[PATCH 00/31] Allow building sandbox with MSYS2
This expands the existing work to allow sandbox to build and run on Windows using MSYS2.
It also fixes a few issues so that binman can be used.
There are various limitations and some features do not work fully yet. In particular, weak functions are not well supported on Windows so these are disabled. Various minor compiler-flag and filename adjustments are also needed.
This does not support SDL, so U-Boot has no display. This is potentially possible, but requires using minggw instead of the base toolchain [1] so needs to be dealt with separately.
[1] https://gist.github.com/thales17/fb2e4cff60890a51d9dddd4c6e832ad2
Simon Glass (31): patman: Declare the future Series memory u_boot_pylib: Correct name of readme u_boot_pylib: Make pty optional binman: Avoid using a symlink binman: Don't require a HOME directory pylibfdt: Allow building on Windows Fix Makefile warning about parallel targets mkimage: Correct checking of configuration node Kbuild: Detect including an MSYS2 path sandbox: Provide a linker script for MSYS2 sandbox: Provide an EFI link script for PE sandbox: Drop dead code from Makefile sandbox: Disable raw Ethernet on MSYS2 sandbox: Drop signal handling for MSYS2 sandbox: Correct SDL.h header inclusion sandbox: Include errno.h in the test header sandbox: Allow weak symbols to be dropped sections: Drop use of linux/types.h sandbox: Drop incorrect inclusion of linux/types.h sandbox: Drop inclusion of os.h in sscanf.c test: Avoid strange symbols in the assembler file sandbox: Fix up setting of monitor_len on MSYS2 ctype: Avoid using a symlink build: Disable weak symbols for MSYS2 Makefile: Disable unsupported compiler options with PE Makefile: Correct the ans1_compiler rule for MSYS2 Makefile: Disable LTO when building with MSYS2 doc: Update the MSYS2 packages and versions doc: Show how to build sandbox for MSYS2 Makefile: Drop unwind tables CI: Enable sandbox build for Windows
.azure-pipelines.yml | 27 ++ Kconfig | 15 + Makefile | 27 +- arch/sandbox/Makefile | 7 - arch/sandbox/config.mk | 8 +- arch/sandbox/cpu/Makefile | 2 + arch/sandbox/cpu/os.c | 3 +- arch/sandbox/cpu/sdl.c | 2 +- arch/sandbox/cpu/u-boot-pe.lds | 447 ++++++++++++++++++++++++++ arch/sandbox/include/asm/test.h | 1 + arch/x86/lib/crt0_x86_64_efi.S | 2 + arch/x86/lib/pe_x86_64_efi.lds | 83 +++++ cmd/bootefi.c | 3 +- cmd/bootz.c | 3 + common/board_f.c | 2 +- common/usb.c | 3 + doc/build/gcc.rst | 35 ++ doc/build/tools.rst | 20 +- drivers/core/root.c | 3 + drivers/net/Makefile | 2 + drivers/spi/sandbox_spi.c | 3 + env/env.c | 6 + include/asm-generic/sections.h | 16 +- include/ctype.h | 7 +- include/linux/compiler_attributes.h | 4 + include/os.h | 2 - include/test/test.h | 4 +- lib/efi_loader/Makefile | 8 + lib/efi_loader/efi_image_loader.c | 3 + lib/efi_loader/efi_runtime.c | 4 + lib/lmb.c | 4 +- lib/sscanf.c | 1 - lib/time.c | 3 + scripts/Kbuild.include | 3 +- scripts/Makefile.build | 2 +- scripts/Makefile.lib | 9 +- scripts/dtc/pylibfdt/Makefile | 16 +- scripts/make_pip.sh | 9 +- tools/Makefile | 14 +- tools/binman/binman | 11 +- tools/binman/cmdline.py | 2 +- tools/image-host.c | 4 +- tools/patman/commit.py | 3 + tools/u_boot_pylib/README.rst | 2 +- tools/u_boot_pylib/cros_subprocess.py | 28 +- tools/u_boot_pylib/pyproject.toml | 2 +- 46 files changed, 803 insertions(+), 62 deletions(-) create mode 100644 arch/sandbox/cpu/u-boot-pe.lds create mode 100644 arch/x86/lib/pe_x86_64_efi.lds mode change 120000 => 100644 include/ctype.h mode change 120000 => 100755 tools/binman/binman
This member is used in series.MakeCcFile() so should be declared in the Series class.
Add a declaration to silence the warning.
tools/patman/commit.py | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/patman/commit.py b/tools/patman/commit.py index 9537de43d391..684225c0e60d 100644 --- a/tools/patman/commit.py +++ b/tools/patman/commit.py @@ -29,6 +29,8 @@ class Commit: value: Set of people who gave that rtag, each a name/email string warn: List of warnings for this commit, each a str patch (str): Filename of the patch file for this commit + future (concurrent.futures.Future): Future object for processing this + commit, or None """ def __init__(self, hash): self.hash = hash @@ -42,6 +44,7 @@ class Commit: self.rtags = collections.defaultdict(set) self.warn = [] self.patch = '' + self.future = None
def __str__(self): return self.subject
This has an rst prefix rather than md. Fix it.
tools/u_boot_pylib/README.rst | 2 +- tools/u_boot_pylib/pyproject.toml | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/u_boot_pylib/README.rst b/tools/u_boot_pylib/README.rst index 93858f5571da..b1bab4364896 100644 --- a/tools/u_boot_pylib/README.rst +++ b/tools/u_boot_pylib/README.rst @@ -1,6 +1,6 @@ .. SPDX-License-Identifier: GPL-2.0+
-# U-Boot Python Library +U-Boot Python Library =====================
This is a Python library used by various U-Boot tools, including patman, diff --git a/tools/u_boot_pylib/pyproject.toml b/tools/u_boot_pylib/pyproject.toml index 3f33caf6f8d2..31a4c0adae87 100644 --- a/tools/u_boot_pylib/pyproject.toml +++ b/tools/u_boot_pylib/pyproject.toml @@ -9,7 +9,7 @@ authors = [ { name="Simon Glass", email="sjg@chromium.org" }, ] description = "U-Boot python library" -readme = "README.md" +readme = "README.rst" requires-python = ">=3.7" classifiers = [ "Programming Language :: Python :: 3",
This library is not available on Windows. Detect this and work around it by using a normal pipe.
scripts/make_pip.sh | 9 +++++++-- tools/u_boot_pylib/cros_subprocess.py | 28 ++++++++++++++++++++++----- 2 files changed, 30 insertions(+), 7 deletions(-)
diff --git a/scripts/make_pip.sh b/scripts/make_pip.sh index 4602dcf61c88..bcff65240ba1 100755 --- a/scripts/make_pip.sh +++ b/scripts/make_pip.sh @@ -91,7 +91,12 @@ find ${dest} -name __pycache__ -type f -exec rm {} ; find ${dest} -depth -name __pycache__ -exec rmdir 112 ;
# Remove test files -rm -rf ${dest}/*test* +for path in ${dest}/*test*; do + echo ${path} + if ! [[ "${path}" =~ .*test_util.* ]]; then + rm -rf ${path} + fi +done
mkdir ${dir}/tests cd ${dir} @@ -108,7 +113,7 @@ echo "Completed build of ${tool}" # Use --skip-existing to work even if the version is already present if [ -n "${upload}" ]; then echo "Uploading from ${dir}" - python3 -m twine upload ${repo} -u __token__ dist/* + python3 -m twine upload ${repo} --verbose -u __token__ dist/* echo "Completed upload of ${tool}" fi
diff --git a/tools/u_boot_pylib/cros_subprocess.py b/tools/u_boot_pylib/cros_subprocess.py index cd614f38a648..35cef7333f3a 100644 --- a/tools/u_boot_pylib/cros_subprocess.py +++ b/tools/u_boot_pylib/cros_subprocess.py @@ -16,12 +16,18 @@ progress information and filter output in real time.
import errno import os -import pty import select import subprocess import sys import unittest
+try: + import pty + HAVE_PTY = True +except: + # For Windows + HAVE_PTY = False +
# Import these here so the caller does not need to import subprocess also. PIPE = subprocess.PIPE @@ -74,11 +80,17 @@ class Popen(subprocess.Popen): stderr_pty = None
if stdout == PIPE_PTY: - stdout_pty = pty.openpty() - stdout = os.fdopen(stdout_pty[1]) + if HAVE_PTY: + stdout_pty = pty.openpty() + stdout = os.fdopen(stdout_pty[1]) + else: + stdout = PIPE if stderr == PIPE_PTY: - stderr_pty = pty.openpty() - stderr = os.fdopen(stderr_pty[1]) + if HAVE_PTY: + stderr_pty = pty.openpty() + stderr = os.fdopen(stderr_pty[1]) + else: + stderr = PIPE
super(Popen, self).__init__(args, stdin=stdin, stdout=stdout, stderr=stderr, shell=shell, cwd=cwd, env=env, @@ -156,6 +168,12 @@ class Popen(subprocess.Popen): Note also that if you set stderr to STDOUT, then stderr will be empty and the combined output will just be the same as stdout. """ + if not HAVE_PTY: + stdout, stderr = self.communicate(input_buf) + stdout = self.convert_data(stdout) + stderr = self.convert_data(stderr) + combined = self.convert_data(stdout + stderr) + return (stdout, stderr, combined)
read_set = [] write_set = []
- echo ${path}
- if ! [[ "${path}" =~ .*test_util.* ]]; then
rm -rf ${path}
- fi
+done
- python3 -m twine upload ${repo} --verbose -u __token__ dist/* echo "Completed upload of ${tool}"
fi
The verbose here is I assume a debugging left-over.
Use a small Python script instead of a symlink to avoid problems with Windows.
tools/binman/binman | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-) mode change 120000 => 100755 tools/binman/binman
diff --git a/tools/binman/binman b/tools/binman/binman deleted file mode 120000 index 11a5d8e18ab7..000000000000 --- a/tools/binman/binman +++ /dev/null @@ -1 +0,0 @@ -main.py \ No newline at end of file diff --git a/tools/binman/binman b/tools/binman/binman new file mode 100755 index 000000000000..2b0633073abc --- /dev/null +++ b/tools/binman/binman @@ -0,0 +1,10 @@ +#!/usr/bin/env python3 +# SPDX-License-Identifier: GPL-2.0+ + +import os + +our_path = os.path.dirname(os.path.realpath(__file__)) + +import main + +main.start_binman()
This doesn't exist on Windows, so use os.expanduser() instead.
tools/binman/cmdline.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/cmdline.py b/tools/binman/cmdline.py index 4b875a9dcda3..fafccab06012 100644 --- a/tools/binman/cmdline.py +++ b/tools/binman/cmdline.py @@ -95,7 +95,7 @@ controlled by a description in the board device tree.''' parser.add_argument('-H', '--full-help', action='store_true', default=False, help='Display the README file') parser.add_argument('--tooldir', type=str, - default=os.path.join(os.getenv('HOME'), '.binman-tools'), + default=os.path.expanduser('~/binman-tools'), help='Set the directory to store tools') parser.add_argument('--toolpath', type=str, action='append', help='Add a path to the list of directories containing tools')
Handle the different shared-object extension with MSYS2 by creating a new SOEXT variable.
Makefile | 11 +++++++++++ scripts/dtc/pylibfdt/Makefile | 16 +++++++++------- 2 files changed, 20 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index eaaf7d267d31..dd3fcd1782e5 100644 --- a/Makefile +++ b/Makefile @@ -39,6 +39,17 @@ else ifeq ("riscv64", $(MK_ARCH)) endif undefine MK_ARCH
+# Building on Windows with MSYS2 +export MSYS_VERSION = $(if $(findstring Msys, $(shell uname -o)),$(word 1, $(subst ., ,$(shell uname -r))),0) +# $(info The version of MSYS you are running is $(MSYS_VERSION) (0 meaning not MSYS at all)) + +# Sets the extension to use for shared-object files +ifeq ($(MSYS_VERSION),0) +export SOEXT := so +else +export SOEXT := dll +endif + # Avoid funny character set dependencies unexport LC_ALL LC_COLLATE=C diff --git a/scripts/dtc/pylibfdt/Makefile b/scripts/dtc/pylibfdt/Makefile index e442d5c24201..feca0bb9abb1 100644 --- a/scripts/dtc/pylibfdt/Makefile +++ b/scripts/dtc/pylibfdt/Makefile @@ -7,6 +7,8 @@ LIBFDT_srcdir = $(abspath $(srctree)/$(src)/../libfdt)
include $(LIBFDT_srcdir)/Makefile.libfdt
+LIBFILE := _libfdt.$(SOEXT) + # Unfortunately setup.py (or actually the Python distutil implementation) puts # files into the same directory as the .i file. We cannot touch the source # directory, so we "ship" .i file into the objtree. @@ -29,16 +31,16 @@ quiet_cmd_pymod = PYMOD $@ rebuild: $(src)/setup.py $(PYLIBFDT_srcs) @# Remove the library since otherwise Python doesn't seem to regenerate @# the libfdt.py file if it is missing. - @rm -f $(obj)/_libfdt*.so + @rm -f $(obj)/_libfdt*.$(SOEXT) $(call if_changed,pymod) - @# Rename the file to _libfdt.so so this Makefile doesn't run every time - @if [ ! -e $(obj)/_libfdt.so ]; then \ - mv $(obj)/_libfdt*.so $(obj)/_libfdt.so; \ + @# Rename the file to $(LIBFILE) so this Makefile doesn't run every time + @if [ ! -e $(obj)/$(LIBFILE) ]; then \ + mv $(obj)/_libfdt*.$(SOEXT) $(obj)/$(LIBFILE); \ fi
-$(obj)/_libfdt.so $(obj)/libfdt.py &: rebuild +$(obj)/$(LIBFILE) $(obj)/libfdt.py &: rebuild @:
-always += _libfdt.so libfdt.py +always += $(LIBFILE) libfdt.py
-clean-files += libfdt.i _libfdt.so libfdt.py libfdt_wrap.c +clean-files += libfdt.i $(LIBFILE) libfdt.py libfdt_wrap.c
LIBEXT would be a better name as "SO" name refers to ELF. I saw that variable LIBEXT is used in more projects for this purpose.
- @rm -f $(obj)/_libfdt*.$(SOEXT) $(call if_changed,pymod)
- @# Rename the file to $(LIBFILE) so this Makefile doesn't run every time
- @if [ ! -e $(obj)/$(LIBFILE) ]; then \
fimv $(obj)/_libfdt*.$(SOEXT) $(obj)/$(LIBFILE); \
2.40.0.634.g4ca3ef3211-goog
These targets are not really parallel; they are handled one at a time when invoked by other rules. Some recent versions of make (e.g. on MSYS2) give a warning about this. Split out the rules to avoid the warning.
tools/Makefile | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/tools/Makefile b/tools/Makefile index 38699b069d63..2c5df76638f6 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -263,7 +263,19 @@ HOSTCFLAGS_sha512.o := -pedantic -DCONFIG_SHA512 -DCONFIG_SHA384 quiet_cmd_wrap = WRAP $@ cmd_wrap = echo "#include <../$(patsubst $(obj)/%,%,$@)>" >$@
-$(obj)/boot/%.c $(obj)/common/%.c $(obj)/env/%.c $(obj)/lib/%.c: +# $(obj)/boot/%.c $(obj)/common/%.c $(obj)/env/%.c $(obj)/lib/%.c: +# $(call cmd,wrap) + +$(obj)/boot/%.c: + $(call cmd,wrap) + +$(obj)/common/%.c: + $(call cmd,wrap) + +$(obj)/env/%.c: + $(call cmd,wrap) + +$(obj)/lib/%.c: $(call cmd,wrap)
clean-dirs := lib common
This returns a negative value on error. Update the logic to detect this and avoid a segfault when the node is not found.
tools/image-host.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/tools/image-host.c b/tools/image-host.c index 4a24dee8153c..e4e44e33badd 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -1336,8 +1336,10 @@ int fit_check_sign(const void *fit, const void *key, int ret;
cfg_noffset = fit_conf_get_node(fit, fit_uname_config); - if (!cfg_noffset) + if (cfg_noffset < 0) { + fprintf(stderr, "Configuration node not found\n"); return -1; + }
printf("Verifying Hash Integrity for node '%s'... ", fdt_get_name(fit, cfg_noffset, NULL));
The source-tree directory is prepended to relative include paths, but this does not work on Windows, where a path may have a drive letter like C: at the start of it.
This breaks SDL which includes an absolute path to the header directory to the C flags, e.g. -IC:/msys64/mingw64/include/SDL2
Add this as a special case to leave these absolute paths alone on Windows.
scripts/Kbuild.include | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 62e0207f91b4..411a768a7767 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -205,9 +205,10 @@ clean := -f $(srctree)/scripts/Makefile.clean obj hdr-inst := -f $(srctree)/scripts/Makefile.headersinst obj
# Prefix -I with $(srctree) if it is not an absolute path. +# Detect C: (C drive) with MSYS2 # skip if -I has no parameter addtree = $(if $(patsubst -I%,%,$(1)), \ -$(if $(filter-out -I/% -I./% -I../%,$(1)),$(patsubst -I%,-I$(srctree)/%,$(1)),$(1)),$(1)) +$(if $(filter-out -I/% -I./% -I../% -IC:%,$(1)),$(patsubst -I%,-I$(srctree)/%,$(1)),$(1)),$(1))
# Find all -I options and call addtree flags = $(foreach o,$($(1)),$(if $(filter -I%,$(o)),$(call addtree,$(o)),$(o)))
Add a script to allow the U-Boot sandbox executable to be built for Windows. Add a note as to why this seems to be necessary for now.
Makefile | 11 +- arch/sandbox/config.mk | 4 + arch/sandbox/cpu/u-boot-pe.lds | 447 +++++++++++++++++++++++++++++++++ 3 files changed, 460 insertions(+), 2 deletions(-) create mode 100644 arch/sandbox/cpu/u-boot-pe.lds
diff --git a/Makefile b/Makefile index dd3fcd1782e5..0aa97a2c3b48 100644 --- a/Makefile +++ b/Makefile @@ -1730,6 +1730,13 @@ else u-boot-keep-syms-lto := endif
+ifeq ($(MSYS_VERSION),0) +add_ld_script := -T u-boot.lds +else +add_ld_script := u-boot.lds +$(warning msys) +endif + # Rule to link u-boot # May be overridden by arch/$(ARCH)/config.mk ifeq ($(LTO_ENABLE),y) @@ -1738,7 +1745,7 @@ quiet_cmd_u-boot__ ?= LTO $@ $(CC) -nostdlib -nostartfiles \ $(LTO_FINAL_LDFLAGS) $(c_flags) \ $(KBUILD_LDFLAGS:%=-Wl,%) $(LDFLAGS_u-boot:%=-Wl,%) -o $@ \ - -T u-boot.lds $(u-boot-init) \ + $(add_ld_script) $(u-boot-init) \ -Wl,--whole-archive \ $(u-boot-main) \ $(u-boot-keep-syms-lto) \ @@ -1749,7 +1756,7 @@ quiet_cmd_u-boot__ ?= LTO $@ else quiet_cmd_u-boot__ ?= LD $@ cmd_u-boot__ ?= $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ - -T u-boot.lds $(u-boot-init) \ + $(add_ld_script) $(u-boot-init) \ --whole-archive \ $(u-boot-main) \ --no-whole-archive \ diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index 2d184c5f652a..e05daf57ef8e 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -71,3 +71,7 @@ EFI_CRT0 := crt0_sandbox_efi.o EFI_RELOC := reloc_sandbox_efi.o AFLAGS_crt0_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" CFLAGS_reloc_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" + +ifneq ($(MSYS_VERSION),0) +LDSCRIPT = $(srctree)/arch/sandbox/cpu/u-boot-pe.lds +endif diff --git a/arch/sandbox/cpu/u-boot-pe.lds b/arch/sandbox/cpu/u-boot-pe.lds new file mode 100644 index 000000000000..031e70fafd03 --- /dev/null +++ b/arch/sandbox/cpu/u-boot-pe.lds @@ -0,0 +1,447 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * U-Boot note: This was obtained by using the -verbose linker option. The + * U-Boot additions are marked below. + * + * Ideally we would add sections to the executable, as is done with the Linux + * build. But PE executables do not appear to work correctly if unexpected + * sections are present: + * + * $ /tmp/b/sandbox/u-boot.exe + * -bash: /tmp/b/sandbox/u-boot.exe: cannot execute binary file: Exec format error + * + * So we take a approach of rewriting the whole file, for now. This will likely + * break in the future when a toolchain change is made. + */ + +/* Default linker script, for normal executables */ +/* Copyright (C) 2014-2023 Free Software Foundation, Inc. + Copying and distribution of this script, with or without modification, + are permitted in any medium without royalty provided the copyright + notice and this notice are preserved. */ + +OUTPUT_FORMAT(pei-x86-64) +SEARCH_DIR("/usr/x86_64-pc-msys/lib"); SEARCH_DIR("/usr/lib"); SEARCH_DIR("/usr/lib/w32api"); +SECTIONS +{ + /* Make the virtual address and file offset synced if the alignment is + lower than the target page size. */ + . = SIZEOF_HEADERS; + . = ALIGN(__section_alignment__); + .text __image_base__ + ( __section_alignment__ < 0x1000 ? . : __section_alignment__ ) : + { + KEEP (*(SORT_NONE(.init))) + *(.text) + *(SORT(.text$*)) + *(.text.*) + *(.gnu.linkonce.t.*) + *(.glue_7t) + *(.glue_7) + . = ALIGN(8); + /* Note: we always define __CTOR_LIST__ and ___CTOR_LIST__ here, + we do not PROVIDE them. This is because the ctors.o startup + code in libgcc defines them as common symbols, with the + expectation that they will be overridden by the definitions + here. If we PROVIDE the symbols then they will not be + overridden and global constructors will not be run. + See PR 22762 for more details. + + This does mean that it is not possible for a user to define + their own __CTOR_LIST__ and __DTOR_LIST__ symbols; if they do, + the content from those variables are included but the symbols + defined here silently take precedence. If they truly need to + be redefined, a custom linker script will have to be used. + (The custom script can just be a copy of this script with the + PROVIDE() qualifiers added). + In particular this means that ld -Ur does not work, because + the proper __CTOR_LIST__ set by ld -Ur is overridden by a + bogus __CTOR_LIST__ set by the final link. See PR 46. */ + ___CTOR_LIST__ = .; + __CTOR_LIST__ = .; + LONG (-1); LONG (-1); + KEEP (*(.ctors)); + KEEP (*(.ctor)); + KEEP (*(SORT_BY_NAME(.ctors.*))); + LONG (0); LONG (0); + /* See comment about __CTOR_LIST__ above. The same reasoning + applies here too. */ + ___DTOR_LIST__ = .; + __DTOR_LIST__ = .; + LONG (-1); LONG (-1); + KEEP (*(.dtors)); + KEEP (*(.dtor)); + KEEP (*(SORT_BY_NAME(.dtors.*))); + LONG (0); LONG (0); + KEEP (*(SORT_NONE(.fini))) + /* ??? Why is .gcc_exc here? */ + *(.gcc_exc) + PROVIDE (etext = .); + KEEP (*(.gcc_except_table)) + } + /* The Cygwin32 library uses a section to avoid copying certain data + on fork. This used to be named ".data". The linker used + to include this between __data_start__ and __data_end__, but that + breaks building the cygwin32 dll. Instead, we name the section + ".data_cygwin_nocopy" and explicitly include it after __data_end__. */ + .data BLOCK(__section_alignment__) : + { + __data_start__ = . ; + *(.data) + *(.data2) + *(SORT(.data$*)) + KEEP(*(.jcr)) + __data_end__ = . ; + *(.data_cygwin_nocopy) + } + .rdata BLOCK(__section_alignment__) : + { + *(.rdata) + *(SORT(.rdata$*)) + . = ALIGN(4); + __rt_psrelocs_start = .; + KEEP(*(.rdata_runtime_pseudo_reloc)) + __rt_psrelocs_end = .; + + /* U-Boot additions from here on */ + . = ALIGN(4); + KEEP(*(SORT(__u_boot_list*))); + + *(_u_boot_sandbox_getopt_start) + *(_u_boot_sandbox_getopt) + *(_u_boot_sandbox_getopt_end) + + *(___efi_runtime_start) + *(efi_runtime_text) + *(efi_runtime_data) + *(___efi_runtime_stop) + + *(___efi_runtime_rel_start) + *(.relefi_runtime_text) + *(.relefi_runtime_data) + *(___efi_runtime_rel_stop) + + . = ALIGN(4); + *(.rodata.ttf.init) + *(.rodata.splash.init) + *(.rodata.helloworld.init) + *(.dtb.init.rodata) + + /* U-Boot additions end */ + } + __rt_psrelocs_size = __rt_psrelocs_end - __rt_psrelocs_start; + ___RUNTIME_PSEUDO_RELOC_LIST_END__ = .; + __RUNTIME_PSEUDO_RELOC_LIST_END__ = .; + ___RUNTIME_PSEUDO_RELOC_LIST__ = . - __rt_psrelocs_size; + __RUNTIME_PSEUDO_RELOC_LIST__ = . - __rt_psrelocs_size; + .eh_frame BLOCK(__section_alignment__) : + { + KEEP (*(.eh_frame*)) + } + .pdata BLOCK(__section_alignment__) : + { + KEEP(*(.pdata*)) + } + .xdata BLOCK(__section_alignment__) : + { + KEEP(*(.xdata*)) + } + .bss BLOCK(__section_alignment__) : + { + __bss_start__ = . ; + *(.bss) + *(COMMON) + __bss_end__ = . ; + } + .edata BLOCK(__section_alignment__) : + { + *(.edata) + } + /DISCARD/ : + { + *(.debug$S) + *(.debug$T) + *(.debug$F) + *(.drectve) + *(.note.GNU-stack) + *(.gnu.lto_*) + } + .idata BLOCK(__section_alignment__) : + { + /* This cannot currently be handled with grouped sections. + See pep.em:sort_sections. */ + KEEP (SORT(*)(.idata$2)) + KEEP (SORT(*)(.idata$3)) + /* These zeroes mark the end of the import list. */ + LONG (0); LONG (0); LONG (0); LONG (0); LONG (0); + . = ALIGN(8); + KEEP (SORT(*)(.idata$4)) + __IAT_start__ = .; + SORT(*)(.idata$5) + __IAT_end__ = .; + KEEP (SORT(*)(.idata$6)) + KEEP (SORT(*)(.idata$7)) + } + .CRT BLOCK(__section_alignment__) : + { + ___crt_xc_start__ = . ; + KEEP (*(SORT(.CRT$XC*))) /* C initialization */ + ___crt_xc_end__ = . ; + ___crt_xi_start__ = . ; + KEEP (*(SORT(.CRT$XI*))) /* C++ initialization */ + ___crt_xi_end__ = . ; + ___crt_xl_start__ = . ; + KEEP (*(SORT(.CRT$XL*))) /* TLS callbacks */ + /* ___crt_xl_end__ is defined in the TLS Directory support code */ + ___crt_xp_start__ = . ; + KEEP (*(SORT(.CRT$XP*))) /* Pre-termination */ + ___crt_xp_end__ = . ; + ___crt_xt_start__ = . ; + KEEP (*(SORT(.CRT$XT*))) /* Termination */ + ___crt_xt_end__ = . ; + } + /* Windows TLS expects .tls$AAA to be at the start and .tls$ZZZ to be + at the end of the .tls section. This is important because _tls_start MUST + be at the beginning of the section to enable SECREL32 relocations with TLS + data. */ + .tls BLOCK(__section_alignment__) : + { + ___tls_start__ = . ; + KEEP (*(.tls$AAA)) + KEEP (*(.tls)) + KEEP (*(.tls$)) + KEEP (*(SORT(.tls$*))) + KEEP (*(.tls$ZZZ)) + ___tls_end__ = . ; + } + .endjunk BLOCK(__section_alignment__) : + { + /* end is deprecated, don't use it */ + PROVIDE (end = .); + PROVIDE ( _end = .); + __end__ = .; + } + .rsrc BLOCK(__section_alignment__) : SUBALIGN(4) + { + KEEP (*(.rsrc)) + KEEP (*(.rsrc$*)) + } + .reloc BLOCK(__section_alignment__) : + { + *(.reloc) + } + .stab BLOCK(__section_alignment__) (NOLOAD) : + { + *(.stab) + } + .stabstr BLOCK(__section_alignment__) (NOLOAD) : + { + *(.stabstr) + } + /* DWARF debug sections. + Symbols in the DWARF debugging sections are relative to the beginning + of the section. Unlike other targets that fake this by putting the + section VMA at 0, the PE format will not allow it. */ + /* DWARF 1.1 and DWARF 2. */ + .debug_aranges BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_aranges) + } + .zdebug_aranges BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_aranges) + } + .debug_pubnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_pubnames) + } + .zdebug_pubnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_pubnames) + } + /* DWARF 2. */ + .debug_info BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_info .gnu.linkonce.wi.*) + } + .zdebug_info BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_info .zdebug.gnu.linkonce.wi.*) + } + .debug_abbrev BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_abbrev) + } + .zdebug_abbrev BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_abbrev) + } + .debug_line BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_line) + } + .zdebug_line BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_line) + } + .debug_frame BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_frame*) + } + .zdebug_frame BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_frame*) + } + .debug_str BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_str) + } + .zdebug_str BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_str) + } + .debug_loc BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_loc) + } + .zdebug_loc BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_loc) + } + .debug_macinfo BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_macinfo) + } + .zdebug_macinfo BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_macinfo) + } + /* SGI/MIPS DWARF 2 extensions. */ + .debug_weaknames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_weaknames) + } + .zdebug_weaknames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_weaknames) + } + .debug_funcnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_funcnames) + } + .zdebug_funcnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_funcnames) + } + .debug_typenames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_typenames) + } + .zdebug_typenames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_typenames) + } + .debug_varnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_varnames) + } + .zdebug_varnames BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_varnames) + } + /* DWARF 3. */ + .debug_pubtypes BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_pubtypes) + } + .zdebug_pubtypes BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_pubtypes) + } + .debug_ranges BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_ranges) + } + .zdebug_ranges BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_ranges) + } + /* DWARF 4. */ + .debug_types BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_types .gnu.linkonce.wt.*) + } + .zdebug_types BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_types .gnu.linkonce.wt.*) + } + /* DWARF 5. */ + .debug_addr BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_addr) + } + .zdebug_addr BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_addr) + } + .debug_line_str BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_line_str) + } + .zdebug_line_str BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_line_str) + } + .debug_loclists BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_loclists) + } + .zdebug_loclists BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_loclists) + } + .debug_macro BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_macro) + } + .zdebug_macro BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_macro) + } + .debug_names BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_names) + } + .zdebug_names BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_names) + } + .debug_rnglists BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_rnglists) + } + .zdebug_rnglists BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_rnglists) + } + .debug_str_offsets BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_str_offsets) + } + .zdebug_str_offsets BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_str_offsets) + } + .debug_sup BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_sup) + } + /* For Go and Rust. */ + .debug_gdb_scripts BLOCK(__section_alignment__) (NOLOAD) : + { + *(.debug_gdb_scripts) + } + .zdebug_gdb_scripts BLOCK(__section_alignment__) (NOLOAD) : + { + *(.zdebug_gdb_scripts) + } +}
-Wl,--whole-archive \ $(u-boot-main) \ $(u-boot-keep-syms-lto) \$(add_ld_script) $(u-boot-init) \
--whole-archive \ $(u-boot-main) \ --no-whole-archive \$(add_ld_script) $(u-boot-init) \
- U-Boot note: This was obtained by using the -verbose linker option. The
- U-Boot additions are marked below.
- Ideally we would add sections to the executable, as is done with the Linux
- build. But PE executables do not appear to work correctly if unexpected
- sections are present:
- $ /tmp/b/sandbox/u-boot.exe
- -bash: /tmp/b/sandbox/u-boot.exe: cannot execute binary file: Exec format error
- So we take a approach of rewriting the whole file, for now. This will likely
- break in the future when a toolchain change is made.
Why not rather provide "layer" linker script which does this "rewriting" on top of the default linker script? With this way it is not needed to update linker script when a toolchain change it.
- Copying and distribution of this script, with or without modification,
- are permitted in any medium without royalty provided the copyright
- notice and this notice are preserved. */
- /* Make the virtual address and file offset synced if the alignment is
- . = SIZEOF_HEADERS;
- . = ALIGN(__section_alignment__);
- .text __image_base__ + ( __section_alignment__ < 0x1000 ? . : __section_alignment__ ) :
- KEEP (*(SORT_NONE(.init)))
- *(.text)
- *(SORT(.text$*))
*(.text.*)
- *(.glue_7t)
- *(.glue_7)
- . = ALIGN(8);
___CTOR_LIST__ = .;
__CTOR_LIST__ = .;
KEEP (*(.ctors));
KEEP (*(.ctor));
LONG (0); LONG (0);
___DTOR_LIST__ = .;
__DTOR_LIST__ = .;
KEEP (*(.dtors));
KEEP (*(.dtor));
LONG (0); LONG (0);
- KEEP (*(SORT_NONE(.fini)))
- /* ??? Why is .gcc_exc here? */
*(.gcc_exc)
- PROVIDE (etext = .);
- /* The Cygwin32 library uses a section to avoid copying certain data
- .data BLOCK(__section_alignment__) :
- __data_start__ = . ;
- *(.data)
- *(.data2)
- *(SORT(.data$*))
- KEEP(*(.jcr))
- __data_end__ = . ;
- *(.data_cygwin_nocopy)
- .rdata BLOCK(__section_alignment__) :
- *(.rdata)
*(SORT(.rdata$*))
- . = ALIGN(4);
- __rt_psrelocs_start = .;
- KEEP(*(.rdata_runtime_pseudo_reloc))
- __rt_psrelocs_end = .;
- /* U-Boot additions from here on */
- . = ALIGN(4);
- KEEP(*(SORT(__u_boot_list*)));
- *(_u_boot_sandbox_getopt_start)
- *(_u_boot_sandbox_getopt)
- *(_u_boot_sandbox_getopt_end)
- *(___efi_runtime_start)
- *(efi_runtime_text)
- *(efi_runtime_data)
- *(___efi_runtime_stop)
- *(___efi_runtime_rel_start)
- *(.relefi_runtime_text)
- *(.relefi_runtime_data)
- *(___efi_runtime_rel_stop)
- . = ALIGN(4);
- *(.rodata.ttf.init)
- *(.rodata.splash.init)
- *(.rodata.helloworld.init)
- *(.dtb.init.rodata)
- /* U-Boot additions end */
- __rt_psrelocs_size = __rt_psrelocs_end - __rt_psrelocs_start;
- ___RUNTIME_PSEUDO_RELOC_LIST_END__ = .;
- __RUNTIME_PSEUDO_RELOC_LIST_END__ = .;
- ___RUNTIME_PSEUDO_RELOC_LIST__ = . - __rt_psrelocs_size;
- __RUNTIME_PSEUDO_RELOC_LIST__ = . - __rt_psrelocs_size;
- .eh_frame BLOCK(__section_alignment__) :
- KEEP (*(.eh_frame*))
- .pdata BLOCK(__section_alignment__) :
- KEEP(*(.pdata*))
- .xdata BLOCK(__section_alignment__) :
- KEEP(*(.xdata*))
- .bss BLOCK(__section_alignment__) :
- __bss_start__ = . ;
- *(.bss)
- *(COMMON)
- __bss_end__ = . ;
- .edata BLOCK(__section_alignment__) :
- *(.edata)
- /DISCARD/ :
- *(.debug$S)
- *(.debug$T)
- *(.debug$F)
*(.drectve)
*(.note.GNU-stack)
*(.gnu.lto_*)
- .idata BLOCK(__section_alignment__) :
- /* This cannot currently be handled with grouped sections.
- See pep.em:sort_sections. */
- KEEP (SORT(*)(.idata$2))
- KEEP (SORT(*)(.idata$3))
- /* These zeroes mark the end of the import list. */
- LONG (0); LONG (0); LONG (0); LONG (0); LONG (0);
- . = ALIGN(8);
- KEEP (SORT(*)(.idata$4))
- __IAT_start__ = .;
- SORT(*)(.idata$5)
- __IAT_end__ = .;
- KEEP (SORT(*)(.idata$6))
- KEEP (SORT(*)(.idata$7))
- .CRT BLOCK(__section_alignment__) :
- ___crt_xc_start__ = . ;
- KEEP (*(SORT(.CRT$XC*))) /* C initialization */
- ___crt_xc_end__ = . ;
- ___crt_xi_start__ = . ;
- KEEP (*(SORT(.CRT$XI*))) /* C++ initialization */
- ___crt_xi_end__ = . ;
- ___crt_xl_start__ = . ;
- KEEP (*(SORT(.CRT$XL*))) /* TLS callbacks */
- /* ___crt_xl_end__ is defined in the TLS Directory support code */
- ___crt_xp_start__ = . ;
- KEEP (*(SORT(.CRT$XP*))) /* Pre-termination */
- ___crt_xp_end__ = . ;
- ___crt_xt_start__ = . ;
- KEEP (*(SORT(.CRT$XT*))) /* Termination */
- ___crt_xt_end__ = . ;
- /* Windows TLS expects .tls$AAA to be at the start and .tls$ZZZ to be
data. */
- .tls BLOCK(__section_alignment__) :
- ___tls_start__ = . ;
- KEEP (*(.tls$AAA))
- KEEP (*(.tls))
- KEEP (*(.tls$))
- KEEP (*(SORT(.tls$*)))
- KEEP (*(.tls$ZZZ))
- ___tls_end__ = . ;
- .endjunk BLOCK(__section_alignment__) :
- /* end is deprecated, don't use it */
- PROVIDE (end = .);
- PROVIDE ( _end = .);
__end__ = .;
- .rsrc BLOCK(__section_alignment__) : SUBALIGN(4)
- KEEP (*(.rsrc))
- KEEP (*(.rsrc$*))
- .reloc BLOCK(__section_alignment__) :
- *(.reloc)
- .stab BLOCK(__section_alignment__) (NOLOAD) :
- *(.stab)
- .stabstr BLOCK(__section_alignment__) (NOLOAD) :
- *(.stabstr)
- /* DWARF debug sections.
- /* DWARF 1.1 and DWARF 2. */
- .debug_aranges BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_aranges)
- .zdebug_aranges BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_aranges)
- .debug_pubnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_pubnames)
- .zdebug_pubnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_pubnames)
- /* DWARF 2. */
- .debug_info BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_info .gnu.linkonce.wi.*)
- .zdebug_info BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_info .zdebug.gnu.linkonce.wi.*)
- .debug_abbrev BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_abbrev)
- .zdebug_abbrev BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_abbrev)
- .debug_line BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_line)
- .zdebug_line BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_line)
- .debug_frame BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_frame*)
- .zdebug_frame BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_frame*)
- .debug_str BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_str)
- .zdebug_str BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_str)
- .debug_loc BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_loc)
- .zdebug_loc BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_loc)
- .debug_macinfo BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_macinfo)
- .zdebug_macinfo BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_macinfo)
- /* SGI/MIPS DWARF 2 extensions. */
- .debug_weaknames BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_weaknames)
- .zdebug_weaknames BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_weaknames)
- .debug_funcnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_funcnames)
- .zdebug_funcnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_funcnames)
- .debug_typenames BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_typenames)
- .zdebug_typenames BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_typenames)
- .debug_varnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_varnames)
- .zdebug_varnames BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_varnames)
- /* DWARF 3. */
- .debug_pubtypes BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_pubtypes)
- .zdebug_pubtypes BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_pubtypes)
- .debug_ranges BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_ranges)
- .zdebug_ranges BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_ranges)
- /* DWARF 4. */
- .debug_types BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_types .gnu.linkonce.wt.*)
- .zdebug_types BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_types .gnu.linkonce.wt.*)
- /* DWARF 5. */
- .debug_addr BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_addr)
- .zdebug_addr BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_addr)
- .debug_line_str BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_line_str)
- .zdebug_line_str BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_line_str)
- .debug_loclists BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_loclists)
- .zdebug_loclists BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_loclists)
- .debug_macro BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_macro)
- .zdebug_macro BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_macro)
- .debug_names BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_names)
- .zdebug_names BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_names)
- .debug_rnglists BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_rnglists)
- .zdebug_rnglists BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_rnglists)
- .debug_str_offsets BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_str_offsets)
- .zdebug_str_offsets BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_str_offsets)
- .debug_sup BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_sup)
- /* For Go and Rust. */
- .debug_gdb_scripts BLOCK(__section_alignment__) (NOLOAD) :
- *(.debug_gdb_scripts)
- .zdebug_gdb_scripts BLOCK(__section_alignment__) (NOLOAD) :
- *(.zdebug_gdb_scripts)
Hi Pali,
How can we reliably do that, though? We don't really know the format of the script and where to insert stuff.
On Tuesday 25 April 2023 12:01:04 Simon Glass wrote:
Hi Pali,
Well, I do not know what is the current issue. The proposed script in your patch looks like it is copied from some binutils version and then modified. Also I do not know from which binutils you have copied and what modification you have done in it. So I cannot react or comment anymore more here.
My idea is that to write those modifications into new layer script.
Hi Pali,
Hi Pali,
See the comment at the top of the script:
Yes, exactly.
But I have marked this clearly in the script. See /* U-Boot additions from here on */
So I think you are suggesting that I get binutils to emit the default script, then have a script which detects the end of the .rdata section and emits its own stuff in there? That may be more robust, since it is unlikely that the .rdata section will be removed.
But I was rather hoping that someone could help with the core problem, i.e. why I cannot just insert another section into the image, like we do with ELF?
On Tuesday 25 April 2023 13:23:04 Simon Glass wrote:
Hi Pali,
Hi Pali,
Exec format error
Yes, exactly.
I read this, but I have not found from which binutils you took it... There are many released binutils versions and also each binutils version has more PE linker scripts. So it is really hard to track from which it comes. -verbose argument show you the final linker script but we need to know also from which files it was composed...
Yes, exactly. And you do not need to take and copy default script from binutils to u-boot sources. If you write "layer" linker script (I hope that this is how it is called in LD documentation), then LD automatically uses its own default script and apply your "layer" script on it. So with this way you can completely avoid copy+paste files from binutils to u-boot repository.
That is interesting. Theoretically it should work but I have not seen it widely used outside of NT kernel modules. So maybe there is some bug in Windows loader for userspace binaries, or another bug in GNU LD, or just a bug in u-boot / linker script.
Could you show linker script which is causing generation of that buggy non-working binary? And ideally can you provide also that buggy EXE binary? I could try to inspect it, but I do not have time to setup MSYS2 environment to compile my own buggy EXE binary.
Hi Pali,
Hi Pali,
Hi Pali,
Exec format error
Yes, exactly.
$ ld -V GNU ld (GNU Binutils) 2.40 Supported emulations: i386pep i386pe
sglass@DESKTOP-OHNGJ4K MINGW64 ~/u-boot $ cc -v Using built-in specs. COLLECT_GCC=cc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-msys/11.3.0/lto-wrapper.exe Target: x86_64-pc-msys Configured with: /c/S/gcc/src/gcc-11.3.0/configure --build=x86_64-pc-msys --prefix=/usr --libexecdir=/usr/lib --enable-bootstrap --enable-shared --enable-shared-libgcc --enable-static --enable-version-specific-runtime-libs --with-arch=x86-64 --with-tune=generic --disable-multilib --enable-__cxa_atexit --with-dwarf2 --enable-languages=c,c++,fortran,lto --enable-graphite --enable-threads=posix --enable-libatomic --enable-libgomp --disable-libitm --enable-libquadmath --enable-libquadmath-support --disable-libssp --disable-win32-registry --disable-symvers --with-gnu-ld --with-gnu-as --disable-isl-version-check --enable-checking=release --without-libiconv-prefix --without-libintl-prefix --with-system-zlib --enable-linker-build-id --with-default-libstdcxx-abi=gcc4-compatible --enable-libstdcxx-filesystem-ts Thread model: posix Supported LTO compression algorithms: zlib
That is considerably more complicated, though.
Please see [1] for the file.
sglass@DESKTOP-OHNGJ4K MINGW64 ~/u-boot $ objdump.exe -h /tmp/b/sandbox/u-boot.exe
/tmp/b/sandbox/u-boot.exe: file format pei-x86-64
Sections: Idx Name Size VMA LMA File off Algn 0 .text 00208b98 0000000100401000 0000000100401000 00000600 2**4 CONTENTS, ALLOC, LOAD, READONLY, CODE, DATA 1 __u_boot_list 00014960 0000000100609ba0 0000000100609ba0 00209200 2**2 CONTENTS, ALLOC, LOAD, DATA 2 _u_boot_sandbox_getopt 000000c0 000000010061e500 000000010061e500 0021dc00 2**2 CONTENTS, ALLOC, LOAD, DATA 3 .data 00019a20 000000010061f000 000000010061f000 0021de00 2**4 CONTENTS, ALLOC, LOAD, DATA 4 .rodata.ttf.init 00036e10 0000000100639000 0000000100639000 00237a00 2**2 CONTENTS, ALLOC, LOAD, DATA 5 .rodata.splash.init 00001b20 0000000100670000 0000000100670000 0026ea00 2**2 CONTENTS, ALLOC, LOAD, DATA 6 .rodata.helloworld.init 00003030 0000000100672000 0000000100672000 00270600 2**2 CONTENTS, ALLOC, LOAD, DATA 7 .data.efi_runtime 00000170 0000000100676000 0000000100676000 00273800 2**4 CONTENTS, ALLOC, LOAD, DATA 8 .dtb.init.rodata 000007c0 0000000100677000 0000000100677000 00273a00 2**2 CONTENTS, ALLOC, LOAD, DATA 9 .rdata 000a3fe0 0000000100678000 0000000100678000 00274200 2**4 CONTENTS, ALLOC, LOAD, READONLY, DATA 10 .buildid 00000035 000000010071c000 000000010071c000 00318200 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 11 .rodata.efi_runtime 00000400 000000010071d000 000000010071d000 00318400 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 12 .pdata 0001785c 000000010071e000 000000010071e000 00318800 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 13 .xdata 00016f58 0000000100736000 0000000100736000 00330200 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 14 .bss 0001ecc0 000000010074d000 000000010074d000 00000000 2**4 ALLOC 15 .idata 00000894 000000010076c000 000000010076c000 00347200 2**2 CONTENTS, ALLOC, LOAD, DATA 16 .rsrc 000004e8 000000010076d000 000000010076d000 00347c00 2**2 CONTENTS, ALLOC, LOAD, DATA 17 .reloc 00005284 000000010076e000 000000010076e000 00348200 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 18 .debug_aranges 0000b720 0000000100774000 0000000100774000 0034d600 2**0 CONTENTS, READONLY, DEBUGGING 19 .debug_info 00a6c954 0000000100780000 0000000100780000 00358e00 2**0 CONTENTS, READONLY, DEBUGGING 20 .debug_abbrev 000cb6b2 00000001011ed000 00000001011ed000 00dc5800 2**0 CONTENTS, READONLY, DEBUGGING 21 .debug_line 001f646a 00000001012b9000 00000001012b9000 00e91000 2**0 CONTENTS, READONLY, DEBUGGING 22 .debug_frame 000a9bd0 00000001014b0000 00000001014b0000 01087600 2**0 CONTENTS, READONLY, DEBUGGING 23 .debug_str 0001d6c1 000000010155a000 000000010155a000 01131200 2**0 CONTENTS, READONLY, DEBUGGING 24 .debug_loc 004673a1 0000000101578000 0000000101578000 0114ea00 2**0 CONTENTS, READONLY, DEBUGGING 25 .debug_ranges 00060260 00000001019e0000 00000001019e0000 015b5e00 2**0 CONTENTS, READONLY, DEBUGGING 26 .debug_line_str 00000264 0000000101a41000 0000000101a41000 01616200 2**0 CONTENTS, READONLY, DEBUGGING
sglass@DESKTOP-OHNGJ4K MINGW64 ~/u-boot $ !$ /tmp/b/sandbox/u-boot.exe -bash: /tmp/b/sandbox/u-boot.exe: cannot execute binary file: Exec format error
[1] https://drive.google.com/file/d/1vtJlvCd1BxkhRtQtUe4YqiRizcUP_zB2/view?usp=s...
On Tuesday 25 April 2023 18:50:59 Simon Glass wrote:
Hi Pali,
Hi Pali,
Hi Pali,
On Monday 24 April 2023 17:08:15 Simon Glass wrote: > Add a script to allow the U-Boot sandbox executable to be built for > Windows. Add a note as to why this seems to be necessary for now. > > Signed-off-by: Simon Glass sjg@chromium.org > --- > > Makefile | 11 +- > arch/sandbox/config.mk | 4 + > arch/sandbox/cpu/u-boot-pe.lds | 447 +++++++++++++++++++++++++++++++++ > 3 files changed, 460 insertions(+), 2 deletions(-) > create mode 100644 arch/sandbox/cpu/u-boot-pe.lds > > diff --git a/Makefile b/Makefile > index dd3fcd1782e5..0aa97a2c3b48 100644 > --- a/Makefile > +++ b/Makefile > @@ -1730,6 +1730,13 @@ else > u-boot-keep-syms-lto := > endif > > +ifeq ($(MSYS_VERSION),0) > +add_ld_script := -T u-boot.lds > +else > +add_ld_script := u-boot.lds > +$(warning msys) > +endif > + > # Rule to link u-boot > # May be overridden by arch/$(ARCH)/config.mk > ifeq ($(LTO_ENABLE),y) > @@ -1738,7 +1745,7 @@ quiet_cmd_u-boot__ ?= LTO $@ > $(CC) -nostdlib -nostartfiles \ > $(LTO_FINAL_LDFLAGS) $(c_flags) \ > $(KBUILD_LDFLAGS:%=-Wl,%) $(LDFLAGS_u-boot:%=-Wl,%) -o $@ \ > - -T u-boot.lds $(u-boot-init) \ > + $(add_ld_script) $(u-boot-init) \ > -Wl,--whole-archive \ > $(u-boot-main) \ > $(u-boot-keep-syms-lto) \ > @@ -1749,7 +1756,7 @@ quiet_cmd_u-boot__ ?= LTO $@ > else > quiet_cmd_u-boot__ ?= LD $@ > cmd_u-boot__ ?= $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ > - -T u-boot.lds $(u-boot-init) \ > + $(add_ld_script) $(u-boot-init) \ > --whole-archive \ > $(u-boot-main) \ > --no-whole-archive \ > diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk > index 2d184c5f652a..e05daf57ef8e 100644 > --- a/arch/sandbox/config.mk > +++ b/arch/sandbox/config.mk > @@ -71,3 +71,7 @@ EFI_CRT0 := crt0_sandbox_efi.o > EFI_RELOC := reloc_sandbox_efi.o > AFLAGS_crt0_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" > CFLAGS_reloc_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" > + > +ifneq ($(MSYS_VERSION),0) > +LDSCRIPT = $(srctree)/arch/sandbox/cpu/u-boot-pe.lds > +endif > diff --git a/arch/sandbox/cpu/u-boot-pe.lds b/arch/sandbox/cpu/u-boot-pe.lds > new file mode 100644 > index 000000000000..031e70fafd03 > --- /dev/null > +++ b/arch/sandbox/cpu/u-boot-pe.lds > @@ -0,0 +1,447 @@ > +/* SPDX-License-Identifier: GPL-2.0+ */ > +/* > + * U-Boot note: This was obtained by using the -verbose linker option. The > + * U-Boot additions are marked below. > + * > + * Ideally we would add sections to the executable, as is done with the Linux > + * build. But PE executables do not appear to work correctly if unexpected > + * sections are present: > + * > + * $ /tmp/b/sandbox/u-boot.exe > + * -bash: /tmp/b/sandbox/u-boot.exe: cannot execute binary file: Exec format error > + * > + * So we take a approach of rewriting the whole file, for now. This will likely > + * break in the future when a toolchain change is made.
Exec format error
Yes, exactly.
I have run readpe parser on this binary and parser crashed! Have not seen such thing it. So I suspect that this binary is broken. I will look at it deeply later. Another thing which I see suspicious in above output are section names. They are too long and cannot fit into PE format which has (small) limit on section names. Not sure if this can be an issue...
Hi Pali,
Hi Pali,
Hi Pali,
On Tue, 25 Apr 2023 at 10:21, Pali Rohár pali@kernel.org wrote: > > On Monday 24 April 2023 17:08:15 Simon Glass wrote: > > Add a script to allow the U-Boot sandbox executable to be built for > > Windows. Add a note as to why this seems to be necessary for now. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > --- > > > > Makefile | 11 +- > > arch/sandbox/config.mk | 4 + > > arch/sandbox/cpu/u-boot-pe.lds | 447 +++++++++++++++++++++++++++++++++ > > 3 files changed, 460 insertions(+), 2 deletions(-) > > create mode 100644 arch/sandbox/cpu/u-boot-pe.lds > > > > diff --git a/Makefile b/Makefile > > index dd3fcd1782e5..0aa97a2c3b48 100644 > > --- a/Makefile > > +++ b/Makefile > > @@ -1730,6 +1730,13 @@ else > > u-boot-keep-syms-lto := > > endif > > > > +ifeq ($(MSYS_VERSION),0) > > +add_ld_script := -T u-boot.lds > > +else > > +add_ld_script := u-boot.lds > > +$(warning msys) > > +endif > > + > > # Rule to link u-boot > > # May be overridden by arch/$(ARCH)/config.mk > > ifeq ($(LTO_ENABLE),y) > > @@ -1738,7 +1745,7 @@ quiet_cmd_u-boot__ ?= LTO $@ > > $(CC) -nostdlib -nostartfiles \ > > $(LTO_FINAL_LDFLAGS) $(c_flags) \ > > $(KBUILD_LDFLAGS:%=-Wl,%) $(LDFLAGS_u-boot:%=-Wl,%) -o $@ \ > > - -T u-boot.lds $(u-boot-init) \ > > + $(add_ld_script) $(u-boot-init) \ > > -Wl,--whole-archive \ > > $(u-boot-main) \ > > $(u-boot-keep-syms-lto) \ > > @@ -1749,7 +1756,7 @@ quiet_cmd_u-boot__ ?= LTO $@ > > else > > quiet_cmd_u-boot__ ?= LD $@ > > cmd_u-boot__ ?= $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ > > - -T u-boot.lds $(u-boot-init) \ > > + $(add_ld_script) $(u-boot-init) \ > > --whole-archive \ > > $(u-boot-main) \ > > --no-whole-archive \ > > diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk > > index 2d184c5f652a..e05daf57ef8e 100644 > > --- a/arch/sandbox/config.mk > > +++ b/arch/sandbox/config.mk > > @@ -71,3 +71,7 @@ EFI_CRT0 := crt0_sandbox_efi.o > > EFI_RELOC := reloc_sandbox_efi.o > > AFLAGS_crt0_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" > > CFLAGS_reloc_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" > > + > > +ifneq ($(MSYS_VERSION),0) > > +LDSCRIPT = $(srctree)/arch/sandbox/cpu/u-boot-pe.lds > > +endif > > diff --git a/arch/sandbox/cpu/u-boot-pe.lds b/arch/sandbox/cpu/u-boot-pe.lds > > new file mode 100644 > > index 000000000000..031e70fafd03 > > --- /dev/null > > +++ b/arch/sandbox/cpu/u-boot-pe.lds > > @@ -0,0 +1,447 @@ > > +/* SPDX-License-Identifier: GPL-2.0+ */ > > +/* > > + * U-Boot note: This was obtained by using the -verbose linker option. The > > + * U-Boot additions are marked below. > > + * > > + * Ideally we would add sections to the executable, as is done with the Linux > > + * build. But PE executables do not appear to work correctly if unexpected > > + * sections are present: > > + * > > + * $ /tmp/b/sandbox/u-boot.exe > > + * -bash: /tmp/b/sandbox/u-boot.exe: cannot execute binary file: Exec format error > > + * > > + * So we take a approach of rewriting the whole file, for now. This will likely > > + * break in the future when a toolchain change is made. > > Why not rather provide "layer" linker script which does this "rewriting" > on top of the default linker script? With this way it is not needed to > update linker script when a toolchain change it. >
Exec format error
Yes, exactly.
Ok, this binary is really broken / corrupted. objdump -p also show lot of errors "xdata section corrupt". Maybe this is just an another bug in LD? I have found them a lot and some of them I reported to their bugzilla. If you are trying to produce PE binaries it would be better to switch to MS tools they always had better quality for production software. GNU tools are here good just for playing or research.
Add another case for sandbox, when it is built on Windows.
arch/sandbox/config.mk | 4 +- arch/x86/lib/crt0_x86_64_efi.S | 2 + arch/x86/lib/pe_x86_64_efi.lds | 83 ++++++++++++++++++++++++++++++++++ 3 files changed, 88 insertions(+), 1 deletion(-) create mode 100644 arch/x86/lib/pe_x86_64_efi.lds
diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index e05daf57ef8e..3269e6f3d2ce 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -44,7 +44,9 @@ cmd_u-boot-spl = (cd $(obj) && $(CC) -o $(SPL_BIN) -Wl,-T u-boot-spl.lds \ -Wl,--no-whole-archive \ $(PLATFORM_LIBS) -Wl,-Map -Wl,u-boot-spl.map -Wl,--gc-sections)
-ifeq ($(HOST_ARCH),$(HOST_ARCH_X86_64)) +ifneq ($(MSYS_VERSION),0) +EFI_LDS := ${SRCDIR}/../../../arch/x86/lib/pe_x86_64_efi.lds +else ifeq ($(HOST_ARCH),$(HOST_ARCH_X86_64)) EFI_LDS := ${SRCDIR}/../../../arch/x86/lib/elf_x86_64_efi.lds EFI_TARGET := --target=efi-app-x86_64 else ifeq ($(HOST_ARCH),$(HOST_ARCH_X86)) diff --git a/arch/x86/lib/crt0_x86_64_efi.S b/arch/x86/lib/crt0_x86_64_efi.S index 47ed5af97228..cd61b4bdd82f 100644 --- a/arch/x86/lib/crt0_x86_64_efi.S +++ b/arch/x86/lib/crt0_x86_64_efi.S @@ -15,6 +15,7 @@ _start: subq $8, %rsp
+#ifndef __CYGWIN__ pushq %rcx pushq %rdx
@@ -28,6 +29,7 @@ _start:
testq %rax, %rax jnz .exit +#endif
call efi_main .exit: diff --git a/arch/x86/lib/pe_x86_64_efi.lds b/arch/x86/lib/pe_x86_64_efi.lds new file mode 100644 index 000000000000..1ee08f6e662e --- /dev/null +++ b/arch/x86/lib/pe_x86_64_efi.lds @@ -0,0 +1,83 @@ +/* SPDX-License-Identifier: BSD-2-Clause */ +/* + * U-Boot EFI linker script + * + * Modified from usr/lib32/elf_x86_64_efi.lds in gnu-efi + */ + +OUTPUT_FORMAT("pe-x86-64", "pe-x86-64", "pe-x86-64") +OUTPUT_ARCH(i386:x86-64) +ENTRY(_start) +SECTIONS +{ + image_base = .; + .hash : { *(.hash) } /* this MUST come first, EFI expects it */ + . = ALIGN(4096); + .eh_frame : { + *(.eh_frame) + } + + . = ALIGN(4096); + + .text : { + *(.text) + *(.text.*) + *(.gnu.linkonce.t.*) + } + + . = ALIGN(4096); + + .reloc : { + *(.reloc) + } + + . = ALIGN(4096); + + .data : { + *(.rodata*) + *(.got.plt) + *(.got) + *(.data*) + *(.sdata) + /* the EFI loader doesn't seem to like a .bss section, so we stick + * it all into .data: */ + *(.sbss) + *(.scommon) + *(.dynbss) + *(.bss*) + *(COMMON) + *(.rel.local) + + /* U-Boot lists and device tree */ + . = ALIGN(8); + *(SORT(__u_boot_list*)); + . = ALIGN(8); + *(.dtb*); + } + + . = ALIGN(4096); + .dynamic : { *(.dynamic) } + . = ALIGN(4096); + + .rela : { + *(.rela.data*) + *(.rela.got) + *(.rela.stab) + *(.rela__u_boot_list*) + } + + . = ALIGN(4096); + .dynsym : { *(.dynsym) } + . = ALIGN(4096); + .dynstr : { *(.dynstr) } + . = ALIGN(4096); + + /DISCARD/ : { *(.eh_frame) } + + .ignored.reloc : { + *(.rela.reloc) + *(.note.GNU-stack) + } + + .comment 0 : { *(.comment) } +}
This is not used, since the same code appears in cpu/Makefile
Drop it.
arch/sandbox/Makefile | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/arch/sandbox/Makefile b/arch/sandbox/Makefile index a335f8acfde6..f6cf859f249c 100644 --- a/arch/sandbox/Makefile +++ b/arch/sandbox/Makefile @@ -4,10 +4,3 @@ head-y := arch/sandbox/cpu/start.o arch/sandbox/cpu/os.o head-$(CONFIG_SANDBOX_SDL) += arch/sandbox/cpu/sdl.o libs-y += arch/sandbox/cpu/ libs-y += arch/sandbox/lib/ - -# sdl.c fails to compile with -fshort-wchar using musl. -cmd_cc_sdl.o = $(CC) $(filter-out -nostdinc -fshort-wchar, \ - $(patsubst -I%,-idirafter%,$(c_flags))) -fno-lto -c -o $@ $< - -$(obj)/sdl.o: $(src)/sdl.c FORCE - $(call if_changed_dep,cc_sdl.o)
This relies on Linux features so cannot be built for Windows. Drop it.
arch/sandbox/cpu/Makefile | 2 ++ drivers/net/Makefile | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/sandbox/cpu/Makefile b/arch/sandbox/cpu/Makefile index 7c5c52652f5c..be6b57692dd5 100644 --- a/arch/sandbox/cpu/Makefile +++ b/arch/sandbox/cpu/Makefile @@ -9,7 +9,9 @@ obj-y := cache.o cpu.o state.o extra-y := start.o os.o extra-$(CONFIG_SANDBOX_SDL) += sdl.o obj-$(CONFIG_SPL_BUILD) += spl.o +ifeq ($(MSYS_VERSION),0) obj-$(CONFIG_ETH_SANDBOX_RAW) += eth-raw-os.o +endif
# os.c is build in the system environment, so needs standard includes # CFLAGS_REMOVE_os.o cannot be used to drop header include path diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 46a40e2ed9f8..6580f8d85510 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -30,8 +30,10 @@ obj-$(CONFIG_ETH_DESIGNWARE_MESON8B) += dwmac_meson8b.o obj-$(CONFIG_ETH_DESIGNWARE_S700) += dwmac_s700.o obj-$(CONFIG_ETH_DESIGNWARE_SOCFPGA) += dwmac_socfpga.o obj-$(CONFIG_ETH_SANDBOX) += sandbox.o +ifeq ($(MSYS_VERSION),0) obj-$(CONFIG_ETH_SANDBOX_RAW) += sandbox-raw-bus.o obj-$(CONFIG_ETH_SANDBOX_RAW) += sandbox-raw.o +endif obj-$(CONFIG_FEC_MXC) += fec_mxc.o obj-$(CONFIG_FMAN_ENET) += fm/ obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o
The Linux register format is not used in Windows, so disable this feature.
arch/sandbox/cpu/os.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 5e66304e2b9d..c8b83f923ddb 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -285,7 +285,7 @@ static void os_signal_handler(int sig, siginfo_t *info, void *con) ucontext_t __maybe_unused *context = con; unsigned long pc;
-#if defined(__x86_64__) +#if defined(__x86_64__) && defined(__linux) pc = context->uc_mcontext.gregs[REG_RIP]; #elif defined(__aarch64__) pc = context->uc_mcontext.pc;
Am 25. April 2023 01:08:19 MESZ schrieb Simon Glass sjg@chromium.org:
In the commit message you only mention Linux and Windows. How about BSD and other POSIX?
__aarch64__ does not imply Linux. There are Windows and other POSIX (BSD, macOS) systems running on ARM.
__riscv, armhf may also occur on different POSIX systems.
Best regards
Heinrich
We rely on sdl-config to provide the include directory for this header file, so should not add the include directory in the C file. Drop it so that this works as expected on Windows.
arch/sandbox/cpu/sdl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/sdl.c b/arch/sandbox/cpu/sdl.c index 2c570ed8d164..31d3e9c32dec 100644 --- a/arch/sandbox/cpu/sdl.c +++ b/arch/sandbox/cpu/sdl.c @@ -7,7 +7,7 @@ #include <unistd.h> #include <stdbool.h> #include <linux/input.h> -#include <SDL2/SDL.h> +#include <SDL.h> #include <asm/state.h>
Add this so that the header file can used without first including the errno.h header.
arch/sandbox/include/asm/test.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index e482271fe975..86968ea6d345 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -8,6 +8,7 @@ #ifndef __ASM_TEST_H #define __ASM_TEST_H
+#include <errno.h> #include <video.h> #include <pci_ids.h>
The sandbox build makes use of a small number of weak symbols. Allow these to be dropped when building for the PE format, since its support for weak symbols is poor.
cmd/bootefi.c | 3 ++- cmd/bootz.c | 3 +++ common/usb.c | 3 +++ drivers/core/root.c | 3 +++ drivers/spi/sandbox_spi.c | 3 +++ env/env.c | 6 ++++++ lib/efi_loader/efi_image_loader.c | 3 +++ lib/efi_loader/efi_runtime.c | 4 ++++ lib/lmb.c | 4 +++- lib/time.c | 3 +++ 10 files changed, 33 insertions(+), 2 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 8aa15a64c836..21e4a87da53a 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -358,7 +358,8 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) u16 *exit_data = NULL;
/* On ARM switch from EL3 or secure mode to EL2 or non-secure mode */ - switch_to_non_secure_mode(); + if (IS_ENABLED(CONFIG_WEAK_SYMBOLS)) + switch_to_non_secure_mode();
/* * The UEFI standard requires that the watchdog timer is set to five diff --git a/cmd/bootz.c b/cmd/bootz.c index f1423573d23d..1ffafbd6f2b9 100644 --- a/cmd/bootz.c +++ b/cmd/bootz.c @@ -13,6 +13,8 @@ #include <log.h> #include <linux/compiler.h>
+#ifdef CONFIG_WEAK_SYMBOLS + int __weak bootz_setup(ulong image, ulong *start, ulong *end) { /* Please define bootz_setup() for your platform */ @@ -20,6 +22,7 @@ int __weak bootz_setup(ulong image, ulong *start, ulong *end) puts("Your platform's zImage format isn't supported yet!\n"); return -1; } +#endif
/* * zImage booting support diff --git a/common/usb.c b/common/usb.c index ae9253dfc0ed..cff53254a379 100644 --- a/common/usb.c +++ b/common/usb.c @@ -1220,6 +1220,8 @@ int usb_new_device(struct usb_device *dev) } #endif
+#ifdef CONFIG_WEAK_SYMBOLS + __weak int board_usb_init(int index, enum usb_init_type init) { @@ -1231,6 +1233,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) { return 0; } +#endif /* CONFIG_WEAK_SYMBOLS */
bool usb_device_has_child_on_port(struct usb_device *parent, int port) { diff --git a/drivers/core/root.c b/drivers/core/root.c index c4fb48548bb3..e311f93a08c9 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -347,10 +347,13 @@ int dm_extended_scan(bool pre_reloc_only) } #endif
+#ifdef CONFIG_WEAK_SYMBOLS + __weak int dm_scan_other(bool pre_reloc_only) { return 0; } +#endif
#if CONFIG_IS_ENABLED(OF_PLATDATA_INST) && CONFIG_IS_ENABLED(READ_ONLY) void *dm_priv_to_rw(void *priv) diff --git a/drivers/spi/sandbox_spi.c b/drivers/spi/sandbox_spi.c index f844597d04cf..f68c9f33bdb4 100644 --- a/drivers/spi/sandbox_spi.c +++ b/drivers/spi/sandbox_spi.c @@ -41,12 +41,15 @@ struct sandbox_spi_priv { uint mode; };
+#ifdef CONFIG_WEAK_SYMBOLS + __weak int sandbox_spi_get_emul(struct sandbox_state *state, struct udevice *bus, struct udevice *slave, struct udevice **emulp) { return -ENOENT; } +#endif
uint sandbox_spi_get_speed(struct udevice *dev) { diff --git a/env/env.c b/env/env.c index ad774f41175b..bcc66b4a6a12 100644 --- a/env/env.c +++ b/env/env.c @@ -53,6 +53,8 @@ static struct env_driver *_env_driver_lookup(enum env_location loc) return NULL; }
+#ifdef CONFIG_WEAK_SYMBOLS + static enum env_location env_locations[] = { #ifdef CONFIG_ENV_IS_IN_EEPROM ENVL_EEPROM, @@ -88,6 +90,7 @@ static enum env_location env_locations[] = { ENVL_NOWHERE, #endif }; +#endif /* CONFIG_WEAK_SYMBOLS */
static bool env_has_inited(enum env_location location) { @@ -106,6 +109,8 @@ static void env_set_inited(enum env_location location) gd->env_has_init |= BIT(location); }
+#ifdef CONFIG_WEAK_SYMBOLS + /** * arch_env_get_location() - Returns the best env location for an arch * @op: operations performed on the environment @@ -155,6 +160,7 @@ __weak enum env_location env_get_location(enum env_operation op, int prio) { return arch_env_get_location(op, prio); } +#endif /* CONFIG_WEAK_SYMBOLS */
/** * env_driver_lookup() - Finds the most suited environment location diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 26df0da16c93..c473cd58cfb8 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -174,10 +174,13 @@ static efi_status_t efi_loader_relocate(const IMAGE_BASE_RELOCATION *rel, return EFI_SUCCESS; }
+#ifdef CONFIG_WEAK_SYMBOLS + void __weak invalidate_icache_all(void) { /* If the system doesn't support icache_all flush, cross our fingers */ } +#endif
/** * efi_set_code_and_data_type() - determine the memory types to be used for code diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index bf54d6ad871d..d7cf3b7e9dc8 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -375,6 +375,9 @@ out: return EFI_EXIT(EFI_UNSUPPORTED); #endif } + +#ifdef CONFIG_WEAK_SYMBOLS + /** * efi_reset_system() - reset system * @@ -399,6 +402,7 @@ void __weak __efi_runtime EFIAPI efi_reset_system( { return; } +#endif /* CONFIG_WEAK_SYMBOLS */
/** * efi_reset_system_init() - initialize the reset driver diff --git a/lib/lmb.c b/lib/lmb.c index b2c233edb64e..f46442aba48a 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -148,9 +148,11 @@ void arch_lmb_reserve_generic(struct lmb *lmb, ulong sp, ulong end, ulong align)
lmb_reserve(lmb, sp, bank_end - sp + 1);
+#ifdef CONFIG_WEAK_SYMBOLS + if (gd->flags & GD_FLG_SKIP_RELOC) lmb_reserve(lmb, (phys_addr_t)(uintptr_t)_start, gd->mon_len); - +#endif break; } } diff --git a/lib/time.c b/lib/time.c index 00f4a1ac8fb3..e8da2a3aa6a6 100644 --- a/lib/time.c +++ b/lib/time.c @@ -179,6 +179,8 @@ uint64_t usec_to_tick(unsigned long usec) return tick; }
+#ifdef CONFIG_WEAK_SYMBOLS + void __weak __udelay(unsigned long usec) { uint64_t tmp; @@ -188,6 +190,7 @@ void __weak __udelay(unsigned long usec) while (get_ticks() < tmp+1) /* loop till event */ /*NOP*/; } +#endif
Am 25. April 2023 01:08:22 MESZ schrieb Simon Glass sjg@chromium.org:
This comment does not explain the necessity of the change. Why is it really needed? Has the compiler version in MSYS a problem?
Best regards
Heinrich
- The UEFI standard requires that the watchdog timer is set to five
- zImage booting support
- arch_env_get_location() - Returns the best env location for an arch
- @op: operations performed on the environment
- env_driver_lookup() - Finds the most suited environment location
- efi_set_code_and_data_type() - determine the memory types to be used for code
- efi_reset_system() - reset system
- efi_reset_system_init() - initialize the reset driver
- if (gd->flags & GD_FLG_SKIP_RELOC) lmb_reserve(lmb, (phys_addr_t)(uintptr_t)_start, gd->mon_len);
Hi Heinrich,
Yes, from what I understand, PE has never really supported weak symbols properly. I'm not sure if that has changed, but it doesn't look like it.
I'm hoping there is another workaround.
That said, I really don't like weak symbols and I think we should use them less.
Hi Simon,
You probably need to use:
__declspec(selectany)
to replace __weak in the ELF for the *nix world.
Note this Microsoft bizarre does not provide the "strong override weak" effect but I suspect what you only need is to get the build pass on Windows so it should be okay.
Regards, Bin
On Tuesday 25 April 2023 10:44:17 Bin Meng wrote:
Hi Simon,
Regards, Bin
You have selectany and external weaks support in PE format. For the majority of weak function cases, this is enough. Cannot we use them?
Hi Pali,
Hi Simon,
Regards, Bin
Not that I can tell.
Can you provide a patch to linux/compiler_attributes.h which handles this?
On Saturday 29 April 2023 12:41:31 Simon Glass wrote:
Hi Pali,
Hi Simon,
Regards, Bin
I can after all my patches on the list are reviewed and merged.
No, I'm not going to _again_ spend time on another patch and then wait years after somebody take it.
Hi Bin,
On Mon, 24 Apr 2023 at 20:44, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
With that I get:
lib/sha1.c:226:1: error: ‘selectany’ attribute applies only to initialized variables with external linkage
and it dies.
The line is:
__weak void sha1_process(sha1_context *ctx, const unsigned char *data, unsigned int blocks)
I tried adding a prototype to the header but got the same error.
Hi Simon,
On Sun, Apr 30, 2023 at 2:41 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
With that I get:
and it dies.
The line is:
I will see if I can find some time to check this.
Regards, Bin
Use 'unsigned long' instead of 'ulong' so this file does not need to include the linux/types.h header file. This allows it to be built with MSYS2.
include/asm-generic/sections.h | 16 +++++++--------- 1 file changed, 7 insertions(+), 9 deletions(-)
diff --git a/include/asm-generic/sections.h b/include/asm-generic/sections.h index 267f1db73f23..4ed9a8478cc5 100644 --- a/include/asm-generic/sections.h +++ b/include/asm-generic/sections.h @@ -8,8 +8,6 @@ #ifndef _ASM_GENERIC_SECTIONS_H_ #define _ASM_GENERIC_SECTIONS_H_
-#include <linux/types.h> - /* References to section boundaries */
extern char _text[], _stext[], _etext[]; @@ -71,7 +69,7 @@ extern char __image_copy_end[]; extern void _start(void);
/* - * ARM defines its symbols as char[]. Other arches define them as ulongs. + * ARM defines its symbols as char[]. Other archs define them as unsigned long */ #ifdef CONFIG_ARM
@@ -86,13 +84,13 @@ extern char __rel_dyn_end[]; #else /* don't use offsets: */
/* Exports from the Linker Script */ -extern ulong __data_end; -extern ulong __rel_dyn_start; -extern ulong __rel_dyn_end; -extern ulong __bss_end; -extern ulong _image_binary_end; +extern unsigned long __data_end; +extern unsigned long __rel_dyn_start; +extern unsigned long __rel_dyn_end; +extern unsigned long __bss_end; +extern unsigned long _image_binary_end;
-extern ulong _TEXT_BASE; /* code start */ +extern unsigned long _TEXT_BASE; /* code start */
#endif
This header file should only be included in U-Boot standalone files, not those built in the Linux environment. When not building for Linux, the header file does not exist, except in the U-Boot tree. In any case, it should not be used.
arch/sandbox/cpu/os.c | 1 - include/os.h | 2 -- 2 files changed, 3 deletions(-)
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index c8b83f923ddb..38689bff1695 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -26,7 +26,6 @@ #include <sys/time.h> #include <sys/types.h> #include <linux/compiler_attributes.h> -#include <linux/types.h>
#include <asm/fuzzing_engine.h> #include <asm/getopt.h> diff --git a/include/os.h b/include/os.h index 0415f0f0e7a1..43e79fa9330e 100644 --- a/include/os.h +++ b/include/os.h @@ -11,8 +11,6 @@ #ifndef __OS_H__ #define __OS_H__
-#include <linux/types.h> - struct rtc_time; struct sandbox_state;
There is no need for this file and it should not be included unless sandbox is being used. Drop it.
lib/sscanf.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/lib/sscanf.c b/lib/sscanf.c index 4c35c035fe10..b79f6d79255c 100644 --- a/lib/sscanf.c +++ b/lib/sscanf.c @@ -17,7 +17,6 @@
#if !defined HAVE_LIBC
-#include <os.h> #include <linux/kernel.h> #include <linux/ctype.h> #include <vsprintf.h>
This works correctly on Linux with ELF but not on Windows with PE, since it creates assembly symbols with invalid names.
Use the lowest/highest valid characters instead. This should still work correctly, since we have no tests starting with $ and none starting with 'z' at present.
include/test/test.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/test/test.h b/include/test/test.h index 838e3ce8a8f3..3e3d14878a7b 100644 --- a/include/test/test.h +++ b/include/test/test.h @@ -127,8 +127,8 @@ struct unit_test { ll_entry_count(struct unit_test, ut_ ## _suite)
/* Use ! and ~ so that all tests will be sorted between these two values */ -#define UNIT_TEST_ALL_START() ll_entry_start(struct unit_test, ut_!) -#define UNIT_TEST_ALL_END() ll_entry_start(struct unit_test, ut_~) +#define UNIT_TEST_ALL_START() ll_entry_start(struct unit_test, ut_$) +#define UNIT_TEST_ALL_END() ll_entry_start(struct unit_test, ut_z) #define UNIT_TEST_ALL_COUNT() (UNIT_TEST_ALL_END() - UNIT_TEST_ALL_START())
/* Sizes for devres tests */
Am 25. April 2023 01:08:26 MESZ schrieb Simon Glass sjg@chromium.org:
This comment needs to be updated.
Can we use ut_zz here?
Best regards
Heinrich
The required linker symbols are not present. For now just return 0 in this case.
common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 1688e27071fc..4f380d7c82c8 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -290,7 +290,7 @@ static int setup_mon_len(void) { #if defined(__ARM__) || defined(__MICROBLAZE__) gd->mon_len = (ulong)&__bss_end - (ulong)_start; -#elif defined(CONFIG_SANDBOX) && !defined(__riscv) +#elif defined(CONFIG_SANDBOX) && !defined(__riscv) && !defined(__MSYS__) gd->mon_len = (ulong)&_end - (ulong)_init; #elif defined(CONFIG_SANDBOX) /* gcc does not provide _init in crti.o on RISC-V */
Windows doesn't really support symlinks so fails to build this file. Use a single-line #include instead.
include/ctype.h | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-) mode change 120000 => 100644 include/ctype.h
diff --git a/include/ctype.h b/include/ctype.h deleted file mode 120000 index 9e43f9c6c6c4..000000000000 --- a/include/ctype.h +++ /dev/null @@ -1 +0,0 @@ -linux/ctype.h \ No newline at end of file diff --git a/include/ctype.h b/include/ctype.h new file mode 100644 index 000000000000..155e3c63e59d --- /dev/null +++ b/include/ctype.h @@ -0,0 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2023 Google LLC + */ + +#include <linux/ctype.h>
Weak symbols are not well supported by the PE format, so disable them. We need to manually ensure that only one function is present in the source code.
Add a Kconfig option to control this and enable it when building for Windows.
Kconfig | 15 +++++++++++++++ include/linux/compiler_attributes.h | 4 ++++ 2 files changed, 19 insertions(+)
diff --git a/Kconfig b/Kconfig index f24e4f0a331e..ca1402d09d10 100644 --- a/Kconfig +++ b/Kconfig @@ -72,6 +72,21 @@ config CLANG_VERSION int default $(shell,$(srctree)/scripts/clang-version.sh $(CC))
+config CC_IS_MSYS + def_bool $(success,uname -o | grep -q Msys) + +config WEAK_SYMBOLS + bool "Enable use of weak symbols" + default y if !CC_IS_MSYS + help + The Portable Executable (PE) format used by Windows does not support + weak symbols very well. Even where it can be made to work, the __weak + function attribute cannot be made to work with PE. Supporting weak + symbols would involve changing the source code in undesirable ways. + + This option controls whether weak symbols are used, or not. When + disabled, the __weak function attribute does nothing. + choice prompt "Optimization level" default CC_OPTIMIZE_FOR_SIZE diff --git a/include/linux/compiler_attributes.h b/include/linux/compiler_attributes.h index 44c9a08d7346..c954109a065b 100644 --- a/include/linux/compiler_attributes.h +++ b/include/linux/compiler_attributes.h @@ -268,6 +268,10 @@ * gcc: https://gcc.gnu.org/onlinedocs/gcc/Common-Function-Attributes.html#index-wea... * gcc: https://gcc.gnu.org/onlinedocs/gcc/Common-Variable-Attributes.html#index-wea... */ +#ifdef CONFIG_WEAK_SYMBOLS #define __weak __attribute__((__weak__)) +#else +#define __weak +#endif
#endif /* __LINUX_COMPILER_ATTRIBUTES_H */
They are supported by PE format. This is likely issue of (older) toolchain. What about rather requiring better toolchain version and fix special cases of weak functions do not work correctly?
+config CC_IS_MSYS
- def_bool $(success,uname -o | grep -q Msys)
- bool "Enable use of weak symbols"
- default y if !CC_IS_MSYS
- help
- gcc: https://gcc.gnu.org/onlinedocs/gcc/Common-Function-Attributes.html#index-wea...
- gcc: https://gcc.gnu.org/onlinedocs/gcc/Common-Variable-Attributes.html#index-wea...
2.40.0.634.g4ca3ef3211-goog
Hi Pali,
What compiler are you using? How do weak symbols work in that compiler?
I am using:
$ gcc -v
COLLECT_GCC=gcc
Thread model: posix
gcc version 11.3.0 (GCC)
$ ld -v
+config CC_IS_MSYS
help
The MSYS2 compiler does not support some of these options. Drop them to avoid build errors.
Makefile | 2 ++ scripts/Makefile.lib | 5 ++++- 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 0aa97a2c3b48..773260b81d5d 100644 --- a/Makefile +++ b/Makefile @@ -818,7 +818,9 @@ KBUILD_CPPFLAGS += $(KCPPFLAGS) KBUILD_AFLAGS += $(KAFLAGS) KBUILD_CFLAGS += $(KCFLAGS)
+ifeq ($(MSYS_VERSION),0) KBUILD_LDFLAGS += -z noexecstack +endif KBUILD_LDFLAGS += $(call ld-option,--no-warn-rwx-segments)
KBUILD_HOSTCFLAGS += $(if $(CONFIG_TOOLS_DEBUG),-g) diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 7b27224b5d44..d309e26aaec8 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -425,7 +425,10 @@ cmd_efi_objcopy = $(OBJCOPY) -j .header -j .text -j .sdata -j .data -j \ $(obj)/%.efi: $(obj)/%_efi.so $(call cmd,efi_objcopy)
-KBUILD_EFILDFLAGS = -nostdlib -zexecstack -znocombreloc -znorelro +KBUILD_EFILDFLAGS = -nostdlib +ifeq ($(MSYS_VERSION),0) +KBUILD_EFILDFLAGS += -zexecstack -znocombreloc -znorelro +endif KBUILD_EFILDFLAGS += $(call ld-option,--no-warn-rwx-segments) quiet_cmd_efi_ld = LD $@ cmd_efi_ld = $(LD) $(KBUILD_EFILDFLAGS) -T $(EFI_LDS_PATH) \
We should use $(call ld-option,...) here instead.
What about rather using $(call ...) instead of ifeq?
-KBUILD_EFILDFLAGS = -nostdlib -zexecstack -znocombreloc -znorelro +KBUILD_EFILDFLAGS = -nostdlib +ifeq ($(MSYS_VERSION),0) +KBUILD_EFILDFLAGS += -zexecstack -znocombreloc -znorelro +endif KBUILD_EFILDFLAGS += $(call ld-option,--no-warn-rwx-segments) quiet_cmd_efi_ld = LD $@ cmd_efi_ld = $(LD) $(KBUILD_EFILDFLAGS) -T $(EFI_LDS_PATH) \ -- 2.40.0.634.g4ca3ef3211-goog
Add the required extension to the Makefile rule.
Makefile | 1 + scripts/Makefile.build | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 773260b81d5d..08eab87d0a11 100644 --- a/Makefile +++ b/Makefile @@ -48,6 +48,7 @@ ifeq ($(MSYS_VERSION),0) export SOEXT := so else export SOEXT := dll +export ELFEXT := .exe endif
# Avoid funny character set dependencies diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 97dd4a64f6ef..547dc039ceb4 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -309,7 +309,7 @@ quiet_cmd_asn1_compiler = ASN.1 $@ cmd_asn1_compiler = $(objtree)/tools/asn1_compiler $< \ $(subst .h,.c,$@) $(subst .c,.h,$@)
-$(obj)/%.asn1.c $(obj)/%.asn1.h: $(src)/%.asn1 $(objtree)/tools/asn1_compiler +$(obj)/%.asn1.c $(obj)/%.asn1.h: $(src)/%.asn1 $(objtree)/tools/asn1_compiler$(ELFEXT) $(call cmd,asn1_compiler)
# Build the compiled-in targets
.EXE is not extension for ELF format :-)
Autotools and also other tools use EXEEXT Makefile variable for this. What about following this de-factor standard variable name?
endif
This creates a lot of errors of the form:
`__stack_chk_fail' referenced in section `.text' of ...ltrans.o: defined in discarded section `.text' of common/stackprot.o (symbol from plugin)
Drop LTO for now.
Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/Makefile b/Makefile index 08eab87d0a11..3a35d14a4497 100644 --- a/Makefile +++ b/Makefile @@ -658,9 +658,11 @@ export EFI_TARGET # binutils target if EFI is natively supported export LTO_ENABLE
# This is y if LTO is enabled for this build. See NO_LTO=1 to disable LTO +ifeq ($(MSYS_VERSION),0) ifeq ($(NO_LTO),) LTO_ENABLE=$(if $(CONFIG_LTO),y) endif +endif
# If board code explicitly specified LDSCRIPT or CONFIG_SYS_LDSCRIPT, use # that (or fail if absent). Otherwise, search for a linker script in a
This issue should be rather fixed...
Drop LTO for now.
... and until it happens is not CONFIG_LTO for disabling enough?
LTO does not work for more other boards / platforms and it is just _not_ enabled via CONFIG_LTO in those cases...
Hi Pali,
Drop LTO for now.
The thing is, LTO is enabled for sandbox normally (clang and gcc). It is just the MSYS2 platform where there are problems.
I am not sure how to fix it, since I don't know what discarded section it is referring to.
On Tuesday 25 April 2023 19:04:10 Simon Glass wrote:
Hi Pali,
Drop LTO for now.
So what about having CONFIG_LTO by default 'n' for CONFIG_MSYS2?
Hi Pali,
Hi Pali,
Drop LTO for now.
But that would require creating a new board. I am trying to use the same board, just building it in a different environment.
On Thursday 27 April 2023 10:25:13 Simon Glass wrote:
Hi Pali,
Hi Pali,
Drop LTO for now.
Sorry, but I do not understand why you need a new board. Just introduce a new Kconfig symbol CONFIG_MSYS2 which value is by default assigned from the detected compiler and then set default value for CONFIG_LTO symbol to "n" when CONFIG_MSYS2 is "y". This does not require a new board and neither menuconfig user changes of (default) symbols.
On Thu, Apr 27, 2023 at 10:25:13AM -0600, Simon Glass wrote:
Hi Pali,
Hi Pali,
Drop LTO for now.
I think we need to make CONFIG_LTO depend on CC_IS_GCC for now as it also doesn't work (but could be addressed) for CC_IS_CLANG.
Hi Pali,
Hi Pali,
Drop LTO for now.
It got broken? It should work at least for sandbox...
Marek
Hi Pali,
Hi Pali,
On Monday 24 April 2023 17:08:32 Simon Glass wrote: > This creates a lot of errors of the form: > > `__stack_chk_fail' referenced in section `.text' of ...ltrans.o: defined > in discarded section `.text' of common/stackprot.o (symbol from plugin)
> Drop LTO for now.
Ah right, we do clang + sandbox (so + LTO). In my clang for arm experiments, I could only get LTO to almost-link if I also used lld instead of GNU ld (on the platform I was checking there's some _other_ problem that causes clang's SPL build to be something like 40kB larger than gcc, so even with LTO it was still overflowing).
These are now quite out-of-date. Update to 2023 versions and bring in those are are needed for the newer tool features.
doc/build/tools.rst | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/doc/build/tools.rst b/doc/build/tools.rst index ec0172292585..6b7342a27606 100644 --- a/doc/build/tools.rst +++ b/doc/build/tools.rst @@ -24,15 +24,18 @@ you can use MSYS2, a software distro and building platform for Windows. Download the MSYS2 installer from https://www.msys2.org. Make sure you have installed all required packages below in order to build these host tools::
- * gcc (9.1.0) - * make (4.2.1) - * bison (3.4.2) - * diffutils (3.7) - * openssl-devel (1.1.1.d) + * gcc (11.3.0-3) + * make (4.4.1-1) + * bison (3.8.2-4) + * diffutils (3.9-1) + * flex (2.6.4-3) + * libgnutls-devel (3.8.0-1) + * libutil-linux-devel (2.35.2) + * openssl-devel (3.1.0-1)
Note the version numbers in these parentheses above are the package versions at the time being when writing this document. The MSYS2 installer tested is -http://repo.msys2.org/distrib/x86_64/msys2-x86_64-20190524.exe. +https://github.com/msys2/msys2-installer/releases/download/2023-03-18/msys2-...
There are 3 MSYS subsystems installed: MSYS2, MinGW32 and MinGW64. Each subsystem provides an environment to build Windows applications. The MSYS2 @@ -43,5 +46,6 @@ applications using a linux toolchain (gcc, bash, etc), targeting respectively
Launch the MSYS2 shell of the MSYS2 environment, and do the following::
- $ make tools-only_defconfig - $ make tools-only + $ pacman -S bison diffutils flex gcc libgnutls-devel libutil-linux-devel \ + make openssl-devel + $ make tools-only_defconfig tools-only
Add instructions for building u-boot.exe to run on Windows.
doc/build/gcc.rst | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/doc/build/gcc.rst b/doc/build/gcc.rst index a0650a51db4b..40d0bde52413 100644 --- a/doc/build/gcc.rst +++ b/doc/build/gcc.rst @@ -184,8 +184,43 @@ Important ones are * clean - remove most generated files but keep the configuration * mrproper - remove all generated files + config + various backup files
+Building for Windows +-------------------- + +Limited support is available for Windows, including building sandbox. + +It is best to use an out-of-tree build, so you can build multiple boards, +with the output in a temporary directory like `/tmp/b`. + +First enable Windows developer mode with `Developer Mode`_. Then run the MSYS2 +shell and enable symbolic links:: + + cd + echo "export MSYS=winsymlinks:nativestrict" >>.bashrc + +Close all MSYS2 shells so that the setting takes effect. + +To build sandbox, first install some required packages:: + + pacman install bc bison diffutils flex gcc libgnutls-devel \ + libutil-linux-devel make openssl-devel python python-setuptools swig + +then:: + + make O=/tmp/b/sandbox -j$(nproc) sandbox_defconfig all + +Note that it currently only gets as far as running binman, since this doesn't +fully work on Windows. + +You can also build sandbox_spl:: + + make O=/tmp/b/sandbox_spl -j$(nproc) sandbox_spl_defconfig all + + Installation ------------
The process for installing U-Boot on the target device is device specific. Please, refer to the board specific documentation :doc:`../board/index`. + +.. _`Developer Mode`: https://msdn.microsoft.com/en-us/windows/uwp/get-started/enable-your-device-...
Am 25. April 2023 01:08:34 MESZ schrieb Simon Glass sjg@chromium.org:
- clean - remove most generated files but keep the configuration
- mrproper - remove all generated files + config + various backup files
Please, describe why you suggest to enable developer mode.
According to https://learn.microsoft.com/en-us/windows/security/threat-protection/securit... creation of symbolic links depends on policies and user authorization.
Please, mention the security implications.
Best regards
Heinrich
- cd
- echo "export MSYS=winsymlinks:nativestrict" >>.bashrc
- pacman install bc bison diffutils flex gcc libgnutls-devel \
+then::
- make O=/tmp/b/sandbox -j$(nproc) sandbox_defconfig all
- make O=/tmp/b/sandbox_spl -j$(nproc) sandbox_spl_defconfig all
Installation
Do you mean 'on Windows'?
This chapter sems not to be about building on Windows generally. Are you possibly using MinGW or MinGW-w64? How about cygwin?
Please, describe the build environment accurately.
Wouldn't it be a much saner approach to use WSL? Then we don't need any of the quirks.
Best regards
Heinrich
- cd
+then::
Installation
On Tue, Apr 25, 2023 at 10:54 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
The toolchain in the MSYS2 env should be MinGW-w64. cygwin is not for native Windows application build.
WSL is essentially Linux and that's not what Simon wanted to do in this series. Building sandbox under WSL is no different from what it is on a Linux machine.
Regards, Bin
Am 25. April 2023 05:01:30 MESZ schrieb Bin Meng bmeng.cn@gmail.com:
This patch is incomplete.
That is why the motivation for this series remains unclear.
Best regards
Heinrich
Regards, Bin
These give lots of warnings for the form:
lib/efi_loader/helloworld.o:helloworld.c:(.pdata+0x0): relocation truncated to fit: IMAGE_REL_AMD64_ADDR32NB against `.text'
The tables are not needed except when debugging, so disable them for now.
lib/efi_loader/Makefile | 8 ++++++++ scripts/Makefile.lib | 4 ++++ 2 files changed, 12 insertions(+)
diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 13a35eae6c06..c17d39eba91e 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -15,11 +15,19 @@ CFLAGS_efi_boottime.o += \ CFLAGS_boothart.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_boothart.o := $(CFLAGS_NON_EFI) CFLAGS_helloworld.o := $(CFLAGS_EFI) -Os -ffreestanding + +ifneq ($(MSYS_VERSION),0) +CFLAGS_helloworld.o += -fno-asynchronous-unwind-tables -fno-unwind-tables +endif + CFLAGS_REMOVE_helloworld.o := $(CFLAGS_NON_EFI) CFLAGS_dtbdump.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_dtbdump.o := $(CFLAGS_NON_EFI) CFLAGS_initrddump.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_initrddump.o := $(CFLAGS_NON_EFI) +ifneq ($(MSYS_VERSION),0) +CFLAGS_initrddump.o += -fno-asynchronous-unwind-tables -fno-unwind-tables +endif
ifdef CONFIG_RISCV always += boothart.efi diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index d309e26aaec8..1c3781a751fc 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -450,6 +450,10 @@ targets += $(obj)/efi_crt0.o $(obj)/efi_reloc.o $(obj)/efi_freestanding.o
CFLAGS_REMOVE_efi_reloc.o := $(LTO_CFLAGS) CFLAGS_REMOVE_efi_freestanding.o := $(LTO_CFLAGS) +ifneq ($(MSYS_VERSION),0) +CFLAGS_efi_reloc.o += -fno-asynchronous-unwind-tables -fno-unwind-tables +CFLAGS_efi_freestanding.o += -fno-asynchronous-unwind-tables -fno-unwind-tables +endif
# ACPI # ---------------------------------------------------------------------------
Add a new rule to build sandbox for Windows. For now, no tests are run in this configuration.
.azure-pipelines.yml | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 76ffdeebd667..d15a86ff3650 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -39,6 +39,33 @@ stages: # Tell MSYS2 not to ‘cd’ our startup directory to HOME CHERE_INVOKING: yes
+ - job: sandbox_windows + displayName: 'Ensure sandbox build for Windows' + pool: + vmImage: $(windows_vm) + steps: + - powershell: | + (New-Object Net.WebClient).DownloadFile("https://github.com/msys2/msys2-installer/releases/download/2021-06-04/msys2-...", "sfx.exe") + displayName: 'Install MSYS2' + - script: | + sfx.exe -y -o%CD:~0,2%\ + %CD:~0,2%\msys64\usr\bin\bash -lc " " + %CD:~0,2%\msys64\usr\bin\bash -lc "pacman --noconfirm -Syuu" + %CD:~0,2%\msys64\usr\bin\bash -lc "pacman --noconfirm -Syuu" + displayName: 'Update MSYS2' + - script: | + %CD:~0,2%\msys64\usr\bin\bash -lc "pacman --noconfirm --needed -Sy bc bison diffutils flex gcc libgnutls-devel libutil-linux-devel make openssl-devel python python-setuptools swig" + displayName: 'Install Toolchain' + - script: | + echo make sandbox_defconfig all > build-tools.sh + %CD:~0,2%\msys64\usr\bin\bash -lc "bash build-tools.sh" + displayName: 'Build sandbox' + env: + # Tell MSYS2 we need a POSIX emulation layer + MSYSTEM: MSYS + # Tell MSYS2 not to ‘cd’ our startup directory to HOME + CHERE_INVOKING: yes + - job: tools_only_macOS displayName: 'Ensure host tools build for macOS X' pool:
Am 25. April 2023 01:08:05 MESZ schrieb Simon Glass sjg@chromium.org:
This expands the existing work to allow sandbox to build and run on Windows using MSYS2.
Why do we need this? Wouldn't a developer on Windows be much better served using WSL (https://learn.microsoft.com/en-us/windows/wsl/install)?
Best regards
Heinrich
It also fixes a few issues so that binman can be used.
There are various limitations and some features do not work fully yet. In particular, weak functions are not well supported on Windows so these are disabled. Various minor compiler-flag and filename adjustments are also needed.
This does not support SDL, so U-Boot has no display. This is potentially possible, but requires using minggw instead of the base toolchain [1] so needs to be dealt with separately.
[1] https://gist.github.com/thales17/fb2e4cff60890a51d9dddd4c6e832ad2
Simon Glass (31): patman: Declare the future Series memory u_boot_pylib: Correct name of readme u_boot_pylib: Make pty optional binman: Avoid using a symlink binman: Don't require a HOME directory pylibfdt: Allow building on Windows Fix Makefile warning about parallel targets mkimage: Correct checking of configuration node Kbuild: Detect including an MSYS2 path sandbox: Provide a linker script for MSYS2 sandbox: Provide an EFI link script for PE sandbox: Drop dead code from Makefile sandbox: Disable raw Ethernet on MSYS2 sandbox: Drop signal handling for MSYS2 sandbox: Correct SDL.h header inclusion sandbox: Include errno.h in the test header sandbox: Allow weak symbols to be dropped sections: Drop use of linux/types.h sandbox: Drop incorrect inclusion of linux/types.h sandbox: Drop inclusion of os.h in sscanf.c test: Avoid strange symbols in the assembler file sandbox: Fix up setting of monitor_len on MSYS2 ctype: Avoid using a symlink build: Disable weak symbols for MSYS2 Makefile: Disable unsupported compiler options with PE Makefile: Correct the ans1_compiler rule for MSYS2 Makefile: Disable LTO when building with MSYS2 doc: Update the MSYS2 packages and versions doc: Show how to build sandbox for MSYS2 Makefile: Drop unwind tables CI: Enable sandbox build for Windows
.azure-pipelines.yml | 27 ++ Kconfig | 15 + Makefile | 27 +- arch/sandbox/Makefile | 7 - arch/sandbox/config.mk | 8 +- arch/sandbox/cpu/Makefile | 2 + arch/sandbox/cpu/os.c | 3 +- arch/sandbox/cpu/sdl.c | 2 +- arch/sandbox/cpu/u-boot-pe.lds | 447 ++++++++++++++++++++++++++ arch/sandbox/include/asm/test.h | 1 + arch/x86/lib/crt0_x86_64_efi.S | 2 + arch/x86/lib/pe_x86_64_efi.lds | 83 +++++ cmd/bootefi.c | 3 +- cmd/bootz.c | 3 + common/board_f.c | 2 +- common/usb.c | 3 + doc/build/gcc.rst | 35 ++ doc/build/tools.rst | 20 +- drivers/core/root.c | 3 + drivers/net/Makefile | 2 + drivers/spi/sandbox_spi.c | 3 + env/env.c | 6 + include/asm-generic/sections.h | 16 +- include/ctype.h | 7 +- include/linux/compiler_attributes.h | 4 + include/os.h | 2 - include/test/test.h | 4 +- lib/efi_loader/Makefile | 8 + lib/efi_loader/efi_image_loader.c | 3 + lib/efi_loader/efi_runtime.c | 4 + lib/lmb.c | 4 +- lib/sscanf.c | 1 - lib/time.c | 3 + scripts/Kbuild.include | 3 +- scripts/Makefile.build | 2 +- scripts/Makefile.lib | 9 +- scripts/dtc/pylibfdt/Makefile | 16 +- scripts/make_pip.sh | 9 +- tools/Makefile | 14 +- tools/binman/binman | 11 +- tools/binman/cmdline.py | 2 +- tools/image-host.c | 4 +- tools/patman/commit.py | 3 + tools/u_boot_pylib/README.rst | 2 +- tools/u_boot_pylib/cros_subprocess.py | 28 +- tools/u_boot_pylib/pyproject.toml | 2 +- 46 files changed, 803 insertions(+), 62 deletions(-) create mode 100644 arch/sandbox/cpu/u-boot-pe.lds create mode 100644 arch/x86/lib/pe_x86_64_efi.lds mode change 120000 => 100644 include/ctype.h mode change 120000 => 100755 tools/binman/binman
Depending on corporate rules that may or may not be allowed. But I too am interested in the use case driving these changes. Sandbox is essentially a test platform. We test that we can do host tools on Windows via MSYS2 for semi-reasonable reasons, since those tools can be used in a number of places. We do the same on macOS in Azure as a check on building regular targets there too (which should work and I believe people do, both from macOS and from *BSD which this is a stand-in for, as we can't get free VMs for them today). What's the end goal of this series?
Hi Tom,
It is really just an extension of the existing tools-only build. I am not sure it is strongly motivated, but the end goal is to be able to do small features / development on U-Boot on Windows, since some users seem to only use a 'pure' Windows environment and don't use WSL, which after all is for cross-compiling. For example, it is possible to build a FIT and check it using the tools, but it is not possible (without this series) to see whether U-Boot will load it and behave correctly.
The binman changes are to make that work on Windows (pip install binary-manager) which is important for that tool.
The 'weak' issue is something that I am hoping can be resolved (in fact Bin made a promising comment on that patch).
This has all come up as we try to establish a standard 'payload' format which can be used across the industry. For better or worse, some people do use Windows for development.
participants (6)
Bin Meng
Marek Behún
Pali Rohár
