[PATCH] mmc: Add support for enumerating MMC card in a given mode using mmc command
Add support for enumerating MMC card in a given mode using mmc rescan and mmc dev commands. The speed mode is provided as the last argument in these commands and is indicated using the index from enum bus_mode in include/mmc.h. A speed mode can be set only if it has already been enabled in the device tree.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- cmd/Kconfig | 10 ++++++ cmd/mmc.c | 71 ++++++++++++++++++++++++++++------------ drivers/mmc/mmc-uclass.c | 3 ++ drivers/mmc/mmc.c | 18 ++++++++++ include/mmc.h | 4 +++ 5 files changed, 85 insertions(+), 21 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index ffef3cc76ca4..3a857b3f6e2e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2389,4 +2389,14 @@ config CMD_UBIFS help UBIFS is a file system for flash devices which works on top of UBI.
+config MMC_SPEED_MODE_SET + bool "set speed mode using mmc command" + depends on CMD_MMC + default n + help + Enable setting speed mode using mmc rescan and mmc dev commands. + The speed mode is provided as the last argument in these commands + and is indicated using the index from enum bus_mode in + include/mmc.h. A speed mode can be set only if it has already + been enabled in the device tree. endmenu diff --git a/cmd/mmc.c b/cmd/mmc.c index b942576b58ac..073e87d69634 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -120,7 +120,9 @@ static void print_mmcinfo(struct mmc *mmc) } } } -static struct mmc *init_mmc_device(int dev, bool force_init) + +static struct mmc *init_mmc_device(int dev, bool force_init, + enum bus_mode speed_mode) { struct mmc *mmc; mmc = find_mmc_device(dev); @@ -134,6 +136,11 @@ static struct mmc *init_mmc_device(int dev, bool force_init)
if (force_init) mmc->has_init = 0; + +#if CONFIG_IS_ENABLED(MMC_SPEED_MODE_SET) + mmc->user_speed_mode = speed_mode; +#endif + if (mmc_init(mmc)) return NULL;
@@ -159,7 +166,7 @@ static int do_mmcinfo(struct cmd_tbl *cmdtp, int flag, int argc, } }
- mmc = init_mmc_device(curr_device, false); + mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
@@ -293,7 +300,7 @@ static int do_mmcrpmb(struct cmd_tbl *cmdtp, int flag, if (flag == CMD_FLAG_REPEAT && !cmd_is_repeatable(cp)) return CMD_RET_SUCCESS;
@@ -338,7 +345,7 @@ static int do_mmc_read(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[2], NULL, 16); cnt = simple_strtoul(argv[3], NULL, 16);
@@ -387,7 +394,7 @@ static int do_mmc_sparse_write(struct cmd_tbl *cmdtp, int flag, return CMD_RET_FAILURE; }
@@ -431,7 +438,7 @@ static int do_mmc_write(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[2], NULL, 16); cnt = simple_strtoul(argv[3], NULL, 16);
@@ -460,7 +467,7 @@ static int do_mmc_erase(struct cmd_tbl *cmdtp, int flag, blk = simple_strtoul(argv[1], NULL, 16); cnt = simple_strtoul(argv[2], NULL, 16);
@@ -482,8 +489,19 @@ static int do_mmc_rescan(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct mmc *mmc; + enum bus_mode speed_mode = MMC_MODES_END; + + if (argc == 1) { + mmc = init_mmc_device(curr_device, true, MMC_MODES_END); + } else if (argc == 2) { + /* parse the mode */ + speed_mode = simple_strtoul(argv[1], NULL, 10); + /* Need to pass the the speed mode required too */ + mmc = init_mmc_device(curr_device, true, speed_mode); + } else { + return CMD_RET_USAGE; + }
- mmc = init_mmc_device(curr_device, true); if (!mmc) return CMD_RET_FAILURE;
@@ -496,7 +514,7 @@ static int do_mmc_part(struct cmd_tbl *cmdtp, int flag, struct blk_desc *mmc_dev; struct mmc *mmc;
@@ -515,11 +533,14 @@ static int do_mmc_dev(struct cmd_tbl *cmdtp, int flag, { int dev, part = 0, ret; struct mmc *mmc; + enum bus_mode speed_mode = MMC_MODES_END;
if (argc == 1) { dev = curr_device; + mmc = init_mmc_device(dev, true, MMC_MODES_END); } else if (argc == 2) { dev = simple_strtoul(argv[1], NULL, 10); + mmc = init_mmc_device(dev, true, MMC_MODES_END); } else if (argc == 3) { dev = (int)simple_strtoul(argv[1], NULL, 10); part = (int)simple_strtoul(argv[2], NULL, 10); @@ -528,11 +549,16 @@ static int do_mmc_dev(struct cmd_tbl *cmdtp, int flag, PART_ACCESS_MASK); return CMD_RET_FAILURE; } + mmc = init_mmc_device(dev, true, MMC_MODES_END); + } else if (argc == 4) { + dev = (int)simple_strtoul(argv[1], NULL, 10); + part = (int)simple_strtoul(argv[2], NULL, 10); + speed_mode = simple_strtoul(argv[3], NULL, 10); + mmc = init_mmc_device(curr_device, true, speed_mode); } else { return CMD_RET_USAGE; }
- mmc = init_mmc_device(dev, true); if (!mmc) return CMD_RET_FAILURE;
@@ -636,7 +662,7 @@ static int do_mmc_hwpartition(struct cmd_tbl *cmdtp, int flag, enum mmc_hwpart_conf_mode mode = MMC_HWPART_CONF_CHECK; int i, r, pidx;
@@ -726,7 +752,7 @@ static int do_mmc_bootbus(struct cmd_tbl *cmdtp, int flag, reset = simple_strtoul(argv[3], NULL, 10); mode = simple_strtoul(argv[4], NULL, 10);
- mmc = init_mmc_device(dev, false); + mmc = init_mmc_device(dev, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
@@ -789,7 +815,7 @@ static int do_mmc_boot_resize(struct cmd_tbl *cmdtp, int flag, bootsize = simple_strtoul(argv[2], NULL, 10); rpmbsize = simple_strtoul(argv[3], NULL, 10);
@@ -844,7 +870,7 @@ static int do_mmc_partconf(struct cmd_tbl *cmdtp, int flag,
@@ -887,7 +913,7 @@ static int do_mmc_rst_func(struct cmd_tbl *cmdtp, int flag, return CMD_RET_USAGE; }
@@ -939,7 +965,7 @@ static int do_mmc_bkops_enable(struct cmd_tbl *cmdtp, int flag,
@@ -958,7 +984,7 @@ static int do_mmc_boot_wp(struct cmd_tbl *cmdtp, int flag, int err; struct mmc *mmc;
- mmc = init_mmc_device(curr_device, false); + mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE; if (IS_SD(mmc)) { @@ -983,9 +1009,9 @@ static struct cmd_tbl cmd_mmc[] = { #if CONFIG_IS_ENABLED(CMD_MMC_SWRITE) U_BOOT_CMD_MKENT(swrite, 3, 0, do_mmc_sparse_write, "", ""), #endif - U_BOOT_CMD_MKENT(rescan, 1, 1, do_mmc_rescan, "", ""), + U_BOOT_CMD_MKENT(rescan, 2, 1, do_mmc_rescan, "", ""), U_BOOT_CMD_MKENT(part, 1, 1, do_mmc_part, "", ""), - U_BOOT_CMD_MKENT(dev, 3, 0, do_mmc_dev, "", ""), + U_BOOT_CMD_MKENT(dev, 4, 0, do_mmc_dev, "", ""), U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""), #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) U_BOOT_CMD_MKENT(hwpartition, 28, 0, do_mmc_hwpartition, "", ""), @@ -1042,9 +1068,12 @@ U_BOOT_CMD( "mmc swrite addr blk#\n" #endif "mmc erase blk# cnt\n" - "mmc rescan\n" + "mmc rescan [mode]\n" "mmc part - lists available partition on current mmc device\n" - "mmc dev [dev] [part] - show or set current mmc device [partition]\n" + "mmc dev [dev] [part] [mode] - show or set current mmc device [partition] and set mode\n" + " - the required speed mode is passed as the index from the following list\n" + " [MMC_LEGACY, MMC_HS, SD_HS, MMC_HS_52, MMC_DDR_52, UHS_SDR12, UHS_SDR25,\n" + " UHS_SDR50, UHS_DDR50, UHS_SDR104, MMC_HS_200, MMC_HS_400, MMC_HS_400_ES]\n" "mmc list - lists available devices\n" "mmc wp - power on write protect boot partitions\n" #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 0e13238c7e7a..66fe8bed984b 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -415,6 +415,9 @@ int mmc_bind(struct udevice *dev, struct mmc *mmc, const struct mmc_config *cfg) bdesc->part_type = cfg->part_type; mmc->dev = dev;
+#if CONFIG_IS_ENABLED(MMC_SPEED_MODE_SET) + mmc->user_speed_mode = MMC_MODES_END; +#endif return 0; }
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 8078a89f18cb..b24a45d458d4 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2863,6 +2863,24 @@ int mmc_start_init(struct mmc *mmc) */ mmc->host_caps = mmc->cfg->host_caps | MMC_CAP(MMC_LEGACY) | MMC_CAP(MMC_LEGACY) | MMC_MODE_1BIT; + +#if CONFIG_IS_ENABLED(MMC_SPEED_MODE_SET) + if (mmc->user_speed_mode != MMC_MODES_END) { + int i; + /* set host caps */ + if (mmc->host_caps & MMC_CAP(mmc->user_speed_mode)) { + /* Remove all existing speed capabilities */ + for (i = MMC_LEGACY; i < MMC_MODES_END; i++) + mmc->host_caps &= ~MMC_CAP(i); + mmc->host_caps |= (MMC_CAP(mmc->user_speed_mode) + | MMC_CAP(MMC_LEGACY) | + MMC_CAP(MMC_LEGACY) | MMC_MODE_1BIT); + } else { + pr_err("bus_mode requested is not supported\n"); + return -EINVAL; + } + } +#endif #if CONFIG_IS_ENABLED(DM_MMC) mmc_deferred_probe(mmc); #endif diff --git a/include/mmc.h b/include/mmc.h index 0bf19de20e52..e64ef7611dd7 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -726,6 +726,10 @@ struct mmc { */ u32 quirks; u8 hs400_tuning; + +#if CONFIG_IS_ENABLED(MMC_SPEED_MODE_SET) + enum bus_mode user_speed_mode; +#endif };
Hi Aswath,
Thanks for this patch. It seems that it's useful to develope and debug. I will test with this patch.
Could you also update doc/usage/mmc.rst file?
Best Regards, Jaehoo Chung
- bool "set speed mode using mmc command"
- depends on CMD_MMC
- default n
- help
- mmc->user_speed_mode = speed_mode;
- if (mmc_init(mmc)) return NULL;
- mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
- enum bus_mode speed_mode = MMC_MODES_END;
- if (argc == 1) {
- } else if (argc == 2) {
- } else {
- } else if (argc == 4) {
} else { return CMD_RET_USAGE; }mmc = init_mmc_device(curr_device, true, speed_mode);
- mmc = init_mmc_device(dev, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE;
- mmc = init_mmc_device(curr_device, false, MMC_MODES_END); if (!mmc) return CMD_RET_FAILURE; if (IS_SD(mmc)) {
- U_BOOT_CMD_MKENT(rescan, 2, 1, do_mmc_rescan, "", ""), U_BOOT_CMD_MKENT(part, 1, 1, do_mmc_part, "", ""),
- U_BOOT_CMD_MKENT(dev, 4, 0, do_mmc_dev, "", ""), U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""),
- "mmc rescan\n"
- "mmc rescan [mode]\n" "mmc part - lists available partition on current mmc device\n"
- "mmc dev [dev] [part] [mode] - show or set current mmc device [partition] and set mode\n"
- " - the required speed mode is passed as the index from the following list\n"
- " [MMC_LEGACY, MMC_HS, SD_HS, MMC_HS_52, MMC_DDR_52, UHS_SDR12, UHS_SDR25,\n"
- " UHS_SDR50, UHS_DDR50, UHS_SDR104, MMC_HS_200, MMC_HS_400, MMC_HS_400_ES]\n" "mmc list - lists available devices\n" "mmc wp - power on write protect boot partitions\n"
- mmc->user_speed_mode = MMC_MODES_END;
+#endif return 0; }
- if (mmc->user_speed_mode != MMC_MODES_END) {
int i;
/* set host caps */
} else {
return -EINVAL;
- enum bus_mode user_speed_mode;
+#endif };
Hi Jaehoon,
On 30/07/21 4:00 am, Jaehoon Chung wrote:
Hi Aswath,
Sure, I'll update it in the respin.
Thanks, Aswath
- default n
- help
- if (argc == 1) {
- } else {
- "mmc rescan\n"
+#endif return 0; }
int i;
/* set host caps */
} else {
return -EINVAL;
+#endif };
Hi Aswath,
On 7/30/21 2:12 PM, Aswath Govindraju wrote:
Hi Jaehoon,
Hi Aswath,
When I have simply tested with this patch, it's not working correct. I will test more and share them. Did you test about SD-card?
Best Regards, Jaehoon Chung
Thanks, Aswath
- default n
- help
- if (argc == 1) {
- } else {
- "mmc rescan\n"
+#endif return 0; }
int i;
/* set host caps */
} else {
return -EINVAL;
+#endif };
Hi Jaehoon,
On 30/07/21 2:44 pm, Jaehoon Chung wrote:
Hi Aswath,
Hi Jaehoon,
Hi Aswath,
Yes, I tested with both SD-Card and eMMC.
Also, please note that MMC_SPEED_MODE_SET has to be enabled in the defconfig files.
Thanks, Aswath
Thanks, Aswath
- default n
- help
- if (argc == 1) {
- } else {
- "mmc rescan\n"
+#endif return 0; }
int i;
/* set host caps */
} else {
return -EINVAL;
+#endif };
On 7/30/21 6:20 PM, Aswath Govindraju wrote:
Hi Jaehoon,
Hi Aswath,
Hi Jaehoon,
Hi Aswath,
I did. :) (enabled MMC_SPEED_MODE_SET). If it's not supported mode, it seems that always set to LEGACY mode. Is it intention behavior?
I will test on eMMC and SD. Well it will take a little time. Maybe Next week?
Thanks, Aswath
Thanks, Aswath
- default n
- help
- if (argc == 1) {
- } else {
- "mmc rescan\n"
+#endif return 0; }
int i;
/* set host caps */
} else {
return -EINVAL;
+#endif };
Hi Jaehoon,
Hi Jaehoon,
Hi Aswath,
Hi Jaehoon,
Hi Aswath,
Actually I just found one error but I am not sure if it is the same error you are seeing.
In my case even if mode is supported it shows that if is not supported and this is because of [1], it should have been dev there. On correcting it I don't see this error anymore.
No, it is not expected to always set to MMC_LEGACY mode if an unsupported mode is input.
Sure, I will post a respin before this weekend. Please do test and share your results.
Thanks, Aswath
Thanks, Aswath
Thanks, Aswath
- default n
- help
- if (argc == 1) {
- } else {
[1]
- "mmc rescan\n"
+#endif return 0; }
int i;
/* set host caps */
} else {
return -EINVAL;
+#endif };
Hi Aswath,
-----Original Message----- From: Aswath Govindraju a-govindraju@ti.com Sent: Thursday, July 29, 2021 8:25 PM Cc: Lokesh Vutla lokeshvutla@ti.com; Vignesh Raghavendra vigneshr@ti.com; Kishon Vijay Abraham I kishon@ti.com; Aswath Govindraju a-govindraju@ti.com; Peng Fan peng.fan@nxp.com; Jaehoon Chung jh80.chung@samsung.com; Simon Glass sjg@chromium.org; Heinrich Schuchardt xypron.glpk@gmx.de; Bin Meng bmeng.cn@gmail.com; Patrick Delaunay patrick.delaunay@foss.st.com; Pragnesh Patel pragnesh.patel@sifive.com; Frédéric Danis frederic.danis@collabora.com; Reuben Dowle reubendowle0@gmail.com; Yangbo Lu yangbo.lu@nxp.com; Stefan Bosch stefan_b@posteo.net; Ashok Reddy Soma ashokred@xilinx.com; Nicolas Saenz Julienne nsaenzjulienne@suse.de; Pali Rohár pali@kernel.org; u-boot@lists.denx.de Subject: [PATCH] mmc: Add support for enumerating MMC card in a given mode using mmc command
- default n
- help
commands.
Can you please use if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET)
- if (argc == 1) {
MMC_MODES_END);
- } else {
- U_BOOT_CMD_MKENT(dev, 4, 0, do_mmc_dev, "", ""), U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""), #if
- "mmc rescan\n"
list\n"
same here
return 0; }
here as well
Thanks, Ashok
int i;
/* set host caps */
user_speed_mode)
MMC_MODE_1BIT);
} else {
return -EINVAL;
+#endif };
2.17.1
Hi Ashok,
On 30/07/21 10:17 am, Ashok Reddy Soma wrote:
Hi Aswath,
- default n
- help
commands.
- if (argc == 1) {
MMC_MODES_END);
- } else {
- "mmc rescan\n"
list\n"
same here
return 0; }
here as well
I can't use if (IS_ENABLED(CONFIG_MMC_SPEED_MODE_SET) because of [1], as it would lead to build errors.
If it is ok, to remove #ifdef around [1] and add user_speed_mode field irrespective of config, then I will be able to use it.
Thanks, Aswath
Thanks, Ashok
int i;
/* set host caps */
user_speed_mode)
MMC_MODE_1BIT);
} else {
return -EINVAL;
[1]
2.17.1
HI Aswath,
-----Original Message----- From: Aswath Govindraju a-govindraju@ti.com Sent: Friday, July 30, 2021 10:41 AM To: Ashok Reddy Soma ashokred@xilinx.com Cc: Lokesh Vutla lokeshvutla@ti.com; Vignesh Raghavendra vigneshr@ti.com; Kishon Vijay Abraham I kishon@ti.com; Peng Fan peng.fan@nxp.com; Jaehoon Chung jh80.chung@samsung.com; Simon Glass sjg@chromium.org; Heinrich Schuchardt xypron.glpk@gmx.de; Bin Meng bmeng.cn@gmail.com; Patrick Delaunay patrick.delaunay@foss.st.com; Pragnesh Patel pragnesh.patel@sifive.com; Frédéric Danis frederic.danis@collabora.com; Reuben Dowle reubendowle0@gmail.com; Yangbo Lu yangbo.lu@nxp.com; Stefan Bosch stefan_b@posteo.net; Nicolas Saenz Julienne nsaenzjulienne@suse.de; Pali Rohár pali@kernel.org; u-boot@lists.denx.de Subject: Re: [PATCH] mmc: Add support for enumerating MMC card in a given mode using mmc command
Hi Ashok,
Hi Aswath,
Bosch
- default n
- help
commands.
flag,
- if (argc == 1) {
MMC_MODES_END);
- } else {
flag,
#endif
- "mmc rescan\n"
+following list\n"
- mmc->user_speed_mode = MMC_MODES_END; #endif
same here
return 0; }
here as well
I see no problem in removing [1]. Please go ahead.
Thanks, Ashok
Thanks, Aswath
Thanks, Ashok
int i;
/* set host caps */
user_speed_mode)
MMC_MODE_1BIT);
} else {
return -EINVAL;
[1]
2.17.1
Ashok Reddy Soma
Aswath Govindraju
Jaehoon Chung
