[PATCH] MAINTAINERS: add RaspberryPi co-maintainer
Peter accpeted to step up as a co-maintainer for the RPis. Reflect that in the corresponding MAINTAINERS files.
Signed-off-by: Matthias Brugger mbrugger@suse.com
MAINTAINERS | 1 + board/raspberrypi/rpi/MAINTAINERS | 1 + 2 files changed, 2 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index bc9081b62a9..f9f4eeda1c2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -192,6 +192,7 @@ N: aspeed
ARM BROADCOM BCM283X / BCM27XX M: Matthias Brugger mbrugger@suse.com +M: Peter Robinson pbrobinson@gmail.com S: Maintained F: arch/arm/dts/bcm283* F: arch/arm/mach-bcm283x/ diff --git a/board/raspberrypi/rpi/MAINTAINERS b/board/raspberrypi/rpi/MAINTAINERS index 4f1b23efc8e..98935119f0a 100644 --- a/board/raspberrypi/rpi/MAINTAINERS +++ b/board/raspberrypi/rpi/MAINTAINERS @@ -1,5 +1,6 @@ RPI BOARD M: Matthias Brugger mbrugger@suse.com +M: Peter Robinson pbrobinson@gmail.com S: Maintained F: board/raspberrypi/rpi/ F: include/configs/rpi.h
Reviewed-by: Peter Robinson pbrobinson@gmail.com
I suspect I'll need some setup around gitlab/CI here.
ARM BROADCOM BCM283X / BCM27XX M: Matthias Brugger mbrugger@suse.com +M: Peter Robinson pbrobinson@gmail.com S: Maintained F: arch/arm/dts/bcm283* F: arch/arm/mach-bcm283x/ diff --git a/board/raspberrypi/rpi/MAINTAINERS b/board/raspberrypi/rpi/MAINTAINERS index 4f1b23efc8e..98935119f0a 100644 --- a/board/raspberrypi/rpi/MAINTAINERS +++ b/board/raspberrypi/rpi/MAINTAINERS @@ -1,5 +1,6 @@ RPI BOARD M: Matthias Brugger mbrugger@suse.com +M: Peter Robinson pbrobinson@gmail.com S: Maintained F: board/raspberrypi/rpi/ F: include/configs/rpi.h -- 2.38.1
Thanks! I'll push and apply this shortly.
And I'll follow-up off-list about getting you access to https://source.denx.de/u-boot/custodians/u-boot-raspberrypi
Signed-off-by: Matthias Brugger mbrugger@suse.com Reviewed-by: Peter Robinson pbrobinson@gmail.com
Peter Robinson
