB3_CORE_BASE + 0x20010) +#define usb_ien (USB3_CORE_BASE + 0x20014) +#define usb_ists (USB3_CORE_BASE + 0x20018) +#define ep_sel (USB3_CORE_BASE + 0x2001c) +#define ep_traddr (USB3_CORE_BASE + 0x20020) +#define ep_cfg (USB3_CORE_BASE + 0x20024) +#define ep_cmd (USB3_CORE_BASE + 0x20028) +#define ep_sts (USB3_CORE_BASE + 0x2002c) +#define ep_sts_sid (USB3_CORE_BASE + 0x20030) +#define ep_sts_en (USB3_CORE_BASE + 0x20034) +#define drbl (USB3_CORE_BASE + 0x20038) +#define ep_ien (USB3_CORE_BASE + 0x2003c) +#define ep_ists (USB3_CORE_BASE + 0x20040) +#define usb_pwr (USB3_CORE_BASE + 0x20044) +#define usb_conf2 (USB3_CORE_BASE + 0x20048) +#define usb_cap1 (USB3_CORE_BASE + 0x2004c) +#define usb_cap2 (USB3_CORE_BASE + 0x20050) +#define usb_cap3 (USB3_CORE_BASE + 0x20054) +#define usb_cap4 (USB3_CORE_BASE + 0x20058) +#define usb_cap5 (USB3_CORE_BASE + 0x2005c) +#define usb_cpkt1 (USB3_CORE_BASE + 0x20060) +#define usb_cpkt2 (USB3_CORE_BASE + 0x20064) +#define usb_cpkt3 (USB3_CORE_BASE + 0x20068) +#define cfg_reg1 (USB3_CORE_BASE + 0x20100) +#define dbg_link1 (USB3_CORE_BASE + 0x20104) +#define dbg_link2 (USB3_CORE_BASE + 0x20108) +#define cfg_reg4 (USB3_CORE_BASE + 0x2010c) +#define cfg_reg5 (USB3_CORE_BASE + 0x20110) +#define cfg_reg6 (USB3_CORE_BASE + 0x20114) +#define cfg_reg7 (USB3_CORE_BASE + 0x20118) +#define cfg_reg8 (USB3_CORE_BASE + 0x2011c) +#define cfg_reg9 (USB3_CORE_BASE + 0x20120) +#define cfg_reg10 (USB3_CORE_BASE + 0x20124) +#define cfg_reg11 (USB3_CORE_BASE + 0x20128) +#define cfg_reg12 (USB3_CORE_BASE + 0x2012c) +#define cfg_reg13 (USB3_CORE_BASE + 0x20130) +#define cfg_reg14 (USB3_CORE_BASE + 0x20134) +#define cfg_reg15 (USB3_CORE_BASE + 0x20138) +#define cfg_reg16 (USB3_CORE_BASE + 0x2013c) +#define cfg_reg17 (USB3_CORE_BASE + 0x20140) +#define cfg_reg18 (USB3_CORE_BASE + 0x20144) +#define cfg_reg19 (USB3_CORE_BASE + 0x20148) +#define cfg_reg20 (USB3_CORE_BASE + 0x2014c) +#define cfg_reg21 (USB3_CORE_BASE + 0x20150) +#define cfg_reg22 (USB3_CORE_BASE + 0x20154) +#define cfg_reg23 (USB3_CORE_BASE + 0x20158) +#define cfg_reg24 (USB3_CORE_BASE + 0x2015c) +#define cfg_reg25 (USB3_CORE_BASE + 0x20160) +#define cfg_reg26 (USB3_CORE_BASE + 0x20164) +#define cfg_reg27 (USB3_CORE_BASE + 0x20168) +#define cfg_reg28 (USB3_CORE_BASE + 0x2016c) +#define cfg_reg29 (USB3_CORE_BASE + 0x20170) +#define cfg_reg30 (USB3_CORE_BASE + 0x20174) +#define cfg_reg31 (USB3_CORE_BASE + 0x20178) +#define cfg_reg32 (USB3_CORE_BASE + 0x2017c) +#define cfg_reg33 (USB3_CORE_BASE + 0x20180) +#define cfg_reg34 (USB3_CORE_BASE + 0x20184) +#define cfg_reg35 (USB3_CORE_BASE + 0x20188) +#define cfg_reg36 (USB3_CORE_BASE + 0x201ac) +#define cfg_reg37 (USB3_CORE_BASE + 0x201b0) +#define cfg_reg38 (USB3_CORE_BASE + 0x201b4) +#define cfg_reg39 (USB3_CORE_BASE + 0x201b8) +#define cfg_reg40 (USB3_CORE_BASE + 0x201bc) +#define cfg_reg41 (USB3_CORE_BASE + 0x201c0) +#define cfg_reg42 (USB3_CORE_BASE + 0x201c4) +#define cfg_reg43 (USB3_CORE_BASE + 0x201c8) +#define cfg_reg44 (USB3_CORE_BASE + 0x201cc) +#define cfg_reg45 (USB3_CORE_BASE + 0x201d0) +#define cfg_reg46 (USB3_CORE_BASE + 0x201d4) +#define cfg_reg47 (USB3_CORE_BASE + 0x201d8) +#define cfg_reg48 (USB3_CORE_BASE + 0x201dc) +#define cfg_reg49 (USB3_CORE_BASE + 0x201e0) +#define cfg_reg50 (USB3_CORE_BASE + 0x201e4) +#define cfg_reg51 (USB3_CORE_BASE + 0x201e8) +#define cfg_reg52 (USB3_CORE_BASE + 0x201ec) +#define cfg_reg53 (USB3_CORE_BASE + 0x201f0) +#define cfg_reg54 (USB3_CORE_BASE + 0x201f4) +#define cfg_reg55 (USB3_CORE_BASE + 0x201f8) +#define cfg_reg56 (USB3_CORE_BASE + 0x201fc) +#define cfg_reg57 (USB3_CORE_BASE + 0x20200) +#define cfg_reg58 (USB3_CORE_BASE + 0x20204) +#define cfg_reg59 (USB3_CORE_BASE + 0x20208) +#define cfg_reg60 (USB3_CORE_BASE + 0x2020c) +#define cfg_reg61 (USB3_CORE_BASE + 0x20210) +#define cfg_reg62 (USB3_CORE_BASE + 0x20214) + +/* None-core registers */ +#define USB3_CORE_CTRL1 (USB3_CTRL_BASE + 0x00) +#define USB3_CORE_CTRL2 (USB3_CTRL_BASE + 0x04) +#define USB3_INT_REG (USB3_CTRL_BASE + 0x08) +#define USB3_CORE_STATUS (USB3_CTRL_BASE + 0x0c) +#define XHCI_DEBUG_LINK_ST (USB3_CTRL_BASE + 0x10) +#define XHCI_DEBUG_BUS (USB3_CTRL_BASE + 0x14) +#define USB3_SSPHY_CTRL1 (USB3_CTRL_BASE + 0x40) +#define USB3_SSPHY_CTRL2 (USB3_CTRL_BASE + 0x44) +#define USB3_SSPHY_STATUS (USB3_CTRL_BASE + 0x4c) +#define USB2_PHY_CTRL1 (USB3_CTRL_BASE + 0x50) +#define USB2_PHY_CTRL2 (USB3_CTRL_BASE + 0x54) +#define USB2_PHY_STATUS (USB3_CTRL_BASE + 0x5c) + +#endif /* _IMX8_USB3_H_ */
I don't this this line above is particularly useful.
- bool "XHCI support for imx8"
- depends on ARCH_IMX8
- default y
- help
imx8qxp SoCs.
- Copyright 2019 NXP
- NXP i.MX8 USB HOST xHCI Controller (Cadence IP)
- Author: Peter Chen peter.chen@nxp.com
Is this needed ?
Shouldn't this be a separate PHY driver ?
- writel(0x0830, PHY_PMA_CMN_CTRL1);
- writel(0x10, TB_ADDR_CMN_DIAG_HSCLK_SEL);
- writel(0x00F0, TB_ADDR_CMN_PLL0_VCOCAL_INIT_TMR);
- writel(0x0018, TB_ADDR_CMN_PLL0_VCOCAL_ITER_TMR);
- writel(0x00D0, TB_ADDR_CMN_PLL0_INTDIV);
- writel(0x4aaa, TB_ADDR_CMN_PLL0_FRACDIV);
- writel(0x0034, TB_ADDR_CMN_PLL0_HIGH_THR);
- writel(0x1ee, TB_ADDR_CMN_PLL0_SS_CTRL1);
- writel(0x7F03, TB_ADDR_CMN_PLL0_SS_CTRL2);
- writel(0x0020, TB_ADDR_CMN_PLL0_DSM_DIAG);
- writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_OVRD);
- writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_FBH_OVRD);
- writel(0x0000, TB_ADDR_CMN_DIAG_PLL0_FBL_OVRD);
- writel(0x0007, TB_ADDR_CMN_DIAG_PLL0_V2I_TUNE);
- writel(0x0027, TB_ADDR_CMN_DIAG_PLL0_CP_TUNE);
- writel(0x0008, TB_ADDR_CMN_DIAG_PLL0_LF_PROG);
- writel(0x0022, TB_ADDR_CMN_DIAG_PLL0_TEST_MODE);
- writel(0x000a, TB_ADDR_CMN_PSM_CLK_CTRL);
- writel(0x139, TB_ADDR_XCVR_DIAG_RX_LANE_CAL_RST_TMR);
- writel(0xbefc, TB_ADDR_XCVR_PSM_RCTRL);
- writel(0x7799, TB_ADDR_TX_PSC_A0);
- writel(0x7798, TB_ADDR_TX_PSC_A1);
- writel(0x509b, TB_ADDR_TX_PSC_A2);
- writel(0x3, TB_ADDR_TX_DIAG_ECTRL_OVRD);
- writel(0x5098, TB_ADDR_TX_PSC_A3);
- writel(0x2090, TB_ADDR_TX_PSC_CAL);
- writel(0x2090, TB_ADDR_TX_PSC_RDY);
- writel(0xA6FD, TB_ADDR_RX_PSC_A0);
- writel(0xA6FD, TB_ADDR_RX_PSC_A1);
- writel(0xA410, TB_ADDR_RX_PSC_A2);
- writel(0x2410, TB_ADDR_RX_PSC_A3);
- writel(0x23FF, TB_ADDR_RX_PSC_CAL);
- writel(0x2010, TB_ADDR_RX_PSC_RDY);
- writel(0x0020, TB_ADDR_TX_TXCC_MGNLS_MULT_000);
- writel(0x00ff, TB_ADDR_TX_DIAG_BGREF_PREDRV_DELAY);
- writel(0x0002, TB_ADDR_RX_SLC_CU_ITER_TMR);
- writel(0x0013, TB_ADDR_RX_SIGDET_HL_FILT_TMR);
- writel(0x0000, TB_ADDR_RX_SAMP_DAC_CTRL);
- writel(0x1004, TB_ADDR_RX_DIAG_SIGDET_TUNE);
- writel(0x4041, TB_ADDR_RX_DIAG_LFPSDET_TUNE2);
- writel(0x0480, TB_ADDR_RX_DIAG_BS_TM);
- writel(0x8006, TB_ADDR_RX_DIAG_DFE_CTRL1);
- writel(0x003f, TB_ADDR_RX_DIAG_ILL_IQE_TRIM4);
- writel(0x543f, TB_ADDR_RX_DIAG_ILL_E_TRIM0);
- writel(0x543f, TB_ADDR_RX_DIAG_ILL_IQ_TRIM0);
- writel(0x0000, TB_ADDR_RX_DIAG_ILL_IQE_TRIM6);
- writel(0x8000, TB_ADDR_RX_DIAG_RXFE_TM3);
- writel(0x0003, TB_ADDR_RX_DIAG_RXFE_TM4);
- writel(0x2408, TB_ADDR_RX_DIAG_LFPSDET_TUNE);
- writel(0x05ca, TB_ADDR_RX_DIAG_DFE_CTRL3);
- writel(0x0258, TB_ADDR_RX_DIAG_SC2C_DELAY);
- writel(0x1fff, TB_ADDR_RX_REE_VGA_GAIN_NODFE);
- writel(0x02c6, TB_ADDR_XCVR_PSM_CAL_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A0BYP_TMR);
- writel(0x02c6, TB_ADDR_XCVR_PSM_A0IN_TMR);
- writel(0x0010, TB_ADDR_XCVR_PSM_A1IN_TMR);
- writel(0x0010, TB_ADDR_XCVR_PSM_A2IN_TMR);
- writel(0x0010, TB_ADDR_XCVR_PSM_A3IN_TMR);
- writel(0x0010, TB_ADDR_XCVR_PSM_A4IN_TMR);
- writel(0x0010, TB_ADDR_XCVR_PSM_A5IN_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A0OUT_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A1OUT_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A2OUT_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A3OUT_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A4OUT_TMR);
- writel(0x0002, TB_ADDR_XCVR_PSM_A5OUT_TMR);
- /* Change rx detect parameter */
- writel(0x960, TB_ADDR_TX_RCVDET_EN_TMR);
- writel(0x01e0, TB_ADDR_TX_RCVDET_ST_TMR);
- writel(0x0090, TB_ADDR_XCVR_DIAG_LANE_FCM_EN_MGN_TMR);
- udelay(10);
- /* force rx detect */
- u32 tmp_data;
- tmp_data = readl(USB3_SSPHY_STATUS);
- writel(tmp_data, USB3_SSPHY_STATUS);
- while ((tmp_data & 0xf0000000) != 0xf0000000) {
udelay(10);
- tmp_data = readl(USB3_CORE_CTRL1);
- tmp_data = (tmp_data & 0xfffffff8) | 0x202;
- writel(tmp_data, USB3_CORE_CTRL1);
- tmp_data &= ~0x04000000; /* clear PHY apb reset */
- imx_usb3_phy_init();
- tmp_data &= ~0xfc000000; /* clear all sw_rst */
clrbits_le32() , fix globally.
- NXP i.MX8 USB HOST xHCI Controller (Cadence IP) Register Definition
Remove this macro.
This should come from DT
Are all these macros needed ?
Hi, Marek
I'm so sorry to check the e-mail and reply you so late.
Ok, I will remove this from the commit messages.
SoCs.
- default y
- help
imx8qxp SoCs.
- Author: Peter Chen peter.chen@nxp.com */
Is this needed ?
Yes, the global_data pointer will be used in later functions. So the declare is needed here.
+/* According to UG CH 3.1.1 Bring-up Sequence */ static void +imx_usb3_phy_init(void) {
Okay, I will try to add a new PHY driver to replace the code below.
- udelay(10);
- u32 tmp_data;
udelay(10);
I will do it, thanks.
+Definition */
Remove this macro.
Ok,I will change this, thanks.
+#define USB3_CTRL_BASE (USB3_REGS_BASE + 0x00000) #define +USB3_CORE_BASE (USB3_REGS_BASE + 0x10000) #define USB3_PHY_BASE +(USB3_REGS_BASE + 0x50000) +/* PHY registers */ +#define PHY_PMA_CMN_CTRL1 (USB3_PHY_BASE + 0xC800 *
0x01e0 * 4)
0x0084 * 4)
0x0085 * 4)
0x0097 * 4)
0x01c2 * 4)
0x01c0 * 4)
0x01c1 * 4)
- 0x01C5 * 4)
0x01c4 * 4)
0x40ea * 4)
Most of them are needed, I will remove the unnecessary parts.
Thanks for your advice.
Best regards Sherry sun
This patch was copied from kernel commit: 67fdfda4a99ed.
Sometimes, the gadget driver we want to run has max_speed lower than what the UDC supports. In such situations, UDC might want to make sure we don't try to connect on speeds not supported by the gadget driver because that will just fail.
So here introduce a new optional ->udc_set_speed() method which can be implemented by interested UDC drivers to achieve this purpose.
Signed-off-by: Sherry Sun sherry.sun@nxp.com --- drivers/usb/gadget/udc/udc-core.c | 23 +++++++++++++++++++++++ include/linux/usb/gadget.h | 2 ++ 2 files changed, 25 insertions(+)
diff --git a/drivers/usb/gadget/udc/udc-core.c b/drivers/usb/gadget/udc/udc-core.c index 62b47781dd..8d1d90e3e3 100644 --- a/drivers/usb/gadget/udc/udc-core.c +++ b/drivers/usb/gadget/udc/udc-core.c @@ -267,6 +267,27 @@ EXPORT_SYMBOL_GPL(usb_del_gadget_udc);
+/** + * usb_gadget_udc_set_speed - tells usb device controller speed supported by + * current driver + * @udc: The device we want to set maximum speed + * @speed: The maximum speed to allowed to run + * + * This call is issued by the UDC Class driver before calling + * usb_gadget_udc_start() in order to make sure that we don't try to + * connect on speeds the gadget driver doesn't support. + */ +static inline void usb_gadget_udc_set_speed(struct usb_udc *udc, + enum usb_device_speed speed) +{ + if (udc->gadget->ops->udc_set_speed) { + enum usb_device_speed s; + + s = min(speed, udc->gadget->max_speed); + udc->gadget->ops->udc_set_speed(udc->gadget, s); + } +} + static int udc_bind_to_driver(struct usb_udc *udc, struct usb_gadget_driver *driver) { int ret; @@ -276,6 +297,8 @@ static int udc_bind_to_driver(struct usb_udc *udc, struct usb_gadget_driver *dri
udc->driver = driver;
+ usb_gadget_udc_set_speed(udc, driver->speed); + ret = driver->bind(udc->gadget); if (ret) goto err1; diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index a34f3478f3..78e245a1b5 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -450,6 +450,8 @@ struct usb_gadget_ops { int (*match_ep)(struct usb_gadget *gadget, struct usb_ep *ep, struct usb_endpoint_descriptor *desc); + void (*udc_set_speed)(struct usb_gadget *gadget, + enum usb_device_speed); };
Hi Sherry,
On Tue, Jul 16, 2019 at 4:15 PM sherry sun sherry.sun@nxp.com wrote:
These patches introduce new Cadence USBSS driver to U-Boot.
The first patch is to add the Cadence USB3 IP(CDNS3) driver for the usb gadget, but the host mode is not supported now. The second patch introduce the xhci-imx8 usb host driver separately. The cdns3 usb gadget driver and xhci-imx8 host driver both use DM mode.
The current driver has been validated on i.MX8 platform.
Sherry Sun (3): USB: gadget: Add the cadence USB3 gadget driver USB: host: Add the USB3 host driver USB: gadget: core: introduce ->udc_set_speed() method
Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 20 + drivers/usb/cdns3/Makefile | 5 + drivers/usb/cdns3/cdns3-generic.c | 176 ++ drivers/usb/cdns3/cdns3-nxp-reg-def.h | 158 ++ drivers/usb/cdns3/core.c | 408 +++++ drivers/usb/cdns3/core.h | 129 ++ drivers/usb/cdns3/dev-regs-macro.h | 116 ++ drivers/usb/cdns3/dev-regs-map.h | 117 ++ drivers/usb/cdns3/gadget-export.h | 26 + drivers/usb/cdns3/gadget.c | 2278 +++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 238 +++ drivers/usb/cdns3/io.h | 30 + drivers/usb/cdns3/linux-compat.h | 16 + drivers/usb/gadget/epautoconf.c | 4 + drivers/usb/gadget/gadget_chips.h | 7 + drivers/usb/gadget/udc/Makefile | 1 + drivers/usb/gadget/udc/udc-core.c | 23 + drivers/usb/host/Kconfig | 9 + drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-imx8.c | 311 ++++ include/cdns3-uboot.h | 26 + include/linux/usb/gadget.h | 5 + include/usb/imx8_usb3_reg_def.h | 455 +++++ scripts/Makefile.spl | 1 + 26 files changed, 4563 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/cdns3-generic.c create mode 100644 drivers/usb/cdns3/cdns3-nxp-reg-def.h create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/dev-regs-macro.h create mode 100644 drivers/usb/cdns3/dev-regs-map.h create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/io.h create mode 100644 drivers/usb/cdns3/linux-compat.h create mode 100644 drivers/usb/host/xhci-imx8.c create mode 100644 include/cdns3-uboot.h create mode 100644 include/usb/imx8_usb3_reg_def.h
-- 2.17.1
Thanks for your patches! Taking into account that this series introduces a brand new driver, it would be really nice to also have proper device tree bindings in doc/device-tree-bindings (so I can at least quickly enable it for my board, test it and leave my T-b tags).
Thanks
Igor,
Subject: Re: [U-Boot] [PATCH 0/3] USB: Add cadence USB3 gadget driver and host driver
Hi Sherry,
-- 2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flist
s.denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7Cpeng.fan%40nxp.co m%7C
fbf069e4184b49805ff608d716792228%7C686ea1d3bc2b4c6fa92cd99c5c301 635%7C
0%7C0%7C637002581830489188&sdata=2sLbnCK6jSV9a3NQZFK8iwc1r lh5jSyAR
qSveO4nebg%3D&reserved=0
Currently there is also no linux upstream bindings for the new IP, so this will be dedicated for U-Boot. In future when Linux is ready, need to migrate to use Linux bindings.
To let you test the patchset, suggest Sherry to create a branch on github or somewhere.
Regards, Peng.
Thanks
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fua.linke din.com%2Fin%2Fiopaniuk&data=02%7C01%7Cpeng.fan%40nxp.com%7 Cfbf069e4184b49805ff608d716792228%7C686ea1d3bc2b4c6fa92cd99c5c30 1635%7C0%7C0%7C637002581830489188&sdata=xgOmj3btCYHz8akdK 6oK7rLSGD9AhLnQmd6Ob2aq%2Bzc%3D&reserved=0
Hi Igor,
Sorry for the late reply.
Igor,
Hi Sherry,
mode
-- 2.17.1
st
s.denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7Cpeng.fan%40nx p.co
m%7C
fbf069e4184b49805ff608d716792228%7C686ea1d3bc2b4c6fa92cd99c 5c301
635%7C
0%7C0%7C637002581830489188&sdata=2sLbnCK6jSV9a3NQZFK8i wc1r
lh5jSyAR
Regards, Peng.
I created a branch on github, you can access it at https://github.com/sherrysun1/u-boot-imx.git. It includes some patches which I tested for cdns3 driver on imx8qm/qxp, maybe useful to you. By the way, I also add device tree bindings in doc/device-tree-bindings/usb/ at my branch in github, in case you need. Feel free to let me know if any problems.
Thanks
Igor Opaniuk
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fua. li
nke
din.com%2Fin%2Fiopaniuk&data=02%7C01%7Cpeng.fan%40nxp.co m%7
Cfbf069e4184b49805ff608d716792228%7C686ea1d3bc2b4c6fa92cd99 c5c30
1635%7C0%7C0%7C637002581830489188&sdata=xgOmj3btCYHz8 akdK
participants (5)
Igor Opaniuk
Peng Fan
Sherry Sun
sherry sun
