[U-Boot] [PATCH] mips: rename arch mt7620 to mt7628
The MediaTek MT7620 and MT7628 SoCs are different. Although they use the same memory controller, the lowlevel code (CPU PLL) and other peripherals they use are totally different. Which means they should use seperate mach directories.
Currently the mach mt7620 contains only architecture code of MT7628. In case we add real arch support of MT7620 in the future, the arch should be renamed to mt7628, including both Kconfig files and directories. Other files affected are also modified.
Cc: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/Kconfig | 6 +++--- arch/mips/Makefile | 2 +- arch/mips/dts/Makefile | 2 +- arch/mips/{mach-mt7620 => mach-mt7628}/Kconfig | 16 ++++++++-------- arch/mips/{mach-mt7620 => mach-mt7628}/Makefile | 0 arch/mips/{mach-mt7620 => mach-mt7628}/cpu.c | 0 .../{mach-mt7620 => mach-mt7628}/ddr_calibrate.c | 0 .../{mach-mt7620 => mach-mt7628}/lowlevel_init.S | 0 arch/mips/{mach-mt7620 => mach-mt7628}/mt76xx.h | 0 configs/linkit-smart-7688-ram_defconfig | 2 +- configs/linkit-smart-7688_defconfig | 2 +- drivers/gpio/Kconfig | 2 +- drivers/net/Kconfig | 2 +- drivers/spi/Kconfig | 2 +- drivers/watchdog/Kconfig | 2 +- 15 files changed, 19 insertions(+), 19 deletions(-) rename arch/mips/{mach-mt7620 => mach-mt7628}/Kconfig (92%) rename arch/mips/{mach-mt7620 => mach-mt7628}/Makefile (100%) rename arch/mips/{mach-mt7620 => mach-mt7628}/cpu.c (100%) rename arch/mips/{mach-mt7620 => mach-mt7628}/ddr_calibrate.c (100%) rename arch/mips/{mach-mt7620 => mach-mt7628}/lowlevel_init.S (100%) rename arch/mips/{mach-mt7620 => mach-mt7628}/mt76xx.h (100%)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 194f4f349e..fc861c8273 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -74,8 +74,8 @@ config ARCH_BMIPS select SYSRESET imply CMD_DM
-config ARCH_MT7620 - bool "Support MT7620/7688 SoCs" +config ARCH_MT7628 + bool "Support MediaTek MT7628/7688 SoCs" imply CMD_DM select DISPLAY_CPUINFO select DM @@ -153,7 +153,7 @@ source "arch/mips/mach-mscc/Kconfig" source "arch/mips/mach-bmips/Kconfig" source "arch/mips/mach-jz47xx/Kconfig" source "arch/mips/mach-pic32/Kconfig" -source "arch/mips/mach-mt7620/Kconfig" +source "arch/mips/mach-mt7628/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 029d290f1e..da5b9c0e74 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -15,7 +15,7 @@ machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_ARCH_BMIPS) += bmips machine-$(CONFIG_ARCH_JZ47XX) += jz47xx machine-$(CONFIG_MACH_PIC32) += pic32 -machine-$(CONFIG_ARCH_MT7620) += mt7620 +machine-$(CONFIG_ARCH_MT7628) += mt7628 machine-$(CONFIG_ARCH_MSCC) += mscc
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 3522e6cdc8..1c4ad5207d 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-dtb-$(CONFIG_ARCH_MT7620) += \ +dtb-$(CONFIG_ARCH_MT7628) += \ gardena-smart-gateway-mt7688.dtb \ linkit-smart-7688.dtb dtb-$(CONFIG_TARGET_AP121) += ap121.dtb diff --git a/arch/mips/mach-mt7620/Kconfig b/arch/mips/mach-mt7628/Kconfig similarity index 92% rename from arch/mips/mach-mt7620/Kconfig rename to arch/mips/mach-mt7628/Kconfig index a983443999..6a46640479 100644 --- a/arch/mips/mach-mt7620/Kconfig +++ b/arch/mips/mach-mt7628/Kconfig @@ -1,20 +1,20 @@ -menu "MediaTek MIPS platforms" - depends on ARCH_MT7620 +menu "MediaTek MT7628/7688 platforms" + depends on ARCH_MT7628
config SYS_MALLOC_F_LEN default 0x1000
config SYS_SOC - default "mt7620" if SOC_MT7620 + default "mt7628" if SOC_MT7628
choice prompt "MediaTek MIPS SoC select"
-config SOC_MT7620 - bool "MT7620/8" +config SOC_MT7628 + bool "MT7628/7688" select MIPS_L1_CACHE_SHIFT_5 help - This supports MediaTek MIPS MT7620 family. + This supports MediaTek MT7628/7688 SoCs.
endchoice
@@ -23,7 +23,7 @@ choice
config BOARD_GARDENA_SMART_GATEWAY_MT7688 bool "GARDENA smart Gateway" - depends on SOC_MT7620 + depends on SOC_MT7628 select BOARD_LATE_INIT select SUPPORTS_BOOT_RAM help @@ -32,7 +32,7 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688
config BOARD_LINKIT_SMART_7688 bool "LinkIt Smart 7688" - depends on SOC_MT7620 + depends on SOC_MT7628 select SUPPORTS_BOOT_RAM help Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM diff --git a/arch/mips/mach-mt7620/Makefile b/arch/mips/mach-mt7628/Makefile similarity index 100% rename from arch/mips/mach-mt7620/Makefile rename to arch/mips/mach-mt7628/Makefile diff --git a/arch/mips/mach-mt7620/cpu.c b/arch/mips/mach-mt7628/cpu.c similarity index 100% rename from arch/mips/mach-mt7620/cpu.c rename to arch/mips/mach-mt7628/cpu.c diff --git a/arch/mips/mach-mt7620/ddr_calibrate.c b/arch/mips/mach-mt7628/ddr_calibrate.c similarity index 100% rename from arch/mips/mach-mt7620/ddr_calibrate.c rename to arch/mips/mach-mt7628/ddr_calibrate.c diff --git a/arch/mips/mach-mt7620/lowlevel_init.S b/arch/mips/mach-mt7628/lowlevel_init.S similarity index 100% rename from arch/mips/mach-mt7620/lowlevel_init.S rename to arch/mips/mach-mt7628/lowlevel_init.S diff --git a/arch/mips/mach-mt7620/mt76xx.h b/arch/mips/mach-mt7628/mt76xx.h similarity index 100% rename from arch/mips/mach-mt7620/mt76xx.h rename to arch/mips/mach-mt7628/mt76xx.h diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 649db0f67d..6705740fdc 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -1,6 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MT7628=y CONFIG_BOARD_LINKIT_SMART_7688=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 41aa900e56..d276114a14 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,6 +1,6 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9c000000 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MT7628=y CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index b3e4ecc50e..131ea11cec 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -351,7 +351,7 @@ config MPC8XXX_GPIO
config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" - depends on DM_GPIO && ARCH_MT7620 + depends on DM_GPIO && ARCH_MT7628 default y help Say yes here to support MediaTek MT7621 compatible GPIOs. diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6e436b56ab..0c0932f63a 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -269,7 +269,7 @@ config MACB_ZYNQ
config MT7628_ETH bool "MediaTek MT7628 Ethernet Interface" - depends on ARCH_MT7620 + depends on ARCH_MT7628 help The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards. diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index fb794adae7..b2b5061490 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -133,7 +133,7 @@ config MPC8XX_SPI
config MT7621_SPI bool "MediaTek MT7621 SPI driver" - depends on ARCH_MT7620 + depends on ARCH_MT7628 help Enable the MT7621 SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Ralink / MediaTek diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 3bce0aa0b8..0f7d827581 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -143,7 +143,7 @@ config WDT_AT91
config WDT_MT7621 bool "MediaTek MT7621 watchdog timer support" - depends on WDT && ARCH_MT7620 + depends on WDT && ARCH_MT7628 help Select this to enable Ralink / Mediatek watchdog timer, which can be found on some MediaTek chips.
s/seperate/separate
Perhaps it would be possible to support both SoC's (MT7620 and MT7628/88) in one mach directory? Frankly I don't know the differences in detail, so its your call.
You missed updating the gardena defconfig files:
$ git grep MT7620 configs/gardena-smart-gateway-mt7688-ram_defconfig:CONFIG_ARCH_MT7620=y configs/gardena-smart-gateway-mt7688_defconfig:CONFIG_ARCH_MT7620=y
Other than this:
Thanks, Stefan
-config ARCH_MT7620
+config ARCH_MT7628
- bool "Support MediaTek MT7628/7688 SoCs" imply CMD_DM select DISPLAY_CPUINFO select DM
if MIPS
config SYS_SOC
-config SOC_MT7620
- bool "MT7620/8"
+config SOC_MT7628
- bool "MT7628/7688" select MIPS_L1_CACHE_SHIFT_5 help
endchoice
- depends on SOC_MT7628 select BOARD_LATE_INIT select SUPPORTS_BOOT_RAM help
- depends on SOC_MT7628 select SUPPORTS_BOOT_RAM help Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM
- depends on DM_GPIO && ARCH_MT7628 default y help Say yes here to support MediaTek MT7621 compatible GPIOs.
- depends on ARCH_MT7628 help The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards.
- depends on ARCH_MT7628 help Enable the MT7621 SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Ralink / MediaTek
- depends on WDT && ARCH_MT7628 help Select this to enable Ralink / Mediatek watchdog timer, which can be found on some MediaTek chips.
Viele Grüße, Stefan
s/seperate/separate
Other than this:
Thanks, Stefan
-config ARCH_MT7620
+config ARCH_MT7628
if MIPS
config SYS_SOC
-config SOC_MT7620
- bool "MT7620/8"
+config SOC_MT7628
endchoice
Viele Grüße, Stefan
Dear Stefan,
Thanks for pointing out the missing files.
Here is the summary of HW components needed by u-boot for MT7620 and MT7628:
L1 data cache: MT7620 can not lock it. MT7628 uses it to do DDR calibration. CPU frequency (PLL): MT7620 can change it. MT7628 can't. The PLL registers are different. DRAM controller: Near the same. MT7620 can't do calibration. MT7628 has extra PAD configurations. GPIO controller: Not the same IP core. SPI controller: Not the same IP core. Frame engine: Similar IP core, different generation. Built-in Ethernet switch: Not the same IP core.
So I insist to split them into two mach directory.
Best Regards,
Weijie
s/seperate/separate
<snip>
Dear Stefan,
These "devices / controllers" are handled in the mach-foo directory.
And these controllers are handled in the drivers/foo directly. So any different IP core (between MT7620 and MT7628) has no effect to the mach directory.
Please don't misunderstand me. I absolutely agree that we need to differentiate between those two SoC's. So moving to CONFIG_SOC_MT7628 instead of SOC_MT7620 makes perfect sense. I only want to avoid the creation of another mach-foo directory, where code might be shared between both SoC's.
I see. Okay, lets move forward then with your patch and lets finally decide if and what can be shared between those SoC's, once (if) support for the MT7620 arrives in mainline.
BTW: Do you plan on adding support for the MT7620 anytime soon?
Thanks, Stefan
Am 29.04.19 um 11:40 schrieb Stefan Roese:
s/seperate/separate
<snip>
Dear Stefan,
I agree with Stefan, there is no need to create separate mach- directories. With the power of Kconfig and Kbuild you can easily handle multiple SoCs within one mach- directory, for instance look at mach-bmips or mach-mscc. Could you rather rename to mach-mediatek or mach-mtmips so that we would have the Kconfig symbols ARCH_MEDIATEK and SOC_MT7628 (plus SOC_MT7620 in the future)? Thanks.
BTW: it's good to see that another vendor in the MIPS area is stepping up to maintain its products in mainline ;)
s/seperate/separate
<snip>
Dear Stefan,
Hi Daniel,
You are right. I forgot I've already submitted a mach- like this: MediaTek's ARM SoCs - MT7623 and MT7629.
They are both placed in mach-mediatek. A submenu can choose whether to build MT7623 or MT7629.
ARCH_MEDIATEK is already used. I think ARCH_MTMIPS is just fine. I'll modify and resubmit the patch.
Hi Stefan,
I'm just starting to rewrite some lowlevel codes for mt7628 in the next one or two months. Then add support for MT7620.
Best Regards,
Weijie
Daniel Schwierzeck
Stefan Roese
Weijie Gao
