[U-Boot] [PATCH] bootcount: Correct #endif comment to match, other aesthetics
Correct mismatched comment on #endif to agree with its #if defined().
Also add some missing #endif comments for consistency, take out extraneous blank lines for readability.
rday
diff --git a/drivers/bootcount/bootcount.c b/drivers/bootcount/bootcount.c index e0343f7..d5ce450 100644 --- a/drivers/bootcount/bootcount.c +++ b/drivers/bootcount/bootcount.c @@ -31,16 +31,14 @@
#if defined(CONFIG_MPC8260) #include <asm/cpm_8260.h> - #define CONFIG_SYS_BOOTCOUNT_ADDR (CONFIG_SYS_IMMR + CPM_BOOTCOUNT_ADDR) #endif /* defined(CONFIG_MPC8260) */
#if defined(CONFIG_QE) #include <linux/immap_qe.h> - #define CONFIG_SYS_BOOTCOUNT_ADDR (CONFIG_SYS_IMMR + 0x110000 + \ QE_MURAM_SIZE - 2 * sizeof(u32)) -#endif /* defined(CONFIG_MPC8360) */ +#endif /* defined(CONFIG_QE) */
#if defined(CONFIG_4xx) #define CONFIG_SYS_BOOTCOUNT_ADDR (CONFIG_SYS_OCM_DATA_ADDR + \ @@ -60,7 +58,7 @@ __weak void bootcount_store(ulong a) #else raw_bootcount_store(reg, a); raw_bootcount_store(reg + 4, BOOTCOUNT_MAGIC); -#endif +#endif /* defined(CONFIG_SYS_BOOTCOUNT_SINGLEWORD */ }
__weak ulong bootcount_load(void) @@ -79,6 +77,6 @@ __weak ulong bootcount_load(void) return 0; else return raw_bootcount_load(reg); -#endif +#endif /* defined(CONFIG_SYS_BOOTCOUNT_SINGLEWORD) */ } -#endif +#endif /* defined(CONFIG_SYS_BOOTCOUNT_ADDR) */
rday
Robert P. J. Day
