[U-Boot] [UBOOT PATCH] Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch moves the the config SYS_MALLOC_LEN to Kconfig. It will be just for Zynq arch and to do will be for all other archs.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Vipul Kumar vipul.kumar@xilinx.com --- Kconfig | 7 +++++++ arch/arm/mach-zynq/Kconfig | 3 +++ configs/zynq_cse_nand_defconfig | 1 + configs/zynq_cse_nor_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + include/configs/zynq-common.h | 2 -- include/configs/zynq_cse.h | 3 --- 7 files changed, 13 insertions(+), 5 deletions(-)
diff --git a/Kconfig b/Kconfig index c8b86cd..61795e3 100644 --- a/Kconfig +++ b/Kconfig @@ -136,6 +136,13 @@ config SYS_MALLOC_F_LEN particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
+config SYS_MALLOC_LEN + hex "Define memory for Dynamic allocation" + depends on ARCH_ZYNQ + help + This defines memory to be allocated for Dynamic allocation + TODO: Use for other architectures + config SPL_SYS_MALLOC_F_LEN hex "Size of malloc() pool in SPL before relocation" depends on SYS_MALLOC_F diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index 1352359..a599ed6 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -57,6 +57,9 @@ config SYS_CONFIG_NAME config SYS_MALLOC_F_LEN default 0x600
+config SYS_MALLOC_LEN + default 0x1400000 + config BOOT_INIT_FILE string "boot.bin init register filename" default "" diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index eb7e574..d228f9a 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x100000 CONFIG_ENV_SIZE=0x190 CONFIG_SPL=y CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x1000 CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 95b31a0..3052c5b 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_ENV_SIZE=0x190 CONFIG_SPL=y CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x1000 CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" CONFIG_BOOTDELAY=-1 # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index c094a5e..2410806 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BASE=0x0 CONFIG_DEBUG_UART_CLOCK=0 CONFIG_SPL_STACK_R_ADDR=0x200000 # CONFIG_ZYNQ_DDRC_INIT is not set +CONFIG_SYS_MALLOC_LEN=0x1000 # CONFIG_CMD_ZYNQ is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-qspi-single" CONFIG_DEBUG_UART=y diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index c41dc2c..3c2987b 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -236,8 +236,6 @@ #define CONFIG_SYS_MEMTEST_START 0 #define CONFIG_SYS_MEMTEST_END 0x1000
-#define CONFIG_SYS_MALLOC_LEN 0x1400000 - #define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ diff --git a/include/configs/zynq_cse.h b/include/configs/zynq_cse.h index 36fbe0e..c4587a1 100644 --- a/include/configs/zynq_cse.h +++ b/include/configs/zynq_cse.h @@ -36,7 +36,4 @@ #define CONFIG_SPL_BSS_START_ADDR 0x20000 #define CONFIG_SPL_BSS_MAX_SIZE 0x8000
-#undef CONFIG_SYS_MALLOC_LEN -#define CONFIG_SYS_MALLOC_LEN 0x1000 - #endif /* __CONFIG_ZYNQ_CSE_H */
- hex "Define memory for Dynamic allocation"
- depends on ARCH_ZYNQ
- help
- default 0x1400000
Applied. M
Michal Simek
Vipul Kumar
