[PATCH v3 0/6] arm64: meson: add libretech-pc support
Add libretech PC platform support. This platform comes in 2 variants, one with the s905d and the other s912.
While working on these boards, I've found a problem related the mmc clock. In some cases, the ROM code will leave the mmc clocks in such a weird state that any access to the mmc controller would lock the device.
Making sure the MMC clocks are properly reset and enabled is enough to solve the problem.
I have also synced all amlogic supported dts. Since I had to update the gx dsti files, it made sense to update the dts as well. This is done to keep things coherent even if it is not the original purpose of this series.
Changes since v2: - actually rebase on master
Changes since v1: - Split dt sync, libretech-pc import and config addition. - Rebase on master (... not really)
Jerome Brunet (6): dt-bindings: leds: import common led bindings from linux v5.5 mmc: meson-gx: enable input clocks clk: meson: reset mmc clock on probe arm64: dts: meson: sync dt and bindings from v5.6-rc2 arm64: dts: meson: import libretech-pc from linux v5.6-rc2 arm64: dts: meson: add libretech-pc support
arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-axg-s400.dts | 70 ++- arch/arm/dts/meson-axg.dtsi | 273 ++++++++-- arch/arm/dts/meson-g12-common.dtsi | 478 ++++++------------ arch/arm/dts/meson-g12.dtsi | 398 +++++++++++++++ arch/arm/dts/meson-g12a-sei510.dts | 64 +++ arch/arm/dts/meson-g12a-u200.dts | 54 ++ arch/arm/dts/meson-g12a.dtsi | 33 +- arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 25 + arch/arm/dts/meson-g12b-odroid-n2.dts | 2 +- arch/arm/dts/meson-g12b.dtsi | 26 +- arch/arm/dts/meson-gx-libretech-pc.dtsi | 375 ++++++++++++++ arch/arm/dts/meson-gx.dtsi | 87 +++- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 26 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 100 +++- arch/arm/dts/meson-gxbb-p200.dts | 9 +- arch/arm/dts/meson-gxbb-p201.dts | 2 +- arch/arm/dts/meson-gxbb-p20x.dtsi | 9 +- arch/arm/dts/meson-gxbb.dtsi | 118 ++++- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- .../meson-gxl-s905d-libretech-pc-u-boot.dtsi | 7 + arch/arm/dts/meson-gxl-s905d-libretech-pc.dts | 16 + arch/arm/dts/meson-gxl-s905d.dtsi | 12 + arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 20 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 26 +- arch/arm/dts/meson-gxl-s905x-p212.dtsi | 10 +- arch/arm/dts/meson-gxl.dtsi | 76 ++- arch/arm/dts/meson-gxm-khadas-vim2.dts | 71 +-- .../meson-gxm-s912-libretech-pc-u-boot.dtsi | 7 + arch/arm/dts/meson-gxm-s912-libretech-pc.dts | 62 +++ arch/arm/dts/meson-gxm.dtsi | 39 +- arch/arm/dts/meson-khadas-vim3.dtsi | 7 + arch/arm/dts/meson-sm1-sei610.dts | 236 ++++++++- arch/arm/dts/meson-sm1.dtsi | 356 +++++++++++++ configs/libretech-s905d-pc_defconfig | 73 +++ configs/libretech-s912-pc_defconfig | 73 +++ drivers/clk/meson/axg.c | 7 + drivers/clk/meson/g12a.c | 7 + drivers/clk/meson/gxbb.c | 7 + drivers/mmc/meson_gx_mmc.c | 14 +- include/dt-bindings/clock/axg-audio-clkc.h | 10 + include/dt-bindings/clock/gxbb-aoclkc.h | 7 + include/dt-bindings/clock/gxbb-clkc.h | 21 + include/dt-bindings/gpio/meson-gxbb-gpio.h | 8 +- include/dt-bindings/gpio/meson-gxl-gpio.h | 8 +- include/dt-bindings/leds/common.h | 75 +++ .../reset/amlogic,meson-axg-audio-arb.h | 2 + .../reset/amlogic,meson-axg-reset.h | 3 +- .../reset/amlogic,meson-g12a-audio-reset.h | 15 + .../reset/amlogic,meson-gxbb-reset.h | 51 +- 50 files changed, 2855 insertions(+), 624 deletions(-) create mode 100644 arch/arm/dts/meson-g12.dtsi create mode 100644 arch/arm/dts/meson-gx-libretech-pc.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc.dts create mode 100644 arch/arm/dts/meson-gxl-s905d.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc.dts create mode 100644 configs/libretech-s905d-pc_defconfig create mode 100644 configs/libretech-s912-pc_defconfig create mode 100644 include/dt-bindings/leds/common.h
Import the common leds bindings definition from linux d5226fa6dbae ("Linux 5.5")
Reviewed-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- include/dt-bindings/leds/common.h | 75 +++++++++++++++++++++++++++++++ 1 file changed, 75 insertions(+) create mode 100644 include/dt-bindings/leds/common.h
diff --git a/include/dt-bindings/leds/common.h b/include/dt-bindings/leds/common.h new file mode 100644 index 000000000000..9e1256a7c1bf --- /dev/null +++ b/include/dt-bindings/leds/common.h @@ -0,0 +1,75 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides macros for the common LEDs device tree bindings. + * + * Copyright (C) 2015, Samsung Electronics Co., Ltd. + * Author: Jacek Anaszewski j.anaszewski@samsung.com + * + * Copyright (C) 2019 Jacek Anaszewski jacek.anaszewski@gmail.com + */ + +#ifndef __DT_BINDINGS_LEDS_H +#define __DT_BINDINGS_LEDS_H + +/* External trigger type */ +#define LEDS_TRIG_TYPE_EDGE 0 +#define LEDS_TRIG_TYPE_LEVEL 1 + +/* Boost modes */ +#define LEDS_BOOST_OFF 0 +#define LEDS_BOOST_ADAPTIVE 1 +#define LEDS_BOOST_FIXED 2 + +/* Standard LED colors */ +#define LED_COLOR_ID_WHITE 0 +#define LED_COLOR_ID_RED 1 +#define LED_COLOR_ID_GREEN 2 +#define LED_COLOR_ID_BLUE 3 +#define LED_COLOR_ID_AMBER 4 +#define LED_COLOR_ID_VIOLET 5 +#define LED_COLOR_ID_YELLOW 6 +#define LED_COLOR_ID_IR 7 +#define LED_COLOR_ID_MAX 8 + +/* Standard LED functions */ +#define LED_FUNCTION_ACTIVITY "activity" +#define LED_FUNCTION_ALARM "alarm" +#define LED_FUNCTION_BACKLIGHT "backlight" +#define LED_FUNCTION_BLUETOOTH "bluetooth" +#define LED_FUNCTION_BOOT "boot" +#define LED_FUNCTION_CPU "cpu" +#define LED_FUNCTION_CAPSLOCK "capslock" +#define LED_FUNCTION_CHARGING "charging" +#define LED_FUNCTION_DEBUG "debug" +#define LED_FUNCTION_DISK "disk" +#define LED_FUNCTION_DISK_ACTIVITY "disk-activity" +#define LED_FUNCTION_DISK_ERR "disk-err" +#define LED_FUNCTION_DISK_READ "disk-read" +#define LED_FUNCTION_DISK_WRITE "disk-write" +#define LED_FUNCTION_FAULT "fault" +#define LED_FUNCTION_FLASH "flash" +#define LED_FUNCTION_HEARTBEAT "heartbeat" +#define LED_FUNCTION_INDICATOR "indicator" +#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" +#define LED_FUNCTION_LAN "lan" +#define LED_FUNCTION_MAIL "mail" +#define LED_FUNCTION_MTD "mtd" +#define LED_FUNCTION_MICMUTE "micmute" +#define LED_FUNCTION_MUTE "mute" +#define LED_FUNCTION_NUMLOCK "numlock" +#define LED_FUNCTION_PANIC "panic" +#define LED_FUNCTION_PROGRAMMING "programming" +#define LED_FUNCTION_POWER "power" +#define LED_FUNCTION_RX "rx" +#define LED_FUNCTION_SD "sd" +#define LED_FUNCTION_SCROLLLOCK "scrolllock" +#define LED_FUNCTION_STANDBY "standby" +#define LED_FUNCTION_STATUS "status" +#define LED_FUNCTION_TORCH "torch" +#define LED_FUNCTION_TX "tx" +#define LED_FUNCTION_USB "usb" +#define LED_FUNCTION_WAN "wan" +#define LED_FUNCTION_WLAN "wlan" +#define LED_FUNCTION_WPS "wps" + +#endif /* __DT_BINDINGS_LEDS_H */
Until now, the mmc clock was left in a good enough state by the ROM code to be used by the controller. However on some SoC, if the ROM code finds a bootloader on USB or SPI, it might leave the MMC clock in state the controller cannot work with.
Enable the input clocks provided to the mmc controller. While the u-boot mmc controller driver is not doing fancy settings like the Linux, it at least needs to make these clocks are running.
Reviewed-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- drivers/mmc/meson_gx_mmc.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/meson_gx_mmc.c b/drivers/mmc/meson_gx_mmc.c index b5f5122b1b7b..86c1a7164a93 100644 --- a/drivers/mmc/meson_gx_mmc.c +++ b/drivers/mmc/meson_gx_mmc.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <clk.h> #include <cpu_func.h> #include <dm.h> #include <fdtdec.h> @@ -241,12 +242,23 @@ static int meson_mmc_probe(struct udevice *dev) struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct mmc *mmc = &pdata->mmc; struct mmc_config *cfg = &pdata->cfg; + struct clk_bulk clocks; uint32_t val; + int ret; + #ifdef CONFIG_PWRSEQ struct udevice *pwr_dev; - int ret; #endif
+ /* Enable the clocks feeding the MMC controller */ + ret = clk_get_bulk(dev, &clocks); + if (ret) + return ret; + + ret = clk_enable_bulk(&clocks); + if (ret) + return ret; + cfg->voltages = MMC_VDD_33_34 | MMC_VDD_32_33 | MMC_VDD_31_32 | MMC_VDD_165_195; cfg->host_caps = MMC_MODE_8BIT | MMC_MODE_4BIT |
Hi Jerome,
Please add my Reviewed-by: Anand Moon linux.amoon@gmail.com
-Anand
int ret;
int ret;
#endif
if (ret)
return ret;
if (ret)
return ret;
-- 2.24.1
On some SoCs, depending on the boot device, the MMC clock block may be left in a weird state by the ROM code, in which no decent clock may be provided. Reset the related register to make sure a sane MMC clock is ready for the controller.
Reviewed-by: Neil Armstrong narmstrong@baylibre.com Tested-by: Anand Moon linux.amoon@gmail.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- drivers/clk/meson/axg.c | 7 +++++++ drivers/clk/meson/g12a.c | 7 +++++++ drivers/clk/meson/gxbb.c | 7 +++++++ 3 files changed, 21 insertions(+)
diff --git a/drivers/clk/meson/axg.c b/drivers/clk/meson/axg.c index 7035b59a1379..4b0028d04bf6 100644 --- a/drivers/clk/meson/axg.c +++ b/drivers/clk/meson/axg.c @@ -291,6 +291,13 @@ static int meson_clk_probe(struct udevice *dev) if (IS_ERR(priv->map)) return PTR_ERR(priv->map);
+ /* + * Depending on the boot src, the state of the MMC clock might + * be different. Reset it to make sure we won't get stuck + */ + regmap_write(priv->map, HHI_NAND_CLK_CNTL, 0); + regmap_write(priv->map, HHI_SD_EMMC_CLK_CNTL, 0); + debug("meson-clk-axg: probed\n");
return 0; diff --git a/drivers/clk/meson/g12a.c b/drivers/clk/meson/g12a.c index 686d94ebfe85..9e6beca94ac3 100644 --- a/drivers/clk/meson/g12a.c +++ b/drivers/clk/meson/g12a.c @@ -977,6 +977,13 @@ static int meson_clk_probe(struct udevice *dev) if (IS_ERR(priv->map)) return PTR_ERR(priv->map);
+ /* + * Depending on the boot src, the state of the MMC clock might + * be different. Reset it to make sure we won't get stuck + */ + regmap_write(priv->map, HHI_NAND_CLK_CNTL, 0); + regmap_write(priv->map, HHI_SD_EMMC_CLK_CNTL, 0); + debug("meson-clk-g12a: probed\n");
return 0; diff --git a/drivers/clk/meson/gxbb.c b/drivers/clk/meson/gxbb.c index e781e08d9d5d..5ef4dd794d52 100644 --- a/drivers/clk/meson/gxbb.c +++ b/drivers/clk/meson/gxbb.c @@ -887,6 +887,13 @@ static int meson_clk_probe(struct udevice *dev) if (IS_ERR(priv->map)) return PTR_ERR(priv->map);
+ /* + * Depending on the boot src, the state of the MMC clock might + * be different. Reset it to make sure we won't get stuck + */ + regmap_write(priv->map, HHI_NAND_CLK_CNTL, 0); + regmap_write(priv->map, HHI_SD_EMMC_CLK_CNTL, 0); + debug("meson-clk: probed\n");
Sync the device tree and dt-bindings from Linux v5.6-rc2 11a48a5a18c6 ("Linux 5.6-rc2")
The only exception to this is the mmc pinctrl pin bias of gxl SoC family. This is a fix which found its way to u-boot but not Linux yet.
Acked-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- arch/arm/dts/meson-axg-s400.dts | 70 ++- arch/arm/dts/meson-axg.dtsi | 273 ++++++++-- arch/arm/dts/meson-g12-common.dtsi | 478 ++++++------------ arch/arm/dts/meson-g12.dtsi | 398 +++++++++++++++ arch/arm/dts/meson-g12a-sei510.dts | 64 +++ arch/arm/dts/meson-g12a-u200.dts | 54 ++ arch/arm/dts/meson-g12a.dtsi | 33 +- arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 25 + arch/arm/dts/meson-g12b-odroid-n2.dts | 2 +- arch/arm/dts/meson-g12b.dtsi | 26 +- arch/arm/dts/meson-gx.dtsi | 87 +++- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 26 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 100 +++- arch/arm/dts/meson-gxbb-p200.dts | 9 +- arch/arm/dts/meson-gxbb-p201.dts | 2 +- arch/arm/dts/meson-gxbb-p20x.dtsi | 9 +- arch/arm/dts/meson-gxbb.dtsi | 118 ++++- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 20 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 26 +- arch/arm/dts/meson-gxl-s905x-p212.dtsi | 10 +- arch/arm/dts/meson-gxl.dtsi | 76 ++- arch/arm/dts/meson-gxm-khadas-vim2.dts | 71 +-- arch/arm/dts/meson-gxm.dtsi | 39 +- arch/arm/dts/meson-khadas-vim3.dtsi | 7 + arch/arm/dts/meson-sm1-sei610.dts | 236 ++++++++- arch/arm/dts/meson-sm1.dtsi | 356 +++++++++++++ include/dt-bindings/clock/axg-audio-clkc.h | 10 + include/dt-bindings/clock/gxbb-aoclkc.h | 7 + include/dt-bindings/clock/gxbb-clkc.h | 21 + include/dt-bindings/gpio/meson-gxbb-gpio.h | 8 +- include/dt-bindings/gpio/meson-gxl-gpio.h | 8 +- .../reset/amlogic,meson-axg-audio-arb.h | 2 + .../reset/amlogic,meson-axg-reset.h | 3 +- .../reset/amlogic,meson-g12a-audio-reset.h | 15 + .../reset/amlogic,meson-gxbb-reset.h | 51 +- 36 files changed, 2119 insertions(+), 623 deletions(-) create mode 100644 arch/arm/dts/meson-g12.dtsi
diff --git a/arch/arm/dts/meson-axg-s400.dts b/arch/arm/dts/meson-axg-s400.dts index 18778ada7bd3..4cd2d5951822 100644 --- a/arch/arm/dts/meson-axg-s400.dts +++ b/arch/arm/dts/meson-axg-s400.dts @@ -60,7 +60,7 @@ serial1 = &uart_A; };
- linein: audio-codec@0 { + linein: audio-codec-0 { #sound-dai-cells = <0>; compatible = "everest,es7241"; VDDA-supply = <&vcc_3v3>; @@ -70,7 +70,7 @@ sound-name-prefix = "Linein"; };
- lineout: audio-codec@1 { + lineout: audio-codec-1 { #sound-dai-cells = <0>; compatible = "everest,es7154"; VDD-supply = <&vcc_3v3>; @@ -79,14 +79,14 @@ sound-name-prefix = "Lineout"; };
- spdif_dit: audio-codec@2 { + spdif_dit: audio-codec-2 { #sound-dai-cells = <0>; compatible = "linux,spdif-dit"; status = "okay"; sound-name-prefix = "DIT"; };
- dmics: audio-codec@3 { + dmics: audio-codec-3 { #sound-dai-cells = <0>; compatible = "dmic-codec"; num-channels = <7>; @@ -95,6 +95,13 @@ sound-name-prefix = "MIC"; };
+ spdif_dir: audio-codec-4 { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dir"; + status = "okay"; + sound-name-prefix = "DIR"; + }; + emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; @@ -249,6 +256,9 @@ "TODDR_A IN 2", "TDMIN_C OUT", "TODDR_B IN 2", "TDMIN_C OUT", "TODDR_C IN 2", "TDMIN_C OUT", + "TODDR_A IN 3", "SPDIFIN Capture", + "TODDR_B IN 3", "SPDIFIN Capture", + "TODDR_C IN 3", "SPDIFIN Capture", "TODDR_A IN 4", "PDM Capture", "TODDR_B IN 4", "PDM Capture", "TODDR_C IN 4", "PDM Capture", @@ -272,31 +282,31 @@ <393216000>; status = "okay";
- dai-link@0 { + dai-link-0 { sound-dai = <&frddr_a>; };
- dai-link@1 { + dai-link-1 { sound-dai = <&frddr_b>; };
- dai-link@2 { + dai-link-2 { sound-dai = <&frddr_c>; };
- dai-link@3 { + dai-link-3 { sound-dai = <&toddr_a>; };
- dai-link@4 { + dai-link-4 { sound-dai = <&toddr_b>; };
- dai-link@5 { + dai-link-5 { sound-dai = <&toddr_c>; };
- dai-link@6 { + dai-link-6 { sound-dai = <&tdmif_c>; dai-format = "i2s"; dai-tdm-slot-tx-mask-2 = <1 1>; @@ -317,7 +327,7 @@
- dai-link@7 { + dai-link-7 { sound-dai = <&spdifout>;
codec { @@ -325,7 +335,15 @@ }; };
- dai-link@8 { + dai-link-8 { + sound-dai = <&spdifin>; + + codec { + sound-dai = <&spdif_dir>; + }; + }; + + dai-link-9 { sound-dai = <&pdm>;
codec { @@ -357,6 +375,8 @@ eth_phy0: ethernet-phy@0 { /* Realtek RTL8211F (0x001cc916) */ reg = <0>; + interrupt-parent = <&gpio_intc>; + interrupts = <98 IRQ_TYPE_LEVEL_LOW>; eee-broken-1000t; }; }; @@ -444,7 +464,8 @@
bus-width = <4>; cap-sd-highspeed; - max-frequency = <100000000>; + sd-uhs-sdr104; + max-frequency = <200000000>; non-removable; disable-wp;
@@ -461,15 +482,14 @@
/* emmc storage */ &sd_emmc_c { - status = "disabled"; - pinctrl-0 = <&emmc_pins>; + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; pinctrl-1 = <&emmc_clk_gate_pins>; pinctrl-names = "default", "clk-gate";
bus-width = <8>; - cap-sd-highspeed; cap-mmc-highspeed; - max-frequency = <180000000>; + max-frequency = <200000000>; non-removable; disable-wp; mmc-ddr-1_8v; @@ -481,6 +501,12 @@ vqmmc-supply = <&vddio_boot>; };
+&spdifin { + pinctrl-0 = <&spdif_in_a19_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + &spdifout { pinctrl-0 = <&spdif_out_a20_pins>; pinctrl-names = "default"; @@ -543,8 +569,14 @@
&uart_A { status = "okay"; - pinctrl-0 = <&uart_a_pins>; + pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; pinctrl-names = "default"; + uart-has-rtscts; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio GPIOX_21 GPIO_ACTIVE_HIGH>; + }; };
&uart_AO { diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index df017dbd2e57..aace3d32a3df 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -20,7 +20,7 @@ #address-cells = <2>; #size-cells = <2>;
- tdmif_a: audio-controller@0 { + tdmif_a: audio-controller-0 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = <0>; sound-name-prefix = "TDM_A"; @@ -31,7 +31,7 @@ status = "disabled"; };
- tdmif_b: audio-controller@1 { + tdmif_b: audio-controller-1 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = <0>; sound-name-prefix = "TDM_B"; @@ -42,7 +42,7 @@ status = "disabled"; };
- tdmif_c: audio-controller@2 { + tdmif_c: audio-controller-2 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = <0>; sound-name-prefix = "TDM_C"; @@ -53,13 +53,6 @@ status = "disabled"; };
- ao_alt_xtal: ao_alt_xtal-clk { - compatible = "fixed-clock"; - clock-frequency = <32000000>; - clock-output-names = "ao_alt_xtal"; - #clock-cells = <0>; - }; - arm-pmu { compatible = "arm,cortex-a53-pmu"; interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, @@ -75,34 +68,38 @@
cpu0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x0>; enable-method = "psci"; next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; };
cpu1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x1>; enable-method = "psci"; next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; };
cpu2: cpu@2 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x2>; enable-method = "psci"; next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; };
cpu3: cpu@3 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x3>; enable-method = "psci"; next-level-cache = <&l2>; + clocks = <&scpi_dvfs 0>; };
l2: l2-cache0 { @@ -110,6 +107,19 @@ }; };
+ sm: secure-monitor { + compatible = "amlogic,meson-gxbb-sm"; + }; + + efuse: efuse { + compatible = "amlogic,meson-gxbb-efuse"; + clocks = <&clkc CLKID_EFUSE>; + #address-cells = <1>; + #size-cells = <1>; + read-only; + secure-monitor = <&sm>; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; @@ -133,6 +143,28 @@ }; };
+ scpi { + compatible = "arm,scpi-pre-1.0"; + mboxes = <&mailbox 1 &mailbox 2>; + shmem = <&cpu_scp_lpri &cpu_scp_hpri>; + + scpi_clocks: clocks { + compatible = "arm,scpi-clocks"; + + scpi_dvfs: clock-controller { + compatible = "arm,scpi-dvfs-clocks"; + #clock-cells = <1>; + clock-indices = <0>; + clock-output-names = "vcpu"; + }; + }; + + scpi_sensors: sensors { + compatible = "amlogic,meson-gxbb-scpi-sensors"; + #thermal-sensor-cells = <1>; + }; + }; + soc { compatible = "simple-bus"; #address-cells = <2>; @@ -140,15 +172,19 @@ ranges;
ethmac: ethernet@ff3f0000 { - compatible = "amlogic,meson-axg-dwmac", "snps,dwmac"; - reg = <0x0 0xff3f0000 0x0 0x10000 - 0x0 0xff634540 0x0 0x8>; - interrupts = <GIC_SPI 8 IRQ_TYPE_EDGE_RISING>; + compatible = "amlogic,meson-axg-dwmac", + "snps,dwmac-3.70a", + "snps,dwmac"; + reg = <0x0 0xff3f0000 0x0 0x10000>, + <0x0 0xff634540 0x0 0x8>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq"; clocks = <&clkc CLKID_ETH>, <&clkc CLKID_FCLK_DIV2>, <&clkc CLKID_MPLL2>; clock-names = "stmmaceth", "clkin0", "clkin1"; + rx-fifo-depth = <4096>; + tx-fifo-depth = <2048>; status = "disabled"; };
@@ -200,6 +236,7 @@ groups = "i2c0_sck", "i2c0_sda"; function = "i2c0"; + bias-disable; }; };
@@ -208,6 +245,7 @@ groups = "i2c1_sck_x", "i2c1_sda_x"; function = "i2c1"; + bias-disable; }; };
@@ -216,6 +254,7 @@ groups = "i2c1_sck_z", "i2c1_sda_z"; function = "i2c1"; + bias-disable; }; };
@@ -224,6 +263,7 @@ groups = "i2c2_sck_a", "i2c2_sda_a"; function = "i2c2"; + bias-disable; }; };
@@ -232,6 +272,7 @@ groups = "i2c2_sck_x", "i2c2_sda_x"; function = "i2c2"; + bias-disable; }; };
@@ -240,6 +281,7 @@ groups = "i2c3_sda_a6", "i2c3_sck_a7"; function = "i2c3"; + bias-disable; }; };
@@ -248,6 +290,7 @@ groups = "i2c3_sda_a12", "i2c3_sck_a13"; function = "i2c3"; + bias-disable; }; };
@@ -256,11 +299,12 @@ groups = "i2c3_sda_a19", "i2c3_sck_a20"; function = "i2c3"; + bias-disable; }; };
emmc_pins: emmc { - mux { + mux-0 { groups = "emmc_nand_d0", "emmc_nand_d1", "emmc_nand_d2", @@ -269,10 +313,23 @@ "emmc_nand_d5", "emmc_nand_d6", "emmc_nand_d7", - "emmc_clk", - "emmc_cmd", - "emmc_ds"; + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + }; + + mux-1 { + groups = "emmc_clk"; function = "emmc"; + bias-disable; + }; + }; + + emmc_ds_pins: emmc_ds { + mux { + groups = "emmc_ds"; + function = "emmc"; + bias-pull-down; }; };
@@ -280,9 +337,6 @@ mux { groups = "BOOT_8"; function = "gpio_periphs"; - }; - cfg-pull-down { - pins = "BOOT_8"; bias-pull-down; }; }; @@ -304,6 +358,7 @@ "eth_txd2_rgmii", "eth_txd3_rgmii"; function = "eth"; + bias-disable; }; };
@@ -324,6 +379,7 @@ "eth_txd2_rgmii", "eth_txd3_rgmii"; function = "eth"; + bias-disable; }; };
@@ -339,6 +395,7 @@ "eth_txd0_x", "eth_txd1_x"; function = "eth"; + bias-disable; }; };
@@ -354,6 +411,7 @@ "eth_txd0_y", "eth_txd1_y"; function = "eth"; + bias-disable; }; };
@@ -361,6 +419,7 @@ mux { groups = "mclk_b"; function = "mclk_b"; + bias-disable; }; };
@@ -368,6 +427,7 @@ mux { groups = "mclk_c"; function = "mclk_c"; + bias-disable; }; };
@@ -375,6 +435,7 @@ mux { groups = "pdm_dclk_a14"; function = "pdm"; + bias-disable; }; };
@@ -382,6 +443,7 @@ mux { groups = "pdm_dclk_a19"; function = "pdm"; + bias-disable; }; };
@@ -389,6 +451,7 @@ mux { groups = "pdm_din0"; function = "pdm"; + bias-disable; }; };
@@ -396,6 +459,7 @@ mux { groups = "pdm_din1"; function = "pdm"; + bias-disable; }; };
@@ -403,6 +467,7 @@ mux { groups = "pdm_din2"; function = "pdm"; + bias-disable; }; };
@@ -410,6 +475,7 @@ mux { groups = "pdm_din3"; function = "pdm"; + bias-disable; }; };
@@ -417,6 +483,7 @@ mux { groups = "pwm_a_a"; function = "pwm_a"; + bias-disable; }; };
@@ -424,6 +491,7 @@ mux { groups = "pwm_a_x18"; function = "pwm_a"; + bias-disable; }; };
@@ -431,6 +499,7 @@ mux { groups = "pwm_a_x20"; function = "pwm_a"; + bias-disable; }; };
@@ -438,6 +507,7 @@ mux { groups = "pwm_a_z"; function = "pwm_a"; + bias-disable; }; };
@@ -445,6 +515,7 @@ mux { groups = "pwm_b_a"; function = "pwm_b"; + bias-disable; }; };
@@ -452,6 +523,7 @@ mux { groups = "pwm_b_x"; function = "pwm_b"; + bias-disable; }; };
@@ -459,6 +531,7 @@ mux { groups = "pwm_b_z"; function = "pwm_b"; + bias-disable; }; };
@@ -466,6 +539,7 @@ mux { groups = "pwm_c_a"; function = "pwm_c"; + bias-disable; }; };
@@ -473,6 +547,7 @@ mux { groups = "pwm_c_x10"; function = "pwm_c"; + bias-disable; }; };
@@ -480,6 +555,7 @@ mux { groups = "pwm_c_x17"; function = "pwm_c"; + bias-disable; }; };
@@ -487,6 +563,7 @@ mux { groups = "pwm_d_x11"; function = "pwm_d"; + bias-disable; }; };
@@ -494,18 +571,25 @@ mux { groups = "pwm_d_x16"; function = "pwm_d"; + bias-disable; }; };
sdio_pins: sdio { - mux { + mux-0 { groups = "sdio_d0", "sdio_d1", "sdio_d2", "sdio_d3", - "sdio_cmd", - "sdio_clk"; + "sdio_cmd"; + function = "sdio"; + bias-pull-up; + }; + + mux-1 { + groups = "sdio_clk"; function = "sdio"; + bias-disable; }; };
@@ -513,9 +597,6 @@ mux { groups = "GPIOX_4"; function = "gpio_periphs"; - }; - cfg-pull-down { - pins = "GPIOX_4"; bias-pull-down; }; }; @@ -524,6 +605,7 @@ mux { groups = "spdif_in_z"; function = "spdif_in"; + bias-disable; }; };
@@ -531,6 +613,7 @@ mux { groups = "spdif_in_a1"; function = "spdif_in"; + bias-disable; }; };
@@ -538,6 +621,7 @@ mux { groups = "spdif_in_a7"; function = "spdif_in"; + bias-disable; }; };
@@ -545,6 +629,7 @@ mux { groups = "spdif_in_a19"; function = "spdif_in"; + bias-disable; }; };
@@ -552,6 +637,7 @@ mux { groups = "spdif_in_a20"; function = "spdif_in"; + bias-disable; }; };
@@ -559,6 +645,7 @@ mux { groups = "spdif_out_a1"; function = "spdif_out"; + bias-disable; }; };
@@ -566,6 +653,7 @@ mux { groups = "spdif_out_a11"; function = "spdif_out"; + bias-disable; }; };
@@ -573,6 +661,7 @@ mux { groups = "spdif_out_a19"; function = "spdif_out"; + bias-disable; }; };
@@ -580,6 +669,7 @@ mux { groups = "spdif_out_a20"; function = "spdif_out"; + bias-disable; }; };
@@ -587,6 +677,7 @@ mux { groups = "spdif_out_z"; function = "spdif_out"; + bias-disable; }; };
@@ -596,6 +687,7 @@ "spi0_mosi", "spi0_clk"; function = "spi0"; + bias-disable; }; };
@@ -603,6 +695,7 @@ mux { groups = "spi0_ss0"; function = "spi0"; + bias-disable; }; };
@@ -610,6 +703,7 @@ mux { groups = "spi0_ss1"; function = "spi0"; + bias-disable; }; };
@@ -617,6 +711,7 @@ mux { groups = "spi0_ss2"; function = "spi0"; + bias-disable; }; };
@@ -626,6 +721,7 @@ "spi1_mosi_a", "spi1_clk_a"; function = "spi1"; + bias-disable; }; };
@@ -633,6 +729,7 @@ mux { groups = "spi1_ss0_a"; function = "spi1"; + bias-disable; }; };
@@ -640,6 +737,7 @@ mux { groups = "spi1_ss1"; function = "spi1"; + bias-disable; }; };
@@ -649,6 +747,7 @@ "spi1_mosi_x", "spi1_clk_x"; function = "spi1"; + bias-disable; }; };
@@ -656,6 +755,7 @@ mux { groups = "spi1_ss0_x"; function = "spi1"; + bias-disable; }; };
@@ -663,6 +763,7 @@ mux { groups = "tdma_din0"; function = "tdma"; + bias-disable; }; };
@@ -670,6 +771,7 @@ mux { groups = "tdma_dout0_x14"; function = "tdma"; + bias-disable; }; };
@@ -677,6 +779,7 @@ mux { groups = "tdma_dout0_x15"; function = "tdma"; + bias-disable; }; };
@@ -684,6 +787,7 @@ mux { groups = "tdma_dout1"; function = "tdma"; + bias-disable; }; };
@@ -691,6 +795,7 @@ mux { groups = "tdma_din1"; function = "tdma"; + bias-disable; }; };
@@ -698,6 +803,7 @@ mux { groups = "tdma_fs"; function = "tdma"; + bias-disable; }; };
@@ -705,6 +811,7 @@ mux { groups = "tdma_fs_slv"; function = "tdma"; + bias-disable; }; };
@@ -712,6 +819,7 @@ mux { groups = "tdma_sclk"; function = "tdma"; + bias-disable; }; };
@@ -719,6 +827,7 @@ mux { groups = "tdma_sclk_slv"; function = "tdma"; + bias-disable; }; };
@@ -726,6 +835,7 @@ mux { groups = "tdmb_din0"; function = "tdmb"; + bias-disable; }; };
@@ -733,6 +843,7 @@ mux { groups = "tdmb_din1"; function = "tdmb"; + bias-disable; }; };
@@ -740,6 +851,7 @@ mux { groups = "tdmb_din2"; function = "tdmb"; + bias-disable; }; };
@@ -747,6 +859,7 @@ mux { groups = "tdmb_din3"; function = "tdmb"; + bias-disable; }; };
@@ -754,6 +867,7 @@ mux { groups = "tdmb_dout0"; function = "tdmb"; + bias-disable; }; };
@@ -761,6 +875,7 @@ mux { groups = "tdmb_dout1"; function = "tdmb"; + bias-disable; }; };
@@ -768,6 +883,7 @@ mux { groups = "tdmb_dout2"; function = "tdmb"; + bias-disable; }; };
@@ -775,6 +891,7 @@ mux { groups = "tdmb_dout3"; function = "tdmb"; + bias-disable; }; };
@@ -782,6 +899,7 @@ mux { groups = "tdmb_fs"; function = "tdmb"; + bias-disable; }; };
@@ -789,6 +907,7 @@ mux { groups = "tdmb_fs_slv"; function = "tdmb"; + bias-disable; }; };
@@ -796,6 +915,7 @@ mux { groups = "tdmb_sclk"; function = "tdmb"; + bias-disable; }; };
@@ -803,6 +923,7 @@ mux { groups = "tdmb_sclk_slv"; function = "tdmb"; + bias-disable; }; };
@@ -810,6 +931,7 @@ mux { groups = "tdmc_fs"; function = "tdmc"; + bias-disable; }; };
@@ -817,6 +939,7 @@ mux { groups = "tdmc_fs_slv"; function = "tdmc"; + bias-disable; }; };
@@ -824,6 +947,7 @@ mux { groups = "tdmc_sclk"; function = "tdmc"; + bias-disable; }; };
@@ -831,6 +955,7 @@ mux { groups = "tdmc_sclk_slv"; function = "tdmc"; + bias-disable; }; };
@@ -838,6 +963,7 @@ mux { groups = "tdmc_din0"; function = "tdmc"; + bias-disable; }; };
@@ -845,6 +971,7 @@ mux { groups = "tdmc_din1"; function = "tdmc"; + bias-disable; }; };
@@ -852,6 +979,7 @@ mux { groups = "tdmc_din2"; function = "tdmc"; + bias-disable; }; };
@@ -859,6 +987,7 @@ mux { groups = "tdmc_din3"; function = "tdmc"; + bias-disable; }; };
@@ -866,6 +995,7 @@ mux { groups = "tdmc_dout0"; function = "tdmc"; + bias-disable; }; };
@@ -873,6 +1003,7 @@ mux { groups = "tdmc_dout1"; function = "tdmc"; + bias-disable; }; };
@@ -880,6 +1011,7 @@ mux { groups = "tdmc_dout2"; function = "tdmc"; + bias-disable; }; };
@@ -887,6 +1019,7 @@ mux { groups = "tdmc_dout3"; function = "tdmc"; + bias-disable; }; };
@@ -895,6 +1028,7 @@ groups = "uart_tx_a", "uart_rx_a"; function = "uart_a"; + bias-disable; }; };
@@ -903,6 +1037,7 @@ groups = "uart_cts_a", "uart_rts_a"; function = "uart_a"; + bias-disable; }; };
@@ -911,6 +1046,7 @@ groups = "uart_tx_b_x", "uart_rx_b_x"; function = "uart_b"; + bias-disable; }; };
@@ -919,6 +1055,7 @@ groups = "uart_cts_b_x", "uart_rts_b_x"; function = "uart_b"; + bias-disable; }; };
@@ -927,6 +1064,7 @@ groups = "uart_tx_b_z", "uart_rx_b_z"; function = "uart_b"; + bias-disable; }; };
@@ -935,6 +1073,7 @@ groups = "uart_cts_b_z", "uart_rts_b_z"; function = "uart_b"; + bias-disable; }; };
@@ -943,6 +1082,7 @@ groups = "uart_ao_tx_b_z", "uart_ao_rx_b_z"; function = "uart_ao_b_z"; + bias-disable; }; };
@@ -951,6 +1091,7 @@ groups = "uart_ao_cts_b_z", "uart_ao_rts_b_z"; function = "uart_ao_b_z"; + bias-disable; }; }; }; @@ -971,13 +1112,15 @@ clkc: clock-controller { compatible = "amlogic,axg-clkc"; #clock-cells = <1>; + clocks = <&xtal>; + clock-names = "xtal"; }; }; };
- mailbox: mailbox@ff63dc00 { - compatible = "amlogic,meson-gx-mhu", "amlogic,meson-gxbb-mhu"; - reg = <0 0xff63dc00 0 0x400>; + mailbox: mailbox@ff63c404 { + compatible = "amlogic,meson-gxbb-mhu"; + reg = <0 0xff63c404 0 0x4c>; interrupts = <GIC_SPI 208 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 209 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 210 IRQ_TYPE_EDGE_RISING>; @@ -1020,67 +1163,73 @@
toddr_a: audio-controller@100 { compatible = "amlogic,axg-toddr"; - reg = <0x0 0x100 0x0 0x1c>; + reg = <0x0 0x100 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "TODDR_A"; interrupts = <GIC_SPI 84 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_TODDR_A>; resets = <&arb AXG_ARB_TODDR_A>; + amlogic,fifo-depth = <512>; status = "disabled"; };
toddr_b: audio-controller@140 { compatible = "amlogic,axg-toddr"; - reg = <0x0 0x140 0x0 0x1c>; + reg = <0x0 0x140 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "TODDR_B"; interrupts = <GIC_SPI 85 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_TODDR_B>; resets = <&arb AXG_ARB_TODDR_B>; + amlogic,fifo-depth = <256>; status = "disabled"; };
toddr_c: audio-controller@180 { compatible = "amlogic,axg-toddr"; - reg = <0x0 0x180 0x0 0x1c>; + reg = <0x0 0x180 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "TODDR_C"; interrupts = <GIC_SPI 86 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_TODDR_C>; resets = <&arb AXG_ARB_TODDR_C>; + amlogic,fifo-depth = <256>; status = "disabled"; };
frddr_a: audio-controller@1c0 { compatible = "amlogic,axg-frddr"; - reg = <0x0 0x1c0 0x0 0x1c>; + reg = <0x0 0x1c0 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "FRDDR_A"; interrupts = <GIC_SPI 88 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; resets = <&arb AXG_ARB_FRDDR_A>; + amlogic,fifo-depth = <512>; status = "disabled"; };
frddr_b: audio-controller@200 { compatible = "amlogic,axg-frddr"; - reg = <0x0 0x200 0x0 0x1c>; + reg = <0x0 0x200 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "FRDDR_B"; interrupts = <GIC_SPI 89 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; resets = <&arb AXG_ARB_FRDDR_B>; + amlogic,fifo-depth = <256>; status = "disabled"; };
frddr_c: audio-controller@240 { compatible = "amlogic,axg-frddr"; - reg = <0x0 0x240 0x0 0x1c>; + reg = <0x0 0x240 0x0 0x2c>; #sound-dai-cells = <0>; sound-name-prefix = "FRDDR_C"; interrupts = <GIC_SPI 90 IRQ_TYPE_EDGE_RISING>; clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; resets = <&arb AXG_ARB_FRDDR_C>; + amlogic,fifo-depth = <256>; status = "disabled"; };
@@ -1147,6 +1296,18 @@ status = "disabled"; };
+ spdifin: audio-controller@400 { + compatible = "amlogic,axg-spdifin"; + reg = <0x0 0x400 0x0 0x30>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFIN"; + interrupts = <GIC_SPI 87 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, + <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; + clock-names = "pclk", "refclk"; + status = "disabled"; + }; + spdifout: audio-controller@480 { compatible = "amlogic,axg-spdifout"; reg = <0x0 0x480 0x0 0x50>; @@ -1216,6 +1377,8 @@ compatible = "amlogic,meson-axg-aoclkc"; #clock-cells = <1>; #reset-cells = <1>; + clocks = <&xtal>, <&clkc CLKID_CLK81>; + clock-names = "xtal", "mpeg-clk"; }; };
@@ -1239,6 +1402,7 @@ mux { groups = "i2c_ao_sck_4"; function = "i2c_ao"; + bias-disable; }; };
@@ -1246,6 +1410,7 @@ mux { groups = "i2c_ao_sck_8"; function = "i2c_ao"; + bias-disable; }; };
@@ -1253,6 +1418,7 @@ mux { groups = "i2c_ao_sck_10"; function = "i2c_ao"; + bias-disable; }; };
@@ -1260,6 +1426,7 @@ mux { groups = "i2c_ao_sda_5"; function = "i2c_ao"; + bias-disable; }; };
@@ -1267,6 +1434,7 @@ mux { groups = "i2c_ao_sda_9"; function = "i2c_ao"; + bias-disable; }; };
@@ -1274,6 +1442,7 @@ mux { groups = "i2c_ao_sda_11"; function = "i2c_ao"; + bias-disable; }; };
@@ -1281,6 +1450,7 @@ mux { groups = "remote_input_ao"; function = "remote_input_ao"; + bias-disable; }; };
@@ -1289,6 +1459,7 @@ groups = "uart_ao_tx_a", "uart_ao_rx_a"; function = "uart_ao_a"; + bias-disable; }; };
@@ -1297,6 +1468,7 @@ groups = "uart_ao_cts_a", "uart_ao_rts_a"; function = "uart_ao_a"; + bias-disable; }; };
@@ -1305,6 +1477,7 @@ groups = "uart_ao_tx_b", "uart_ao_rx_b"; function = "uart_ao_b"; + bias-disable; }; };
@@ -1313,6 +1486,7 @@ groups = "uart_ao_cts_b", "uart_ao_rts_b"; function = "uart_ao_b"; + bias-disable; }; }; }; @@ -1414,12 +1588,18 @@ };
gpio_intc: interrupt-controller@f080 { - compatible = "amlogic,meson-gpio-intc"; + compatible = "amlogic,meson-axg-gpio-intc", + "amlogic,meson-gpio-intc"; reg = <0x0 0xf080 0x0 0x10>; interrupt-controller; #interrupt-cells = <2>; amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; - status = "disabled"; + }; + + watchdog@f0d0 { + compatible = "amlogic,meson-gxbb-wdt"; + reg = <0x0 0xf0d0 0x0 0x10>; + clocks = <&xtal>; };
pwm_ab: pwm@1b000 { @@ -1458,6 +1638,11 @@ status = "disabled"; };
+ clk_msr: clock-measure@18000 { + compatible = "amlogic,meson-axg-clk-measure"; + reg = <0x0 0x18000 0x0 0x10>; + }; + i2c3: i2c@1c000 { compatible = "amlogic,meson-axg-i2c"; reg = <0x0 0x1c000 0x0 0x20>; @@ -1556,12 +1741,12 @@ #size-cells = <1>; ranges = <0 0x0 0xfffc0000 0x20000>;
- cpu_scp_lpri: scp-shmem@0 { + cpu_scp_lpri: scp-shmem@13000 { compatible = "amlogic,meson-axg-scp-shmem"; reg = <0x13000 0x400>; };
- cpu_scp_hpri: scp-shmem@200 { + cpu_scp_hpri: scp-shmem@13400 { compatible = "amlogic,meson-axg-scp-shmem"; reg = <0x13400 0x400>; }; diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi index 3f39e020f74e..abe04f4ad7d8 100644 --- a/arch/arm/dts/meson-g12-common.dtsi +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -5,51 +5,42 @@
#include <dt-bindings/phy/phy.h> #include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/clock/axg-audio-clkc.h> #include <dt-bindings/clock/g12a-clkc.h> #include <dt-bindings/clock/g12a-aoclkc.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> -#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h> #include <dt-bindings/reset/amlogic,meson-g12a-reset.h> +#include <dt-bindings/thermal/thermal.h>
/ { interrupt-parent = <&gic>; #address-cells = <2>; #size-cells = <2>;
- tdmif_a: audio-controller-0 { - compatible = "amlogic,axg-tdm-iface"; - #sound-dai-cells = <0>; - sound-name-prefix = "TDM_A"; - clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, - <&clkc_audio AUD_CLKID_MST_A_SCLK>, - <&clkc_audio AUD_CLKID_MST_A_LRCLK>; - clock-names = "mclk", "sclk", "lrclk"; - status = "disabled"; - }; + chosen { + #address-cells = <2>; + #size-cells = <2>; + ranges;
- tdmif_b: audio-controller-1 { - compatible = "amlogic,axg-tdm-iface"; - #sound-dai-cells = <0>; - sound-name-prefix = "TDM_B"; - clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, - <&clkc_audio AUD_CLKID_MST_B_SCLK>, - <&clkc_audio AUD_CLKID_MST_B_LRCLK>; - clock-names = "mclk", "sclk", "lrclk"; - status = "disabled"; - }; + simplefb_cvbs: framebuffer-cvbs { + compatible = "amlogic,simple-framebuffer", + "simple-framebuffer"; + amlogic,pipeline = "vpu-cvbs"; + clocks = <&clkc CLKID_HDMI>, + <&clkc CLKID_HTX_PCLK>, + <&clkc CLKID_VPU_INTR>; + status = "disabled"; + };
- tdmif_c: audio-controller-2 { - compatible = "amlogic,axg-tdm-iface"; - #sound-dai-cells = <0>; - sound-name-prefix = "TDM_C"; - clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, - <&clkc_audio AUD_CLKID_MST_C_SCLK>, - <&clkc_audio AUD_CLKID_MST_C_LRCLK>; - clock-names = "mclk", "sclk", "lrclk"; - status = "disabled"; + simplefb_hdmi: framebuffer-hdmi { + compatible = "amlogic,simple-framebuffer", + "simple-framebuffer"; + amlogic,pipeline = "vpu-hdmi"; + clocks = <&clkc CLKID_HDMI>, + <&clkc CLKID_HTX_PCLK>, + <&clkc CLKID_VPU_INTR>; + status = "disabled"; + }; };
efuse: efuse { @@ -58,6 +49,7 @@ #address-cells = <1>; #size-cells = <1>; read-only; + secure-monitor = <&sm>; };
psci { @@ -95,6 +87,94 @@ #size-cells = <2>; ranges;
+ pcie: pcie@fc000000 { + compatible = "amlogic,g12a-pcie", "snps,dw-pcie"; + reg = <0x0 0xfc000000 0x0 0x400000 + 0x0 0xff648000 0x0 0x2000 + 0x0 0xfc400000 0x0 0x200000>; + reg-names = "elbi", "cfg", "config"; + interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>; + bus-range = <0x0 0xff>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x81000000 0 0 0x0 0xfc600000 0 0x00100000 + 0x82000000 0 0xfc700000 0x0 0xfc700000 0 0x1900000>; + + clocks = <&clkc CLKID_PCIE_PHY + &clkc CLKID_PCIE_COMB + &clkc CLKID_PCIE_PLL>; + clock-names = "general", + "pclk", + "port"; + resets = <&reset RESET_PCIE_CTRL_A>, + <&reset RESET_PCIE_APB>; + reset-names = "port", + "apb"; + num-lanes = <1>; + phys = <&usb3_pcie_phy PHY_TYPE_PCIE>; + phy-names = "pcie"; + status = "disabled"; + }; + + thermal-zones { + cpu_thermal: cpu-thermal { + polling-delay = <1000>; + polling-delay-passive = <100>; + thermal-sensors = <&cpu_temp>; + + trips { + cpu_passive: cpu-passive { + temperature = <85000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + + cpu_hot: cpu-hot { + temperature = <95000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "hot"; + }; + + cpu_critical: cpu-critical { + temperature = <110000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + }; + + ddr_thermal: ddr-thermal { + polling-delay = <1000>; + polling-delay-passive = <100>; + thermal-sensors = <&ddr_temp>; + + trips { + ddr_passive: ddr-passive { + temperature = <85000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + + ddr_critical: ddr-critical { + temperature = <110000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map { + trip = <&ddr_passive>; + cooling-device = <&mali THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + ethmac: ethernet@ff3f0000 { compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.70a", @@ -1356,6 +1436,26 @@ }; };
+ cpu_temp: temperature-sensor@34800 { + compatible = "amlogic,g12a-cpu-thermal", + "amlogic,g12a-thermal"; + reg = <0x0 0x34800 0x0 0x50>; + interrupts = <GIC_SPI 35 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_TS>; + #thermal-sensor-cells = <0>; + amlogic,ao-secure = <&sec_AO>; + }; + + ddr_temp: temperature-sensor@34c00 { + compatible = "amlogic,g12a-ddr-thermal", + "amlogic,g12a-thermal"; + reg = <0x0 0x34c00 0x0 0x50>; + interrupts = <GIC_SPI 36 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_TS>; + #thermal-sensor-cells = <0>; + amlogic,ao-secure = <&sec_AO>; + }; + usb2_phy0: phy@36000 { compatible = "amlogic,g12a-usb2-phy"; reg = <0x0 0x36000 0x0 0x2000>; @@ -1457,290 +1557,6 @@ }; };
- pdm: audio-controller@40000 { - compatible = "amlogic,g12a-pdm", - "amlogic,axg-pdm"; - reg = <0x0 0x40000 0x0 0x34>; - #sound-dai-cells = <0>; - sound-name-prefix = "PDM"; - clocks = <&clkc_audio AUD_CLKID_PDM>, - <&clkc_audio AUD_CLKID_PDM_DCLK>, - <&clkc_audio AUD_CLKID_PDM_SYSCLK>; - clock-names = "pclk", "dclk", "sysclk"; - status = "disabled"; - }; - - audio: bus@42000 { - compatible = "simple-bus"; - reg = <0x0 0x42000 0x0 0x2000>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>; - - clkc_audio: clock-controller@0 { - status = "disabled"; - compatible = "amlogic,g12a-audio-clkc"; - reg = <0x0 0x0 0x0 0xb4>; - #clock-cells = <1>; - #reset-cells = <1>; - - clocks = <&clkc CLKID_AUDIO>, - <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>, - <&clkc CLKID_MPLL3>, - <&clkc CLKID_HIFI_PLL>, - <&clkc CLKID_FCLK_DIV3>, - <&clkc CLKID_FCLK_DIV4>, - <&clkc CLKID_GP0_PLL>; - clock-names = "pclk", - "mst_in0", - "mst_in1", - "mst_in2", - "mst_in3", - "mst_in4", - "mst_in5", - "mst_in6", - "mst_in7"; - - resets = <&reset RESET_AUDIO>; - }; - - toddr_a: audio-controller@100 { - compatible = "amlogic,g12a-toddr", - "amlogic,axg-toddr"; - reg = <0x0 0x100 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "TODDR_A"; - interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_TODDR_A>; - resets = <&arb AXG_ARB_TODDR_A>; - status = "disabled"; - }; - - toddr_b: audio-controller@140 { - compatible = "amlogic,g12a-toddr", - "amlogic,axg-toddr"; - reg = <0x0 0x140 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "TODDR_B"; - interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_TODDR_B>; - resets = <&arb AXG_ARB_TODDR_B>; - status = "disabled"; - }; - - toddr_c: audio-controller@180 { - compatible = "amlogic,g12a-toddr", - "amlogic,axg-toddr"; - reg = <0x0 0x180 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "TODDR_C"; - interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_TODDR_C>; - resets = <&arb AXG_ARB_TODDR_C>; - status = "disabled"; - }; - - frddr_a: audio-controller@1c0 { - compatible = "amlogic,g12a-frddr", - "amlogic,axg-frddr"; - reg = <0x0 0x1c0 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "FRDDR_A"; - interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; - resets = <&arb AXG_ARB_FRDDR_A>; - status = "disabled"; - }; - - frddr_b: audio-controller@200 { - compatible = "amlogic,g12a-frddr", - "amlogic,axg-frddr"; - reg = <0x0 0x200 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "FRDDR_B"; - interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; - resets = <&arb AXG_ARB_FRDDR_B>; - status = "disabled"; - }; - - frddr_c: audio-controller@240 { - compatible = "amlogic,g12a-frddr", - "amlogic,axg-frddr"; - reg = <0x0 0x240 0x0 0x1c>; - #sound-dai-cells = <0>; - sound-name-prefix = "FRDDR_C"; - interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; - resets = <&arb AXG_ARB_FRDDR_C>; - status = "disabled"; - }; - - arb: reset-controller@280 { - status = "disabled"; - compatible = "amlogic,meson-axg-audio-arb"; - reg = <0x0 0x280 0x0 0x4>; - #reset-cells = <1>; - clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; - }; - - tdmin_a: audio-controller@300 { - compatible = "amlogic,g12a-tdmin", - "amlogic,axg-tdmin"; - reg = <0x0 0x300 0x0 0x40>; - sound-name-prefix = "TDMIN_A"; - resets = <&clkc_audio AUD_RESET_TDMIN_A>; - clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, - <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, - <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, - <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - tdmin_b: audio-controller@340 { - compatible = "amlogic,g12a-tdmin", - "amlogic,axg-tdmin"; - reg = <0x0 0x340 0x0 0x40>; - sound-name-prefix = "TDMIN_B"; - resets = <&clkc_audio AUD_RESET_TDMIN_B>; - clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, - <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, - <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, - <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - tdmin_c: audio-controller@380 { - compatible = "amlogic,g12a-tdmin", - "amlogic,axg-tdmin"; - reg = <0x0 0x380 0x0 0x40>; - sound-name-prefix = "TDMIN_C"; - resets = <&clkc_audio AUD_RESET_TDMIN_C>; - clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, - <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, - <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, - <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - tdmin_lb: audio-controller@3c0 { - compatible = "amlogic,g12a-tdmin", - "amlogic,axg-tdmin"; - reg = <0x0 0x3c0 0x0 0x40>; - sound-name-prefix = "TDMIN_LB"; - resets = <&clkc_audio AUD_RESET_TDMIN_LB>; - clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, - <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, - <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, - <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - spdifin: audio-controller@400 { - compatible = "amlogic,g12a-spdifin", - "amlogic,axg-spdifin"; - reg = <0x0 0x400 0x0 0x30>; - #sound-dai-cells = <0>; - sound-name-prefix = "SPDIFIN"; - interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, - <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; - clock-names = "pclk", "refclk"; - status = "disabled"; - }; - - spdifout: audio-controller@480 { - compatible = "amlogic,g12a-spdifout", - "amlogic,axg-spdifout"; - reg = <0x0 0x480 0x0 0x50>; - #sound-dai-cells = <0>; - sound-name-prefix = "SPDIFOUT"; - clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>, - <&clkc_audio AUD_CLKID_SPDIFOUT_CLK>; - clock-names = "pclk", "mclk"; - status = "disabled"; - }; - - tdmout_a: audio-controller@500 { - compatible = "amlogic,g12a-tdmout"; - reg = <0x0 0x500 0x0 0x40>; - sound-name-prefix = "TDMOUT_A"; - resets = <&clkc_audio AUD_RESET_TDMOUT_A>; - clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, - <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - tdmout_b: audio-controller@540 { - compatible = "amlogic,g12a-tdmout"; - reg = <0x0 0x540 0x0 0x40>; - sound-name-prefix = "TDMOUT_B"; - resets = <&clkc_audio AUD_RESET_TDMOUT_B>; - clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, - <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - tdmout_c: audio-controller@580 { - compatible = "amlogic,g12a-tdmout"; - reg = <0x0 0x580 0x0 0x40>; - sound-name-prefix = "TDMOUT_C"; - resets = <&clkc_audio AUD_RESET_TDMOUT_C>; - clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, - <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, - <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, - <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; - clock-names = "pclk", "sclk", "sclk_sel", - "lrclk", "lrclk_sel"; - status = "disabled"; - }; - - spdifout_b: audio-controller@680 { - compatible = "amlogic,g12a-spdifout", - "amlogic,axg-spdifout"; - reg = <0x0 0x680 0x0 0x50>; - #sound-dai-cells = <0>; - sound-name-prefix = "SPDIFOUT_B"; - clocks = <&clkc_audio AUD_CLKID_SPDIFOUT_B>, - <&clkc_audio AUD_CLKID_SPDIFOUT_B_CLK>; - clock-names = "pclk", "mclk"; - status = "disabled"; - }; - - tohdmitx: audio-controller@744 { - compatible = "amlogic,g12a-tohdmitx"; - reg = <0x0 0x744 0x0 0x4>; - #sound-dai-cells = <1>; - sound-name-prefix = "TOHDMITX"; - status = "disabled"; - }; - }; - usb3_pcie_phy: phy@46000 { compatible = "amlogic,g12a-usb3-pcie-phy"; reg = <0x0 0x46000 0x0 0x2000>; @@ -2152,6 +1968,29 @@ }; };
+ vdec: video-decoder@ff620000 { + compatible = "amlogic,g12a-vdec"; + reg = <0x0 0xff620000 0x0 0x10000>, + <0x0 0xffd0e180 0x0 0xe4>; + reg-names = "dos", "esparser"; + interrupts = <GIC_SPI 44 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 32 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "vdec", "esparser"; + + amlogic,ao-sysctrl = <&rti>; + amlogic,canvas = <&canvas>; + + clocks = <&clkc CLKID_PARSER>, + <&clkc CLKID_DOS>, + <&clkc CLKID_VDEC_1>, + <&clkc CLKID_VDEC_HEVC>, + <&clkc CLKID_VDEC_HEVCF>; + clock-names = "dos_parser", "dos", "vdec_1", + "vdec_hevc", "vdec_hevcf"; + resets = <&reset RESET_PARSER>; + reset-names = "esparser"; + }; + vpu: vpu@ff900000 { compatible = "amlogic,meson-g12a-vpu"; reg = <0x0 0xff900000 0x0 0x100000>, @@ -2388,10 +2227,10 @@ compatible = "amlogic,meson-g12a-mali", "arm,mali-bifrost"; reg = <0x0 0xffe40000 0x0 0x40000>; interrupt-parent = <&gic>; - interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>, + interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "gpu", "mmu", "job"; + <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "job", "mmu", "gpu"; clocks = <&clkc CLKID_MALI>; resets = <&reset RESET_DVALIN_CAPB3>, <&reset RESET_DVALIN>;
@@ -2409,6 +2248,7 @@ assigned-clock-rates = <0>, /* Do Nothing */ <800000000>, <0>; /* Do Nothing */ + #cooling-cells = <2>; }; };
diff --git a/arch/arm/dts/meson-g12.dtsi b/arch/arm/dts/meson-g12.dtsi new file mode 100644 index 000000000000..03054c478896 --- /dev/null +++ b/arch/arm/dts/meson-g12.dtsi @@ -0,0 +1,398 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +#include "meson-g12-common.dtsi" +#include <dt-bindings/clock/axg-audio-clkc.h> +#include <dt-bindings/power/meson-g12a-power.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> +#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h> + +/ { + tdmif_a: audio-controller-0 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_A"; + clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, + <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_b: audio-controller-1 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_B"; + clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, + <&clkc_audio AUD_CLKID_MST_B_SCLK>, + <&clkc_audio AUD_CLKID_MST_B_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_c: audio-controller-2 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_C"; + clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, + <&clkc_audio AUD_CLKID_MST_C_SCLK>, + <&clkc_audio AUD_CLKID_MST_C_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; +}; + +&apb { + pdm: audio-controller@40000 { + compatible = "amlogic,g12a-pdm", + "amlogic,axg-pdm"; + reg = <0x0 0x40000 0x0 0x34>; + #sound-dai-cells = <0>; + sound-name-prefix = "PDM"; + clocks = <&clkc_audio AUD_CLKID_PDM>, + <&clkc_audio AUD_CLKID_PDM_DCLK>, + <&clkc_audio AUD_CLKID_PDM_SYSCLK>; + clock-names = "pclk", "dclk", "sysclk"; + status = "disabled"; + }; + + audio: bus@42000 { + compatible = "simple-bus"; + reg = <0x0 0x42000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>; + + clkc_audio: clock-controller@0 { + status = "disabled"; + compatible = "amlogic,g12a-audio-clkc"; + reg = <0x0 0x0 0x0 0xb4>; + #clock-cells = <1>; + #reset-cells = <1>; + + clocks = <&clkc CLKID_AUDIO>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL3>, + <&clkc CLKID_HIFI_PLL>, + <&clkc CLKID_FCLK_DIV3>, + <&clkc CLKID_FCLK_DIV4>, + <&clkc CLKID_GP0_PLL>; + clock-names = "pclk", + "mst_in0", + "mst_in1", + "mst_in2", + "mst_in3", + "mst_in4", + "mst_in5", + "mst_in6", + "mst_in7"; + + resets = <&reset RESET_AUDIO>; + }; + + toddr_a: audio-controller@100 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x100 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_A"; + interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_A>; + resets = <&arb AXG_ARB_TODDR_A>, + <&clkc_audio AUD_RESET_TODDR_A>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <512>; + status = "disabled"; + }; + + toddr_b: audio-controller@140 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x140 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_B"; + interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_B>; + resets = <&arb AXG_ARB_TODDR_B>, + <&clkc_audio AUD_RESET_TODDR_B>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + toddr_c: audio-controller@180 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x180 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_C"; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_C>; + resets = <&arb AXG_ARB_TODDR_C>, + <&clkc_audio AUD_RESET_TODDR_C>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + frddr_a: audio-controller@1c0 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x1c0 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_A"; + interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; + resets = <&arb AXG_ARB_FRDDR_A>, + <&clkc_audio AUD_RESET_FRDDR_A>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <512>; + status = "disabled"; + }; + + frddr_b: audio-controller@200 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x200 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_B"; + interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; + resets = <&arb AXG_ARB_FRDDR_B>, + <&clkc_audio AUD_RESET_FRDDR_B>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + frddr_c: audio-controller@240 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x240 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_C"; + interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; + resets = <&arb AXG_ARB_FRDDR_C>, + <&clkc_audio AUD_RESET_FRDDR_C>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + arb: reset-controller@280 { + status = "disabled"; + compatible = "amlogic,meson-axg-audio-arb"; + reg = <0x0 0x280 0x0 0x4>; + #reset-cells = <1>; + clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; + }; + + tdmin_a: audio-controller@300 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x300 0x0 0x40>; + sound-name-prefix = "TDMIN_A"; + resets = <&clkc_audio AUD_RESET_TDMIN_A>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_b: audio-controller@340 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x340 0x0 0x40>; + sound-name-prefix = "TDMIN_B"; + resets = <&clkc_audio AUD_RESET_TDMIN_B>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_c: audio-controller@380 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x380 0x0 0x40>; + sound-name-prefix = "TDMIN_C"; + resets = <&clkc_audio AUD_RESET_TDMIN_C>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_lb: audio-controller@3c0 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x3c0 0x0 0x40>; + sound-name-prefix = "TDMIN_LB"; + resets = <&clkc_audio AUD_RESET_TDMIN_LB>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifin: audio-controller@400 { + compatible = "amlogic,g12a-spdifin", + "amlogic,axg-spdifin"; + reg = <0x0 0x400 0x0 0x30>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFIN"; + interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, + <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; + clock-names = "pclk", "refclk"; + resets = <&clkc_audio AUD_RESET_SPDIFIN>; + status = "disabled"; + }; + + spdifout: audio-controller@480 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x480 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>, + <&clkc_audio AUD_CLKID_SPDIFOUT_CLK>; + clock-names = "pclk", "mclk"; + resets = <&clkc_audio AUD_RESET_SPDIFOUT>; + status = "disabled"; + }; + + tdmout_a: audio-controller@500 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x500 0x0 0x40>; + sound-name-prefix = "TDMOUT_A"; + resets = <&clkc_audio AUD_RESET_TDMOUT_A>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_b: audio-controller@540 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x540 0x0 0x40>; + sound-name-prefix = "TDMOUT_B"; + resets = <&clkc_audio AUD_RESET_TDMOUT_B>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_c: audio-controller@580 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x580 0x0 0x40>; + sound-name-prefix = "TDMOUT_C"; + resets = <&clkc_audio AUD_RESET_TDMOUT_C>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifout_b: audio-controller@680 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x680 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT_B"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT_B>, + <&clkc_audio AUD_CLKID_SPDIFOUT_B_CLK>; + clock-names = "pclk", "mclk"; + resets = <&clkc_audio AUD_RESET_SPDIFOUT_B>; + status = "disabled"; + }; + + tohdmitx: audio-controller@744 { + compatible = "amlogic,g12a-tohdmitx"; + reg = <0x0 0x744 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOHDMITX"; + resets = <&clkc_audio AUD_RESET_TOHDMITX>; + status = "disabled"; + }; + }; +}; + +&cpu_thermal { + cooling-maps { + map0 { + trip = <&cpu_passive>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu100 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu101 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu102 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu103 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu_hot>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu100 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu101 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu102 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu103 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; +}; + +ðmac { + power-domains = <&pwrc PWRC_G12A_ETH_ID>; +}; + +&vpu { + power-domains = <&pwrc PWRC_G12A_VPU_ID>; +}; + +&sd_emmc_a { + amlogic,dram-access-quirk; +}; + +&simplefb_cvbs { + power-domains = <&pwrc PWRC_G12A_VPU_ID>; +}; + +&simplefb_hdmi { + power-domains = <&pwrc PWRC_G12A_VPU_ID>; +}; + diff --git a/arch/arm/dts/meson-g12a-sei510.dts b/arch/arm/dts/meson-g12a-sei510.dts index c7a87368850b..2ac9e3a43b96 100644 --- a/arch/arm/dts/meson-g12a-sei510.dts +++ b/arch/arm/dts/meson-g12a-sei510.dts @@ -129,6 +129,25 @@ enable-active-high; };
+ vddcpu: regulator-vddcpu { + /* + * SY8120B1ABC DC/DC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU"; + regulator-min-microvolt = <721000>; + regulator-max-microvolt = <1022000>; + + vin-supply = <&dc_in>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + vddio_ao1v8: regulator-vddio_ao1v8 { compatible = "regulator-fixed"; regulator-name = "VDDIO_AO1V8"; @@ -297,6 +316,34 @@ status = "okay"; };
+&cpu0 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu2 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu3 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + &cvbs_vdac_port { cvbs_vdac_out: endpoint { remote-endpoint = <&cvbs_connector_in>; @@ -339,6 +386,20 @@ pinctrl-names = "default"; };
+&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + &pwm_ef { status = "okay"; pinctrl-0 = <&pwm_e_pins>; @@ -377,6 +438,9 @@ non-removable; disable-wp;
+ /* WiFi firmware requires power to be kept while in suspend */ + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>;
vmmc-supply = <&vddao_3v3>; diff --git a/arch/arm/dts/meson-g12a-u200.dts b/arch/arm/dts/meson-g12a-u200.dts index 8551fbd4a488..2a324f0136e3 100644 --- a/arch/arm/dts/meson-g12a-u200.dts +++ b/arch/arm/dts/meson-g12a-u200.dts @@ -129,6 +129,24 @@ regulator-always-on; };
+ vddcpu: regulator-vddcpu { + /* + * MP8756GD Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU"; + regulator-min-microvolt = <721000>; + regulator-max-microvolt = <1022000>; + + vin-supply = <&main_12v>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; };
&cec_AO { @@ -145,6 +163,34 @@ hdmi-phandle = <&hdmi_tx>; };
+&cpu0 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu2 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu3 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + &cvbs_vdac_port { cvbs_vdac_out: endpoint { remote-endpoint = <&cvbs_connector_in>; @@ -197,6 +243,14 @@ pinctrl-names = "default"; };
+&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + /* SD card */ &sd_emmc_b { status = "okay"; diff --git a/arch/arm/dts/meson-g12a.dtsi b/arch/arm/dts/meson-g12a.dtsi index eb5d177d7a99..fb0ab27d1f64 100644 --- a/arch/arm/dts/meson-g12a.dtsi +++ b/arch/arm/dts/meson-g12a.dtsi @@ -3,8 +3,7 @@ * Copyright (c) 2018 Amlogic, Inc. All rights reserved. */
-#include "meson-g12-common.dtsi" -#include <dt-bindings/power/meson-g12a-power.h> +#include "meson-g12.dtsi"
/ { compatible = "amlogic,g12a"; @@ -19,6 +18,7 @@ reg = <0x0 0x0>; enable-method = "psci"; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu1: cpu@1 { @@ -27,6 +27,7 @@ reg = <0x0 0x1>; enable-method = "psci"; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu2: cpu@2 { @@ -35,6 +36,7 @@ reg = <0x0 0x2>; enable-method = "psci"; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu3: cpu@3 { @@ -43,6 +45,7 @@ reg = <0x0 0x3>; enable-method = "psci"; next-level-cache = <&l2>; + #cooling-cells = <2>; };
l2: l2-cache0 { @@ -111,14 +114,22 @@ }; };
-ðmac { - power-domains = <&pwrc PWRC_G12A_ETH_ID>; -}; - -&vpu { - power-domains = <&pwrc PWRC_G12A_VPU_ID>; -}; +&cpu_thermal { + cooling-maps { + map0 { + trip = <&cpu_passive>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + };
-&sd_emmc_a { - amlogic,dram-access-quirk; + map1 { + trip = <&cpu_hot>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; }; diff --git a/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts index 3a6a1e0c1e32..124a80901084 100644 --- a/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts +++ b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts @@ -14,3 +14,28 @@ / { compatible = "khadas,vim3", "amlogic,a311d", "amlogic,g12b"; }; + +/* + * The VIM3 on-board MCU can mux the PCIe/USB3.0 shared differential + * lines using a FUSB340TMX USB 3.1 SuperSpeed Data Switch between + * an USB3.0 Type A connector and a M.2 Key M slot. + * The PHY driving these differential lines is shared between + * the USB3.0 controller and the PCIe Controller, thus only + * a single controller can use it. + * If the MCU is configured to mux the PCIe/USB3.0 differential lines + * to the M.2 Key M slot, uncomment the following block to disable + * USB3.0 from the USB Complex and enable the PCIe controller. + * The End User is not expected to uncomment the following except for + * testing purposes, but instead rely on the firmware/bootloader to + * update these nodes accordingly if PCIe mode is selected by the MCU. + */ +/* +&pcie { + status = "okay"; +}; + +&usb { + phys = <&usb2_phy0>, <&usb2_phy1>; + phy-names = "usb2-phy0", "usb2-phy1"; +}; + */ diff --git a/arch/arm/dts/meson-g12b-odroid-n2.dts b/arch/arm/dts/meson-g12b-odroid-n2.dts index 42f15405750c..0e54c1dc2842 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2.dts +++ b/arch/arm/dts/meson-g12b-odroid-n2.dts @@ -12,7 +12,7 @@ #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
/ { - compatible = "hardkernel,odroid-n2", "amlogic,g12b"; + compatible = "hardkernel,odroid-n2", "amlogic,s922x", "amlogic,g12b"; model = "Hardkernel ODROID-N2";
aliases { diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 5628ccd54531..6dbc3968045b 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -4,8 +4,7 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
/ { compatible = "amlogic,g12b"; @@ -49,7 +48,9 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x0>; enable-method = "psci"; + capacity-dmips-mhz = <592>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu1: cpu@1 { @@ -57,7 +58,9 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x1>; enable-method = "psci"; + capacity-dmips-mhz = <592>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu100: cpu@100 { @@ -65,7 +68,9 @@ compatible = "arm,cortex-a73"; reg = <0x0 0x100>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu101: cpu@101 { @@ -73,7 +78,9 @@ compatible = "arm,cortex-a73"; reg = <0x0 0x101>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu102: cpu@102 { @@ -81,7 +88,9 @@ compatible = "arm,cortex-a73"; reg = <0x0 0x102>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
cpu103: cpu@103 { @@ -89,7 +98,9 @@ compatible = "arm,cortex-a73"; reg = <0x0 0x103>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; + #cooling-cells = <2>; };
l2: l2-cache0 { @@ -102,14 +113,3 @@ compatible = "amlogic,g12b-clkc"; };
-ðmac { - power-domains = <&pwrc PWRC_G12A_ETH_ID>; -}; - -&vpu { - power-domains = <&pwrc PWRC_G12A_VPU_ID>; -}; - -&sd_emmc_a { - amlogic,dram-access-quirk; -}; diff --git a/arch/arm/dts/meson-gx.dtsi b/arch/arm/dts/meson-gx.dtsi index f1e5cdbade5e..40db06e28b66 100644 --- a/arch/arm/dts/meson-gx.dtsi +++ b/arch/arm/dts/meson-gx.dtsi @@ -50,13 +50,35 @@ }; };
+ chosen { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + simplefb_cvbs: framebuffer-cvbs { + compatible = "amlogic,simple-framebuffer", + "simple-framebuffer"; + amlogic,pipeline = "vpu-cvbs"; + power-domains = <&pwrc_vpu>; + status = "disabled"; + }; + + simplefb_hdmi: framebuffer-hdmi { + compatible = "amlogic,simple-framebuffer", + "simple-framebuffer"; + amlogic,pipeline = "vpu-hdmi"; + power-domains = <&pwrc_vpu>; + status = "disabled"; + }; + }; + cpus { #address-cells = <0x2>; #size-cells = <0x0>;
cpu0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x0>; enable-method = "psci"; next-level-cache = <&l2>; @@ -65,7 +87,7 @@
cpu1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x1>; enable-method = "psci"; next-level-cache = <&l2>; @@ -74,7 +96,7 @@
cpu2: cpu@2 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x2>; enable-method = "psci"; next-level-cache = <&l2>; @@ -83,7 +105,7 @@
cpu3: cpu@3 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x3>; enable-method = "psci"; next-level-cache = <&l2>; @@ -139,6 +161,7 @@ #address-cells = <1>; #size-cells = <1>; read-only; + secure-monitor = <&sm>;
sn: sn@14 { reg = <0x14 0x10>; @@ -198,7 +221,7 @@ };
reset: reset-controller@4404 { - compatible = "amlogic,meson-gx-reset", "amlogic,meson-gxbb-reset"; + compatible = "amlogic,meson-gxbb-reset"; reg = <0x0 0x04404 0x0 0x9c>; #reset-cells = <1>; }; @@ -218,7 +241,7 @@ };
i2c_A: i2c@8500 { - compatible = "amlogic,meson-gx-i2c", "amlogic,meson-gxbb-i2c"; + compatible = "amlogic,meson-gxbb-i2c"; reg = <0x0 0x08500 0x0 0x20>; interrupts = <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>; #address-cells = <1>; @@ -262,8 +285,13 @@ status = "disabled"; };
+ clock-measure@8758 { + compatible = "amlogic,meson-gx-clk-measure"; + reg = <0x0 0x8758 0x0 0x10>; + }; + i2c_B: i2c@87c0 { - compatible = "amlogic,meson-gx-i2c", "amlogic,meson-gxbb-i2c"; + compatible = "amlogic,meson-gxbb-i2c"; reg = <0x0 0x087c0 0x0 0x20>; interrupts = <GIC_SPI 214 IRQ_TYPE_EDGE_RISING>; #address-cells = <1>; @@ -272,7 +300,7 @@ };
i2c_C: i2c@87e0 { - compatible = "amlogic,meson-gx-i2c", "amlogic,meson-gxbb-i2c"; + compatible = "amlogic,meson-gxbb-i2c"; reg = <0x0 0x087e0 0x0 0x20>; interrupts = <GIC_SPI 215 IRQ_TYPE_EDGE_RISING>; #address-cells = <1>; @@ -290,7 +318,7 @@ };
spifc: spi@8c80 { - compatible = "amlogic,meson-gx-spifc", "amlogic,meson-gxbb-spifc"; + compatible = "amlogic,meson-gxbb-spifc"; reg = <0x0 0x08c80 0x0 0x80>; #address-cells = <1>; #size-cells = <0>; @@ -298,7 +326,7 @@ };
watchdog@98d0 { - compatible = "amlogic,meson-gx-wdt", "amlogic,meson-gxbb-wdt"; + compatible = "amlogic,meson-gxbb-wdt"; reg = <0x0 0x098d0 0x0 0x10>; clocks = <&xtal>; }; @@ -364,6 +392,7 @@ compatible = "amlogic,meson-gx-ao-cec"; reg = <0x0 0x00100 0x0 0x14>; interrupts = <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; };
sec_AO: ao-secure@140 { @@ -387,7 +416,7 @@ };
i2c_AO: i2c@500 { - compatible = "amlogic,meson-gx-i2c", "amlogic,meson-gxbb-i2c"; + compatible = "amlogic,meson-gxbb-i2c"; reg = <0x0 0x500 0x0 0x20>; interrupts = <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>; #address-cells = <1>; @@ -410,7 +439,21 @@ }; };
- periphs: periphs@c8834000 { + vdec: video-codec@c8820000 { + compatible = "amlogic,gx-vdec"; + reg = <0x0 0xc8820000 0x0 0x10000>, + <0x0 0xc110a580 0x0 0xe4>; + reg-names = "dos", "esparser"; + + interrupts = <GIC_SPI 44 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 32 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "vdec", "esparser"; + + amlogic,ao-sysctrl = <&sysctrl_AO>; + amlogic,canvas = <&canvas>; + }; + + periphs: bus@c8834000 { compatible = "simple-bus"; reg = <0x0 0xc8834000 0x0 0x2000>; #address-cells = <2>; @@ -449,7 +492,7 @@ };
mailbox: mailbox@404 { - compatible = "amlogic,meson-gx-mhu", "amlogic,meson-gxbb-mhu"; + compatible = "amlogic,meson-gxbb-mhu"; reg = <0 0x404 0 0x4c>; interrupts = <GIC_SPI 208 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 209 IRQ_TYPE_EDGE_RISING>, @@ -459,11 +502,15 @@ };
ethmac: ethernet@c9410000 { - compatible = "amlogic,meson-gx-dwmac", "amlogic,meson-gxbb-dwmac", "snps,dwmac"; - reg = <0x0 0xc9410000 0x0 0x10000 - 0x0 0xc8834540 0x0 0x4>; - interrupts = <GIC_SPI 8 IRQ_TYPE_EDGE_RISING>; + compatible = "amlogic,meson-gxbb-dwmac", + "snps,dwmac-3.70a", + "snps,dwmac"; + reg = <0x0 0xc9410000 0x0 0x10000>, + <0x0 0xc8834540 0x0 0x4>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq"; + rx-fifo-depth = <4096>; + tx-fifo-depth = <2048>; status = "disabled"; };
@@ -499,12 +546,12 @@ vpu: vpu@d0100000 { compatible = "amlogic,meson-gx-vpu"; reg = <0x0 0xd0100000 0x0 0x100000>, - <0x0 0xc883c000 0x0 0x1000>, - <0x0 0xc8838000 0x0 0x1000>; - reg-names = "vpu", "hhi", "dmc"; + <0x0 0xc883c000 0x0 0x1000>; + reg-names = "vpu", "hhi"; interrupts = <GIC_SPI 3 IRQ_TYPE_EDGE_RISING>; #address-cells = <1>; #size-cells = <0>; + amlogic,canvas = <&canvas>;
/* CVBS VDAC output port */ cvbs_vdac_port: port@0 { diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts index cbe99bd4e06d..d6ca684e0e61 100644 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ b/arch/arm/dts/meson-gxbb-nanopi-k2.dts @@ -10,6 +10,7 @@
/ { compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; + model = "FriendlyARM NanoPi K2";
aliases { serial0 = &uart_AO; @@ -154,10 +155,6 @@
amlogic,tx-delay-ns = <2>;
- snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-active-low; - mdio { compatible = "snps,dwmac-mdio"; #address-cells = <1>; @@ -166,6 +163,11 @@ eth_phy0: ethernet-phy@0 { /* Realtek RTL8211F (0x001cc916) */ reg = <0>; + + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; /* MAC_INTR on GPIOZ_15 */ interrupts = <29 IRQ_TYPE_LEVEL_LOW>; @@ -191,7 +193,7 @@ pinctrl-names = "default"; };
-&pinctrl_aobus { +&gpio_ao { gpio-line-names = "UART TX", "UART RX", "Power Control", "Power Key In", "VCCK En", "CON1 Header Pin31", "I2S Header Pin6", "IR In", "I2S Header Pin7", @@ -201,7 +203,7 @@ ""; };
-&pinctrl_periphs { +&gpio { gpio-line-names = /* Bank GPIOZ */ "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", @@ -273,11 +275,14 @@
bus-width = <4>; cap-sd-highspeed; - max-frequency = <200000000>; + max-frequency = <50000000>;
vmmc-supply = <&vddio_ao3v3>; @@ -301,12 +306,11 @@ sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; - sd-uhs-sdr104; - max-frequency = <200000000>; + sd-uhs-ddr50; + max-frequency = <100000000>; disable-wp;
- cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_HIGH>; - cd-inverted; + cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>;
vmmc-supply = <&vddio_ao3v3>; vqmmc-supply = <&vddio_tf>; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index 54954b314a45..6ded279c40c8 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -36,8 +36,15 @@ regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;
+ /* + * signal name from schematics: PWREN + */ gpio = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; enable-active-high; + /* + * signal name from schematics: USB_POWER + */ + vin-supply = <&p5v0>; };
leds { @@ -50,18 +57,38 @@ }; };
+ p5v0: regulator-p5v0 { + compatible = "regulator-fixed"; + + regulator-name = "P5V0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + hdmi_p5v0: regulator-hdmi_p5v0 { + compatible = "regulator-fixed"; + regulator-name = "HDMI_P5V0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + /* AP2331SA-7 */ + vin-supply = <&p5v0>; + }; + tflash_vdd: regulator-tflash_vdd { - /* - * signal name from schematics: TFLASH_VDD_EN - */ compatible = "regulator-fixed";
regulator-name = "TFLASH_VDD"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
+ /* + * signal name from schematics: TFLASH_VDD_EN + */ gpio = <&gpio GPIOY_12 GPIO_ACTIVE_HIGH>; enable-active-high; + /* U16 RT9179GB */ + vin-supply = <&vddio_ao3v3>; };
tf_io: gpio-regulator-tf_io { @@ -77,8 +104,10 @@ gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; gpios-states = <0>;
- states = <3300000 0 - 1800000 1>; + states = <3300000 0>, + <1800000 1>; + /* U12/U13 RT9179GB */ + vin-supply = <&vddio_ao3v3>; };
vcc1v8: regulator-vcc1v8 { @@ -86,6 +115,9 @@ regulator-name = "VCC1V8"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; + regulator-always-on; + /* U18 RT9179GB */ + vin-supply = <&vddio_ao3v3>; };
vcc3v3: regulator-vcc3v3 { @@ -95,6 +127,36 @@ regulator-max-microvolt = <3300000>; };
+ vddio_ao1v8: regulator-vddio-ao1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + /* U17 RT9179GB */ + vin-supply = <&p5v0>; + }; + + vddio_ao3v3: regulator-vddio-ao3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + /* U11 MP2161GJ-C499 */ + vin-supply = <&p5v0>; + }; + + ddr3_1v5: regulator-ddr3_1v5 { + compatible = "regulator-fixed"; + regulator-name = "DDR3_1V5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + /* U15 MP2161GJ-C499 */ + vin-supply = <&p5v0>; + }; + emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; @@ -126,10 +188,6 @@ phy-handle = <ð_phy0>; phy-mode = "rgmii";
- snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-active-low; - amlogic,tx-delay-ns = <2>;
mdio { @@ -140,10 +198,14 @@ eth_phy0: ethernet-phy@0 { /* Realtek RTL8211F (0x001cc916) */ reg = <0>; + + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; /* MAC_INTR on GPIOZ_15 */ interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - eee-broken-1000t; }; }; }; @@ -167,6 +229,7 @@ status = "okay"; pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; pinctrl-names = "default"; + hdmi-supply = <&hdmi_p5v0>; };
&hdmi_tx_tmds_port { @@ -187,7 +250,7 @@ pinctrl-names = "default"; };
-&pinctrl_aobus { +&gpio_ao { gpio-line-names = "UART TX", "UART RX", "VCCK En", "TF 3V3/1V8 En", "USB HUB nRESET", "USB OTG Power En", "J7 Header Pin2", "IR In", "J7 Header Pin4", @@ -197,7 +260,7 @@ ""; };
-&pinctrl_periphs { +&gpio { gpio-line-names = /* Bank GPIOZ */ "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", @@ -256,11 +319,14 @@
bus-width = <4>; cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-ddr50; max-frequency = <100000000>; disable-wp;
vmmc-supply = <&tflash_vdd>; vqmmc-supply = <&tf_io>; @@ -274,7 +340,7 @@ pinctrl-names = "default", "clk-gate";
bus-width = <8>; - max-frequency = <100000000>; + max-frequency = <200000000>; non-removable; disable-wp; cap-mmc-highspeed; @@ -293,7 +359,7 @@ };
&usb0_phy { - status = "okay"; + status = "disabled"; phy-supply = <&usb_otg_pwr>; };
@@ -303,7 +369,7 @@ };
&usb0 { - status = "okay"; + status = "disabled"; };
&usb1 { diff --git a/arch/arm/dts/meson-gxbb-p200.dts b/arch/arm/dts/meson-gxbb-p200.dts index 9d2406a7c4fa..3c93d1898b40 100644 --- a/arch/arm/dts/meson-gxbb-p200.dts +++ b/arch/arm/dts/meson-gxbb-p200.dts @@ -68,10 +68,6 @@
- snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-active-low; - mdio { compatible = "snps,dwmac-mdio"; #address-cells = <1>; @@ -80,6 +76,11 @@ eth_phy0: ethernet-phy@3 { /* Micrel KSZ9031 (0x00221620) */ reg = <3>; + + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; /* MAC_INTR on GPIOZ_15 */ interrupts = <29 IRQ_TYPE_LEVEL_LOW>; diff --git a/arch/arm/dts/meson-gxbb-p201.dts b/arch/arm/dts/meson-gxbb-p201.dts index 56e0dd1ff55c..150a82f3b2d7 100644 --- a/arch/arm/dts/meson-gxbb-p201.dts +++ b/arch/arm/dts/meson-gxbb-p201.dts @@ -21,6 +21,6 @@ phy-mode = "rmii";
snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0 10000 1000000>; + snps,reset-delays-us = <0>, <10000>, <1000000>; snps,reset-active-low; }; diff --git a/arch/arm/dts/meson-gxbb-p20x.dtsi b/arch/arm/dts/meson-gxbb-p20x.dtsi index 0be0f2a5d2fe..e803a466fe4e 100644 --- a/arch/arm/dts/meson-gxbb-p20x.dtsi +++ b/arch/arm/dts/meson-gxbb-p20x.dtsi @@ -46,8 +46,8 @@ gpios-states = <1>;
/* Based on P200 schematics, signal CARD_1.8V/3.3V_CTR */ - states = <1800000 0 - 3300000 1>; + states = <1800000 0>, + <3300000 1>;
regulator-settling-time-up-us = <10000>; regulator-settling-time-down-us = <150000>; @@ -165,11 +165,14 @@
bus-width = <4>; cap-sd-highspeed; - max-frequency = <100000000>; + max-frequency = <50000000>;
vmmc-supply = <&vddao_3v3>; diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi index 1ade7e486828..0cb40326b0d3 100644 --- a/arch/arm/dts/meson-gxbb.dtsi +++ b/arch/arm/dts/meson-gxbb.dtsi @@ -81,6 +81,7 @@ mux { groups = "uart_tx_ao_a", "uart_rx_ao_a"; function = "uart_ao"; + bias-disable; }; };
@@ -89,6 +90,7 @@ groups = "uart_cts_ao_a", "uart_rts_ao_a"; function = "uart_ao"; + bias-disable; }; };
@@ -96,6 +98,7 @@ mux { groups = "uart_tx_ao_b", "uart_rx_ao_b"; function = "uart_ao_b"; + bias-disable; }; };
@@ -104,6 +107,7 @@ groups = "uart_cts_ao_b", "uart_rts_ao_b"; function = "uart_ao_b"; + bias-disable; }; };
@@ -111,6 +115,7 @@ mux { groups = "remote_input_ao"; function = "remote_input_ao"; + bias-disable; }; };
@@ -119,6 +124,7 @@ groups = "i2c_sck_ao", "i2c_sda_ao"; function = "i2c_ao"; + bias-disable; }; };
@@ -126,6 +132,7 @@ mux { groups = "pwm_ao_a_3"; function = "pwm_ao_a_3"; + bias-disable; }; };
@@ -133,6 +140,7 @@ mux { groups = "pwm_ao_a_6"; function = "pwm_ao_a_6"; + bias-disable; }; };
@@ -140,6 +148,7 @@ mux { groups = "pwm_ao_a_12"; function = "pwm_ao_a_12"; + bias-disable; }; };
@@ -147,6 +156,7 @@ mux { groups = "pwm_ao_b"; function = "pwm_ao_b"; + bias-disable; }; };
@@ -154,6 +164,7 @@ mux { groups = "i2s_am_clk"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -161,6 +172,7 @@ mux { groups = "i2s_out_ao_clk"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -168,6 +180,7 @@ mux { groups = "i2s_out_lr_clk"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -175,6 +188,7 @@ mux { groups = "i2s_out_ch01_ao"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -182,6 +196,7 @@ mux { groups = "i2s_out_ch23_ao"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -189,6 +204,7 @@ mux { groups = "i2s_out_ch45_ao"; function = "i2s_out_ao"; + bias-disable; }; };
@@ -203,6 +219,7 @@ mux { groups = "spdif_out_ao_13"; function = "spdif_out_ao"; + bias-disable; }; };
@@ -210,6 +227,7 @@ mux { groups = "ao_cec"; function = "cec_ao"; + bias-disable; }; };
@@ -217,6 +235,7 @@ mux { groups = "ee_cec"; function = "cec_ao"; + bias-disable; }; }; }; @@ -280,6 +299,12 @@
&clkc_AO { compatible = "amlogic,meson-gxbb-aoclkc", "amlogic,meson-gx-aoclkc"; + clocks = <&xtal>, <&clkc CLKID_CLK81>; + clock-names = "xtal", "mpeg-clk"; +}; + +&efuse { + clocks = <&clkc CLKID_EFUSE>; };
ðmac { @@ -311,6 +336,8 @@ clkc: clock-controller { compatible = "amlogic,gxbb-clkc"; #clock-cells = <1>; + clocks = <&xtal>; + clock-names = "xtal"; }; };
@@ -354,11 +381,17 @@ };
emmc_pins: emmc { - mux { + mux-0 { groups = "emmc_nand_d07", - "emmc_cmd", - "emmc_clk"; + "emmc_cmd"; function = "emmc"; + bias-pull-up; + }; + + mux-1 { + groups = "emmc_clk"; + function = "emmc"; + bias-disable; }; };
@@ -366,6 +399,7 @@ mux { groups = "emmc_ds"; function = "emmc"; + bias-pull-down; }; };
@@ -373,9 +407,6 @@ mux { groups = "BOOT_8"; function = "gpio_periphs"; - }; - cfg-pull-down { - pins = "BOOT_8"; bias-pull-down; }; }; @@ -387,6 +418,7 @@ "nor_c", "nor_cs"; function = "nor"; + bias-disable; }; };
@@ -396,6 +428,7 @@ "spi_mosi", "spi_sclk"; function = "spi"; + bias-disable; }; };
@@ -403,18 +436,25 @@ mux { groups = "spi_ss0"; function = "spi"; + bias-disable; }; };
sdcard_pins: sdcard { - mux { + mux-0 { groups = "sdcard_d0", "sdcard_d1", "sdcard_d2", "sdcard_d3", - "sdcard_cmd", - "sdcard_clk"; + "sdcard_cmd"; + function = "sdcard"; + bias-pull-up; + }; + + mux-1 { + groups = "sdcard_clk"; function = "sdcard"; + bias-disable; }; };
@@ -422,22 +462,25 @@ mux { groups = "CARD_2"; function = "gpio_periphs"; - }; - cfg-pull-down { - pins = "CARD_2"; bias-pull-down; }; };
sdio_pins: sdio { - mux { + mux-0 { groups = "sdio_d0", "sdio_d1", "sdio_d2", "sdio_d3", - "sdio_cmd", - "sdio_clk"; + "sdio_cmd"; + function = "sdio"; + bias-pull-up; + }; + + mux-1 { + groups = "sdio_clk"; function = "sdio"; + bias-disable; }; };
@@ -445,9 +488,6 @@ mux { groups = "GPIOX_4"; function = "gpio_periphs"; - }; - cfg-pull-down { - pins = "GPIOX_4"; bias-pull-down; }; }; @@ -456,6 +496,7 @@ mux { groups = "sdio_irq"; function = "sdio"; + bias-disable; }; };
@@ -464,6 +505,7 @@ groups = "uart_tx_a", "uart_rx_a"; function = "uart_a"; + bias-disable; }; };
@@ -472,6 +514,7 @@ groups = "uart_cts_a", "uart_rts_a"; function = "uart_a"; + bias-disable; }; };
@@ -480,6 +523,7 @@ groups = "uart_tx_b", "uart_rx_b"; function = "uart_b"; + bias-disable; }; };
@@ -488,6 +532,7 @@ groups = "uart_cts_b", "uart_rts_b"; function = "uart_b"; + bias-disable; }; };
@@ -496,6 +541,7 @@ groups = "uart_tx_c", "uart_rx_c"; function = "uart_c"; + bias-disable; }; };
@@ -504,6 +550,7 @@ groups = "uart_cts_c", "uart_rts_c"; function = "uart_c"; + bias-disable; }; };
@@ -512,6 +559,7 @@ groups = "i2c_sck_a", "i2c_sda_a"; function = "i2c_a"; + bias-disable; }; };
@@ -520,6 +568,7 @@ groups = "i2c_sck_b", "i2c_sda_b"; function = "i2c_b"; + bias-disable; }; };
@@ -528,6 +577,7 @@ groups = "i2c_sck_c", "i2c_sda_c"; function = "i2c_c"; + bias-disable; }; };
@@ -548,6 +598,7 @@ "eth_txd2", "eth_txd3"; function = "eth"; + bias-disable; }; };
@@ -563,6 +614,7 @@ "eth_txd0", "eth_txd1"; function = "eth"; + bias-disable; }; };
@@ -570,6 +622,7 @@ mux { groups = "pwm_a_x"; function = "pwm_a_x"; + bias-disable; }; };
@@ -577,6 +630,7 @@ mux { groups = "pwm_a_y"; function = "pwm_a_y"; + bias-disable; }; };
@@ -584,6 +638,7 @@ mux { groups = "pwm_b"; function = "pwm_b"; + bias-disable; }; };
@@ -591,6 +646,7 @@ mux { groups = "pwm_d"; function = "pwm_d"; + bias-disable; }; };
@@ -598,6 +654,7 @@ mux { groups = "pwm_e"; function = "pwm_e"; + bias-disable; }; };
@@ -605,6 +662,7 @@ mux { groups = "pwm_f_x"; function = "pwm_f_x"; + bias-disable; }; };
@@ -612,6 +670,7 @@ mux { groups = "pwm_f_y"; function = "pwm_f_y"; + bias-disable; }; };
@@ -619,6 +678,7 @@ mux { groups = "hdmi_hpd"; function = "hdmi_hpd"; + bias-disable; }; };
@@ -626,6 +686,7 @@ mux { groups = "hdmi_sda", "hdmi_scl"; function = "hdmi_i2c"; + bias-disable; }; };
@@ -633,6 +694,7 @@ mux { groups = "i2sout_ch23_y"; function = "i2s_out"; + bias-disable; }; };
@@ -640,6 +702,7 @@ mux { groups = "i2sout_ch45_y"; function = "i2s_out"; + bias-disable; }; };
@@ -647,6 +710,7 @@ mux { groups = "i2sout_ch67_y"; function = "i2s_out"; + bias-disable; }; };
@@ -654,6 +718,7 @@ mux { groups = "spdif_out_y"; function = "spdif_out"; + bias-disable; }; }; }; @@ -734,6 +799,12 @@ resets = <&reset RESET_SD_EMMC_C>; };
+&simplefb_hdmi { + clocks = <&clkc CLKID_HDMI_PCLK>, + <&clkc CLKID_CLK81>, + <&clkc CLKID_GCLK_VENCI_INT0>; +}; + &spicc { clocks = <&clkc CLKID_SPICC>; clock-names = "core"; @@ -774,3 +845,14 @@ compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu"; power-domains = <&pwrc_vpu>; }; + +&vdec { + compatible = "amlogic,gxbb-vdec", "amlogic,gx-vdec"; + clocks = <&clkc CLKID_DOS_PARSER>, + <&clkc CLKID_DOS>, + <&clkc CLKID_VDEC_1>, + <&clkc CLKID_VDEC_HEVC>; + clock-names = "dos_parser", "dos", "vdec_1", "vdec_hevc"; + resets = <&reset RESET_PARSER>; + reset-names = "esparser"; +}; diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts index 82b1c4851147..4d5949496596 100644 --- a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts +++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts @@ -14,7 +14,7 @@ / { compatible = "libretech,aml-s805x-ac", "amlogic,s805x", "amlogic,meson-gxl"; - model = "Libre Computer Board AML-S805X-AC"; + model = "Libre Computer AML-S805X-AC";
aliases { serial0 = &uart_AO; diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts index ceb34afe421d..440bc23c7342 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts @@ -33,11 +33,9 @@
gpio-keys-polled { compatible = "gpio-keys-polled"; - #address-cells = <1>; - #size-cells = <0>; poll-interval = <100>;
- button@0 { + power-button { label = "power"; linux,code = <KEY_POWER>; gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>; @@ -110,10 +108,10 @@ };
&ir { - linux,rc-map-name = "rc-geekbox"; + linux,rc-map-name = "rc-khadas"; };
-&pinctrl_aobus { +&gpio_ao { gpio-line-names = "UART TX", "UART RX", "Power Key In", @@ -128,7 +126,7 @@ ""; };
-&pinctrl_periphs { +&gpio { gpio-line-names = /* Bank GPIOZ */ "", "", "", "", "", "", "", "", "", "", "", "", "", "", @@ -188,6 +186,16 @@ }; };
+&uart_A { + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; + max-speed = <2000000>; + clocks = <&wifi32k>; + clock-names = "lpo"; + }; +}; + /* This is brought out on the Linux_RX (18) and Linux_TX (19) pins: */ &uart_AO { status = "okay"; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts index a23252efc685..e8348b2728db 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts @@ -12,8 +12,9 @@ #include "meson-gxl-s905x.dtsi"
/ { - compatible = "libretech,cc", "amlogic,s905x", "amlogic,meson-gxl"; - model = "Libre Computer Board AML-S905X-CC"; + compatible = "libretech,aml-s905x-cc", "amlogic,s905x", + "amlogic,meson-gxl"; + model = "Libre Computer AML-S905X-CC";
aliases { serial0 = &uart_AO; @@ -115,11 +116,13 @@ regulator-max-microvolt = <1800000>; };
+ /* This is provided by LDOs on the eMMC daugther card */ vddio_boot: regulator-vddio_boot { compatible = "regulator-fixed"; regulator-name = "VDDIO_BOOT"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; }; };
@@ -164,7 +167,7 @@ }; };
-&pinctrl_aobus { +&gpio_ao { gpio-line-names = "UART TX", "UART RX", "Blue LED", @@ -179,7 +182,7 @@ "7J1 Header Pin15"; };
-&pinctrl_periphs { +&gpio { gpio-line-names = /* Bank GPIOZ */ "", "", "", "", "", "", "", "", "", "", "", "", "", "", @@ -235,11 +238,10 @@
bus-width = <4>; cap-sd-highspeed; - max-frequency = <100000000>; + max-frequency = <50000000>; disable-wp;
vmmc-supply = <&vcc_3v3>; vqmmc-supply = <&vcc_card>; @@ -254,9 +256,9 @@
bus-width = <8>; cap-mmc-highspeed; - mmc-ddr-3_3v; - max-frequency = <50000000>; - non-removable; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; disable-wp;
mmc-pwrseq = <&emmc_pwrseq>; diff --git a/arch/arm/dts/meson-gxl-s905x-p212.dtsi b/arch/arm/dts/meson-gxl-s905x-p212.dtsi index a1b31013ab6e..43eb7d149e36 100644 --- a/arch/arm/dts/meson-gxl-s905x-p212.dtsi +++ b/arch/arm/dts/meson-gxl-s905x-p212.dtsi @@ -114,11 +114,14 @@
vmmc-supply = <&vddao_3v3>; @@ -134,11 +137,10 @@
vmmc-supply = <&vddao_3v3>; vqmmc-supply = <&vddio_boot>; diff --git a/arch/arm/dts/meson-gxl.dtsi b/arch/arm/dts/meson-gxl.dtsi index d5c3d78aafeb..259d86399390 100644 --- a/arch/arm/dts/meson-gxl.dtsi +++ b/arch/arm/dts/meson-gxl.dtsi @@ -36,6 +36,16 @@ phys = <&usb3_phy>, <&usb2_phy0>, <&usb2_phy1>; }; }; + + crypto: crypto@c883e000 { + compatible = "amlogic,gxl-crypto"; + reg = <0x0 0xc883e000 0x0 0x36>; + interrupts = <GIC_SPI 188 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_BLKMV>; + clock-names = "blkmv"; + status = "okay"; + }; }; };
@@ -80,9 +90,6 @@ };
ðmac { - reg = <0x0 0xc9410000 0x0 0x10000 - 0x0 0xc8834540 0x0 0x4>; - clocks = <&clkc CLKID_ETH>, <&clkc CLKID_FCLK_DIV2>, <&clkc CLKID_MPLL2>; @@ -326,10 +333,15 @@ };
emmc_pins: emmc { - mux { + mux-0 { groups = "emmc_nand_d07", - "emmc_cmd", - "emmc_clk"; + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + }; + + mux-1 { + groups = "emmc_clk"; function = "emmc"; bias-disable; }; @@ -339,7 +351,7 @@ mux { groups = "emmc_ds"; function = "emmc"; - bias-disable; + bias-pull-down; }; };
@@ -381,13 +393,18 @@ };
sdcard_pins: sdcard { - mux { + mux-0 { groups = "sdcard_d0", "sdcard_d1", "sdcard_d2", "sdcard_d3", - "sdcard_cmd", - "sdcard_clk"; + "sdcard_cmd"; + function = "sdcard"; + bias-pull-up; + }; + + mux-1 { + groups = "sdcard_clk"; function = "sdcard"; bias-disable; }; @@ -402,13 +419,18 @@ };
sdio_pins: sdio { - mux { + mux-0 { groups = "sdio_d0", "sdio_d1", "sdio_d2", "sdio_d3", - "sdio_cmd", - "sdio_clk"; + "sdio_cmd"; + function = "sdio"; + bias-pull-up; + }; + + mux-1 { + groups = "sdio_clk"; function = "sdio"; bias-disable; }; @@ -511,6 +533,15 @@ }; };
+ i2c_c_dv18_pins: i2c_c_dv18 { + mux { + groups = "i2c_sck_c_dv19", + "i2c_sda_c_dv18"; + function = "i2c_c"; + bias-disable; + }; + }; + eth_pins: eth_c { mux { groups = "eth_mdio", @@ -697,7 +728,7 @@ #size-cells = <0>;
internal_phy: ethernet-phy@8 { - compatible = "ethernet-phy-id0181.4400", "ethernet-phy-ieee802.3-c22"; + compatible = "ethernet-phy-id0181.4400"; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; reg = <8>; max-speed = <100>; @@ -787,6 +818,12 @@ resets = <&reset RESET_SD_EMMC_C>; };
+&simplefb_hdmi { + clocks = <&clkc CLKID_HDMI_PCLK>, + <&clkc CLKID_CLK81>, + <&clkc CLKID_GCLK_VENCI_INT0>; +}; + &spicc { clocks = <&clkc CLKID_SPICC>; clock-names = "core"; @@ -827,3 +864,14 @@ compatible = "amlogic,meson-gxl-vpu", "amlogic,meson-gx-vpu"; power-domains = <&pwrc_vpu>; }; + +&vdec { + compatible = "amlogic,gxl-vdec", "amlogic,gx-vdec"; + clocks = <&clkc CLKID_DOS_PARSER>, + <&clkc CLKID_DOS>, + <&clkc CLKID_VDEC_1>, + <&clkc CLKID_VDEC_HEVC>; + clock-names = "dos_parser", "dos", "vdec_1", "vdec_hevc"; + resets = <&reset RESET_PARSER>; + reset-names = "esparser"; +}; diff --git a/arch/arm/dts/meson-gxm-khadas-vim2.dts b/arch/arm/dts/meson-gxm-khadas-vim2.dts index 782e9edac805..f82f25c1a5f9 100644 --- a/arch/arm/dts/meson-gxm-khadas-vim2.dts +++ b/arch/arm/dts/meson-gxm-khadas-vim2.dts @@ -18,7 +18,6 @@
aliases { serial0 = &uart_AO; - serial1 = &uart_A; serial2 = &uart_AO_B; };
@@ -63,11 +62,9 @@
- button@0 { + power-button { label = "power"; linux,code = <KEY_POWER>; gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>; @@ -132,19 +129,15 @@
map1 { trip = <&cpu_alert1>; - cooling-device = <&gpio_fan 2 THERMAL_NO_LIMIT>; - }; - - map2 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - - map3 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + cooling-device = <&gpio_fan 2 THERMAL_NO_LIMIT>, + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -246,11 +239,6 @@
- /* External PHY reset is shared with internal PHY Led signals */ - snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-active-low; - /* External PHY is in RGMII */ phy-mode = "rgmii";
@@ -261,6 +249,11 @@ external_phy: ethernet-phy@0 { /* Realtek RTL8211F (0x001cc916) */ reg = <0>; + + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; /* MAC_INTR on GPIOZ_15 */ interrupts = <25 IRQ_TYPE_LEVEL_LOW>; @@ -306,7 +299,7 @@ status = "okay"; pinctrl-0 = <&remote_input_ao_pins>; pinctrl-names = "default"; - linux,rc-map-name = "rc-geekbox"; + linux,rc-map-name = "rc-khadas"; };
&pwm_AO_ab { @@ -328,16 +321,20 @@ &sd_emmc_a { status = "okay"; pinctrl-0 = <&sdio_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; #address-cells = <1>; #size-cells = <0>;
bus-width = <4>; - max-frequency = <100000000>; + max-frequency = <50000000>;
vmmc-supply = <&vddao_3v3>; @@ -353,15 +350,15 @@ &sd_emmc_b { status = "okay"; pinctrl-0 = <&sdcard_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
vmmc-supply = <&vddao_3v3>; vqmmc-supply = <&vddio_boot>; @@ -371,17 +368,16 @@ &sd_emmc_c { status = "okay"; pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <8>; - cap-sd-highspeed; cap-mmc-highspeed; max-frequency = <200000000>; non-removable; disable-wp; mmc-ddr-1_8v; mmc-hs200-1_8v; - mmc-hs400-1_8v;
mmc-pwrseq = <&emmc_pwrseq>; vmmc-supply = <&vcc_3v3>; @@ -409,8 +405,17 @@ /* This one is connected to the Bluetooth module */ &uart_A { status = "okay"; - pinctrl-0 = <&uart_a_pins>; + pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; pinctrl-names = "default"; + uart-has-rtscts; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; + max-speed = <2000000>; + clocks = <&wifi32k>; + clock-names = "lpo"; + }; };
/* This is brought out on the Linux_RX (18) and Linux_TX (19) pins: */ diff --git a/arch/arm/dts/meson-gxm.dtsi b/arch/arm/dts/meson-gxm.dtsi index 247888d68a3a..5ff64a0d2dcf 100644 --- a/arch/arm/dts/meson-gxm.dtsi +++ b/arch/arm/dts/meson-gxm.dtsi @@ -44,7 +44,7 @@
cpu4: cpu@100 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x100>; enable-method = "psci"; next-level-cache = <&l2>; @@ -53,7 +53,7 @@
cpu5: cpu@101 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x101>; enable-method = "psci"; next-level-cache = <&l2>; @@ -62,7 +62,7 @@
cpu6: cpu@102 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x102>; enable-method = "psci"; next-level-cache = <&l2>; @@ -71,7 +71,7 @@
cpu7: cpu@103 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x103>; enable-method = "psci"; next-level-cache = <&l2>; @@ -91,6 +91,33 @@ reset-names = "phy"; status = "okay"; }; + + mali: gpu@c0000 { + compatible = "amlogic,meson-gxm-mali", "arm,mali-t820"; + reg = <0x0 0xc0000 0x0 0x40000>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "job", "mmu", "gpu"; + clocks = <&clkc CLKID_MALI>; + resets = <&reset RESET_MALI_CAPB3>, <&reset RESET_MALI>; + + /* + * Mali clocking is provided by two identical clock paths + * MALI_0 and MALI_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + */ + assigned-clocks = <&clkc CLKID_MALI_0_SEL>, + <&clkc CLKID_MALI_0>, + <&clkc CLKID_MALI>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_MALI_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>; /* Do Nothing */ + }; };
&clkc_AO { @@ -117,3 +144,7 @@ &dwc3 { phys = <&usb3_phy>, <&usb2_phy0>, <&usb2_phy1>, <&usb2_phy2>; }; + +&vdec { + compatible = "amlogic,gxm-vdec", "amlogic,gx-vdec"; +}; diff --git a/arch/arm/dts/meson-khadas-vim3.dtsi b/arch/arm/dts/meson-khadas-vim3.dtsi index 8647da7d6609..90815fa25ec6 100644 --- a/arch/arm/dts/meson-khadas-vim3.dtsi +++ b/arch/arm/dts/meson-khadas-vim3.dtsi @@ -246,6 +246,10 @@ linux,rc-map-name = "rc-khadas"; };
+&pcie { + reset-gpios = <&gpio GPIOA_8 GPIO_ACTIVE_LOW>; +}; + &pwm_ef { status = "okay"; pinctrl-0 = <&pwm_e_pins>; @@ -274,6 +278,9 @@ non-removable; disable-wp;
vmmc-supply = <&vsys_3v3>; diff --git a/arch/arm/dts/meson-sm1-sei610.dts b/arch/arm/dts/meson-sm1-sei610.dts index 3435aaa4e8db..a8bb3fa9fec9 100644 --- a/arch/arm/dts/meson-sm1-sei610.dts +++ b/arch/arm/dts/meson-sm1-sei610.dts @@ -9,6 +9,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h>
/ { compatible = "seirobotics,sei610", "amlogic,sm1"; @@ -19,6 +20,22 @@ ethernet0 = ðmac; };
+ mono_dac: audio-codec-0 { + compatible = "maxim,max98357a"; + #sound-dai-cells = <0>; + sound-name-prefix = "U16"; + sdmode-gpios = <&gpio GPIOX_8 GPIO_ACTIVE_HIGH>; + }; + + dmics: audio-codec-1 { + #sound-dai-cells = <0>; + compatible = "dmic-codec"; + num-channels = <2>; + wakeup-delay-ms = <50>; + status = "okay"; + sound-name-prefix = "MIC"; + }; + chosen { stdout-path = "serial0:115200n8"; }; @@ -29,25 +46,47 @@ };
gpio-keys { - compatible = "gpio-keys-polled"; - poll-interval = <100>; + compatible = "gpio-keys";
key1 { label = "A"; linux,code = <BTN_0>; gpios = <&gpio GPIOH_6 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <34 IRQ_TYPE_EDGE_BOTH>; };
key2 { label = "B"; linux,code = <BTN_1>; gpios = <&gpio GPIOH_7 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <35 IRQ_TYPE_EDGE_BOTH>; };
key3 { label = "C"; linux,code = <BTN_2>; gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <2 IRQ_TYPE_EDGE_BOTH>; + }; + + mic_mute { + label = "MicMute"; + linux,code = <SW_MUTE_DEVICE>; + linux,input-type = <EV_SW>; + gpios = <&gpio_ao GPIOE_2 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <99 IRQ_TYPE_EDGE_BOTH>; + }; + + power_key { + label = "PowerKey"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <3 IRQ_TYPE_EDGE_BOTH>; }; };
@@ -179,6 +218,120 @@ clock-names = "ext_clock"; };
+ sound { + compatible = "amlogic,axg-sound-card"; + model = "SM1-SEI610"; + audio-aux-devs = <&tdmout_a>, <&tdmout_b>, + <&tdmin_a>, <&tdmin_b>; + audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", + "TDMOUT_A IN 1", "FRDDR_B OUT 0", + "TDMOUT_A IN 2", "FRDDR_C OUT 0", + "TDM_A Playback", "TDMOUT_A OUT", + "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT", + "TODDR_A IN 4", "PDM Capture", + "TODDR_B IN 4", "PDM Capture", + "TODDR_C IN 4", "PDM Capture", + "TDMIN_A IN 0", "TDM_A Capture", + "TDMIN_A IN 3", "TDM_A Loopback", + "TDMIN_B IN 0", "TDM_A Capture", + "TDMIN_B IN 3", "TDM_A Loopback", + "TDMIN_A IN 1", "TDM_B Capture", + "TDMIN_A IN 4", "TDM_B Loopback", + "TDMIN_B IN 1", "TDM_B Capture", + "TDMIN_B IN 4", "TDM_B Loopback", + "TODDR_A IN 0", "TDMIN_A OUT", + "TODDR_B IN 0", "TDMIN_A OUT", + "TODDR_C IN 0", "TDMIN_A OUT", + "TODDR_A IN 1", "TDMIN_B OUT", + "TODDR_B IN 1", "TDMIN_B OUT", + "TODDR_C IN 1", "TDMIN_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + dai-link-3 { + sound-dai = <&toddr_a>; + }; + + dai-link-4 { + sound-dai = <&toddr_b>; + }; + + dai-link-5 { + sound-dai = <&toddr_c>; + }; + + /* internal speaker interface */ + dai-link-6 { + sound-dai = <&tdmif_a>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&mono_dac>; + }; + + codec-1 { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_A>; + }; + }; + + /* 8ch hdmi interface */ + dai-link-7 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* internal digital mics */ + dai-link-8 { + sound-dai = <&pdm>; + + codec { + sound-dai = <&dmics>; + }; + }; + + /* hdmi glue */ + dai-link-9 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; + wifi32k: wifi32k { compatible = "pwm-clock"; #clock-cells = <0>; @@ -187,6 +340,10 @@ }; };
+&arb { + status = "okay"; +}; + &cec_AO { pinctrl-0 = <&cec_ao_a_h_pins>; pinctrl-names = "default"; @@ -201,6 +358,10 @@ hdmi-phandle = <&hdmi_tx>; };
+&clkc_audio { + status = "okay"; +}; + &cpu0 { cpu-supply = <&vddcpu>; operating-points-v2 = <&cpu_opp_table>; @@ -235,6 +396,18 @@ phy-mode = "rmii"; };
+&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + &hdmi_tx { status = "okay"; pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; @@ -259,6 +432,12 @@ pinctrl-names = "default"; };
+&pdm { + pinctrl-0 = <&pdm_din0_z_pins>, <&pdm_dclk_z_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + &pwm_AO_ab { status = "okay"; pinctrl-0 = <&pwm_ao_a_pins>; @@ -305,6 +484,9 @@ non-removable; disable-wp;
vmmc-supply = <&vddao_3v3>; @@ -353,6 +535,54 @@ vqmmc-supply = <&emmc_1v8>; };
+&tdmif_a { + pinctrl-0 = <&tdm_a_dout0_pins>, <&tdm_a_fs_pins>, <&tdm_a_sclk_pins>; + pinctrl-names = "default"; + status = "okay"; + + assigned-clocks = <&clkc_audio AUD_CLKID_TDM_SCLK_PAD0>, + <&clkc_audio AUD_CLKID_TDM_LRCLK_PAD0>; + assigned-clock-parents = <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + assigned-clock-rates = <0>, <0>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmin_a { + status = "okay"; +}; + +&tdmin_b { + status = "okay"; +}; + +&tdmout_a { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&toddr_a { + status = "okay"; +}; + +&toddr_b { + status = "okay"; +}; + +&toddr_c { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + &uart_A { status = "okay"; pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; @@ -361,6 +591,8 @@
bluetooth { compatible = "brcm,bcm43438-bt"; + interrupt-parent = <&gpio_intc>; + interrupts = <95 IRQ_TYPE_LEVEL_HIGH>; shutdown-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; max-speed = <2000000>; clocks = <&wifi32k>; diff --git a/arch/arm/dts/meson-sm1.dtsi b/arch/arm/dts/meson-sm1.dtsi index 521573f3a5ba..d847a3fcbc85 100644 --- a/arch/arm/dts/meson-sm1.dtsi +++ b/arch/arm/dts/meson-sm1.dtsi @@ -5,11 +5,47 @@ */
#include "meson-g12-common.dtsi" +#include <dt-bindings/clock/axg-audio-clkc.h> #include <dt-bindings/power/meson-sm1-power.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> +#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h>
/ { compatible = "amlogic,sm1";
+ tdmif_a: audio-controller-0 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_A"; + clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, + <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_b: audio-controller-1 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_B"; + clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, + <&clkc_audio AUD_CLKID_MST_B_SCLK>, + <&clkc_audio AUD_CLKID_MST_B_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_c: audio-controller-2 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_C"; + clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, + <&clkc_audio AUD_CLKID_MST_C_SCLK>, + <&clkc_audio AUD_CLKID_MST_C_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + cpus { #address-cells = <0x2>; #size-cells = <0x0>; @@ -117,6 +153,305 @@ }; };
+&apb { + audio: bus@60000 { + compatible = "simple-bus"; + reg = <0x0 0x60000 0x0 0x1000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x60000 0x0 0x1000>; + + clkc_audio: clock-controller@0 { + status = "disabled"; + compatible = "amlogic,sm1-audio-clkc"; + reg = <0x0 0x0 0x0 0xb4>; + #clock-cells = <1>; + #reset-cells = <1>; + + clocks = <&clkc CLKID_AUDIO>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL3>, + <&clkc CLKID_HIFI_PLL>, + <&clkc CLKID_FCLK_DIV3>, + <&clkc CLKID_FCLK_DIV4>, + <&clkc CLKID_FCLK_DIV5>; + clock-names = "pclk", + "mst_in0", + "mst_in1", + "mst_in2", + "mst_in3", + "mst_in4", + "mst_in5", + "mst_in6", + "mst_in7"; + + resets = <&reset RESET_AUDIO>; + }; + + toddr_a: audio-controller@100 { + compatible = "amlogic,sm1-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x100 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_A"; + interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_A>; + resets = <&arb AXG_ARB_TODDR_A>, + <&clkc_audio AUD_RESET_TODDR_A>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <8192>; + status = "disabled"; + }; + + toddr_b: audio-controller@140 { + compatible = "amlogic,sm1-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x140 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_B"; + interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_B>; + resets = <&arb AXG_ARB_TODDR_B>, + <&clkc_audio AUD_RESET_TODDR_B>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + toddr_c: audio-controller@180 { + compatible = "amlogic,sm1-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x180 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_C"; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_C>; + resets = <&arb AXG_ARB_TODDR_C>, + <&clkc_audio AUD_RESET_TODDR_C>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + frddr_a: audio-controller@1c0 { + compatible = "amlogic,sm1-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x1c0 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_A"; + interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; + resets = <&arb AXG_ARB_FRDDR_A>, + <&clkc_audio AUD_RESET_FRDDR_A>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <512>; + status = "disabled"; + }; + + frddr_b: audio-controller@200 { + compatible = "amlogic,sm1-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x200 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_B"; + interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; + resets = <&arb AXG_ARB_FRDDR_B>, + <&clkc_audio AUD_RESET_FRDDR_B>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + frddr_c: audio-controller@240 { + compatible = "amlogic,sm1-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x240 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_C"; + interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; + resets = <&arb AXG_ARB_FRDDR_C>, + <&clkc_audio AUD_RESET_FRDDR_C>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + arb: reset-controller@280 { + status = "disabled"; + compatible = "amlogic,meson-sm1-audio-arb"; + reg = <0x0 0x280 0x0 0x4>; + #reset-cells = <1>; + clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; + }; + + tdmin_a: audio-controller@300 { + compatible = "amlogic,sm1-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x300 0x0 0x40>; + sound-name-prefix = "TDMIN_A"; + resets = <&clkc_audio AUD_RESET_TDMIN_A>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_b: audio-controller@340 { + compatible = "amlogic,sm1-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x340 0x0 0x40>; + sound-name-prefix = "TDMIN_B"; + resets = <&clkc_audio AUD_RESET_TDMIN_B>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_c: audio-controller@380 { + compatible = "amlogic,sm1-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x380 0x0 0x40>; + sound-name-prefix = "TDMIN_C"; + resets = <&clkc_audio AUD_RESET_TDMIN_C>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_lb: audio-controller@3c0 { + compatible = "amlogic,sm1-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x3c0 0x0 0x40>; + sound-name-prefix = "TDMIN_LB"; + resets = <&clkc_audio AUD_RESET_TDMIN_LB>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_a: audio-controller@500 { + compatible = "amlogic,sm1-tdmout"; + reg = <0x0 0x500 0x0 0x40>; + sound-name-prefix = "TDMOUT_A"; + resets = <&clkc_audio AUD_RESET_TDMOUT_A>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_b: audio-controller@540 { + compatible = "amlogic,sm1-tdmout"; + reg = <0x0 0x540 0x0 0x40>; + sound-name-prefix = "TDMOUT_B"; + resets = <&clkc_audio AUD_RESET_TDMOUT_B>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_c: audio-controller@580 { + compatible = "amlogic,sm1-tdmout"; + reg = <0x0 0x580 0x0 0x40>; + sound-name-prefix = "TDMOUT_C"; + resets = <&clkc_audio AUD_RESET_TDMOUT_C>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tohdmitx: audio-controller@744 { + compatible = "amlogic,sm1-tohdmitx", + "amlogic,g12a-tohdmitx"; + reg = <0x0 0x744 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOHDMITX"; + resets = <&clkc_audio AUD_RESET_TOHDMITX>; + status = "disabled"; + }; + + toddr_d: audio-controller@840 { + compatible = "amlogic,sm1-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x840 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_D"; + interrupts = <GIC_SPI 49 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_D>; + resets = <&arb AXG_ARB_TODDR_D>, + <&clkc_audio AUD_RESET_TODDR_D>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + + frddr_d: audio-controller@880 { + compatible = "amlogic,sm1-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x880 0x0 0x2c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_D"; + interrupts = <GIC_SPI 50 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_D>; + resets = <&arb AXG_ARB_FRDDR_D>, + <&clkc_audio AUD_RESET_FRDDR_D>; + reset-names = "arb", "rst"; + amlogic,fifo-depth = <256>; + status = "disabled"; + }; + }; + + pdm: audio-controller@61000 { + compatible = "amlogic,sm1-pdm", + "amlogic,axg-pdm"; + reg = <0x0 0x61000 0x0 0x34>; + #sound-dai-cells = <0>; + sound-name-prefix = "PDM"; + clocks = <&clkc_audio AUD_CLKID_PDM>, + <&clkc_audio AUD_CLKID_PDM_DCLK>, + <&clkc_audio AUD_CLKID_PDM_SYSCLK>; + clock-names = "pclk", "dclk", "sysclk"; + status = "disabled"; + }; +}; + &cecb_AO { compatible = "amlogic,meson-sm1-ao-cec"; }; @@ -134,10 +469,31 @@ power-domains = <&pwrc PWRC_SM1_ETH_ID>; };
+&gpio_intc { + compatible = "amlogic,meson-sm1-gpio-intc", + "amlogic,meson-gpio-intc"; +}; + +&pcie { + power-domains = <&pwrc PWRC_SM1_PCIE_ID>; +}; + &pwrc { compatible = "amlogic,meson-sm1-pwrc"; };
+&simplefb_cvbs { + power-domains = <&pwrc PWRC_SM1_VPU_ID>; +}; + +&simplefb_hdmi { + power-domains = <&pwrc PWRC_SM1_VPU_ID>; +}; + +&vdec { + compatible = "amlogic,sm1-vdec"; +}; + &vpu { power-domains = <&pwrc PWRC_SM1_VPU_ID>; }; diff --git a/include/dt-bindings/clock/axg-audio-clkc.h b/include/dt-bindings/clock/axg-audio-clkc.h index 75901c636893..f561f5c5ef8f 100644 --- a/include/dt-bindings/clock/axg-audio-clkc.h +++ b/include/dt-bindings/clock/axg-audio-clkc.h @@ -80,5 +80,15 @@ #define AUD_CLKID_TDM_SCLK_PAD0 160 #define AUD_CLKID_TDM_SCLK_PAD1 161 #define AUD_CLKID_TDM_SCLK_PAD2 162 +#define AUD_CLKID_TOP 163 +#define AUD_CLKID_TORAM 164 +#define AUD_CLKID_EQDRC 165 +#define AUD_CLKID_RESAMPLE_B 166 +#define AUD_CLKID_TOVAD 167 +#define AUD_CLKID_LOCKER 168 +#define AUD_CLKID_SPDIFIN_LB 169 +#define AUD_CLKID_FRDDR_D 170 +#define AUD_CLKID_TODDR_D 171 +#define AUD_CLKID_LOOPBACK_B 172
#endif /* __AXG_AUDIO_CLKC_BINDINGS_H */ diff --git a/include/dt-bindings/clock/gxbb-aoclkc.h b/include/dt-bindings/clock/gxbb-aoclkc.h index 9d15e2221fdb..ec3b26319fc4 100644 --- a/include/dt-bindings/clock/gxbb-aoclkc.h +++ b/include/dt-bindings/clock/gxbb-aoclkc.h @@ -63,5 +63,12 @@ #define CLKID_AO_UART2 4 #define CLKID_AO_IR_BLASTER 5 #define CLKID_AO_CEC_32K 6 +#define CLKID_AO_CTS_OSCIN 7 +#define CLKID_AO_32K_PRE 8 +#define CLKID_AO_32K_DIV 9 +#define CLKID_AO_32K_SEL 10 +#define CLKID_AO_32K 11 +#define CLKID_AO_CTS_RTC_OSCIN 12 +#define CLKID_AO_CLK81 13
#endif diff --git a/include/dt-bindings/clock/gxbb-clkc.h b/include/dt-bindings/clock/gxbb-clkc.h index 8ba99a5e3fd3..db0763e96173 100644 --- a/include/dt-bindings/clock/gxbb-clkc.h +++ b/include/dt-bindings/clock/gxbb-clkc.h @@ -125,5 +125,26 @@ #define CLKID_VAPB_1 138 #define CLKID_VAPB_SEL 139 #define CLKID_VAPB 140 +#define CLKID_VDEC_1 153 +#define CLKID_VDEC_HEVC 156 +#define CLKID_GEN_CLK 159 +#define CLKID_VID_PLL 166 +#define CLKID_VCLK 175 +#define CLKID_VCLK2 176 +#define CLKID_VCLK_DIV1 185 +#define CLKID_VCLK_DIV2 186 +#define CLKID_VCLK_DIV4 187 +#define CLKID_VCLK_DIV6 188 +#define CLKID_VCLK_DIV12 189 +#define CLKID_VCLK2_DIV1 190 +#define CLKID_VCLK2_DIV2 191 +#define CLKID_VCLK2_DIV4 192 +#define CLKID_VCLK2_DIV6 193 +#define CLKID_VCLK2_DIV12 194 +#define CLKID_CTS_ENCI 199 +#define CLKID_CTS_ENCP 200 +#define CLKID_CTS_VDAC 201 +#define CLKID_HDMI_TX 202 +#define CLKID_HDMI 205
#endif /* __GXBB_CLKC_H */ diff --git a/include/dt-bindings/gpio/meson-gxbb-gpio.h b/include/dt-bindings/gpio/meson-gxbb-gpio.h index 43a68a1110f0..489c75b27645 100644 --- a/include/dt-bindings/gpio/meson-gxbb-gpio.h +++ b/include/dt-bindings/gpio/meson-gxbb-gpio.h @@ -1,15 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * GPIO definitions for Amlogic Meson GXBB SoCs * * Copyright (C) 2016 Endless Mobile, Inc. * Author: Carlo Caione carlo@endlessm.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * version 2 as published by the Free Software Foundation. - * - * You should have received a copy of the GNU General Public License - * along with this program. If not, see http://www.gnu.org/licenses/. */
#ifndef _DT_BINDINGS_MESON_GXBB_GPIO_H diff --git a/include/dt-bindings/gpio/meson-gxl-gpio.h b/include/dt-bindings/gpio/meson-gxl-gpio.h index 01f2a2abd35e..0a001ae48272 100644 --- a/include/dt-bindings/gpio/meson-gxl-gpio.h +++ b/include/dt-bindings/gpio/meson-gxl-gpio.h @@ -1,15 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * GPIO definitions for Amlogic Meson GXL SoCs * * Copyright (C) 2016 Endless Mobile, Inc. * Author: Carlo Caione carlo@endlessm.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * version 2 as published by the Free Software Foundation. - * - * You should have received a copy of the GNU General Public License - * along with this program. If not, see http://www.gnu.org/licenses/. */
#ifndef _DT_BINDINGS_MESON_GXL_GPIO_H diff --git a/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h b/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h index 05c36367875c..1ef807856cb8 100644 --- a/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h +++ b/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h @@ -13,5 +13,7 @@ #define AXG_ARB_FRDDR_A 3 #define AXG_ARB_FRDDR_B 4 #define AXG_ARB_FRDDR_C 5 +#define AXG_ARB_TODDR_D 6 +#define AXG_ARB_FRDDR_D 7
#endif /* _DT_BINDINGS_AMLOGIC_MESON_AXG_AUDIO_ARB_H */ diff --git a/include/dt-bindings/reset/amlogic,meson-axg-reset.h b/include/dt-bindings/reset/amlogic,meson-axg-reset.h index ad6f55dabd6d..0f2e0fe45ca4 100644 --- a/include/dt-bindings/reset/amlogic,meson-axg-reset.h +++ b/include/dt-bindings/reset/amlogic,meson-axg-reset.h @@ -1,12 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ /* - * * Copyright (c) 2016 BayLibre, SAS. * Author: Neil Armstrong narmstrong@baylibre.com * * Copyright (c) 2017 Amlogic, inc. * Author: Yixun Lan yixun.lan@amlogic.com * - * SPDX-License-Identifier: (GPL-2.0+ OR BSD) */
#ifndef _DT_BINDINGS_AMLOGIC_MESON_AXG_RESET_H diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h index 14b78dabed0e..f805129ca7af 100644 --- a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h +++ b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h @@ -35,4 +35,19 @@ #define AUD_RESET_TOHDMITX 24 #define AUD_RESET_CLKTREE 25
+/* SM1 added resets */ +#define AUD_RESET_RESAMPLE_B 26 +#define AUD_RESET_TOVAD 27 +#define AUD_RESET_LOCKER 28 +#define AUD_RESET_SPDIFIN_LB 29 +#define AUD_RESET_FRATV 30 +#define AUD_RESET_FRHDMIRX 31 +#define AUD_RESET_FRDDR_D 32 +#define AUD_RESET_TODDR_D 33 +#define AUD_RESET_LOOPBACK_B 34 +#define AUD_RESET_EARCTX 35 +#define AUD_RESET_EARCRX 36 +#define AUD_RESET_FRDDR_E 37 +#define AUD_RESET_TODDR_E 38 + #endif diff --git a/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h b/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h index 524d6077ac1b..ea5058618863 100644 --- a/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h +++ b/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h @@ -1,56 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0 OR BSD-3-Clause */ /* - * This file is provided under a dual BSD/GPLv2 license. When using or - * redistributing this file, you may do so under either license. - * - * GPL LICENSE SUMMARY - * * Copyright (c) 2016 BayLibre, SAS. * Author: Neil Armstrong narmstrong@baylibre.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of version 2 of the GNU General Public License as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU - * General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, see http://www.gnu.org/licenses/. - * The full GNU General Public License is included in this distribution - * in the file called COPYING. - * - * BSD LICENSE - * - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * * Neither the name of Intel Corporation nor the names of its - * contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS - * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT - * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR - * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT - * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, - * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY - * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE - * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #ifndef _DT_BINDINGS_AMLOGIC_MESON_GXBB_RESET_H #define _DT_BINDINGS_AMLOGIC_MESON_GXBB_RESET_H
Sync the libretech-pc device tree from Linux v5.6-rc2 11a48a5a18c6 ("Linux 5.6-rc2")
Acked-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- arch/arm/dts/meson-gx-libretech-pc.dtsi | 375 ++++++++++++++++++ arch/arm/dts/meson-gxl-s905d-libretech-pc.dts | 16 + arch/arm/dts/meson-gxl-s905d.dtsi | 12 + arch/arm/dts/meson-gxm-s912-libretech-pc.dts | 62 +++ 4 files changed, 465 insertions(+) create mode 100644 arch/arm/dts/meson-gx-libretech-pc.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc.dts create mode 100644 arch/arm/dts/meson-gxl-s905d.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc.dts
diff --git a/arch/arm/dts/meson-gx-libretech-pc.dtsi b/arch/arm/dts/meson-gx-libretech-pc.dtsi new file mode 100644 index 000000000000..248b018c83d5 --- /dev/null +++ b/arch/arm/dts/meson-gx-libretech-pc.dtsi @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019 BayLibre SAS. + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +/* Libretech Amlogic GX PC form factor - AKA: Tartiflette */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> + +/ { + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + update-button { + label = "update"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <1300000>; + }; + }; + + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + spi0 = &spifc; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + cvbs-connector { + compatible = "composite-video-connector"; + status = "disabled"; + + port { + cvbs_connector_in: endpoint { + remote-endpoint = <&cvbs_vdac_out>; + }; + }; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + power-button { + label = "power"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>; + }; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ao_5v: regulator-ao_5v { + compatible = "regulator-fixed"; + regulator-name = "AO_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + dc_in: regulator-dc_in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + leds { + compatible = "gpio-leds"; + + green { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK_ACTIVITY; + gpios = <&gpio_ao GPIOAO_9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "disk-activity"; + }; + + blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio GPIODV_28 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + panic-indicator; + }; + }; + + vcc_card: regulator-vcc_card { + compatible = "regulator-fixed"; + regulator-name = "VCC_CARD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vddio_ao3v3>; + + gpio = <&gpio GPIODV_4 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vcc5v: regulator-vcc5v { + compatible = "regulator-fixed"; + regulator-name = "VCC5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&ao_5v>; + + gpio = <&gpio GPIOH_3 GPIO_OPEN_DRAIN>; + }; + + vddio_ao18: regulator-vddio_ao18 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&ao_5v>; + regulator-always-on; + }; + + vddio_ao3v3: regulator-vddio_ao3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&ao_5v>; + regulator-always-on; + }; + + vddio_boot: regulator-vddio_boot { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_BOOT"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddio_ao3v3>; + regulator-always-on; + }; + + vddio_card: regulator-vddio-card { + compatible = "regulator-gpio"; + regulator-name = "VDDIO_CARD"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio GPIODV_5 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + + states = <3300000 0>, + <1800000 1>; + + regulator-settling-time-up-us = <200>; + regulator-settling-time-down-us = <50000>; + }; +}; + +&cec_AO { + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; + status = "okay"; +}; + +&cvbs_vdac_port { + cvbs_vdac_out: endpoint { + remote-endpoint = <&cvbs_connector_in>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_phy_irq_pins>; + pinctrl-names = "default"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; + phy-mode = "rgmii"; + status = "okay"; +}; + +&external_mdio { + external_phy: ethernet-phy@0 { + reg = <0>; + max-speed = <1000>; + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <25 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&pinctrl_periphs { + /* + * Make sure the reset pin of the usb HUB is driven high to take + * it out of reset. + */ + usb1_rst_pins: usb1_rst_irq { + mux { + groups = "GPIODV_3"; + function = "gpio_periphs"; + bias-disable; + output-high; + }; + }; + + /* Make sure the phy irq pin is properly configured as input */ + eth_phy_irq_pins: eth_phy_irq { + mux { + groups = "GPIOZ_15"; + function = "gpio_periphs"; + bias-disable; + output-disable; + }; + }; +}; + +&hdmi_tx { + pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc5v>; + status = "okay"; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&ir { + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&i2c_C { + pinctrl-0 = <&i2c_c_dv18_pins>; + pinctrl-names = "default"; + status = "okay"; + + rtc: rtc@51 { + reg = <0x51>; + compatible = "nxp,pcf8563"; + #clock-cells = <0>; + clock-output-names = "rtc_clkout"; + }; +}; + +&pwm_AO_ab { + pinctrl-0 = <&pwm_ao_a_3_pins>; + pinctrl-names = "default"; + clocks = <&clkc CLKID_FCLK_DIV4>; + clock-names = "clkin0"; + status = "okay"; +}; + +&pwm_ab { + pinctrl-0 = <&pwm_b_pins>; + pinctrl-names = "default"; + clocks = <&clkc CLKID_FCLK_DIV4>; + clock-names = "clkin0"; + status = "okay"; +}; + +&pwm_ef { + pinctrl-0 = <&pwm_e_pins>, <&pwm_f_clk_pins>; + pinctrl-names = "default"; + clocks = <&clkc CLKID_FCLK_DIV4>; + clock-names = "clkin0"; + status = "okay"; +}; + +&saradc { + vref-supply = <&vddio_ao18>; + status = "okay"; +}; + +/* SD card */ +&sd_emmc_b { + pinctrl-0 = <&sdcard_pins>; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-ddr50; + max-frequency = <200000000>; + disable-wp; + + cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; + + vmmc-supply = <&vcc_card>; + vqmmc-supply = <&vddio_card>; + + status = "okay"; +}; + +/* eMMC */ +&sd_emmc_c { + pinctrl-0 = <&emmc_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vddio_ao3v3>; + vqmmc-supply = <&vddio_boot>; + + status = "okay"; +}; + +&spifc { + pinctrl-0 = <&nor_pins>; + pinctrl-names = "default"; + status = "okay"; + + gd25lq128: spi-flash@0 { + compatible = "jedec,spi-nor"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + spi-max-frequency = <12000000>; + }; +}; + +&uart_AO { + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb2_phy0 { + pinctrl-0 = <&usb1_rst_pins>; + pinctrl-names = "default"; + phy-supply = <&vcc5v>; +}; + +&usb2_phy1 { + phy-supply = <&vcc5v>; +}; diff --git a/arch/arm/dts/meson-gxl-s905d-libretech-pc.dts b/arch/arm/dts/meson-gxl-s905d-libretech-pc.dts new file mode 100644 index 000000000000..100a1cfeea15 --- /dev/null +++ b/arch/arm/dts/meson-gxl-s905d-libretech-pc.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019 BayLibre SAS. All rights reserved. + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +/dts-v1/; + +#include "meson-gxl-s905d.dtsi" +#include "meson-gx-libretech-pc.dtsi" + +/ { + compatible = "libretech,aml-s905d-pc", "amlogic,s905d", + "amlogic,meson-gxl"; + model = "Libre Computer AML-S905D-PC"; +}; diff --git a/arch/arm/dts/meson-gxl-s905d.dtsi b/arch/arm/dts/meson-gxl-s905d.dtsi new file mode 100644 index 000000000000..43321919547a --- /dev/null +++ b/arch/arm/dts/meson-gxl-s905d.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016 Endless Computers, Inc. + * Author: Carlo Caione carlo@endlessm.com + */ + +#include "meson-gxl.dtsi" +#include "meson-gxl-mali.dtsi" + +/ { + compatible = "amlogic,s905d", "amlogic,meson-gxl"; +}; diff --git a/arch/arm/dts/meson-gxm-s912-libretech-pc.dts b/arch/arm/dts/meson-gxm-s912-libretech-pc.dts new file mode 100644 index 000000000000..444c249863cb --- /dev/null +++ b/arch/arm/dts/meson-gxm-s912-libretech-pc.dts @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019 BayLibre SAS. All rights reserved. + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +/dts-v1/; + +#include "meson-gxm.dtsi" +#include "meson-gx-libretech-pc.dtsi" + +/ { + compatible = "libretech,aml-s912-pc", "amlogic,s912", + "amlogic,meson-gxm"; + model = "Libre Computer AML-S912-PC"; + + typec2_vbus: regulator-typec2_vbus { + compatible = "regulator-fixed"; + regulator-name = "TYPEC2_VBUS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v>; + + gpio = <&gpio GPIODV_1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; + +&pinctrl_periphs { + /* + * Make sure the irq pin of the TYPE C controller is not driven + * by the SoC. + */ + fusb302_irq_pins: fusb302_irq { + mux { + groups = "GPIODV_0"; + function = "gpio_periphs"; + bias-pull-up; + output-disable; + }; + }; +}; + +&i2c_C { + fusb302@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + + pinctrl-0 = <&fusb302_irq_pins>; + pinctrl-names = "default"; + interrupt-parent = <&gpio_intc>; + interrupts = <59 IRQ_TYPE_LEVEL_LOW>; + + vbus-supply = <&typec2_vbus>; + + status = "okay"; + }; +}; + +&usb2_phy2 { + phy-supply = <&typec2_vbus>; +};
Add support for the Amlogic based libretech-pc platform. This platform comes with 2 variant, based on the s905d or s912 SoC.
Acked-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- arch/arm/dts/Makefile | 2 + .../meson-gxl-s905d-libretech-pc-u-boot.dtsi | 7 ++ .../meson-gxm-s912-libretech-pc-u-boot.dtsi | 7 ++ configs/libretech-s905d-pc_defconfig | 73 +++++++++++++++++++ configs/libretech-s912-pc_defconfig | 73 +++++++++++++++++++ 5 files changed, 162 insertions(+) create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi create mode 100644 configs/libretech-s905d-pc_defconfig create mode 100644 configs/libretech-s912-pc_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9c593b2c986a..cfe1b7849f46 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -147,7 +147,9 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-gxl-s805x-libretech-ac.dtb \ meson-gxl-s905x-libretech-cc.dtb \ meson-gxl-s905x-khadas-vim.dtb \ + meson-gxl-s905d-libretech-pc.dtb \ meson-gxm-khadas-vim2.dtb \ + meson-gxm-s912-libretech-pc.dtb \ meson-axg-s400.dtb \ meson-g12a-u200.dtb \ meson-g12a-sei510.dtb \ diff --git a/arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi b/arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi new file mode 100644 index 000000000000..c35158d7e9ee --- /dev/null +++ b/arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-gx-u-boot.dtsi" diff --git a/arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi b/arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi new file mode 100644 index 000000000000..c35158d7e9ee --- /dev/null +++ b/arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-gx-u-boot.dtsi" diff --git a/configs/libretech-s905d-pc_defconfig b/configs/libretech-s905d-pc_defconfig new file mode 100644 index 000000000000..7e0c95872a62 --- /dev/null +++ b/configs/libretech-s905d-pc_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="q200" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_MESON_GXL=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xFFFF0000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_IDENT_STRING=" libretech-s905d-pc" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="usb start" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxl-s905d-libretech-pc" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SARADC_MESON=y +CONFIG_DM_GPIO=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PHY=y +CONFIG_MESON_GXL_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXL=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_GX_VPU_POWER_DOMAIN=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MESON_SPIFC=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_DWC3=y +CONFIG_USB_KEYBOARD=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/libretech-s912-pc_defconfig b/configs/libretech-s912-pc_defconfig new file mode 100644 index 000000000000..5f4ee329e276 --- /dev/null +++ b/configs/libretech-s912-pc_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="q200" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_MESON_GXM=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xFFFF0000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_IDENT_STRING=" libretech-s912-pc" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="usb start" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxm-s912-libretech-pc" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SARADC_MESON=y +CONFIG_DM_GPIO=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PHY=y +CONFIG_MESON_GXL_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXL=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_GX_VPU_POWER_DOMAIN=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MESON_SPIFC=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_DWC3=y +CONFIG_USB_KEYBOARD=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_OF_LIBFDT_OVERLAY=y
On 05/03/2020 12:12, Jerome Brunet wrote:
Add libretech PC platform support. This platform comes in 2 variants, one with the s905d and the other s912.
While working on these boards, I've found a problem related the mmc clock. In some cases, the ROM code will leave the mmc clocks in such a weird state that any access to the mmc controller would lock the device.
Making sure the MMC clocks are properly reset and enabled is enough to solve the problem.
I have also synced all amlogic supported dts. Since I had to update the gx dsti files, it made sense to update the dts as well. This is done to keep things coherent even if it is not the original purpose of this series.
Changes since v2:
- actually rebase on master
Changes since v1:
- Split dt sync, libretech-pc import and config addition.
- Rebase on master (... not really)
Jerome Brunet (6): dt-bindings: leds: import common led bindings from linux v5.5 mmc: meson-gx: enable input clocks clk: meson: reset mmc clock on probe arm64: dts: meson: sync dt and bindings from v5.6-rc2 arm64: dts: meson: import libretech-pc from linux v5.6-rc2 arm64: dts: meson: add libretech-pc support
arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-axg-s400.dts | 70 ++- arch/arm/dts/meson-axg.dtsi | 273 ++++++++-- arch/arm/dts/meson-g12-common.dtsi | 478 ++++++------------ arch/arm/dts/meson-g12.dtsi | 398 +++++++++++++++ arch/arm/dts/meson-g12a-sei510.dts | 64 +++ arch/arm/dts/meson-g12a-u200.dts | 54 ++ arch/arm/dts/meson-g12a.dtsi | 33 +- arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 25 + arch/arm/dts/meson-g12b-odroid-n2.dts | 2 +- arch/arm/dts/meson-g12b.dtsi | 26 +- arch/arm/dts/meson-gx-libretech-pc.dtsi | 375 ++++++++++++++ arch/arm/dts/meson-gx.dtsi | 87 +++- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 26 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 100 +++- arch/arm/dts/meson-gxbb-p200.dts | 9 +- arch/arm/dts/meson-gxbb-p201.dts | 2 +- arch/arm/dts/meson-gxbb-p20x.dtsi | 9 +- arch/arm/dts/meson-gxbb.dtsi | 118 ++++- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- .../meson-gxl-s905d-libretech-pc-u-boot.dtsi | 7 + arch/arm/dts/meson-gxl-s905d-libretech-pc.dts | 16 + arch/arm/dts/meson-gxl-s905d.dtsi | 12 + arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 20 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 26 +- arch/arm/dts/meson-gxl-s905x-p212.dtsi | 10 +- arch/arm/dts/meson-gxl.dtsi | 76 ++- arch/arm/dts/meson-gxm-khadas-vim2.dts | 71 +-- .../meson-gxm-s912-libretech-pc-u-boot.dtsi | 7 + arch/arm/dts/meson-gxm-s912-libretech-pc.dts | 62 +++ arch/arm/dts/meson-gxm.dtsi | 39 +- arch/arm/dts/meson-khadas-vim3.dtsi | 7 + arch/arm/dts/meson-sm1-sei610.dts | 236 ++++++++- arch/arm/dts/meson-sm1.dtsi | 356 +++++++++++++ configs/libretech-s905d-pc_defconfig | 73 +++ configs/libretech-s912-pc_defconfig | 73 +++ drivers/clk/meson/axg.c | 7 + drivers/clk/meson/g12a.c | 7 + drivers/clk/meson/gxbb.c | 7 + drivers/mmc/meson_gx_mmc.c | 14 +- include/dt-bindings/clock/axg-audio-clkc.h | 10 + include/dt-bindings/clock/gxbb-aoclkc.h | 7 + include/dt-bindings/clock/gxbb-clkc.h | 21 + include/dt-bindings/gpio/meson-gxbb-gpio.h | 8 +- include/dt-bindings/gpio/meson-gxl-gpio.h | 8 +- include/dt-bindings/leds/common.h | 75 +++ .../reset/amlogic,meson-axg-audio-arb.h | 2 + .../reset/amlogic,meson-axg-reset.h | 3 +- .../reset/amlogic,meson-g12a-audio-reset.h | 15 + .../reset/amlogic,meson-gxbb-reset.h | 51 +- 50 files changed, 2855 insertions(+), 624 deletions(-) create mode 100644 arch/arm/dts/meson-g12.dtsi create mode 100644 arch/arm/dts/meson-gx-libretech-pc.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905d-libretech-pc.dts create mode 100644 arch/arm/dts/meson-gxl-s905d.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxm-s912-libretech-pc.dts create mode 100644 configs/libretech-s905d-pc_defconfig create mode 100644 configs/libretech-s912-pc_defconfig create mode 100644 include/dt-bindings/leds/common.h
Applied to u-boot-amlogic for next release
I'll run tests on most board to check nothing was broken.
Neil
Anand Moon
Jerome Brunet
Neil Armstrong
