[U-Boot] [PATCH] Correct ffs/fls regression for PowerPC etc
Commits
02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405
introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself.
Signed-off-by: Simon Kagstrom simon.kagstrom@netinsight.net --- I've runtime tested on ARM (OpenRD base) and build-tested on MPC8536DS, where __ilog2_u64 now at least is non-empty. It would be nice if (at least!) some PowerPC people could test the patch.
include/asm-arm/bitops.h | 8 -------- include/asm-blackfin/bitops.h | 10 +--------- include/asm-i386/bitops.h | 2 +- include/asm-m68k/bitops.h | 2 +- include/asm-microblaze/bitops.h | 3 ++- include/asm-mips/bitops.h | 13 +------------ include/asm-nios/bitops.h | 2 +- include/asm-nios2/bitops.h | 2 +- include/asm-ppc/bitops.h | 4 ++-- include/asm-sh/bitops.h | 2 +- include/linux/bitops.h | 8 ++++---- 11 files changed, 15 insertions(+), 41 deletions(-)
diff --git a/include/asm-arm/bitops.h b/include/asm-arm/bitops.h index 3c7b00c..270f163 100644 --- a/include/asm-arm/bitops.h +++ b/include/asm-arm/bitops.h @@ -125,14 +125,6 @@ static inline unsigned long ffz(unsigned long word) }
/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - -/* * hweightN: returns the hamming weight (i.e. the number * of bits set) of a N-bit word */ diff --git a/include/asm-blackfin/bitops.h b/include/asm-blackfin/bitops.h index cc3685d..f469f1c 100644 --- a/include/asm-blackfin/bitops.h +++ b/include/asm-blackfin/bitops.h @@ -79,7 +79,7 @@ static __inline__ void __set_bit(int nr, volatile void *addr) mask = 1 << (nr & 0x1f); *a |= mask; } -#define __set_bit +#define PLATFORM__set_bit
/* * clear_bit() doesn't provide any barrier for the compiler. @@ -270,14 +270,6 @@ static __inline__ int find_next_zero_bit(void *addr, int size, int offset) }
/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - -/* * hweightN: returns the hamming weight (i.e. the number * of bits set) of a N-bit word */ diff --git a/include/asm-i386/bitops.h b/include/asm-i386/bitops.h index ac6285a..c7a38f2 100644 --- a/include/asm-i386/bitops.h +++ b/include/asm-i386/bitops.h @@ -349,7 +349,7 @@ static __inline__ int ffs(int x) "1:" : "=r" (r) : "g" (x)); return r+1; } -#define ffs +#define PLATFORM_FFS
/** * hweightN - returns the hamming weight of a N-bit word diff --git a/include/asm-m68k/bitops.h b/include/asm-m68k/bitops.h index e0c35fa..ad971b4 100644 --- a/include/asm-m68k/bitops.h +++ b/include/asm-m68k/bitops.h @@ -51,7 +51,7 @@ extern __inline__ int ffs(int x) return r; } #define __ffs(x) (ffs(x) - 1) -#define ffs +#define PLATFORM_FFS
#endif /* __KERNEL__ */
diff --git a/include/asm-microblaze/bitops.h b/include/asm-microblaze/bitops.h index aac9061..3b39e16 100644 --- a/include/asm-microblaze/bitops.h +++ b/include/asm-microblaze/bitops.h @@ -23,6 +23,7 @@ extern void __set_bit(int nr, volatile void * addr);
extern void clear_bit(int nr, volatile void * addr); #define __clear_bit(nr, addr) clear_bit(nr, addr) +#define PLATFORM__clear_bit
extern void change_bit(int nr, volatile void * addr); extern void __change_bit(int nr, volatile void * addr); @@ -75,7 +76,7 @@ extern __inline__ void __set_bit(int nr, volatile void * addr) mask = 1 << (nr & 0x1f); *a |= mask; } -#define __set_bit +#define PLATFORM__set_bit
/* * clear_bit() doesn't provide any barrier for the compiler. diff --git a/include/asm-mips/bitops.h b/include/asm-mips/bitops.h index 0c07b68..18dee51 100644 --- a/include/asm-mips/bitops.h +++ b/include/asm-mips/bitops.h @@ -90,7 +90,7 @@ static __inline__ void __set_bit(int nr, volatile void * addr)
*m |= 1UL << (nr & 31); } -#define __set_bit +#define PLATFORM__set_bit
/* * clear_bit - Clears a bit in memory @@ -706,17 +706,6 @@ static __inline__ unsigned long ffz(unsigned long word)
#ifdef __KERNEL__
-/** - * ffs - find first bit set - * @x: the word to search - * - * This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - /* * hweightN - returns the hamming weight of a N-bit word * @x: the word to weigh diff --git a/include/asm-nios/bitops.h b/include/asm-nios/bitops.h index 8315fb7..2047b7c 100644 --- a/include/asm-nios/bitops.h +++ b/include/asm-nios/bitops.h @@ -33,6 +33,6 @@ extern int test_and_set_bit(int nr, volatile void * a); extern int test_and_change_bit(int nr, volatile void * addr); extern int test_bit(int nr, volatile void * a); extern int ffs(int i); -#define ffs +#define PLATFORM_ffs
#endif /* _ASM_NIOS_BITOPS_H */ diff --git a/include/asm-nios2/bitops.h b/include/asm-nios2/bitops.h index b01a89d..c4851ef 100644 --- a/include/asm-nios2/bitops.h +++ b/include/asm-nios2/bitops.h @@ -33,6 +33,6 @@ extern int test_and_set_bit(int nr, volatile void * a); extern int test_and_change_bit(int nr, volatile void * addr); extern int test_bit(int nr, volatile void * a); extern int ffs(int i); -#define ffs +#define PLATFORM_ffs
#endif /* __ASM_NIOS2_BITOPS_H */ diff --git a/include/asm-ppc/bitops.h b/include/asm-ppc/bitops.h index 9ed2f5d..1ad1256 100644 --- a/include/asm-ppc/bitops.h +++ b/include/asm-ppc/bitops.h @@ -178,7 +178,7 @@ static __inline__ int fls(unsigned int x) { return __ilog2(x) + 1; } -#define fls +#define PLATFORM_fls
/** * fls64 - find last set bit in a 64-bit word @@ -231,7 +231,7 @@ extern __inline__ int ffs(int x) { return __ilog2(x & -x) + 1; } -#define ffs +#define PLATFORM_ffs
/* * hweightN: returns the hamming weight (i.e. the number diff --git a/include/asm-sh/bitops.h b/include/asm-sh/bitops.h index 95167bd..405c9ff 100644 --- a/include/asm-sh/bitops.h +++ b/include/asm-sh/bitops.h @@ -146,7 +146,7 @@ static inline int ffs (int x) } return r; } -#define ffs +#define PLATFORM_ffs
diff --git a/include/linux/bitops.h b/include/linux/bitops.h index e14e6c7..2ea19ce 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -111,19 +111,19 @@ static inline unsigned int generic_hweight8(unsigned int w)
/* linux/include/asm-generic/bitops/non-atomic.h */
-#ifndef __set_bit +#ifndef PLATFORM__set_bit # define __set_bit generic_set_bit #endif
-#ifndef __clear_bit +#ifndef PLATFORM__clear_bit # define __clear_bit generic_clear_bit #endif
-#ifndef ffs +#ifndef PLATFORM_ffs # define ffs generic_ffs #endif
-#ifndef fls +#ifndef PLATFORM_fls # define fls generic_fls #endif
Hi Simon,
Commits
Thanks. I tested it on my faulting ppc4xx platform (sequoia). And the problem is gone now, so thanks.
But I've spotted a problem with other platforms in this patch. See below...
- ffs: find first bit set. This is defined the same way as
- the libc and compiler builtin ffs routines, therefore
- differs in spirit from the above ffz (man ffs).
- hweightN: returns the hamming weight (i.e. the number
- of bits set) of a N-bit word
- clear_bit() doesn't provide any barrier for the compiler.
Here you define "FFS" in upper case.
- hweightN - returns the hamming weight of a N-bit word
And here again.
- clear_bit - Clears a bit in memory
#ifdef __KERNEL__
- ffs - find first bit set
- @x: the word to search
- This is defined the same way as
- @x: the word to weigh
Here it's lower case.
<snip>
And here you check against lower case "_ffs". So the platforms with upper case "_FFS" are still broken. Please fix and resubmit.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
Thanks for testing.
... which is acctually correct, as macro names _shall_ use upper case letters.
This is not a legal macro name.
Yeah, the patch is not clean.
Simon, this needs to be cleaned up. Please make sure to use upper case macro names only.
Commits
ChangeLog:
v2 - Make _all_ macros upper case (Stefan, Wolfgang)
/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - -/* * hweightN: returns the hamming weight (i.e. the number * of bits set) of a N-bit word */ diff --git a/include/asm-blackfin/bitops.h b/include/asm-blackfin/bitops.h index cc3685d..ab1fea5 100644 --- a/include/asm-blackfin/bitops.h +++ b/include/asm-blackfin/bitops.h @@ -79,7 +79,7 @@ static __inline__ void __set_bit(int nr, volatile void *addr) mask = 1 << (nr & 0x1f); *a |= mask; } -#define __set_bit +#define PLATFORM__SET_BIT
diff --git a/include/asm-microblaze/bitops.h b/include/asm-microblaze/bitops.h index aac9061..5d814f0 100644 --- a/include/asm-microblaze/bitops.h +++ b/include/asm-microblaze/bitops.h @@ -23,6 +23,7 @@ extern void __set_bit(int nr, volatile void * addr);
extern void clear_bit(int nr, volatile void * addr); #define __clear_bit(nr, addr) clear_bit(nr, addr) +#define PLATFORM__CLEAR_BIT
extern void change_bit(int nr, volatile void * addr); extern void __change_bit(int nr, volatile void * addr); @@ -75,7 +76,7 @@ extern __inline__ void __set_bit(int nr, volatile void * addr) mask = 1 << (nr & 0x1f); *a |= mask; } -#define __set_bit +#define PLATFORM__SET_BIT
/* * clear_bit() doesn't provide any barrier for the compiler. diff --git a/include/asm-mips/bitops.h b/include/asm-mips/bitops.h index 0c07b68..1c8f4c0 100644 --- a/include/asm-mips/bitops.h +++ b/include/asm-mips/bitops.h @@ -90,7 +90,7 @@ static __inline__ void __set_bit(int nr, volatile void * addr)
*m |= 1UL << (nr & 31); } -#define __set_bit +#define PLATFORM__SET_BIT
#ifdef __KERNEL__
-/** - * ffs - find first bit set - * @x: the word to search - * - * This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - /* * hweightN - returns the hamming weight of a N-bit word * @x: the word to weigh diff --git a/include/asm-nios/bitops.h b/include/asm-nios/bitops.h index 8315fb7..0be74f4 100644 --- a/include/asm-nios/bitops.h +++ b/include/asm-nios/bitops.h @@ -33,6 +33,6 @@ extern int test_and_set_bit(int nr, volatile void * a); extern int test_and_change_bit(int nr, volatile void * addr); extern int test_bit(int nr, volatile void * a); extern int ffs(int i); -#define ffs +#define PLATFORM_FFS
#endif /* _ASM_NIOS_BITOPS_H */ diff --git a/include/asm-nios2/bitops.h b/include/asm-nios2/bitops.h index b01a89d..5776bda 100644 --- a/include/asm-nios2/bitops.h +++ b/include/asm-nios2/bitops.h @@ -33,6 +33,6 @@ extern int test_and_set_bit(int nr, volatile void * a); extern int test_and_change_bit(int nr, volatile void * addr); extern int test_bit(int nr, volatile void * a); extern int ffs(int i); -#define ffs +#define PLATFORM_FFS
#endif /* __ASM_NIOS2_BITOPS_H */ diff --git a/include/asm-ppc/bitops.h b/include/asm-ppc/bitops.h index 9ed2f5d..adaf091 100644 --- a/include/asm-ppc/bitops.h +++ b/include/asm-ppc/bitops.h @@ -178,7 +178,7 @@ static __inline__ int fls(unsigned int x) { return __ilog2(x) + 1; } -#define fls +#define PLATFORM_FLS
/** * fls64 - find last set bit in a 64-bit word @@ -231,7 +231,7 @@ extern __inline__ int ffs(int x) { return __ilog2(x & -x) + 1; } -#define ffs +#define PLATFORM_FFS
/* * hweightN: returns the hamming weight (i.e. the number diff --git a/include/asm-sh/bitops.h b/include/asm-sh/bitops.h index 95167bd..c57d628 100644 --- a/include/asm-sh/bitops.h +++ b/include/asm-sh/bitops.h @@ -146,7 +146,7 @@ static inline int ffs (int x) } return r; } -#define ffs +#define PLATFORM_FFS
diff --git a/include/linux/bitops.h b/include/linux/bitops.h index e14e6c7..e724310 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -111,19 +111,19 @@ static inline unsigned int generic_hweight8(unsigned int w)
-#ifndef __set_bit +#ifndef PLATFORM__SET_BIT # define __set_bit generic_set_bit #endif
-#ifndef __clear_bit +#ifndef PLATFORM__CLEAR_BIT # define __clear_bit generic_clear_bit #endif
-#ifndef ffs +#ifndef PLATFORM_FFS # define ffs generic_ffs #endif
-#ifndef fls +#ifndef PLATFORM_FLS # define fls generic_fls #endif
Commits
ChangeLog:
Acked-by: Kumar Gala galak@kernel.crashing.org
This fixes the issue I was seeing.
- k
Commits
You have the subject "Correct ffs/fls regression for PowerPC etc" twice in the commit message, once in the email subject and once at the beginning of the mail body.
Other than this:
Acked-by: Stefan Roese sr@denx.de
Thanks.
Cheers, Stefan
Well, I'll admit that I haven't setup git to send emails yet, so I simply paste them into my regular mail program. I'll submit with the first line only in the subject from now on.
Or setup git-send-email one day :-)
// Simon
Yes, git send-email really saves time and trouble from my experience. :)
Cheers, Stefan
Dear Simon Kagstrom,
Commits
ChangeLog:
Applied, thanks.
Kumar Gala
Simon Kagstrom
Stefan Roese
