[PATCH 00/16] Fix i.MXRT1020/50
This patchset adds imx-gpt-timer driver that is supported by i.MXRT and also a lot of other i.MX* SoCs. This driver is needed for i.MXRT SoC family that is lacking at the moment the timer at all and that makes u-boot to fail running on i.MXRT. There are also some fixes in imxrt10*0-evk.dts and other minor fixed and improvements.
Giulio Benetti (16): arm: imxrt: soc: make mpu regions generic timer: imx-gpt: Add timer support for i.MX SoCs family ARM: dts: imxrt1020: add alias to osc ARM: dts: imxrt1020: add gpt1 node ARM: dts: imxrt1020-evk: enable gpt1 timer ARM: dts: imxrt1020-evk: set gpt1 as tick-timer for u-boot ARM: dts: imxrt1020-evk-u-boot: make gpt1 present for SPL ARM: dts: imxrt1020-evk: add device_type = "memory" to memory node configs: imxrt1020-evk: enable imx gpt timer as tick-timer ARM: dts: imxrt1050: add alias to osc ARM: dts: imxrt1050: add gpt1 node ARM: dts: imxrt1050-evk: enable gpt1 timer ARM: dts: imxrt1050-evk: set gpt1 as tick-timer for u-boot ARM: dts: imxrt1050-evk-u-boot: make gpt1 present for SPL ARM: dts: imxrt1050-evk: add device_type = "memory" to memory node configs: imxrt1050-evk: enable imx gpt timer as tick-timer
arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 4 + arch/arm/dts/imxrt1020-evk.dts | 6 + arch/arm/dts/imxrt1020.dtsi | 10 +- arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 4 + arch/arm/dts/imxrt1050-evk.dts | 6 + arch/arm/dts/imxrt1050.dtsi | 10 +- arch/arm/mach-imx/imxrt/soc.c | 6 +- configs/imxrt1020-evk_defconfig | 1 + configs/imxrt1050-evk_defconfig | 1 + drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/imx-gpt-timer.c | 162 +++++++++++++++++++++++++ 12 files changed, 213 insertions(+), 5 deletions(-) create mode 100644 drivers/timer/imx-gpt-timer.c
This mpu handling works for every i.MXRT SoC that we have, so let's generalize imxrt1050_region_config to imxrt_region_config.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/mach-imx/imxrt/soc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/imxrt/soc.c b/arch/arm/mach-imx/imxrt/soc.c index 8e7d15160d..c533f3554a 100644 --- a/arch/arm/mach-imx/imxrt/soc.c +++ b/arch/arm/mach-imx/imxrt/soc.c @@ -14,7 +14,7 @@ int arch_cpu_init(void) { int i;
- struct mpu_region_config imxrt1050_region_config[] = { + struct mpu_region_config imxrt_region_config[] = { { 0x00000000, REGION_0, XN_DIS, PRIV_RW_USR_RW, STRONG_ORDER, REGION_4GB }, { PHYS_SDRAM, REGION_1, XN_DIS, PRIV_RW_USR_RW, @@ -29,8 +29,8 @@ int arch_cpu_init(void) * the whole 4GB address space. */ disable_mpu(); - for (i = 0; i < ARRAY_SIZE(imxrt1050_region_config); i++) - mpu_config(&imxrt1050_region_config[i]); + for (i = 0; i < ARRAY_SIZE(imxrt_region_config); i++) + mpu_config(&imxrt_region_config[i]); enable_mpu();
This timer driver is using GPT Timer (General Purpose Timer) available on almost all i.MX SoCs family. Since this driver is only meant to provide u-boot's timer and counter, and most of the i.MX* SoCs use a 24Mhz crystal, let's only deal with that specific source.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com [Giulio: added the driver's stub and handled peripheral clock prescaler setting] Signed-off-by: Jesse Taube mr.bossman075@gmail.com [Jesse: added init, setting prescaler for 24Mhz support and enabling timer] --- drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/imx-gpt-timer.c | 162 ++++++++++++++++++++++++++++++++++ 3 files changed, 170 insertions(+) create mode 100644 drivers/timer/imx-gpt-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 80743a2551..ee81dfa776 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -227,4 +227,11 @@ config MCHP_PIT64B_TIMER Select this to enable support for Microchip 64-bit periodic interval timer.
+config IMX_GPT_TIMER + bool "NXP i.MX GPT timer support" + depends on TIMER + help + Select this to enable support for the timer found on + NXP i.MX devices. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index eb5c48cc6c..e214ba7268 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -25,3 +25,4 @@ obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o obj-$(CONFIG_MCHP_PIT64B_TIMER) += mchp-pit64b-timer.o +obj-$(CONFIG_IMX_GPT_TIMER) += imx-gpt-timer.o diff --git a/drivers/timer/imx-gpt-timer.c b/drivers/timer/imx-gpt-timer.c new file mode 100644 index 0000000000..a498f2e21c --- /dev/null +++ b/drivers/timer/imx-gpt-timer.c @@ -0,0 +1,162 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <fdtdec.h> +#include <timer.h> +#include <dm/device_compat.h> + +#include <asm/io.h> + +#define GPT_CR_EN BIT(0) +#define GPT_CR_FRR BIT(9) +#define GPT_CR_EN_24M BIT(10) +#define GPT_CR_SWR BIT(15) + +#define GPT_PR_PRESCALER24M_MASK 0x0000F000 +#define GPT_PR_PRESCALER24M_SHIFT 12 +#define GPT_PR_PRESCALER24M_MAX (GPT_PR_PRESCALER24M_MASK >> GPT_PR_PRESCALER24M_SHIFT) +#define GPT_PR_PRESCALER_MASK 0x00000FFF +#define GPT_PR_PRESCALER_SHIFT 0 +#define GPT_PR_PRESCALER_MAX (GPT_PR_PRESCALER_MASK >> GPT_PR_PRESCALER_SHIFT) + +#define GPT_CLKSRC_IPG_CLK (1 << 6) +#define GPT_CLKSRC_IPG_CLK_24M (5 << 6) + +/* If CONFIG_SYS_HZ_CLOCK not specified et's default to 3Mhz */ +#ifndef CONFIG_SYS_HZ_CLOCK +#define CONFIG_SYS_HZ_CLOCK 3000000 +#endif + +struct imx_gpt_timer_regs { + u32 cr; + u32 pr; + u32 sr; + u32 ir; + u32 ocr1; + u32 ocr2; + u32 ocr3; + u32 icr1; + u32 icr2; + u32 cnt; +}; + +struct imx_gpt_timer_priv { + struct imx_gpt_timer_regs *base; +}; + +static u64 imx_gpt_timer_get_count(struct udevice *dev) +{ + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs = priv->base; + + return readl(®s->cnt); +} + +static int imx_gpt_setup(struct imx_gpt_timer_regs *regs, u32 rate) +{ + u32 prescaler = (rate / CONFIG_SYS_HZ_CLOCK) - 1; + + /* Reset the timer */ + setbits_le32(®s->cr, GPT_CR_SWR); + + /* Wait for timer to finish reset */ + while (readl(®s->cr) & GPT_CR_SWR) + ; + + if (rate == 24000000UL) { + /* Set timer frequency if using 24M clock source */ + if (prescaler > GPT_PR_PRESCALER24M_MAX) + return -EINVAL; + + /* Set 24M prescaler */ + writel((prescaler << GPT_PR_PRESCALER24M_SHIFT), ®s->pr); + /* Set Oscillator as clock source, enable 24M input and set gpt + * in free-running mode + */ + writel(GPT_CLKSRC_IPG_CLK_24M | GPT_CR_EN_24M | GPT_CR_FRR, ®s->cr); + } else { + if (prescaler > GPT_PR_PRESCALER_MAX) + return -EINVAL; + + /* Set prescaler */ + writel((prescaler << GPT_PR_PRESCALER_SHIFT), ®s->pr); + /* Set Peripheral as clock source and set gpt in free-running + * mode + */ + writel(GPT_CLKSRC_IPG_CLK | GPT_CR_FRR, ®s->cr); + } + + /* Start timer */ + setbits_le32(®s->cr, GPT_CR_EN); + + return 0; +} + +static int imx_gpt_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs; + struct clk clk; + fdt_addr_t addr; + u32 clk_rate; + int ret; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = (struct imx_gpt_timer_regs *)addr; + regs = priv->base; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + if (ret) { + dev_err(dev, "Failed to enable clock\n"); + return ret; + } + + /* Get timer clock rate */ + clk_rate = clk_get_rate(&clk); + if (clk_rate <= 0) { + dev_err(dev, "Could not get clock rate...\n"); + return -EINVAL; + } + + ret = imx_gpt_setup(regs, clk_rate); + if (ret) { + dev_err(dev, "Could not setup timer\n"); + return ret; + } + + uc_priv->clock_rate = CONFIG_SYS_HZ_CLOCK; + + return 0; +} + +static const struct timer_ops imx_gpt_timer_ops = { + .get_count = imx_gpt_timer_get_count, +}; + +static const struct udevice_id imx_gpt_timer_ids[] = { + { .compatible = "fsl,imxrt-gpt" }, + {} +}; + +U_BOOT_DRIVER(imx_gpt_timer) = { + .name = "imx_gpt_timer", + .id = UCLASS_TIMER, + .of_match = imx_gpt_timer_ids, + .priv_auto = sizeof(struct imx_gpt_timer_priv), + .probe = imx_gpt_timer_probe, + .ops = &imx_gpt_timer_ops, +};
Sorry, it's not true we deal 24Mhz only, also peripheral clock is dealt. So commit log should be: ``` This timer driver is using GPT Timer (General Purpose Timer) available on almost all i.MX SoCs family. This driver deals with both 24Mhz oscillator as well as peripheral clock. ```
Let me know if I need to re-send.
Best regards
return -EINVAL;
In the datasheet for the imxrt1050 the 24Mhz scaler output goes into the normal prescaler.The width of the 24Mhz prescaler is only 4 bits it seems to be meant to divide the 24Mhz to something more reasonable for the other prescaler. I would do something like this...
+ if (rate == 24000000UL) { + /* Set timer frequency if using 24M clock source */ + if (prescaler > (GPT_PR_PRESCALER24M_MAX << 12) | GPT_PR_PRESCALER_MAX) + return -EINVAL; + + /* Set 24M prescaler */ + writel(( (prescaler >> 12) << GPT_PR_PRESCALER24M_SHIFT), ®s->pr); + writel(( (prescaler & GPT_PR_PRESCALER_MASK) << GPT_PR_PRESCALER_SHIFT), ®s->pr);
Ideally we would have the lengths in bits for GPT_PR_PRESCALER_MASK to replace the 12, but we can also do...
+ if (rate == 24000000UL) { + /* Set timer frequency if using 24M clock source */ + if (prescaler > (GPT_PR_PRESCALER24M_MASK | GPT_PR_PRESCALER_MAX)) + return -EINVAL; + + /* Set 24M prescaler */ + writel(prescaler , ®s->pr);
Side note while debugging this i added `KCFLAGS=-DDEBUG` and the boot would hang with it but without it would boot normally. The cause for the hang is this loop will never exit, not this only happens while booting u-boot and not during the spl stage. /drivers/serial/serial_lpuart.c @@ -356,7 +356,9 @@ static void _lpuart32_serial_putc(struct lpuart_serial_plat *plat,
while (true) { lpuart_read32(plat->flags, &base->stat, &stat);
if ((stat & STAT_TDRE)) break;
Sorry if im being dumb im new to this stuff and thanks for every one for walking me through this.
On Wed, Apr 7, 2021 at 3:20 PM Giulio Benetti < giulio.benetti@benettiengineering.com> wrote:
Best regards
Giulio Benetti Benetti Engineering sas
depends on TIMER
help
NXP i.MX devices.
- endmenu
- Copyright (C) 2021
- Author(s): Giulio Benetti giulio.benetti@benettiengineering.com
u32 cr;
u32 pr;
u32 sr;
u32 ir;
u32 ocr1;
u32 ocr2;
u32 ocr3;
u32 icr1;
u32 icr2;
u32 cnt;
return -EINVAL;
®s->pr);
set gpt
} else {
return -EINVAL;
/* Set prescaler */
free-running
* mode
/* Start timer */
struct clk clk;
fdt_addr_t addr;
u32 clk_rate;
int ret;
return -EINVAL;
regs = priv->base;
if (ret < 0)
return ret;
if (ret) {
return ret;
return -EINVAL;
if (ret) {
return ret;
.id = UCLASS_TIMER,
Hi Jesse,
please use plain-text e-mail instead of html,
On 4/8/21 3:06 AM, Jesse T wrote:
> + if (rate == 24000000UL) { > + /* Set timer frequency if using 24M clock source */ > + if (prescaler > GPT_PR_PRESCALER24M_MAX) > + return -EINVAL; > +
You're right, I've missed RM Figure 51-2 against 51-1, I was sure that Prescaler 24M was directly feeding the Timer Counter. Anyway I was trying to follow what they do in Linux kernel: https://elixir.bootlin.com/linux/latest/source/drivers/clocksource/timer-imx...
What they try to do as I understand is to avoid using PLL if 3Mhz is the wished rate and the same I'm trying to do here. Then yes, you're right that main prescaler can divide again.
I can't understand this check ^^^
+ return -EINVAL;
This way ^^^ you set the 2 in-series prescalers with the same value if it's what you mean.
Still don't understand this ^^^ with the 2 or'ed macros.
That gets expanded like: ``` if (prescaler > (GPT_PR_PRESCALER24M_MASK | ((GPT_PR_PRESCALER24M_MASK
GPT_PR_PRESCALER24M_SHIFT)))
``` and to: ``` if (prescaler > (0x0000F000 | (0x0000F000 >> 12))) ``` that results in: ``` if (prescaler > (0x0000F000 | 0xF)) ```
so it doesn't make sense to me, maybe did you mean something different or I'm wrong while expanding?
+ return -EINVAL;
Thanks for recalling me this, I still didn't check it, so I'm going through this and fix it.
You're not being dumb
You're welcome :-) and thank you for helping me with this driver and reviewing! Reviewing is a very important part of the process of upstreaming patches.
Kind regards
- bool "NXP i.MX GPT timer support"
- depends on TIMER
- help
NXP i.MX devices.
- endmenu
- u32 cr;
- u32 pr;
- u32 sr;
- u32 ir;
- u32 ocr1;
- u32 ocr2;
- u32 ocr3;
- u32 icr1;
- u32 icr2;
- u32 cnt;
- struct imx_gpt_timer_regs *base;
- struct imx_gpt_timer_priv *priv = dev_get_priv(dev);
- struct imx_gpt_timer_regs *regs = priv->base;
- return readl(®s->cnt);
This should use timer_conv_64 since it is a 32-bit timer.
--Sean
- u32 prescaler = (rate / CONFIG_SYS_HZ_CLOCK) - 1;
- /* Reset the timer */
- setbits_le32(®s->cr, GPT_CR_SWR);
- /* Wait for timer to finish reset */
- while (readl(®s->cr) & GPT_CR_SWR)
- if (rate == 24000000UL) {
return -EINVAL;
- } else {
return -EINVAL;
/* Set prescaler */
* mode
- /* Start timer */
- setbits_le32(®s->cr, GPT_CR_EN);
- struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- struct imx_gpt_timer_regs *regs;
- struct clk clk;
- fdt_addr_t addr;
- u32 clk_rate;
- int ret;
- addr = dev_read_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->base = (struct imx_gpt_timer_regs *)addr;
- regs = priv->base;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0)
return ret;
- ret = clk_enable(&clk);
- if (ret) {
return ret;
- /* Get timer clock rate */
- clk_rate = clk_get_rate(&clk);
- if (clk_rate <= 0) {
return -EINVAL;
- ret = imx_gpt_setup(regs, clk_rate);
- if (ret) {
return ret;
- uc_priv->clock_rate = CONFIG_SYS_HZ_CLOCK;
- .get_count = imx_gpt_timer_get_count,
- { .compatible = "fsl,imxrt-gpt" },
- .name = "imx_gpt_timer",
- .id = UCLASS_TIMER,
- .of_match = imx_gpt_timer_ids,
- .priv_auto = sizeof(struct imx_gpt_timer_priv),
- .probe = imx_gpt_timer_probe,
- .ops = &imx_gpt_timer_ops,
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imxrt1020.dtsi b/arch/arm/dts/imxrt1020.dtsi index 97f3cec9f3..0a3a3b451a 100644 --- a/arch/arm/dts/imxrt1020.dtsi +++ b/arch/arm/dts/imxrt1020.dtsi @@ -36,7 +36,7 @@ clock-frequency = <0>; };
- osc { + osc: osc { u-boot,dm-spl; compatible = "fsl,imx-osc", "fixed-clock"; #clock-cells = <0>;
Hi Giulio,
On Wed, Apr 7, 2021 at 4:03 PM Giulio Benetti giulio.benetti@benettiengineering.com wrote:
osc {
osc: osc {
Nit: what you are adding here is a "node label", not an "alias".
It would be nice to always add a commit log, even if it is a short one.
Hi Gabio,
Il giorno 3 mag 2021, alle ore 16:01, Fabio Estevam festevam@gmail.com ha scritto:
Hi Giulio,
osc {
osc: osc {
Thank you, you’re right.
Ok, is it ok if it even repeats the first line? Because I don’t know what write more than that.
Best regards Giulio Benetti
On Mon, May 3, 2021 at 2:52 PM Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Yes, that would be fine.
Il giorno 3 mag 2021, alle ore 20:21, Fabio Estevam festevam@gmail.com ha scritto:
Ok thank you. This was a doubt I always had.
Giulio
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/imxrt1020.dtsi b/arch/arm/dts/imxrt1020.dtsi index 0a3a3b451a..cab608c644 100644 --- a/arch/arm/dts/imxrt1020.dtsi +++ b/arch/arm/dts/imxrt1020.dtsi @@ -129,5 +129,13 @@ interrupt-controller; #interrupt-cells = <2>; }; + + gpt1: gpt1@401ec000 { + compatible = "fsl,imxrt-gpt"; + reg = <0x401ec000 0x4000>; + interrupts = <100>; + clocks = <&osc>; + status = "disabled"; + }; }; };
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020-evk.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imxrt1020-evk.dts b/arch/arm/dts/imxrt1020-evk.dts index ece13601bd..a471ff3838 100644 --- a/arch/arm/dts/imxrt1020-evk.dts +++ b/arch/arm/dts/imxrt1020-evk.dts @@ -186,6 +186,10 @@ }; };
+&gpt1 { + status = "okay"; +}; + &usdhc1 { pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; pinctrl-0 = <&pinctrl_usdhc0>;
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020-evk.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/imxrt1020-evk.dts b/arch/arm/dts/imxrt1020-evk.dts index a471ff3838..b527206fcf 100644 --- a/arch/arm/dts/imxrt1020-evk.dts +++ b/arch/arm/dts/imxrt1020-evk.dts @@ -16,6 +16,7 @@ chosen { bootargs = "root=/dev/ram"; stdout-path = "serial0:115200n8"; + tick-timer = &gpt1; };
memory {
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi index d32c98de9c..34d19e06c5 100644 --- a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi @@ -10,6 +10,10 @@ }; };
+&gpt1 { + u-boot,dm-spl; +}; + &lpuart1 { /* console */ u-boot,dm-spl; };
Now device_type = "memory" is mandatory to allow u-boot to read memory node, so let's add it to memory node.
diff --git a/arch/arm/dts/imxrt1020-evk.dts b/arch/arm/dts/imxrt1020-evk.dts index b527206fcf..2da79e5c20 100644 --- a/arch/arm/dts/imxrt1020-evk.dts +++ b/arch/arm/dts/imxrt1020-evk.dts @@ -20,6 +20,7 @@ };
memory { + device_type = "memory"; reg = <0x80000000 0x2000000>; }; };
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- configs/imxrt1020-evk_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/imxrt1020-evk_defconfig b/configs/imxrt1020-evk_defconfig index 9bddb69cd4..51ff702bc6 100644 --- a/configs/imxrt1020-evk_defconfig +++ b/configs/imxrt1020-evk_defconfig @@ -62,6 +62,7 @@ CONFIG_IMXRT_SDRAM=y CONFIG_FSL_LPUART=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y +CONFIG_IMX_GPT_TIMER=y CONFIG_SHA1=y CONFIG_SHA256=y CONFIG_HEXDUMP=y
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index a9281001e5..b7cc3fbc2a 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -28,7 +28,7 @@ clocks { u-boot,dm-spl;
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index b7cc3fbc2a..6f9da3fe8a 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -154,5 +154,13 @@ clock-names = "per"; status = "disabled"; }; + + gpt1: gpt1@401ec000 { + compatible = "fsl,imxrt-gpt"; + reg = <0x401ec000 0x4000>; + interrupts = <100>; + clocks = <&osc>; + status = "disabled"; + }; }; };
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050-evk.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts index b5e781275e..e592330332 100644 --- a/arch/arm/dts/imxrt1050-evk.dts +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -215,6 +215,10 @@ }; };
--- V1->V2: * fixed 32 to 64 bit conversion on timer as suggested by Sean Anderson ---
This timer driver uses GPT Timer (General Purpose Timer) available on a lot of i.MX SoCs family. This driver deals with both 24Mhz oscillator as well as peripheral clock.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com [Giulio: added the driver's stub and handled peripheral clock prescaler setting] Signed-off-by: Jesse Taube mr.bossman075@gmail.com [Jesse: added init, setting prescaler for 24Mhz support and enabling timer] --- V1->V2: * fixed 32 to 64 bit conversion on timer as suggested by Sean Anderson by using timer_conv_64() in imx_gpt_timer_get_count() --- drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/imx-gpt-timer.c | 162 ++++++++++++++++++++++++++++++++++ 3 files changed, 170 insertions(+) create mode 100644 drivers/timer/imx-gpt-timer.c
+config IMX_GPT_TIMER + bool "NXP i.MX GPT timer support" + depends on TIMER + help + Select this to enable support for the timer found on + NXP i.MX devices. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index eb5c48cc6c..e214ba7268 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -25,3 +25,4 @@ obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o obj-$(CONFIG_MCHP_PIT64B_TIMER) += mchp-pit64b-timer.o +obj-$(CONFIG_IMX_GPT_TIMER) += imx-gpt-timer.o diff --git a/drivers/timer/imx-gpt-timer.c b/drivers/timer/imx-gpt-timer.c new file mode 100644 index 0000000000..72be297754 --- /dev/null +++ b/drivers/timer/imx-gpt-timer.c @@ -0,0 +1,162 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <fdtdec.h> +#include <timer.h> +#include <dm/device_compat.h> + +#include <asm/io.h> + +#define GPT_CR_EN BIT(0) +#define GPT_CR_FRR BIT(9) +#define GPT_CR_EN_24M BIT(10) +#define GPT_CR_SWR BIT(15) + +#define GPT_PR_PRESCALER24M_MASK 0x0000F000 +#define GPT_PR_PRESCALER24M_SHIFT 12 +#define GPT_PR_PRESCALER24M_MAX (GPT_PR_PRESCALER24M_MASK >> GPT_PR_PRESCALER24M_SHIFT) +#define GPT_PR_PRESCALER_MASK 0x00000FFF +#define GPT_PR_PRESCALER_SHIFT 0 +#define GPT_PR_PRESCALER_MAX (GPT_PR_PRESCALER_MASK >> GPT_PR_PRESCALER_SHIFT) + +#define GPT_CLKSRC_IPG_CLK (1 << 6) +#define GPT_CLKSRC_IPG_CLK_24M (5 << 6) + +/* If CONFIG_SYS_HZ_CLOCK not specified et's default to 3Mhz */ +#ifndef CONFIG_SYS_HZ_CLOCK +#define CONFIG_SYS_HZ_CLOCK 3000000 +#endif + +struct imx_gpt_timer_regs { + u32 cr; + u32 pr; + u32 sr; + u32 ir; + u32 ocr1; + u32 ocr2; + u32 ocr3; + u32 icr1; + u32 icr2; + u32 cnt; +}; + +struct imx_gpt_timer_priv { + struct imx_gpt_timer_regs *base; +}; + +static u64 imx_gpt_timer_get_count(struct udevice *dev) +{ + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs = priv->base; + + return timer_conv_64(readl(®s->cnt)); +} + +static int imx_gpt_setup(struct imx_gpt_timer_regs *regs, u32 rate) +{ + u32 prescaler = (rate / CONFIG_SYS_HZ_CLOCK) - 1; + + /* Reset the timer */ + setbits_le32(®s->cr, GPT_CR_SWR); + + /* Wait for timer to finish reset */ + while (readl(®s->cr) & GPT_CR_SWR) + ; + + if (rate == 24000000UL) { + /* Set timer frequency if using 24M clock source */ + if (prescaler > GPT_PR_PRESCALER24M_MAX) + return -EINVAL; + + /* Set 24M prescaler */ + writel((prescaler << GPT_PR_PRESCALER24M_SHIFT), ®s->pr); + /* Set Oscillator as clock source, enable 24M input and set gpt + * in free-running mode + */ + writel(GPT_CLKSRC_IPG_CLK_24M | GPT_CR_EN_24M | GPT_CR_FRR, ®s->cr); + } else { + if (prescaler > GPT_PR_PRESCALER_MAX) + return -EINVAL; + + /* Set prescaler */ + writel((prescaler << GPT_PR_PRESCALER_SHIFT), ®s->pr); + /* Set Peripheral as clock source and set gpt in free-running + * mode + */ + writel(GPT_CLKSRC_IPG_CLK | GPT_CR_FRR, ®s->cr); + } + + /* Start timer */ + setbits_le32(®s->cr, GPT_CR_EN); + + return 0; +} + +static int imx_gpt_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs; + struct clk clk; + fdt_addr_t addr; + u32 clk_rate; + int ret; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = (struct imx_gpt_timer_regs *)addr; + regs = priv->base; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + if (ret) { + dev_err(dev, "Failed to enable clock\n"); + return ret; + } + + /* Get timer clock rate */ + clk_rate = clk_get_rate(&clk); + if (clk_rate <= 0) { + dev_err(dev, "Could not get clock rate...\n"); + return -EINVAL; + } + + ret = imx_gpt_setup(regs, clk_rate); + if (ret) { + dev_err(dev, "Could not setup timer\n"); + return ret; + } + + uc_priv->clock_rate = CONFIG_SYS_HZ_CLOCK; + + return 0; +} + +static const struct timer_ops imx_gpt_timer_ops = { + .get_count = imx_gpt_timer_get_count, +}; + +static const struct udevice_id imx_gpt_timer_ids[] = { + { .compatible = "fsl,imxrt-gpt" }, + {} +}; + +U_BOOT_DRIVER(imx_gpt_timer) = { + .name = "imx_gpt_timer", + .id = UCLASS_TIMER, + .of_match = imx_gpt_timer_ids, + .priv_auto = sizeof(struct imx_gpt_timer_priv), + .probe = imx_gpt_timer_probe, + .ops = &imx_gpt_timer_ops, +};
memory {
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050-evk.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts index e592330332..6d21f2b738 100644 --- a/arch/arm/dts/imxrt1050-evk.dts +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -16,6 +16,7 @@ chosen { bootargs = "root=/dev/ram"; stdout-path = "serial0:115200n8"; + tick-timer = &gpt1; };
memory {
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi index fb4f7f6f9d..a4b50f0bb2 100644 --- a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi @@ -10,6 +10,10 @@ }; };
diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts index 6d21f2b738..2052d4eb4e 100644 --- a/arch/arm/dts/imxrt1050-evk.dts +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -20,6 +20,7 @@ };
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- configs/imxrt1050-evk_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index f639ea7623..e74473511d 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -65,6 +65,7 @@ CONFIG_IMXRT_SDRAM=y CONFIG_FSL_LPUART=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y +CONFIG_IMX_GPT_TIMER=y CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT_GPIO=y CONFIG_SYS_WHITE_ON_BLACK=y
Fabio Estevam
Giulio Benetti
Jesse T
Sean Anderson
