[U-Boot] AM335x : failure to boot SPL from NAND
I'm trying to diagnose why our AM335x based CPU board (based on the AM335x Starter Kit) can boot SPL and U-Boot from an MMC card, but is unable to boot from NAND (connected to CS0).
Following the TI wiki (http://processors.wiki.ti.com/index.php/AM335x_U-Boot_User%27s_Guide#Flashin...) I:-
(1) boot from MMC (2) erase the nand (3) copy MLO from MMC into NAND (4) verified it copied correctly (using crc32)
When I reboot the board in NAND mode, I get nothing on UART0.
If I reboot in MMC mode, SPL and U-Boot load correctly.
Can anyone give me some pointers on the boot sequence, and where I might look to help debug the problem ?
Regards Mark JACKSON
Assuming you're using mainline U-Boot and can rule out "vendor problems", if you can access the SYSBOOT pins, set it up for a mode that does NAND and UART. If you never see the 'CCC' on console (or only see it the first time if you do UART then NAND), then you are starting SPL and dying in there. If you just see a stream of C then your file is not written to NAND correctly.
Interesting ... I don't get any 'CCC' on the console.
However, I then tested this by booting via MMC, erasing the NAND chip and then trying to reboot via NAND again.
I still get no 'CCC' on the console !?!
This is using boot mode 10011 (NAND, NANDI2C, MMC0, UART0), so I would expect to either boot via MMC (if I left it in) or get some 'CCC' output on the console.
I can see that the NAND signals always have a burst of activity every 10ms. That must be a timeout of some sort ... do you know if that's a hardware or software timeout ?
Mark J.
How did you wire the SYSBOOT pins, and which UART is connected to console? If you have UART0 as the one hooked up to console and have SYSBOOT[4:0] as 00100, the order is UART0,XIP (NOR),MMC0,NAND. So you should see 'CCCCCCCC' (UART0 trying to initiate X-Modem), then it will try MMC0 and then NAND..
Correct. If you have an empty NAND and nothing inserted in MMC, it should be an endless cycle of 'C'.
Moving beyond what I can easily help with, sorry. Hit up the TI forums at http://e2e.ti.com/ as this is getting a bit off-topic for the U-Boot list as well :) Thanks!
Just a quick update (in case anyone else is in the same boat) ...
Looks like the upper data bus (AD[15:8]) needs to have pullups on it, even though you're booting from an 8bit device.
I guess the AM335x internal boot code assumes everything is 16bit (even though SYSBOOT[8] is used to configure 8/16bit device).
Mark J.
Just to update this ... *pulldowns* (not pullups) were needed to get it to boot reliably.
Mark Jackson
