[U-Boot] [PATCH v1 0/3] ARM: pinctrl: Provide pinctrl driver for Vybrid (vf610)
This series enables pinctrl driver for the vybrid NXP SoC.
Changes in v1: - None
Lukasz Majewski (3): ARM: vybrid: Provide pinctrl driver for Vybrid (vf610) ARM: DTS: Add iomux node to vf.dtsi for Vybrid devices ARM: DTS: Provide pinfunc definitions for vybrid vf610 from Linux kernel
arch/arm/dts/vf.dtsi | 5 + arch/arm/dts/vf610-pinfunc.h | 810 ++++++++++++++++++++++++++++++++++++ drivers/pinctrl/nxp/Kconfig | 14 + drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-vf610.c | 41 ++ 5 files changed, 871 insertions(+) create mode 100644 arch/arm/dts/vf610-pinfunc.h create mode 100644 drivers/pinctrl/nxp/pinctrl-vf610.c
This implementation comply with other iMX devices pinctrl drivers already available in U-boot.
Signed-off-by: Lukasz Majewski lukma@denx.de
drivers/pinctrl/nxp/Kconfig | 14 +++++++++++++ drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-vf610.c | 41 +++++++++++++++++++++++++++++++++++++ 3 files changed, 56 insertions(+) create mode 100644 drivers/pinctrl/nxp/pinctrl-vf610.c
diff --git a/drivers/pinctrl/nxp/Kconfig b/drivers/pinctrl/nxp/Kconfig index 799d1d2465bd..f1d5a5c50d39 100644 --- a/drivers/pinctrl/nxp/Kconfig +++ b/drivers/pinctrl/nxp/Kconfig @@ -74,3 +74,17 @@ config PINCTRL_IMX8 is different from the linux one, this is a simple implementation, only parses the 'fsl,pins' property and configures related registers. + +config PINCTRL_VYBRID + bool "Vybrid (vf610) pinctrl driver" + depends on ARCH_VF610 && PINCTRL_FULL + select DEVRES + select PINCTRL_IMX + help + Say Y here to enable the Vybrid (vf610) pinctrl driver + + This provides a simple pinctrl driver for Vybrid SoC familiy, + vf610. This feature depends on device tree + configuration. This driver is different from the linux one, + this is a simple implementation, only parses the 'fsl,pins' + property and configure related registers. diff --git a/drivers/pinctrl/nxp/Makefile b/drivers/pinctrl/nxp/Makefile index 310b3b3a2e1e..891ee6e47747 100644 --- a/drivers/pinctrl/nxp/Makefile +++ b/drivers/pinctrl/nxp/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_PINCTRL_IMX7) += pinctrl-imx7.o obj-$(CONFIG_PINCTRL_IMX7ULP) += pinctrl-imx7ulp.o obj-$(CONFIG_PINCTRL_IMX_SCU) += pinctrl-scu.o obj-$(CONFIG_PINCTRL_IMX8) += pinctrl-imx8.o +obj-$(CONFIG_PINCTRL_VYBRID) += pinctrl-vf610.o diff --git a/drivers/pinctrl/nxp/pinctrl-vf610.c b/drivers/pinctrl/nxp/pinctrl-vf610.c new file mode 100644 index 000000000000..ae22c7a9ca4e --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-vf610.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> + +#include "pinctrl-imx.h" + +static struct imx_pinctrl_soc_info vf610_pinctrl_soc_info = { + .flags = SHARE_MUX_CONF_REG | ZERO_OFFSET_VALID, + .mux_mask = 0x700000, +}; + +static int vf610_pinctrl_probe(struct udevice *dev) +{ + struct imx_pinctrl_soc_info *info = + (struct imx_pinctrl_soc_info *)dev_get_driver_data(dev); + + return imx_pinctrl_probe(dev, info); +} + +static const struct udevice_id vf610_pinctrl_match[] = { + { .compatible = "fsl,vf610-iomuxc", + .data = (ulong)&vf610_pinctrl_soc_info }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(vf610_pinctrl) = { + .name = "vf610-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(vf610_pinctrl_match), + .probe = vf610_pinctrl_probe, + .remove = imx_pinctrl_remove, + .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv), + .ops = &imx_pinctrl_ops, + .flags = DM_FLAG_PRE_RELOC, +};
This node is in sync with v4.20-next tree: e4dda4f5a4df "x86/kaslr, ACPI/NUMA: avoid including asm/kaslr.h on arm64"
Signed-off-by: Lukasz Majewski lukma@denx.de ---
Changes in v1: None
arch/arm/dts/vf.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/vf.dtsi b/arch/arm/dts/vf.dtsi index 5198eee02419..103a74ac726b 100644 --- a/arch/arm/dts/vf.dtsi +++ b/arch/arm/dts/vf.dtsi @@ -89,6 +89,11 @@ status = "disabled"; };
+ iomuxc: iomuxc@40048000 { + compatible = "fsl,vf610-iomuxc"; + reg = <0x40048000 0x1000>; + }; + gpio0: gpio@40049000 { compatible = "fsl,vf610-gpio"; reg = <0x400ff000 0x40>;
This file is in sync with v4.20-next tree: e4dda4f5a4df "x86/kaslr, ACPI/NUMA: avoid including asm/kaslr.h on arm64"
Changes in v1: None
arch/arm/dts/vf610-pinfunc.h | 810 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 810 insertions(+) create mode 100644 arch/arm/dts/vf610-pinfunc.h
diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610-pinfunc.h new file mode 100644 index 000000000000..fcad7132c871 --- /dev/null +++ b/arch/arm/dts/vf610-pinfunc.h @@ -0,0 +1,810 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DTS_VF610_PINFUNC_H +#define __DTS_VF610_PINFUNC_H + +/* + * The pin function ID for VF610 is a tuple of: + * <mux_reg input_reg mux_mode input_val> + */ + +#define ALT0 0x0 +#define ALT1 0x1 +#define ALT2 0x2 +#define ALT3 0x3 +#define ALT4 0x4 +#define ALT5 0x5 +#define ALT6 0x6 +#define ALT7 0x7 + + +#define VF610_PAD_PTA6__GPIO_0 0x000 0x000 ALT0 0x0 +#define VF610_PAD_PTA6__RMII_CLKOUT 0x000 0x000 ALT1 0x0 +#define VF610_PAD_PTA6__RMII_CLKIN 0x000 0x2F0 ALT2 0x0 +#define VF610_PAD_PTA6__DCU1_TCON11 0x000 0x000 ALT4 0x0 +#define VF610_PAD_PTA6__DCU1_R2 0x000 0x000 ALT7 0x0 +#define VF610_PAD_PTA8__GPIO_1 0x004 0x000 ALT0 0x0 +#define VF610_PAD_PTA8__TCLK 0x004 0x000 ALT1 0x0 +#define VF610_PAD_PTA8__DCU0_R0 0x004 0x000 ALT4 0x0 +#define VF610_PAD_PTA8__MLB_CLK 0x004 0x354 ALT7 0x0 +#define VF610_PAD_PTA9__GPIO_2 0x008 0x000 ALT0 0x0 +#define VF610_PAD_PTA9__TDI 0x008 0x000 ALT1 0x0 +#define VF610_PAD_PTA9__RMII_CLKOUT 0x008 0x000 ALT2 0x0 +#define VF610_PAD_PTA9__RMII_CLKIN 0x008 0x2F0 ALT3 0x1 +#define VF610_PAD_PTA9__DCU0_R1 0x008 0x000 ALT4 0x0 +#define VF610_PAD_PTA9__WDOG_B 0x008 0x000 ALT6 0x0 +#define VF610_PAD_PTA10__GPIO_3 0x00C 0x000 ALT0 0x0 +#define VF610_PAD_PTA10__TDO 0x00C 0x000 ALT1 0x0 +#define VF610_PAD_PTA10__EXT_AUDIO_MCLK 0x00C 0x2EC ALT2 0x0 +#define VF610_PAD_PTA10__DCU0_G0 0x00C 0x000 ALT4 0x0 +#define VF610_PAD_PTA10__ENET_TS_CLKIN 0x00C 0x2F4 ALT6 0x0 +#define VF610_PAD_PTA10__MLB_SIGNAL 0x00C 0x35C ALT7 0x0 +#define VF610_PAD_PTA11__GPIO_4 0x010 0x000 ALT0 0x0 +#define VF610_PAD_PTA11__TMS 0x010 0x000 ALT1 0x0 +#define VF610_PAD_PTA11__DCU0_G1 0x010 0x000 ALT4 0x0 +#define VF610_PAD_PTA11__MLB_DATA 0x010 0x358 ALT7 0x0 +#define VF610_PAD_PTA12__GPIO_5 0x014 0x000 ALT0 0x0 +#define VF610_PAD_PTA12__TRACECK 0x014 0x000 ALT1 0x0 +#define VF610_PAD_PTA12__EXT_AUDIO_MCLK 0x014 0x2EC ALT2 0x1 +#define VF610_PAD_PTA12__VIU_DATA13 0x014 0x000 ALT6 0x0 +#define VF610_PAD_PTA12__I2C0_SCL 0x014 0x33C ALT7 0x0 +#define VF610_PAD_PTA16__GPIO_6 0x018 0x000 ALT0 0x0 +#define VF610_PAD_PTA16__TRACED0 0x018 0x000 ALT1 0x0 +#define VF610_PAD_PTA16__USB0_VBUS_EN 0x018 0x000 ALT2 0x0 +#define VF610_PAD_PTA16__ADC1_SE0 0x018 0x000 ALT3 0x0 +#define VF610_PAD_PTA16__LCD29 0x018 0x000 ALT4 0x0 +#define VF610_PAD_PTA16__SAI2_TX_BCLK 0x018 0x370 ALT5 0x0 +#define VF610_PAD_PTA16__VIU_DATA14 0x018 0x000 ALT6 0x0 +#define VF610_PAD_PTA16__I2C0_SDA 0x018 0x340 ALT7 0x0 +#define VF610_PAD_PTA17__GPIO_7 0x01C 0x000 ALT0 0x0 +#define VF610_PAD_PTA17__TRACED1 0x01C 0x000 ALT1 0x0 +#define VF610_PAD_PTA17__USB0_VBUS_OC 0x01C 0x000 ALT2 0x0 +#define VF610_PAD_PTA17__ADC1_SE1 0x01C 0x000 ALT3 0x0 +#define VF610_PAD_PTA17__LCD30 0x01C 0x000 ALT4 0x0 +#define VF610_PAD_PTA17__USB0_SOF_PULSE 0x01C 0x000 ALT5 0x0 +#define VF610_PAD_PTA17__VIU_DATA15 0x01C 0x000 ALT6 0x0 +#define VF610_PAD_PTA17__I2C1_SCL 0x01C 0x344 ALT7 0x0 +#define VF610_PAD_PTA18__GPIO_8 0x020 0x000 ALT0 0x0 +#define VF610_PAD_PTA18__TRACED2 0x020 0x000 ALT1 0x0 +#define VF610_PAD_PTA18__ADC0_SE0 0x020 0x000 ALT2 0x0 +#define VF610_PAD_PTA18__FTM1_QD_PHA 0x020 0x334 ALT3 0x0 +#define VF610_PAD_PTA18__LCD31 0x020 0x000 ALT4 0x0 +#define VF610_PAD_PTA18__SAI2_TX_DATA 0x020 0x000 ALT5 0x0 +#define VF610_PAD_PTA18__VIU_DATA16 0x020 0x000 ALT6 0x0 +#define VF610_PAD_PTA18__I2C1_SDA 0x020 0x348 ALT7 0x0 +#define VF610_PAD_PTA19__GPIO_9 0x024 0x000 ALT0 0x0 +#define VF610_PAD_PTA19__TRACED3 0x024 0x000 ALT1 0x0 +#define VF610_PAD_PTA19__ADC0_SE1 0x024 0x000 ALT2 0x0 +#define VF610_PAD_PTA19__FTM1_QD_PHB 0x024 0x338 ALT3 0x0 +#define VF610_PAD_PTA19__LCD32 0x024 0x000 ALT4 0x0 +#define VF610_PAD_PTA19__SAI2_TX_SYNC 0x024 0x000 ALT5 0x0 +#define VF610_PAD_PTA19__VIU_DATA17 0x024 0x000 ALT6 0x0 +#define VF610_PAD_PTA19__QSPI1_A_QSCK 0x024 0x374 ALT7 0x0 +#define VF610_PAD_PTA20__GPIO_10 0x028 0x000 ALT0 0x0 +#define VF610_PAD_PTA20__TRACED4 0x028 0x000 ALT1 0x0 +#define VF610_PAD_PTA20__LCD33 0x028 0x000 ALT4 0x0 +#define VF610_PAD_PTA20__UART3_TX 0x028 0x394 ALT6 0x0 +#define VF610_PAD_PTA20__DCU1_HSYNC 0x028 0x000 ALT7 0x0 +#define VF610_PAD_PTA21__GPIO_11 0x02C 0x000 ALT0 0x0 +#define VF610_PAD_PTA21__TRACED5 0x02C 0x000 ALT1 0x0 +#define VF610_PAD_PTA21__SAI2_RX_BCLK 0x02C 0x364 ALT5 0x0 +#define VF610_PAD_PTA21__UART3_RX 0x02C 0x390 ALT6 0x0 +#define VF610_PAD_PTA21__DCU1_VSYNC 0x02C 0x000 ALT7 0x0 +#define VF610_PAD_PTA22__GPIO_12 0x030 0x000 ALT0 0x0 +#define VF610_PAD_PTA22__TRACED6 0x030 0x000 ALT1 0x0 +#define VF610_PAD_PTA22__SAI2_RX_DATA 0x030 0x368 ALT5 0x0 +#define VF610_PAD_PTA22__I2C2_SCL 0x030 0x34C ALT6 0x0 +#define VF610_PAD_PTA22__DCU1_TAG 0x030 0x000 ALT7 0x0 +#define VF610_PAD_PTA23__GPIO_13 0x034 0x000 ALT0 0x0 +#define VF610_PAD_PTA23__TRACED7 0x034 0x000 ALT1 0x0 +#define VF610_PAD_PTA23__SAI2_RX_SYNC 0x034 0x36C ALT5 0x0 +#define VF610_PAD_PTA23__I2C2_SDA 0x034 0x350 ALT6 0x0 +#define VF610_PAD_PTA23__DCU1_DE 0x034 0x000 ALT7 0x0 +#define VF610_PAD_PTA24__GPIO_14 0x038 0x000 ALT0 0x0 +#define VF610_PAD_PTA24__TRACED8 0x038 0x000 ALT1 0x0 +#define VF610_PAD_PTA24__USB1_VBUS_EN 0x038 0x000 ALT2 0x0 +#define VF610_PAD_PTA24__ESDHC1_CLK 0x038 0x000 ALT5 0x0 +#define VF610_PAD_PTA24__DCU1_TCON4 0x038 0x000 ALT6 0x0 +#define VF610_PAD_PTA24__DDR_TEST_PAD_CTRL 0x038 0x000 ALT7 0x0 +#define VF610_PAD_PTA25__GPIO_15 0x03C 0x000 ALT0 0x0 +#define VF610_PAD_PTA25__TRACED9 0x03C 0x000 ALT1 0x0 +#define VF610_PAD_PTA25__USB1_VBUS_OC 0x03C 0x000 ALT2 0x0 +#define VF610_PAD_PTA25__ESDHC1_CMD 0x03C 0x000 ALT5 0x0 +#define VF610_PAD_PTA25__DCU1_TCON5 0x03C 0x000 ALT6 0x0 +#define VF610_PAD_PTA26__GPIO_16 0x040 0x000 ALT0 0x0 +#define VF610_PAD_PTA26__TRACED10 0x040 0x000 ALT1 0x0 +#define VF610_PAD_PTA26__SAI3_TX_BCLK 0x040 0x000 ALT2 0x0 +#define VF610_PAD_PTA26__ESDHC1_DAT0 0x040 0x000 ALT5 0x0 +#define VF610_PAD_PTA26__DCU1_TCON6 0x040 0x000 ALT6 0x0 +#define VF610_PAD_PTA27__GPIO_17 0x044 0x000 ALT0 0x0 +#define VF610_PAD_PTA27__TRACED11 0x044 0x000 ALT1 0x0 +#define VF610_PAD_PTA27__SAI3_RX_BCLK 0x044 0x000 ALT2 0x0 +#define VF610_PAD_PTA27__ESDHC1_DAT1 0x044 0x000 ALT5 0x0 +#define VF610_PAD_PTA27__DCU1_TCON7 0x044 0x000 ALT6 0x0 +#define VF610_PAD_PTA28__GPIO_18 0x048 0x000 ALT0 0x0 +#define VF610_PAD_PTA28__TRACED12 0x048 0x000 ALT1 0x0 +#define VF610_PAD_PTA28__SAI3_RX_DATA 0x048 0x000 ALT2 0x0 +#define VF610_PAD_PTA28__ENET1_1588_TMR0 0x048 0x000 ALT3 0x0 +#define VF610_PAD_PTA28__UART4_TX 0x048 0x000 ALT4 0x0 +#define VF610_PAD_PTA28__ESDHC1_DATA2 0x048 0x000 ALT5 0x0 +#define VF610_PAD_PTA28__DCU1_TCON8 0x048 0x000 ALT6 0x0 +#define VF610_PAD_PTA29__GPIO_19 0x04C 0x000 ALT0 0x0 +#define VF610_PAD_PTA29__TRACED13 0x04C 0x000 ALT1 0x0 +#define VF610_PAD_PTA29__SAI3_TX_DATA 0x04C 0x000 ALT2 0x0 +#define VF610_PAD_PTA29__ENET1_1588_TMR1 0x04C 0x000 ALT3 0x0 +#define VF610_PAD_PTA29__UART4_RX 0x04C 0x000 ALT4 0x0 +#define VF610_PAD_PTA29__ESDHC1_DAT3 0x04C 0x000 ALT5 0x0 +#define VF610_PAD_PTA29__DCU1_TCON9 0x04C 0x000 ALT6 0x0 +#define VF610_PAD_PTA30__GPIO_20 0x050 0x000 ALT0 0x0 +#define VF610_PAD_PTA30__TRACED14 0x050 0x000 ALT1 0x0 +#define VF610_PAD_PTA30__SAI3_RX_SYNC 0x050 0x000 ALT2 0x0 +#define VF610_PAD_PTA30__ENET1_1588_TMR2 0x050 0x000 ALT3 0x0 +#define VF610_PAD_PTA30__UART4_RTS 0x050 0x000 ALT4 0x0 +#define VF610_PAD_PTA30__I2C3_SCL 0x050 0x000 ALT5 0x0 +#define VF610_PAD_PTA30__UART3_TX 0x050 0x394 ALT7 0x1 +#define VF610_PAD_PTA31__GPIO_21 0x054 0x000 ALT0 0x0 +#define VF610_PAD_PTA31__TRACED15 0x054 0x000 ALT1 0x0 +#define VF610_PAD_PTA31__SAI3_TX_SYNC 0x054 0x000 ALT2 0x0 +#define VF610_PAD_PTA31__ENET1_1588_TMR3 0x054 0x000 ALT3 0x0 +#define VF610_PAD_PTA31__UART4_CTS 0x054 0x000 ALT4 0x0 +#define VF610_PAD_PTA31__I2C3_SDA 0x054 0x000 ALT5 0x0 +#define VF610_PAD_PTA31__UART3_RX 0x054 0x390 ALT7 0x1 +#define VF610_PAD_PTB0__GPIO_22 0x058 0x000 ALT0 0x0 +#define VF610_PAD_PTB0__FTM0_CH0 0x058 0x000 ALT1 0x0 +#define VF610_PAD_PTB0__ADC0_SE2 0x058 0x000 ALT2 0x0 +#define VF610_PAD_PTB0__TRACE_CTL 0x058 0x000 ALT3 0x0 +#define VF610_PAD_PTB0__LCD34 0x058 0x000 ALT4 0x0 +#define VF610_PAD_PTB0__SAI2_RX_BCLK 0x058 0x364 ALT5 0x1 +#define VF610_PAD_PTB0__VIU_DATA18 0x058 0x000 ALT6 0x0 +#define VF610_PAD_PTB0__QSPI1_A_QPCS0 0x058 0x000 ALT7 0x0 +#define VF610_PAD_PTB1__GPIO_23 0x05C 0x000 ALT0 0x0 +#define VF610_PAD_PTB1__FTM0_CH1 0x05C 0x000 ALT1 0x0 +#define VF610_PAD_PTB1__ADC0_SE3 0x05C 0x000 ALT2 0x0 +#define VF610_PAD_PTB1__SRC_RCON30 0x05C 0x000 ALT3 0x0 +#define VF610_PAD_PTB1__LCD35 0x05C 0x000 ALT4 0x0 +#define VF610_PAD_PTB1__SAI2_RX_DATA 0x05C 0x368 ALT5 0x1 +#define VF610_PAD_PTB1__VIU_DATA19 0x05C 0x000 ALT6 0x0 +#define VF610_PAD_PTB1__QSPI1_A_DATA3 0x05C 0x000 ALT7 0x0 +#define VF610_PAD_PTB2__GPIO_24 0x060 0x000 ALT0 0x0 +#define VF610_PAD_PTB2__FTM0_CH2 0x060 0x000 ALT1 0x0 +#define VF610_PAD_PTB2__ADC1_SE2 0x060 0x000 ALT2 0x0 +#define VF610_PAD_PTB2__SRC_RCON31 0x060 0x000 ALT3 0x0 +#define VF610_PAD_PTB2__LCD36 0x060 0x000 ALT4 0x0 +#define VF610_PAD_PTB2__SAI2_RX_SYNC 0x060 0x36C ALT5 0x1 +#define VF610_PAD_PTB2__VIDEO_IN0_DATA20 0x060 0x000 ALT6 0x0 +#define VF610_PAD_PTB2__QSPI1_A_DATA2 0x060 0x000 ALT7 0x0 +#define VF610_PAD_PTB3__GPIO_25 0x064 0x000 ALT0 0x0 +#define VF610_PAD_PTB3__FTM0_CH3 0x064 0x000 ALT1 0x0 +#define VF610_PAD_PTB3__ADC1_SE3 0x064 0x000 ALT2 0x0 +#define VF610_PAD_PTB3__PDB_EXTRIG 0x064 0x000 ALT3 0x0 +#define VF610_PAD_PTB3__LCD37 0x064 0x000 ALT4 0x0 +#define VF610_PAD_PTB3__VIU_DATA21 0x064 0x000 ALT6 0x0 +#define VF610_PAD_PTB3__QSPI1_A_DATA1 0x064 0x000 ALT7 0x0 +#define VF610_PAD_PTB4__GPIO_26 0x068 0x000 ALT0 0x0 +#define VF610_PAD_PTB4__FTM0_CH4 0x068 0x000 ALT1 0x0 +#define VF610_PAD_PTB4__UART1_TX 0x068 0x380 ALT2 0x0 +#define VF610_PAD_PTB4__ADC0_SE4 0x068 0x000 ALT3 0x0 +#define VF610_PAD_PTB4__LCD38 0x068 0x000 ALT4 0x0 +#define VF610_PAD_PTB4__VIU_FID 0x068 0x3A8 ALT5 0x0 +#define VF610_PAD_PTB4__VIU_DATA22 0x068 0x000 ALT6 0x0 +#define VF610_PAD_PTB4__QSPI1_A_DATA0 0x068 0x000 ALT7 0x0 +#define VF610_PAD_PTB5__GPIO_27 0x06C 0x000 ALT0 0x0 +#define VF610_PAD_PTB5__FTM0_CH5 0x06C 0x000 ALT1 0x0 +#define VF610_PAD_PTB5__UART1_RX 0x06C 0x37C ALT2 0x0 +#define VF610_PAD_PTB5__ADC1_SE4 0x06C 0x000 ALT3 0x0 +#define VF610_PAD_PTB5__LCD39 0x06C 0x000 ALT4 0x0 +#define VF610_PAD_PTB5__VIU_DE 0x06C 0x3A4 ALT5 0x0 +#define VF610_PAD_PTB5__QSPI1_A_DQS 0x06C 0x000 ALT7 0x0 +#define VF610_PAD_PTB6__GPIO_28 0x070 0x000 ALT0 0x0 +#define VF610_PAD_PTB6__FTM0_CH6 0x070 0x000 ALT1 0x0 +#define VF610_PAD_PTB6__UART1_RTS 0x070 0x000 ALT2 0x0 +#define VF610_PAD_PTB6__QSPI0_QPCS1_A 0x070 0x000 ALT3 0x0 +#define VF610_PAD_PTB6__LCD_LCD40 0x070 0x000 ALT4 0x0 +#define VF610_PAD_PTB6__FB_CLKOUT 0x070 0x000 ALT5 0x0 +#define VF610_PAD_PTB6__VIU_HSYNC 0x070 0x000 ALT6 0x0 +#define VF610_PAD_PTB6__UART2_TX 0x070 0x38C ALT7 0x0 +#define VF610_PAD_PTB7__GPIO_29 0x074 0x000 ALT0 0x0 +#define VF610_PAD_PTB7__FTM0_CH7 0x074 0x000 ALT1 0x0 +#define VF610_PAD_PTB7__UART1_CTS 0x074 0x378 ALT2 0x0 +#define VF610_PAD_PTB7__QSPI0_B_QPCS1 0x074 0x000 ALT3 0x0 +#define VF610_PAD_PTB7__LCD41 0x074 0x000 ALT4 0x0 +#define VF610_PAD_PTB7__VIU_VSYNC 0x074 0x000 ALT6 0x0 +#define VF610_PAD_PTB7__UART2_RX 0x074 0x388 ALT7 0x0 +#define VF610_PAD_PTB8__GPIO_30 0x078 0x000 ALT0 0x0 +#define VF610_PAD_PTB8__FTM1_CH0 0x078 0x32C ALT1 0x0 +#define VF610_PAD_PTB8__FTM1_QD_PHA 0x078 0x334 ALT3 0x1 +#define VF610_PAD_PTB8__VIU_DE 0x078 0x3A4 ALT5 0x1 +#define VF610_PAD_PTB8__DCU1_R6 0x078 0x000 ALT7 0x0 +#define VF610_PAD_PTB9__GPIO_31 0x07C 0x000 ALT0 0x0 +#define VF610_PAD_PTB9__FTM1_CH1 0x07C 0x330 ALT1 0x0 +#define VF610_PAD_PTB9__FTM1_QD_PHB 0x07C 0x338 ALT3 0x1 +#define VF610_PAD_PTB9__DCU1_R7 0x07C 0x000 ALT7 0x0 +#define VF610_PAD_PTB10__GPIO_32 0x080 0x000 ALT0 0x0 +#define VF610_PAD_PTB10__UART0_TX 0x080 0x000 ALT1 0x0 +#define VF610_PAD_PTB10__DCU0_TCON4 0x080 0x000 ALT4 0x0 +#define VF610_PAD_PTB10__VIU_DE 0x080 0x3A4 ALT5 0x2 +#define VF610_PAD_PTB10__CKO1 0x080 0x000 ALT6 0x0 +#define VF610_PAD_PTB10__ENET_TS_CLKIN 0x080 0x2F4 ALT7 0x1 +#define VF610_PAD_PTB11__GPIO_33 0x084 0x000 ALT0 0x0 +#define VF610_PAD_PTB11__UART0_RX 0x084 0x000 ALT1 0x0 +#define VF610_PAD_PTB11__DCU0_TCON5 0x084 0x000 ALT4 0x0 +#define VF610_PAD_PTB11__SNVS_ALARM_OUT_B 0x084 0x000 ALT5 0x0 +#define VF610_PAD_PTB11__CKO2 0x084 0x000 ALT6 0x0 +#define VF610_PAD_PTB11_ENET0_1588_TMR0 0x084 0x304 ALT7 0x0 +#define VF610_PAD_PTB12__GPIO_34 0x088 0x000 ALT0 0x0 +#define VF610_PAD_PTB12__UART0_RTS 0x088 0x000 ALT1 0x0 +#define VF610_PAD_PTB12__DSPI0_CS5 0x088 0x000 ALT3 0x0 +#define VF610_PAD_PTB12__DCU0_TCON6 0x088 0x000 ALT4 0x0 +#define VF610_PAD_PTB12__FB_AD1 0x088 0x000 ALT5 0x0 +#define VF610_PAD_PTB12__NMI 0x088 0x000 ALT6 0x0 +#define VF610_PAD_PTB12__ENET0_1588_TMR1 0x088 0x308 ALT7 0x0 +#define VF610_PAD_PTB13__GPIO_35 0x08C 0x000 ALT0 0x0 +#define VF610_PAD_PTB13__UART0_CTS 0x08C 0x000 ALT1 0x0 +#define VF610_PAD_PTB13__DSPI0_CS4 0x08C 0x000 ALT3 0x0 +#define VF610_PAD_PTB13__DCU0_TCON7 0x08C 0x000 ALT4 0x0 +#define VF610_PAD_PTB13__FB_AD0 0x08C 0x000 ALT5 0x0 +#define VF610_PAD_PTB13__TRACE_CTL 0x08C 0x000 ALT6 0x0 +#define VF610_PAD_PTB14__GPIO_36 0x090 0x000 ALT0 0x0 +#define VF610_PAD_PTB14__CAN0_RX 0x090 0x000 ALT1 0x0 +#define VF610_PAD_PTB14__I2C0_SCL 0x090 0x33C ALT2 0x1 +#define VF610_PAD_PTB14__DCU0_TCON8 0x090 0x000 ALT4 0x0 +#define VF610_PAD_PTB14__DCU1_PCLK 0x090 0x000 ALT7 0x0 +#define VF610_PAD_PTB15__GPIO_37 0x094 0x000 ALT0 0x0 +#define VF610_PAD_PTB15__CAN0_TX 0x094 0x000 ALT1 0x0 +#define VF610_PAD_PTB15__I2C0_SDA 0x094 0x340 ALT2 0x1 +#define VF610_PAD_PTB15__DCU0_TCON9 0x094 0x000 ALT4 0x0 +#define VF610_PAD_PTB15__VIU_PIX_CLK 0x094 0x3AC ALT7 0x0 +#define VF610_PAD_PTB16__GPIO_38 0x098 0x000 ALT0 0x0 +#define VF610_PAD_PTB16__CAN1_RX 0x098 0x000 ALT1 0x0 +#define VF610_PAD_PTB16__I2C1_SCL 0x098 0x344 ALT2 0x1 +#define VF610_PAD_PTB16__DCU0_TCON10 0x098 0x000 ALT4 0x0 +#define VF610_PAD_PTB17__GPIO_39 0x09C 0x000 ALT0 0x0 +#define VF610_PAD_PTB17__CAN1_TX 0x09C 0x000 ALT1 0x0 +#define VF610_PAD_PTB17__I2C1_SDA 0x09C 0x348 ALT2 0x1 +#define VF610_PAD_PTB17__DCU0_TCON11 0x09C 0x000 ALT4 0x0 +#define VF610_PAD_PTB18__GPIO_40 0x0A0 0x000 ALT0 0x0 +#define VF610_PAD_PTB18__DSPI0_CS1 0x0A0 0x000 ALT1 0x0 +#define VF610_PAD_PTB18__EXT_AUDIO_MCLK 0x0A0 0x2EC ALT2 0x2 +#define VF610_PAD_PTB18__VIU_DATA9 0x0A0 0x000 ALT6 0x0 +#define VF610_PAD_PTB19__GPIO_41 0x0A4 0x000 ALT0 0x0 +#define VF610_PAD_PTB19__DSPI0_CS0 0x0A4 0x000 ALT1 0x0 +#define VF610_PAD_PTB19__VIU_DATA10 0x0A4 0x000 ALT6 0x0 +#define VF610_PAD_PTB20__GPIO_42 0x0A8 0x000 ALT0 0x0 +#define VF610_PAD_PTB20__DSPI0_SIN 0x0A8 0x000 ALT1 0x0 +#define VF610_PAD_PTB20__LCD42 0x0A8 0x000 ALT4 0x0 +#define VF610_PAD_PTB20__VIU_DATA11 0x0A8 0x000 ALT6 0x0 +#define VF610_PAD_PTB21__GPIO_43 0x0AC 0x000 ALT0 0x0 +#define VF610_PAD_PTB21__DSPI0_SOUT 0x0AC 0x000 ALT1 0x0 +#define VF610_PAD_PTB21__LCD43 0x0AC 0x000 ALT4 0x0 +#define VF610_PAD_PTB21__VIU_DATA12 0x0AC 0x000 ALT6 0x0 +#define VF610_PAD_PTB21__DCU1_PCLK 0x0AC 0x000 ALT7 0x0 +#define VF610_PAD_PTB22__GPIO_44 0x0B0 0x000 ALT0 0x0 +#define VF610_PAD_PTB22__DSPI0_SCK 0x0B0 0x000 ALT1 0x0 +#define VF610_PAD_PTB22__VLCD 0x0B0 0x000 ALT4 0x0 +#define VF610_PAD_PTB22__VIU_FID 0x0B0 0x3A8 ALT5 0x1 +#define VF610_PAD_PTC0__GPIO_45 0x0B4 0x000 ALT0 0x0 +#define VF610_PAD_PTC0__ENET_RMII0_MDC 0x0B4 0x000 ALT1 0x0 +#define VF610_PAD_PTC0__FTM1_CH0 0x0B4 0x32C ALT2 0x1 +#define VF610_PAD_PTC0__DSPI0_CS3 0x0B4 0x000 ALT3 0x0 +#define VF610_PAD_PTC0__ESAI_SCKT 0x0B4 0x310 ALT4 0x0 +#define VF610_PAD_PTC0__ESDHC0_CLK 0x0B4 0x000 ALT5 0x0 +#define VF610_PAD_PTC0__VIU_DATA0 0x0B4 0x000 ALT6 0x0 +#define VF610_PAD_PTC0__SRC_RCON18 0x0B4 0x398 ALT7 0x0 +#define VF610_PAD_PTC1__GPIO_46 0x0B8 0x000 ALT0 0x0 +#define VF610_PAD_PTC1__ENET_RMII0_MDIO 0x0B8 0x000 ALT1 0x0 +#define VF610_PAD_PTC1__FTM1_CH1 0x0B8 0x330 ALT2 0x1 +#define VF610_PAD_PTC1__DSPI0_CS2 0x0B8 0x000 ALT3 0x0 +#define VF610_PAD_PTC1__ESAI_FST 0x0B8 0x30C ALT4 0x0 +#define VF610_PAD_PTC1__ESDHC0_CMD 0x0B8 0x000 ALT5 0x0 +#define VF610_PAD_PTC1__VIU_DATA1 0x0B8 0x000 ALT6 0x0 +#define VF610_PAD_PTC1__SRC_RCON19 0x0B8 0x39C ALT7 0x0 +#define VF610_PAD_PTC2__GPIO_47 0x0BC 0x000 ALT0 0x0 +#define VF610_PAD_PTC2__ENET_RMII0_CRS 0x0BC 0x000 ALT1 0x0 +#define VF610_PAD_PTC2__UART1_TX 0x0BC 0x380 ALT2 0x1 +#define VF610_PAD_PTC2__ESAI_SDO0 0x0BC 0x314 ALT4 0x0 +#define VF610_PAD_PTC2__ESDHC0_DAT0 0x0BC 0x000 ALT5 0x0 +#define VF610_PAD_PTC2__VIU_DATA2 0x0BC 0x000 ALT6 0x0 +#define VF610_PAD_PTC2__SRC_RCON20 0x0BC 0x3A0 ALT7 0x0 +#define VF610_PAD_PTC3__GPIO_48 0x0C0 0x000 ALT0 0x0 +#define VF610_PAD_PTC3__ENET_RMII0_RXD1 0x0C0 0x000 ALT1 0x0 +#define VF610_PAD_PTC3__UART1_RX 0x0C0 0x37C ALT2 0x1 +#define VF610_PAD_PTC3__ESAI_SDO1 0x0C0 0x318 ALT4 0x0 +#define VF610_PAD_PTC3__ESDHC0_DAT1 0x0C0 0x000 ALT5 0x0 +#define VF610_PAD_PTC3__VIU_DATA3 0x0C0 0x000 ALT6 0x0 +#define VF610_PAD_PTC3__DCU0_R0 0x0C0 0x000 ALT7 0x0 +#define VF610_PAD_PTC4__GPIO_49 0x0C4 0x000 ALT0 0x0 +#define VF610_PAD_PTC4__ENET_RMII0_RXD0 0x0C4 0x000 ALT1 0x0 +#define VF610_PAD_PTC4__UART1_RTS 0x0C4 0x000 ALT2 0x0 +#define VF610_PAD_PTC4__DSPI1_CS1 0x0C4 0x000 ALT3 0x0 +#define VF610_PAD_PTC4__ESAI_SDO2 0x0C4 0x31C ALT4 0x0 +#define VF610_PAD_PTC4__ESDHC0_DAT2 0x0C4 0x000 ALT5 0x0 +#define VF610_PAD_PTC4__VIU_DATA4 0x0C4 0x000 ALT6 0x0 +#define VF610_PAD_PTC4__DCU0_R1 0x0C4 0x000 ALT7 0x0 +#define VF610_PAD_PTC5__GPIO_50 0x0C8 0x000 ALT0 0x0 +#define VF610_PAD_PTC5__ENET_RMII0_RXER 0x0C8 0x000 ALT1 0x0 +#define VF610_PAD_PTC5__UART1_CTS 0x0C8 0x378 ALT2 0x1 +#define VF610_PAD_PTC5__DSPI1_CS0 0x0C8 0x300 ALT3 0x0 +#define VF610_PAD_PTC5__ESAI_SDO3 0x0C8 0x320 ALT4 0x0 +#define VF610_PAD_PTC5__ESDHC0_DAT3 0x0C8 0x000 ALT5 0x0 +#define VF610_PAD_PTC5__VIU_DATA5 0x0C8 0x000 ALT6 0x0 +#define VF610_PAD_PTC5__DCU0_G0 0x0C8 0x000 ALT7 0x0 +#define VF610_PAD_PTC6__GPIO_51 0x0CC 0x000 ALT0 0x0 +#define VF610_PAD_PTC6__ENET_RMII0_TXD1 0x0CC 0x000 ALT1 0x0 +#define VF610_PAD_PTC6__DSPI1_SIN 0x0CC 0x2FC ALT3 0x0 +#define VF610_PAD_PTC6__ESAI_SDI0 0x0CC 0x328 ALT4 0x0 +#define VF610_PAD_PTC6__ESDHC0_WP 0x0CC 0x000 ALT5 0x0 +#define VF610_PAD_PTC6__VIU_DATA6 0x0CC 0x000 ALT6 0x0 +#define VF610_PAD_PTC6__DCU0_G1 0x0CC 0x000 ALT7 0x0 +#define VF610_PAD_PTC7__GPIO_52 0x0D0 0x000 ALT0 0x0 +#define VF610_PAD_PTC7__ENET_RMII0_TXD0 0x0D0 0x000 ALT1 0x0 +#define VF610_PAD_PTC7__DSPI1_SOUT 0x0D0 0x000 ALT3 0x0 +#define VF610_PAD_PTC7__ESAI_SDI1 0x0D0 0x324 ALT4 0x0 +#define VF610_PAD_PTC7__VIU_DATA7 0x0D0 0x000 ALT6 0x0 +#define VF610_PAD_PTC7__DCU0_B0 0x0D0 0x000 ALT7 0x0 +#define VF610_PAD_PTC8__GPIO_53 0x0D4 0x000 ALT0 0x0 +#define VF610_PAD_PTC8__ENET_RMII0_TXEN 0x0D4 0x000 ALT1 0x0 +#define VF610_PAD_PTC8__DSPI1_SCK 0x0D4 0x2F8 ALT3 0x0 +#define VF610_PAD_PTC8__VIU_DATA8 0x0D4 0x000 ALT6 0x0 +#define VF610_PAD_PTC8__DCU0_B1 0x0D4 0x000 ALT7 0x0 +#define VF610_PAD_PTC9__GPIO_54 0x0D8 0x000 ALT0 0x0 +#define VF610_PAD_PTC9__ENET_RMII1_MDC 0x0D8 0x000 ALT1 0x0 +#define VF610_PAD_PTC9__ESAI_SCKT 0x0D8 0x310 ALT3 0x1 +#define VF610_PAD_PTC9__MLB_CLK 0x0D8 0x354 ALT6 0x1 +#define VF610_PAD_PTC9__DEBUG_OUT0 0x0D8 0x000 ALT7 0x0 +#define VF610_PAD_PTC10__GPIO_55 0x0DC 0x000 ALT0 0x0 +#define VF610_PAD_PTC10__ENET_RMII1_MDIO 0x0DC 0x000 ALT1 0x0 +#define VF610_PAD_PTC10__ESAI_FST 0x0DC 0x30C ALT3 0x1 +#define VF610_PAD_PTC10__MLB_SIGNAL 0x0DC 0x35C ALT6 0x1 +#define VF610_PAD_PTC10__DEBUG_OUT1 0x0DC 0x000 ALT7 0x0 +#define VF610_PAD_PTC11__GPIO_56 0x0E0 0x000 ALT0 0x0 +#define VF610_PAD_PTC11__ENET_RMII1_CRS 0x0E0 0x000 ALT1 0x0 +#define VF610_PAD_PTC11__ESAI_SDO0 0x0E0 0x314 ALT3 0x1 +#define VF610_PAD_PTC11__MLB_DATA 0x0E0 0x358 ALT6 0x1 +#define VF610_PAD_PTC11__DEBUG_OUT 0x0E0 0x000 ALT7 0x0 +#define VF610_PAD_PTC12__GPIO_57 0x0E4 0x000 ALT0 0x0 +#define VF610_PAD_PTC12__ENET_RMII1_RXD1 0x0E4 0x000 ALT1 0x0 +#define VF610_PAD_PTC12__ESAI_SDO1 0x0E4 0x318 ALT3 0x1 +#define VF610_PAD_PTC12__SAI2_TX_BCLK 0x0E4 0x370 ALT5 0x1 +#define VF610_PAD_PTC12__DEBUG_OUT3 0x0E4 0x000 ALT7 0x0 +#define VF610_PAD_PTC13__GPIO_58 0x0E8 0x000 ALT0 0x0 +#define VF610_PAD_PTC13__ENET_RMII1_RXD0 0x0E8 0x000 ALT1 0x0 +#define VF610_PAD_PTC13__ESAI_SDO2 0x0E8 0x31C ALT3 0x1 +#define VF610_PAD_PTC13__SAI2_RX_BCLK 0x0E8 0x364 ALT5 0x2 +#define VF610_PAD_PTC13__DEBUG_OUT4 0x0E8 0x000 ALT7 0x0 +#define VF610_PAD_PTC14__GPIO_59 0x0EC 0x000 ALT0 0x0 +#define VF610_PAD_PTC14__ENET_RMII1_RXER 0x0EC 0x000 ALT1 0x0 +#define VF610_PAD_PTC14__ESAI_SDO3 0x0EC 0x320 ALT3 0x1 +#define VF610_PAD_PTC14__UART5_TX 0x0EC 0x000 ALT4 0x0 +#define VF610_PAD_PTC14__SAI2_RX_DATA 0x0EC 0x368 ALT5 0x2 +#define VF610_PAD_PTC14__ADC0_SE6 0x0EC 0x000 ALT6 0x0 +#define VF610_PAD_PTC14__DEBUG_OUT5 0x0EC 0x000 ALT7 0x0 +#define VF610_PAD_PTC15__GPIO_60 0x0F0 0x000 ALT0 0x0 +#define VF610_PAD_PTC15__ENET_RMII1_TXD1 0x0F0 0x000 ALT1 0x0 +#define VF610_PAD_PTC15__ESAI_SDI0 0x0F0 0x328 ALT3 0x1 +#define VF610_PAD_PTC15__UART5_RX 0x0F0 0x000 ALT4 0x0 +#define VF610_PAD_PTC15__SAI2_TX_DATA 0x0F0 0x000 ALT5 0x0 +#define VF610_PAD_PTC15__ADC0_SE7 0x0F0 0x000 ALT6 0x0 +#define VF610_PAD_PTC15__DEBUG_OUT6 0x0F0 0x000 ALT7 0x0 +#define VF610_PAD_PTC16__GPIO_61 0x0F4 0x000 ALT0 0x0 +#define VF610_PAD_PTC16__ENET_RMII1_TXD0 0x0F4 0x000 ALT1 0x0 +#define VF610_PAD_PTC16__ESAI_SDI1 0x0F4 0x324 ALT3 0x1 +#define VF610_PAD_PTC16__UART5_RTS 0x0F4 0x000 ALT4 0x0 +#define VF610_PAD_PTC16__SAI2_RX_SYNC 0x0F4 0x36C ALT5 0x2 +#define VF610_PAD_PTC16__ADC1_SE6 0x0F4 0x000 ALT6 0x0 +#define VF610_PAD_PTC16__DEBUG_OUT7 0x0F4 0x000 ALT7 0x0 +#define VF610_PAD_PTC17__GPIO_62 0x0F8 0x000 ALT0 0x0 +#define VF610_PAD_PTC17__ENET_RMII1_TXEN 0x0F8 0x000 ALT1 0x0 +#define VF610_PAD_PTC17__ADC1_SE7 0x0F8 0x000 ALT3 0x0 +#define VF610_PAD_PTC17__UART5_CTS 0x0F8 0x000 ALT4 0x0 +#define VF610_PAD_PTC17__SAI2_TX_SYNC 0x0F8 0x374 ALT5 0x1 +#define VF610_PAD_PTC17__USB1_SOF_PULSE 0x0F8 0x000 ALT6 0x0 +#define VF610_PAD_PTC17__DEBUG_OUT8 0x0F8 0x000 ALT7 0x0 +#define VF610_PAD_PTD31__GPIO_63 0x0FC 0x000 ALT0 0x0 +#define VF610_PAD_PTD31__FB_AD31 0x0FC 0x000 ALT1 0x0 +#define VF610_PAD_PTD31__NF_IO15 0x0FC 0x000 ALT2 0x0 +#define VF610_PAD_PTD31__FTM3_CH0 0x0FC 0x000 ALT4 0x0 +#define VF610_PAD_PTD31__DSPI2_CS1 0x0FC 0x000 ALT5 0x0 +#define VF610_PAD_PTD31__DEBUG_OUT9 0x0FC 0x000 ALT7 0x0 +#define VF610_PAD_PTD30__GPIO_64 0x100 0x000 ALT0 0x0 +#define VF610_PAD_PTD30__FB_AD30 0x100 0x000 ALT1 0x0 +#define VF610_PAD_PTD30__NF_IO14 0x100 0x000 ALT2 0x0 +#define VF610_PAD_PTD30__FTM3_CH1 0x100 0x000 ALT4 0x0 +#define VF610_PAD_PTD30__DSPI2_CS0 0x100 0x000 ALT5 0x0 +#define VF610_PAD_PTD30__DEBUG_OUT10 0x100 0x000 ALT7 0x0 +#define VF610_PAD_PTD29__GPIO_65 0x104 0x000 ALT0 0x0 +#define VF610_PAD_PTD29__FB_AD29 0x104 0x000 ALT1 0x0 +#define VF610_PAD_PTD29__NF_IO13 0x104 0x000 ALT2 0x0 +#define VF610_PAD_PTD29__FTM3_CH2 0x104 0x000 ALT4 0x0 +#define VF610_PAD_PTD29__DSPI2_SIN 0x104 0x000 ALT5 0x0 +#define VF610_PAD_PTD29__DEBUG_OUT11 0x104 0x000 ALT7 0x0 +#define VF610_PAD_PTD28__GPIO_66 0x108 0x000 ALT0 0x0 +#define VF610_PAD_PTD28__FB_AD28 0x108 0x000 ALT1 0x0 +#define VF610_PAD_PTD28__NF_IO12 0x108 0x000 ALT2 0x0 +#define VF610_PAD_PTD28__I2C2_SCL 0x108 0x34C ALT3 0x1 +#define VF610_PAD_PTD28__FTM3_CH3 0x108 0x000 ALT4 0x0 +#define VF610_PAD_PTD28__DSPI2_SOUT 0x108 0x000 ALT5 0x0 +#define VF610_PAD_PTD28__DEBUG_OUT12 0x108 0x000 ALT7 0x0 +#define VF610_PAD_PTD27__GPIO_67 0x10C 0x000 ALT0 0x0 +#define VF610_PAD_PTD27__FB_AD27 0x10C 0x000 ALT1 0x0 +#define VF610_PAD_PTD27__NF_IO11 0x10C 0x000 ALT2 0x0 +#define VF610_PAD_PTD27__I2C2_SDA 0x10C 0x350 ALT3 0x1 +#define VF610_PAD_PTD27__FTM3_CH4 0x10C 0x000 ALT4 0x0 +#define VF610_PAD_PTD27__DSPI2_SCK 0x10C 0x000 ALT5 0x0 +#define VF610_PAD_PTD27__DEBUG_OUT13 0x10C 0x000 ALT7 0x0 +#define VF610_PAD_PTD26__GPIO_68 0x110 0x000 ALT0 0x0 +#define VF610_PAD_PTD26__FB_AD26 0x110 0x000 ALT1 0x0 +#define VF610_PAD_PTD26__NF_IO10 0x110 0x000 ALT2 0x0 +#define VF610_PAD_PTD26__FTM3_CH5 0x110 0x000 ALT4 0x0 +#define VF610_PAD_PTD26__ESDHC1_WP 0x110 0x000 ALT5 0x0 +#define VF610_PAD_PTD26__DEBUG_OUT14 0x110 0x000 ALT7 0x0 +#define VF610_PAD_PTD25__GPIO_69 0x114 0x000 ALT0 0x0 +#define VF610_PAD_PTD25__FB_AD25 0x114 0x000 ALT1 0x0 +#define VF610_PAD_PTD25__NF_IO9 0x114 0x000 ALT2 0x0 +#define VF610_PAD_PTD25__FTM3_CH6 0x114 0x000 ALT4 0x0 +#define VF610_PAD_PTD25__DEBUG_OUT15 0x114 0x000 ALT7 0x0 +#define VF610_PAD_PTD24__GPIO_70 0x118 0x000 ALT0 0x0 +#define VF610_PAD_PTD24__FB_AD24 0x118 0x000 ALT1 0x0 +#define VF610_PAD_PTD24__NF_IO8 0x118 0x000 ALT2 0x0 +#define VF610_PAD_PTD24__FTM3_CH7 0x118 0x000 ALT4 0x0 +#define VF610_PAD_PTD24__DEBUG_OUT16 0x118 0x000 ALT7 0x0 +#define VF610_PAD_PTD23__GPIO_71 0x11C 0x000 ALT0 0x0 +#define VF610_PAD_PTD23__FB_AD23 0x11C 0x000 ALT1 0x0 +#define VF610_PAD_PTD23__NF_IO7 0x11C 0x000 ALT2 0x0 +#define VF610_PAD_PTD23__FTM2_CH0 0x11C 0x000 ALT3 0x0 +#define VF610_PAD_PTD23__ENET0_1588_TMR0 0x11C 0x304 ALT4 0x1 +#define VF610_PAD_PTD23__ESDHC0_DAT4 0x11C 0x000 ALT5 0x0 +#define VF610_PAD_PTD23__UART2_TX 0x11C 0x38C ALT6 0x1 +#define VF610_PAD_PTD23__DCU1_R3 0x11C 0x000 ALT7 0x0 +#define VF610_PAD_PTD22__GPIO_72 0x120 0x000 ALT0 0x0 +#define VF610_PAD_PTD22__FB_AD22 0x120 0x000 ALT1 0x0 +#define VF610_PAD_PTD22__NF_IO6 0x120 0x000 ALT2 0x0 +#define VF610_PAD_PTD22__FTM2_CH1 0x120 0x000 ALT3 0x0 +#define VF610_PAD_PTD22__ENET0_1588_TMR1 0x120 0x308 ALT4 0x1 +#define VF610_PAD_PTD22__ESDHC0_DAT5 0x120 0x000 ALT5 0x0 +#define VF610_PAD_PTD22__UART2_RX 0x120 0x388 ALT6 0x1 +#define VF610_PAD_PTD22__DCU1_R4 0x120 0x000 ALT7 0x0 +#define VF610_PAD_PTD21__GPIO_73 0x124 0x000 ALT0 0x0 +#define VF610_PAD_PTD21__FB_AD21 0x124 0x000 ALT1 0x0 +#define VF610_PAD_PTD21__NF_IO5 0x124 0x000 ALT2 0x0 +#define VF610_PAD_PTD21__ENET0_1588_TMR2 0x124 0x000 ALT4 0x0 +#define VF610_PAD_PTD21__ESDHC0_DAT6 0x124 0x000 ALT5 0x0 +#define VF610_PAD_PTD21__UART2_RTS 0x124 0x000 ALT6 0x0 +#define VF610_PAD_PTD21__DCU1_R5 0x124 0x000 ALT7 0x0 +#define VF610_PAD_PTD20__GPIO_74 0x128 0x000 ALT0 0x0 +#define VF610_PAD_PTD20__FB_AD20 0x128 0x000 ALT1 0x0 +#define VF610_PAD_PTD20__NF_IO4 0x128 0x000 ALT2 0x0 +#define VF610_PAD_PTD20__ENET0_1588_TMR3 0x128 0x000 ALT4 0x0 +#define VF610_PAD_PTD20__ESDHC0_DAT7 0x128 0x000 ALT5 0x0 +#define VF610_PAD_PTD20__UART2_CTS 0x128 0x384 ALT6 0x0 +#define VF610_PAD_PTD20__DCU1_R0 0x128 0x000 ALT7 0x0 +#define VF610_PAD_PTD19__GPIO_75 0x12C 0x000 ALT0 0x0 +#define VF610_PAD_PTD19__FB_AD19 0x12C 0x000 ALT1 0x0 +#define VF610_PAD_PTD19__NF_IO3 0x12C 0x000 ALT2 0x0 +#define VF610_PAD_PTD19__ESAI_SCKR 0x12C 0x000 ALT3 0x0 +#define VF610_PAD_PTD19__I2C0_SCL 0x12C 0x33C ALT4 0x2 +#define VF610_PAD_PTD19__FTM2_QD_PHA 0x12C 0x000 ALT5 0x0 +#define VF610_PAD_PTD19__DCU1_R1 0x12C 0x000 ALT7 0x0 +#define VF610_PAD_PTD18__GPIO_76 0x130 0x000 ALT0 0x0 +#define VF610_PAD_PTD18__FB_AD18 0x130 0x000 ALT1 0x0 +#define VF610_PAD_PTD18__NF_IO2 0x130 0x000 ALT2 0x0 +#define VF610_PAD_PTD18__ESAI_FSR 0x130 0x000 ALT3 0x0 +#define VF610_PAD_PTD18__I2C0_SDA 0x130 0x340 ALT4 0x2 +#define VF610_PAD_PTD18__FTM2_QD_PHB 0x130 0x000 ALT5 0x0 +#define VF610_PAD_PTD18__DCU1_G0 0x130 0x000 ALT7 0x0 +#define VF610_PAD_PTD17__GPIO_77 0x134 0x000 ALT0 0x0 +#define VF610_PAD_PTD17__FB_AD17 0x134 0x000 ALT1 0x0 +#define VF610_PAD_PTD17__NF_IO1 0x134 0x000 ALT2 0x0 +#define VF610_PAD_PTD17__ESAI_HCKR 0x134 0x000 ALT3 0x0 +#define VF610_PAD_PTD17__I2C1_SCL 0x134 0x344 ALT4 0x2 +#define VF610_PAD_PTD17__DCU1_G1 0x134 0x000 ALT7 0x0 +#define VF610_PAD_PTD16__GPIO_78 0x138 0x000 ALT0 0x0 +#define VF610_PAD_PTD16__FB_AD16 0x138 0x000 ALT1 0x0 +#define VF610_PAD_PTD16__NF_IO0 0x138 0x000 ALT2 0x0 +#define VF610_PAD_PTD16__ESAI_HCKT 0x138 0x000 ALT3 0x0 +#define VF610_PAD_PTD16__I2C1_SDA 0x138 0x348 ALT4 0x2 +#define VF610_PAD_PTD16__DCU1_G2 0x138 0x000 ALT7 0x0 +#define VF610_PAD_PTD0__GPIO_79 0x13C 0x000 ALT0 0x0 +#define VF610_PAD_PTD0__QSPI0_A_QSCK 0x13C 0x000 ALT1 0x0 +#define VF610_PAD_PTD0__UART2_TX 0x13C 0x38C ALT2 0x2 +#define VF610_PAD_PTD0__FB_AD15 0x13C 0x000 ALT4 0x0 +#define VF610_PAD_PTD0__SPDIF_EXTCLK 0x13C 0x000 ALT5 0x0 +#define VF610_PAD_PTD0__DEBUG_OUT17 0x13C 0x000 ALT7 0x0 +#define VF610_PAD_PTD1__GPIO_80 0x140 0x000 ALT0 0x0 +#define VF610_PAD_PTD1__QSPI0_A_CS0 0x140 0x000 ALT1 0x0 +#define VF610_PAD_PTD1__UART2_RX 0x140 0x388 ALT2 0x2 +#define VF610_PAD_PTD1__FB_AD14 0x140 0x000 ALT4 0x0 +#define VF610_PAD_PTD1__SPDIF_IN1 0x140 0x000 ALT5 0x0 +#define VF610_PAD_PTD1__DEBUG_OUT18 0x140 0x000 ALT7 0x0 +#define VF610_PAD_PTD2__GPIO_81 0x144 0x000 ALT0 0x0 +#define VF610_PAD_PTD2__QSPI0_A_DATA3 0x144 0x000 ALT1 0x0 +#define VF610_PAD_PTD2__UART2_RTS 0x144 0x000 ALT2 0x0 +#define VF610_PAD_PTD2__DSPI1_CS3 0x144 0x000 ALT3 0x0 +#define VF610_PAD_PTD2__FB_AD13 0x144 0x000 ALT4 0x0 +#define VF610_PAD_PTD2__SPDIF_OUT1 0x144 0x000 ALT5 0x0 +#define VF610_PAD_PTD2__DEBUG_OUT19 0x144 0x000 ALT7 0x0 +#define VF610_PAD_PTD3__GPIO_82 0x148 0x000 ALT0 0x0 +#define VF610_PAD_PTD3__QSPI0_A_DATA2 0x148 0x000 ALT1 0x0 +#define VF610_PAD_PTD3__UART2_CTS 0x148 0x384 ALT2 0x1 +#define VF610_PAD_PTD3__DSPI1_CS2 0x148 0x000 ALT3 0x0 +#define VF610_PAD_PTD3__FB_AD12 0x148 0x000 ALT4 0x0 +#define VF610_PAD_PTD3__SPDIF_PLOCK 0x148 0x000 ALT5 0x0 +#define VF610_PAD_PTD3__DEBUG_OUT20 0x148 0x000 ALT7 0x0 +#define VF610_PAD_PTD4__GPIO_83 0x14C 0x000 ALT0 0x0 +#define VF610_PAD_PTD4__QSPI0_A_DATA1 0x14C 0x000 ALT1 0x0 +#define VF610_PAD_PTD4__DSPI1_CS1 0x14C 0x000 ALT3 0x0 +#define VF610_PAD_PTD4__FB_AD11 0x14C 0x000 ALT4 0x0 +#define VF610_PAD_PTD4__SPDIF_SRCLK 0x14C 0x000 ALT5 0x0 +#define VF610_PAD_PTD4__DEBUG_OUT21 0x14C 0x000 ALT7 0x0 +#define VF610_PAD_PTD5__GPIO_84 0x150 0x000 ALT0 0x0 +#define VF610_PAD_PTD5__QSPI0_A_DATA0 0x150 0x000 ALT1 0x0 +#define VF610_PAD_PTD5__DSPI1_CS0 0x150 0x300 ALT3 0x1 +#define VF610_PAD_PTD5__FB_AD10 0x150 0x000 ALT4 0x0 +#define VF610_PAD_PTD5__DEBUG_OUT22 0x150 0x000 ALT7 0x0 +#define VF610_PAD_PTD6__GPIO_85 0x154 0x000 ALT0 0x0 +#define VF610_PAD_PTD6__QSPI1_A_DQS 0x154 0x000 ALT1 0x0 +#define VF610_PAD_PTD6__DSPI1_SIN 0x154 0x2FC ALT3 0x1 +#define VF610_PAD_PTD6__FB_AD9 0x154 0x000 ALT4 0x0 +#define VF610_PAD_PTD6__DEBUG_OUT23 0x154 0x000 ALT7 0x0 +#define VF610_PAD_PTD7__GPIO_86 0x158 0x000 ALT0 0x0 +#define VF610_PAD_PTD7__QSPI0_B_QSCK 0x158 0x000 ALT1 0x0 +#define VF610_PAD_PTD7__DSPI1_SOUT 0x158 0x000 ALT3 0x0 +#define VF610_PAD_PTD7__FB_AD8 0x158 0x000 ALT4 0x0 +#define VF610_PAD_PTD7__DEBUG_OUT24 0x158 0x000 ALT7 0x0 +#define VF610_PAD_PTD8__GPIO_87 0x15C 0x000 ALT0 0x0 +#define VF610_PAD_PTD8__QSPI0_B_CS0 0x15C 0x000 ALT1 0x0 +#define VF610_PAD_PTD8__FB_CLKOUT 0x15C 0x000 ALT2 0x0 +#define VF610_PAD_PTD8__DSPI1_SCK 0x15C 0x2F8 ALT3 0x1 +#define VF610_PAD_PTD8__FB_AD7 0x15C 0x000 ALT4 0x0 +#define VF610_PAD_PTD8__DEBUG_OUT25 0x15C 0x000 ALT7 0x0 +#define VF610_PAD_PTD9__GPIO_88 0x160 0x000 ALT0 0x0 +#define VF610_PAD_PTD9__QSPI0_B_DATA3 0x160 0x000 ALT1 0x0 +#define VF610_PAD_PTD9__DSPI3_CS1 0x160 0x000 ALT2 0x0 +#define VF610_PAD_PTD9__FB_AD6 0x160 0x000 ALT4 0x0 +#define VF610_PAD_PTD9__SAI1_TX_SYNC 0x160 0x360 ALT6 0x0 +#define VF610_PAD_PTD9__DCU1_B0 0x160 0x000 ALT7 0x0 +#define VF610_PAD_PTD10__GPIO_89 0x164 0x000 ALT0 0x0 +#define VF610_PAD_PTD10__QSPI0_B_DATA2 0x164 0x000 ALT1 0x0 +#define VF610_PAD_PTD10__DSPI3_CS0 0x164 0x000 ALT2 0x0 +#define VF610_PAD_PTD10__FB_AD5 0x164 0x000 ALT4 0x0 +#define VF610_PAD_PTD10__DCU1_B1 0x164 0x000 ALT7 0x0 +#define VF610_PAD_PTD11__GPIO_90 0x168 0x000 ALT0 0x0 +#define VF610_PAD_PTD11__QSPI0_B_DATA1 0x168 0x000 ALT1 0x0 +#define VF610_PAD_PTD11__DSPI3_SIN 0x168 0x000 ALT2 0x0 +#define VF610_PAD_PTD11__FB_AD4 0x168 0x000 ALT4 0x0 +#define VF610_PAD_PTD11__DEBUG_OUT26 0x168 0x000 ALT7 0x0 +#define VF610_PAD_PTD12__GPIO_91 0x16C 0x000 ALT0 0x0 +#define VF610_PAD_PTD12__QSPI0_B_DATA0 0x16C 0x000 ALT1 0x0 +#define VF610_PAD_PTD12__DSPI3_SOUT 0x16C 0x000 ALT2 0x0 +#define VF610_PAD_PTD12__FB_AD3 0x16C 0x000 ALT4 0x0 +#define VF610_PAD_PTD12__DEBUG_OUT27 0x16C 0x000 ALT7 0x0 +#define VF610_PAD_PTD13__GPIO_92 0x170 0x000 ALT0 0x0 +#define VF610_PAD_PTD13__QSPI0_B_DQS 0x170 0x000 ALT1 0x0 +#define VF610_PAD_PTD13__DSPI3_SCK 0x170 0x000 ALT2 0x0 +#define VF610_PAD_PTD13__FB_AD2 0x170 0x000 ALT4 0x0 +#define VF610_PAD_PTD13__DEBUG_OUT28 0x170 0x000 ALT7 0x0 +#define VF610_PAD_PTB23__GPIO_93 0x174 0x000 ALT0 0x0 +#define VF610_PAD_PTB23__SAI0_TX_BCLK 0x174 0x000 ALT1 0x0 +#define VF610_PAD_PTB23__UART1_TX 0x174 0x380 ALT2 0x2 +#define VF610_PAD_PTB23__SRC_RCON18 0x174 0x398 ALT3 0x1 +#define VF610_PAD_PTB23__FB_MUXED_ALE 0x174 0x000 ALT4 0x0 +#define VF610_PAD_PTB23__FB_TS_B 0x174 0x000 ALT5 0x0 +#define VF610_PAD_PTB23__UART3_RTS 0x174 0x000 ALT6 0x0 +#define VF610_PAD_PTB23__DCU1_G3 0x174 0x000 ALT7 0x0 +#define VF610_PAD_PTB24__GPIO_94 0x178 0x000 ALT0 0x0 +#define VF610_PAD_PTB24__SAI0_RX_BCLK 0x178 0x000 ALT1 0x0 +#define VF610_PAD_PTB24__UART1_RX 0x178 0x37C ALT2 0x2 +#define VF610_PAD_PTB24__SRC_RCON19 0x178 0x39C ALT3 0x1 +#define VF610_PAD_PTB24__FB_MUXED_TSIZ0 0x178 0x000 ALT4 0x0 +#define VF610_PAD_PTB24__NF_WE_B 0x178 0x000 ALT5 0x0 +#define VF610_PAD_PTB24__UART3_CTS 0x178 0x000 ALT6 0x0 +#define VF610_PAD_PTB24__DCU1_G4 0x178 0x000 ALT7 0x0 +#define VF610_PAD_PTB25__GPIO_95 0x17C 0x000 ALT0 0x0 +#define VF610_PAD_PTB25__SAI0_RX_DATA 0x17C 0x000 ALT1 0x0 +#define VF610_PAD_PTB25__UART1_RTS 0x17C 0x000 ALT2 0x0 +#define VF610_PAD_PTB25__SRC_RCON20 0x17C 0x3A0 ALT3 0x1 +#define VF610_PAD_PTB25__FB_CS1_B 0x17C 0x000 ALT4 0x0 +#define VF610_PAD_PTB25__NF_CE0_B 0x17C 0x000 ALT5 0x0 +#define VF610_PAD_PTB25__DCU1_G5 0x17C 0x000 ALT7 0x0 +#define VF610_PAD_PTB26__GPIO_96 0x180 0x000 ALT0 0x0 +#define VF610_PAD_PTB26__SAI0_TX_DATA 0x180 0x000 ALT1 0x0 +#define VF610_PAD_PTB26__UART1_CTS 0x180 0x378 ALT2 0x2 +#define VF610_PAD_PTB26__SRC_RCON21 0x180 0x000 ALT3 0x0 +#define VF610_PAD_PTB26__FB_CS0_B 0x180 0x000 ALT4 0x0 +#define VF610_PAD_PTB26__NF_CE1_B 0x180 0x000 ALT5 0x0 +#define VF610_PAD_PTB26__DCU1_G6 0x180 0x000 ALT7 0x0 +#define VF610_PAD_PTB27__GPIO_97 0x184 0x000 ALT0 0x0 +#define VF610_PAD_PTB27__SAI0_RX_SYNC 0x184 0x000 ALT1 0x0 +#define VF610_PAD_PTB27__SRC_RCON22 0x184 0x000 ALT3 0x0 +#define VF610_PAD_PTB27__FB_OE_B 0x184 0x000 ALT4 0x0 +#define VF610_PAD_PTB27__FB_MUXED_TBST_B 0x184 0x000 ALT5 0x0 +#define VF610_PAD_PTB27__NF_RE_B 0x184 0x000 ALT6 0x0 +#define VF610_PAD_PTB27__DCU1_G7 0x184 0x000 ALT7 0x0 +#define VF610_PAD_PTB28__GPIO_98 0x188 0x000 ALT0 0x0 +#define VF610_PAD_PTB28__SAI0_TX_SYNC 0x188 0x000 ALT1 0x0 +#define VF610_PAD_PTB28__SRC_RCON23 0x188 0x000 ALT3 0x0 +#define VF610_PAD_PTB28__FB_RW_B 0x188 0x000 ALT4 0x0 +#define VF610_PAD_PTB28__DCU1_B6 0x188 0x000 ALT7 0x0 +#define VF610_PAD_PTC26__GPIO_99 0x18C 0x000 ALT0 0x0 +#define VF610_PAD_PTC26__SAI1_TX_BCLK 0x18C 0x000 ALT1 0x0 +#define VF610_PAD_PTC26__DSPI0_CS5 0x18C 0x000 ALT2 0x0 +#define VF610_PAD_PTC26__SRC_RCON24 0x18C 0x000 ALT3 0x0 +#define VF610_PAD_PTC26__FB_TA_B 0x18C 0x000 ALT4 0x0 +#define VF610_PAD_PTC26__NF_RB_B 0x18C 0x000 ALT5 0x0 +#define VF610_PAD_PTC26__DCU1_B7 0x18C 0x000 ALT7 0x0 +#define VF610_PAD_PTC27__GPIO_100 0x190 0x000 ALT0 0x0 +#define VF610_PAD_PTC27__SAI1_RX_BCLK 0x190 0x000 ALT1 0x0 +#define VF610_PAD_PTC27__DSPI0_CS4 0x190 0x000 ALT2 0x0 +#define VF610_PAD_PTC27__SRC_RCON25 0x190 0x000 ALT3 0x0 +#define VF610_PAD_PTC27__FB_BE3_B 0x190 0x000 ALT4 0x0 +#define VF610_PAD_PTC27__FB_CS3_B 0x190 0x000 ALT5 0x0 +#define VF610_PAD_PTC27__NF_ALE 0x190 0x000 ALT6 0x0 +#define VF610_PAD_PTC27__DCU1_B2 0x190 0x000 ALT7 0x0 +#define VF610_PAD_PTC28__GPIO_101 0x194 0x000 ALT0 0x0 +#define VF610_PAD_PTC28__SAI1_RX_DATA 0x194 0x000 ALT1 0x0 +#define VF610_PAD_PTC28__DSPI0_CS3 0x194 0x000 ALT2 0x0 +#define VF610_PAD_PTC28__SRC_RCON26 0x194 0x000 ALT3 0x0 +#define VF610_PAD_PTC28__FB_BE2_B 0x194 0x000 ALT4 0x0 +#define VF610_PAD_PTC28__FB_CS2_B 0x194 0x000 ALT5 0x0 +#define VF610_PAD_PTC28__NF_CLE 0x194 0x000 ALT6 0x0 +#define VF610_PAD_PTC28__DCU1_B3 0x194 0x000 ALT7 0x0 +#define VF610_PAD_PTC29__GPIO_102 0x198 0x000 ALT0 0x0 +#define VF610_PAD_PTC29__SAI1_TX_DATA 0x198 0x000 ALT1 0x0 +#define VF610_PAD_PTC29__DSPI0_CS2 0x198 0x000 ALT2 0x0 +#define VF610_PAD_PTC29__SRC_RCON27 0x198 0x000 ALT3 0x0 +#define VF610_PAD_PTC29__FB_BE1_B 0x198 0x000 ALT4 0x0 +#define VF610_PAD_PTC29__FB_MUXED_TSIZE1 0x198 0x000 ALT5 0x0 +#define VF610_PAD_PTC29__DCU1_B4 0x198 0x000 ALT7 0x0 +#define VF610_PAD_PTC30__GPIO_103 0x19C 0x000 ALT0 0x0 +#define VF610_PAD_PTC30__SAI1_RX_SYNC 0x19C 0x000 ALT1 0x0 +#define VF610_PAD_PTC30__DSPI1_CS2 0x19C 0x000 ALT2 0x0 +#define VF610_PAD_PTC30__SRC_RCON28 0x19C 0x000 ALT3 0x0 +#define VF610_PAD_PTC30__FB_MUXED_BE0_B 0x19C 0x000 ALT4 0x0 +#define VF610_PAD_PTC30__FB_TSIZ0 0x19C 0x000 ALT5 0x0 +#define VF610_PAD_PTC30__ADC0_SE5 0x19C 0x000 ALT6 0x0 +#define VF610_PAD_PTC30__DCU1_B5 0x19C 0x000 ALT7 0x0 +#define VF610_PAD_PTC31__GPIO_104 0x1A0 0x000 ALT0 0x0 +#define VF610_PAD_PTC31__SAI1_TX_SYNC 0x1A0 0x360 ALT1 0x1 +#define VF610_PAD_PTC31__SRC_RCON29 0x1A0 0x000 ALT3 0x0 +#define VF610_PAD_PTC31__ADC1_SE5 0x1A0 0x000 ALT6 0x0 +#define VF610_PAD_PTC31__DCU1_B6 0x1A0 0x000 ALT7 0x0 +#define VF610_PAD_PTE0__GPIO_105 0x1A4 0x000 ALT0 0x0 +#define VF610_PAD_PTE0__DCU0_HSYNC 0x1A4 0x000 ALT1 0x0 +#define VF610_PAD_PTE0__SRC_BMODE1 0x1A4 0x000 ALT2 0x0 +#define VF610_PAD_PTE0__LCD0 0x1A4 0x000 ALT4 0x0 +#define VF610_PAD_PTE0__DEBUG_OUT29 0x1A4 0x000 ALT7 0x0 +#define VF610_PAD_PTE1__GPIO_106 0x1A8 0x000 ALT0 0x0 +#define VF610_PAD_PTE1__DCU0_VSYNC 0x1A8 0x000 ALT1 0x0 +#define VF610_PAD_PTE1__SRC_BMODE0 0x1A8 0x000 ALT2 0x0 +#define VF610_PAD_PTE1__LCD1 0x1A8 0x000 ALT4 0x0 +#define VF610_PAD_PTE1__DEBUG_OUT30 0x1A8 0x000 ALT7 0x0 +#define VF610_PAD_PTE2__GPIO_107 0x1AC 0x000 ALT0 0x0 +#define VF610_PAD_PTE2__DCU0_PCLK 0x1AC 0x000 ALT1 0x0 +#define VF610_PAD_PTE2__LCD2 0x1AC 0x000 ALT4 0x0 +#define VF610_PAD_PTE2__DEBUG_OUT31 0x1AC 0x000 ALT7 0x0 +#define VF610_PAD_PTE3__GPIO_108 0x1B0 0x000 ALT0 0x0 +#define VF610_PAD_PTE3__DCU0_TAG 0x1B0 0x000 ALT1 0x0 +#define VF610_PAD_PTE3__LCD3 0x1B0 0x000 ALT4 0x0 +#define VF610_PAD_PTE3__DEBUG_OUT32 0x1B0 0x000 ALT7 0x0 +#define VF610_PAD_PTE4__GPIO_109 0x1B4 0x000 ALT0 0x0 +#define VF610_PAD_PTE4__DCU0_DE 0x1B4 0x000 ALT1 0x0 +#define VF610_PAD_PTE4__LCD4 0x1B4 0x000 ALT4 0x0 +#define VF610_PAD_PTE4__DEBUG_OUT33 0x1B4 0x000 ALT7 0x0 +#define VF610_PAD_PTE5__GPIO_110 0x1B8 0x000 ALT0 0x0 +#define VF610_PAD_PTE5__DCU0_R0 0x1B8 0x000 ALT1 0x0 +#define VF610_PAD_PTE5__LCD5 0x1B8 0x000 ALT4 0x0 +#define VF610_PAD_PTE5__DEBUG_OUT34 0x1B8 0x000 ALT7 0x0 +#define VF610_PAD_PTE6__GPIO_111 0x1BC 0x000 ALT0 0x0 +#define VF610_PAD_PTE6__DCU0_R1 0x1BC 0x000 ALT1 0x0 +#define VF610_PAD_PTE6__LCD6 0x1BC 0x000 ALT4 0x0 +#define VF610_PAD_PTE6__DEBUG_OUT35 0x1BC 0x000 ALT7 0x0 +#define VF610_PAD_PTE7__GPIO_112 0x1C0 0x000 ALT0 0x0 +#define VF610_PAD_PTE7__DCU0_R2 0x1C0 0x000 ALT1 0x0 +#define VF610_PAD_PTE7__SRC_RCON0 0x1C0 0x000 ALT3 0x0 +#define VF610_PAD_PTE7__LCD7 0x1C0 0x000 ALT4 0x0 +#define VF610_PAD_PTE7__DEBUG_OUT36 0x1C0 0x000 ALT7 0x0 +#define VF610_PAD_PTE8__GPIO_113 0x1C4 0x000 ALT0 0x0 +#define VF610_PAD_PTE8__DCU0_R3 0x1C4 0x000 ALT1 0x0 +#define VF610_PAD_PTE8__SRC_RCON1 0x1C4 0x000 ALT3 0x0 +#define VF610_PAD_PTE8__LCD8 0x1C4 0x000 ALT4 0x0 +#define VF610_PAD_PTE8__DEBUG_OUT37 0x1C4 0x000 ALT7 0x0 +#define VF610_PAD_PTE9__GPIO_114 0x1C8 0x000 ALT0 0x0 +#define VF610_PAD_PTE9__DCU0_R4 0x1C8 0x000 ALT1 0x0 +#define VF610_PAD_PTE9__SRC_RCON2 0x1C8 0x000 ALT3 0x0 +#define VF610_PAD_PTE9__LCD9 0x1C8 0x000 ALT4 0x0 +#define VF610_PAD_PTE9__DEBUG_OUT38 0x1C8 0x000 ALT7 0x0 +#define VF610_PAD_PTE10__GPIO_115 0x1CC 0x000 ALT0 0x0 +#define VF610_PAD_PTE10__DCU0_R5 0x1CC 0x000 ALT1 0x0 +#define VF610_PAD_PTE10__SRC_RCON3 0x1CC 0x000 ALT3 0x0 +#define VF610_PAD_PTE10__LCD10 0x1CC 0x000 ALT4 0x0 +#define VF610_PAD_PTE10__DEBUG_OUT39 0x1CC 0x000 ALT7 0x0 +#define VF610_PAD_PTE11__GPIO_116 0x1D0 0x000 ALT0 0x0 +#define VF610_PAD_PTE11__DCU0_R6 0x1D0 0x000 ALT1 0x0 +#define VF610_PAD_PTE11__SRC_RCON4 0x1D0 0x000 ALT3 0x0 +#define VF610_PAD_PTE11__LCD11 0x1D0 0x000 ALT4 0x0 +#define VF610_PAD_PTE11__DEBUG_OUT40 0x1D0 0x000 ALT7 0x0 +#define VF610_PAD_PTE12__GPIO_117 0x1D4 0x000 ALT0 0x0 +#define VF610_PAD_PTE12__DCU0_R7 0x1D4 0x000 ALT1 0x0 +#define VF610_PAD_PTE12__DSPI1_CS3 0x1D4 0x000 ALT2 0x0 +#define VF610_PAD_PTE12__SRC_RCON5 0x1D4 0x000 ALT3 0x0 +#define VF610_PAD_PTE12__LCD12 0x1D4 0x000 ALT4 0x0 +#define VF610_PAD_PTE12__LPT_ALT0 0x1D4 0x000 ALT7 0x0 +#define VF610_PAD_PTE13__GPIO_118 0x1D8 0x000 ALT0 0x0 +#define VF610_PAD_PTE13__DCU0_G0 0x1D8 0x000 ALT1 0x0 +#define VF610_PAD_PTE13__LCD13 0x1D8 0x000 ALT4 0x0 +#define VF610_PAD_PTE13__DEBUG_OUT41 0x1D8 0x000 ALT7 0x0 +#define VF610_PAD_PTE14__GPIO_119 0x1DC 0x000 ALT0 0x0 +#define VF610_PAD_PTE14__DCU0_G1 0x1DC 0x000 ALT1 0x0 +#define VF610_PAD_PTE14__LCD14 0x1DC 0x000 ALT4 0x0 +#define VF610_PAD_PTE14__DEBUG_OUT42 0x1DC 0x000 ALT7 0x0 +#define VF610_PAD_PTE15__GPIO_120 0x1E0 0x000 ALT0 0x0 +#define VF610_PAD_PTE15__DCU0_G2 0x1E0 0x000 ALT1 0x0 +#define VF610_PAD_PTE15__SRC_RCON6 0x1E0 0x000 ALT3 0x0 +#define VF610_PAD_PTE15__LCD15 0x1E0 0x000 ALT4 0x0 +#define VF610_PAD_PTE15__DEBUG_OUT43 0x1E0 0x000 ALT7 0x0 +#define VF610_PAD_PTE16__GPIO_121 0x1E4 0x000 ALT0 0x0 +#define VF610_PAD_PTE16__DCU0_G3 0x1E4 0x000 ALT1 0x0 +#define VF610_PAD_PTE16__SRC_RCON7 0x1E4 0x000 ALT3 0x0 +#define VF610_PAD_PTE16__LCD16 0x1E4 0x000 ALT4 0x0 +#define VF610_PAD_PTE17__GPIO_122 0x1E8 0x000 ALT0 0x0 +#define VF610_PAD_PTE17__DCU0_G4 0x1E8 0x000 ALT1 0x0 +#define VF610_PAD_PTE17__SRC_RCON8 0x1E8 0x000 ALT3 0x0 +#define VF610_PAD_PTE17__LCD17 0x1E8 0x000 ALT4 0x0 +#define VF610_PAD_PTE18__GPIO_123 0x1EC 0x000 ALT0 0x0 +#define VF610_PAD_PTE18__DCU0_G5 0x1EC 0x000 ALT1 0x0 +#define VF610_PAD_PTE18__SRC_RCON9 0x1EC 0x000 ALT3 0x0 +#define VF610_PAD_PTE18__LCD18 0x1EC 0x000 ALT4 0x0 +#define VF610_PAD_PTE19__GPIO_124 0x1F0 0x000 ALT0 0x0 +#define VF610_PAD_PTE19__DCU0_G6 0x1F0 0x000 ALT1 0x0 +#define VF610_PAD_PTE19__SRC_RCON10 0x1F0 0x000 ALT3 0x0 +#define VF610_PAD_PTE19__LCD19 0x1F0 0x000 ALT4 0x0 +#define VF610_PAD_PTE19__I2C0_SCL 0x1F0 0x33C ALT5 0x3 +#define VF610_PAD_PTE20__GPIO_125 0x1F4 0x000 ALT0 0x0 +#define VF610_PAD_PTE20__DCU0_G7 0x1F4 0x000 ALT1 0x0 +#define VF610_PAD_PTE20__SRC_RCON11 0x1F4 0x000 ALT3 0x0 +#define VF610_PAD_PTE20__LCD20 0x1F4 0x000 ALT4 0x0 +#define VF610_PAD_PTE20__I2C0_SDA 0x1F4 0x340 ALT5 0x3 +#define VF610_PAD_PTE20__EWM_IN 0x1F4 0x000 ALT7 0x0 +#define VF610_PAD_PTE21__GPIO_126 0x1F8 0x000 ALT0 0x0 +#define VF610_PAD_PTE21__DCU0_B0 0x1F8 0x000 ALT1 0x0 +#define VF610_PAD_PTE21__LCD21 0x1F8 0x000 ALT4 0x0 +#define VF610_PAD_PTE22__GPIO_127 0x1FC 0x000 ALT0 0x0 +#define VF610_PAD_PTE22__DCU0_B1 0x1FC 0x000 ALT1 0x0 +#define VF610_PAD_PTE22__LCD22 0x1FC 0x000 ALT4 0x0 +#define VF610_PAD_PTE23__GPIO_128 0x200 0x000 ALT0 0x0 +#define VF610_PAD_PTE23__DCU0_B2 0x200 0x000 ALT1 0x0 +#define VF610_PAD_PTE23__SRC_RCON12 0x200 0x000 ALT3 0x0 +#define VF610_PAD_PTE23__LCD23 0x200 0x000 ALT4 0x0 +#define VF610_PAD_PTE24__GPIO_129 0x204 0x000 ALT0 0x0 +#define VF610_PAD_PTE24__DCU0_B3 0x204 0x000 ALT1 0x0 +#define VF610_PAD_PTE24__SRC_RCON13 0x204 0x000 ALT3 0x0 +#define VF610_PAD_PTE24__LCD24 0x204 0x000 ALT4 0x0 +#define VF610_PAD_PTE25__GPIO_130 0x208 0x000 ALT0 0x0 +#define VF610_PAD_PTE25__DCU0_B4 0x208 0x000 ALT1 0x0 +#define VF610_PAD_PTE25__SRC_RCON14 0x208 0x000 ALT3 0x0 +#define VF610_PAD_PTE25__LCD25 0x208 0x000 ALT4 0x0 +#define VF610_PAD_PTE26__GPIO_131 0x20C 0x000 ALT0 0x0 +#define VF610_PAD_PTE26__DCU0_B5 0x20C 0x000 ALT1 0x0 +#define VF610_PAD_PTE26__SRC_RCON15 0x20C 0x000 ALT3 0x0 +#define VF610_PAD_PTE26__LCD26 0x20C 0x000 ALT4 0x0 +#define VF610_PAD_PTE27__GPIO_132 0x210 0x000 ALT0 0x0 +#define VF610_PAD_PTE27__DCU0_B6 0x210 0x000 ALT1 0x0 +#define VF610_PAD_PTE27__SRC_RCON16 0x210 0x000 ALT3 0x0 +#define VF610_PAD_PTE27__LCD27 0x210 0x000 ALT4 0x0 +#define VF610_PAD_PTE27__I2C1_SCL 0x210 0x344 ALT5 0x3 +#define VF610_PAD_PTE28__GPIO_133 0x214 0x000 ALT0 0x0 +#define VF610_PAD_PTE28__DCU0_B7 0x214 0x000 ALT1 0x0 +#define VF610_PAD_PTE28__SRC_RCON17 0x214 0x000 ALT3 0x0 +#define VF610_PAD_PTE28__LCD28 0x214 0x000 ALT4 0x0 +#define VF610_PAD_PTE28__I2C1_SDA 0x214 0x348 ALT5 0x3 +#define VF610_PAD_PTE28__EWM_OUT 0x214 0x000 ALT7 0x0 +#define VF610_PAD_PTA7__GPIO_134 0x218 0x000 ALT0 0x0 +#define VF610_PAD_PTA7__VIU_PIX_CLK 0x218 0x3AC ALT1 0x1 + +#endif
Lukasz Majewski
