[U-Boot] [PATCH] board/freescale/vid: Add correction for ltc3882 read error.
Voltage regulator LTC3882 device has 0.5% voltage read error. So for NXP SoC devices this generally equates to 2mV
Update set_voltage_to_LTC for below: 1.Add coorection of upto 2mV in voltage comparison to take care of voltage read error of voltage regulator 2.Add loop max count kept as 100 to avoid infinte loop.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- board/freescale/common/vid.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index eb5cf88..db158cb 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -318,6 +318,7 @@ static int set_voltage_to_IR(int i2caddress, int vdd) static int set_voltage_to_LTC(int i2caddress, int vdd) { int ret, vdd_last, vdd_target = vdd; + int count = 100, temp = 0;
/* Scale up to the LTC resolution is 1/4096V */ vdd = (vdd * 4096) / 1000; @@ -343,7 +344,9 @@ static int set_voltage_to_LTC(int i2caddress, int vdd) printf("VID: Couldn't read sensor abort VID adjust\n"); return -1; } - } while (vdd_last != vdd_target); + count--; + temp = vdd_last - vdd_target; + } while ((abs(temp) > 2) && (count > 0));
return vdd_last; }
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Priyanka Jain
York Sun
