[U-Boot] [PATCH] arm: socfpga: migration of CONFIG_SPI_FLASH_BAR
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h and placed in socfpga_*_defconfig where it makes sense.
Signed-off-by: Denis Bakhvalov denis.bakhvalov@nokia.com Reported-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com --- configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + include/configs/socfpga_common.h | 2 -- 8 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 7b60d95..505a68d 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -19,6 +19,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 6a487f4..df19a95 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -19,6 +19,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index cfcae5d..5e18844 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -18,6 +18,7 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y +CONFIG_SPI_FLASH_BAR=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index b6f6a65..8a76aa1 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -19,5 +19,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y +CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index f45c3ed..36bb1e1 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -19,6 +19,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index e25d09b..0aaef76 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -22,6 +22,7 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y +CONFIG_SPI_FLASH_BAR=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index d499a14..83eada3 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -17,6 +17,7 @@ CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 56d32e6..2ad0287 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -93,7 +93,6 @@ #define CONFIG_CMD_SPI #define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 30000000 -#define CONFIG_SPI_FLASH_BAR /* * The base address is configurable in QSys, each board must specify the * base address based on it's particular FPGA configuration. Please note @@ -219,7 +218,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #endif #define CONFIG_CQSPI_DECODER 0 #define CONFIG_CMD_SF -#define CONFIG_SPI_FLASH_BAR
/* * Designware SPI support -- 2.7.0
On 03/22/2016 10:26 AM, Bakhvalov, Denis (Nokia - PL/Wroclaw) wrote:
Hi!
Thanks for the patch, comments below.
I didn't report this stuff, so just Cc me.
This change is fine with me.
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Hi!
The patch does not apply, so please rebase on u-boot-socfpga/master and repost. You can keep the Ack.
