[PATCH 1/2] ARM: dts: renesas: Clean up R8A779G0 V4H RPC SPI DT node
Use the phandle reference to &rpc node in arch/arm/dts/r8a779g0.dtsi and remove properties which are already in arch/arm/dts/r8a779g0.dtsi. No functional change and no resulting DT change.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/dts/r8a779g0-u-boot.dtsi | 18 ++++-------------- 1 file changed, 4 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/r8a779g0-u-boot.dtsi b/arch/arm/dts/r8a779g0-u-boot.dtsi index 150657fad54..cc8becac996 100644 --- a/arch/arm/dts/r8a779g0-u-boot.dtsi +++ b/arch/arm/dts/r8a779g0-u-boot.dtsi @@ -7,20 +7,10 @@
#include "r8a779x-u-boot.dtsi"
-/ { - soc { - rpc: spi@ee200000 { - compatible = "renesas,r8a779g0-rpc-if", "renesas,rcar-gen4-rpc-if"; - reg = <0 0xee200000 0 0x200>, <0 0x08000000 0 0x04000000>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 629>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 629>; - bank-width = <2>; - num-cs = <1>; - status = "disabled"; - }; - }; +&rpc { + reg = <0 0xee200000 0 0x200>, <0 0x08000000 0 0x04000000>; + bank-width = <2>; + num-cs = <1>; };
&extalr_clk {
As requirement of CR side, QSPI Flash usage via RPC driver shall be disabled and leaving the control of this module to CR side. Perform DT modification to disable the RPC SPI.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Cong Dang cong.dang.xn@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org [Marek: Do not modify defconfig, modify the DT instead, this way the RPC SPI can be enabled without recompiling the U-Boot itself. Update commit message accordingly.] --- arch/arm/dts/r8a779g0-white-hawk-u-boot.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/r8a779g0-white-hawk-u-boot.dts b/arch/arm/dts/r8a779g0-white-hawk-u-boot.dts index efc1b9519ef..bd756036645 100644 --- a/arch/arm/dts/r8a779g0-white-hawk-u-boot.dts +++ b/arch/arm/dts/r8a779g0-white-hawk-u-boot.dts @@ -28,7 +28,7 @@ #address-cells = <1>; #size-cells = <0>; spi-max-frequency = <40000000>; - status = "okay"; + status = "disabled";
spi-flash@0 { #address-cells = <1>;
