RE: [U-Boot-Users] omap2420h4 u-boot debugging CCS JTAG
Komal,
As long as you have set your SDR and GPMC timings correctly you can load into DDR to start your work. Do know that the code will skip Clock and DDR init then.
Yes. I am running from SDRAM. And loading the "elf" through CCS.
Is there anything specific you are expecting for the gel files to do it?
Generally, I and have the gel file do nothing, and load directly into SRAM for initial debugging. Then try it from SDRAM, then finally from flash. I've had good success stepping everything with a Lauterbach emulator.
And in debugging the new cvs code, it gives me following values for the registers after executing the following instruction:
80E80554 E59FD024 LDR R13, 0x80E80580
You providing the info that SP (R13) = 0x0 confuses me. Is your working SP really 0, or is it 0x4020FFC. You should be in SVC mode, so I bet its 0x4020FFFC, which would be correct. Why do you provide the 0 info, is this after the fatal abort, perhaps?
SP(R13) : 0x00000000 R13_SVC : 0x4020FFFC
value at 0x80E80580 is 0x4020FFFC.
But the next instruction
80E80558 E58DC000 STR R12, [R13]
If R13 as seen in your register has a 0 in it, then your crash is expected (originally, I thought this was your case due to a memory or image mis-configuration). If it has 0x4020FFFC in it, then it shouldn't crash.
If it crashed with 0x4020FFFC, I'd say you are using an OLD version of CCS which for some unknown reason needed a different driver to access SRAM. Other emulators I've used didn't have this issue, but I did hear that some version of CCS did.
So update your CCS. Or ask them for the magic driver which allows you to access SRAM.
You will likely have some crashes due to needed changes in the code, but this is not one of them. It is likely a tool issue.
I don't have the same emulator you are using so I can't really help out directly here.
Regards, Richard W.
Richard,
Yes. I gone through the code of s_init(...) and if(!sdram)..stuff !!!.
I need to acquire the Lauterbach soon then :-).
Right now I am using 2.30.01 + patch for 24xx, with xds560 jtag driver supplied with the CCS.
Sure. I will check up and come back with more debug test outputs.
Yes. I think it is time to update the tools.
===== ---Komal Shah
__________________________________ Do you Yahoo!? The all-new My Yahoo! - What will yours do? http://my.yahoo.com
Also consider a BDI2000. It's better integrated with the U-Bot and Linux environment, and less pricey.
Komal Shah
Woodruff, Richard
