Fwd: New Defects reported by Coverity Scan for Das U-Boot
Here's the current set of new issues since I last ran Coverity.
---------- Forwarded message --------- From: scan-admin@coverity.com Date: Thu, Jan 18, 2024 at 9:20 AM Subject: New Defects reported by Coverity Scan for Das U-Boot To: tom.rini@gmail.com
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
2 new defect(s) introduced to Das U-Boot found with Coverity Scan. 16 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 2 of 2 defect(s)
** CID 478334: Memory - corruptions (OVERRUN)
________________________________________________________________________________________________________ *** CID 478334: Memory - corruptions (OVERRUN) /cmd/eficonfig.c: 534 in eficonfig_create_device_path() 528 p += fp_size; 529 *((struct efi_device_path *)p) = END; 530 531 dp = efi_dp_shorten(dp_volume); 532 if (!dp) 533 dp = dp_volume;
CID 478334: Memory - corruptions (OVERRUN) Overrunning struct type efi_device_path of 4 bytes by passing it to a function which accesses it at byte offset 5 using argument "fp->dp.length" (which evaluates to 6).
534 dp = efi_dp_concat(dp, &fp->dp, false); 535 free(buf); 536 537 return dp; 538 } 539
** CID 478333: Error handling issues (CHECKED_RETURN) /lib/efi_loader/efi_firmware.c: 413 in efi_firmware_set_fmp_state_var()
________________________________________________________________________________________________________ *** CID 478333: Error handling issues (CHECKED_RETURN) /lib/efi_loader/efi_firmware.c: 413 in efi_firmware_set_fmp_state_var() 407 /* 408 * GetVariable may fail, EFI_NOT_FOUND is returned if FmpState 409 * variable has not been set yet. 410 * Ignore the error here since the correct FmpState variable 411 * is set later. 412 */
CID 478333: Error handling issues (CHECKED_RETURN) Calling "efi_get_variable_int" without checking return value (as is done elsewhere 29 out of 33 times).
413 efi_get_variable_int(varname, image_type_id, NULL, &size, var_state, 414 NULL); 415 416 /* 417 * Only the fw_version is set here. 418 * lowest_supported_version in FmpState variable is ignored since
