[U-Boot] [PATCH] powerpc/85xx: Introduce CONFIG_SYS_EXTRA_ENV_RELOC
Some systems need to relocate the env_addr pointer early because the location its point to will get invalidated before env_relocate is called. One example is on systems that might use a L2 or L3 cache in SRAM mode and initialize that cache from SRAM mode back to being a cache in cpu_init_r.
We set this on the 85xx boards that have support for NAND, SPI, or SDHC/MMC boot support as they use a secondary cache in SRAM mode and need the env_addr pointer relocated since we change from SRAM to normal cache mode in cpu_init_r.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/lib/board.c | 11 +++++++++++ include/configs/MPC8536DS.h | 1 + include/configs/MPC8569MDS.h | 1 + include/configs/P1_P2_RDB.h | 1 + 4 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 2e0749d..ce51c8f 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -645,6 +645,17 @@ void board_init_r (gd_t *id, ulong dest_addr) gd->cpu += dest_addr - CONFIG_SYS_MONITOR_BASE; #endif
+#ifdef CONFIG_SYS_EXTRA_ENV_RELOC + /* + * Some systems need to relocate the env_addr pointer early because the + * location its point to will get invalidated before env_relocate is + * called. One example is on systems that might use a L2 or L3 cache + * in SRAM mode and initialize that cache from SRAM mode back to being + * a cache in cpu_init_r. + */ + gd->env_addr += dest_addr - CONFIG_SYS_MONITOR_BASE; +#endif + #ifdef CONFIG_SERIAL_MULTI serial_initialize(); #endif diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 850665a..50d282c 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -245,6 +245,7 @@ #if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) \ || defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC #else #undef CONFIG_SYS_RAMBOOT #endif diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index c7973b4..20fd672 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -205,6 +205,7 @@ extern unsigned long get_clock_freq(void);
#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) #define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC #else #undef CONFIG_SYS_RAMBOOT #endif diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 610f3ed..8069b55 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -204,6 +204,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) \ || defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC #else #undef CONFIG_SYS_RAMBOOT #endif
Wolfgang,
I dont think either of us are happy with this solution but not really sure what else to do. Please ack if you're grudgingly ok with this. :)
- k
Not to nitpick, but please correct this - I think you meant "location it points to"?
-B
Becky Bruce
Kumar Gala
