[U-Boot] [PATCH v2 0/5] Marvell DB-XC3-24G4XG board support
This series adds support for Marvell's Switches with integrated CPUs and the DB-XC3-24G4XG board. The CPU side is similar to the Armada range.
For now the DDR training code needs to come from the Marvell bin_hdr. It's one area where the integrated SoCs differ from the Armada range so neither the Armada-XP nor Armada-38x training code will work as-is. I'm asking Marvell about the possibility of re-licensing the code under a Proprietary/BSD/GPL as they did with Armada-38x.
I also have access to a DB-DXBC2-MM board with a different chip. I'll look at adding support for that as well at some point. It's harder to work with because it has no USB, but other than that it's similar to the DB-XC3.
Changes in v2: - use CONFIG_ARMADA_MSYS instead of just CONFIG_MSYS - Disable MBUS Error proagation - new, split out from Add DB-XC3-24G4XG board with a better explanation - u-boot specific changes in u-boot.dtsi - remove unnecessary entries from board config.h - move some changes to earlier patches
Chris Packham (5): arm: sync armada-xp dts files from Linux 5.0 arm: mvebu: Add Marvell's integrated CPUs arm: mvebu: NAND clock support for MSYS devices tools: kwbimage: don't adjust for image_header for Armada MSYS arm: mvebu: Add DB-XC3-24G4XG board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/armada-370-xp.dtsi | 133 +++---- arch/arm/dts/armada-xp-98dx3236.dtsi | 343 ++++++++++++++++++ arch/arm/dts/armada-xp-98dx3336.dtsi | 39 ++ arch/arm/dts/armada-xp-98dx4251.dtsi | 54 +++ .../dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 24 ++ arch/arm/dts/armada-xp-db-xc3-24g4xg.dts | 110 ++++++ arch/arm/dts/armada-xp-gp.dts | 167 ++++----- arch/arm/dts/armada-xp-maxbcm.dts | 24 +- arch/arm/dts/armada-xp-mv78230.dtsi | 55 +-- arch/arm/dts/armada-xp-mv78260.dtsi | 58 +-- arch/arm/dts/armada-xp-mv78460.dtsi | 58 +-- arch/arm/dts/armada-xp-synology-ds414.dts | 199 +++++----- arch/arm/dts/armada-xp-theadorable.dts | 69 ++-- arch/arm/dts/armada-xp.dtsi | 214 ++++++----- arch/arm/mach-mvebu/Kconfig | 26 +- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 33 +- arch/arm/mach-mvebu/include/mach/config.h | 2 +- arch/arm/mach-mvebu/include/mach/cpu.h | 3 + arch/arm/mach-mvebu/include/mach/soc.h | 31 ++ arch/arm/mach-mvebu/mbus.c | 5 + board/Marvell/db-xc3-24g4xg/MAINTAINERS | 7 + board/Marvell/db-xc3-24g4xg/Makefile | 5 + board/Marvell/db-xc3-24g4xg/README | 4 + board/Marvell/db-xc3-24g4xg/binary.0 | 11 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 68 ++++ board/Marvell/db-xc3-24g4xg/kwbimage.cfg | 12 + configs/db-xc3-24g4xg_defconfig | 55 +++ drivers/ddr/marvell/axp/xor_regs.h | 4 + include/configs/db-xc3-24g4xg.h | 41 +++ tools/Makefile | 4 + tools/kwbimage.c | 4 + 33 files changed, 1319 insertions(+), 547 deletions(-) create mode 100644 arch/arm/dts/armada-xp-98dx3236.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx3336.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx4251.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg.dts create mode 100644 board/Marvell/db-xc3-24g4xg/MAINTAINERS create mode 100644 board/Marvell/db-xc3-24g4xg/Makefile create mode 100644 board/Marvell/db-xc3-24g4xg/README create mode 100644 board/Marvell/db-xc3-24g4xg/binary.0 create mode 100644 board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c create mode 100644 board/Marvell/db-xc3-24g4xg/kwbimage.cfg create mode 100644 configs/db-xc3-24g4xg_defconfig create mode 100644 include/configs/db-xc3-24g4xg.h
Bring in the Armada 370/XP dts/dtsi files from Linux. As U-Boot hasn't got the new NAND driver the updating binding has not been included.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v2: None
arch/arm/dts/armada-370-xp.dtsi | 133 ++++++-------- arch/arm/dts/armada-xp-gp.dts | 167 +++++++---------- arch/arm/dts/armada-xp-maxbcm.dts | 24 +-- arch/arm/dts/armada-xp-mv78230.dtsi | 55 ++---- arch/arm/dts/armada-xp-mv78260.dtsi | 58 ++---- arch/arm/dts/armada-xp-mv78460.dtsi | 58 ++---- arch/arm/dts/armada-xp-synology-ds414.dts | 199 ++++++++++---------- arch/arm/dts/armada-xp-theadorable.dts | 69 +++---- arch/arm/dts/armada-xp.dtsi | 214 ++++++++++++---------- 9 files changed, 435 insertions(+), 542 deletions(-)
diff --git a/arch/arm/dts/armada-370-xp.dtsi b/arch/arm/dts/armada-370-xp.dtsi index 0b2a78d39301..e4c35d4e98f4 100644 --- a/arch/arm/dts/armada-370-xp.dtsi +++ b/arch/arm/dts/armada-370-xp.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree Include file for Marvell Armada 370 and Armada XP SoC * @@ -8,50 +9,10 @@ * Thomas Petazzoni thomas.petazzoni@free-electrons.com * Ben Dooks ben.dooks@codethink.co.uk * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * This file contains the definitions that are common to the Armada * 370 and Armada XP SoC. */
-/include/ "skeleton64.dtsi" - #define MBUS_ID(target,attributes) (((target) << 24) | ((attributes) << 16))
/ { @@ -86,7 +47,7 @@ pcie-mem-aperture = <0xf8000000 0x7e00000>; pcie-io-aperture = <0xffe00000 0x100000>;
- devbus-bootcs { + devbus_bootcs: devbus-bootcs { compatible = "marvell,mvebu-devbus"; reg = <MBUS_ID(0xf0, 0x01) 0x10400 0x8>; ranges = <0 MBUS_ID(0x01, 0x2f) 0 0xffffffff>; @@ -96,7 +57,7 @@ status = "disabled"; };
- devbus-cs0 { + devbus_cs0: devbus-cs0 { compatible = "marvell,mvebu-devbus"; reg = <MBUS_ID(0xf0, 0x01) 0x10408 0x8>; ranges = <0 MBUS_ID(0x01, 0x3e) 0 0xffffffff>; @@ -106,7 +67,7 @@ status = "disabled"; };
- devbus-cs1 { + devbus_cs1: devbus-cs1 { compatible = "marvell,mvebu-devbus"; reg = <MBUS_ID(0xf0, 0x01) 0x10410 0x8>; ranges = <0 MBUS_ID(0x01, 0x3d) 0 0xffffffff>; @@ -116,7 +77,7 @@ status = "disabled"; };
- devbus-cs2 { + devbus_cs2: devbus-cs2 { compatible = "marvell,mvebu-devbus"; reg = <MBUS_ID(0xf0, 0x01) 0x10418 0x8>; ranges = <0 MBUS_ID(0x01, 0x3b) 0 0xffffffff>; @@ -126,7 +87,7 @@ status = "disabled"; };
- devbus-cs3 { + devbus_cs3: devbus-cs3 { compatible = "marvell,mvebu-devbus"; reg = <MBUS_ID(0xf0, 0x01) 0x10420 0x8>; ranges = <0 MBUS_ID(0x01, 0x37) 0 0xffffffff>; @@ -141,34 +102,13 @@ #address-cells = <1>; #size-cells = <1>; ranges = <0 MBUS_ID(0xf0, 0x01) 0 0x100000>; - u-boot,dm-pre-reloc;
- rtc@10300 { + rtc: rtc@10300 { compatible = "marvell,orion-rtc"; reg = <0x10300 0x20>; interrupts = <50>; };
- spi0: spi@10600 { - reg = <0x10600 0x28>; - #address-cells = <1>; - #size-cells = <0>; - cell-index = <0>; - interrupts = <30>; - clocks = <&coreclk 0>; - status = "disabled"; - }; - - spi1: spi@10680 { - reg = <0x10680 0x28>; - #address-cells = <1>; - #size-cells = <0>; - cell-index = <1>; - interrupts = <92>; - clocks = <&coreclk 0>; - status = "disabled"; - }; - i2c0: i2c@11000 { compatible = "marvell,mv64xxx-i2c"; #address-cells = <1>; @@ -235,33 +175,38 @@ msi-controller; };
- coherency-fabric@20200 { + coherencyfab: coherency-fabric@20200 { compatible = "marvell,coherency-fabric"; reg = <0x20200 0xb0>, <0x21010 0x1c>; };
- timer@20300 { + timer: timer@20300 { reg = <0x20300 0x30>, <0x21040 0x30>; interrupts = <37>, <38>, <39>, <40>, <5>, <6>; };
- watchdog@20300 { + watchdog: watchdog@20300 { reg = <0x20300 0x34>, <0x20704 0x4>; };
- pmsu@22000 { + cpurst: cpurst@20800 { + compatible = "marvell,armada-370-cpu-reset"; + reg = <0x20800 0x8>; + }; + + pmsu: pmsu@22000 { compatible = "marvell,armada-370-pmsu"; reg = <0x22000 0x1000>; };
- usb@50000 { + usb0: usb@50000 { compatible = "marvell,orion-ehci"; reg = <0x50000 0x500>; interrupts = <45>; status = "disabled"; };
- usb@51000 { + usb1: usb@51000 { compatible = "marvell,orion-ehci"; reg = <0x51000 0x500>; interrupts = <46>; @@ -275,7 +220,7 @@ status = "disabled"; };
- mdio: mdio { + mdio: mdio@72004 { #address-cells = <1>; #size-cells = <0>; compatible = "marvell,orion-mdio"; @@ -290,7 +235,7 @@ status = "disabled"; };
- sata@a0000 { + sata: sata@a0000 { compatible = "marvell,armada-370-sata"; reg = <0xa0000 0x5000>; interrupts = <55>; @@ -309,7 +254,7 @@ status = "disabled"; };
- mvsdio@d4000 { + sdio: mvsdio@d4000 { compatible = "marvell,orion-sdio"; reg = <0xd4000 0x200>; interrupts = <54>; @@ -321,6 +266,42 @@ status = "disabled"; }; }; + + spi0: spi@10600 { + reg = <MBUS_ID(0xf0, 0x01) 0x10600 0x28>, /* control */ + <MBUS_ID(0x01, 0x1e) 0 0xffffffff>, /* CS0 */ + <MBUS_ID(0x01, 0x5e) 0 0xffffffff>, /* CS1 */ + <MBUS_ID(0x01, 0x9e) 0 0xffffffff>, /* CS2 */ + <MBUS_ID(0x01, 0xde) 0 0xffffffff>, /* CS3 */ + <MBUS_ID(0x01, 0x1f) 0 0xffffffff>, /* CS4 */ + <MBUS_ID(0x01, 0x5f) 0 0xffffffff>, /* CS5 */ + <MBUS_ID(0x01, 0x9f) 0 0xffffffff>, /* CS6 */ + <MBUS_ID(0x01, 0xdf) 0 0xffffffff>; /* CS7 */ + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + interrupts = <30>; + clocks = <&coreclk 0>; + status = "disabled"; + }; + + spi1: spi@10680 { + reg = <MBUS_ID(0xf0, 0x01) 0x10680 0x28>, /* control */ + <MBUS_ID(0x01, 0x1a) 0 0xffffffff>, /* CS0 */ + <MBUS_ID(0x01, 0x5a) 0 0xffffffff>, /* CS1 */ + <MBUS_ID(0x01, 0x9a) 0 0xffffffff>, /* CS2 */ + <MBUS_ID(0x01, 0xda) 0 0xffffffff>, /* CS3 */ + <MBUS_ID(0x01, 0x1b) 0 0xffffffff>, /* CS4 */ + <MBUS_ID(0x01, 0x5b) 0 0xffffffff>, /* CS5 */ + <MBUS_ID(0x01, 0x9b) 0 0xffffffff>, /* CS6 */ + <MBUS_ID(0x01, 0xdb) 0 0xffffffff>; /* CS7 */ + #address-cells = <1>; + #size-cells = <0>; + cell-index = <1>; + interrupts = <92>; + clocks = <&coreclk 0>; + status = "disabled"; + }; };
clocks { diff --git a/arch/arm/dts/armada-xp-gp.dts b/arch/arm/dts/armada-xp-gp.dts index 27799d1254ea..1139e9469a83 100644 --- a/arch/arm/dts/armada-xp-gp.dts +++ b/arch/arm/dts/armada-xp-gp.dts @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree file for Marvell Armada XP development board * (DB-MV784MP-GP) @@ -8,44 +9,6 @@ * Gregory CLEMENT gregory.clement@free-electrons.com * Thomas Petazzoni thomas.petazzoni@free-electrons.com * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * Note: this Device Tree assumes that the bootloader has remapped the * internal registers to 0xf1000000 (instead of the default * 0xd0000000). The 0xf1000000 is the default used by the recent, @@ -68,11 +31,7 @@ stdout-path = "serial0:115200n8"; };
- aliases { - spi0 = &spi0; - }; - - memory { + memory@0 { device_type = "memory"; /* * 8 GB of plug-in RAM modules by default.The amount @@ -98,7 +57,10 @@ soc { ranges = <MBUS_ID(0xf0, 0x01) 0 0 0xf1000000 0x100000 MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000 - MBUS_ID(0x01, 0x2f) 0 0 0xf0000000 0x1000000>; + MBUS_ID(0x01, 0x2f) 0 0 0xf0000000 0x1000000 + MBUS_ID(0x09, 0x09) 0 0 0xf1100000 0x10000 + MBUS_ID(0x09, 0x05) 0 0 0xf1110000 0x10000 + MBUS_ID(0x0c, 0x04) 0 0 0xf1200000 0x100000>;
devbus-bootcs { status = "okay"; @@ -128,31 +90,9 @@ }; };
- pcie-controller { - status = "okay"; - - /* - * The 3 slots are physically present as - * standard PCIe slots on the board. - */ - pcie@1,0 { - /* Port 0, Lane 0 */ - status = "okay"; - }; - pcie@9,0 { - /* Port 2, Lane 0 */ - status = "okay"; - }; - pcie@10,0 { - /* Port 3, Lane 0 */ - status = "okay"; - }; - }; - internal-regs { serial@12000 { status = "okay"; - u-boot,dm-pre-reloc; }; serial@12100 { status = "okay"; @@ -177,43 +117,33 @@ status = "okay"; };
- mdio { - phy0: ethernet-phy@0 { - reg = <16>; - }; - - phy1: ethernet-phy@1 { - reg = <17>; - }; - - phy2: ethernet-phy@2 { - reg = <18>; - }; - - phy3: ethernet-phy@3 { - reg = <19>; - }; - }; - ethernet@70000 { status = "okay"; phy = <&phy0>; phy-mode = "qsgmii"; + buffer-manager = <&bm>; + bm,pool-long = <0>; }; ethernet@74000 { status = "okay"; phy = <&phy1>; phy-mode = "qsgmii"; + buffer-manager = <&bm>; + bm,pool-long = <1>; }; ethernet@30000 { status = "okay"; phy = <&phy2>; phy-mode = "qsgmii"; + buffer-manager = <&bm>; + bm,pool-long = <2>; }; ethernet@34000 { status = "okay"; phy = <&phy3>; phy-mode = "qsgmii"; + buffer-manager = <&bm>; + bm,pool-long = <3>; };
/* Front-side USB slot */ @@ -226,27 +156,72 @@ status = "okay"; };
- spi0: spi@10600 { + bm@c0000 { status = "okay"; - u-boot,dm-pre-reloc; - - spi-flash@0 { - u-boot,dm-pre-reloc; - #address-cells = <1>; - #size-cells = <1>; - compatible = "n25q128a13", "jedec,spi-nor"; - reg = <0>; /* Chip select 0 */ - spi-max-frequency = <108000000>; - }; };
nand@d0000 { status = "okay"; + label = "pxa3xx_nand-0"; num-cs = <1>; marvell,nand-keep-config; - marvell,nand-enable-arbiter; nand-on-flash-bbt; }; }; + + bm-bppi { + status = "okay"; + }; + }; +}; + +&pciec { + status = "okay"; + + /* + * The 3 slots are physically present as + * standard PCIe slots on the board. + */ + pcie@1,0 { + /* Port 0, Lane 0 */ + status = "okay"; + }; + pcie@9,0 { + /* Port 2, Lane 0 */ + status = "okay"; + }; + pcie@a,0 { + /* Port 3, Lane 0 */ + status = "okay"; + }; +}; + +&mdio { + phy0: ethernet-phy@0 { + reg = <16>; + }; + + phy1: ethernet-phy@1 { + reg = <17>; + }; + + phy2: ethernet-phy@2 { + reg = <18>; + }; + + phy3: ethernet-phy@3 { + reg = <19>; + }; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q128a13", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; }; }; diff --git a/arch/arm/dts/armada-xp-maxbcm.dts b/arch/arm/dts/armada-xp-maxbcm.dts index d7d7f65c85fe..921eb7086254 100644 --- a/arch/arm/dts/armada-xp-maxbcm.dts +++ b/arch/arm/dts/armada-xp-maxbcm.dts @@ -225,18 +225,6 @@ status = "okay"; };
- spi0: spi@10600 { - status = "okay"; - - spi-flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "n25q128a13", "jedec,spi-nor"; - reg = <0>; /* Chip select 0 */ - spi-max-frequency = <108000000>; - }; - }; - nand@d0000 { status = "okay"; num-cs = <1>; @@ -247,3 +235,15 @@ }; }; }; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q128a13", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + }; +}; diff --git a/arch/arm/dts/armada-xp-mv78230.dtsi b/arch/arm/dts/armada-xp-mv78230.dtsi index f6bab9fb20a9..8558bf6bb54c 100644 --- a/arch/arm/dts/armada-xp-mv78230.dtsi +++ b/arch/arm/dts/armada-xp-mv78230.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree Include file for Marvell Armada XP family SoC * @@ -5,44 +6,6 @@ * * Thomas Petazzoni thomas.petazzoni@free-electrons.com * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * Contains definitions specific to the Armada XP MV78230 SoC that are not * common to all Armada XP SoCs. */ @@ -207,25 +170,33 @@
internal-regs { gpio0: gpio@18100 { - compatible = "marvell,orion-gpio"; - reg = <0x18100 0x40>; + compatible = "marvell,armada-370-gpio", + "marvell,orion-gpio"; + reg = <0x18100 0x40>, <0x181c0 0x08>; + reg-names = "gpio", "pwm"; ngpios = <32>; gpio-controller; #gpio-cells = <2>; + #pwm-cells = <2>; interrupt-controller; #interrupt-cells = <2>; interrupts = <82>, <83>, <84>, <85>; + clocks = <&coreclk 0>; };
gpio1: gpio@18140 { - compatible = "marvell,orion-gpio"; - reg = <0x18140 0x40>; + compatible = "marvell,armada-370-gpio", + "marvell,orion-gpio"; + reg = <0x18140 0x40>, <0x181c8 0x08>; + reg-names = "gpio", "pwm"; ngpios = <17>; gpio-controller; #gpio-cells = <2>; + #pwm-cells = <2>; interrupt-controller; #interrupt-cells = <2>; interrupts = <87>, <88>, <89>; + clocks = <&coreclk 0>; }; }; }; diff --git a/arch/arm/dts/armada-xp-mv78260.dtsi b/arch/arm/dts/armada-xp-mv78260.dtsi index d39231f69d9a..2d85fe8ac327 100644 --- a/arch/arm/dts/armada-xp-mv78260.dtsi +++ b/arch/arm/dts/armada-xp-mv78260.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree Include file for Marvell Armada XP family SoC * @@ -5,44 +6,6 @@ * * Thomas Petazzoni thomas.petazzoni@free-electrons.com * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * Contains definitions specific to the Armada XP MV78260 SoC that are not * common to all Armada XP SoCs. */ @@ -294,29 +257,38 @@
gpio1: gpio@18140 { - compatible = "marvell,orion-gpio"; - reg = <0x18140 0x40>; + compatible = "marvell,armada-370-gpio", + "marvell,orion-gpio"; + reg = <0x18140 0x40>, <0x181c8 0x08>; + reg-names = "gpio", "pwm"; ngpios = <32>; gpio-controller; #gpio-cells = <2>; + #pwm-cells = <2>; interrupt-controller; #interrupt-cells = <2>; interrupts = <87>, <88>, <89>, <90>; + clocks = <&coreclk 0>; };
gpio2: gpio@18180 { - compatible = "marvell,orion-gpio"; + compatible = "marvell,armada-370-gpio", + "marvell,orion-gpio"; reg = <0x18180 0x40>; ngpios = <3>; gpio-controller; diff --git a/arch/arm/dts/armada-xp-mv78460.dtsi b/arch/arm/dts/armada-xp-mv78460.dtsi index c642565d1bc6..230a3fd36b30 100644 --- a/arch/arm/dts/armada-xp-mv78460.dtsi +++ b/arch/arm/dts/armada-xp-mv78460.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree Include file for Marvell Armada XP family SoC * @@ -5,44 +6,6 @@ * * Thomas Petazzoni thomas.petazzoni@free-electrons.com * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * Contains definitions specific to the Armada XP MV78460 SoC that are not * common to all Armada XP SoCs. */ @@ -333,29 +296,38 @@
gpio2: gpio@18180 { - compatible = "marvell,orion-gpio"; + compatible = "marvell,armada-370-gpio", + "marvell,orion-gpio"; reg = <0x18180 0x40>; ngpios = <3>; gpio-controller; diff --git a/arch/arm/dts/armada-xp-synology-ds414.dts b/arch/arm/dts/armada-xp-synology-ds414.dts index 0a60ddfa4149..861967cd7e87 100644 --- a/arch/arm/dts/armada-xp-synology-ds414.dts +++ b/arch/arm/dts/armada-xp-synology-ds414.dts @@ -1,13 +1,9 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree file for Synology DS414 * * Copyright (C) 2014, Arnaud EBALARD arno@natisbad.org * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * as published by the Free Software Foundation; either version - * 2 of the License, or (at your option) any later version. - * * Note: this Device Tree assumes that the bootloader has remapped the * internal registers to 0xf1000000 (instead of the old 0xd0000000). * The 0xf1000000 is the default used by the recent, DT-capable, U-Boot @@ -42,36 +38,16 @@ spi0 = &spi0; };
- memory { + memory@0 { device_type = "memory"; reg = <0 0x00000000 0 0x40000000>; /* 1GB */ };
soc { ranges = <MBUS_ID(0xf0, 0x01) 0 0 0xf1000000 0x100000 - MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000>; - - pcie-controller { - status = "okay"; - - /* - * Connected to Marvell 88SX7042 SATA-II controller - * handling the four disks. - */ - pcie@1,0 { - /* Port 0, Lane 0 */ - status = "okay"; - }; - - /* - * Connected to EtronTech EJ168A XHCI controller - * providing the two rear USB 3.0 ports. - */ - pcie@5,0 { - /* Port 1, Lane 0 */ - status = "okay"; - }; - }; + MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000 + MBUS_ID(0x09, 0x09) 0 0 0xf1100000 0x10000 + MBUS_ID(0x09, 0x05) 0 0 0xf1110000 0x10000>;
internal-regs {
@@ -80,64 +56,6 @@ status = "disabled"; };
- spi0: spi@10600 { - status = "okay"; - u-boot,dm-pre-reloc; - - spi-flash@0 { - u-boot,dm-pre-reloc; - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q064"; - reg = <0>; /* Chip select 0 */ - spi-max-frequency = <20000000>; - - /* - * Warning! - * - * Synology u-boot uses its compiled-in environment - * and it seems Synology did not care to change u-boot - * default configuration in order to allow saving a - * modified environment at a sensible location. So, - * if you do a 'saveenv' under u-boot, your modified - * environment will be saved at 1MB after the start - * of the flash, i.e. in the middle of the uImage. - * For that reason, it is strongly advised not to - * change the default environment, unless you know - * what you are doing. - */ - partition@00000000 { /* u-boot */ - label = "RedBoot"; - reg = <0x00000000 0x000d0000>; /* 832KB */ - }; - - partition@000c0000 { /* uImage */ - label = "zImage"; - reg = <0x000d0000 0x002d0000>; /* 2880KB */ - }; - - partition@003a0000 { /* uInitramfs */ - label = "rd.gz"; - reg = <0x003a0000 0x00430000>; /* 4250KB */ - }; - - partition@007d0000 { /* MAC address and serial number */ - label = "vendor"; - reg = <0x007d0000 0x00010000>; /* 64KB */ - }; - - partition@007e0000 { - label = "RedBoot config"; - reg = <0x007e0000 0x00010000>; /* 64KB */ - }; - - partition@007f0000 { - label = "FIS directory"; - reg = <0x007f0000 0x00010000>; /* 64KB */ - }; - }; - }; - i2c@11000 { clock-frequency = <400000>; status = "okay"; @@ -179,16 +97,6 @@ status = "okay"; };
- mdio { - phy0: ethernet-phy@0 { /* Marvell 88E1512 */ - reg = <0>; - }; - - phy1: ethernet-phy@1 { /* Marvell 88E1512 */ - reg = <1>; - }; - }; - ethernet@70000 { status = "okay"; pinctrl-0 = <&ge0_rgmii_pins>; @@ -215,7 +123,7 @@ &sata3_pwr_pin &sata4_pwr_pin>; pinctrl-names = "default";
- sata1_regulator: sata1-regulator { + sata1_regulator: sata1-regulator@1 { compatible = "regulator-fixed"; reg = <1>; regulator-name = "SATA1 Power"; @@ -228,7 +136,7 @@ gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>; };
- sata2_regulator: sata2-regulator { + sata2_regulator: sata2-regulator@2 { compatible = "regulator-fixed"; reg = <2>; regulator-name = "SATA2 Power"; @@ -241,7 +149,7 @@ gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; };
- sata3_regulator: sata3-regulator { + sata3_regulator: sata3-regulator@3 { compatible = "regulator-fixed"; reg = <3>; regulator-name = "SATA3 Power"; @@ -254,7 +162,7 @@ gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; };
- sata4_regulator: sata4-regulator { + sata4_regulator: sata4-regulator@4 { compatible = "regulator-fixed"; reg = <4>; regulator-name = "SATA4 Power"; @@ -269,6 +177,39 @@ }; };
+&pciec { + status = "okay"; + + /* + * Connected to Marvell 88SX7042 SATA-II controller + * handling the four disks. + */ + pcie@1,0 { + /* Port 0, Lane 0 */ + status = "okay"; + }; + + /* + * Connected to EtronTech EJ168A XHCI controller + * providing the two rear USB 3.0 ports. + */ + pcie@5,0 { + /* Port 1, Lane 0 */ + status = "okay"; + }; +}; + + +&mdio { + phy0: ethernet-phy@0 { /* Marvell 88E1512 */ + reg = <0>; + }; + + phy1: ethernet-phy@1 { /* Marvell 88E1512 */ + reg = <1>; + }; +}; + &pinctrl { sata1_pwr_pin: sata1-pwr-pin { marvell,pins = "mpp42"; @@ -335,3 +276,59 @@ marvell,function = "gpio"; }; }; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q064", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <20000000>; + + /* + * Warning! + * + * Synology u-boot uses its compiled-in environment + * and it seems Synology did not care to change u-boot + * default configuration in order to allow saving a + * modified environment at a sensible location. So, + * if you do a 'saveenv' under u-boot, your modified + * environment will be saved at 1MB after the start + * of the flash, i.e. in the middle of the uImage. + * For that reason, it is strongly advised not to + * change the default environment, unless you know + * what you are doing. + */ + partition@0 { /* u-boot */ + label = "RedBoot"; + reg = <0x00000000 0x000d0000>; /* 832KB */ + }; + + partition@c0000 { /* uImage */ + label = "zImage"; + reg = <0x000d0000 0x002d0000>; /* 2880KB */ + }; + + partition@3a0000 { /* uInitramfs */ + label = "rd.gz"; + reg = <0x003a0000 0x00430000>; /* 4250KB */ + }; + + partition@7d0000 { /* MAC address and serial number */ + label = "vendor"; + reg = <0x007d0000 0x00010000>; /* 64KB */ + }; + + partition@7e0000 { + label = "RedBoot config"; + reg = <0x007e0000 0x00010000>; /* 64KB */ + }; + + partition@7f0000 { + label = "FIS directory"; + reg = <0x007f0000 0x00010000>; /* 64KB */ + }; + }; +}; diff --git a/arch/arm/dts/armada-xp-theadorable.dts b/arch/arm/dts/armada-xp-theadorable.dts index 5695e9b75856..bcb4bfdd5c19 100644 --- a/arch/arm/dts/armada-xp-theadorable.dts +++ b/arch/arm/dts/armada-xp-theadorable.dts @@ -126,40 +126,6 @@ status = "okay"; };
- spi0: spi@10600 { - status = "okay"; - u-boot,dm-pre-reloc; - - spi-flash@0 { - u-boot,dm-pre-reloc; - #address-cells = <1>; - #size-cells = <1>; - compatible = "n25q128a13", "jedec,spi-nor", "spi-flash"; - reg = <0>; /* Chip select 0 */ - spi-max-frequency = <27777777>; - }; - - fpga@1 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "spi-generic-device"; - reg = <1>; /* Chip select 1 */ - spi-max-frequency = <27777777>; - }; - }; - - spi1: spi@10680 { - status = "okay"; - - fpga@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "spi-generic-device"; - reg = <0>; /* Chip select 0 */ - spi-max-frequency = <27777777>; - }; - }; - /* The LCD controller is only used on this board */ lcd0: lcd-controller@e0000 { compatible = "marvell,armada-xp-lcd"; @@ -188,6 +154,41 @@ }; };
+&spi0 { + status = "okay"; + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q128a13", "jedec,spi-nor", "spi-flash"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <27777777>; + }; + + fpga@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-generic-device"; + reg = <1>; /* Chip select 1 */ + spi-max-frequency = <27777777>; + }; +}; + +&spi1 { + status = "okay"; + + fpga@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-generic-device"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <27777777>; + }; +}; + + &pciec { status = "okay";
diff --git a/arch/arm/dts/armada-xp.dtsi b/arch/arm/dts/armada-xp.dtsi index 3fac39e41d78..d856d9602272 100644 --- a/arch/arm/dts/armada-xp.dtsi +++ b/arch/arm/dts/armada-xp.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device Tree Include file for Marvell Armada XP family SoC * @@ -8,44 +9,6 @@ * Thomas Petazzoni thomas.petazzoni@free-electrons.com * Ben Dooks ben.dooks@codethink.co.uk * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - * * Contains definitions specific to the Armada XP SoC that are not * common to all Armada SoCs. */ @@ -53,6 +16,9 @@ #include "armada-370-xp.dtsi"
/ { + #address-cells = <2>; + #size-cells = <2>; + model = "Marvell Armada XP family SoC"; compatible = "marvell,armadaxp", "marvell,armada-370-xp";
@@ -71,12 +37,12 @@ };
internal-regs { - sdramc@1400 { + sdramc: sdramc@1400 { compatible = "marvell,armada-xp-sdram-controller"; reg = <0x1400 0x500>; };
- L2: l2-cache { + L2: l2-cache@8000 { compatible = "marvell,aurora-system-cache"; reg = <0x08000 0x1000>; cache-id-part = <0x100>; @@ -85,29 +51,6 @@ wt-override; };
- spi0: spi@10600 { - compatible = "marvell,armada-xp-spi", - "marvell,orion-spi"; - pinctrl-0 = <&spi0_pins>; - pinctrl-names = "default"; - }; - - spi1: spi@10680 { - compatible = "marvell,armada-xp-spi", - "marvell,orion-spi"; - }; - - - i2c0: i2c@11000 { - compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; - reg = <0x11000 0x100>; - }; - - i2c1: i2c@11100 { - compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; - reg = <0x11100 0x100>; - }; - uart2: serial@12200 { compatible = "snps,dw-apb-uart"; pinctrl-0 = <&uart2_pins>; @@ -132,7 +75,7 @@ status = "disabled"; };
- system-controller@18200 { + systemc: system-controller@18200 { compatible = "marvell,armada-370-xp-system-controller"; reg = <0x18200 0x500>; }; @@ -150,7 +93,7 @@ #clock-cells = <1>; };
- thermal@182b0 { + thermal: thermal@182b0 { compatible = "marvell,armadaxp-thermal"; reg = <0x182b0 0x4 0x184d0 0x4>; @@ -164,25 +107,9 @@ clocks = <&coreclk 1>; };
- interrupt-controller@20a00 { - reg = <0x20a00 0x2d0>, <0x21070 0x58>; - }; - - timer@20300 { - compatible = "marvell,armada-xp-timer"; - clocks = <&coreclk 2>, <&refclk>; - clock-names = "nbclk", "fixed"; - }; - - watchdog@20300 { - compatible = "marvell,armada-xp-wdt"; - clocks = <&coreclk 2>, <&refclk>; - clock-names = "nbclk", "fixed"; - }; - - cpurst@20800 { - compatible = "marvell,armada-370-cpu-reset"; - reg = <0x20800 0x20>; + cpu-config@21000 { + compatible = "marvell,armada-xp-cpu-config"; + reg = <0x21000 0x8>; };
eth2: ethernet@30000 { @@ -193,15 +120,7 @@ status = "disabled"; };
- usb@50000 { - clocks = <&gateclk 18>; - }; - - usb@51000 { - clocks = <&gateclk 19>; - }; - - usb@52000 { + usb2: usb@52000 { compatible = "marvell,orion-ehci"; reg = <0x52000 0x500>; interrupts = <47>; @@ -209,7 +128,7 @@ status = "disabled"; };
- xor@60900 { + xor1: xor@60900 { compatible = "marvell,orion-xor"; reg = <0x60900 0x100 0x60b00 0x100>; @@ -237,7 +156,27 @@ compatible = "marvell,armada-xp-neta"; };
- xor@f0900 { + cesa: crypto@90000 { + compatible = "marvell,armada-xp-crypto"; + reg = <0x90000 0x10000>; + reg-names = "regs"; + interrupts = <48>, <49>; + clocks = <&gateclk 23>, <&gateclk 23>; + clock-names = "cesa0", "cesa1"; + marvell,crypto-srams = <&crypto_sram0>, + <&crypto_sram1>; + marvell,crypto-sram-size = <0x800>; + }; + + bm: bm@c0000 { + compatible = "marvell,armada-380-neta-bm"; + reg = <0xc0000 0xac>; + clocks = <&gateclk 13>; + internal-mem = <&bm_bppi>; + status = "disabled"; + }; + + xor0: xor@f0900 { compatible = "marvell,orion-xor"; reg = <0xF0900 0x100 0xF0B00 0x100>; @@ -257,6 +196,35 @@ }; }; }; + + crypto_sram0: sa-sram0 { + compatible = "mmio-sram"; + reg = <MBUS_ID(0x09, 0x09) 0 0x800>; + clocks = <&gateclk 23>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x09, 0x09) 0 0x800>; + }; + + crypto_sram1: sa-sram1 { + compatible = "mmio-sram"; + reg = <MBUS_ID(0x09, 0x05) 0 0x800>; + clocks = <&gateclk 23>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x09, 0x05) 0 0x800>; + }; + + bm_bppi: bm-bppi { + compatible = "mmio-sram"; + reg = <MBUS_ID(0x0c, 0x04) 0 0x100000>; + ranges = <0 MBUS_ID(0x0c, 0x04) 0 0x100000>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&gateclk 13>; + no-memory-wc; + status = "disabled"; + }; };
clocks { @@ -269,6 +237,44 @@ }; };
+&i2c0 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11000 0x100>; +}; + +&i2c1 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11100 0x100>; +}; + +&mpic { + reg = <0x20a00 0x2d0>, <0x21070 0x58>; +}; + +&timer { + compatible = "marvell,armada-xp-timer"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&watchdog { + compatible = "marvell,armada-xp-wdt"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&cpurst { + reg = <0x20800 0x20>; +}; + +&usb0 { + clocks = <&gateclk 18>; +}; + +&usb1 { + clocks = <&gateclk 19>; +}; + &pinctrl { ge0_gmii_pins: ge0-gmii-pins { marvell,pins = @@ -309,6 +315,12 @@ marvell,function = "spi0"; };
+ spi1_pins: spi1-pins { + marvell,pins = "mpp13", "mpp14", + "mpp16", "mpp17"; + marvell,function = "spi1"; + }; + uart2_pins: uart2-pins { marvell,pins = "mpp42", "mpp43"; marvell,function = "uart2"; @@ -319,3 +331,15 @@ marvell,function = "uart3"; }; }; + +&spi0 { + compatible = "marvell,armada-xp-spi", "marvell,orion-spi"; + pinctrl-0 = <&spi0_pins>; + pinctrl-names = "default"; +}; + +&spi1 { + compatible = "marvell,armada-xp-spi", "marvell,orion-spi"; + pinctrl-0 = <&spi1_pins>; + pinctrl-names = "default"; +};
Thanks, Stefan
Changes in v2: None
Applied to u-boot-marvell/master.
Thanks, Stefan
Marvell's switch chips with integrated CPUs (collectively referred to as MSYS) share common ancestry with the Armada SoCs. Some of the IP blocks (e.g. xor) are located at different addresses and DFX server exists as a separate target on the MBUS (on Armada-38x it's just part of the core complex registers).
arch/arm/mach-mvebu/Kconfig | 18 ++++++++++++- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 31 +++++++++++++++++++++-- arch/arm/mach-mvebu/include/mach/config.h | 2 +- arch/arm/mach-mvebu/include/mach/cpu.h | 3 +++ arch/arm/mach-mvebu/include/mach/soc.h | 20 +++++++++++++++ arch/arm/mach-mvebu/mbus.c | 5 ++++ drivers/ddr/marvell/axp/xor_regs.h | 4 +++ 8 files changed, 80 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 7dda04e0e34e..08c9972f02d7 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -46,7 +46,7 @@ config ARMADA_8K # Armada PLL frequency (used for NAND clock generation) config SYS_MVEBU_PLL_CLOCK int - default "2000000000" if ARMADA_XP || ARMADA_3700 || ARMADA_8K + default "2000000000" if ARMADA_XP || ARMADA_3700 || ARMADA_8K || ARMADA_MSYS default "1000000000" if ARMADA_38X || ARMADA_375
# Armada XP/38x SoC types... @@ -63,6 +63,22 @@ config MV78460 bool select ARMADA_XP
+config ARMADA_MSYS + bool + select ARMADA_32BIT + +config 98DX4251 + bool + select ARMADA_MSYS + +config 98DX3336 + bool + select ARMADA_MSYS + +config 98DX3236 + bool + select ARMADA_MSYS + config 88F6820 bool select ARMADA_38X diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index ee2eca913484..2ab7b3c8417e 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -24,6 +24,7 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_ARMADA_38X) += ../../../drivers/ddr/marvell/a38x/xor.o obj-$(CONFIG_ARMADA_XP) += ../../../drivers/ddr/marvell/axp/xor.o +obj-$(CONFIG_ARMADA_MSYS) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_MVEBU_EFUSE) += efuse.o
extra-y += kwbimage.cfg diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 919d05c88c77..61b222a21070 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -23,6 +23,11 @@ static struct mbus_win windows[] = { /* NOR */ { MBUS_BOOTROM_BASE, MBUS_BOOTROM_SIZE, CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_BOOTROM }, + +#ifdef CONFIG_ARMADA_MSYS + /* DFX */ + { MBUS_DFX_BASE, MBUS_DFX_SIZE, CPU_TARGET_DFX, 0 }, +#endif };
void lowlevel_init(void) @@ -121,6 +126,14 @@ static const struct sar_freq_modes sar_freq_tab[] = { { 0x13, 0x0, 2000, 1000, 933 }, { 0xff, 0xff, 0, 0, 0 } /* 0xff marks end of array */ }; +#elif defined(CONFIG_ARMADA_MSYS) +static const struct sar_freq_modes sar_freq_tab[] = { + { 0x0, 0x0, 400, 400, 400 }, + { 0x2, 0x0, 667, 333, 667 }, + { 0x3, 0x0, 800, 400, 800 }, + { 0x5, 0x0, 800, 400, 800 }, + { 0xff, 0xff, 0, 0, 0 } /* 0xff marks end of array */ +}; #else /* SAR frequency values for Armada XP */ static const struct sar_freq_modes sar_freq_tab[] = { @@ -144,7 +157,7 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) u32 freq; int i;
-#if defined(CONFIG_ARMADA_375) +#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_MSYS) val = readl(CONFIG_SAR2_REG); /* SAR - Sample At Reset */ #else val = readl(CONFIG_SAR_REG); /* SAR - Sample At Reset */ @@ -160,7 +173,7 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) #endif for (i = 0; sar_freq_tab[i].val != 0xff; i++) { if (sar_freq_tab[i].val == freq) { -#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_MSYS) *sar_freq = sar_freq_tab[i]; return; #else @@ -270,6 +283,20 @@ int print_cpuinfo(void) } }
+ if (mvebu_soc_family() == MVEBU_SOC_MSYS) { + switch (revid) { + case 3: + puts("A0"); + break; + case 4: + puts("A1"); + break; + default: + printf("?? (%x)", revid); + break; + } + } + get_sar_freq(&sar_freq); printf(" at %d MHz\n", sar_freq.p_clk);
diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index e3235fc67ecd..a14d1e3836bb 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -17,7 +17,7 @@ #include <asm/arch/soc.h>
#if defined(CONFIG_ARMADA_XP) || defined(CONFIG_ARMADA_375) \ - || defined(CONFIG_ARMADA_38X) + || defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_MSYS) /* * Set this for the common xor register definitions needed in dram.c * for A38x as well here. diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 9e23043a4857..b9153d86c669 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -34,6 +34,7 @@ enum cpu_target { CPU_TARGET_PCIE02 = 0x4, CPU_TARGET_ETH01 = 0x7, CPU_TARGET_PCIE13 = 0x8, + CPU_TARGET_DFX = 0x8, CPU_TARGET_SASRAM = 0x9, CPU_TARGET_SATA01 = 0xa, /* A38X */ CPU_TARGET_NAND = 0xd, @@ -79,6 +80,8 @@ enum { #define MBUS_PCI_IO_SIZE (64 << 10) #define MBUS_SPI_BASE 0xF4000000 #define MBUS_SPI_SIZE (8 << 20) +#define MBUS_DFX_BASE 0xF6000000 +#define MBUS_DFX_SIZE (1 << 20) #define MBUS_BOOTROM_BASE 0xF8000000 #define MBUS_BOOTROM_SIZE (8 << 20)
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 01577f469b0e..2d88c410b88c 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -76,7 +76,11 @@ #define MVEBU_NAND_BASE (MVEBU_REGISTER(0xd0000)) #define MVEBU_SDIO_BASE (MVEBU_REGISTER(0xd8000)) #define MVEBU_LCD_BASE (MVEBU_REGISTER(0xe0000)) +#ifdef CONFIG_ARMADA_MSYS +#define MVEBU_DFX_BASE (MBUS_DFX_BASE) +#else #define MVEBU_DFX_BASE (MVEBU_REGISTER(0xe4000)) +#endif
#define SOC_COHERENCY_FABRIC_CTRL_REG (MVEBU_REGISTER(0x20200)) #define MBUS_ERR_PROP_EN (1 << 8) @@ -149,6 +153,22 @@ #define BOOT_FROM_SPI 0x32 #define BOOT_FROM_MMC 0x30 #define BOOT_FROM_MMC_ALT 0x31 +#elif defined(CONFIG_ARMADA_MSYS) +/* SAR values for MSYS */ +#define CONFIG_SAR_REG (MBUS_DFX_BASE + 0xf8200) +#define CONFIG_SAR2_REG (MBUS_DFX_BASE + 0xf8204) + +#define SAR_CPU_FREQ_OFFS 18 +#define SAR_CPU_FREQ_MASK (0x7 << SAR_CPU_FREQ_OFFS) +#define SAR_BOOT_DEVICE_OFFS 11 +#define SAR_BOOT_DEVICE_MASK (0x7 << SAR_BOOT_DEVICE_OFFS) + +#define BOOT_DEV_SEL_OFFS 11 +#define BOOT_DEV_SEL_MASK (0x7 << BOOT_DEV_SEL_OFFS) + +#define BOOT_FROM_NAND 0x1 +#define BOOT_FROM_UART 0x2 +#define BOOT_FROM_SPI 0x3 #else /* SAR values for Armada XP */ #define CONFIG_SAR_REG (MVEBU_REGISTER(0x18230)) diff --git a/arch/arm/mach-mvebu/mbus.c b/arch/arm/mach-mvebu/mbus.c index df4c5cb2d718..3a869e09d3ba 100644 --- a/arch/arm/mach-mvebu/mbus.c +++ b/arch/arm/mach-mvebu/mbus.c @@ -344,6 +344,11 @@ static void mvebu_mbus_default_setup_cpu_target(struct mvebu_mbus_state *mbus) } } mbus_dram_info.num_cs = cs; + +#if defined(CONFIG_ARMADA_MSYS) + /* Disable MBUS Err Prop - in order to avoid data aborts */ + clrbits_le32(mbus->mbuswins_base + 0x200, BIT(8)); +#endif }
static const struct mvebu_mbus_soc_data diff --git a/drivers/ddr/marvell/axp/xor_regs.h b/drivers/ddr/marvell/axp/xor_regs.h index db5c41967393..d779e564189a 100644 --- a/drivers/ddr/marvell/axp/xor_regs.h +++ b/drivers/ddr/marvell/axp/xor_regs.h @@ -13,7 +13,11 @@ #define XOR_UNIT(chan) ((chan) >> 1) #define XOR_CHAN(chan) ((chan) & 1)
+#ifdef CONFIG_ARMADA_MSYS +#define MV_XOR_REGS_OFFSET(unit) (0xF0800) +#else #define MV_XOR_REGS_OFFSET(unit) (0x60900) +#endif #define MV_XOR_REGS_BASE(unit) (MV_XOR_REGS_OFFSET(unit))
/* XOR Engine Control Register Map */
Thanks, Stefan
One difference with the integrated CPUs is that they use a different clock control block to the Armada devices. Update mvebu_get_nand_clock() accordingly.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This could probably be squashed into the previous change. I was trying to separate things to aid review but it's hard to do so and keep bisectability.
Changes in v2: None
arch/arm/mach-mvebu/cpu.c | 2 ++ arch/arm/mach-mvebu/include/mach/soc.h | 11 +++++++++++ 2 files changed, 13 insertions(+)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 61b222a21070..5609ee2f9a3b 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -499,6 +499,8 @@ u32 mvebu_get_nand_clock(void)
if (mvebu_soc_family() == MVEBU_SOC_A38X) reg = MVEBU_DFX_DIV_CLK_CTRL(1); + else if (mvebu_soc_family() == MVEBU_SOC_MSYS) + reg = MVEBU_DFX_DIV_CLK_CTRL(8); else reg = MVEBU_CORE_DIV_CLK_CTRL(1);
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 2d88c410b88c..f666ee24243b 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -100,9 +100,20 @@ #define SPI_PUP_EN BIT(5)
#define MVEBU_CORE_DIV_CLK_CTRL(i) (MVEBU_CLOCK_BASE + ((i) * 0x8)) +#ifdef CONFIG_ARMADA_MSYS +#define MVEBU_DFX_DIV_CLK_CTRL(i) (MVEBU_DFX_BASE + 0xf8000 + 0x250 + ((i) * 0x4)) +#define NAND_ECC_DIVCKL_RATIO_OFFS 6 +#define NAND_ECC_DIVCKL_RATIO_MASK (0xF << NAND_ECC_DIVCKL_RATIO_OFFS) +#else #define MVEBU_DFX_DIV_CLK_CTRL(i) (MVEBU_DFX_BASE + 0x250 + ((i) * 0x4)) +#endif +#ifdef CONFIG_ARMADA_MSYS +#define NAND_ECC_DIVCKL_RATIO_OFFS 6 +#define NAND_ECC_DIVCKL_RATIO_MASK (0xF << NAND_ECC_DIVCKL_RATIO_OFFS) +#else #define NAND_ECC_DIVCKL_RATIO_OFFS 8 #define NAND_ECC_DIVCKL_RATIO_MASK (0x3F << NAND_ECC_DIVCKL_RATIO_OFFS) +#endif
#define SDRAM_MAX_CS 4 #define SDRAM_ADDR_MASK 0xFF000000
Thanks, Stefan
For the time being the Armada MSYS SoCs need to use the bin_hdr from the Marvell U-Boot. Because of this the binary.0 does not contain the image header that a proper u-boot SPL would so the adjustment introduced by commit 94084eea3bd3 ("tools: kwbimage: Fix dest addr") does not apply.
Changes in v2: - new, split out from Add DB-XC3-24G4XG board with a better explanation
tools/Makefile | 4 ++++ tools/kwbimage.c | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/tools/Makefile b/tools/Makefile index 081383d7a790..d99098d6167a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -148,6 +148,10 @@ ifneq ($(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X),) HOSTCFLAGS_kwbimage.o += -DCONFIG_KWB_SECURE endif
+ifneq ($(CONFIG_ARMADA_MSYS),) +HOSTCFLAGS_kwbimage.o += -DCONFIG_KWB_DESTADDR_COMPAT +endif + # MXSImage needs LibSSL ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE),) HOSTLOADLIBES_mkimage += \ diff --git a/tools/kwbimage.c b/tools/kwbimage.c index a88a3830c0c8..4c60679fbb53 100644 --- a/tools/kwbimage.c +++ b/tools/kwbimage.c @@ -1252,8 +1252,12 @@ static void *image_create_v1(size_t *imagesz, struct image_tool_params *params, cpu_to_le32(payloadsz - headersz + sizeof(uint32_t)); main_hdr->headersz_lsb = cpu_to_le16(headersz & 0xFFFF); main_hdr->headersz_msb = (headersz & 0xFFFF0000) >> 16; +#ifdef CONFIG_KWB_DESTADDR_COMPAT + main_hdr->destaddr = cpu_to_le32(params->addr); +#else main_hdr->destaddr = cpu_to_le32(params->addr) - sizeof(image_header_t); +#endif main_hdr->execaddr = cpu_to_le32(params->ep); main_hdr->srcaddr = cpu_to_le32(headersz); main_hdr->ext = hasext;
Hi Chris,
Thanks for the explanation. I'm wondering if it would be better (if possible) to auto detect this situation of using a bin_hdr from Marvell vs U-Boot SPL instead in this tool. This would help especially if we have full DDR init support in mainline U-Boot for this SoC at some time, as we then need to differentiate between those two options for this SoC.
Would this be possible?
Thanks, Stefan
Changes in v2:
- # MXSImage needs LibSSL ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE),) HOSTLOADLIBES_mkimage += \
- main_hdr->destaddr = cpu_to_le32(params->addr);
Viele Grüße, Stefan
On Mon, Feb 18, 2019 at 8:13 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
One way would be to check the filename, binary.0 means don't adjust it whereas u-boot-spl.img does. I also considered modifying the process to create binary.0 to prepend sizeof(image_header_t) bytes to allow it to work but I went with the quickest option for me to implement.
If it's an acceptable solution the filename thing would be quite easy to implement. Adding a flag or parameter in the kwbimage.cfg would also be relatively easy.
Thanks, Stefan
Changes in v2:
Viele Grüße, Stefan
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Hi Chris,
Hi Chris,
I'm okay with using the filename to decide here. Please go ahead with this change and perhaps add a warning / error, if none of the standard names is provided (u-boot-spl.* vs binary.0).
Thanks, Stefan
From: Chris Packham chris.packham@alliedtelesis.co.nz
The DB-XC3-24G4XG is a switch development board from Marvell. It can either use and external CPU card such as the db-88f6820-amc or the internal CPU that is integrated into the switch.
Add support for running U-Boot on the internal CPU and enable the USB, SPI and NAND peripherals. For now this needs the bin_hdr from the Marvell U-Boot for this board.
Changes in v2: - u-boot specific changes in u-boot.dtsi - remove unnecessary entries from board config.h - move some changes to earlier patches
arch/arm/dts/Makefile | 3 +- arch/arm/dts/armada-xp-98dx3236.dtsi | 343 ++++++++++++++++++ arch/arm/dts/armada-xp-98dx3336.dtsi | 39 ++ arch/arm/dts/armada-xp-98dx4251.dtsi | 54 +++ .../dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 24 ++ arch/arm/dts/armada-xp-db-xc3-24g4xg.dts | 110 ++++++ arch/arm/mach-mvebu/Kconfig | 8 + board/Marvell/db-xc3-24g4xg/MAINTAINERS | 7 + board/Marvell/db-xc3-24g4xg/Makefile | 5 + board/Marvell/db-xc3-24g4xg/README | 4 + board/Marvell/db-xc3-24g4xg/binary.0 | 11 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 68 ++++ board/Marvell/db-xc3-24g4xg/kwbimage.cfg | 12 + configs/db-xc3-24g4xg_defconfig | 55 +++ include/configs/db-xc3-24g4xg.h | 41 +++ 15 files changed, 783 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/armada-xp-98dx3236.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx3336.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx4251.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg.dts create mode 100644 board/Marvell/db-xc3-24g4xg/MAINTAINERS create mode 100644 board/Marvell/db-xc3-24g4xg/Makefile create mode 100644 board/Marvell/db-xc3-24g4xg/README create mode 100644 board/Marvell/db-xc3-24g4xg/binary.0 create mode 100644 board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c create mode 100644 board/Marvell/db-xc3-24g4xg/kwbimage.cfg create mode 100644 configs/db-xc3-24g4xg_defconfig create mode 100644 include/configs/db-xc3-24g4xg.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ca5062348087..133f09d8ba63 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -113,7 +113,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-theadorable.dtb \ armada-38x-controlcenterdc.dtb \ armada-385-atl-x530.dtb \ - armada-385-atl-x530DP.dtb + armada-385-atl-x530DP.dtb \ + armada-xp-db-xc3-24g4xg.dtb
dtb-$(CONFIG_ARCH_UNIPHIER_LD11) += \ uniphier-ld11-global.dtb \ diff --git a/arch/arm/dts/armada-xp-98dx3236.dtsi b/arch/arm/dts/armada-xp-98dx3236.dtsi new file mode 100644 index 000000000000..5df1d1848dbc --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx3236.dtsi @@ -0,0 +1,343 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx3236 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx3236 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-370-xp.dtsi" + +/ { + #address-cells = <2>; + #size-cells = <2>; + + model = "Marvell 98DX3236 SoC"; + compatible = "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "marvell,98dx3236-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <0>; + clocks = <&cpuclk 0>; + clock-latency = <1000000>; + }; + }; + + soc { + compatible = "marvell,armadaxp-mbus", "simple-bus"; + + ranges = <MBUS_ID(0xf0, 0x01) 0 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000 + MBUS_ID(0x01, 0x2f) 0 0 0xf0000000 0x1000000 + MBUS_ID(0x03, 0x00) 0 0 0xa8000000 0x4000000 + MBUS_ID(0x08, 0x00) 0 0 0xac000000 0x100000>; + + bootrom { + compatible = "marvell,bootrom"; + reg = <MBUS_ID(0x01, 0x1d) 0 0x100000>; + }; + + /* + * 98DX3236 has 1 x1 PCIe unit Gen2.0 + */ + pciec: pcie@82000000 { + compatible = "marvell,armada-xp-pcie"; + status = "disabled"; + device_type = "pci"; + + #address-cells = <3>; + #size-cells = <2>; + + msi-parent = <&mpic>; + bus-range = <0x00 0xff>; + + ranges = + <0x82000000 0 0x40000 MBUS_ID(0xf0, 0x01) 0x40000 0 0x00002000 /* Port 0.0 registers */ + 0x82000000 0x1 0 MBUS_ID(0x04, 0xe8) 0 1 0 /* Port 0.0 MEM */ + 0x81000000 0x1 0 MBUS_ID(0x04, 0xe0) 0 1 0 /* Port 0.0 IO */>; + + pcie1: pcie@1,0 { + device_type = "pci"; + assigned-addresses = <0x82000800 0 0x40000 0 0x2000>; + reg = <0x0800 0 0 0 0>; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + ranges = <0x82000000 0 0 0x82000000 0x1 0 1 0 + 0x81000000 0 0 0x81000000 0x1 0 1 0>; + bus-range = <0x00 0xff>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &mpic 58>; + marvell,pcie-port = <0>; + marvell,pcie-lane = <0>; + clocks = <&gateclk 5>; + status = "disabled"; + }; + }; + + internal-regs { + sdramc: sdramc@1400 { + compatible = "marvell,armada-xp-sdram-controller"; + reg = <0x1400 0x500>; + }; + + L2: l2-cache@8000 { + compatible = "marvell,aurora-system-cache"; + reg = <0x08000 0x1000>; + cache-id-part = <0x100>; + cache-level = <2>; + cache-unified; + wt-override; + }; + + gpio0: gpio@18100 { + compatible = "marvell,orion-gpio"; + reg = <0x18100 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <82>, <83>, <84>, <85>; + }; + + /* does not exist */ + gpio1: gpio@18140 { + compatible = "marvell,orion-gpio"; + reg = <0x18140 0x40>; + status = "disabled"; + }; + + gpio2: gpio@18180 { /* rework some properties */ + compatible = "marvell,orion-gpio"; + reg = <0x18180 0x40>; + ngpios = <1>; /* only gpio #32 */ + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <87>; + }; + + systemc: system-controller@18200 { + compatible = "marvell,armada-370-xp-system-controller"; + reg = <0x18200 0x500>; + }; + + gateclk: clock-gating-control@18220 { + compatible = "marvell,mv98dx3236-gating-clock"; + reg = <0x18220 0x4>; + clocks = <&coreclk 0>; + #clock-cells = <1>; + }; + + cpuclk: clock-complex@18700 { + #clock-cells = <1>; + compatible = "marvell,mv98dx3236-cpu-clock"; + reg = <0x18700 0x24>, <0x1c054 0x10>; + clocks = <&coreclk 1>; + }; + + corediv-clock@18740 { + status = "disabled"; + }; + + cpu-config@21000 { + compatible = "marvell,armada-xp-cpu-config"; + reg = <0x21000 0x8>; + }; + + ethernet@70000 { + compatible = "marvell,armada-xp-neta"; + }; + + ethernet@74000 { + compatible = "marvell,armada-xp-neta"; + }; + + xor1: xor@f0800 { + compatible = "marvell,orion-xor"; + reg = <0xf0800 0x100 + 0xf0a00 0x100>; + clocks = <&gateclk 22>; + status = "okay"; + + xor10 { + interrupts = <51>; + dmacap,memcpy; + dmacap,xor; + }; + xor11 { + interrupts = <52>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + + nand_controller: nand@d0000 { + clocks = <&dfx_coredivclk 0>; + }; + + xor0: xor@f0900 { + compatible = "marvell,orion-xor"; + reg = <0xF0900 0x100 + 0xF0B00 0x100>; + clocks = <&gateclk 28>; + status = "okay"; + + xor00 { + interrupts = <94>; + dmacap,memcpy; + dmacap,xor; + }; + xor01 { + interrupts = <95>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + }; + + dfx: dfx-server@ac000000 { + compatible = "marvell,dfx-server", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x08, 0x00) 0 0x100000>; + reg = <MBUS_ID(0x08, 0x00) 0 0x100000>; + + thermal: thermal@f8078 { + compatible = "marvell,armada380-thermal"; + reg = <0xf8078 0x4>, <0xf8074 0x4>; + status = "okay"; + }; + + coreclk: mvebu-sar@f8204 { + compatible = "marvell,mv98dx3236-core-clock"; + reg = <0xf8204 0x4>; + #clock-cells = <1>; + }; + + dfx_coredivclk: corediv-clock@f8268 { + compatible = "marvell,mv98dx3236-corediv-clock"; + reg = <0xf8268 0xc>; + #clock-cells = <1>; + clocks = <&mainpll>; + clock-output-names = "nand"; + }; + }; + + switch: switch@a8000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x03, 0x00) 0 0x100000>; + + pp0: packet-processor@0 { + compatible = "marvell,prestera-98dx3236", "marvell,prestera"; + reg = <0 0x4000000>; + interrupts = <33>, <34>, <35>; + dfx = <&dfx>; + }; + }; + }; + + clocks { + /* 25 MHz reference crystal */ + refclk: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + }; +}; + +&i2c0 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11000 0x100>; +}; + +&i2c1 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11100 0x100>; +}; + +&mpic { + reg = <0x20a00 0x2d0>, <0x21070 0x58>; +}; + +&rtc { + status = "disabled"; +}; + +&timer { + compatible = "marvell,armada-xp-timer"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&watchdog { + compatible = "marvell,armada-xp-wdt"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&cpurst { + reg = <0x20800 0x20>; +}; + +&usb0 { + clocks = <&gateclk 18>; +}; + +&usb1 { + clocks = <&gateclk 19>; +}; + +&pinctrl { + compatible = "marvell,98dx3236-pinctrl"; + + nand_pins: nand-pins { + marvell,pins = "mpp20", "mpp21", "mpp22", + "mpp23", "mpp24", "mpp25", + "mpp26", "mpp27", "mpp28", + "mpp29", "mpp30"; + marvell,function = "dev"; + }; + + nand_rb: nand-rb { + marvell,pins = "mpp19"; + marvell,function = "nand"; + }; + + spi0_pins: spi0-pins { + marvell,pins = "mpp0", "mpp1", + "mpp2", "mpp3"; + marvell,function = "spi0"; + }; +}; + +&spi0 { + compatible = "marvell,armada-xp-spi", "marvell,orion-spi"; + pinctrl-0 = <&spi0_pins>; + pinctrl-names = "default"; +}; + +&sdio { + status = "disabled"; +}; diff --git a/arch/arm/dts/armada-xp-98dx3336.dtsi b/arch/arm/dts/armada-xp-98dx3336.dtsi new file mode 100644 index 000000000000..1d9d8a8ea60c --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx3336.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx3336 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx3236 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-xp-98dx3236.dtsi" + +/ { + model = "Marvell 98DX3336 SoC"; + compatible = "marvell,armadaxp-98dx3336", "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + cpus { + cpu@1 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <1>; + clocks = <&cpuclk 1>; + clock-latency = <1000000>; + }; + }; + + soc { + internal-regs { + resume@20980 { + compatible = "marvell,98dx3336-resume-ctrl"; + reg = <0x20980 0x10>; + }; + }; + }; +}; + +&pp0 { + compatible = "marvell,prestera-98dx3336", "marvell,prestera"; +}; diff --git a/arch/arm/dts/armada-xp-98dx4251.dtsi b/arch/arm/dts/armada-xp-98dx4251.dtsi new file mode 100644 index 000000000000..48ffdc72bfc7 --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx4251.dtsi @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx4521 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx4521 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-xp-98dx3236.dtsi" + +/ { + model = "Marvell 98DX4251 SoC"; + compatible = "marvell,armadaxp-98dx4251", "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + cpus { + cpu@1 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <1>; + clocks = <&cpuclk 1>; + clock-latency = <1000000>; + }; + }; + + soc { + internal-regs { + resume@20980 { + compatible = "marvell,98dx3336-resume-ctrl"; + reg = <0x20980 0x10>; + }; + }; + }; +}; + +&sdio { + status = "okay"; +}; + +&pinctrl { + compatible = "marvell,98dx4251-pinctrl"; + + sdio_pins: sdio-pins { + marvell,pins = "mpp5", "mpp6", "mpp7", + "mpp8", "mpp9", "mpp10"; + marvell,function = "sd0"; + }; +}; + +&pp0 { + compatible = "marvell,prestera-98dx4251", "marvell,prestera"; + interrupts = <33>, <34>, <35>, <36>; +}; diff --git a/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi new file mode 100644 index 000000000000..90cad85506d0 --- /dev/null +++ b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&nand_controller { + compatible="marvell,mvebu-pxa3xx-nand"; + status = "okay"; + label = "pxa3xx_nand-0"; + nand-rb = <0>; + marvell,nand-keep-config; + nand-on-flash-bbt; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; diff --git a/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts b/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts new file mode 100644 index 000000000000..d4b52881e6f0 --- /dev/null +++ b/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for DB-XC3-24G4XG board + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Based on armada-xp-db.dts + * + * Note: this Device Tree assumes that the bootloader has remapped the + * internal registers to 0xf1000000 (instead of the default + * 0xd0000000). The 0xf1000000 is the default used by the recent, + * DT-capable, U-Boot bootloaders provided by Marvell. Some earlier + * boards were delivered with an older version of the bootloader that + * left internal registers mapped at 0xd0000000. If you are in this + * situation, you should either update your bootloader (preferred + * solution) or the below Device Tree should be adjusted. + */ + +/dts-v1/; +#include "armada-xp-98dx3336.dtsi" +#include "armada-xp-db-xc3-24g4xg-u-boot.dtsi" + +/ { + model = "DB-XC3-24G4XG"; + compatible = "marvell,armadaxp-98dx3336", "marvell,armadaxp-mv78260", "marvell,armadaxp", "marvell,armada-370-xp"; + + chosen { + stdout-path = "serial0:115200n8"; + bootargs = "console=ttyS0,115200 earlyprintk"; + }; + + aliases { + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x40000000>; /* 1 GB */ + }; +}; + +&L2 { + arm,parity-enable; + marvell,ecc-enable; +}; + +&devbus_bootcs { + status = "okay"; + + /* Device Bus parameters are required */ + + /* Read parameters */ + devbus,bus-width = <16>; + devbus,turn-off-ps = <60000>; + devbus,badr-skew-ps = <0>; + devbus,acc-first-ps = <124000>; + devbus,acc-next-ps = <248000>; + devbus,rd-setup-ps = <0>; + devbus,rd-hold-ps = <0>; + + /* Write parameters */ + devbus,sync-enable = <0>; + devbus,wr-high-ps = <60000>; + devbus,wr-low-ps = <60000>; + devbus,ale-wr-ps = <60000>; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <100000>; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x00100000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x00100000 0x00040000>; + label = "u-boot-env"; + }; + partition@unused { + reg = <0x00140000 0x00ec0000>; + label = "unused"; + }; + + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 08c9972f02d7..cfb464def8a7 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -152,6 +152,10 @@ config TARGET_X530 bool "Support Allied Telesis x530" select 88F6820
+config TARGET_DB_XC3_24G4XG + bool "Support DB-XC3-24G4XG" + select 98DX3336 + endchoice
config SYS_BOARD @@ -170,6 +174,7 @@ config SYS_BOARD default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG @@ -187,6 +192,7 @@ config SYS_CONFIG_NAME default "turris_mox" if TARGET_TURRIS_MOX default "controlcenterdc" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP @@ -195,6 +201,8 @@ config SYS_VENDOR default "Marvell" if TARGET_DB_88F6820_GP default "Marvell" if TARGET_DB_88F6820_AMC default "Marvell" if TARGET_MVEBU_ARMADA_8K + default "Marvell" if TARGET_DB_XC3_24G4XG + default "Marvell" if TARGET_MVEBU_DB_88F7040 default "solidrun" if TARGET_CLEARFOG default "kobol" if TARGET_HELIOS4 default "Synology" if TARGET_DS414 diff --git a/board/Marvell/db-xc3-24g4xg/MAINTAINERS b/board/Marvell/db-xc3-24g4xg/MAINTAINERS new file mode 100644 index 000000000000..94d4a901783b --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/MAINTAINERS @@ -0,0 +1,7 @@ +DB-XC3-24G4XG BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/Marvell/db-xc3-24g4xg/ +F: include/configs/db-xc3-24g4xg.h +F: configs/db-xc3-24g4xg-amc_defconfig +F: arch/arm/dts/armada-xp-db-xc3-24g4xg.dts diff --git a/board/Marvell/db-xc3-24g4xg/Makefile b/board/Marvell/db-xc3-24g4xg/Makefile new file mode 100644 index 000000000000..199837a84fe6 --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2015 Stefan Roese sr@denx.de + +obj-y := db-xc3-24g4xg.o diff --git a/board/Marvell/db-xc3-24g4xg/README b/board/Marvell/db-xc3-24g4xg/README new file mode 100644 index 000000000000..5e479b433e4d --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/README @@ -0,0 +1,4 @@ +To generate binary.0 from Marvell's bin_hdr.elf use the following command + + arm-softfloat-linux-gnueabi-objcopy -S -O binary bin_hdr.elf \ + board/Marvell/db-xc3-24g4xg/binary.0 diff --git a/board/Marvell/db-xc3-24g4xg/binary.0 b/board/Marvell/db-xc3-24g4xg/binary.0 new file mode 100644 index 000000000000..8dd687286a00 --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/binary.0 @@ -0,0 +1,11 @@ +-------- +WARNING: +-------- +This file should contain the bin_hdr generated by the original Marvell +U-Boot implementation. As this is currently not included in this +U-Boot version, we have added this placeholder, so that the U-Boot +image can be generated without errors. + +If you have a known to be working bin_hdr for your board, then you +just need to replace this text file here with the binary header +and recompile U-Boot. diff --git a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c new file mode 100644 index 000000000000..cae428ffd06c --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2015 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <linux/mbus.h> +#include <linux/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * These values and defines are taken from the Marvell U-Boot version + * "u-boot-2013.01-2016_T1.0.eng_drop_v6" + */ +#define DB_DX_AC3_GPP_OUT_ENA_LOW (~(BIT(0) | BIT(2) | BIT(3) | BIT(4) | BIT(6) | BIT(12) \ + | BIT(13) | BIT(16) | BIT(17) | BIT(20) | BIT(29) | BIT(30))) +#define DB_DX_AC3_GPP_OUT_ENA_MID (~(0)) +#define DB_DX_AC3_GPP_OUT_VAL_LOW (BIT(0) | BIT(2) | BIT(3) | BIT(4) | BIT(6) | BIT(12) \ + | BIT(13) | BIT(16) | BIT(17) | BIT(20) | BIT(29) | BIT(30)) +#define DB_DX_AC3_GPP_OUT_VAL_MID 0x0 +#define DB_DX_AC3_GPP_POL_LOW 0x0 +#define DB_DX_AC3_GPP_POL_MID 0x0 + +int board_early_init_f(void) +{ + /* Configure MPP */ + writel(0x00142222, MVEBU_MPP_BASE + 0x00); + writel(0x11122000, MVEBU_MPP_BASE + 0x04); + writel(0x44444004, MVEBU_MPP_BASE + 0x08); + writel(0x14444444, MVEBU_MPP_BASE + 0x0c); + writel(0x00000001, MVEBU_MPP_BASE + 0x10); + + /* Set GPP Out value */ + writel(DB_DX_AC3_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00); + writel(DB_DX_AC3_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00); + + /* Set GPP Polarity */ + writel(DB_DX_AC3_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c); + writel(DB_DX_AC3_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c); + + /* Set GPP Out Enable */ + writel(DB_DX_AC3_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); + writel(DB_DX_AC3_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board: " CONFIG_SYS_BOARD "\n"); + + return 0; +} +#endif diff --git a/board/Marvell/db-xc3-24g4xg/kwbimage.cfg b/board/Marvell/db-xc3-24g4xg/kwbimage.cfg new file mode 100644 index 000000000000..b8bb7a6eb75b --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/kwbimage.cfg @@ -0,0 +1,12 @@ +# +# Copyright (C) 2014 Stefan Roese sr@denx.de +# + +# Armada XP uses version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM spi + +# Binary Header (bin_hdr) with DDR3 training code +BINARY board/Marvell/db-xc3-24g4xg/binary.0 0000005b 00000068 diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig new file mode 100644 index 000000000000..0285ccaa365c --- /dev/null +++ b/configs/db-xc3-24g4xg_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_DB_XC3_24G4XG=y +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-db-xc3-24g4xg" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_BLK=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_DEVICE=y +CONFIG_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y diff --git a/include/configs/db-xc3-24g4xg.h b/include/configs/db-xc3-24g4xg.h new file mode 100644 index 000000000000..0f75ad71859e --- /dev/null +++ b/include/configs/db-xc3-24g4xg.h @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + */ + +#ifndef _CONFIG_DB_XC3_24G4G_H +#define _CONFIG_DB_XC3_24G4G_H + +/* + * High Level Configuration Options (easy to change) + */ + +#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg +#define CONFIG_SYS_TCLK 200000000 /* 200MHz */ + +/* USB/EHCI configuration */ +#define CONFIG_EHCI_IS_TDI + +/* Environment in SPI NOR flash */ +#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ +#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ +#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ + +/* NAND */ +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* Keep device tree and initrd in lower memory so the kernel can access them */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x10000000\0" \ + "initrd_high=0x10000000\0" + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" +#undef CONFIG_SYS_MAXARGS +#define CONFIG_SYS_MAXARGS 96 + +#endif /* _CONFIG_DB_XC3_24G4G_H */
Thanks, Stefan
Hi Chris,
Compiling this with buildman (Travis) leads to this error:
arm: + db-xc3-24g4xg +Didn't find the file 'board/Marvell/db-xc3-24g4xg/binary.0' in '/home/stefan/git/u-boot/.bm-work/00/build' which is mandatory to generate the image +This file generally contains the DDR3 training code, and should be extracted from an existing bootable +image for your board. See 'kwbimage -x' to extract it from an existing image. +Could not create image +make[1]: *** [u-boot.kwb] Error 1 +make[1]: *** Deleting file 'u-boot.kwb'
The external build output directory seems to be the problem here. Could you please look into this?
Thanks, Stefan
On Thu, Apr 11, 2019 at 6:46 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
Yep I'll take a look.
Hi Chris,
There are a two options
1. Add a rule to copy the binary blob to the output directory $(obj)/binary.0: $(src}/binary.0 cp $^ $@
2. Set CONFIG_BUILD_TARGET to u-boot.bin
Option 1 suits me because I have the required binary blob from Marvell's tree. Option 2 would work for the compile tests and for anyone chain loading the upstream u-boot.
Any preferences?
Hi Chris,
- Add a rule to copy the binary blob to the output directory $(obj)/binary.0: $(src}/binary.0 cp $^ $@
This would be in the board directory, right?
- Set CONFIG_BUILD_TARGET to u-boot.bin
Any preferences?
If 1 suits you better, then I don't object. Please continue this way.
Thanks, Stefan
Hi Chris,
Any preferences?
I couldn't get the original option 1 to work due to the circular dependency. But option #3 is to generate the kwbimage.cfg adjusting the path as needed. I'll send a v3 shortly.
Chris Packham
Stefan Roese
