[U-Boot] [PATCH v2 1/3] x86: congatec: add secureboot enabled defconfig for conga-qeval20-qa3-e3845
Signed-off-by: Markus Valentin mv@denx.de [agust: rebased, fixed to build with v2017.05] Signed-off-by: Anatolij Gustschin agust@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - add Reviewed-by tag
...0-qa3-e3845-internal-uart-secure-boot_defconfig | 77 ++++++++++++++++++++++ 1 file changed, 77 insertions(+) create mode 100644 configs/conga-qeval20-qa3-e3845-internal-uart-secure-boot_defconfig
diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart-secure-boot_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart-secure-boot_defconfig new file mode 100644 index 0000000..b78f90e --- /dev/null +++ b/configs/conga-qeval20-qa3-e3845-internal-uart-secure-boot_defconfig @@ -0,0 +1,77 @@ +CONFIG_X86=y +CONFIG_VENDOR_CONGATEC=y +CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y +CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" +CONFIG_INTERNAL_UART=y +CONFIG_HAVE_INTEL_ME=y +CONFIG_BAYTRAIL_SECURE_BOOT=y +CONFIG_ENABLE_MRC_CACHE=y +CONFIG_SMP=y +CONFIG_HAVE_VGA_BIOS=y +CONFIG_VGA_BIOS_ADDR=0xfffa0000 +CONFIG_GENERATE_PIRQ_TABLE=y +CONFIG_GENERATE_MP_TABLE=y +CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_SEABIOS=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y +CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CPU=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_INTEL=y +CONFIG_WINBOND_W83627=y +CONFIG_MMC=y +CONFIG_MMC_PCI=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_DM_PCI=y +CONFIG_DM_RTC=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x3f8 +CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_SYS_NS16550=y +CONFIG_ICH_SPI=y +CONFIG_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_VESA=y +CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_USE_PRIVATE_LIBGCC=y
Introduce a new Kconfig variable for secure boot on baytrail based platforms. If this variable is set the build process tries to use fsp-sb.bin instead of fsp.bin (-sb is the secure boot enabled fsp).
Also check the two fsp headers against each other and print if secure boot is enabled or not.
Signed-off-by: Markus Valentin mv@denx.de Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes in v2: - use if (IS_ENABLED(CONFIG_*)) instead of #ifdef - s/SB/Secure Boot/ - minor Kconfig help cleanup
arch/x86/Kconfig | 13 ++++++++++++- arch/x86/include/asm/fsp/fsp_support.h | 2 ++ arch/x86/lib/fsp/fsp_support.c | 18 ++++++++++++++++++ 3 files changed, 32 insertions(+), 1 deletion(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 9ead3eb..8cea393 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -348,7 +348,8 @@ config HAVE_FSP config FSP_FILE string "Firmware Support Package binary filename" depends on HAVE_FSP - default "fsp.bin" + default "fsp.bin" if !BAYTRAIL_SECURE_BOOT + default "fsp-sb.bin" if BAYTRAIL_SECURE_BOOT help The filename of the file to use as Firmware Support Package binary in the board directory. @@ -400,6 +401,16 @@ config FSP_BROKEN_HOB do not overwrite the important boot service data which is used by FSP, otherwise the subsequent call to fsp_notify() will fail.
+config BAYTRAIL_SECURE_BOOT + bool "Enable Secure Boot on BayTrail" + depends on HAVE_FSP + default n + help + Use the SecureBoot Features of the BayTrail platform. This switch + enables the usage of the secure-boot enabled fsp.bin (fsp-sb.bin) + for your board you need to provide this yourself. You can reconfigure + your fsp with the Intel BCT tool to enable SecureBoot. + config ENABLE_MRC_CACHE bool "Enable MRC cache" depends on !EFI && !SYS_COREBOOT diff --git a/arch/x86/include/asm/fsp/fsp_support.h b/arch/x86/include/asm/fsp/fsp_support.h index 61d811f..bae17bc 100644 --- a/arch/x86/include/asm/fsp/fsp_support.h +++ b/arch/x86/include/asm/fsp/fsp_support.h @@ -21,6 +21,8 @@ #define FSP_LOWMEM_BASE 0x100000UL #define FSP_HIGHMEM_BASE 0x100000000ULL #define UPD_TERMINATOR 0x55AA +#define FSP_FIRST_HEADER_OFFSET 0x94 +#define FSP_SECOND_HEADER_OFFSET 0x20494
/** diff --git a/arch/x86/lib/fsp/fsp_support.c b/arch/x86/lib/fsp/fsp_support.c index a480361..0bbd9ae 100644 --- a/arch/x86/lib/fsp/fsp_support.c +++ b/arch/x86/lib/fsp/fsp_support.c @@ -120,6 +120,14 @@ void fsp_init(u32 stack_top, u32 boot_mode, void *nvs_buf) panic("Invalid FSP header"); }
+ if (IS_ENABLED(CONFIG_BAYTRAIL_SECURE_BOOT)) { + /* compare primary and secondary header */ + if (memcmp((void *)(CONFIG_FSP_ADDR + FSP_FIRST_HEADER_OFFSET), + (void *)(CONFIG_FSP_ADDR + FSP_SECOND_HEADER_OFFSET), + fsp_hdr->hdr_len)) + panic("Secure Boot: 1st & 2nd FSP headers don't match"); + } + config_data.common.fsp_hdr = fsp_hdr; config_data.common.stack_top = stack_top; config_data.common.boot_mode = boot_mode; @@ -134,6 +142,16 @@ void fsp_init(u32 stack_top, u32 boot_mode, void *nvs_buf)
fsp_upd = &config_data.fsp_upd;
+ if (IS_ENABLED(CONFIG_BAYTRAIL_SECURE_BOOT)) { + /* + * if the enable secure boot flag is not 1, secure boot has not + * been activated in the FSP which results in the TXE-Engine not + * getting loaded + */ + printf("FSP: Secure Boot %sabled\n", + fsp_vpd->enable_secure_boot == 1 ? "en" : "dis"); + } + /* Copy default data from Flash */ memcpy(fsp_upd, (void *)(fsp_hdr->img_base + fsp_vpd->upd_offset), sizeof(struct upd_region));
Hi Anatolij,
Changes in v2:
- s/SB/Secure Boot/
default "fsp.bin"
Should this be in arch/x86/cpu/baytrail/Kconfig instead?
depends on HAVE_FSP
default n
help
nits: secure boot feature
nits: secure boot
Are these two offsets common to all FSP, or BayTrail-specific values?
fsp_hdr->hdr_len))
* getting loaded
I believe this won't build for other FSP platforms due to no enable_secure_boot member in fsp_vpd structure.
Regards, Bin
Hi Bin,
On Tue, 16 May 2017 22:39:23 +0800 Bin Meng bmeng.cn@gmail.com wrote:
Hi Anatolij,
Changes in v2:
- s/SB/Secure Boot/
default "fsp.bin"
right, I'll move it to baytrail subdir.
depends on HAVE_FSP
default n
help
OK.
nits: secure boot
OK.
I think that 0x204094 is BayTrail-specific. 0x94 is common, I have seen this value in all FSP integration guide files, when it is documented there.
fsp_hdr->hdr_len))
* getting loaded
Yes, this breaks crownbay_defconfig build. AFAIK, we do not have support for multiple platforms in a single image, so I have to use ifdef here to avoid build issues.
Thanks for review and comments!
-- Anatolij
Introduce functions that check the integrity of U-Boot by utilising the hashes stored in the oem-data block.
The verification functions get called in fsp_init()
Signed-off-by: Markus Valentin mv@denx.de Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes in v2: - use 'const void *' for fdt property ptr, drop cast - s/u-boot/U-Boot/ - fix function comment style and move comments to header with prototypes. Use fsp_ prefix - fix multiline comment style - s/SB:/Secure Boot/ for non-debug messages
arch/x86/cpu/baytrail/Makefile | 1 + arch/x86/cpu/baytrail/secure_boot.c | 105 +++++++++++++++++++++ .../include/asm/arch-baytrail/fsp/fsp_configs.h | 22 +++++ arch/x86/lib/fsp/fsp_support.c | 17 ++++ 4 files changed, 145 insertions(+) create mode 100644 arch/x86/cpu/baytrail/secure_boot.c
diff --git a/arch/x86/cpu/baytrail/Makefile b/arch/x86/cpu/baytrail/Makefile index a0216f3..dbf9a82 100644 --- a/arch/x86/cpu/baytrail/Makefile +++ b/arch/x86/cpu/baytrail/Makefile @@ -8,4 +8,5 @@ obj-y += cpu.o obj-y += early_uart.o obj-y += fsp_configs.o obj-y += valleyview.o +obj-$(CONFIG_BAYTRAIL_SECURE_BOOT) += secure_boot.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o diff --git a/arch/x86/cpu/baytrail/secure_boot.c b/arch/x86/cpu/baytrail/secure_boot.c new file mode 100644 index 0000000..97acea8 --- /dev/null +++ b/arch/x86/cpu/baytrail/secure_boot.c @@ -0,0 +1,105 @@ +/* + * Copyright (C) 2017 Markus Valentin mv@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#define SB_MANIFEST_BASE 0xFFFE0000 +#define SB_MANIFEST_SIZE 0x400 +#define SB_MANIFEST_OEM_DATA_OFFSET 0x58 +#define SB_MANIFEST_OEM_HASH_OFFSET (SB_MANIFEST_OEM_DATA_OFFSET + 4) +#define SB_MANIFEST_OEM_HASH_BASE (SB_MANIFEST_BASE +\ + SB_MANIFEST_OEM_HASH_OFFSET) +#define SB_MANIFEST_END (SB_MANIFEST_BASE + SB_MANIFEST_SIZE) + +#define PUB_KEY_MODULUS_SIZE 0x100 +#define U_BOOT_STAGE_SIZE 0xDD360 +#define U_BOOT_OFFSET 0x2CA0 + +#define U_BOOT_STAGE_START (CONFIG_SYS_TEXT_BASE + U_BOOT_OFFSET) +#define U_BOOT_STAGE_END (U_BOOT_STAGE_START + U_BOOT_STAGE_SIZE) + +#define SHA256_U_BOOT_STAGE_ID 0 +#define SHA256_FSP_STAGE2_ID 1 +#define SHA256_FIT_PUB_KEY_ID 2 + +#define FIT_KEY_NAME "dev" + +/** + * verify_oem_sha256() - oem data block verification + * + * This function compares a hash which gets retrieved from the oem data block + * with the runtime calculated hash of start_address+size. If they match, + * this function returns true. If not, it returns false. + * + * @hash_id: offset of oem-data block for hash to compare + * @start_address: address where the hash calculation should start + * @size: length of the region for hash calculation + * + * @retval: true on success, false on error + */ +static bool verify_oem_sha256(unsigned int hash_id, + const void *start_address, + size_t size) +{ + uint8_t value[SHA256_SUM_LEN]; + int value_len; + + /* calculate address of hash to compare in the oemdata block*/ + void *hash_to_verify = (void *)SB_MANIFEST_OEM_HASH_BASE + + (SHA256_SUM_LEN * hash_id); +#ifdef DEBUG + unsigned int i = 0; + uint8_t oem_value[SHA256_SUM_LEN]; + + memcpy(oem_value, hash_to_verify, SHA256_SUM_LEN); + printf("SB: Hash to verify:\t"); + for (i = 0; i < SHA256_SUM_LEN; i++) + printf("%X", oem_value[i]); + printf("\n"); +#endif + + /* calculate the hash of the binary */ + calculate_hash(start_address, size, "sha256", value, &value_len); + +#ifdef DEBUG + printf("SB: calculated hash:\t"); + for (i = 0; i < SHA256_SUM_LEN; i++) + printf("%X", value[i]); + printf("\n"); +#endif + /* compare the two hash values */ + if (memcmp(hash_to_verify, value, SHA256_SUM_LEN)) + return false; + return true; +} + +bool fsp_verify_u_boot_bin(void) +{ + return verify_oem_sha256(SHA256_U_BOOT_STAGE_ID, + (const void *)U_BOOT_STAGE_START, + U_BOOT_STAGE_SIZE); +} + +bool fsp_verify_public_key(void) +{ + const void *fit_public_key_modulus; + + int offset = fdt_node_offset_by_prop_value(gd->fdt_blob, -1, + "key-name-hint", + FIT_KEY_NAME, + 4); + + fit_public_key_modulus = fdt_getprop(gd->fdt_blob, offset, + "rsa,modulus", NULL); + if (!fit_public_key_modulus) { + debug("SB: Could not fetch public key from U-Boot Devicetree\n"); + return false; + } + + return verify_oem_sha256(SHA256_FIT_PUB_KEY_ID, + fit_public_key_modulus, + PUB_KEY_MODULUS_SIZE); +} diff --git a/arch/x86/include/asm/arch-baytrail/fsp/fsp_configs.h b/arch/x86/include/asm/arch-baytrail/fsp/fsp_configs.h index e539890..a07853c 100644 --- a/arch/x86/include/asm/arch-baytrail/fsp/fsp_configs.h +++ b/arch/x86/include/asm/arch-baytrail/fsp/fsp_configs.h @@ -16,4 +16,26 @@ struct fspinit_rtbuf { struct common_buf common; /* FSP common runtime data structure */ };
+/** + * fsp_verify_u_boot_bin() - U-Boot binary verification + * + * This function verifies the integrity for U-Boot, its devicetree and the ucode + * appended or inserted to the devicetree. + * + * @retval: true on success, false on error + */ +bool fsp_verify_u_boot_bin(void); + +/** + * fsp_verify_public_key() - integrity of public key for fit image verification + * + * This function verifies the integrity for the modulus of the public key which + * is stored in the U-Boot devicetree for fit image verification. It tries to + * find the "rsa,modulus" property in the dtb and then verifies it with the + * checksum stored in the oem-data block + * + * @retval: true on success, false on error + */ +bool fsp_verify_public_key(void); + #endif /* __FSP_CONFIGS_H__ */ diff --git a/arch/x86/lib/fsp/fsp_support.c b/arch/x86/lib/fsp/fsp_support.c index 0bbd9ae..5e3ce13 100644 --- a/arch/x86/lib/fsp/fsp_support.c +++ b/arch/x86/lib/fsp/fsp_support.c @@ -150,6 +150,23 @@ void fsp_init(u32 stack_top, u32 boot_mode, void *nvs_buf) */ printf("FSP: Secure Boot %sabled\n", fsp_vpd->enable_secure_boot == 1 ? "en" : "dis"); + + if (!fsp_verify_u_boot_bin()) { + /* + * If our U-Boot binary checksum isn't equal to + * our expected checksum we need to stop booting + */ + puts("Secure Boot: Failed to verify U-Boot and dtb\n"); + hang(); + } + + /* + * Verification of the public key happens with verification of + * the devicetree binary (that's where it's stored), this check + * is not necessary, but nice to see it's integer + */ + if (!fsp_verify_public_key()) + puts("Secure Boot: Failed to verify public key for fit-image\n"); }
Hi Anatolij,
Changes in v2:
- s/u-boot/U-Boot/
- Copyright (C) 2017 Markus Valentin mv@denx.de
nits: please use lower case hex and fix this globally in this file
What is this?
and this?
I believe a comment block is needed for explaining things like number 0/1/2, at least where are they coming?
- verify_oem_sha256() - oem data block verification
- This function compares a hash which gets retrieved from the oem data block
- with the runtime calculated hash of start_address+size. If they match,
- this function returns true. If not, it returns false.
- @hash_id: offset of oem-data block for hash to compare
- @start_address: address where the hash calculation should start
- @size: length of the region for hash calculation
- @retval: true on success, false on error
size_t size)
int value_len;
+#ifdef DEBUG
unsigned int i = 0;
printf("\n");
+#ifdef DEBUG
printf("\n");
nits: two spaces after 'hash'
return false;
return true;
U_BOOT_STAGE_SIZE);
"key-name-hint",
FIT_KEY_NAME,
4);
return false;
- fsp_verify_u_boot_bin() - U-Boot binary verification
- This function verifies the integrity for U-Boot, its devicetree and the ucode
- appended or inserted to the devicetree.
- fsp_verify_public_key() - integrity of public key for fit image verification
- This function verifies the integrity for the modulus of the public key which
- is stored in the U-Boot devicetree for fit image verification. It tries to
nits: device tree
- find the "rsa,modulus" property in the dtb and then verifies it with the
- checksum stored in the oem-data block
Again, are these two APIs common for all FSP based platforms?
hang();
nits: device tree
As the comments say it's not necessary, which means it will never fail, right? But in case it fails, that means either hardware is doing wrong, or software is doing wrong? Can we adjust the output message to indicate some hints?
} /* Copy default data from Flash */
BTW: I don't see device tree update for the secure boot enabled board, like a device tree that has the "rsa,modulus" stuff.
Regards, Bin
Hi Bin,
Sorry for long delay, I finally got to prepare v3 series.
On Tue, 16 May 2017 22:40:29 +0800 Bin Meng bmeng.cn@gmail.com wrote: ...
OK, done in v3.
What is this?
and this?
I don't know where these values are comming from, but I think they are both wrong. A big U-Boot RAM stage part from reset vector remains unprotected with these. I'll fix U_BOOT_STAGE_SIZE, drop U_BOOT_OFFSET and will add a comment in v3. Will also adapt the image signing script as needed.
These are indexes of 32-byte blocks in the manifest containing SHA256 hashes, the stage order is fixed. Will add some comments here in v3.
OK, fixed.
nits: device tree
OK, fixed.
No, these are used only for Bay Trail secure boot, so the prototypes are in baytrail specific fsp_configs.h.
nits: device tree
OK, fixed.
It can fail if the key is missing in the device tree or if the key hash in the verified boot manifest doesn't match the hash of the key in the device tree. I'll slightly rework it here to give more hints.
The device tree will be updated by users, they have to supply their own keys to the mkimage tool and it will insert the signature node with custom "rsa,modulus" and other properties.
Thanks,
Anatolij
Hi Anatolij,
Can you add a simple sentence for this commit?
Changes in v2:
This commit should come in later in this patch series, as CONFIG_BAYTRAIL_SECURE_BOOT is not available yet at this point.
Regards, Bin
Hi Bin,
On Tue, 16 May 2017 22:39:17 +0800 Bin Meng bmeng.cn@gmail.com wrote:
Hi Anatolij,
yes, will do in next version.
OK, will move it.
-- Anatolij
Anatolij Gustschin
Bin Meng
