[PATCH 0/2] rockchip: Use dwc3-generic driver on RK3328 and RK3399
This series change to use the dwc3-generic driver on all RK3328 and RK3399 boards. Also switch to use DM_USB_GADGET and remove then obsolete board_usb_init() and dm_usb_gadget_handle_interrupts() functions.
First patch change all RK33xx boards to use dwc3-generic driver. Second patch remove obsolete rk3399 usb gadget functions.
This has been tested and validated on rockpro64 and rock-pi-4 boards.
Jonas Karlman (2): configs: rockchip: Use dwc3-generic driver on RK3328 and RK3399 rockchip: board: Remove dwc3 usb init and gadget handler functions
arch/arm/mach-rockchip/board.c | 24 ------------------- configs/chromebook_bob_defconfig | 2 +- configs/chromebook_kevin_defconfig | 2 +- configs/eaidk-610-rk3399_defconfig | 4 +++- configs/evb-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 1 - configs/khadas-edge-captain-rk3399_defconfig | 4 +++- configs/khadas-edge-rk3399_defconfig | 4 +++- configs/khadas-edge-v-rk3399_defconfig | 4 +++- configs/leez-rk3399_defconfig | 4 +++- configs/nanopc-t4-rk3399_defconfig | 4 +++- configs/nanopi-m4-2gb-rk3399_defconfig | 4 +++- configs/nanopi-m4-rk3399_defconfig | 4 +++- configs/nanopi-m4b-rk3399_defconfig | 4 +++- configs/nanopi-neo4-rk3399_defconfig | 4 +++- configs/nanopi-r4s-rk3399_defconfig | 3 ++- configs/orangepi-r1-plus-lts-rk3328_defconfig | 3 ++- configs/orangepi-r1-plus-rk3328_defconfig | 3 ++- configs/orangepi-rk3399_defconfig | 4 +++- configs/pinebook-pro-rk3399_defconfig | 1 - configs/pinephone-pro-rk3399_defconfig | 1 - configs/puma-rk3399_defconfig | 1 - configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-4c-plus-rk3399_defconfig | 2 +- configs/rock-4se-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rock-pi-n10-rk3399pro_defconfig | 2 +- configs/rock960-rk3399_defconfig | 3 ++- configs/rockpro64-rk3399_defconfig | 1 - drivers/usb/host/Kconfig | 1 - 32 files changed, 50 insertions(+), 55 deletions(-)
Change to use the dwc3-generic driver on all RK3328 and RK3399 boards.
MISC, USB_DWC3 and USB_DWC3_GENERIC are enabled on boards that enabled USB_XHCI_DWC3. Also enable DM_USB_GADGET for any board that enable USB_DWC3_GADGET.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- configs/chromebook_bob_defconfig | 2 +- configs/chromebook_kevin_defconfig | 2 +- configs/eaidk-610-rk3399_defconfig | 4 +++- configs/evb-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 1 - configs/khadas-edge-captain-rk3399_defconfig | 4 +++- configs/khadas-edge-rk3399_defconfig | 4 +++- configs/khadas-edge-v-rk3399_defconfig | 4 +++- configs/leez-rk3399_defconfig | 4 +++- configs/nanopc-t4-rk3399_defconfig | 4 +++- configs/nanopi-m4-2gb-rk3399_defconfig | 4 +++- configs/nanopi-m4-rk3399_defconfig | 4 +++- configs/nanopi-m4b-rk3399_defconfig | 4 +++- configs/nanopi-neo4-rk3399_defconfig | 4 +++- configs/nanopi-r4s-rk3399_defconfig | 3 ++- configs/orangepi-r1-plus-lts-rk3328_defconfig | 3 ++- configs/orangepi-r1-plus-rk3328_defconfig | 3 ++- configs/orangepi-rk3399_defconfig | 4 +++- configs/pinebook-pro-rk3399_defconfig | 1 - configs/pinephone-pro-rk3399_defconfig | 1 - configs/puma-rk3399_defconfig | 1 - configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-4c-plus-rk3399_defconfig | 2 +- configs/rock-4se-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rock-pi-n10-rk3399pro_defconfig | 2 +- configs/rock960-rk3399_defconfig | 3 ++- configs/rockpro64-rk3399_defconfig | 1 - drivers/usb/host/Kconfig | 1 - 31 files changed, 50 insertions(+), 31 deletions(-)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 1807e838223a..b5a5ae737e52 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -98,12 +98,12 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index 638beee2c6d3..20913d2cf0fe 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -99,12 +99,12 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/eaidk-610-rk3399_defconfig b/configs/eaidk-610-rk3399_defconfig index 77edbdbf9597..22ad98b95ad3 100644 --- a/configs/eaidk-610-rk3399_defconfig +++ b/configs/eaidk-610-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,8 +57,9 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 5740ffc38f6c..d6140527b752 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -66,7 +66,6 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index b4660a051dfd..b7c8e95b7b89 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -66,7 +66,6 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index ed06fe7846e6..8b6935d86730 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -61,11 +62,12 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index 9df945e6c0fe..070f0ea48c40 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -60,11 +61,12 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index e216c0e86f7f..5344ecd1f20f 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -61,11 +62,12 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index fa936609e9b1..76dd91911c7c 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 82e86ca07026..a722891fdd75 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -59,11 +60,12 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig index dd715517d5a1..e3bdbccccbec 100644 --- a/configs/nanopi-m4-2gb-rk3399_defconfig +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index 3da93db06da3..e51e51c8cf5c 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/nanopi-m4b-rk3399_defconfig b/configs/nanopi-m4b-rk3399_defconfig index 701dde15f3e2..ca57c7f81a51 100644 --- a/configs/nanopi-m4b-rk3399_defconfig +++ b/configs/nanopi-m4b-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 3f9d0340c81e..02e7f4e2ecb7 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index 4f4363cb0f90..cacaab14d21f 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -63,9 +63,10 @@ CONFIG_SYSINFO_SMBIOS=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig index 0ea45df33338..d3d9417509e9 100644 --- a/configs/orangepi-r1-plus-lts-rk3328_defconfig +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -71,6 +71,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_GIGADEVICE=y @@ -99,7 +100,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y @@ -107,6 +107,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig index e3d7f0b8aeb0..9356e87132e7 100644 --- a/configs/orangepi-r1-plus-rk3328_defconfig +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -71,6 +71,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_GIGADEVICE=y @@ -99,7 +100,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y @@ -107,6 +107,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index ba6d91e877d6..27add8a29b92 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -56,9 +57,10 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index ae3211bbe9c4..de357415fbe4 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -96,7 +96,6 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/pinephone-pro-rk3399_defconfig b/configs/pinephone-pro-rk3399_defconfig index 11243bc5c193..d08224fe536b 100644 --- a/configs/pinephone-pro-rk3399_defconfig +++ b/configs/pinephone-pro-rk3399_defconfig @@ -85,7 +85,6 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index b632fa3dcf34..c2aa02ec74bd 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -97,7 +97,6 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 06d97c3e1a2d..f4b2e394cb35 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -80,8 +80,8 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index c53e8622431e..ff4c7b55726e 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -81,8 +81,8 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/rock-4c-plus-rk3399_defconfig b/configs/rock-4c-plus-rk3399_defconfig index 3028a86705ca..2e730f029b43 100644 --- a/configs/rock-4c-plus-rk3399_defconfig +++ b/configs/rock-4c-plus-rk3399_defconfig @@ -73,8 +73,8 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/rock-4se-rk3399_defconfig b/configs/rock-4se-rk3399_defconfig index 9abe8bf85354..083fc80e5471 100644 --- a/configs/rock-4se-rk3399_defconfig +++ b/configs/rock-4se-rk3399_defconfig @@ -75,8 +75,8 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 84e0dcf02827..fedf0dfd7b77 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -76,8 +76,8 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index 5c9fb14787d8..9e8664bfa6b4 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -73,8 +73,8 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 1978fd525b8f..3bae2a1e9c3a 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -67,8 +67,8 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index fee10c471946..f74864b6eb90 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -70,12 +71,12 @@ CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 4cd6b76665bd..44171aac06a6 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -93,7 +93,6 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 1a883babf4c2..85dcbac3aec5 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -39,7 +39,6 @@ config USB_XHCI_DWC3 config USB_XHCI_DWC3_OF_SIMPLE bool "DesignWare USB3 DRD Generic OF Simple Glue Layer" depends on DM_USB - default y if ARCH_ROCKCHIP default y if DRA7XX help Support USB2/3 functionality in simple SoC integrations with
Why not add 'default y if ROCKCHIP' into the Kconfig instead ? This will have the same effect, without requiring such massive modification of config files.
(seems some of the CC domains are not even working, so CC list clipped)
Not fully sure what you mean by this and how that would reduce number of affected defconfig-files. The USB_XHCI_DWC3 should still be removed from these defconfig-files or wrong driver could be used by these boards.
Touching the defconfig-files help notify board maintainers that changes are happening to their boards.
There will also be a separate patch that remove the rockchip,rk3399-dwc3 compatible from the dwc3-of-simple driver to finalize this transition to use dwc3-generic driver for affected rockchip boards.
Regards, Jonas
It wasn't clear to me you're switching one driver to another, thanks for clarification.
" Also enable DM_USB_GADGET for any board that enable USB_DWC3_GADGET. "
This you can do in Kconfig file, something like: select DM_USB_GADGET if USB_DWC3_GADGET && <rockchip>
Hi Jonas, Marek,
This patch including remove old Kconfig option and add new option, just move to
enable generic driver option in Kconfig file instead of defconfig file.
Not all the rockchip socs have usb dwc3 controller, so make this change in SoC level will be better.
Thanks,
- Kever
On 2023-11-09 04:29, Kever Yang wrote:
Hi Jonas, Marek,
I will try to send out a v2 of this later this weekend.
Regards, Jonas
Thanks,
- Kever
Remove board_usb_init() and dm_usb_gadget_handle_interrupts() functions related to dwc3, they use e.g. a hard-coded reg address for RK3399 and are obsolete with use of DM_USB_GADGET.
Use of DM_USB_GADGET, USB_DWC3_GENERIC and USB_DWC3_GADGET have replaced same feature provided by the removed functions on RK3399 boards.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/mach-rockchip/board.c | 24 ------------------------ 1 file changed, 24 deletions(-)
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index 57f08e0be0e9..3496839c879c 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -287,30 +287,6 @@ int board_usb_cleanup(int index, enum usb_init_type init) } #endif /* CONFIG_USB_GADGET_DWC2_OTG */
-#if defined(CONFIG_USB_DWC3_GADGET) && !defined(CONFIG_DM_USB_GADGET) -#include <dwc3-uboot.h> - -static struct dwc3_device dwc3_device_data = { - .maximum_speed = USB_SPEED_HIGH, - .base = 0xfe800000, - .dr_mode = USB_DR_MODE_PERIPHERAL, - .index = 0, - .dis_u2_susphy_quirk = 1, - .hsphy_mode = USBPHY_INTERFACE_MODE_UTMIW, -}; - -int dm_usb_gadget_handle_interrupts(struct udevice *dev) -{ - dwc3_uboot_handle_interrupt(dev); - return 0; -} - -int board_usb_init(int index, enum usb_init_type init) -{ - return dwc3_uboot_init(&dwc3_device_data); -} -#endif /* CONFIG_USB_DWC3_GADGET */ - #endif /* CONFIG_USB_GADGET */
#if IS_ENABLED(CONFIG_FASTBOOT)
Jonas Karlman
Kever Yang
